  4. Test Adapter Material Design Widgets v0.2.x
visadapatervisualizationmaterialwidget
902 Beiträge 77 Kommentatoren 343.4k Aufrufe 79 Beobachtet
  • ScroungerS Scrounger
    @Buddinski88 sagte in Test Adapter Material Design Widgets v0.2.x:
    Ich vermute das dir viele sehr dankbar wären, wenn es zu den zwei Themen eine Lösung geben würde.
    Hier das Beispielskript:
    on({ id: 'ical.0.data.table', change: 'any' }, function (obj) {
        let icalObj = obj.state.val;
        let calList = [];
        for (var i = 0; i <= icalObj.length - 1; i++) {
            let item = icalObj[i];
            // Kalendername extrahieren
            let kalenderName = item._class.split(' ')[0].replace('ical_', '');
            // Objekt für Tabelle erzeugen
            calList.push({
                farbe: `<div style="background: ${getMyKalenderFarbe(kalenderName)}; width: 3px; height: 20px"></div>`,
                zeit: item.date,
                termin: item.event,
                kalender: kalenderName,
                timestamp: Date.parse(item._date)
        function getMyKalenderFarbe(kalenderName) {
            // Farben über die Kalendernamen zuordnen, Kalendername wie in ical eingestellt verwenden
            if (kalenderName === 'calendar1') {
                return 'red';
            } else if (kalenderName === 'calendar2') {
                return '#44739e'
        // Hier den Ziel Datenpunkt eingeben, der als Objekt ID im Widget verwendet werden soll
        setState('0_userdata.0.ical', JSON.stringify(calList), true);
    Widget dazu:
    [{"tpl":"tplVis-materialdesign-Table","data":{"oid":"0_userdata.0.ical","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","countCols":"3","tableLayout":"standard","showHeader":"true","headerTextSize":"headline6","showColumn0":"true","colType0":"text","textAlign0":"left","showColumn1":"true","colType1":"text","textAlign1":"left","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"showColumn2":"true","colType2":"text","textAlign2":"left","showColumn3":"true","colType3":"text","textAlign3":"left","label0":" ","label1":"Zeit","label2":"Termin","label3":"Kalender","columnWidth0":"0","sortKey1":"timestamp"},"style":{"left":"163px","top":"67px","width":"692px","height":"341px"},"widgetSet":"materialdesign"}]
    Und so sieht das dann aus:
    Buddinski88
    schrieb am zuletzt editiert von Buddinski88
    #585
    @Scrounger, auch hier noch mal einen großen Dank an dich! (Spende ging raus) :-)
    Ich habe die Abfrage des Kalenders für dessen Farbe noch etwas erweitert, damit mehrere/beliebig viele Kalender abgefragt werden können.
    Hier mein Code:
        let calList = [];
            calList.push({
                zeit: item.date,
                termin: item.event,
            switch (kalenderName){
                case 'Abfall':
                    return '795548';
                    break;
                case 'Familie':
                    return '#0b8044';
                    break;
                case 'Familie Arbeit':
                    return '#f6c226';
                    break;
                case 'Geburtstage':
                    return '#d50000';
                    break;
                case 'Aquascape':
                    return '#1baade';
                    break;
                default:
                    return '#000000'
                    break;
        setState('javascript.0.variables.vis.ical.convertedData', JSON.stringify(calList), true);
      darkbrain85
      #586
      Hi zusammen!
      Ich würde gerne meine Flot Diagramme alle auf Line History Chart umstellen.
      Für meine PV Anlage habe ich ein Diagramm in dem mehrere Datensätze übereinander liegen.
      Dort benötige ich zwar eine Farbige Füllung, aber keine Linie . Wenn die Liniendicke auf 0 ist wird immer noch eine ganz dünne Linie angezeigt. Diese ist dann leider auch auf den darüber liegenden Flächen zu sehen.
      Hier mal ein vergrößerter Screenshot davon:
      Wie kann ich diese rote Linie in diesem Fall ausblenden? Schon wäre, wenn bei Liniendicke "0" einfach die Linie ganz verschwinden würde.
      Anke für Eure Hilfe!
      ScroungerS 1 Antwort Letzte Antwort
      • D darkbrain85
        Hi zusammen!
        ScroungerS Offline
        ScroungerS Offline
        Scrounger
        #587
        @darkbrain85
        Versuch mal die Linienfarbe / Datenfarbe auf transparentzu setzen.
          @darkbrain85
          darkbrain85
          #588
          @Scrounger
          Ja klar, das ich da nicht selber drauf gekommen bin... Danke für den Tip!
          Eine Sache noch:
          Lässt sich der Abstand von einer unten angeordneten Legende zur X-Achse verkleinern? Da geht IMHO viel Platz verloren...
          • D darkbrain85
            @Scrounger
            Eine Sache noch:
            ScroungerS Offline
            ScroungerS Offline
            Scrounger
            #589
            @darkbrain85 sagte in Test Adapter Material Design Widgets v0.2.x:
            Habs eingebaut, aktullen master testen
              darkbrain85
              schrieb am zuletzt editiert von darkbrain85
              #590
              @Scrounger
              Danke!
              Das funktioniert für mich erstmal ganz gut. Je kleiner der padding Wert ist, desto mehr rutschen die Legendeneinträge aneinander. Das kann man aber mit Leerzeichen korrigieren. In so fern erstmal funktional, wenn auch noch nicht 100% sauber.
              Edit:
              Da fällt mir noch was auf: Mache ich drei Leerzeichen am Ende des Legendentextes, wird direkt hinter dem letzten Buchstaben ein Punkt (.) eingefügt.
              Edit2: Kann man die Angabe der Uhrzeit auf der X-Achse noch schöner bekommen?
              Edit3: Es wäre gut, wenn für den Tooltip dann auch die Füllfarbe genommen wird, wenn die Linienfarbe "transparent" ist.
              • D darkbrain85
                @Scrounger
                Danke!
                Edit:
                ScroungerS Offline
                ScroungerS Offline
                Scrounger
                #591
                Besser geht es leider nicht, da die chartjs api nur padding zur verfügung stellt und nicht explizit padding-left, padding-right, etc. Da die charts gerendert werden, kann ich hier nix machen.
                Ich sehe weder in dem Screenshot einen . noch kann ich das bei mir reproduzieren. Leerzeichen wird als leerzeichen ausgegeben.
                Ja steht in der doku!
                Geht nicht, api nimmt immer die Farbe von der Linie.
                Dann würde ich dir empfehlen, für Linien und Füllfarbe die gleiche zu nehmen und Liniendicke auf 0 zu setzen.
                Oder blende in im Tooltip das farbfeld aus.
                • ScroungerS Offline
                  ScroungerS Offline
                  Scrounger
                  #592
                  Alerts Widget ist fertig:
                  Damit kann man sich z.B. Nachrichten direkt in der VIS anzeigen, z.B. so wie das mit dem Pushover adapter möglich ist, eben nur direkt in der VIS.
                  Wie man das Widget nutzen kann steht in der Doku https://github.com/Scrounger/ioBroker.vis-materialdesign#alerts
                  Oder schaut Euch das online beispiel an: https://github.com/Scrounger/ioBroker.vis-materialdesign#online-example-project
                  Um das Widget nutzen zu können, müsst ihr euch die Objekte mit javascript zusammenbauen.
                  Archimedeus AA I S D 4 Antworten Letzte Antwort
                    dos1973
                    #593
                    Wirklich Coole Sache! Top
                    Scheitert bei mir allerdings am Java.
                    Hoffe auf Beispiele
                      Archimedeus AA Offline
                      Archimedeus A
                      #594
                      @Scrounger
                      Hallo, was du machst ist saucool, aber murkse noch mit den Anfängen herum.
                      Fragen:
                      • Wo kann man anschauen, wie die Listen gemacht sind (die in der Doku abgebildet sind). In der Life-view sind sie nicht
                      • Gibt es eine einfache Möglichkeit, List-Items abhängig vom Status anzeigen zu lassen oder nicht?
                      • Kann man eine View in Masonry views als Navi-Button definieren?
                      Warum will ich das? Ich möchte eine Statusübersicht bauen, wo auf den Karten drauf steht wieviel Lampen an sind (oder Heizkörper etc). Wenn man drauftappt soll man die Liste der Lampen bekommen mit Schaltern, die an sind.
                      Eine Karte mit Navi bekomme ich hin, indem ich in der View einen unsichtbaren Button drüberlege. Ist aber unpraktisch beim Bauen.
                      Fernziel: Maximale Nutzervereinfachung.
                      Danke im Voraus. Ich nehme auch kommentarlose Links :-)
                      Archi
                      • Archimedeus AA Archimedeus A
                        @Scrounger
                        Fragen:
                        Archi
                        ScroungerS Offline
                        ScroungerS Offline
                        Scrounger
                        schrieb am zuletzt editiert von Scrounger
                        #595
                        @Archimedeus-A sagte in Test Adapter Material Design Widgets v0.2.x:
                        Ja ist noch nicht alles in der Lifeview abgebildet.
                        Wie die List funktioniert sieht man in der Doku - Screenshot. Am besten mal damit rumspielen, dann bekommst den dreh sicher raus.
                        In den Threads hier gibt es auch das ein oder andere Beispiel zum List Widget.
                        Ja das kannst damit machen. Für Lichter nimmst am besten type switch.
                        Klar, leg über die gesamte Card z.B. einen Navbutton mit Layout text. Dem weißt dann die View zu, wo du die lichter mit steuerst.
                        Sorry aber im Detail antworten fehlt mir echt die Zeit.
                        Ließ dich hier im Forum ein, probier ein bissle rum und wenn du an nem speziellen Fall hängst, dann frag im Forum nach.
                        Archimedeus AA 1 Antwort Letzte Antwort
                          I Online
                          I Online
                          intruder7
                          schrieb am zuletzt editiert von intruder7
                          #596
                          @Scrounger Auf die Schnelle getestet:
                          Fehler bisher... Sollte der Text länger als die Breite sein, schreibt er ihn über das Widget hinaus und der Bestätigungsbutton ist auch weg
                          Alles was an Buttons hinter dem Widget liegt ist nicht mehr bedienbar. Auch wenn keine Alerts angezeigt werden.
                            Archimedeus A
                            #597
                            @Scrounger Danke, ich fummel mich durch!
                              skokarl
                              #598
                              @Scrounger sagte in Test Adapter Material Design Widgets v0.2.x:
                              Das finde ich ja mal richtig spannend.
                              Falls jemand hier mal ein Javascript Beispiel veröffentlichen möchte.... 👏
                              I 1 Antwort Letzte Antwort
                                D Online
                                D Online
                                darkiop
                                schrieb am zuletzt editiert von darkiop
                                #599
                                Hab das ganze mal versucht über Blockly zu erstellen (so baue ich mir auch die json fürs Tabellen-Widget zusammen).
                                Allerdings ist das Ergebnis hier ein Array, kein json - Fehler in Blockly?
                                [["text","we have a new message"],["text","we have a new message"],["text","we have a new message"],["text","we have a new message"],["text","we have a new message"],["text","we have a new message"]]
                                Edit: Dein Beispiel für den ical Adapter hilft hier weiter:
                                https://forum.iobroker.net/topic/26925/test-adapter-material-design-widgets-v0-2-x/582
                                Kann es sein, das es für Blockly push() nicht gibt?
                                Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
                                • S skokarl
                                  I Online
                                  I Online
                                  intruder7
                                  #600
                                  @skokarl
                                  Hier mal ganz schnell mit dem Telegram Adapter getestet. Alles was ich an mein zuhause schicke wird dann angezeigt.
                                  var instanz = 'javascript.0'; instanz = instanz + '.';     // Instanz fuer die Datenpunkte definieren
                                  var pfad = 'VIS.';
                                  var AlertText = instanz + pfad + "Alerts.AlertText";
                                  createState(AlertText, "", { type: 'string', name: '', read: true, write: true });
                                  let Alert = [];
                                  on({id: 'telegram.0.communicate.request', change: 'any'}, function (obj) {
                                      var stateval = getState('telegram.0.communicate.request').val;              // Statevalue in Variable schreiben
                                      var benutzer = stateval.substring(1,stateval.indexOf("]"));                 // Benutzer aus Statevalue extrahieren
                                      var befehl = stateval.substring(stateval.indexOf("]")+1,stateval.length);   // Befehl/Text aus Statevalue extrahieren
                                          Alert.push({
                                              text: befehl,
                                              backgroundColor: '',
                                              borderColor: 'darkred',
                                              icon: 'message-alert-outline',
                                              iconColor: 'darkred',
                                              fontColor: 'blue'
                                   setState(AlertText, JSON.stringify(Alert), true);
                                   Alert = []
                                  • I intruder7
                                    @skokarl
                                    var pfad = 'VIS.';
                                    let Alert = [];
                                            Alert.push({
                                                text: befehl,
                                                fontColor: 'blue'
                                     Alert = []
                                    skokarl
                                    #601
                                    @intruder7
                                    super, besten Dank.
                                    Hab ich mal etwas damit ich es verstehen kann.
                                      Mr.Oz
                                      #602
                                      seit der Version 0.2.32 / 0.2.40 funktioniert das vibrieren auf Mobilgeräten nicht mehr. Muss man da noch was beachten/umstellen?
                                        ScroungerS Offline
                                        Scrounger
                                        #603
                                        Folgendes Skript könnt ihr euch als gobales Skript speichern
                                        var materialDesignWidgets = {};
                                        materialDesignWidgets.sendTo = function (id, text, backgroundColor = '', borderColor = '', icon = '', iconColor = '', fontColor = '') {
                                            let json = getState(id).val;
                                            json = JSON.parse(json);
                                            json.push(
                                                    text: text,
                                                    backgroundColor: backgroundColor,
                                                    borderColor: borderColor,
                                                    icon: icon,
                                                    iconColor: iconColor,
                                                    fontColor: fontColor
                                            setState(id, JSON.stringify(json), true);
                                        und dann in anderen skripten mit
                                        materialDesignWidgets.sendTo('0_userdata.0.materialdesignwidgets.alerts.json', 'neuer Text', 'red');
                                        neue narichten schicken.
                                        @Mr-Oz sagte in Test Adapter Material Design Widgets v0.2.x:
                                        Kann ich nicht bestätigen. Welcher Browser? Welches Widget? Was steht in der console des browsers?
                                        @intruder7 sagte in Test Adapter Material Design Widgets v0.2.x:
                                        Hab ich behoben. Zeilenumbruch funktioniert aber nur nach wörtern!
                                        sigi234S I M 3 Antworten Letzte Antwort
                                              json.push(
                                                      text: text,
                                                      icon: icon,
                                          sigi234S Online
                                          sigi234S Online
                                          #604
                                          Muss der DP angelegt werden?
