  4. JavaScript
  5. TV Programm Mini Anzeige - HTML Tabelle
javascript
327 Beiträge 20 Kommentatoren 81.3k Aufrufe 29 Beobachtet
  • NashraN Offline
    NashraN Offline
    Nashra
    Most Active Forum Testing
    #69
    Da passte etwas noch nicht so ganz...
    const htmlSigPadLeft="10px";
    const htmlSigPadRight="10px";
    var htmlUnter= "<p></p><div style=\"padding-right:"+htmlSigPadRight+"; padding-left:"+htmlSigPadLeft+"; color:"+html
    Gruß Ralf
    • liv-in-skyL liv-in-sky
      falls jemand ein popup ( in der vis) für die anzeige braucht - das ganze nimmt viel platz ein - hier ein beispiel
      importieren und den datenpunkt angelichen
      [{"tpl":"tplJquiDialog","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"title":"TV Gleich","html":"\n<center><b>TV Gleich</b></center","html_dialog":"{controll-own.0.TABELLEN.TVgleich}","dialog_width":"480","dialog_height":"580","modal":true,"closeOnClick":true},"style":{"left":"839px","top":"430px","width":"66px","height":"38px","background":"linear-gradient(to top, #80CB74 2px, #81A17C 55px )","color":"#52f651"},"widgetSet":"jqui"}]
      ChaotC Offline
      ChaotC Offline
      Chaot
      #70
      @liv-in-sky Das Popup ist eine geniale Sache.
      Aber wie kann ich das einstellen das der an einer bestimmten Stelle mit einer bestimmten Größe aufgeht?
      In den Punkten Dialogbreite ändert sich nichts und bei Position oben/links gibt es auch keine Änderung.
      sigi234S liv-in-skyL 2 Antworten Letzte Antwort
      • ChaotC Chaot
        sigi234S Online
        sigi234S Online
        #71
        @Chaot sagte in TV Programm Mini Anzeige - HTML Tabelle:
        • ChaotC Chaot
          liv-in-skyL Offline
          liv-in-skyL Offline
          #72
          @Chaot dort habe ich es auch eingestellt - so wie bei sigi
            sigi234S Online
            sigi234S Online
            #73
            @liv-in-sky sagte in TV Programm Mini Anzeige - HTML Tabelle:
            Schätze mal px vergessen!
            • sigi234S sigi234
              ChaotC Offline
              ChaotC Offline
              Chaot
              #74
              @sigi234 😯 Jupp 😡 px vergessen.
              Danke euch!
              • NashraN Offline
                NashraN Offline
                Nashra
                #75
                Moin @liv-in-sky
                wollte nochmal Danke sagen für die Scripte, laufen einwandfrei 👍
                Gruß Ralf
                • NashraN Nashra
                  Moin @liv-in-sky
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  #76
                  @Nashra wenn du lust hast, dann poste mal eines deiner scripte - evtl. übernehmeich dann die zusätzlichen einstellungen
                    NashraN Offline
                    NashraN Offline
                    Nashra
                    #77
                    Aber klar doch...
                    Bei der Ausgabe "Das Programm..." habe ich nur den Eintrag von "Last Update..." entfernt
                    und in der Sig umgekehrt, aber das siehst du ja. Kann man auch mit "let" lösen ob oben
                    und unten entsprechend angezeigt wird.
                     //HIER WIRD PFAD UND FILENAME DEFINIERT
                     const path = "/htmltvjetzt.html";                   //FIlenamen definieren
                     const home ='vis.0'                                 //wo soll das file im iobroker-file-system liegen ? (oder z.b auch iqontrol.meta)
                     let   braucheEinFile=false;                          // bei true wird ein file geschrieben
                     let   braucheEinVISWidget=true;                     // bei true wird ein html-tabelle in einen dp geschrieben - siehe nächste zeile
                     let dpVIS="0_userdata.0.TV-Programm.TVjetzt"         //WICHTIG wenn braucheEinVISWidget auf true gesetzt !!  dp zusätzlich für VIS-HTML-Basic-Widget
                     let mySchedule="  0,20,40 9-23,0 * * * ";                       //jede minute
                    //HIER DIE SPALTEN ANZAHL DEFINIEREN - jede Spalte einen Wert - in diesem Beispiel sind es 3
                    var htmlFeld1='SENDER';      var Feld1lAlign="left";                     // überschrift Tabellen Spalte1 und  Ausrichtung left,right or center
                    var htmlFeld2='SEIT';        var Feld2lAlign="center";                      // überschrift Tabellen Spalte2 und  Ausrichtung left,right or center
                    var htmlFeld3='SENDUNG';         var Feld3lAlign="left";                    // überschrift Tabellen Spalte3 und  Ausrichtung left,right or center
                    //hier werden die styles für die tabelle definiert
                    //ÜBERSCHRIFT ÜBER TABELLE
                    let   htmlUberschrift=true;                           // mit Überschrift über der tabelle
                    let   htmlSignature=true;                              // anstatt der Überscghrift eine signature: - kleiner - anliegend
                    const htmlFeldUeber='Das TV Programm - Jetzt im Programm';              // Überschrift
                    const htmlSchriftWeite="normal";
                    const htmlSchriftUeberGroesse="13px";
                    const htmlFarbUber="#40FF00";                         // Farbe der Überschrift
                    //Unter der Tabelle
                    const htmlSchriftUntenGroesse="12px";
                    const htmlSchrifFarbeUnten="#40FF00";
                    const htmlSigTextAlign="right";
                    //MEHRERE TABELLEN NEBENEINANDER
                    let   mehrfachTabelle=1;                              // bis zu 4 Tabellen werden nebeneinander geschrieben-  verkürzt das Ganze, dafür etwas breiter - MÖGLICH 1,2,3,oder 4 !!!
                    const htmlFarbZweiteTabelle="blue"; //"#00FF00";                // Farbe der Überschrift bei jeder 2.ten Tabelle
                    const htmlFarbTableColorUber="blue";               // Überschrift in der tabelle - der einzelnen Spalten
                    //GANZE TABELLE
                    let abstandZelle="2";
                    let weite="auto";  //"805px";                                     //Weite der Tabelle
                    let zentriert=true;                                   //ganze tabelle zentriert
                    const backgroundAll="#000000";                        //Hintergrund für die ganze Seite - für direkten aufruf oder iqontrol sichtber - keine auswirkung auf vis-widget
                    const htmlSchriftart="RobotoCondensed-Regular"; //"Helvetica";
                    const htmlSchriftgroesse="13px";
                    //FELDER UND RAHMEN
                    let   UeberschriftSpalten=true;                // ein- oder ausblenden der spatlen-überschriften
                    const htmlFarbFelderschrift="#000000";                  // SchriftFarbe der Felder
                    const htmlFarbFelderschrift2="#000000";                 // SchriftFarbe der Felder für jede 2te Tabelle
                    const htmlFarbTableColorGradient1="#FFBF00";          //  Gradient - Hintergrund der Tabelle - Verlauffarbe
                    const htmlFarbTableColorGradient2="#D7DF01";          //  Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
                    const htmlFarbTableBorderColor="blue";             // Farbe des Rahmen - is tdieser gleich den gradienten, sind die rahmen unsichtbar
                    let htmlRahmenLinien="all";                            // Format für Rahmen: MÖGLICH: "none" oder "all" oder "cols" oder "rows"
                    const htmlSpalte1Weite="auto";                   //  Weite der ersten beiden  Spalten oder z.b. 115px
                    // HIER NICHTS  ÄNDERN
                    let borderHelpBottum;
                    let borderHelpRight;
                    let htmlcenterHelp;
                    let htmlcenterHelp2;
                    if(htmlRahmenLinien=="rows") {borderHelpBottum=1;borderHelpRight=0;}
                    if(htmlRahmenLinien=="cols") {borderHelpBottum=0;borderHelpRight=1;}
                    if(htmlRahmenLinien=="none") {borderHelpBottum=0;borderHelpRight=0;}
                    if(htmlRahmenLinien=="all")  {borderHelpBottum=1;borderHelpRight=1;}
                    zentriert ? htmlcenterHelp="auto" : htmlcenterHelp="left";
                    zentriert ? htmlcenterHelp2="center" : htmlcenterHelp2="left";
                    const htmlEnd=      '</table></div></body>';
                    const htmlZentriert='<center>'
                    const htmlStart=    "<!DOCTYPE html><html lang=\"de\"><head><title>Vorlage</title><meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\">"+
                                        "<style> * {  margin: 0;} body {background-color: "+backgroundAll+"; margin: 0 auto;  }"+
                                        " p {padding-top: 10px; padding-bottom: 10px; text-align: "+htmlcenterHelp2+"}"+
                                       // " div { margin: 0 auto;  margin-left: auto; margin-right: auto;}"+
                                        " td { padding:"+abstandZelle+"px; border:0px solid "+htmlFarbTableBorderColor+";  border-right:"+borderHelpRight+"px solid "+htmlFarbTableBorderColor+";border-bottom:"+borderHelpBottum+"px solid "+htmlFarbTableBorderColor+";}"+
                                        " table { width: "+weite+";  margin: 0 "+htmlcenterHelp+"; border:1px solid "+htmlFarbTableBorderColor+"; border-spacing=\""+abstandZelle+"0px\" ; }"+   // margin macht center
                                        " td:nth-child(1) {width: "+htmlSpalte1Weite+"}"+"td:nth-child(2) {width:"+htmlSpalte1Weite+"}"+
                                        " </style></head><body> <div>";
                    //const htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-weight: bold\">"+htmlFeldUeber+"</p>";
                    const htmlTabStyle= "<table bordercolor=\""+htmlFarbTableBorderColor+"\" border=\"2px\" cellspacing=\""+abstandZelle+"\" cellpadding=\""+abstandZelle+"\" width=\""+weite+"\" rules=\""+htmlRahmenLinien+"\" style=\"color:"+htmlFarbFelderschrift+";  font-size:"+htmlSchriftgroesse+
                                           "; font-family:"+htmlSchriftart+";background-image: linear-gradient(42deg,"+htmlFarbTableColorGradient2+","+htmlFarbTableColorGradient1+");\">";
                    const htmlTabUeber1="<tr style=\"color:"+htmlFarbTableColorUber+"; font-weight: bold\">";
                    const htmlTabUeber3="</tr>";
                    //NICHTS ÄNDERN - abhängig von den oben definierten _Spalten - in diesem Beispiel sind es 3   class=\"spalteI\"      width=\"300\"
                    		var htmlTabUeber2="<td width="+htmlSpalte1Weite+" class=\"spalteI\" align="+Feld1lAlign+">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+">&ensp;"+htmlFeld2+"&ensp;</td><td  align="+Feld3lAlign+">&ensp;"+htmlFeld3+"&ensp;</td>";
                    var htmlTabUeber2_1="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld2+
                                        "&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld3+"&ensp;</td>";
                    var url='https://www.hoerzu.de/tv-programm/jetzt/';
                     const request = require('request-promise-native');
                    var htmlTabUeber="";
                    var htmlOut="";
                    var mix;
                    var counter;
                     //HIER SIND DIE  WERTE, DIE IN DER SCHLEIFE GEFILTERET WER%DEN - Jede spalte einen wert - jeder valx muss in dieser schleife gesetzt werden !!
                     var val1; var val0; var val2;
                    async function writeHTML(){
                    htmlOut="";
                    counter=-1;
                    htmlTabUeber="";
                    switch (mehrfachTabelle) {
                        case 1: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber3;  break;
                        case 2: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                        case 3: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber3; break;
                        case 4: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                    if (!UeberschriftSpalten) {htmlTabUeber=""}
                     //---------hier kommt eure schleife rein counter++, tabelleBind() und tabelleFinish() müssen so integriert bleiben !!!------------------------------
                     //---------alle valx werte müssen von euch bestimmt werden - val0,val1,val2 !!!---------------------------------------------------------------------
                    //await
                    getTV().then(function() {
                        //getTV().then(holeTV).then(function() {
                    //await holeTV();
                     var myOjects= myObjFilter;
                     //log ("bin hier");
                     // var timeout4 = setTimeout(function () {
                      //  log("______________objetsTest: "+myOjects[14][0]+myOjects[14][1]+myOjects[14][2]);
                      //  log("______________objetsTest: "+myOjects[16][0]+myOjects[16][1]+myOjects[16][2]);
                         //log("______________objetsTest: "+myOjects[4][0]+myOjects[4][1]+myOjects[4][2]);
                       //  log ("bin hier");
                     //for(var index in myObjFilter) {counterlein++;log(counterlein+"---"+myObj[index][0]+"______"+myObj[index][2]+"______"+myObj[index][1])};
                     //var myOjects=holeTV();
                    for (var index in myOjects) {
                               counter++;                                       // SEHR WICHTIG - MUSS IN JEDER SCHLEIFE INTEGRIERT SEIN
                           val1=myOjects[index][0]; val1=val1.replace( /,/g , "");/*log(val1);*/ val1="seit: "+val1; //zeit
                           val0=myOjects[index][1]; val0=val0.replace( /,/g , ""); //log(val0);
                           val2=myOjects[index][2]; val2=val2.replace( /,/g , ""); val2=val2.replace(/-$/,"");
                           if (val2.length>=38)   val2=val2.substring(0,37)+" ..."  //log(val2);
                          tabelleBind(); //HIER NICHTS ÄNDERN : HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT  - diese function muss als letztes in der eigenen schleife aufgerufen werden
                        }; //Schleifen Ende - je nach schleifenart muss hier etwas geändert werden !!!!!!!!!
                    }).then(tabelleFinish)
                     //}, 3000);
                     //--------------------------------------------------Ende der schleife------------------------------------------------------------------------------
                         // tabelleFinish(); // AB HIER NICHTS ÄNDERN - tabelle fertigstellen
                    } // function ende
                     //MAIN:
                    schedule(mySchedule,  function () {
                      writeHTML();
                      //if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}
                     writeHTML();
                     //writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });
                     async function tabelleBind(){
                              case 1:                    htmlOut=htmlOut+"<tr><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>"; break;
                              case 2:  if(counter%2==0)  {htmlOut = htmlOut+"<tr><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; }
                                                    else {htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} break;
                              case 3: if(counter%3==0 )  {htmlOut = htmlOut+"<tr><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; }
                                                    else { if(counter%3==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";}
        else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>";}
                                                               } break;
                              case 4: if(counter%4==0)  {htmlOut = htmlOut+"<tr><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; }
                                                        else {if(counter%2==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";}
        else    {if(counter%2==1 && counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";}
        else    {htmlOut = htmlOut = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><tdalign="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>";}}
                                                               } break; } //switch ende
                    //log("bin raus aus tabelleBind");
                     async function tabelleFinish() {
                              case 1:    break;
                              case 2:    mix=Math.abs(((counter+1)%2)-mehrfachTabelle);
                                         if(mix==1)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                                         break;
                              case 3:    mix =Math.abs(((counter+1)%3)-mehrfachTabelle);
                                         if(mix==2)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                                         break;
                              case 4:    mix=Math.abs(((counter+1)%4)-mehrfachTabelle);
                                         if(mix==3)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                                         break; }
                            //var htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: "+htmlÜberFontGroesse+"; font-weight:"+htmlSchriftWeite+ "\">"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</p>";
                            //var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 70%; text-align: right;\" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>"
                            var htmlUeber= "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size:"+htmlSchriftUeberGroesse+"; font-weight:"+htmlSchriftWeite+"\">"+htmlFeldUeber+"</p>";
                            var htmlUnter= "<div style=\"padding-right:"+htmlSigPadRight+"; padding-left:"+htmlSigPadLeft+"; color:"+htmlSchrifFarbeUnten+"; font-family:"+htmlSchriftart+"; font-size:"+htmlSchriftUntenGroesse+"; text-align:"+htmlSigTextAlign+";\" >Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>"
                             if (!htmlSignature) htmlUnter="";
                               //Ausgabe über VIS html widget - tabelle in datenpunkt schreiben - html tabelle ohne html header und body
                                var htmlOutVIS="";
                              //  htmlUberschrift ? htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>" : htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>";
                                 if (htmlUberschrift)
                                     { zentriert ? htmlOutVIS=htmlZentriert+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter : htmlOutVIS=htmlUeber+"</table>"+htmlUnter ;
                                   } else {
                                    zentriert ?  htmlOutVIS=htmlZentriert+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter :  htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter;
                                if (braucheEinVISWidget) setState(dpVIS, htmlOutVIS );
                      //mit oder ohne überschrift - zentriert oder links
                      htmlUberschrift ? htmlOut=htmlStart+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd : htmlOut=htmlStart+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd;
                     // log("bin raus aus tabelleBind");
                       //getTV2();
                    var gesucht="";
                    var gefunden="";
                    var gefunden_2="";
                    var gefunden2="";
                    var gefunden2_2="";
                    var myArr2=[];   var myArr22=[];  var myArr222=[];
                    var myArr2_2=[]; var myArr22_2=[];
                    var myArr3=[];
                    var myArr3_2=[];
                    var myArr4=[];
                    var myObj=[];
                    var myObjFilter=[];
                    var counterlein=0;
                    var allesDa=true;
                    async function getTV(){
                        return new Promise(async (resolve, reject) => {
                    //try {
                       await request(url, async function (error, response, result) {
                       //console.log("result: "+result);
                       gesucht="";
                       gesucht=result; // log(" gesucht - direct_____________JETZT: "/*+ gesucht*/);
                        // setState("controll-own.0.AAATEST.TVTVTVTV",result);
                         holeTV(gesucht);
                         //log("bin raus getTV");
                         if (gesucht!="") {resolve()} else {reject()}
                    ;  }).on("error", function (e) {console.error(e);});
                    async function holeTV(gesuchtVal){
                     //log("bin in holeTV");
                      gesucht="";
                     gefunden="";
                     gefunden_2="";
                     gefunden2="";
                     gefunden2_2="";
                     myArr2=[];    myArr22=[];   myArr222=[];
                     myArr2_2=[];  myArr22_2=[];
                     myArr3=[];
                     myArr3_2=[];
                     myArr4=[];
                     myObj=[];
                     myObjFilter=[];
                     counterlein=0;
                    var re = /span>\s+<a title=".+?" data/g;
                    gesucht = gesuchtVal;
                    let missing=gesucht.match(/<H3>Es ist jetzt.+?Uhr/g);
                    missing==null? allesDa=false : allesDa=true;
                    //if (!allesDa) {/*log(" DA FEHLT WAS - bin in jetzt ! "+missing)*/}else{log("schreibe --------------JETZT","error")};
                     //log(" DA FHLT WAS ! "+ gesucht.match(/<H3>Es ist jetzt.+?Uhr/g).length.toString());
                    //gesucht.match(/<H3>Es ist jetzt.+?Uhr/g).length==0 ? allesDa=false : allesDa=true;
                    //gefunden = gesucht.match(re);
                    //gesucht=getState("controll-own.0.AAATEST.TVTVTVTV").val
                    //log("gesucht: ----------------: "+gesucht);
                     gefunden= "fff"+gesucht.match(re);
                    //gefunden=gefundenA.replace(/ data/g,"");
                                 // log("gefunden: ----------------: "+gefunden);
                              let helper2=[];
                               let helper=gefunden.match(/\".+\" data/g);
                              // log(helper.length.toString());
                              for (var i=0;i<helper.length;i++){
                                 let hhh= helper[i].replace(/,/g, " --");//          Text2.slice(((Text2.lastIndexOf(':') + 1 + 2) - 1), Text2.lastIndexOf('"') + 1 + 2);
                                 hhh=hhh.replace(/ (\d\d):(\d\d) /g, " $1\-\-\-$2 ");
                                 //log(hhh)
                                 hhh=hhh.replace(/\:/g, ";");
                                // log(hhh)
                                  hhh=hhh.replace(/(\d\d)---(\d\d)/g, " $1:$2 ");
                             //    log(hhh)
                               //   hhh=hhh.replace(/(\d\d:\d\d \d\d\.\d\d\. .+)\.(.+)/g, " $1xxx$2 ");
                                                hhh=hhh.replace(/(\d\d\.\d\d\..+)\.(.+)/g, "$1x_x_x$2 ");
                                                hhh=hhh.replace(/ data/g,"");
                                   // log("++++++++++++++++++++"+hhh)
                                  helper2.push(hhh)
                    //log("+++++++"+helper[2])
                    //log("helper2_"+helper2.toString())
                                    // log("gefunden2: ----------------: "+gefunden2);
                     var myArr    =helper2.toString().split(",");
                    //log(myArr.length.toString()+"---"+myArr[3].toString());
                    for(var i=0;i<myArr.length;i++){   var haken=myArr[i].replace( /,>/g , "");       myArr22.push(haken);}  // /,>/g , ""
                    for(var i=0;i<myArr22.length;i++){  var    haken=myArr22[i].replace("xxx","");     myArr222.push(haken);}  // /,>/g , ""
                    for(var i=0;i<myArr222.length;i++){  var    haken=myArr222[i].replace(/\"/g,"");     myArr2.push(haken);}  // /,>/g , ""
                                    //  log(myArr2.length.toString()+"---"+myArr2[3].toString());
                      for(var i=0;i<myArr2.length;i++) {
                        let val3= myArr2[i].slice(0, (myArr2[i].indexOf(':') + 1) - 5).trim(); // val3=val3.slice(0, (val3.lastIndexOf('-') + 1) - 1);   // sendung
                        let val2=myArr2[i].slice(((myArr2[i].lastIndexOf('.') + 1 + 1) - 1), myArr2[i].length).trim(); val2=val2.replace("x_x_x",".") // uhrzeit
                        let val1=myArr2[i].slice((((myArr2[i].lastIndexOf(':') + 1) - 2) - 1), myArr2[i].indexOf(':') + 1 + 2).trim();                // sender
                        //log(val2);//+"___"+val2+"___"+val3)
                         myObj.push([val1,val2,val3]);
                     //log("vor soert___________________________"+myObj[3][2].toString());
                    var mySort = ["ARD alpha","ZDFneo","n-tv","Servus TV","One","RBB","Phoenix","MDR","SWR","HR","BR","Fix&Foxi","Nicktoons","VH1 Classic","MTV Brand New","Gute Laune TV","Nautical Channel",
                    "Silverline","Penthouse Passion HD","Playboy TV","Lust Pur","Blue Hustler","RTL Living","Disney XD","RCK TV","MTV",
                    "Animal Planet","Planet","Geo Television","auto motor und sport channel","Extreme Sports Channel","SPORT1+","RTL Passion",
                    "RTL Crime","ProSieben Fun", "1 emotions","kabel eins classics","Sony Channel","Sony AXN","Jukebox","MTV Live HD","MTV HD",
                    "Stingray Classica","Boomerang","Cartoon Network","Disney Junior","Junior","TV","Heimatkanal","E! Entertainment","TNT Comedy",
                    "Romance TV","Kinowelt TV","TNT Film","TNT Serie","Universal TV","FOX","Syfy","13TH STREET","Spiegel TV Wissen","Spiegel Geschichte",
                    "Crime + Investigation","History","Der Buckingham-Palast - Geheimnisse -- Affären","National Geographic Wild",
                    "National Geographic","Discovery Channel","Motorvision TV","Sportdigital Fußball","Eurosport 2","Sky Sport Austria 1",
                    "Sky Sport News HD","Sky Sport 2 HD","Sky Sport 1 HD","Sky Sport Bundesliga 1","Sky Krimi","Sky 1","Sky Atlantic HD",
                    "Sky Cinema Special HD","Sky Cinema Family HD","Sky Cinema Nostalgie","Sky Cinema Emotion","Sky Cinema Comedy",
                    "Sky Cinema Action","Sky Cinema Hits","Sky Cinema +24","Sky Cinema +1","Sky Cinema","TRT Türk","TV 2","DR 1",
                    "Rouge TV","France 24","TV5MONDE","CNBC Paneurope","CNN","BBC World News","BBC Entertainment","Die Neue Zeit",
                    "Bibel TV","Star TV","Schweiz 5","5plus","3plus","SRF info","SRF 2","SRF 1","sixx Austria","Puls 4","ATV2","ATV",
                    "ORF Sport +","ORF 3","ORF 2","ORF 1","Spreekanal","rheinmainTV","Rhein-Neckar-Fernsehen","München TV","Hamburg 1",
                    "Franken Fernsehen","Berlin","DW English","Deutsches Anleger Fernsehen","tv","Channel 21","HSE24","QVC",
                    "Deutsches Musik Fernsehen","Deluxe Music","RiC","Anixe Plus","Anixe HD Serie","TLC","Health TV","Home & Garden TV",
                    "VOXup","ProSieben Maxx","N24 Doku","eSports1","SPORT1","Eurosport 1",
                    "Zee One","Comedy Central","Nick","KiKA",,"Tele 5","Disney Channel","Euronews","Welt der Wunder","01. NDR",
                    "WELT","Beate-Uhse.TV","sonnenklar.tv","TV.Berlin","Stingray Classica","Sat.1 emotions","tagesschau24","NICK Jr.","BonGusto"];
                    var fehlendeFilter=["One","ZDFinfo","ZDFneo","tagesschau24","ARD alpha","Phoenix","RBB","HR","SWR","BR","MDR","WDR","n-tv",
                                        "NDR","3sat","Arte","VOX","RTL Zwei","kabel eins","ProSieben","1","RTL","ZDF","Das Erste","NITRO","Servus TV","Sixx"];
                    //log("sortierung: "+mySort.length.toString())
                    //log(myObj[28][1].toString()+mySort[17]+mySort[18]+mySort[19]);
                    //for (var b =0; b<mySort.length; b++){
                        for (var b =0; b<myObj.length; b++){
                         //  if(!mySort.includes(myObj[b][0].replace( /,/g , "").trim()) && myObj[b][0].replace( /,/g , "").trim()!="" )
                           if(!mySort.includes(myObj[b][1].trim()) && myObj[b][1].trim()!="" )
                           myObjFilter.push(myObj[b]);
                        // log("unfiltered  "+myObjFilter[b][0].replace( /,/g , "").trim()+myObj[b][2]+myObj[b][1])
                           } else{
                               //myObjFilter.push(myObj[ind2]);
                               //log("filtered"+myObj[b][1])
                     //for(var ind1 in mySort) {log(mySort[ind1])}
                     //for (var intndex  in myObj){log(myObj[index][0].replace( /,/g , ""))}
                    //log(myObjFilter.length.toString()+"---"+myObjFilter.toString());
                    //log (myObjFilter.length.toString());
                    for(var index in myObjFilter) {counterlein++; /*log(counterlein.toString())*/}
                    //for(var index in myObjFilter) {counterlein++;log("\""+myObj[index][0]+"\"")};
                    //log(counterlein.toString());//
                     //log("bin raus holeTV");
                      // log(myObjFilter.toString());
                    return myObjFilter;
                    Gruß Ralf
                    • NashraN Nashra
                      Aber klar doch...
                      //Unter der Tabelle
                      //GANZE TABELLE
                      //FELDER UND RAHMEN
                      let htmlcenterHelp;
                      var htmlOut="";
                      var mix;
                      var counter;
                      htmlOut="";
                      counter=-1;
                      htmlTabUeber="";
                      //await
                      //await holeTV();
                       //log ("bin hier");
                       //}, 3000);
                      } // function ende
                       //MAIN:
                        writeHTML();
                       writeHTML();
        } break;
                                case 1:    break;
                                           break;
                                           break;
                                           break; }
                                  var htmlOutVIS="";
                                     } else {
                         //getTV2();
                      var gesucht="";
                      var gefunden="";
                      var gefunden_2="";
                      var gefunden2="";
                      var gefunden2_2="";
                      var myArr3=[];
                      var myArr3_2=[];
                      var myArr4=[];
                      var myObj=[];
                      var myObjFilter=[];
                      var counterlein=0;
                      var allesDa=true;
                      //try {
                         gesucht="";
                           holeTV(gesucht);
                        gesucht="";
                       gefunden="";
                       gefunden_2="";
                       gefunden2="";
                       gefunden2_2="";
                       myArr3=[];
                       myArr3_2=[];
                       myArr4=[];
                       myObj=[];
                       myObjFilter=[];
                       counterlein=0;
                                let helper2=[];
                                   //log(hhh)
                                  // log(hhh)
                               //    log(hhh)
                                    helper2.push(hhh)
                             } else{
                      return myObjFilter;
                      ChaotC Offline
                      ChaotC Offline
                      Chaot
                      #78
                      @Nashra Irgendwie bin ich blind.
                      Ich suche schon seit gestern in welcher Zeile ich die Sig einstellen kann.
                      In Zeile 20 ist die Überschrift und in Zeile 19 wird die Sig eingeschaltet. Aber ich sehe nicht wo der Inhalt geändert wird.
                      • ChaotC Chaot
                        NashraN Offline
                        NashraN Offline
                        Nashra
                        #79
                        Was meinst Du mit Inhalt geändert??
                        Ist das html-widget groß genug
                        Gruß Ralf
                        • NashraN Nashra
                          ChaotC Offline
                          ChaotC Offline
                          Chaot
                          #80
                          @Nashra Nein. Ich meine den Text der in der Sig geschrieben wird.
                          • ChaotC Chaot
                            NashraN Offline
                            NashraN Offline
                            Nashra
                            #81
                            Zeile 213
                            Gruß Ralf
                            • NashraN Nashra
                              Zeile 213
                              ChaotC Offline
                              ChaotC Offline
                              Chaot
                              #82
                              @Nashra 👍 👍 Danke 👓
                              • NashraN Offline
                                NashraN Offline
                                Nashra
                                #83
                                Moin @liv-in-sky
                                wo und wie kann ich die Textlänge in der dritten Spalte ändern d.h. müßten so
                                vllt 3-4 Buchstaben weniger sein.
                                Die ganzen Tage wurde es sauber dargestellt, aber heute hat es ein Problem.
                                Gruß Ralf
                                • NashraN Nashra
                                  Moin @liv-in-sky
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  #84
                                  @Nashra kannst du der tabelle ein wenig mehr breite spendieren in der vis - dann gehts wieder - ansonsten müßte ich im script den sendungsnamen noch weiter kürzen
                                  NashraN S 2 Antworten Letzte Antwort
                                    NashraN Offline
                                    NashraN Offline
                                    Nashra
                                    #85
                                    Jep, kann ich auch machen und passe die anderen auch direkt an :-)
                                    Gruß Ralf
                                      Markus_ResPi3
                                      #86
                                      Erstmal Top Arbeit von euch allen Funktioniert super!!!!
                                      ich hätte nur mal ne dumme Frage kann man auch zwei verschieden Tabelen nebeinander anzeigen lassen als links "läuft jetzt im TV" und rechts neben dran "läuft gleich im TV"?
                                      Habe mal geschaut du hast ja im script schon beide URL drin.
                                        skokarl
                                        schrieb am zuletzt editiert von skokarl
                                        #87
                                        @liv-in-sky und den Helfern natürlich ....
                                        Super DANKE, Klassse. 👍 👍 👍
                                          skokarl
                                          #88
                                          Was muss ich noch einstellen damit er automatisch aktualisiert ? Irgendwie
                                          tut er es nicht..... aber im Script ist es doch drin.
                                          Muss beim Widget was eingestellt werden ?
                                          Und die Königsdisziplin ( ich kann es leider nicht ) wäre jetzt natürlich ich könnte die Zeiten eingeben....
                                          Zwischen gleich und 20:15 gibts ja nachmittags noch die Enkelkinderstunde. 😇
                                          Ein Listenfeld würde vielleicht auch gehen, indem man seine eigenen Wunschzeiten als Werte hinterlegt.
                                          Vielleicht kann ja jemand noch sowas bauen.
                                          Kann man das Script noch so anpassen dass die zweite Zeile bündig zur ersten ist ?
                                          Ich weiß, dass ist alles Jammern auf hohem Niveau..... Ihr habt das super macht, wollte schon immer ne Fernsehzeitung auf dem Tablet, nochmals vielen Dank.
                                          NashraN liv-in-skyL 2 Antworten Letzte Antwort
