  4. JavaScript
  5. Sonoff Geräte als HTML Tabelle - Vis
javascriptmonitoringtemplate
632 Beiträge 34 Kommentatoren 251.8k Aufrufe 39 Beobachtet
  • ChaotC Chaot
    @liv-in-sky ... und läuft!
    Alle Geräte sofort da. Keine Fehlermeldung, Eine Warnung.
    javascript.0	2020-01-15 11:31:00.021	warn	(560) at Timer.processTimers (timers.js:223:10)
    javascript.0	2020-01-15 11:31:00.021	warn	(560) at listOnTimeout (timers.js:263:5)
    javascript.0	2020-01-15 11:31:00.021	warn	(560) at tryOnTimeout (timers.js:300:5)
    javascript.0	2020-01-15 11:31:00.020	warn	(560) at ontimeout (timers.js:436:11)
    javascript.0	2020-01-15 11:31:00.020	warn	(560) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
    javascript.0	2020-01-15 11:31:00.020	warn	(560) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
    javascript.0	2020-01-15 11:31:00.020	warn	(560) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
    javascript.0	2020-01-15 11:31:00.020	warn	(560) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1319:34)
    javascript.0	2020-01-15 11:31:00.020	warn	(560) at Object.<anonymous> (script.js.Systeminfo.Tasmota2:1089:2)
    javascript.0	2020-01-15 11:31:00.020	warn	(560) at writeHTML (script.js.Systeminfo.Tasmota2:415:30)
    javascript.0	2020-01-15 11:31:00.020	warn	(560) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:846:29)
    javascript.0	2020-01-15 11:31:00.019	warn	(560) at script.js.Systeminfo.Tasmota2:430:22
    javascript.0	2020-01-15 11:31:00.018	warn	(560) getState "sonoff.0.Martin_Licht.POWER1" not found (3)
    Zeile 430:
    Ist:
     let val6_1=getState(id.replace("INFO.Module","POWER1")).val;
    Soll:
     let val6_1=getState(id.replace("INFO.Module","POWER")).val;
    Der Schalter 1CH hat nur 1 Power. DDeshalb muss dort Power und nicht Power1 stehen.
    ChaotC
    ChaotC
    Chaot
    Noch ein kleiner Fehler ebenfalls beim T1 1CH:
    Zeile 429
    Ist:
    val5=val3=getState(id.replace("INFO.Module","Uptime")).val.toString()
    Soll:
    val5=getState(id.replace("INFO.Module","Uptime")).val.toString()
    Sonst wird RSSI mit Uptime überschrieben.
    • ChaotC Chaot
      Zeile 429
      Ist:
      Soll:
      liv-in-skyL
      liv-in-skyL
      @Chaot danke dir - dieser fehlr hat sich wie ein virus im script verbreitet - ist erledigt
      der andere auch
      //@liv-in-sky Januar 2020
      //HIER WIRD PFAD UND FILENAME DEFINIERT
      const path = "/htmlakku.html";                   //FIlenamen definieren
      const home ='vis.0'                                 //wo soll das file im iobroker-file-system liegen ? (oder z.b auch iqontrol.meta)
      let   braucheEinFile=false;                          // bei true wird ein file geschrieben
      let   braucheEinVISWidget=true;                     // bei true wird ein html-tabelle in einen dp geschrieben - siehe nächste zeile
      let dpVIS="controll-own.0.TABELLEN.SONOFF"         //WICHTIG wenn braucheEinVISWidget auf true gesetzt !!  dp zusätzlich für VIS-HTML-Basic-Widget
      let dpAnzahl="controll-own.0.TABELLEN.AnzahlSonoff";  //WICHTIG datenpunkt erstellen vom typ "number" - bei 0 kein alarm und größer 0 die anzahl der schlechten batterien
      let htmlColorDeviceUeberschrift="white"
      var battAlarm=30;                                     //alarm batterie wert
      var battAlarmWarning=55;                                     //warnungen batterie wert
      // ------------------------    hier einstellen, was man für ein device  hat - die nicht gebraucht werden auf false setzen !!!
      var pow=true;
      var generic=true;
      var basic=true;
      var externalMitInfo=false; //noch nicht integriert
      var externalOhneInfo=false;  //noch nicht integriert
      var schalter2ch=true;
      var dual=true;
      var t1_1ch=true;
      var channel4=true;             //Sonoff 4CH
      var rfbridge=true;
      var stdoseS2X=true;
      var sv=true;
      var blitzwolf_shp=true;
      var sonoffDev=true;
      var ohneInfo=true;
      //Sonderfall
      var linganSteckdose =true;
      var filterArray=["Sonoff Pow","Generic","Sonoff Basic","Sonoff T1 2CH","Sonoff S2X","Lingan SWA1"]; //hier arten eintragen - muss gefiltert werden für geräte ohne INFO
      let mySchedule="  * * * * * ";
      //HIER DIE SPALTEN ANZAHL DEFINIEREN - jede Spalte einen Wert - in diesem Beispiel sind es 5
      var htmlFeld1='Device';       var Feld1lAlign="left";                     // überschrift Tabellen Spalte1 und  Ausrichtung left,right or center
      var htmlFeld2='Status';        var Feld2lAlign="center";                      // überschrift Tabellen Spalte2 und  Ausrichtung left,right or center
      var htmlFeld3='Version';         var Feld3lAlign="center";                    // überschrift Tabellen Spalte3 und  Ausrichtung left,right or center
      var htmlFeld4='WLAN';        var Feld4lAlign="right";                    // überschrift Tabellen Spalte4 und  Ausrichtung left,right or center
      var htmlFeld5='IP';        var Feld5lAlign="left";                    // überschrift Tabellen Spalte5 und  Ausrichtung left,right or center
      var htmlFeld6='';        var Feld6lAlign="center";                    // überschrift Tabellen Spalte5 und  Ausrichtung left,right or center
      var htmlFeld7='';        var Feld7lAlign="center";                    // überschrift Tabellen Spalte5 und  Ausrichtung left,right or center
      var htmlFeld8='';        var Feld8lAlign="center";                    // überschrift Tabellen Spalte5 und  Ausrichtung left,right or center
      //hier werden die styles für die tabelle definiert
      //ÜBERSCHRIFT ÜBER TABELLE
      let   htmlUberschrift=true;                           // mit Überschrift über der tabelle
      let   htmlSignature=true;                              // anstatt der Überscghrift eine signature: - kleiner - anliegend
      const htmlFeldUeber='Sonoff Devices';              // Überschrift und Signature
      const htmlFarbUber="white";                         // Farbe der Überschrift
      const htmlSchriftWeite="normal";                       // bold, normal - Fettschrift für Überschrift
      const htmlÜberFontGroesse="18px";                       // schriftgröße überschrift
      //MEHRERE TABELLEN NEBENEINANDER
      let   mehrfachTabelle=1;                              // bis zu 4 Tabellen werden nebeneinander geschrieben-  verkürzt das Ganze, dafür etwas breiter - MÖGLICH 1,2,3,oder 4 !!!
      const htmlFarbZweiteTabelle="white";                // Farbe der Überschrift bei jeder 2.ten Tabelle
      const htmlFarbTableColorUber="#BDBDBD";               // Überschrift in der tabelle - der einzelnen Spalten
      //GANZE TABELLE
      let abstandZelle="1";
      let weite="auto";                                     //Weite der Tabelle
      let zentriert=true;                                   //ganze tabelle zentriert
      const backgroundAll="#000000";                        //Hintergrund für die ganze Seite - für direkten aufruf oder iqontrol sichtber - keine auswirkung auf vis-widget
      const htmlSchriftart="Helvetica";
      const htmlSchriftgroesse="14px";
      //FELDER UND RAHMEN
      let   UeberschriftSpalten=true;                // ein- oder ausblenden der spatlen-überschriften
      const htmlFarbFelderschrift="#BDBDBD";                  // SchriftFarbe der Felder
      const htmlFarbFelderschrift2="#D8D8D8";                 // SchriftFarbe der Felder für jede 2te Tabelle
      const htmlFarbTableColorGradient1="#424242";          //  Gradient - Hintergrund der Tabelle - Verlauffarbe
      const htmlFarbTableColorGradient2="#424242";          //  Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
      const htmlFarbTableBorderColor="gray";             // Farbe des Rahmen - is tdieser gleich den gradienten, sind die rahmen unsichtbar
      let htmlRahmenLinien="cols";                            // Format für Rahmen: MÖGLICH: "none" oder "all" oder "cols" oder "rows"
      const htmlSpalte1Weite="auto";                   //  Weite der ersten beiden  Spalten oder z.b. 115px
      // HIER NICHTS  ÄNDERN
      let borderHelpBottum;
      let borderHelpRight;
      let htmlcenterHelp;
      let htmlcenterHelp2;
      if(htmlRahmenLinien=="rows") {borderHelpBottum=1;borderHelpRight=0;}
      if(htmlRahmenLinien=="cols") {borderHelpBottum=0;borderHelpRight=1;}
      if(htmlRahmenLinien=="none") {borderHelpBottum=0;borderHelpRight=0;}
      if(htmlRahmenLinien=="all")  {borderHelpBottum=1;borderHelpRight=1;}
      zentriert ? htmlcenterHelp="auto" : htmlcenterHelp="left";
      zentriert ? htmlcenterHelp2="center" : htmlcenterHelp2="left";
      const htmlZentriert='<center>'
      const htmlStart=    "<!DOCTYPE html><html lang=\"de\"><head><title>Vorlage</title><meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\">"+
                         "<style> * {  margin: 0;} body {background-color: "+backgroundAll+"; margin: 0 auto;  }"+
                         " p {padding-top: 10px; padding-bottom: 10px; text-align: "+htmlcenterHelp2+"}"+
                        // " div { margin: 0 auto;  margin-left: auto; margin-right: auto;}"+
                         " td { padding:"+abstandZelle+"px; border:0px solid "+htmlFarbTableBorderColor+";  border-right:"+borderHelpRight+"px solid "+htmlFarbTableBorderColor+";border-bottom:"+borderHelpBottum+"px solid "+htmlFarbTableBorderColor+";}"+
                         " table { width: "+weite+";  margin: 0 "+htmlcenterHelp+"; border:1px solid "+htmlFarbTableBorderColor+"; border-spacing=\""+abstandZelle+"0px\" ; }"+   // margin macht center
                         "td:nth-child(1) {width: "+htmlSpalte1Weite+"}"+"td:nth-child(2) {width:"+htmlSpalte1Weite+"}"+
                         " </style></head><body> <div>";
      //const htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-weight: bold\">"+htmlFeldUeber+"</p>";
      const htmlTabStyle= "<table bordercolor=\""+htmlFarbTableBorderColor+"\" border=\"2px\" cellspacing=\""+abstandZelle+"\" cellpadding=\""+abstandZelle+"\" width=\""+weite+"\" rules=\""+htmlRahmenLinien+"\" style=\"color:"+htmlFarbFelderschrift+";  font-size:"+htmlSchriftgroesse+
                            "; font-family:"+htmlSchriftart+";background-image: linear-gradient(42deg,"+htmlFarbTableColorGradient2+","+htmlFarbTableColorGradient1+");\">";
      const htmlTabUeber1="<tr style=\"color:"+htmlFarbTableColorUber+"; font-weight: bold\">";
      const htmlTabUeber3="</tr>";
      //NICHTS ÄNDERN - abhängig von den oben definierten _Spalten - in diesem Beispiel sind es 5
      var htmlTabUeber2="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+">&ensp;"+htmlFeld2+"&ensp;</td><td  align="+Feld3lAlign+">&ensp;"+htmlFeld3+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+htmlFeld4+"&ensp;</td><td  align="+Feld5lAlign+">&ensp;"+htmlFeld5+"&ensp;</td><td  align="+Feld6lAlign+">&ensp;"+htmlFeld6+"&ensp;</td><td  align="+Feld7lAlign+">&ensp;"+htmlFeld7+"&ensp;</td><td  align="+Feld8lAlign+">&ensp;"+htmlFeld8+"&ensp;</td>";
      var htmlTabUeber2_1="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld3+
                         "&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld3+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld4+
                         "&ensp;</td><td align="+Feld5lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\"&ensp;>"+htmlFeld5+"&ensp;</td><td align="+Feld6lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\"&ensp;>"+htmlFeld6+"&ensp;</td><td align="+Feld7lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\"&ensp;>"+htmlFeld7+"&ensp;</td><td align="+Feld8lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\"&ensp;>"+htmlFeld8+"&ensp;</td>";
      var anzahl;
      var AkkuAlarm=[];
      var htmlOut="";
      var mix;
      var counter;
      var val1; var val2; var val0; var val3; var val4; var val5; var val6; var val7;
      var htmlTabUeber="";
      function writeHTML(){
      anzahl=0;
      htmlOut="";
      counter=-1;
      htmlTabUeber="";
      switch (mehrfachTabelle) {
         case 1: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber3;  break;
         case 2: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
         case 3: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2+htmlTabUeber2+htmlTabUeber3; break;
         case 4: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
      if (!UeberschriftSpalten) {htmlTabUeber=""}
      //---------hier kommt eure schleife rein counter++, tabelleBind() und tabelleFinish() müssen so integriert bleiben !!!------------------------------
      //---------alle valx werte müssen von euch bestimmt werden - val0,val1,val2,val3,val4!!!------------------------------------------------------------
      var myColl=[];
      var val1help;
        if (pow){
                   // UNTERTEILUNG - ÜBERSCHRIFT IN TABELLE
            tabelleAusbessern();
            counter=0;
            val0=val0=""; val1=""; val2="";val3="";val4="";val5="";val6="";val7="";
            tabelleBind(); //HIER NICHTS ÄNDERN : HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT  - diese function muss als letztes in der eigenen schleife aufgerufen werden
            counter=0;
            val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>Pow (R2)</b>"; val1=""; val2="";val3="";val4="";val5="<font color=\""+htmlColorDeviceUeberschrift+"\">kWh Gesamt";val6="<font color=\""+htmlColorDeviceUeberschrift+"\">kWh Today";val7="<font color=\""+htmlColorDeviceUeberschrift+"\">Power Switch"
            counter=-1
      //sonoff.0.SonoffPow1.INFO.Module
       $('sonoff.*.*.INFO.Module').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
            if (getState(id).val=="Sonoff Pow" || getState(id).val=="Sonoff Pow R2") {
               // log (id)
               anzahl++;
              var ida = id.split('.');
                counter++;
                  //log("dad   "+getState(id.replace("Info.Module","alive")).val + " ----" +id.replace("Info.Module","alive"))
                val1=getState(id.replace("INFO.Module","alive")).val;                   //sonoff.0.SonoffPow1.alive          sonoff.0.SonoffPow1.INFO.Module
                val0=getObject(ida[0]+"."+ida[1]+"."+ida[2]).common.name ;
                val4=getState(id.replace("Module","IPAddress")).val
                val2=getState(id.replace("Module","Version")).val.replace(/\(.+\)/g,"")     //sonoff.0.SonoffPow1.Wifi_RSSIsonoff.0.SonoffPow1.POWER
                val3=getState(id.replace("INFO.Module","Wifi_RSSI")).val.toString()+" %";
                let val7_1=getState(id.replace("INFO.Module","POWER")).val;
                val7_1 ? val7=(" <font color=\"lightgreen\"> ")+"ON" : val7=(" <font color=\"red\"> ")+"OFF";
                val6=getState(id.replace("INFO.Module","ENERGY_Today")).val.toString();
                val5=getState(id.replace("INFO.Module","ENERGY_Total")).val.toString();
                if (!getState(id.replace("INFO.Module","alive")).val) {
                    val1="❌";
                    val4=(" <font color=\"red\"> ")+val1;
                    val2=(" <font color=\"red\"> ")+val2;
                    val3=(" <font color=\"red\"> ")+" 0 %";
                    val5=(" <font color=\"red\"> ")+" --- ";
                    val6=(" <font color=\"red\"> ")+" --- ";
                    val7=(" <font color=\"red\"> ")+" --- ";
                    val0=(" <font color=\"red\"> ")+val0}
                else{
                    val1="✅";
                   // val1=(" <font color=\"lightgreen\"> ")+val1
                   // val2=(" <font color=\"green\"> ")+val2
                   // val3=(" <font color=\"green\"> ")+val3
                   // val0=(" <font color=\"green\"> ")+val0
        } }); //Schleifen Ende - je nach schleifenart muss hier etwas geändert werden !!!!!!!!!
      } //ende fritzdect
          if (blitzwolf_shp){
            counter=0;
            counter=0;
            val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>BlitzWolf SHP</b>"; val1=""; val2="";val3="";val4="";val5="<font color=\""+htmlColorDeviceUeberschrift+"\">kWh Gesamt";val6="<font color=\""+htmlColorDeviceUeberschrift+"\">kWh Heute";val7="<font color=\""+htmlColorDeviceUeberschrift+"\">kWh Gestern"
            counter=-1
            if (getState(id).val=="BlitzWolf SHP") {
               // log (id)
               anzahl++;
                counter++;
                let val7_1=getState(id.replace("INFO.Module","ENERGY_Yesterday")).val.toString();
               // val7_1 ? val7=(" <font color=\"lightgreen\"> ")+"ON" : val7=(" <font color=\"red\"> ")+"OFF";
                    val1="❌";
                else{
                    val1="✅";
      } //ende fritzdect
       if (generic){
            counter=0;
            counter=0;
            val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>Generic</b>"; val1=""; val2="";val3="";val4="";val5="<font color=\""+htmlColorDeviceUeberschrift+"\">Uptime";val6="<font color=\""+htmlColorDeviceUeberschrift+"\">";val7="<font color=\""+htmlColorDeviceUeberschrift+"\">"
            counter=-1
            if (getState(id).val=="Generic") {
               //log (id)
               anzahl++;
                counter++;
              //   let val7_1=getState(id.replace("INFO.Module","POWER")).val;
                   val7="";
              //  let val6_1=getState(id.replace("INFO.Module","Switch1")).val;
              //  val6_1 ? val6=(" <font color=\"lightgreen\"> ")+"ON" : val6=(" <font color=\"red\"> ")+"OFF";
               // val6=getState(id.replace("INFO.Module","SWITCH1")).val.toString();
                //val7=getState(id.replace("INFO.Module","ENERGY_Total")).val.toString();
               // val6=""
                 val6="";
                    val1="❌";
                    val4=(" <font color=\"red\"> ")+val4;
                else{
                    val1="✅";
       } //ende xiaomi
      if (basic){
            counter=0;
            counter=0;
            val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>Basic</b>"; val1=""; val2="";val3="";val4="";val5="<font color=\""+htmlColorDeviceUeberschrift+"\">Uptime";val6="<font color=\""+htmlColorDeviceUeberschrift+"\">";val7="<font color=\""+htmlColorDeviceUeberschrift+"\">Power Switch"
            counter=-1
            if (getState(id).val=="Sonoff Basic") {
             //  log (id)
             anzahl++;
                counter++;
             //   let val7_1=getState(id.replace("INFO.Module","Switch1")).val;
                val6=""
                    val1="❌";
                else{
                    val1="✅";
       } //ende xiaomi
        if (t1_1ch){
            counter=0;
            counter=0;
            val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>Schalter T1 1CH</b>"; val1=""; val2="";val3="";val4="";val5="<font color=\""+htmlColorDeviceUeberschrift+"\">Uptime";val6="<font color=\""+htmlColorDeviceUeberschrift+"\">Switch 1";val7="<font color=\""+htmlColorDeviceUeberschrift+"\">"
            counter=-1
            if (getState(id).val=="Sonoff T1 1CH") {
             //  log (id)
             anzahl++;
                counter++;
              //  let val7_1=getState(id.replace("INFO.Module","POWER2")).val;
              val7="";
              //  val6=""
                    val1="❌";
                else{
                    val1="✅";
       } //ende xiaomi
      if (schalter2ch){
            counter=0;
            counter=0;
            val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>Schalter T1 2CH</b>"; val1=""; val2="";val3="";val4="";val5="<font color=\""+htmlColorDeviceUeberschrift+"\">Uptime";val6="<font color=\""+htmlColorDeviceUeberschrift+"\">Switch 1";val7="<font color=\""+htmlColorDeviceUeberschrift+"\">Switch 2"
            counter=-1
            if (getState(id).val=="Sonoff T1 2CH") {
             //  log (id)
             anzahl++;
                counter++;
              //  val6=""
                    val1="❌";
                else{
                    val1="✅";
       } //ende xiaomi
        if (dual){
            counter=0;
            counter=0;
            val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>Dual (R2) </b>"; val1=""; val2="";val3="";val4="";val5="<font color=\""+htmlColorDeviceUeberschrift+"\">Uptime";val6="<font color=\""+htmlColorDeviceUeberschrift+"\">Switch 1";val7="<font color=\""+htmlColorDeviceUeberschrift+"\">Switch 2"
            counter=-1
            if (getState(id).val=="Sonoff Dual" || getState(id).val=="Sonoff Dual R2") {
             //  log (id)
             anzahl++;
                counter++;
              //  val6=""
                    val1="❌";
                else{
                    val1="✅";
       } //ende xiaomi
        if (channel4){
            counter=0;
            counter=0;
            val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>Schalter CH4 </b>"; val1=""; val2="";val3="";val4="";val5="<font color=\""+htmlColorDeviceUeberschrift+"\">Uptime";val6="<font color=\""+htmlColorDeviceUeberschrift+"\">Switch 1";val7="<font color=\""+htmlColorDeviceUeberschrift+"\">Switch 2"
            counter=-1
            if (getState(id).val=="Sonoff 4CH" ) {
             //  log (id)
             anzahl++;
                counter++;
              //  val6=""
                    val1="❌";
                else{
                    val1="✅";
       } //ende xiaomi
      if (stdoseS2X){
            counter=0;
            counter=0;
            val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>Steckdose S2X</b>"; val1=""; val2="";val3="";val4="";val5="<font color=\""+htmlColorDeviceUeberschrift+"\">Uptime";val6="<font color=\""+htmlColorDeviceUeberschrift+"\">";val7="<font color=\""+htmlColorDeviceUeberschrift+"\">Power Switch"
            counter=-1
            if (getState(id).val=="Sonoff S2X") {
             //  log (id)
             anzahl++;
                counter++;
                val6=""
                    val1="❌";
                else{
                    val1="✅";
       } //ende xiaomi
      if (linganSteckdose){
            counter=0;
            counter=0;
            val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>Lingan Steckdose</b>"; val1=""; val2="";val3="";val4="";val5="<font color=\""+htmlColorDeviceUeberschrift+"\">Uptime";val6="<font color=\""+htmlColorDeviceUeberschrift+"\">";val7="<font color=\""+htmlColorDeviceUeberschrift+"\">Power Switch"
            counter=-1
            if (getState(id).val=="Lingan SWA1") {
             //  log (id)
                anzahl++;
                counter++;
                val3="na"; //getState(id.replace("INFO.Module","Wifi_RSSI")).val.toString()+" %";
                val5="na"; //val3=getState(id.replace("INFO.Module","Uptime")).val.toString()
                val6=""
                    val1="❌";
                else{
                    val1="✅";
       } //ende xiaomi
      if (rfbridge){
            counter=0;
            counter=0;
            val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>RF Bridge</b>"; val1=""; val2="";val3="";val4="";val5="<font color=\""+htmlColorDeviceUeberschrift+"\">Uptime";val6="<font color=\""+htmlColorDeviceUeberschrift+"\">Received";val7="<font color=\""+htmlColorDeviceUeberschrift+"\">Power Switch"
            counter=-1
            if (getState(id).val=="Sonoff Bridge") {
             //  log (id)
             anzahl++;
                counter++;
                val6=getState(id.replace("INFO.Module","RfReceived_Data")).val;
                    val1="❌";
                else{
                    val1="✅";
       } //ende xiaomi
       if (ohneInfo){
            counter=0;
            counter=0;
            val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>Sonderfälle ohne INFO</b>"; val1=""; val2="";val3="";val4="";val5="<font color=\""+htmlColorDeviceUeberschrift+"\">Uptime";val6="<font color=\""+htmlColorDeviceUeberschrift+"\">";val7="<font color=\""+htmlColorDeviceUeberschrift+"\">Power Switch"
            counter=-1
      var arrFilt=[];
       $('sonoff.*.*').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
              //  log(ida[0]+"."+ida[1]+"."+ida[2]+"."+"INFO.IPAddress")
                $(ida[0]+"."+ida[1]+"."+ida[2]+"."+"INFO.IPAddress").each(function(id, i) {   // kontrolliere ob  vorhanden
                    var idc = id.split('.');
                    if(!arrFilt.includes(idc[2])){
                  //  log(idc[2])
                 arrFilt.push(idc[2])}
      //log("filter: "+arrFilt.toString())
      //sonoff.0.ShellyWC.alive
       $('sonoff.*.*.alive').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
         //log(ida[2])
            //  log (" hier die werte: "+id)
          //  if (filterArray.includes) {
                if (!arrFilt.includes(ida[2])) {
            //   log (id)
             anzahl++;
                counter++;
                val1=getState(id).val;                   //sonoff.0.SonoffPow1.alive          sonoff.0.SonoffPow1.INFO.Module
                val4=" na "; //getState(id.replace("Module","IPAddress")).val
                val2=" na "; //getState(id.replace("Module","Version")).val.replace(/\(.+\)/g,"")     //sonoff.0.SonoffPow1.Wifi_RSSIsonoff.0.SonoffPow1.POWER
                val7="na" // let val7_1=getState(id.replace("alive","POWER")).val;
                ida[2].includes("Bridge") ?  val6=getState(id.replace("alive","RfReceived_Data")).val : val6="";
                if (!getState(id).val) {
                    val1="❌";
                    val2=(" <font color=\"red\"> ")+val1;
                else{
                    val1="✅";
       } //ende xiaomi
        if (sv){
            counter=0;
            counter=0;
            val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>Sonoff SV</b>"; val1=""; val2="";val3="";val4="";val5="<font color=\""+htmlColorDeviceUeberschrift+"\">Uptime";val6="<font color=\""+htmlColorDeviceUeberschrift+"\">";val7="<font color=\""+htmlColorDeviceUeberschrift+"\">"
            counter=-1
            if (getState(id).val=="Sonoff SV") {
             //  log (id)
             anzahl++;
                counter++;
                //val7_1 ? val7=(" <font color=\"lightgreen\"> ")+"ON" : val7=(" <font color=\"red\"> ")+"OFF";
                val7="";
                val6=""
                    val1="❌";
                else{
                    val1="✅";
       } //ende xiaomi
          if (sonoffDev){
            counter=0;
            counter=0;
            val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>Sonoff Dev</b>"; val1=""; val2="";val3="";val4="";val5="<font color=\""+htmlColorDeviceUeberschrift+"\">Uptime";val6="<font color=\""+htmlColorDeviceUeberschrift+"\">";val7="<font color=\""+htmlColorDeviceUeberschrift+"\">"
            counter=-1
            if (getState(id).val=="Sonoff Dev") {
             //  log (id)
             anzahl++;
                counter++;
                val7="";
                val6=""
                    val1="❌";
                else{
                    val1="✅";
       } //ende xiaomi
       //   if (AkkuAlarm.length >=1 ) {setState(dpAlarm,AkkuAlarm.length)} else {setState(dpAlarm,AkkuAlarm.length)}
         // log("BATTERIE Alarm     : "+AkkuAlarm.length.toString());
      //--------------------------------------------------Ende der schleife------------------------------------------------------------------------------
          tabelleFinish(); // AB HIER NICHTS ÄNDERN - tabelle fertigstellen
          setState(dpAnzahl,anzahl);
      } // function ende
      //MAIN:
      schedule(mySchedule,  function () {
       writeHTML();
       if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}
       writeHTML();
         				 function tabelleBind(){
           //HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT - hat man oben 5 Felder definiert, braucht man hier 5 Werte
               case 1:                    htmlOut=htmlOut+"<tr><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td></tr>"; break;
              case 2:  if(counter%2==0)  {htmlOut = htmlOut+"<tr><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td>"; }
                                    else {htmlOut = htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td></tr>";} break;
              case 3: if(counter%3==0 )  {htmlOut = htmlOut+"<tr><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td>"; }
                                    else { if(counter%3==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td>";}
                                                     else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td></tr>";}
                                               } break;
              case 4: if(counter%4==0)  {htmlOut = htmlOut+"<tr><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td>"; }
                                        else {if(counter%2==1 )  { htmlOut = htmlOut+"<td  align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td>";}
                                                     else    {if(counter%2==1 && counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td></tr>";}
        else    {htmlOut = htmlOut = htmlOut+"<td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td>&ensp;"+val1+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td>";}}
                                               } break;
           } //switch ende
      function tabelleAusbessern() {
               case 1:    break;
               case 2:    mix=Math.abs(((counter+1)%2)-mehrfachTabelle);
                          if(mix==1)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                          break;
               case 3:    mix =Math.abs(((counter+1)%3)-mehrfachTabelle);
                          if(mix==2)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                          break;
               case 4:    mix=Math.abs(((counter+1)%4)-mehrfachTabelle);
                          if(mix==3)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                          break; }
      function tabelleFinish() {
            // tabelle fertigstellen
               case 1:    break;
                          break;
                          break;
                          break; }
                          var htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: "+htmlÜberFontGroesse+"; font-weight:"+htmlSchriftWeite+ "\">"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss")+"&ensp;&ensp;Anzahl: "+anzahl+"</p>";
             var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 70%; text-align: right;\" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss")+"&ensp;&ensp;Anzahl: "+anzahl+"</div>"
              if (!htmlSignature) htmlUnter="";
                //Ausgabe über VIS html widget - tabelle in datenpunkt schreiben - html tabelle ohne html header und body
                 var htmlOutVIS="";
               //  htmlUberschrift ? htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>" : htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>";
                  if (htmlUberschrift)
                      { zentriert ? htmlOutVIS=htmlZentriert+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter : htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter ;
                    } else {
                     zentriert ?  htmlOutVIS=htmlZentriert+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter :  htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter;
      // log("bin raus aus tabelleBind");
                 if (braucheEinVISWidget) setState(dpVIS, htmlOutVIS );
       var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 80%;  text-align: center; \" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>"
       var htmlEnd="</table>"+htmlUnter+"</div></body>";
       //mit oder ohne überschrift - zentriert oder links
      htmlUberschrift ? htmlOut=htmlStart+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd : htmlOut=htmlStart+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd;
       //log(htmlOut);
      ChaotC Meister MopperM 2 Antworten Letzte Antwort
      • liv-in-skyL liv-in-sky
        der andere auch
        var pow=true;
        var generic=true;
        var basic=true;
        var dual=true;
        var t1_1ch=true;
        var rfbridge=true;
        var stdoseS2X=true;
        var sv=true;
        var sonoffDev=true;
        var ohneInfo=true;
        //Sonderfall
        //GANZE TABELLE
        //FELDER UND RAHMEN
        let htmlcenterHelp;
        var anzahl;
        var AkkuAlarm=[];
        var htmlOut="";
        var mix;
        var counter;
        anzahl=0;
        htmlOut="";
        counter=-1;
        htmlTabUeber="";
        var myColl=[];
        var val1help;
          if (pow){
              counter=0;
              counter=0;
              counter=-1
                 // log (id)
                 anzahl++;
                  counter++;
                      val1="❌";
                  else{
                      val1="✅";
        } //ende fritzdect
            if (blitzwolf_shp){
              counter=0;
              counter=0;
              counter=-1
                 // log (id)
                 anzahl++;
                  counter++;
                      val1="❌";
                  else{
                      val1="✅";
        } //ende fritzdect
         if (generic){
              counter=0;
              counter=0;
              counter=-1
                 //log (id)
                 anzahl++;
                  counter++;
                     val7="";
                 // val6=""
                   val6="";
                      val1="❌";
                  else{
                      val1="✅";
         } //ende xiaomi
        if (basic){
              counter=0;
              counter=0;
              counter=-1
               //  log (id)
               anzahl++;
                  counter++;
                  val6=""
                      val1="❌";
                  else{
                      val1="✅";
         } //ende xiaomi
          if (t1_1ch){
              counter=0;
              counter=0;
              counter=-1
               //  log (id)
               anzahl++;
                  counter++;
                val7="";
                //  val6=""
                      val1="❌";
                  else{
                      val1="✅";
         } //ende xiaomi
        if (schalter2ch){
              counter=0;
              counter=0;
              counter=-1
               //  log (id)
               anzahl++;
                  counter++;
                //  val6=""
                      val1="❌";
                  else{
                      val1="✅";
         } //ende xiaomi
          if (dual){
              counter=0;
              counter=0;
              counter=-1
               //  log (id)
               anzahl++;
                  counter++;
                //  val6=""
                      val1="❌";
                  else{
                      val1="✅";
         } //ende xiaomi
          if (channel4){
              counter=0;
              counter=0;
              counter=-1
               //  log (id)
               anzahl++;
                  counter++;
                //  val6=""
                      val1="❌";
                  else{
                      val1="✅";
         } //ende xiaomi
        if (stdoseS2X){
              counter=0;
              counter=0;
              counter=-1
               //  log (id)
               anzahl++;
                  counter++;
                  val6=""
                      val1="❌";
                  else{
                      val1="✅";
         } //ende xiaomi
              counter=0;
              counter=0;
              counter=-1
               //  log (id)
                  anzahl++;
                  counter++;
                  val6=""
                      val1="❌";
                  else{
                      val1="✅";
         } //ende xiaomi
        if (rfbridge){
              counter=0;
              counter=0;
              counter=-1
               //  log (id)
               anzahl++;
                  counter++;
                      val1="❌";
                  else{
                      val1="✅";
         } //ende xiaomi
         if (ohneInfo){
              counter=0;
              counter=0;
              counter=-1
        var arrFilt=[];
                    //  log(idc[2])
           //log(ida[2])
              //   log (id)
               anzahl++;
                  counter++;
                      val1="❌";
                  else{
                      val1="✅";
         } //ende xiaomi
          if (sv){
              counter=0;
              counter=0;
              counter=-1
               //  log (id)
               anzahl++;
                  counter++;
                  val7="";
                  val6=""
                      val1="❌";
                  else{
                      val1="✅";
         } //ende xiaomi
            if (sonoffDev){
              counter=0;
              counter=0;
              counter=-1
               //  log (id)
               anzahl++;
                  counter++;
                  val7="";
                  val6=""
                      val1="❌";
                  else{
                      val1="✅";
         } //ende xiaomi
        } // function ende
        //MAIN:
         writeHTML();
         writeHTML();
                                                 } break;
                                                 } break;
             } //switch ende
                 case 1:    break;
                            break;
                            break;
                            break; }
                 case 1:    break;
                            break;
                            break;
                            break; }
                   var htmlOutVIS="";
                      } else {
         //log(htmlOut);
        ChaotC
        ChaotC
        Chaot
        @liv-in-sky
        Schnell mal getestet.
        Ausfall eines Geräts sieht auch sauber aus:
          der andere auch
          var pow=true;
          var generic=true;
          var basic=true;
          var dual=true;
          var t1_1ch=true;
          var rfbridge=true;
          var stdoseS2X=true;
          var sv=true;
          var sonoffDev=true;
          var ohneInfo=true;
          //Sonderfall
          //GANZE TABELLE
          //FELDER UND RAHMEN
          let htmlcenterHelp;
          var anzahl;
          var AkkuAlarm=[];
          var htmlOut="";
          var mix;
          var counter;
          anzahl=0;
          htmlOut="";
          counter=-1;
          htmlTabUeber="";
          var myColl=[];
          var val1help;
            if (pow){
                counter=0;
                counter=0;
                counter=-1
                   // log (id)
                   anzahl++;
                    counter++;
                        val1="❌";
                    else{
                        val1="✅";
          } //ende fritzdect
              if (blitzwolf_shp){
                counter=0;
                counter=0;
                counter=-1
                   // log (id)
                   anzahl++;
                    counter++;
                        val1="❌";
                    else{
                        val1="✅";
          } //ende fritzdect
           if (generic){
                counter=0;
                counter=0;
                counter=-1
                   //log (id)
                   anzahl++;
                    counter++;
                       val7="";
                   // val6=""
                     val6="";
                        val1="❌";
                    else{
                        val1="✅";
           } //ende xiaomi
          if (basic){
                counter=0;
                counter=0;
                counter=-1
                 //  log (id)
                 anzahl++;
                    counter++;
                    val6=""
                        val1="❌";
                    else{
                        val1="✅";
           } //ende xiaomi
            if (t1_1ch){
                counter=0;
                counter=0;
                counter=-1
                 //  log (id)
                 anzahl++;
                    counter++;
                  val7="";
                  //  val6=""
                        val1="❌";
                    else{
                        val1="✅";
           } //ende xiaomi
          if (schalter2ch){
                counter=0;
                counter=0;
                counter=-1
                 //  log (id)
                 anzahl++;
                    counter++;
                  //  val6=""
                        val1="❌";
                    else{
                        val1="✅";
           } //ende xiaomi
            if (dual){
                counter=0;
                counter=0;
                counter=-1
                 //  log (id)
                 anzahl++;
                    counter++;
                  //  val6=""
                        val1="❌";
                    else{
                        val1="✅";
           } //ende xiaomi
            if (channel4){
                counter=0;
                counter=0;
                counter=-1
                 //  log (id)
                 anzahl++;
                    counter++;
                  //  val6=""
                        val1="❌";
                    else{
                        val1="✅";
           } //ende xiaomi
          if (stdoseS2X){
                counter=0;
                counter=0;
                counter=-1
                 //  log (id)
                 anzahl++;
                    counter++;
                    val6=""
                        val1="❌";
                    else{
                        val1="✅";
           } //ende xiaomi
                counter=0;
                counter=0;
                counter=-1
                 //  log (id)
                    anzahl++;
                    counter++;
                    val6=""
                        val1="❌";
                    else{
                        val1="✅";
           } //ende xiaomi
          if (rfbridge){
                counter=0;
                counter=0;
                counter=-1
                 //  log (id)
                 anzahl++;
                    counter++;
                        val1="❌";
                    else{
                        val1="✅";
           } //ende xiaomi
           if (ohneInfo){
                counter=0;
                counter=0;
                counter=-1
          var arrFilt=[];
                      //  log(idc[2])
             //log(ida[2])
                //   log (id)
                 anzahl++;
                    counter++;
                        val1="❌";
                    else{
                        val1="✅";
           } //ende xiaomi
            if (sv){
                counter=0;
                counter=0;
                counter=-1
                 //  log (id)
                 anzahl++;
                    counter++;
                    val7="";
                    val6=""
                        val1="❌";
                    else{
                        val1="✅";
           } //ende xiaomi
              if (sonoffDev){
                counter=0;
                counter=0;
                counter=-1
                 //  log (id)
                 anzahl++;
                    counter++;
                    val7="";
                    val6=""
                        val1="❌";
                    else{
                        val1="✅";
           } //ende xiaomi
          } // function ende
          //MAIN:
           writeHTML();
           writeHTML();
                                                   } break;
                                                   } break;
               } //switch ende
                   case 1:    break;
                              break;
                              break;
                              break; }
                   case 1:    break;
                              break;
                              break;
                              break; }
                     var htmlOutVIS="";
                        } else {
           //log(htmlOut);
          Meister MopperM
          Meister MopperM
          Meister Mopper
          @liv-in-sky hier habe ich noch einen, der nicht ufgeführt wird:
          Proxmox und HA ...
          liv-in-skyL ? 2 Antworten Letzte Antwort
            liv-in-skyL
            liv-in-skyL
            #66
            @Meister-Mopper was ist teckin
            einfache steckdose wie s2x ?
            ich sortiere nach info.Module teckim kenn ich nicht
            wenn es eine steckdose ist - wäree das ok, wenn ich sie zu dem s2x dazunehme oder sollte das eine eigene überschrift bekommen ?
              #67
              @Meister-Mopper Das ist doch eine eigentlich tuya-Steckdose, die mit Tasmota geflasht wurde oder?
              liv-in-skyL Meister MopperM 2 Antworten Letzte Antwort
                liv-in-skyL
                liv-in-skyL
                #68
                @HeinrichB
                hat es einen POWER datenpunkt ?
                  Meister MopperM
                  Meister MopperM
                  Meister Mopper
                  #69
                  @HeinrichB Nein, es ist eine Teckin mit Tasmota OTA geflashed,
                  Proxmox und HA ...
                    liv-in-skyL
                    liv-in-skyL
                    #70
                    @Meister-Mopper
                    probier mal damit
                    var pow=true;
                    var generic=true;
                    var basic=true;
                    var dual=true;
                    var t1_1ch=true;
                    var rfbridge=true;
                    var stdoseS2X=true;
                    var sv=true;
                    var sonoffDev=true;
                    var ohneInfo=true;
                    //Sonderfall
                    //GANZE TABELLE
                    //FELDER UND RAHMEN
                    let htmlcenterHelp;
                    var anzahl;
                    var AkkuAlarm=[];
                    var htmlOut="";
                    var mix;
                    var counter;
                    anzahl=0;
                    htmlOut="";
                    counter=-1;
                    htmlTabUeber="";
                    var myColl=[];
                    var val1help;
                      if (pow){
                          counter=0;
                          counter=0;
                          counter=-1
                             // log (id)
                             anzahl++;
                              counter++;
                                  val1="❌";
                              else{
                                  val1="✅";
                    } //ende fritzdect
                        if (blitzwolf_shp){
                          counter=0;
                          counter=0;
                          counter=-1
                             // log (id)
                             anzahl++;
                              counter++;
                                  val1="❌";
                              else{
                                  val1="✅";
                    } //ende fritzdect
                     if (generic){
                          counter=0;
                          counter=0;
                          counter=-1
                             //log (id)
                             anzahl++;
                              counter++;
                                 val7="";
                             // val6=""
                               val6="";
                                  val1="❌";
                              else{
                                  val1="✅";
                     } //ende xiaomi
                    if (basic){
                          counter=0;
                          counter=0;
                          counter=-1
                           //  log (id)
                           anzahl++;
                              counter++;
                              val6=""
                                  val1="❌";
                              else{
                                  val1="✅";
                     } //ende xiaomi
                      if (t1_1ch){
                          counter=0;
                          counter=0;
                          counter=-1
                           //  log (id)
                           anzahl++;
                              counter++;
                            val7="";
                            //  val6=""
                                  val1="❌";
                              else{
                                  val1="✅";
                     } //ende xiaomi
                    if (schalter2ch){
                          counter=0;
                          counter=0;
                          counter=-1
                           //  log (id)
                           anzahl++;
                              counter++;
                            //  val6=""
                                  val1="❌";
                              else{
                                  val1="✅";
                     } //ende xiaomi
                      if (dual){
                          counter=0;
                          counter=0;
                          counter=-1
                           //  log (id)
                           anzahl++;
                              counter++;
                            //  val6=""
                                  val1="❌";
                              else{
                                  val1="✅";
                     } //ende xiaomi
                      if (channel4){
                          counter=0;
                          counter=0;
                          counter=-1
                           //  log (id)
                           anzahl++;
                              counter++;
                            //  val6=""
                                  val1="❌";
                              else{
                                  val1="✅";
                     } //ende xiaomi
                    if (stdoseS2X){
                          counter=0;
                          counter=0;
                          counter=-1
                          if (getState(id).val=="Sonoff S2X"  || getState(id).val=="Teckim") {
                           //  log (id)
                           anzahl++;
                              counter++;
                              val6=""
                                  val1="❌";
                              else{
                                  val1="✅";
                     } //ende xiaomi
                          counter=0;
                          counter=0;
                          counter=-1
                           //  log (id)
                              anzahl++;
                              counter++;
                              val6=""
                                  val1="❌";
                              else{
                                  val1="✅";
                     } //ende xiaomi
                    if (rfbridge){
                          counter=0;
                          counter=0;
                          counter=-1
                           //  log (id)
                           anzahl++;
                              counter++;
                                  val1="❌";
                              else{
                                  val1="✅";
                     } //ende xiaomi
                     if (ohneInfo){
                          counter=0;
                          counter=0;
                          counter=-1
                    var arrFilt=[];
                                //  log(idc[2])
                       //log(ida[2])
                          //   log (id)
                           anzahl++;
                              counter++;
                                  val1="❌";
                              else{
                                  val1="✅";
                     } //ende xiaomi
                      if (sv){
                          counter=0;
                          counter=0;
                          counter=-1
                           //  log (id)
                           anzahl++;
                              counter++;
                              val7="";
                              val6=""
                                  val1="❌";
                              else{
                                  val1="✅";
                     } //ende xiaomi
                        if (sonoffDev){
                          counter=0;
                          counter=0;
                          counter=-1
                           //  log (id)
                           anzahl++;
                              counter++;
                              val7="";
                              val6=""
                                  val1="❌";
                              else{
                                  val1="✅";
                     } //ende xiaomi
                    } // function ende
                    //MAIN:
                     writeHTML();
                     writeHTML();
                                                             } break;
                                                             } break;
                         } //switch ende
                             case 1:    break;
                                        break;
                                        break;
                                        break; }
                             case 1:    break;
                                        break;
                                        break;
                                        break; }
                               var htmlOutVIS="";
                                  } else {
                     //log(htmlOut);
                      #71
                      @Meister-Mopper Ja, aber hinter Teckin steht Tuya, wie bei den Gosund meines Wissens. Ungeflasht läuft das alles über die SmartLife-Umgebung
                        Meister MopperM
                        Meister MopperM
                        Meister Mopper
                        #72
                        @liv-in-sky S2x reicht aus für die Steckdose (ist allerdings auch ein Leistungsmesser)
                        Proxmox und HA ...
                          liv-in-skyL
                          liv-in-skyL
                          #73
                          @Meister-Mopper gib mir mal ein bild von allen dp
                          vielleicht geht es unter den Pows
                            #74
                            @Meister-Mopper Der misst aber nur die Leistung und nicht den Verbrauch oder? Ich frage einfach, weil ich nur die ugeflashte Version hier habe :)
                              Meister MopperM
                              Meister MopperM
                              Meister Mopper
                              #75
                              @liv-in-sky gerne;
                              Proxmox und HA ...
                                @liv-in-sky gerne;
                                liv-in-skyL
                                liv-in-skyL
                                #76
                                @Meister-Mopper ich sehe da keine leistung - dann sollte es unter steckdose laufen - dann paßt das script von eben
                                  Meister MopperM
                                  Meister MopperM
                                  Meister Mopper
                                  #77
                                  @liv-in-sky Ich sehe gerade, dass da was fehlt. Hier eine andere:
                                  Proxmox und HA ...
                                    liv-in-skyL
                                    liv-in-skyL
                                    #78
                                    @Meister-Mopper ok das ist jetzt doof - wenn beide existieren kann ich nicht nach teckin sortieren
                                    rein theoretisch hast du eine steckdose mit energiemessung und eine ohne - ist das richtig
                                      Meister MopperM
                                      Meister MopperM
                                      Meister Mopper
                                      #79
                                      @liv-in-sky Nein, nein, sie sind baugleich, bei der ersten wurden offenbar die Datenpunkte nicht komplett geschrieben. Ich werde sie nachher mal vom Strom nehmen.
                                      Proxmox und HA ...
                                        liv-in-skyL
                                        liv-in-skyL
                                        #80
                                        @Meister-Mopper
                                        ja gib mir meldung
                                        ich habe einen eigenen block angelegt füt teckin - jetzt muss ich entscheiden, was angezeigt wird - mit oder ohne energie
                                          @Meister-Mopper
                                          ja gib mir meldung
                                          Meister MopperM
                                          Meister MopperM
                                          Meister Mopper
                                          #81
                                          @liv-in-sky Ich würd mit Energie empfehlen.
                                          Proxmox und HA ...
                                          84.2k
