  4. MagicHome mit Tasmota nicht steuerbar
tasmotasonoff adaptermagic home
47 Beiträge 5 Kommentatoren 9.0k Aufrufe 5 Beobachtet
  • O Offline
    O Offline
    Oli19
    die Tasmota Konsole sagt:
    17:46:29 MQT: Connected
    17:46:29 MQT: tele/tasmota/LWT = Online (retained)
    17:46:29 MQT: cmnd/tasmota/POWER =
    17:46:29 MQT: tele/tasmota/STATE = {"Time":"2019-12-22T17:46:29","Uptime":"0T00:09:45","UptimeSec":585,"Heap":28,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":99,"MqttCount":4,"POWER":"ON","Dimmer":100,"Color":"04FF00","HSBColor":"119,100,100","Channel":[2,100,0],"Scheme":0,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"Thom_D0042615","BSSId":"28:BE:9B:D1:D6:4E","Channel":1,"RSSI":48,"Signal":-76,"LinkCount":1,"Downtime":"0T00:00:09"}}
    17:46:39 MQT: tele/tasmota/STATE = {"Time":"2019-12-22T17:46:39","Uptime":"0T00:09:55","UptimeSec":595,"Heap":28,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":99,"MqttCount":4,"POWER":"ON","Dimmer":100,"Color":"04FF00","HSBColor":"119,100,100","Channel":[2,100,0],"Scheme":0,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"Thom_D0042615","BSSId":"28:BE:9B:D1:D6:4E","Channel":1,"RSSI":48,"Signal":-76,"LinkCount":1,"Downtime":"0T00:00:09"}}
    17:46:40 MQT: stat/tasmota/RESULT = {"POWER":"ON","Dimmer":100,"Color":"FFFF00","HSBColor":"60,100,100","Channel":[100,100,0]}
    17:46:44 APP: Serial logging disabled
    17:46:44 MQT: stat/tasmota/RESULT = {"POWER":"ON","Dimmer":100,"Color":"FF1A00","HSBColor":"6,100,100","Channel":[100,10,0]}
    17:46:49 MQT: stat/tasmota/RESULT = {"POWER":"ON","Dimmer":100,"Color":"FF0000","HSBColor":"0,100,100","Channel":[100,0,0]}
    17:46:49 MQT: tele/tasmota/STATE = {"Time":"2019-12-22T17:46:49","Uptime":"0T00:10:05","UptimeSec":605,"Heap":28,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":99,"MqttCount":4,"POWER":"ON","Dimmer":100,"Color":"FF0000","HSBColor":"0,100,100","Channel":[100,0,0],"Scheme":0,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"Thom_D0042615","BSSId":"28:BE:9B:D1:D6:4E","Channel":1,"RSSI":50,"Signal":-75,"LinkCount":1,"Downtime":"0T00:00:09"}}
    17:46:59 MQT: tele/tasmota/STATE = {"Time":"2019-12-22T17:46:59","Uptime":"0T00:10:15","UptimeSec":615,"Heap":28,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":99,"MqttCount":4,"POWER":"ON","Dimmer":100,"Color":"FF0000","HSBColor":"0,100,100","Channel":[100,0,0],"Scheme":0,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"Thom_D0042615","BSSId":"28:BE:9B:D1:D6:4E","Channel":1,"RSSI":52,"Signal":-74,"LinkCount":1,"Downtime":"0T00:00:09"}}
    17:47:09 MQT: tele/tasmota/STATE = {"Time":"2019-12-22T17:47:09","Uptime":"0T00:10:25","UptimeSec":625,"Heap":28,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":99,"MqttCount":4,"POWER":"ON","Dimmer":100,"Color":"FF0000","HSBColor":"0,100,100","Channel":[100,0,0],"Scheme":0,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"Thom_D0042615","BSSId":"28:BE:9B:D1:D6:4E","Channel":1,"RSSI":56,"Signal":-72,"LinkCount":1,"Downtime":"0T00:00:09"}}
    17:47:19 MQT: tele/tasmota/STATE = {"Time":"2019-12-22T17:47:19","Uptime":"0T00:10:35","UptimeSec":635,"Heap":28,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":99,"MqttCount":4,"POWER":"ON","Dimmer":100,"Color":"FF0000","HSBColor":"0,100,100","Channel":[100,0,0],"Scheme":0,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"Thom_D0042615","BSSId":"28:BE:9B:D1:D6:4E","Channel":1,"RSSI":50,"Signal":-75,"LinkCount":1,"Downtime":"0T00:00:09"}}
    17:47:29 MQT: tele/tasmota/STATE = {"Time":"2019-12-22T17:47:29","Uptime":"0T00:10:45","UptimeSec":645,"Heap":28,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":99,"MqttCount":4,"POWER":"ON","Dimmer":100,"Color":"FF0000","HSBColor":"0,100,100","Channel":[100,0,0],"Scheme":0,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"Thom_D0042615","BSSId":"28:BE:9B:D1:D6:4E","Channel":1,"RSSI":48,"Signal":-76,"LinkCount":1,"Downtime":"0T00:00:09"}}
    17:47:39 MQT: tele/tasmota/STATE = {"Time":"2019-12-22T17:47:39","Uptime":"0T00:10:55","UptimeSec":655,"Heap":28,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":99,"MqttCount":4,"POWER":"ON","Dimmer":100,"Color":"FF0000","HSBColor":"0,100,100","Channel":[100,0,0],"Scheme":0,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"Thom_D0042615","BSSId":"28:BE:9B:D1:D6:4E","Channel":1,"RSSI":54,"Signal":-73,"LinkCount":1,"Downtime":"0T00:00:09"}}
    17:47:49 MQT: tele/tasmota/STATE = {"Time":"2019-12-22T17:47:49","Uptime":"0T00:11:05","UptimeSec":665,"Heap":28,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":99,"MqttCount":4,"POWER":"ON","Dimmer":100,"Color":"FF0000","HSBColor":"0,100,100","Channel":[100,0,0],"Scheme":0,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"Thom_D0042615","BSSId":"28:BE:9B:D1:D6:4E","Channel":1,"RSSI":56,"Signal":-72,"LinkCount":1,"Downtime":"0T00:00:09"}}
    17:47:59 MQT: tele/tasmota/STATE = {"Time":"2019-12-22T17:47:59","Uptime":"0T00:11:15","UptimeSec":675,"Heap":28,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":99,"MqttCount":4,"POWER":"ON","Dimmer":100,"Color":"FF0000","HSBColor":"0,100,100","Channel":[100,0,0],"Scheme":0,"Fade":"OFF","Speed":1,"LedTable":"ON","Wifi":{"AP":1,"SSId":"Thom_D0042615","BSSId":"28:BE:9B:D1:D6:4E","Channel":1,"RSSI":52,"Signal":-74,"LinkCount":1,"Downtime":"0T00:00:09"}}
    • O Oli19
      Jan1
      @Oli19
      pack das bitte mal in "Code Tack", liest sich einfacher.
      • O Offline
        O Offline
        Oli19
        sorry wusste nicht genau wie das geht
        • O Oli19
          Jan1
          @Oli19
          Das sieht aber gut aus.
          Hast noch andere Geräte im Tasmota Adapter und wird der noch gelb?
          • O Offline
            O Offline
            Oli19
            nein ich habe nur den RGB Controller mit dem Sonoff Adapter verbunden
            • O Oli19
              Jan1
              @Oli19
              komisch, wenn der zuerst geht und dann gelb wird.
              Hast das bin selber kompiliert oder was fertiges genommen?
              nimm mal das bin
              • O Offline
                O Offline
                Oli19
                ich habe den Controller mit Tasmotizer geflashed
                • O Oli19
                  Jan1
                  @Oli19
                  ich habe oben ein bin angehängt
                  Könnte aber auch an Deinem IOBroker liegen.
                  Welche Adapter Version hast und welche Node Versionen
                  • O Offline
                    O Offline
                    Oli19
                    schrieb am zuletzt editiert von Oli19
                    das kann sehr gut sein da bei mir regelmäßig (1mal pro Stunde gefühlt) der history, javascript, web und manchmal auch noch die anderen Adapter wie cloud, info, ping abstürzen bzw. die Verbindung verlieren und erst wieder grün werden wenn ich die Instanzen Seite im iobroker aufrufe und meine Scripte funktionieren auch nur wenn ich die Seite offen habe was ganz komisch ist...
                    vielleicht sollte ich alles nochmal neu installieren auf einem Raspberry Pi oder Intel Nuc
                    oder es liegt daran das der Laptop im Wlan ist die Wlan Verbindung immer abkackt
                    • O Oli19
                      Jan1
                      @Oli19
                      Oder einen neuen Thread zu dem Problem öffnen, denn das hier sind nur die Symptome davon😊
                      • O Offline
                        O Offline
                        Oli19
                        achja meine Node Version ist node: v10.18.0
                        • O Oli19
                          Jan1
                          @Oli19
                          beide gleich und sonst noch Fehler im Log?
                          Stabiles WLAN ist Pflicht, sonst wird das nichts. Besser mit LAN verbinden.
                          • O Offline
                            O Offline
                            Oli19
                            den Log muss ich mal kopieren wenn wieder mal alle Adapter ihre Verbindung verlieren
                            • O Offline
                              O Offline
                              Oli19
                              ich habe versucht deine Bin zu flashen aber selbst das geht nicht mehr...😢
                              • O Offline
                                O Offline
                                Oli19
                                ok habs doch noch hinbekommen deine bin zu flashen
                                • O Oli19
                                  Jan1
                                  @Oli19
                                  Das bin File hat nur das nötigste inklusive HUE Emulator drin und sollte somit immer OTA funktionieren.
                                  Aber Dein Problem ist nicht der MagicHome Controller, sondern Dein instabiler IOBroker
                                  • O Offline
                                    O Offline
                                    Oli19
                                    Egal was es ist, es funktioniert jetzt endlich 😄
                                    Vielen Dank für deine Zeit und Mühe
                                    • hg6806H Offline
                                      hg6806H Offline
                                      hg6806
                                      habe ein ähnliches Problem und hänge mich mal hier dran.
                                      Und zwar habe ein normales RGB LED Stripe (kein Magic Home). Das habe ich über FETs an einen Wemos D1 angeschlossen über 3 GPIOs. Diesen mit Tasmota geflasht und auch MQTT eingerichtet. Steuern über die Tasmota Oberfläche geht gut. In ioBroker werden Datenpunkte angelegt in den Verzeichnissen "stat" und "tele". Darin auch "RESULT" mit einer JSON Tabelle und einigen aktuellen Werten wie Power, Dimmer, Color, etc.
                                      Aber eigentlich fehlen mir noch einzelne "CMND" Werte mit "Power, "Dimmer", Color" und "Speed".
                                      Wie werden die angelegt?
                                      • hg6806H hg6806
                                        Jan1
                                        @hg6806
                                        Sonoff Adapter oder MQTT Adapter? Im Sonoff Adapter wird alles passend zu Tasmota automatisch angelegt und muss nicht manuell erstellt werden.
                                        • hg6806H Offline
                                          hg6806H Offline
                                          hg6806
                                          Ich habe nur den MQTT Adapter laufen.
                                          Kann man beiden gleichzeitig laufen lassen und wie ist das dann mit den MQTT Einstellungen? Einfach bei SONOFF und im ESP unter MQTT anderen Port vergeben?
