  4. Test Adapter tr-064-community v1.0.x
    6.0k
tr-064community
727 Beiträge 88 Kommentatoren 243.7k Aufrufe 66 Beobachtet
  • conectasC conectas
    @apollon77
    Musstest jetzt evtl. einen zu weit zurück?
    Teste gerade..
    conectasC Offline
    conectasC Offline
    conectas
    #514
    Fall 02 auch der gleiche Fehler..
    2019-12-12 23:24:03.851  - debug: tr-064-community.0 (21048) callMonitor.set: type=outbound caller=254xy callee=628xy7 callerName=NName Stefan calleeName=NName Stefan
    2019-12-12 23:24:04.235  - debug: tr-064-community.0 (21048) callMonitor.set: type=inbound caller=030254xy callee=628xy7 callerName=NName Stefan calleeName=NName Stefan
    2019-12-12 23:24:06.296  - debug: tr-064-community.0 (21048) callMonitor.set: type=connect caller=030254xy callee=628xy7 callerName=NName Stefan calleeName=NName Stefan
    2019-12-12 23:24:06.437  - debug: tr-064-community.0 (21048) callMonitor.set: type=connect caller=254xy callee=628xy7 callerName=NName Stefan calleeName=NName Stefan
    2019-12-12 23:24:06.878  - debug: tr-064-community.0 (21048) in updateAll
    2019-12-12 23:24:06.881  - debug: tr-064-community.0 (21048) updateDevices
    2019-12-12 23:24:06.883  - debug: tr-064-community.0 (21048) forEachConfiguredDevice
    2019-12-12 23:24:09.784  - debug: tr-064-community.0 (21048) setting 0 enable=false
    2019-12-12 23:24:09.786  - debug: tr-064-community.0 (21048) setting 1 enable=false
    2019-12-12 23:24:09.787  - debug: tr-064-community.0 (21048) setting 2 enable=false
    2019-12-12 23:24:09.787  - debug: tr-064-community.0 (21048) setting 3 enable=false
    2019-12-12 23:24:09.800  - debug: tr-064-community.0 (21048) setting 4 enable=false
    2019-12-12 23:24:09.801  - debug: tr-064-community.0 (21048) setting 5 enable=true
    2019-12-12 23:24:09.802  - debug: tr-064-community.0 (21048) setting 6 enable=true
    2019-12-12 23:24:09.803  - debug: tr-064-community.0 (21048) setting 7 enable=true
    2019-12-12 23:24:09.804  - debug: tr-064-community.0 (21048) setting 8 enable=true
    2019-12-12 23:24:09.805  - debug: tr-064-community.0 (21048) setting 9 enable=true
    2019-12-12 23:24:10.891  - debug: tr-064-community.0 (21048) callMonitor.set: type=lastCall caller=254xy callee=628xy7 callerName=NName Stefan calleeName=NName Stefan
    2019-12-12 23:24:10.933  - debug: tr-064-community.0 (21048) callMonitor.set: type=lastCall caller=030254xy callee=628xy7 callerName=NName Stefan calleeName=NName Stefan
    2019-12-12 23:24:19.806  - debug: tr-064-community.0 (21048) in updateAll
    2019-12-12 23:24:19.809  - debug: tr-064-community.0 (21048) updateDevices
    2019-12-12 23:24:19.810  - debug: tr-064-community.0 (21048) forEachConfiguredDevice
    2019-12-12 23:24:22.140  - debug: tr-064-community.0 (21048) setting 0 enable=false
    2019-12-12 23:24:22.141  - debug: tr-064-community.0 (21048) setting 1 enable=false
    2019-12-12 23:24:22.142  - debug: tr-064-community.0 (21048) setting 2 enable=false
    2019-12-12 23:24:22.142  - debug: tr-064-community.0 (21048) setting 3 enable=false
    2019-12-12 23:24:22.143  - debug: tr-064-community.0 (21048) setting 4 enable=false
    2019-12-12 23:24:22.143  - debug: tr-064-community.0 (21048) setting 5 enable=true
    2019-12-12 23:24:22.143  - debug: tr-064-community.0 (21048) setting 6 enable=true
    2019-12-12 23:24:22.144  - debug: tr-064-community.0 (21048) setting 7 enable=true
    2019-12-12 23:24:22.144  - debug: tr-064-community.0 (21048) setting 8 enable=true
    2019-12-12 23:24:22.145  - debug: tr-064-community.0 (21048) setting 9 enable=true
    • apollon77A Offline
      #515
      Ok, dann mal eine Frage ... der Code macht ein was: Wenn sich der Wert vom State nicht ändert im Vergleich zu dem der aktuell gesetzt ist ... dann wird auch nichts aktualisiert. Kann es sein das das dein Missverständnis ist? UND im Standard hier ist der Delay nachdem Änderungen übernommen werden 500ms.
      Ich habe jetzt als letztes für heute noch ein Update auf GitHub mit:
      • State Change logging ... so sehen wir besser was wirklich geschrieben wird
      • Calllist logging für Refreshs
      Also damit bitte nochmal solche call logs @conectas
      Danke!
      conectasC 1 Antwort Letzte Antwort
      • apollon77A apollon77
        Danke!
        conectasC Offline
        conectasC Offline
        conectas
        #516
        Siehe E-Mail .. 2. kommt gleich
          #517
          @conectas schaue ich morgen an. Für heute bin ich zu Tod und deprimiert ;-)
          Marco TönjesM 1 Antwort Letzte Antwort
            Marco TönjesM Offline
            Marco Tönjes
            #518
            OFFTOPIC
            @apollon77 Nachdem das andere zu ist und ich dir nur ein Feedback geben wollte. Ich habe die Vertrauenseinstellung fürs CERT vergessen :(( nun hat alles auf den 1 Versuch geklappt. Danke Dir PS: Youtube hatte dieses mal geholfen :)
            Gruß Marco
            << kann gelöscht oder verschoben werden >>
            • Marco TönjesM Marco Tönjes
              OFFTOPIC
              Gruß Marco
              #519
              @Marco-Tönjes ich verstehe Nicht was du meinst? Wenn es um einen anderen Adapter geht ist es wiiiirklich off topic
                #520
                So, auf GitHub gibts jetzt die 2.0.0 ... Calllists gehen auch wieder
                jetzt sagt mal .. was ist jetzt noch offen?
                Generell eine Info zu "Sate-Aktualisierungen" bei dem Adapter: States werden nur dann aktualisiert wenn sich der Wert auch ändert! Das hat soef so gebaut und ist immer noch so drin.
                Wenn sich alse caller/callee oder so nicht ändern dann vllt weil es der gleiche Wert wäre wie vorher?
                Im Debug Log sieht man jetzt schön was geschrieben wird.
                Es wäre super wenn jemand mal noch testen könnte das doe phonebook.number/name States funktionieren und da sind wo Sie sein sollen.
                • KnallochseK Nicht stören
                  Knallochse
                  #521
                  @apollon77 wäre es möglich den Adapter so zu erweitern, dass er anzeigt mit welchem Zugangspunkt im Mesh Netzwerk die WLAN Geräte verbunden sind? (Fritzbox, Repeater1, Repeater2 usw.)
                  • KnallochseK Knallochse
                    #522
                    @Knallochse Jetzt lass uns das ding erstmal irgendwie überhaupt wieder zum laufen bringen ... Feature Requests -> GitHub issue bitte
                    KnallochseK 1 Antwort Letzte Antwort
                      Knallochse
                      #523
                      @apollon77 Sorry, war von mir nicht als Aufforderung gemeint. Du leistest hervorragende Arbeit und ich bin Dankbar für deinen Einsatz.
                        #524
                        @Knallochse Alles gut :-) Ich bin nur gerade in dem einen Fokus und der dauert schon deutlich länger als gedacht :-( bevor wir da neue Features einbauen muss man umfangreicher ran
                          klmf2
                          #525
                          so wie ich das verstanden habe, kann man über den Adapter das Bild mit dem QR-Code des Gäste Wlan herunterladen.
                          Ich finde aber nichts, wie man das hin bekommt. Sämtlich Suchbegriffe führten mich nicht weiter. Kann mir jemand sagen, wo ich weitere Infos nachlesen kann? Muss ich dazu bei Command etwas eingeben?
                          • K klmf2
                            sigi234S Online
                            sigi234S Online
                            #526
                            @klmf2 sagte in Test Adapter tr-064-community v1.0.x:
                            JS Skript:
                            // https://www.npmjs.com/package/qr-image
                            var MySSID          = "xxx";           //  SSID Name
                            var MyCrypt         = "xxx";                //  [WEP|WPA|WPA2]
                            var MyVisibility    = "n";                  //  Hidden SSID?
                            var cronStr         = "1 3 * * *"           // Script wird jeden Tag um 03:01 Ausgeführt
                            var idQRZiel = "javascript.0.QR-Code.Gast"; // Zieldatenpunkt für QR-Code
                            var IdGPasswd = "tr-064-community.0.states.wlanGuestPassword"; /*wlanGuestPassword*/
                            if(MyVisibility == "y") {
                                var MyHidden="H:true";
                            else {
                                MyHidden="";
                            createState(idQRZiel, "", {
                                 name: 'QR-Code für Gastpasswort',
                                 desc: 'QR-Code für Gastpasswort',
                                 type: 'string',
                                 role: 'value'
                            function randomString(length) {         // Methode zur Erstellung eines Random-Passworts kann angepasst werden
                                return Math.round((Math.pow(36, length + 1) - Math.random() * Math.pow(36, length))).toString(36).slice(1);
                            function createQRcode() {
                                var qr = require('qr-image');
                                var NewPasswd = randomString(16);       // 16 Stelliges Passwort
                                     var svg_string = qr.imageSync('WIFI:S:'+MySSID+';T:'+MyCrypt+';P:'+NewPasswd+';'+MyHidden+';', { type: 'svg' });
                                setState(idQRZiel, svg_string);
                                setState(IdGPasswd, NewPasswd);
                            // regelmässige Wiederholungen
                            schedule(cronStr, createQRcode);
                            Widget:
                            [{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"{javascript.0.QR-Code.Gast}"},"style":{"left":"1178px","top":"606px","width":"116px","height":"104px","z-index":"2"},"widgetSet":"basic"}]
                              klmf2
                              #527
                              Hups - das ging schnell. Vielen Dank
                              • K klmf2
                                sigi234S Online
                                sigi234S Online
                                #528
                                Bitte benutzt das Voting rechts unten im Beitrag wenn er euch geholfen hat.😀
                                  #529
                                  Hey alle ausser Sigi234 (der hat heute Tagsüber schon mit mir massiv getestet) ... Wie ist der Stand? Jemand die 2.0.0 probiert? Alles ok? Was fehlt?
                                  sigi234S K crunchipC ? bahnuhrB 5 Antworten Letzte Antwort
                                  • sigi234S sigi234
                                    klmf2
                                    #530
                                    @sigi234 sagte in Test Adapter tr-064-community v1.0.x:
                                    Mache ich gerne. Habe aber noch Fehlermeldungen. Schaue mir das gerade genauer an.
                                    javascript.0	2019-12-14 00:05:00.043	error	(7480) at Timer.processTimers (timers.js:223:10)
                                    javascript.0	2019-12-14 00:05:00.043	error	(7480) at listOnTimeout (timers.js:263:5)
                                    javascript.0	2019-12-14 00:05:00.041	error	(7480) at tryOnTimeout (timers.js:300:5)
                                    javascript.0	2019-12-14 00:05:00.041	error	(7480) at ontimeout (timers.js:436:11)
                                    javascript.0	2019-12-14 00:05:00.040	error	(7480) at Timeout._onTimeout (C:\Program Files\iobroker\iobroker\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:501:7)
                                    javascript.0	2019-12-14 00:05:00.040	error	(7480) at C:\Program Files\iobroker\iobroker\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:543:11
                                    javascript.0	2019-12-14 00:05:00.040	error	(7480) at Job.invoke (C:\Program Files\iobroker\iobroker\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:173:10)
                                    javascript.0	2019-12-14 00:05:00.039	error	(7480) at Job.nodeSchedule.scheduleJob [as job] (C:\Program Files\iobroker\iobroker\node_modules\iobroker.javascript\lib\sandbox.js:1181:34)
                                    javascript.0	2019-12-14 00:05:00.038	error	(7480) at Object.createQRcode (script.js.common.Telefon_FritzBox.GästePasswort_lesen:34:30)
                                    javascript.0	2019-12-14 00:05:00.029	error	(7480) Error in callback: TypeError: Cannot read property 'imageSync' of undefined
                                    javascript.0	2019-12-14 00:05:00.027	error	(7480) at Timer.processTimers (timers.js:223:10)
                                    javascript.0	2019-12-14 00:05:00.027	error	(7480) at listOnTimeout (timers.js:263:5)
                                    javascript.0	2019-12-14 00:05:00.027	error	(7480) at tryOnTimeout (timers.js:300:5)
                                    javascript.0	2019-12-14 00:05:00.026	error	(7480) at ontimeout (timers.js:436:11)
                                    javascript.0	2019-12-14 00:05:00.026	error	(7480) at Timeout._onTimeout (C:\Program Files\iobroker\iobroker\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:501:7)
                                    javascript.0	2019-12-14 00:05:00.025	error	(7480) at C:\Program Files\iobroker\iobroker\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:543:11
                                    javascript.0	2019-12-14 00:05:00.025	error	(7480) at Job.invoke (C:\Program Files\iobroker\iobroker\node_modules\iobroker.javascript\node_modules\node-schedule\lib\schedule.js:173:10)
                                    javascript.0	2019-12-14 00:05:00.024	error	(7480) at Job.nodeSchedule.scheduleJob [as job] (C:\Program Files\iobroker\iobroker\node_modules\iobroker.javascript\lib\sandbox.js:1181:34)
                                    javascript.0	2019-12-14 00:05:00.024	error	(7480) at Object.createQRcode (script.js.common.Telefon_FritzBox.GästePasswort_lesen:32:14)
                                    javascript.0	2019-12-14 00:05:00.023	error	(7480) script.js.common.Telefon_FritzBox.GästePasswort_lesen: Error: Cannot find module 'C:\Program Files\iobroker\iobroker\node_modules\iobroker.javascript\lib/../../qr-image'
                                    • K klmf2
                                      sigi234S Online
                                      sigi234S Online
                                      #531
                                      Du musst das Modul qr-image in den JS Adapter eintragen! Neu starten.
                                        klmf2
                                        #532
                                        jau Klasse. Läuft. :-)
                                          sigi234S Online
                                          sigi234S Online
                                          #533
                                          @apollon77 sagte in Test Adapter tr-064-community v1.0.x:
                                          gibt es wo eine Api was alles ausgelesen werden kann, die FB hat ja einen Menge an Daten.
                                          Da hätte ich für später mal noch so einige Wünsche. 😀
