  4. Test Adapter TrashSchedule
adaptercalendaricalkalendermülltrash
1.4k Beiträge 186 Kommentatoren 716.1k Aufrufe 171 Beobachtet
  • D darkiop
    Falls es hier jemand braucht, habe auf die schnelle mal ein Blockly für eine json-Tabelle mit den DPs erstellt:
     <block xmlns="http://www.w3.org/1999/xhtml" type="schedule" id="zH:a+Y|{4CrduNF1VUTG" x="-387" y="13">
      <field name="SCHEDULE">{"time":{"exactTime":true,"start":"00:05"},"period":{"days":1}}</field>
      <statement name="STATEMENT">
        <block type="control_ex" id="$7jAIT_mnpzNLP]~NJy{">
          <field name="TYPE">false</field>
          <value name="OID">
            <shadow type="field_oid" id="sbu^)eqpdG=koC2q;ZDd">
              <field name="oid">Object ID</field>
            </shadow>
            <block type="text" id="2Jn.QUiZj?ycCTjRK_W(">
              <field name="TEXT">javascript.0.VIS.Kalender_Tabelle_Muell</field>
            </block>
          </value>
          <value name="VALUE">
            <shadow type="logic_boolean" id="C3xZGWbRz.8%NyHztTAC">
            </shadow>
            <block type="convert_object2json" id="pu+4RS*`r:#QRXX(d|1I">
              <field name="PRETTIFY">FALSE</field>
                <block type="lists_create_with" id="ZdEEwT){@[oWz7}6T|:6">
                  <mutation items="4"></mutation>
                  <value name="ADD0">
                    <block type="lists_create_with" id="$UUL3})|H~26WlgPAR}}">
                      <value name="ADD0">
                        <block type="text" id="69`+m2b?ah727]cb4b5m">
                          <field name="TEXT">Bio</field>
                        </block>
                      </value>
                      <value name="ADD1">
                        <block type="text_join" id="ErQ7M!ikghZ`#n9pZRgZ">
                          <mutation items="1"></mutation>
                          <value name="ADD0">
                            <block type="get_value_var" id="Mu|`W9bXFB;_0SX!nvgu">
                              <value name="OID">
                                <shadow type="text" id="P#+:y_a5je5/#)4SO^L~">
                                  <field name="TEXT">trashschedule.0.type.Bio.daysleft</field>
                                </shadow>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                      <value name="ADD2">
                        <block type="text_join" id=".5ka+V$wB[[i4LiF3Dch">
                          <value name="ADD0">
                            <block type="get_value_var" id="w)`88fd-tS~uSu$)4=N%">
                              <value name="OID">
                                <shadow type="text" id="puB=e5tWv:s95)2|m63d">
                                  <field name="TEXT">trashschedule.0.type.Bio.nextdateformat</field>
                                </shadow>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </value>
                  <value name="ADD1">
                    <block type="lists_create_with" id="z-XsI{)vm#5U/X{jxJhJ">
                      <value name="ADD0">
                        <block type="text" id="w`QASfUph?E*g6}`1K?B">
                          <field name="TEXT">Papier</field>
                        </block>
                      </value>
                      <value name="ADD1">
                        <block type="text_join" id="QI#7R02;o6yhi)k*GUWH">
                          <value name="ADD0">
                            <block type="get_value_var" id="d%;U*%+S^(/j-C(|f3_6">
                              <value name="OID">
                                <shadow type="text" id="g}Fhsd_#kL-;`ckEn|E$">
                                  <field name="TEXT">trashschedule.0.type.Papier.daysleft</field>
                                </shadow>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                      <value name="ADD2">
                        <block type="text_join" id="]qySTY/w/@JC$^$1T;{G">
                          <value name="ADD0">
                            <block type="get_value_var" id="0){KH+1P@u-*9.*ptmtw">
                              <value name="OID">
                                <shadow type="text" id="I/GJo^!Mp+AJ3=])tG{u">
                                  <field name="TEXT">trashschedule.0.type.Papier.nextdateformat</field>
                                </shadow>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </value>
                  <value name="ADD2">
                    <block type="lists_create_with" id="`.xF_srwKF%7{ISkZ9SS">
                      <value name="ADD0">
                        <block type="text" id="x%CaEm(Er0k@RdJmwY6|">
                          <field name="TEXT">Glas</field>
                        </block>
                      </value>
                      <value name="ADD1">
                        <block type="text_join" id="p}a2rlQ,oC%-6POTT1.n">
                          <value name="ADD0">
                            <block type="get_value_var" id="WMBSm@,}P(h-*tsb2dmG">
                              <value name="OID">
                                <shadow type="text" id="+2IANn@_+1Bu_a97kr/P">
                                  <field name="TEXT">trashschedule.0.type.Glas.daysleft</field>
                                </shadow>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                      <value name="ADD2">
                        <block type="text_join" id="27btsxWYG5;!kT^ypS(w">
                          <value name="ADD0">
                            <block type="get_value_var" id="TXLvr-L9O$^^#IgE7r8/">
                              <value name="OID">
                                <shadow type="text" id="5RS-i8]2v|k98c(IL4jg">
                                  <field name="TEXT">trashschedule.0.type.Glas.nextdateformat</field>
                                </shadow>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </value>
                  <value name="ADD3">
                    <block type="lists_create_with" id="T;;$gR}hB|ZO{5bqJK6C">
                      <value name="ADD0">
                        <block type="text" id="JW[g,${io?zI03+bo_dO">
                          <field name="TEXT">GelberSack</field>
                        </block>
                      </value>
                      <value name="ADD1">
                        <block type="text_join" id="QrX3i+Vd?s2f](@F!Ie,">
                          <value name="ADD0">
                            <block type="get_value_var" id="^Oe/%|U|fQkkLsicq87|">
                              <value name="OID">
                                <shadow type="text" id="+{@)/]CLs+Rj{SCJaBI{">
                                  <field name="TEXT">trashschedule.0.type.GelberSack.daysleft</field>
                                </shadow>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                      <value name="ADD2">
                        <block type="text_join" id="kN@MK8x6Td!$z~Z0lQ|g">
                          <value name="ADD0">
                            <block type="get_value_var" id="F}3W/b(.](8I.VC=5jzy">
                              <value name="OID">
                                <shadow type="text" id="SKqQ1Wjl;z7^4z_o{Nyz">
                                  <field name="TEXT">trashschedule.0.type.GelberSack.nextdateformat</field>
                                </shadow>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </value>
                </block>
              </value>
            </block>
          </value>
          <value name="DELAY_MS">
            <shadow type="math_number" id="T#OSxS{}/L9EbZB6%*;i">
              <field name="NUM">0</field>
            </shadow>
          </value>
        </block>
      </statement>
    </block>
    BostilB Offline
    BostilB Offline
    Bostil
    schrieb am zuletzt editiert von Bostil
    #156
    hier stand Stuss -> kann gelöscht werden
      Sempre
      schrieb am zuletzt editiert von Sempre
      #157
      @haus-automatisierung
      Vielen Dank für den Adapter, ich habe diesen nun auch in Betrieb genommen, aber leider scheint bei mir noch nicht allles zu passen. Ich habe keine aktuellen Werte für Gelbe Tonne, obwohl diese als nächstes Event erkannt wird. Die nächste Leerung wäre diesen Freitag, aber wie gesagt unter den Typen-Objekten wird nichts angezeigt.
      Zusätzlich fehlen mir noch die Werte für den Restmüll, hier habe ich absolut nichts an Daten. Wie weit schaut der Adapter denn in die Zukunft? Ich könnte mir vorstellen, das hier einfach der nächste Wert zu weit in der Zukunft ist, denn die nächste Leerung wäre am 14.1.2020
      Edit: Ok hat sich erledigt, nun sind alle Daten da, warum auch immer das so ewig gedauert hat. Ein Teil der Daten war sofort da, der andere hat 10-15 Minuten gedauert.
      • S Sempre
        ChaotC Offline
        ChaotC Offline
        Chaot
        #158
        @Sempre Das kannst du im ical - Adapter einstellen.
        Dort hast du die Vorschau normalerweise auf 7 Tage stehen. Wenn du dort 60 oder 90 einträgst werden auch sehr späte Termine noch richtig erfasst.
        • ? Offline
          #159
          @Chaot
          Hallo
          ich habe mir über google nun einen Kalendar angelegt und über
          npm i iobroker.trashschedule
          installiert. Aktuell taucht leider das Objekt bei mir noch nicht auf.
          Was könnte ich übersehen haben?
          • ChaotC Chaot
            Sempre
            #160
            @Chaot
            dort habe ich 30 Tage drin, daher soltle es passen. Es hat nach einer Weile ja nun auch alle Datenpuntke angelegt, war nur verwundert warum es so ewig gedauert hat. Eine Vermutung war dann das der Adapter selber eventuell noch eine Zeitbegrenzung hat, aber passt ja :)
              @Chaot
              Hallo
              ChaotC Offline
              ChaotC Offline
              Chaot
              #161
              @HeinrichB Der ical Adapter kommuniziert bei mir mit dem Google Kalender. Dort sind die Termine recht schnell hinterlegt und mit mehreren Kalendern kann man auch im ioBroker mehrfach den iCal laufen lassen
              Geburtstag
              Müll
              Termine
              @Sempre Ja, das ist bei mir auch manchmal das der Adapter recht lange braucht um Daten zu holen. Und manchmal passiert das binnen Sekunden.
              Warum das so ist habe ich aber noch nicht herausgefunden.
              • ChaotC Chaot
                Geburtstag
                Müll
                Termine
                #162
                @Chaot
                Danke Dir. Ich habe den Kalendar mit ein paar Terminen angelegt.
                Dann den Adapter mit
                installiert.
                Leider taucht er bei nicht als Instanz auf. Was könnte ich übersehen haben?
                  @Chaot
                  installiert.
                  ChaotC Offline
                  ChaotC Offline
                  Chaot
                  #163
                  @HeinrichB Du musst noch eine Instanz hinzufügen.
                  Es scheint das du den erst "nur" installiert hast.
                  Warum installierst du den eigentlich so? Geht doch über den ioBroker viel komfortabler finde ich.
                  • ChaotC Chaot
                    #164
                    @Chaot hätte ich gern gemacht und mache ich sonst immer so. Nur taucht er bei mir in der Liste der Adapter nicht auf. 🤔
                      ChaotC Offline
                      ChaotC Offline
                      Chaot
                      #165
                      @HeinrichB Ja, das liegt vermutlich daran das der immer noch Beta ist. Den musst du über die Katze installieren.
                      Aber jetzt müsste er als Adapter zu sehen sein oder?
                      ? 2 Antworten Letzte Antwort
                      • ChaotC Chaot
                        #166
                        @Chaot Tut mir leid, dass ich so doof frage (ich bin erst seit letztem Sa. in dem ioBroker-Thema): Was bedeutet über die Katze?
                        • ChaotC Chaot
                          #167
                          @Chaot noch nicht zu sehen. Hier der Screen dazu
                            ChaotC Offline
                            ChaotC Offline
                            Chaot
                            #168
                            @HeinrichB Ach so.
                            In der Adapteransicht ist ober das dritte Sysmbol von rechts eine stilisierte Katze (wusste ichg früher übrigens auch nicht).
                            Dort wählst du dann als Quelle "Beliebig" und gibst dort den Link zu Github ein:
                            https://github.com/klein0r/ioBroker.trashschedule
                            dann sollte die Installation anfangen zu laufen.
                            Wenn er dann in der Adaterübersicht sichtbar ist musst du noch eine Instanz installieren und du kannst den nutzen.
                            • ChaotC Chaot
                              @HeinrichB Ach so.
                              #169
                              @Chaot
                              VIELEN DANK!
                              Jetzt hat es geklappt:-) Wieder was gelernt ;-)
                              Jetzt gehe ich mal ans einrichten :)
                              • T Termina
                                @darkiop sagte in Test Adapter TrashSchedule v0.0.x:
                                      <value name="OID">
                                        </shadow>
                                        </block>
                                      </value>
                                        </shadow>
                                              <value name="ADD0">
                                                  <value name="ADD0">
                                                    </block>
                                                  </value>
                                                  <value name="ADD1">
                                                      <value name="ADD0">
                                                          <value name="OID">
                                                            </shadow>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="ADD2">
                                                      <value name="ADD0">
                                                          <value name="OID">
                                                            </shadow>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <value name="ADD1">
                                                  <value name="ADD0">
                                                    </block>
                                                  </value>
                                                  <value name="ADD1">
                                                      <value name="ADD0">
                                                          <value name="OID">
                                                            </shadow>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="ADD2">
                                                      <value name="ADD0">
                                                          <value name="OID">
                                                            </shadow>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <value name="ADD2">
                                                  <value name="ADD0">
                                                    </block>
                                                  </value>
                                                  <value name="ADD1">
                                                      <value name="ADD0">
                                                          <value name="OID">
                                                            </shadow>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="ADD2">
                                                      <value name="ADD0">
                                                          <value name="OID">
                                                            </shadow>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <value name="ADD3">
                                                  <value name="ADD0">
                                                    </block>
                                                  </value>
                                                  <value name="ADD1">
                                                      <value name="ADD0">
                                                          <value name="OID">
                                                            </shadow>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="ADD2">
                                                      <value name="ADD0">
                                                          <value name="OID">
                                                            </shadow>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                        </shadow>
                                      </value>
                                    </block>
                                  </statement>
                                </block>
                                Sry, ich meinte diese Tabelle
                                #170
                                @Termina
                                kann ich kurz eine Hilfe bekommen, wie ich diese Tabelle in meiner Vis-Darstellung verfügbar bekomme?
                                Der Adapter ist installiert und liefert auch entsprechend Daten in die Datenpunkte.
                                  @Termina
                                  ChaotC Offline
                                  ChaotC Offline
                                  Chaot
                                  #171
                                  @HeinrichB Gleich hier auf der zweiten Seite:
                                  https://forum.iobroker.net/topic/27050/test-adapter-trashschedule-v0-0-x/26?page=2
                                  ist ein Beitrag der eine VIS Vorlage enthält.
                                  Aber ich glaube etwas später war dann nochmal eine Vorlage angeboten.
                                  Hier in dem Tread sind mehrere Umsetzungsmöglichkeiten aufgeführt.
                                  Ach ja, hier ganz am Ende ist das von mir:
                                  https://forum.iobroker.net/topic/27050/test-adapter-trashschedule-v0-0-x/100?page=5
                                  • ChaotC Chaot
                                    #172
                                    @Chaot Vielen Dank mal wieder. Ich muss mich erstmal einarbeiten, in welches Steuerelement ich den Code ablegen kann, dass er angezeigt wird :)
                                    Sind aktuell viel neue Informationen für mich; manches bekannt aus anderen Sprachen wie die blockly-Sache, aber die konkrete Implementierung ist immer irgendwie ein Tick anders :)
                                      ChaotC Offline
                                      ChaotC Offline
                                      Chaot
                                      #173
                                      @HeinrichB Das schon, aber ich muss dich ausdrücklich warnen.
                                      Wenn man mal den Bogen raus hat macht das süchtig! 🕶
                                      • ChaotC Chaot
                                        #174
                                        @Chaot ich merke es. Jeden Tag biege ich was neues drauf 😁😁
                                        Im Moment übe ich auf meinem MacBook. Später so es eine dauer-on Lösung werden 😁👍
                                        Dein Code Snipped. Ist das ein CSS? und wenn ja, welches Widget nimmt es auf?
                                          ChaotC Offline
                                          ChaotC Offline
                                          Chaot
                                          #175
                                          @HeinrichB Was ich da gepostet habe ist ein Widget.
                                          Das importierst du über den VIS Editor unter "Widget importieren".
                                          Du musst allerdings auch noch die Icons von sigi234 (erster Link) importieren.
                                          Etwas weiter im Tread ist dann auch noch erklärt wie die Dinger zur Abholung blinken 👍
