  4. Test Adapter fb-checkpresence v0.1.x
    6.0k
fb-checkpresence adapter
346 Beiträge 30 Kommentatoren 73.6k Aufrufe 25 Beobachtet
  • Z zahnheinrich
    @afuerhoff
    Hallo, hat schon jemand InfluxDB getestet?
    Jupp:
    Bekomme für beide devices: No history before this day is available (lastVal = null)
    obwohl der Adapter schon einige Tage rennt ohne Fehlermeldungen.
    Das debug-log:
    fb-checkpresence.0	2019-12-09 15:19:00.883	debug	state fb-checkpresence.0.TerrysSamsungS7.historyHtml changed: <table class="mdui-table"><thead><tr><th>Status</th><th>Date</th></tr></thead><tbody><tr><td><div class="mdui-green-bg mdui-state mdui-car
    fb-checkpresence.0	2019-12-09 15:19:00.883	debug	state fb-checkpresence.0.TerrysSamsungS7.history changed: [{"Active":"true","Date":"2019.12.09 03:18:17"},{"Active":"true","Date":"2019.12.09 02:39:00"},{"Active":"false","Date":"2019.12.09 02:37:00"}
    fb-checkpresence.0	2019-12-09 15:19:00.883	debug	state fb-checkpresence.0.TerrysSamsungS7.absent.sum_day changed: 179 (ack = true)
    fb-checkpresence.0	2019-12-09 15:19:00.882	debug	state fb-checkpresence.0.TerrysSamsungS7.present.sum_day changed: 740 (ack = true)
    fb-checkpresence.0	2019-12-09 15:19:00.882	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.historyHtml {"val":"<table class=\"mdui-table\"><thead><tr><th>Status</th><th>Date</th></tr></thead><tbody><tr><td><div cl
    fb-checkpresence.0	2019-12-09 15:19:00.881	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.history {"val":"[{\"Active\":\"true\",\"Date\":\"2019.12.09 03:18:17\"},{\"Active\":\"true\",\"Date\":\"2019.12.09 02:39:0
    fb-checkpresence.0	2019-12-09 15:19:00.881	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.absent.sum_day {"val":179,"ack":true,"ts":1575901140874,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.us
    fb-checkpresence.0	2019-12-09 15:19:00.881	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.present.sum_day {"val":740,"ack":true,"ts":1575901140873,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.u
    fb-checkpresence.0	2019-12-09 15:19:00.875	info	TerrysSamsungS7: No history before this day is available (lastVal = null)
    fb-checkpresence.0	2019-12-09 15:19:00.875	debug	redis pmessage messagebox.system.adapter.fb-checkpresence.0 messagebox.system.adapter.fb-checkpresence.0 {"command":"getHistory","message":{"result":[{"ack":true,"from":"system.adapter.influxdb.0","q
    fb-checkpresence.0	2019-12-09 15:19:00.860	debug	sendTo "getHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2019-12-09 15:19:00.860	debug	redis pmessage messagebox.system.adapter.fb-checkpresence.0 messagebox.system.adapter.fb-checkpresence.0 {"command":"getHistory","message":{"result":[{"val":true,"ts":1575824521227},{"ack":true,"from
    fb-checkpresence.0	2019-12-09 15:19:00.860	debug	state fb-checkpresence.0.presence changed: true (ack = true)
    fb-checkpresence.0	2019-12-09 15:19:00.859	debug	state fb-checkpresence.0.presenceAll changed: true (ack = true)
    fb-checkpresence.0	2019-12-09 15:19:00.858	debug	state fb-checkpresence.0.html changed: <table class="mdui-table"><thead><tr><th>Name</th><th>Status</th><th>Kommt</th><th>Geht</th></tr></thead><tbody><tr><td>UlisSamsungS7</td><td><div class="mdui-gr
    fb-checkpresence.0	2019-12-09 15:19:00.858	debug	state fb-checkpresence.0.json changed: [{"Name":"UlisSamsungS7","Active":"true","Kommt":"2019.12.09 01:48:00","Geht":"2019.12.09 01:46:00"},{"Name":"TerrysSamsungS7","Active":"true","Kommt":"2019.12.0
    fb-checkpresence.0	2019-12-09 15:19:00.858	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.presence {"val":true,"ack":true,"ts":1575901140843,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.admin","lc":157589
    fb-checkpresence.0	2019-12-09 15:19:00.858	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.presenceAll {"val":true,"ack":true,"ts":1575901140843,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.admin","lc":157
    fb-checkpresence.0	2019-12-09 15:19:00.857	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.html {"val":"<table class=\"mdui-table\"><thead><tr><th>Name</th><th>Status</th><th>Kommt</th><th>Geht</th></tr></thead><tbody><tr><td>Uli
    fb-checkpresence.0	2019-12-09 15:19:00.857	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.json {"val":"[{\"Name\":\"UlisSamsungS7\",\"Active\":\"true\",\"Kommt\":\"2019.12.09 01:48:00\",\"Geht\":\"2019.12.09 01:46:00\"},{\"Name\
    fb-checkpresence.0	2019-12-09 15:19:00.849	debug	checkPresence scheduled
    fb-checkpresence.0	2019-12-09 15:19:00.848	debug	sendTo "getHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2019-12-09 15:19:00.847	debug	history start
    fb-checkpresence.0	2019-12-09 15:19:00.846	debug	state fb-checkpresence.0.TerrysSamsungS7.absent.since changed: 0 (ack = true)
    fb-checkpresence.0	2019-12-09 15:19:00.845	debug	state fb-checkpresence.0.TerrysSamsungS7.present.since changed: 40 (ack = true)
    fb-checkpresence.0	2019-12-09 15:19:00.844	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.absent.since {"val":0,"ack":true,"ts":1575901140834,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.a
    fb-checkpresence.0	2019-12-09 15:19:00.844	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.present.since {"val":40,"ack":true,"ts":1575901140834,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user
    fb-checkpresence.0	2019-12-09 15:19:00.843	debug	getActive [{"Name":"UlisSamsungS7","Active":"true","Kommt":"2019.12.09 01:48:00","Geht":"2019.12.09 01:46:00"},{"Name":"TerrysSamsungS7","Active":"true","Kommt":"2019.12.09 02:39:00","Geht":"2019.12.0
    fb-checkpresence.0	2019-12-09 15:19:00.834	debug	getActive TerrysSamsungS7 1
    fb-checkpresence.0	2019-12-09 15:19:00.833	debug	body response: {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n <s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:
    fb-checkpresence.0	2019-12-09 15:19:00.801	debug	state fb-checkpresence.0.UlisSamsungS7.historyHtml changed: <table class="mdui-table"><thead><tr><th>Status</th><th>Date</th></tr></thead><tbody><tr><td><div class="mdui-green-bg mdui-state mdui-card"
    fb-checkpresence.0	2019-12-09 15:19:00.801	debug	state fb-checkpresence.0.UlisSamsungS7.history changed: [{"Active":"true","Date":"2019.12.09 03:18:17"},{"Active":"true","Date":"2019.12.09 01:48:00"},{"Active":"false","Date":"2019.12.09 01:46:00"},{
    fb-checkpresence.0	2019-12-09 15:19:00.801	debug	state fb-checkpresence.0.UlisSamsungS7.absent.sum_day changed: 644 (ack = true)
    fb-checkpresence.0	2019-12-09 15:19:00.801	debug	state fb-checkpresence.0.UlisSamsungS7.present.sum_day changed: 275 (ack = true)
    fb-checkpresence.0	2019-12-09 15:19:00.800	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.historyHtml {"val":"<table class=\"mdui-table\"><thead><tr><th>Status</th><th>Date</th></tr></thead><tbody><tr><td><div clas
    fb-checkpresence.0	2019-12-09 15:19:00.800	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.history {"val":"[{\"Active\":\"true\",\"Date\":\"2019.12.09 03:18:17\"},{\"Active\":\"true\",\"Date\":\"2019.12.09 01:48:00\
    fb-checkpresence.0	2019-12-09 15:19:00.800	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.absent.sum_day {"val":644,"ack":true,"ts":1575901140793,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user
    fb-checkpresence.0	2019-12-09 15:19:00.800	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.present.sum_day {"val":275,"ack":true,"ts":1575901140793,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.use
    fb-checkpresence.0	2019-12-09 15:19:00.794	info	UlisSamsungS7: No history before this day is available (lastVal = null)
    fb-checkpresence.0	2019-12-09 15:19:00.794	debug	redis pmessage messagebox.system.adapter.fb-checkpresence.0 messagebox.system.adapter.fb-checkpresence.0 {"command":"getHistory","message":{"result":[{"ack":true,"from":"system.adapter.influxdb.0","q
    fb-checkpresence.0	2019-12-09 15:19:00.779	debug	sendTo "getHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2019-12-09 15:19:00.779	debug	redis pmessage messagebox.system.adapter.fb-checkpresence.0 messagebox.system.adapter.fb-checkpresence.0 {"command":"getHistory","message":{"result":[{"val":true,"ts":1575793020415},{"ack":true,"from
    fb-checkpresence.0	2019-12-09 15:19:00.773	debug	sendTo "getHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2019-12-09 15:19:00.773	debug	history start
    fb-checkpresence.0	2019-12-09 15:19:00.766	debug	getActive [{"Name":"UlisSamsungS7","Active":"true","Kommt":"2019.12.09 01:48:00","Geht":"2019.12.09 01:46:00"},
    fb-checkpresence.0	2019-12-09 15:19:00.766	debug	state fb-checkpresence.0.UlisSamsungS7.absent.since changed: 0 (ack = true)
    fb-checkpresence.0	2019-12-09 15:19:00.766	debug	state fb-checkpresence.0.UlisSamsungS7.present.since changed: 91 (ack = true)
    fb-checkpresence.0	2019-12-09 15:19:00.766	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.absent.since {"val":0,"ack":true,"ts":1575901140761,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.adm
    fb-checkpresence.0	2019-12-09 15:19:00.766	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.present.since {"val":91,"ack":true,"ts":1575901140761,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.a
    fb-checkpresence.0	2019-12-09 15:19:00.760	debug	getActive UlisSamsungS7 1
    fb-checkpresence.0	2019-12-09 15:19:00.760	debug	body response: {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n <s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:
    fb-checkpresence.0	2019-12-09 15:19:00.721	debug	state fb-checkpresence.0.guest changed: false (ack = true)
    fb-checkpresence.0	2019-12-09 15:19:00.719	debug	state fb-checkpresence.0.activeDevices changed: 67 (ack = true)
    fb-checkpresence.0	2019-12-09 15:19:00.719	debug	state fb-checkpresence.0.guest.count changed: 0 (ack = true)
    fb-checkpresence.0	2019-12-09 15:19:00.719	debug	state fb-checkpresence.0.guest.listJson changed: [] (ack = true)
    fb-checkpresence.0	2019-12-09 15:19:00.718	debug	state fb-checkpresence.0.guest.listHtml changed: <table class="mdui-table"><thead><tr><th>Hostname</th><th>IPAddress</th><th>MACAddress</th></tr></thead><tbody></body></table> (ack = true)
    fb-checkpresence.0	2019-12-09 15:19:00.718	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.guest {"val":false,"ack":true,"ts":1575901140709,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.admin","lc":15757421
    fb-checkpresence.0	2019-12-09 15:19:00.717	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.activeDevices {"val":67,"ack":true,"ts":1575901140708,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.admin","lc":157
    fb-checkpresence.0	2019-12-09 15:19:00.717	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.guest.count {"val":0,"ack":true,"ts":1575901140708,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.admin","lc":157574
    fb-checkpresence.0	2019-12-09 15:19:00.717	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.guest.listJson {"val":"[]","ack":true,"ts":1575901140707,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.admin","lc":
    fb-checkpresence.0	2019-12-09 15:19:00.717	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.guest.listHtml {"val":"<table class=\"mdui-table\"><thead><tr><th>Hostname</th><th>IPAddress</th><th>MACAddress</th></tr></thead><tbody></
    fb-checkpresence.0	2019-12-09 15:19:00.712	debug	getGuests: 67
    fb-checkpresence.0	2019-12-09 15:19:00.709	debug	getDeviceList: [{"Index":"1","IPAddress":"192.168.3.96","MACAddress":"34:EA:34:C7:C6:C6","Active":"0","HostName":"Broadlink","InterfaceType":"","X_AVM-DE_Port":"0","X_AVM-DE_Speed":"0","X_AVM-DE_Updat
    fb-checkpresence.0	2019-12-09 15:19:00.104	debug	body response: {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n <s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:
    fb-checkpresence.0	2019-12-09 15:19:00.080	debug	body response: {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n <s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:
    fb-checkpresence.0	2019-12-09 15:19:00.080	debug	state fb-checkpresence.0.info.lastUpdate changed: 2019-12-09T14:19:00.025Z (ack = true)
    fb-checkpresence.0	2019-12-09 15:19:00.080	debug	state fb-checkpresence.0.info.connection changed: true (ack = true)
    fb-checkpresence.0	2019-12-09 15:19:00.079	debug	state fb-checkpresence.0.devices changed: 108 (ack = true)
    fb-checkpresence.0	2019-12-09 15:19:00.079	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.info.lastUpdate {"val":"2019-12-09T14:19:00.025Z","ack":true,"ts":1575901140061,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"s
    fb-checkpresence.0	2019-12-09 15:19:00.079	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.info.connection {"val":true,"ack":true,"ts":1575901140061,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.admin","lc"
    fb-checkpresence.0	2019-12-09 15:19:00.079	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.devices {"val":"108","ack":true,"ts":1575901140060,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.admin","lc":157589
    fb-checkpresence.0	2019-12-09 15:19:00.063	debug	getHostNo: 108
    fb-checkpresence.0	2019-12-09 15:19:00.062	debug	body response: {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n <s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:
    fb-checkpresence.0	2019-12-09 15:18:18.770	debug	state fb-checkpresence.0.TerrysSamsungS7.historyHtml changed: <table class="mdui-table"><thead><tr><th>Status</th><th>Date</th></tr></thead><tbody><tr><td><div class="mdui-green-bg mdui-state mdui-ca
    fb-checkpresence.0	2019-12-09 15:18:18.770	debug	state fb-checkpresence.0.TerrysSamsungS7.history changed: [{"Active":"true","Date":"2019.12.09 03:18:17"},{"Active":"true","Date":"2019.12.09 02:39:00"},{"Active":"false","Date":"2019.12.09 02:37:00"
    fb-checkpresence.0	2019-12-09 15:18:18.770	debug	state fb-checkpresence.0.TerrysSamsungS7.absent.sum_day changed: 178 (ack = true)
    fb-checkpresence.0	2019-12-09 15:18:18.770	debug	state fb-checkpresence.0.TerrysSamsungS7.present.sum_day changed: 740 (ack = true)
    fb-checkpresence.0	2019-12-09 15:18:18.770	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.historyHtml {"val":"<table class=\"mdui-table\"><thead><tr><th>Status</th><th>Date</th></tr></thead><tbody><tr><td><div c
    fb-checkpresence.0	2019-12-09 15:18:18.769	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.history {"val":"[{\"Active\":\"true\",\"Date\":\"2019.12.09 03:18:17\"},{\"Active\":\"true\",\"Date\":\"2019.12.09 02:39:
    fb-checkpresence.0	2019-12-09 15:18:18.769	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.absent.sum_day {"val":178,"ack":true,"ts":1575901098764,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.u
    fb-checkpresence.0	2019-12-09 15:18:18.768	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.present.sum_day {"val":740,"ack":true,"ts":1575901098763,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.
    fb-checkpresence.0	2019-12-09 15:18:18.758	info	TerrysSamsungS7: No history before this day is available (lastVal = null)
    fb-checkpresence.0	2019-12-09 15:18:18.757	debug	redis pmessage messagebox.system.adapter.fb-checkpresence.0 messagebox.system.adapter.fb-checkpresence.0 {"command":"getHistory","message":{"result":[{"ack":true,"from":"system.adapter.influxdb.0","
    fb-checkpresence.0	2019-12-09 15:18:18.744	debug	state fb-checkpresence.0.presence changed: true (ack = true)
    fb-checkpresence.0	2019-12-09 15:18:18.743	debug	state fb-checkpresence.0.presenceAll changed: true (ack = true)
    fb-checkpresence.0	2019-12-09 15:18:18.743	debug	state fb-checkpresence.0.html changed: <table class="mdui-table"><thead><tr><th>Name</th><th>Status</th><th>Kommt</th><th>Geht</th></tr></thead><tbody><tr><td>UlisSamsungS7</td><td><div class="mdui-g
    fb-checkpresence.0	2019-12-09 15:18:18.743	debug	state fb-checkpresence.0.json changed: [{"Name":"UlisSamsungS7","Active":"true","Kommt":"2019.12.09 01:48:00","Geht":"2019.12.09 01:46:00"},{"Name":"TerrysSamsungS7","Active":"true","Kommt":"2019.12.
    fb-checkpresence.0	2019-12-09 15:18:18.742	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.presence {"val":true,"ack":true,"ts":1575901098738,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.admin","lc":15758
    fb-checkpresence.0	2019-12-09 15:18:18.742	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.presenceAll {"val":true,"ack":true,"ts":1575901098737,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.admin","lc":15
    fb-checkpresence.0	2019-12-09 15:18:18.741	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.html {"val":"<table class=\"mdui-table\"><thead><tr><th>Name</th><th>Status</th><th>Kommt</th><th>Geht</th></tr></thead><tbody><tr><td>Ul
    fb-checkpresence.0	2019-12-09 15:18:18.741	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.json {"val":"[{\"Name\":\"UlisSamsungS7\",\"Active\":\"true\",\"Kommt\":\"2019.12.09 01:48:00\",\"Geht\":\"2019.12.09 01:46:00\"},{\"Name
    fb-checkpresence.0	2019-12-09 15:18:18.740	debug	sendTo "getHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2019-12-09 15:18:18.739	debug	redis pmessage messagebox.system.adapter.fb-checkpresence.0 messagebox.system.adapter.fb-checkpresence.0 {"command":"getHistory","message":{"result":[{"val":true,"ts":1575824521227},{"ack":true,"fro
    fb-checkpresence.0	2019-12-09 15:18:18.700	debug	checkPresence first run
    fb-checkpresence.0	2019-12-09 15:18:18.700	debug	sendTo "getHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2019-12-09 15:18:18.699	debug	history start
    fb-checkpresence.0	2019-12-09 15:18:18.698	debug	state fb-checkpresence.0.TerrysSamsungS7.absent.since changed: 0 (ack = true)
    fb-checkpresence.0	2019-12-09 15:18:18.697	debug	state fb-checkpresence.0.TerrysSamsungS7.present.since changed: 39 (ack = true)
    fb-checkpresence.0	2019-12-09 15:18:18.696	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.absent.since {"val":0,"ack":true,"ts":1575901098687,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.
    fb-checkpresence.0	2019-12-09 15:18:18.695	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.TerrysSamsungS7.present.since {"val":39,"ack":true,"ts":1575901098686,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.use
    fb-checkpresence.0	2019-12-09 15:18:18.693	debug	getActive [{"Name":"UlisSamsungS7","Active":"true","Kommt":"2019.12.09 01:48:00","Geht":"2019.12.09 01:46:00"},{"Name":"TerrysSamsungS7","Active":"true","Kommt":"2019.12.09 02:39:00","Geht":"2019.12.
    fb-checkpresence.0	2019-12-09 15:18:18.684	debug	getActive TerrysSamsungS7 1
    fb-checkpresence.0	2019-12-09 15:18:18.682	debug	</s:Envelope>
    fb-checkpresence.0	2019-12-09 15:18:18.682	debug	</s:Body>
    fb-checkpresence.0	2019-12-09 15:18:18.682	debug	</u:GetSpecificHostEntryResponse>
    fb-checkpresence.0	2019-12-09 15:18:18.682	debug	<NewHostName>TerrysSamsungS7</NewHostName>
    fb-checkpresence.0	2019-12-09 15:18:18.682	debug	<NewActive>1</NewActive>
    fb-checkpresence.0	2019-12-09 15:18:18.682	debug	<NewInterfaceType>802.11</NewInterfaceType>
    fb-checkpresence.0	2019-12-09 15:18:18.682	debug	<NewLeaseTimeRemaining>864000</NewLeaseTimeRemaining>
    fb-checkpresence.0	2019-12-09 15:18:18.682	debug	<NewAddressSource>DHCP</NewAddressSource>
    fb-checkpresence.0	2019-12-09 15:18:18.682	debug	<NewIPAddress>192.168.3.131</NewIPAddress>
    fb-checkpresence.0	2019-12-09 15:18:18.682	debug	<u:GetSpecificHostEntryResponse xmlns:u="urn:dslforum-org:service:Hosts:1">
    fb-checkpresence.0	2019-12-09 15:18:18.682	debug	<s:Body>
    fb-checkpresence.0	2019-12-09 15:18:18.682	debug	<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
    fb-checkpresence.0	2019-12-09 15:18:18.682	debug	body response: {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n <s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s
    fb-checkpresence.0	2019-12-09 15:18:18.590	debug	state fb-checkpresence.0.UlisSamsungS7.historyHtml changed: <table class="mdui-table"><thead><tr><th>Status</th><th>Date</th></tr></thead><tbody><tr><td><div class="mdui-green-bg mdui-state mdui-card
    fb-checkpresence.0	2019-12-09 15:18:18.590	debug	state fb-checkpresence.0.UlisSamsungS7.history changed: [{"Active":"true","Date":"2019.12.09 03:18:17"},{"Active":"true","Date":"2019.12.09 01:48:00"},{"Active":"false","Date":"2019.12.09 01:46:00"},
    fb-checkpresence.0	2019-12-09 15:18:18.590	debug	state fb-checkpresence.0.UlisSamsungS7.absent.sum_day changed: 643 (ack = true)
    fb-checkpresence.0	2019-12-09 15:18:18.589	debug	state fb-checkpresence.0.UlisSamsungS7.present.sum_day changed: 275 (ack = true)
    fb-checkpresence.0	2019-12-09 15:18:18.589	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.historyHtml {"val":"<table class=\"mdui-table\"><thead><tr><th>Status</th><th>Date</th></tr></thead><tbody><tr><td><div cla
    fb-checkpresence.0	2019-12-09 15:18:18.588	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.history {"val":"[{\"Active\":\"true\",\"Date\":\"2019.12.09 03:18:17\"},{\"Active\":\"true\",\"Date\":\"2019.12.09 01:48:00
    fb-checkpresence.0	2019-12-09 15:18:18.587	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.absent.sum_day {"val":643,"ack":true,"ts":1575901098579,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.use
    fb-checkpresence.0	2019-12-09 15:18:18.584	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.present.sum_day {"val":275,"ack":true,"ts":1575901098578,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.us
    fb-checkpresence.0	2019-12-09 15:18:18.574	info	UlisSamsungS7: No history before this day is available (lastVal = null)
    fb-checkpresence.0	2019-12-09 15:18:18.569	debug	redis pmessage messagebox.system.adapter.fb-checkpresence.0 messagebox.system.adapter.fb-checkpresence.0 {"command":"getHistory","message":{"result":[{"ack":true,"from":"system.adapter.influxdb.0","
    fb-checkpresence.0	2019-12-09 15:18:18.558	debug	sendTo "getHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2019-12-09 15:18:18.555	debug	redis pmessage messagebox.system.adapter.fb-checkpresence.0 messagebox.system.adapter.fb-checkpresence.0 {"command":"getHistory","message":{"result":[{"val":true,"ts":1575793020415},{"ack":true,"fro
    fb-checkpresence.0	2019-12-09 15:18:18.542	debug	sendTo "getHistory" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2019-12-09 15:18:18.541	debug	history start
    fb-checkpresence.0	2019-12-09 15:18:18.317	debug	state fb-checkpresence.0.UlisSamsungS7.absent.since changed: 0 (ack = true)
    fb-checkpresence.0	2019-12-09 15:18:18.316	debug	state fb-checkpresence.0.UlisSamsungS7.present.since changed: 90 (ack = true)
    fb-checkpresence.0	2019-12-09 15:18:18.316	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.absent.since {"val":0,"ack":true,"ts":1575901098303,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.ad
    fb-checkpresence.0	2019-12-09 15:18:18.315	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.UlisSamsungS7.present.since {"val":90,"ack":true,"ts":1575901098299,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.
    fb-checkpresence.0	2019-12-09 15:18:18.313	debug	getActive [{"Name":"UlisSamsungS7","Active":"true","Kommt":"2019.12.09 01:48:00","Geht":"2019.12.09 01:46:00"},
    fb-checkpresence.0	2019-12-09 15:18:18.296	debug	getActive UlisSamsungS7 1
    fb-checkpresence.0	2019-12-09 15:18:18.293	debug	</s:Envelope>
    fb-checkpresence.0	2019-12-09 15:18:18.293	debug	</s:Body>
    fb-checkpresence.0	2019-12-09 15:18:18.293	debug	</u:GetSpecificHostEntryResponse>
    fb-checkpresence.0	2019-12-09 15:18:18.293	debug	<NewHostName>UlisSamsungS7</NewHostName>
    fb-checkpresence.0	2019-12-09 15:18:18.293	debug	<NewActive>1</NewActive>
    fb-checkpresence.0	2019-12-09 15:18:18.293	debug	<NewInterfaceType>802.11</NewInterfaceType>
    fb-checkpresence.0	2019-12-09 15:18:18.293	debug	<NewLeaseTimeRemaining>0</NewLeaseTimeRemaining>
    fb-checkpresence.0	2019-12-09 15:18:18.293	debug	<NewAddressSource>DHCP</NewAddressSource>
    fb-checkpresence.0	2019-12-09 15:18:18.293	debug	<NewIPAddress>192.168.3.136</NewIPAddress>
    fb-checkpresence.0	2019-12-09 15:18:18.293	debug	<u:GetSpecificHostEntryResponse xmlns:u="urn:dslforum-org:service:Hosts:1">
    fb-checkpresence.0	2019-12-09 15:18:18.293	debug	<s:Body>
    fb-checkpresence.0	2019-12-09 15:18:18.293	debug	<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
    fb-checkpresence.0	2019-12-09 15:18:18.293	debug	body response: {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n <s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s
    fb-checkpresence.0	2019-12-09 15:18:18.251	debug	state fb-checkpresence.0.guest changed: false (ack = true)
    fb-checkpresence.0	2019-12-09 15:18:18.251	debug	state fb-checkpresence.0.activeDevices changed: 68 (ack = true)
    fb-checkpresence.0	2019-12-09 15:18:18.250	debug	state fb-checkpresence.0.guest.count changed: 0 (ack = true)
    fb-checkpresence.0	2019-12-09 15:18:18.250	debug	state fb-checkpresence.0.guest.listJson changed: [] (ack = true)
    fb-checkpresence.0	2019-12-09 15:18:18.250	debug	state fb-checkpresence.0.guest.listHtml changed: <table class="mdui-table"><thead><tr><th>Hostname</th><th>IPAddress</th><th>MACAddress</th></tr></thead><tbody></body></table> (ack = true)
    fb-checkpresence.0	2019-12-09 15:18:18.249	debug	redis pmessage io.fb-checkpresence.0.* io.fb-checkpresence.0.guest {"val":false,"ack":true,"ts":1575901098240,"q":0,"from":"system.adapter.fb-checkpresence.0","user":"system.user.admin","lc":1575742
    afuerhoffA Offline
    afuerhoffA Offline
    afuerhoff
    #315
    @zahnheinrich sagte in Test Adapter fb-checkpresence v0.1.x:
    @afuerhoff
    Jupp:
    Hallo, hast Du immer noch diese Meldung im Log? Ich habe inzwischen eine neue Version 0.2.0 in der Testrubrik gepostet. Falls Interesse bitte testen.
    Z 3 Antworten Letzte Antwort
    • afuerhoffA afuerhoff
      @afuerhoff
      Jupp:
      Z Offline
      Z Offline
      zahnheinrich
      #316
      @afuerhoff
      Danke für den Hinweis.
      Teste ich und melde mich.
      Grüße Ulrich
      MfG Ulrich
        @afuerhoff
        Jupp:
        Z Offline
        Z Offline
        zahnheinrich
        #317
        @afuerhoff
        Noch eine Frage zum Verständnis:
        Muss ich und wenn ja welche spezielle(n) Datenpunkte in InfluxDB loggen?
        MfG Ulrich
        • Z zahnheinrich
          @afuerhoff
          afuerhoffA Offline
          afuerhoffA Offline
          afuerhoff
          #318
          @afuerhoff
          Der Adapter stellt die History selber ein. Du musst nur in der Konfiguration den History Adapter auswählen.
          Gruß Achim
          Z 1 Antwort Letzte Antwort
            @afuerhoff
            Gruß Achim
            Z Offline
            Z Offline
            zahnheinrich
            #319
            @afuerhoff
            Ok danke.
            Dachte ich mir zwar, aber sicher ist sicher...
            MfG Ulrich
              @afuerhoff
              Jupp:
              Z Offline
              Z Offline
              zahnheinrich
              schrieb am zuletzt editiert von zahnheinrich
              #320
              @afuerhoff
              @afuerhoff sagte in Test Adapter fb-checkpresence v0.1.x:
              Leider ja!
              Adapter (neueste Vers.) läuft seit einigen Tagen, trotzdem kommt:
              fb-checkpresence.0	2020-01-09 15:03:00.890	info	(27205) TerrysSamsungS50: No history before this day is available (lastVal = null)
              fb-checkpresence.0	2020-01-09 15:03:00.829	info	(27205) UlisSamsungS50: No history before this day is available (lastVal = null)
              MfG Ulrich
              afuerhoffA 2 Antworten Letzte Antwort
              • Z zahnheinrich
                @afuerhoff
                Leider ja!
                afuerhoffA Offline
                afuerhoffA Offline
                afuerhoff
                #321
                @zahnheinrich
                Kannst du die Historienwerte aus der ioBroker Objeksicht von einem Familienmitglied einmal hier posten.
                  @zahnheinrich
                  Z Offline
                  Z Offline
                  zahnheinrich
                  #322
                  @afuerhoff
                  Bitteschön:
                  false	true	fb-checkpresence.0	2020-01-07 13:07:17.038
                  false	true	fb-checkpresence.0	2020-01-08 11:25:00.879
                  true	true	fb-checkpresence.0	2020-01-08 11:28:00.765
                  false	true	fb-checkpresence.0	2020-01-08 15:26:00.820
                  true	true	fb-checkpresence.0	2020-01-08 16:24:00.894
                  false	true	fb-checkpresence.0	2020-01-08 17:16:00.835
                  true	true	fb-checkpresence.0	2020-01-08 17:18:00.754
                  false	true	fb-checkpresence.0	2020-01-09 01:22:00.764
                  true	true	fb-checkpresence.0	2020-01-09 09:49:01.226
                  false	true	fb-checkpresence.0	2020-01-09 14:04:00.847
                  true	true	fb-checkpresence.0	2020-01-09 14:50:00.974
                  MfG Ulrich
                  • Z zahnheinrich
                    @afuerhoff
                    Bitteschön:
                    afuerhoffA Offline
                    afuerhoffA Offline
                    afuerhoff
                    #323
                    @zahnheinrich
                    Die Historie sieht gut aus. Da muss noch ein Fehler in der Auswertung sein. Werden denn die Objekte mit den richtigen Werten beschrieben, oder fehlt da was?
                    • O Offline
                      O Offline
                      onkel-ede
                      #324
                      ich habe bei der Visualisierung des Zeitpunktes einen Versatz von 1 Stunde. Wo finde ich eine Einstellmöglichkeit, dies zu korrigieren:
                      onkel-ede
                      • cvidalC cvidal
                        Hi, danke für den Adapter die Installation und Einrichtung lief bei mir Problemlos.
                        Ich würde mir noch den History Adapter Influxdb wünschen oder steht das schon auf deiner To do Liste?
                        Absent.since bzw. Absent.sum_day verstehe ich noch nicht so ganz.
                        Abwesend seit x min. ist klar, bei mir jetzt 53min aber sollte das nicht in sum_day auch stehen? hier steht jetzt -1 oder wann wird der Wert Aktualisiert?
                        Top Adapter, der könnte mir ein Paar Skripte ablösen.
                        Gruß Christian
                        afuerhoffA Offline
                        afuerhoffA Offline
                        afuerhoff
                        #325
                        @cvidal sagte in Test Adapter fb-checkpresence v0.1.x:
                        Hallo, es gibt inzwischen eine Version 0.2.0 die Influxdb enthält. Bitte testen.
                        cvidalC 1 Antwort Letzte Antwort
                        • O onkel-ede
                          onkel-ede
                          afuerhoffA Offline
                          afuerhoffA Offline
                          afuerhoff
                          #326
                          @onkel-ede sagte in Test Adapter fb-checkpresence v0.1.x:
                          Hallo, du kannst im VIS Timestamp (basic Widget) verwenden. Damit sollte es so angezeigt werden, wie du es formatierst.
                            cvidalC Offline
                            cvidalC Offline
                            cvidal
                            Forum Testing
                            #327
                            Hab ich jetzt installiert, lief ohne Probleme.
                            Ich lasse es jetzt mal ein Paar Tage laufen und werde berichten.
                            Besten Dank
                            • O Offline
                              O Offline
                              onkel-ede
                              #328
                              @afuerhoff: Danke für den Tipp mit VIS Timestamp (basic Widget), hat funktioniert. Version 0.2.0 teste ich ebenfalls.
                              • cvidalC cvidal
                                Besten Dank
                                afuerhoffA Offline
                                afuerhoffA Offline
                                afuerhoff
                                schrieb am zuletzt editiert von afuerhoff
                                #329
                                @cvidal @onkel-ede
                                Ergebnisse dann bitte unter 0.2.0 posten.
                                • Z zahnheinrich
                                  @afuerhoff
                                  Leider ja!
                                  afuerhoffA Offline
                                  afuerhoffA Offline
                                  afuerhoff
                                  #330
                                  @afuerhoff
                                  Leider ja!
                                  Hallo, kannst Du von einem der beiden Familienmitglieder mal das Objekt "history"
                                  (json table) hier unter der Version 0.2.0 posten. Ich kann den Zustand "lastVal = null" nicht nachvollziehen. Diese Meldung kommt nur, wenn es vor dem aktuellen Tag keine Historie gibt. Dies kann aber nur nach erstmaliger Anlage des Familienmitglieds für einen Tag auftreten.
                                    @afuerhoff
                                    Leider ja!
                                    Z Offline
                                    Z Offline
                                    zahnheinrich
                                    #331
                                    @afuerhoff
                                    Ja, mach ich gerne, bin aber bis nächste Woche abwesend!
                                    Poste ich, sobald möglich!
                                    Gruß Ulrich
                                    MfG Ulrich
                                    • Z zahnheinrich
                                      @afuerhoff
                                      Gruß Ulrich
                                      afuerhoffA Offline
                                      afuerhoffA Offline
                                      afuerhoff
                                      #332
                                      @afuerhoff
                                      Gruß Ulrich
                                      Hallo, ich habe einen Bugfix Version 0.2.1 auf Github veröffentlicht . Bitte nach Rückkehr mal testen.
                                        @afuerhoff
                                        Gruß Ulrich
                                        Z Offline
                                        Z Offline
                                        zahnheinrich
                                        #333
                                        @afuerhoff
                                        Habe die letzte Version installiert.
                                        Läuft jetzt ohne FM.
                                        Brauchst du trotzdem noch Daten?
                                        Gruß Ulrich
                                        MfG Ulrich
                                        • Z zahnheinrich
                                          @afuerhoff
                                          Gruß Ulrich
                                          afuerhoffA Offline
                                          afuerhoffA Offline
                                          afuerhoff
                                          #334
                                          @zahnheinrich
                                          Hallo, du kannst mal schauen, ob bei dem Familienmitglied mit Fehlermeldungen im Historienverlauf Null Werte waren. Das würde zur Fehlerbehebung passen.
