  4. JavaScript
  5. TV Programm Mini Anzeige - HTML Tabelle
javascript
327 Beiträge 20 Kommentatoren 81.3k Aufrufe 29 Beobachtet
  • liv-in-skyL Offline
    liv-in-skyL Offline
    falls jemand ein popup ( in der vis) für die anzeige braucht - das ganze nimmt viel platz ein - hier ein beispiel
    importieren und den datenpunkt angelichen
    [{"tpl":"tplJquiDialog","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"title":"TV Gleich","html":"\n<center><b>TV Gleich</b></center","html_dialog":"{controll-own.0.TABELLEN.TVgleich}","dialog_width":"480","dialog_height":"580","modal":true,"closeOnClick":true},"style":{"left":"839px","top":"430px","width":"66px","height":"38px","background":"linear-gradient(to top, #80CB74 2px, #81A17C 55px )","color":"#52f651"},"widgetSet":"jqui"}]
    NashraN ChaotC 2 Antworten Letzte Antwort
    • liv-in-skyL liv-in-sky
      NashraN Offline
      NashraN Offline
      Nashra
      Most Active Forum Testing
      schrieb am zuletzt editiert von Nashra
      @liv-in-sky sagte in TV Programm Mini Anzeige - HTML Tabelle:
      Mit dem Popup ist eine gute Idee :-)
      Habe erstmal eine Testseite angelegt um zu sehen ob alles klappt
      Gruß Ralf
      liv-in-skyL O 2 Antworten Letzte Antwort
      • NashraN Nashra
        liv-in-skyL Offline
        liv-in-skyL Offline
        @Nashra das popup kann man auf mehreren seiten plazieren und hat somit in der küche oder im wohnzimmer eine schnelle möglichkeit - ich habe verschiedene views pro zimmer am laufen
        mit dem widget - icon dialog - könnte man auch bildchen verwenden
        • NashraN Nashra
          O Offline
          O Offline
          Oli
          @Nashra
          deine Überschrift bei 22:00 Uhr ist noch falsch eingestellt im Script
          Oliver
            liv-in-skyL Offline
            habe nochmal eine kleine änderung gemacht- es kann jetzt auch eine signature eingebunden werden - diese erscheint direkt unter der tablelle - rechtsbündig und hat den selben inhalt wie die überschrift -ist aber kleiner . die überschrift hat zuviel platz gebraucht, ich wollte aber sehen , wann die letzten updates waren - so kann man sich entscheiden, was man braucht oder will
              sigi234S Online
              sigi234S Online
              @liv-in-sky
              Cool, wie bekomme ich jetzt die ÖSI sender rein?
              Was muss geändert werden im Skript, es ist immer sehr umständlich alles Skripte wieder anzupassen.
              • sigi234S sigi234
                @liv-in-sky
                liv-in-skyL Offline
                liv-in-skyL Offline
                @sigi234 die dürfen nicht in dem const mySort drinstehen - ziemlich weit untem im script - der große rote block
                die hier raus löschen
                • sigi234S sigi234
                  @liv-in-sky
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  @sigi234 du kannst die roten blöcke in jedes script kopieren, wenn du sie einmal geändert hast
                  • O Oli
                    @Nashra
                    NashraN Offline
                    NashraN Offline
                    Nashra
                    @Oli sagte in TV Programm Mini Anzeige - HTML Tabelle:
                    @Nashra
                    Korrigiert und noch eine Constante eingefügt bei font-weight da bei der Schriftart
                    die ich verwende das bold nicht gut aussieht. Könntest Du ja vllt auch übernehmen
                    dann kann es sich jeder selber einstellen wie er es möchte.
                    const htmlSchriftWeite="normal";
                    var htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-weight:"+htmlSchriftWeite+"\">"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</p>";
                    Gruß Ralf
                    • NashraN Nashra
                      @Nashra
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      @Nashra
                      ich wollte das bold eh rausnehmen :-) aus der überschrift
                        @Nashra
                        NashraN Offline
                        NashraN Offline
                        Nashra
                        @Nashra
                        Sehr gut, bitte als constante und dann könnte man der Überschrift auch noch eine Constante
                        verpassen mit der Schriftgröße 😀
                        Gruß Ralf
                        • NashraN Nashra
                          @Nashra
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          @Nashra
                          done
                            @Nashra
                            done
                            NashraN Offline
                            NashraN Offline
                            Nashra
                            #66
                            @Nashra
                            done
                            ich auch 😊 👍
                            Gruß Ralf
                            • NashraN Offline
                              NashraN Offline
                              Nashra
                              #67
                              Noch so einige Ideen :-)
                              Überschrift mit Last Update = true/false
                              Signatur mit "Das TV Programm" = true/false
                              Also wenn Sig true, dann braucht man eigentlich "Das..." nicht
                              und oben könnte dann "Last..." ausgeblendet werden.
                              Was meinst Du :-)
                              Gruß Ralf
                              • NashraN Offline
                                NashraN Offline
                                Nashra
                                #68
                                Nachtrag!
                                Die Schriftgröße in Signatur sowie text-align und Farbe auch in eine Constante gelegt :-)
                                const htmlSchriftUntenGroesse="11px";
                                const htmlSchrifFarbeUnten="#40FF00";
                                const htmlSigTextAlign="right";
                                Gruß Ralf
                                • NashraN Offline
                                  NashraN Offline
                                  Nashra
                                  #69
                                  Da passte etwas noch nicht so ganz...
                                  const htmlSigPadLeft="10px";
                                  const htmlSigPadRight="10px";
                                  var htmlUnter= "<p></p><div style=\"padding-right:"+htmlSigPadRight+"; padding-left:"+htmlSigPadLeft+"; color:"+html
                                  Gruß Ralf
                                    ChaotC Offline
                                    ChaotC Offline
                                    Chaot
                                    #70
                                    @liv-in-sky Das Popup ist eine geniale Sache.
                                    Aber wie kann ich das einstellen das der an einer bestimmten Stelle mit einer bestimmten Größe aufgeht?
                                    In den Punkten Dialogbreite ändert sich nichts und bei Position oben/links gibt es auch keine Änderung.
                                    sigi234S liv-in-skyL 2 Antworten Letzte Antwort
                                    • ChaotC Chaot
                                      sigi234S Online
                                      sigi234S Online
                                      #71
                                      @Chaot sagte in TV Programm Mini Anzeige - HTML Tabelle:
                                      • ChaotC Chaot
                                        liv-in-skyL Offline
                                        liv-in-skyL Offline
                                        #72
                                        @Chaot dort habe ich es auch eingestellt - so wie bei sigi
                                          sigi234S Online
                                          sigi234S Online
                                          #73
                                          Schätze mal px vergessen!
