  4. BackItUp - Fehler in Datenpunkt History
Geplant Angeheftet Gesperrt Verschoben Gelöst Error/Bug
backitup
47 Beiträge 5 Kommentatoren 5.9k Aufrufe 4 Beobachtet
  • simatecS simatec
    Was steht im Objekt "output.line" nach dem abgeschlossenen Backup?
    horos73H Offline
    horos73H Offline
    horos73
    @simatec
    [DEBUG] [history] start with {"type":"creator","time":"06:00","debugging":true,"everyXDays":"3","nameSuffix":"BackitUp_Backup","deleteBackupAfter":0,
    "ftp":{"enabled":true,"type":"storage","source":null,"host":"IP-Adresse-meines-NAS","debugging":true,"deleteOldBackup":false,"ownDir":true,"bkpType":"Minimal",
    "dir":"ioBrokerBackups/StandardBU","dirMinimal":"ioBrokerBackups/StandardBU","user":"USERNAME","pass":"****","port":"85"},"dir":"/opt/iobroker",
    "redis":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"IP-Adresse-meines-NAS","debugging":true,"deleteOldBackup":false,
    "ownDir":true,"bkpType":"Minimal","dir":"ioBrokerBackups/StandardBU","dirMinimal":"ioBrokerBackups/StandardBU","user":"USERNAME","pass":"****","port":"85"},
    "cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":null,"mount":"IP-Adresse-meines-NAS","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup",
    "wakeOnLAN":false,"macAd":"XYZ","wolTime":"25","smb":"vers=1.0","sudo":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/volume1/ioBrokerBackups",
    "dirMinimal":"volume1/USERNAME/ioBrokerBackups","user":"USERNAME","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,
    "accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"googledrive":{"enabled":false,"type":"storage","source":null,
    "debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/var/lib/redis/dump.rdb"},
    "historyDB":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"IP-Adresse-meines-NAS","debugging":true,"deleteOldBackup":false,"ownDir":true,
    "bkpType":"Minimal","dir":"ioBrokerBackups/StandardBU","dirMinimal":"ioBrokerBackups/StandardBU","user":"USERNAME","pass":"****","port":"85"},"cifs":{"enabled":false,"mountType":"NFS",
    "type":"storage","source":null,"mount":"IP-Adresse-meines-NAS","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"XYZ",
    "wolTime":"25","smb":"vers=1.0","sudo":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/volume1/ioBrokerBackups","dirMinimal":"volume1/USERNAME/ioBrokerBackups",
    "user":"USERNAME","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,
    "bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****",
    "ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"media/usb/history"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage",
    "source":null,"host":"IP-Adresse-meines-NAS","debugging":true,"deleteOldBackup":false,"ownDir":true,"bkpType":"Minimal","dir":"ioBrokerBackups/StandardBU","dirMinimal":"ioBrokerBackups/StandardBU",
    "user":"USERNAME","pass":"****","port":"85"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":null,"mount":"IP-Adresse-meines-NAS","debugging":true,
    "fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"XYZ","wolTime":"25","smb":"vers=1.0","sudo":false,"deleteOldBackup":false,"ownDir":false,
    "bkpType":"Minimal","dir":"/volume1/ioBrokerBackups","dirMinimal":"volume1/USERNAME/ioBrokerBackups","user":"USERNAME","pass":"****"},"dropbox":{"enabled":false,"type":"storage",
    "source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},
    "googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir",
    "dirMinimal":"/backupDir/minimal"},"path":"/opt/iobroker/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"15. Januar 2020 um 12:23 Uhr"},
    "telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"MeinName",
    "onlyError":true,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"email.0","NoticeType":"longEmailNotice",
    "emailReceiver":"Email@Adresse.ABC","emailSender":"Email@Adresse.ABC","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram",
    "type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":true,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
    Ich hoffe, ich habe alle sensiblen Daten erwischt ;-)
    Danke, simatec, dass Du den Thread verfolgst und Dich meldest!!! 👍
    • simatecS simatec
      Coffeelover
      @simatec Derzeit steht bei mir:
      [ERROR] [iobroker] - (node:22070) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
      • horos73H horos73
        @simatec
        simatecS Offline
        simatecS Offline
        simatec
        @horos73
        Nein ich meine das Objekt "line" im Ordner "Output"
        • Besuche meine Github Seite
        • HowTo Restore ioBroker
        horos73H 1 Antwort Letzte Antwort
        • simatecS simatec
          @horos73
          horos73H Offline
          horos73H Offline
          horos73
          @simatec Hab Dir vorhin das kopiert, was hinten bei "Wert" steht.
          Hier der Screenshot:
          • C Offline
            Coffeelover
            @simatec Meinen Eintrag siehst du oben. Aber bei mir läuft das Backup auch nicht durch. Folgendes steht im Log:
            backitup.0	2020-01-15 13:10:42.547	info	(2577) [iobroker] backup was activated at 02:10 every 1 day(s)
            backitup.0	2020-01-15 13:10:42.490	info	(2577) starting. Version 1.3.6 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.17.0
            backitup.0	2020-01-15 13:10:35.686	info	(2230) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            backitup.0	2020-01-15 13:10:35.685	info	(2230) terminating
            backitup.0	2020-01-15 13:10:35.183	info	(2230) Got terminate signal TERMINATE_YOURSELF
            • C Coffeelover
              simatecS Offline
              simatecS Offline
              simatec
              @Coffeelover sagte in BackItUp - Fehler in Datenpunkt History:
              Ich sehe keinen Eintrag des Objektes "line" von dir.
              Der Log sagt nix aus. Stelle die Instanz mal auf debug (siehe meiner Signatur)
              • simatecS simatec
                horos73H Offline
                horos73H Offline
                horos73
                schrieb am zuletzt editiert von horos73
                @simatec Bei mir sieht das Log (debug) aktuell so aus:
                backitup.0	2020-01-15 12:23:45.008	debug	[iobroker] exec: done
                backitup.0	2020-01-15 12:23:45.007	debug	[iobroker/history] backitup.0.history.html
                backitup.0	2020-01-15 12:23:44.999	debug	[iobroker/telegram] done
                backitup.0	2020-01-15 12:23:44.999	debug	[iobroker/telegram] [iobroker] used Telegram-Instance: telegram.0
                backitup.0	2020-01-15 12:23:44.995	debug	[iobroker/clean] done
                backitup.0	2020-01-15 12:23:44.993	debug	[iobroker/ftp] done
                backitup.0	2020-01-15 12:23:44.812	debug	[iobroker/ftp] Send iobroker_2020_01_15-12_23_38_BackitUp_Backup_backupiobroker.tar.gz
                backitup.0	2020-01-15 12:23:44.812	debug	[iobroker/ftp] FTP connected.
                backitup.0	2020-01-15 12:23:44.464	debug	[iobroker/iobroker] done
                backitup.0	2020-01-15 12:23:44.449	debug	[iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2020_01_15-12_23_38_BackitUp_Backup_backupiobroker.tar.gz
                backitup.0	2020-01-15 12:23:35.745	debug	sendTo "getTelegramUser" to system.adapter.admin.0 from system.adapter.backitup.0: {"12345678":"MeinName"}
                backitup.0	2020-01-15 12:23:03.713	debug	system.adapter.admin.0: logging true
                Sieht - für mich - ja OK aus..
                • horos73H horos73
                  simatecS Offline
                  simatecS Offline
                  simatec
                  @horos73 sagte in BackItUp - Fehler in Datenpunkt History:
                  Da wird das Backup nicht sauber beendet.
                  Das ist ein Eintrag der history.
                  Kannst du mal den Inhalt des Objektes posten.
                  • simatecS simatec
                    horos73H Offline
                    horos73H Offline
                    horos73
                    @simatec der Output war der, den ich Dir vorhin gepostet habe (drunter schrieb ich "hoffe ich habe alle sensiblen .. erwischt". Oder meinst Du: Objekt bearbeiten/RAW ?:
                      "common": {
                        "name": "Used for debug outputs",
                        "role": "state",
                        "type": "string",
                        "def": "",
                        "read": true,
                        "write": false
                      "native": {},
                      "acl": {
                        "object": 1636,
                        "owner": "system.user.admin",
                        "state": 1636
                      "_id": "backitup.0.output.line",
                      "type": "state"
                    • horos73H horos73
                      simatecS Offline
                      simatecS Offline
                      simatec
                      html
                      History wird nicht beendet. Was hast du als "Anzahl der History-Einträge" eingetragen?
                      • simatecS simatec
                        html
                        horos73H Offline
                        horos73H Offline
                        horos73
                        @simatec Hmm, nutze history nicht - zumindest nicht bewusst. Wo stelle ich das ein?
                        • horos73H horos73
                            "common": {
                              "role": "state",
                              "type": "string",
                              "def": "",
                              "read": true,
                              "write": false
                            "native": {},
                            "acl": {
                              "object": 1636,
                              "state": 1636
                            "type": "state"
                          simatecS Offline
                          simatecS Offline
                          simatec
                          @horos73
                          Nein bitte den Wert des Objektes posten. Ich sehe den im Screenshot nur abgeschnitten.
                          • C Offline
                            Coffeelover
                            @horos73 Habe gerade iobroker komplett neu gestartet. Backup läuft wieder durch. Jetzt habe ich im Objekt lines folgenden Eintrag:
                            [DEBUG] [history] start with {"type":"creator","time":"02:10","debugging":true,"everyXDays":"1","nameSuffix":"iobrokerRevival","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.188.xx","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"/backupDir/minimal","user":"Homee","pass":"****","port":"21"},"dropbox":{"enabled":true,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.188.xx","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"/backupDir/minimal","user":"Homee","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"ftp","mount":"192.168.188.xx","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":true,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"googledrive":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/var/lib/redis"},"historyDB":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.188.xx","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"/backupDir/minimal","user":"Homee","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"ftp","mount":"192.168.188.xx","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"xxxx","wolTime":"25","smb":"vers=1.0","sudo":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":true,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"googledrive":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"media/usb/history"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.188.xx","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"/backupDir/minimal","user":"Homee","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"ftp","mount":"192.168.188.xx","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:2xxx","wolTime":"25","smb":"vers=1.0","sudo":false,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":true,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"googledrive":{"enabled":false,"type":"storage","source":"ftp","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/opt/iobroker/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"15. Januar 2020 um 13:17 Uhr"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"Raimund","onlyError":false,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                            Das sieht ziemlich ähnlich zu Holger aus.
                            • horos73H horos73
                              simatecS Offline
                              simatecS Offline
                              simatec
                              In den Haupteinstellungen von backitup
                              C 1 Antwort Letzte Antwort
                              • simatecS simatec
                                @horos73
                                horos73H Offline
                                horos73H Offline
                                horos73
                                @simatec
                                Screenshot von den history Einstellungen des Adapters:
                                • simatecS simatec
                                  Coffeelover
                                  @simatec Ich nutze History in den Einstellungen auch nicht. Die Anzahl steht auf Default 25.
                                  • C Coffeelover
                                    horos73H Offline
                                    horos73H Offline
                                    horos73
                                    @Coffeelover @simatec bei mir auch auf 25/default
                                    PS: muss mich bis heute Abend hier ausklinken (ein bissel arbeiten ;-)
                                    Bis später!
                                    • simatecS Offline
                                      simatecS Offline
                                      simatec
                                      Welchen js-controller habt ihr laufen?
                                      Nutzt ihr backitup im Compact-Modus?
                                      Probiert mal die Anzahl der Historydaten in den Einstellungen auf 20 zu setzen und lasst mal bitte den Installer Fix (siehe Signatur) drüberlaufen.
                                      • simatecS simatec
                                        Coffeelover
                                        schrieb am zuletzt editiert von Coffeelover
                                        @simatec jscontroller 2.2.7.
                                        Was ist der compact mode?
                                        Fix lasse ich gleich mal laufen und dann Backup mit 20 bei History.
                                        Update:
                                        • Habe 20 bei Anzahl der History-Einträge eingetragen (sonst nichts verändert)
                                        • Habe den Fix durchlaufen lassen
                                        • Backup wird weiterhin durchgeführt (file liegt auf NAS ab), DP backitup.0.history.iobrokerSuccess steht auf false, DP backitup.0.history.iobrokerLastTime zeigt "error: 15. Januar 2020 um 13:59 Uhr"
                                        Gibt es eigentlich einen Grund, warum das Full-Backup nicht mehr vorhanden ist?
                                        • C Coffeelover
                                          Update:
                                          simatecS Offline
                                          simatecS Offline
                                          simatec
                                          @Coffeelover
                                          Irgendwas ist da an eurem System nicht korrekt ... Eventuell irgendwas beim node Update oder der gleichen schief gelaufen.
                                          Sichere mal bitte über die Pfeilbutton in den Haupteinstellungen von Backitup deine Backitup Config und deinstalliere mal Backitup in den Instanzen und im Anschluss auch im Tab Adapter deinstallieren.
                                          Starte danach mal dein System neu und installiere Backitup wieder.
                                          Danach kannst du deine Config über die Pfeilbutton wieder zurückschieben.
