  4. JavaScript
  5. Strom Geräte als HTML Tabelle - Vis - Iqontrol
javascript
289 Beiträge 13 Kommentatoren 67.4k Aufrufe 11 Beobachtet
    @liv-in-sky sagte in Strom Geräte als HTML Tabelle - Vis - Iqontrol:
    für input bin ich dankbar
    Sehe diesen Thread erst jetzt.
    Wenn ich am pc bin nerve ich euch gerne
    Homematic Messteckdose (Telekom-Version)
     "_id": "hm-rpc.0.LTK0124795",
     "type": "device",
     "common": {
       "name": "Strom_Arcade_Games",
       "icon": "/icons/93_hm-es-pmsw1-pl_thumb.png"
     "native": {
       "ADDRESS": "LTK0124795",
       "AVAILABLE_FIRMWARE": "2.5",
       "CHILDREN": [
         "LTK0124795:0",
         "LTK0124795:1",
         "LTK0124795:2",
         "LTK0124795:3",
         "LTK0124795:4",
         "LTK0124795:5",
         "LTK0124795:6"
       "FIRMWARE": "2.5",
       "FLAGS": 1,
       "INTERFACE": "MEQ1888457",
       "PARAMSETS": [
         "MASTER"
       "PARENT": "",
       "RF_ADDRESS": 3291348,
       "ROAMING": 0,
       "RX_MODE": 1,
       "TYPE": "HM-ES-PMSw1-Pl",
       "UPDATABLE": 1,
       "VERSION": 16
     "from": "system.adapter.hm-rega.0",
     "user": "system.user.admin",
     "ts": 1577621401282,
     "acl": {
       "object": 1636,
       "owner": "system.user.admin",
    Ich habe dann noch einen Hutschienen-Aktor, den muss ich allerdings erst mal irgendwo anklemmen.
    Mache ich ASAP
    Done!
     "ts": 1579341156065,
     "common": {
       "name": "Strom_Buero",
       "icon": "/icons/110_hm-es-pmsw1-dr_thump.png"
     "native": {
       "ADDRESS": "NEQ0116043",
       "FIRMWARE": "2.5",
       "INTERFACE": "KEQ1065589",
       "PARENT": "",
       "TYPE": "HM-ES-PMSw1-DR",
       "FLAGS": 1,
       "RF_ADDRESS": 4501779,
       "ROAMING": 0,
       "RX_MODE": 1,
       "UPDATABLE": 1,
       "VERSION": 16,
       "CHILDREN": [
         "NEQ0116043:0",
         "NEQ0116043:1",
         "NEQ0116043:2",
         "NEQ0116043:3",
         "NEQ0116043:4",
         "NEQ0116043:5",
         "NEQ0116043:6"
       "PARAMSETS": [
         "MASTER"
     "acl": {
       "object": 1636,
     "_id": "hm-rpc.0.NEQ0116043",
     "type": "device"
    Dann mal viel Spaß
      Done!
       "common": {
       "native": {
         "FIRMWARE": "2.5",
         "PARENT": "",
         "FLAGS": 1,
         "ROAMING": 0,
         "RX_MODE": 1,
         "UPDATABLE": 1,
         "VERSION": 16,
         "CHILDREN": [
           "NEQ0116043:0",
           "NEQ0116043:1",
           "NEQ0116043:2",
           "NEQ0116043:3",
           "NEQ0116043:4",
           "NEQ0116043:5",
           "NEQ0116043:6"
         "PARAMSETS": [
           "MASTER"
       "acl": {
         "object": 1636,
       "type": "device"
      Dann mal viel Spaß
      liv-in-skyL
      liv-in-skyL
      @Homoran
      danke werd ich haben
      • liv-in-skyL liv-in-sky
        moin,
        wollte heute mit dem script beginnen - falls noch jmd wünsche wegen der spalten anordnung hat - wäre jetzt ein guter zeitpunkt
        sigi234S
        sigi234S
        moin,
        Eventuell eine Summe der Werte?
        Ich glaube du träumst schon sicher nur mehr von Tabellen. 😀
        • sigi234S sigi234
          moin,
          liv-in-skyL
          liv-in-skyL
          @sigi234
          um ehrlich zu sein - mir fehlt gerade der überblick -die datenpunkte sind so unterschiedlich - die selktoren auswahl ist auch nicht klar - die tabellen selbst sind nicht das problem
          werte die bei sonoff da sind - müßten für manche devices erstmal berechnet werden ... - ich sortiere noch
          was meinst du mit summe der werte ?
          sigi234S 2 Antworten Letzte Antwort
            @sigi234
            sigi234S
            sigi234S
            Wieviel Verbrauch(Watt) haben alle Geräte zusammen.
              @sigi234
              sigi234S
              sigi234S
              Ja, das Problem ist das ja nicht alle Geräte eine Leistungsmessung haben.
              HS100 - Ohne
              HS110 - Mit
              • sigi234S sigi234
                liv-in-skyL
                liv-in-skyL
                @sigi234 Ansicht eine gute Idee nur welche: gesamt gesamt oder täglich gesamt oder monatl gesamt
                Und diese Werte existieren bei vielen eurer geposteten Beispiel-dp garnicht
                  sigi234S
                  sigi234S
                  Ja, genau deswegen.
                  Aber da kommen wir vom nur Tabelle Thema ab.Dafür gibt es ja die entsprechenden Adapter.
                  • sigi234S sigi234
                    Ja, genau deswegen.
                    liv-in-skyL
                    liv-in-skyL
                    @sigi234 das bedeutet ich musste für alle ohne Leistung Messung eine kleine Datenbank anlegen und diese pflegen -tägliche Werte addieren um Mitternacht, monatliche Werte berechnen ....
                    Ich denke das kann ich nicht bewerkstelligen -was anderes wäre es wenn der Tabellen Nutzer einen solchen dp zur verfügung stellt - mit diesen werten - und die im script abgerufen werden
                      sigi234S
                      sigi234S
                      Lass es , ich mache das mit Blockly ZB:
                      on({id: new RegExp('hs100\\.0\\.192_168_178_23\\.totalMonthNow' + "|" + 'hs100\\.0\\.192_168_178_43\\.totalMonthNow'), change: "ne"}, function (obj) {
                          setState("javascript.0.Eigene_Datenpunkte.Summe_Bezug"/*Summe_Bezug*/, (getState("hs100.0.192_168_178_23.totalMonthNow").val + getState("hs100.0.192_168_178_43.totalMonthNow").val), true);
                      • sigi234S sigi234
                        HS100 - Ohne
                        HS110 - Mit
                        @sigi234 sagte in Strom Geräte als HTML Tabelle - Vis - Iqontrol:
                        ich hatte es so verstanden, dass nur Geräte mit Leistungsmessung erfasst werden sollen.
                        Alle Aktoren ob sie an oder aus siend ist IMHO zuviel
                        ? sigi234S 2 Antworten Letzte Antwort
                          @Homoran die Meinung Teile ich auch. Sonst wirkt es überladen und man verliert den fokus und sich in Details
                            sigi234S
                            sigi234S
                            @Homoran sagte in Strom Geräte als HTML Tabelle - Vis - Iqontrol:
                            Ich nicht, ein Status in der Tabelle ob ein Gerät eingeschaltet ist wäre schon gut.
                            ZB.:
                            Steckdose Wohnzimmer: ON
                            • sigi234S
                              sigi234S
                              @liv-in-sky
                              Shelly`s auch mitnehmen?
                              https://forum.iobroker.net/topic/24219/shelly-1-pm-leistungsmessung
                              • sigi234S sigi234
                                ZB.:
                                Das wird bei 100 Aktoren aber schon heftig
                                  sigi234S
                                  sigi234S
                                  Jupp, vielleicht als Option?
                                  • sigi234S
                                    sigi234S
                                    Hm, ich denke bei den vielen Tabellen was @liv-in-sky macht wäre da ein Tabellen-Adapter möglich/sinnvoll ?
                                    Nur mal so als Kopfkino. 😐
                                    • NegaleinN
                                      NegaleinN
                                      Negalein
                                      hab auch noch ein Objekt
                                      Xiaomi Mija Smart Plug
                                      mihome.0.devices.plug_158d0001f24aad.json
                                      ° Fixer ---> iob fix
                                      • sigi234S sigi234
                                        @liv-in-sky
                                        M
                                        M
                                        MartyBr
                                        @sigi234
                                        Ich habe mehrere Shellys im Einsatz:
                                          "from": "system.adapter.shelly.0",
                                          "ts": 1578827875860,
                                          "common": {
                                            "name": "Switch",
                                            "type": "boolean",
                                            "role": "switch",
                                            "read": true,
                                            "write": true,
                                            "def": false,
                                            "custom": {
                                              "iot.0": {
                                                "smartName": {
                                                  "de": "Shelly1"
                                          "native": {},
                                          "acl": {
                                            "object": 1636,
                                            "state": 1636
                                          "_id": "shelly.0.SHPLG-S#04096C#1.Relay0.Switch",
                                          "type": "state"
                                        Martin
                                        Homematic und Homematic IP
                                        • liv-in-skyL
                                          liv-in-skyL
                                          was wäre damit
                                          ich habe nur den pow als messung
                                          fehlt was - wäre doof - muss sonst neue tabelle erstellen - aber lieber jetzt als später
                                          84.2k
