  4. Test Adapter ioBroker.backitup v3.1.x
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 2.8m Aufrufe 113 Beobachtet
  • simatecS simatec
    @MathiasJ
    Ich habe deine Config mal nachgestellt und denke dass es auf deinem NAS Probleme mit dem Schreibrechten gibt.
    So sollte dein Log aussehen ...
    backitup.0	2019-12-17 21:36:18.696	debug	(17482) [iobroker] exec: done
    backitup.0	2019-12-17 21:36:18.694	debug	(17482) [iobroker/umount] done
    backitup.0	2019-12-17 21:35:18.424	debug	(17482) [iobroker/umount] mount activ... umount in 60 Seconds!!
    backitup.0	2019-12-17 21:35:18.405	debug	(17482) [iobroker/history] backitup.0.history.html
    backitup.0	2019-12-17 21:35:18.388	debug	(17482) [iobroker/pushover] done
    backitup.0	2019-12-17 21:35:18.387	debug	(17482) sendTo "send" to system.adapter.pushover.0 from system.adapter.backitup.0
    backitup.0	2019-12-17 21:35:18.384	debug	(17482) [iobroker/pushover] [iobroker] used pushover-Instance: pushover.0
    backitup.0	2019-12-17 21:35:18.376	debug	(17482) [iobroker/clean] done
    backitup.0	2019-12-17 21:35:18.371	debug	(17482) [iobroker/googledrive] done
    backitup.0	2019-12-17 21:35:17.776	debug	(17482) [iobroker/googledrive] delete iobroker_2019_12_17-21_13_10_test_backupiobroker.tar.gz
    backitup.0	2019-12-17 21:34:22.730	debug	(17482) [iobroker/googledrive] Copy iobroker_2019_12_17-21_33_20_test_backupiobroker.tar.gz...
    backitup.0	2019-12-17 21:34:22.721	debug	(17482) [iobroker/dropbox] done
    backitup.0	2019-12-17 21:33:28.831	debug	(17482) [iobroker/dropbox] Copy iobroker_2019_12_17-21_33_20_test_backupiobroker.tar.gz...
    backitup.0	2019-12-17 21:33:28.826	debug	(17482) [iobroker/cifs] done
    backitup.0	2019-12-17 21:33:28.823	debug	(17482) [iobroker/iobroker] done
    backitup.0	2019-12-17 21:33:27.490	debug	(17482) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2019_12_17-21_33_20_test_backupiobroker.tar.gz
    backitup.0	2019-12-17 21:33:22.314	debug	(17482) [iobroker/iobroker] host.tinker-test 3058 objects saved
    backitup.0	2019-12-17 21:33:22.267	debug	(17482) [iobroker/iobroker] host.tinker-test 2741 states saved
    backitup.0	2019-12-17 21:33:20.440	debug	(17482) [iobroker/mount] done
    backitup.0	2019-12-17 21:32:53.520	debug	(17482) mount activ... umount in 2 Seconds!!
    backitup.0	2019-12-17 21:32:43.511	debug	(17482) [iobroker] 10 33 21 */1 * *
    backitup.0	2019-12-17 21:32:43.498	info	(17482) [iobroker] backup was activated at 21:33 every 1 day(s)
    backitup.0	2019-12-17 21:32:43.448	info	(17482) starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.17.0
    MathiasJM
    MathiasJM
    MathiasJ
    #179
    @simatec
    Und wie komme ich jetzt dahinter?
    Ich habe weder auf IObroker noch auf der NAS was geändert. :(
    IObroker auf dem NUC als VM.
    • MathiasJM MathiasJ
      @simatec
      simatecS
      simatecS
      simatec
      #180
      @MathiasJ
      Wie nutzt du den NAS? Per NFS oder CIFS?
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      • MathiasJM
        MathiasJM
        MathiasJ
        schrieb am zuletzt editiert von MathiasJ
        #181
        Per CIFS, due ganze Zeit schon.
        CIFS habe ich auf dem PI4 installiert und habe gefühlte 1000 mal den fixer drüber laufen lassen.
        Was ich jetzt aber nicht verstehe:
        Wenn ich das Häkchen bei der Hauotseite von der NAS entferne, müssten doch die Backups funktionieren, wenn es an der NAS liegt. Auch da habe ich 0kb
        simatecS 2 Antworten Letzte Antwort
          simatecS
          simatecS
          simatec
          #182
          @MathiasJ
          Das war aber in deiner Aussage von vorhin anders.
          Da hast du geschrieben, dass es ohne NAS funktioniert
          Dann passen eventuell die Schreibrechte in dem Ordner /opt/iobroker/backups nicht
          MathiasJM 1 Antwort Letzte Antwort
            simatecS
            simatecS
            simatec
            #183
            @MathiasJ
            Probiere mal ein Backup über Konsole zu erstellen ...
            Dann kannst du den Fehler eingrenzen.
            iobroker backup
            • simatecS simatec
              @MathiasJ
              MathiasJM
              MathiasJM
              MathiasJ
              #184
              @simatec
              Beim ersten Mal hat es ohne NAS funktioniert.
              Mit NAS dann 0kb.
              Die NAS wieder weg genommen, wieder 0kb.
              Gruß, Mathias
                @simatec
                Mit NAS dann 0kb.
                Gruß, Mathias
                simatecS
                simatecS
                simatec
                #185
                @MathiasJ sagte in Test Adapter Backitup v1.3.x:
                0kb
                Wo hast du 0 Kb in den Clouds oder auch lokal?
                Probiere mal das manuelle Backup über Konsole siehe Post oben
                GlasfaserG MathiasJM 2 Antworten Letzte Antwort
                • simatecS simatec
                  0kb
                  GlasfaserG
                  GlasfaserG
                  #186
                  @simatec
                  Soll er nicht jetzt ein Backup anstoßen und den kompletten Debug-Log hier posten .Dann könnte man vielleicht mehr sehen !?
                  • GlasfaserG Glasfaser
                    @simatec
                    simatecS
                    simatecS
                    simatec
                    #187
                    @Glasfaser
                    Am besten wäre es ... aber ggfs. sogar ein manuelles Backup mit der aktivierten Debug Option in den Haupteinstellungen von Backitup.
                    Dann die komplette Konsolenausgabe posten
                    • simatecS simatec
                      0kb
                      MathiasJM
                      MathiasJM
                      MathiasJ
                      #188
                      @simatec
                      Auch über der Konsole habe ich 0kb.
                      Nur einen Log kann ich nicht bieten. Habe es über dem Smartphone gemacht.
                        @simatec
                        simatecS
                        simatecS
                        simatec
                        #189
                        @MathiasJ
                        Gut dann liegt dein Problem definitiv nicht an backitup sondern an deinem System
                        Prüfe die Rechte von /opt/iobroker/backups mal als erstes ...
                        • JB_SullivanJ
                          JB_SullivanJ
                          JB_Sullivan
                          #190
                          Ich haue mal wieder eine Frage raus, weil dazu in der Doku auf GitHub nichts zu finden ist.
                          ZiggBee Datenbank - bezieht sich das nur auf den Adapter ZiggBee oder wird auch was von deConz (ist ja auch ZiggBee) gesichert?
                          • JB_SullivanJ JB_Sullivan
                            simatecS
                            simatecS
                            simatec
                            #191
                            @JB_Sullivan
                            Es bezieht sich auf die Gerätedatenbank des zigbee Adapters
                            Unter deconz ist das nicht nötig.
                            • simatecS simatec
                              @MathiasJ
                              MathiasJM
                              MathiasJM
                              MathiasJ
                              #192
                              @simatec
                              Mache ich dann morgen.
                              Wie kann das sein, dass das System von jetzt auf gleich so verhunzt ist?
                              Gehe ich richtig in der Annahme, dass es 777 sein muss bei /opt/iobroker/backups?
                              Rootrechte= chmod 777
                              Ich kann weder mit dem user, noch mit root ein Backup erstellen.
                              ich habe den Fix nochmal drüber laufen lassen, jedoch ohne Erfolg.
                              ich bekomme jedesmal 0 kb.
                                @simatec
                                simatecS
                                simatecS
                                simatec
                                #193
                                @MathiasJ
                                Am besten mit folgenden Befehlen ...
                                sudo chmod 777 /opt/iobroker/backups/
                                sudo chmod 777 /opt/iobroker/backups/*
                                Damit bist du ganz sicher ...
                                • simatecS simatec
                                  @MathiasJ
                                  MathiasJM
                                  MathiasJM
                                  MathiasJ
                                  #194
                                  @simatec
                                  root@ioBroker-RasPi4:~# chmod 777 /opt/iobroker/backups/*
                                  chmod: Zugriff auf '/opt/iobroker/backups/*' nicht möglich: Datei oder Verzeichnis nicht gefunden
                                  Ich werde nach der Arbeit Backitup komplett deinstallieren, den Ordner /opt/iobroker/backups löschen,
                                  Backitup wieder installieren. Dann müsste der Odner neu angelegt werden.
                                  Gruß,
                                  Mathias
                                  E simatecS 2 Antworten Letzte Antwort
                                  • J
                                    J
                                    Jan1
                                    #195
                                    wieder wurde das automatische Backup nicht entsprechend der Vorgabe erstellt. alles doppelt und IOBroker fehlt:
                                    im Log wieder die bekannten compact mode Errors:
                                    2019-12-18 02:00:38.043  - error: backitup.0 (COMPACT) TypeError: Cannot read property 'split' of undefined
                                        at options.adapter.getState (/opt/iobroker/node_modules/iobroker.backitup/lib/scripts/92-history.js:24:40)
                                        at Adapter.getState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5407:29)
                                        at Object.command (/opt/iobroker/node_modules/iobroker.backitup/lib/scripts/92-history.js:10:25)
                                        at Immediate.executeScripts (/opt/iobroker/node_modules/iobroker.backitup/lib/execute.js:216:22)
                                        at runCallback (timers.js:706:11)
                                        at tryOnImmediate (timers.js:676:5)
                                    und auch wieder beim manuellen Start des Backup alles OK.
                                    Warum geht das automatisch nicht?
                                      @simatec
                                      Gruß,
                                      Mathias
                                      E
                                      E
                                      Einstein67
                                      #196
                                      @MathiasJ said in Test Adapter Backitup v1.3.x:
                                      Der Ordner wird nicht von BackitUp angelegt, sondern von ioBroker.
                                      • E Einstein67
                                        simatecS
                                        simatecS
                                        simatec
                                        #197
                                        @Einstein67
                                        Das ist so nicht korrekt.
                                        Backitup legt den Ordner beim ersten Start an
                                        • J Jan1
                                          simatecS
                                          simatecS
                                          simatec
                                          #198
                                          @Jan1
                                          Das ist aber eine andere Fehlermeldung.
                                          Entstanden ist die durch den Compact Modus und wird ebenfalls gefixt.
                                          83.8k
