  4. Test Adapter tr-064-community v1.0.x
    6.0k
tr-064community
727 Beiträge 88 Kommentatoren 243.7k Aufrufe 66 Beobachtet
  • apollon77A Offline
    #480
    Oooook ... ich hab mal erste DInge verändert. Bitte nochmal neu versuchen vom GitHub, bitte checkt aber auch ob der ganze Rest (also auch IP.Devices und so) noch so tut wie es soll.
    Und bitte extra Skripte weglassen. Danke
    conectasC 1 Antwort Letzte Antwort
    • apollon77A apollon77
      conectasC Offline
      conectasC Offline
      conectas
      schrieb am zuletzt editiert von conectas
      #481
      Knallt...
      2019-12-12 21:24:14.636  - info: host.raspberrypi "system.adapter.tr-064-community.0" enabled
      2019-12-12 21:24:14.666  - info: host.raspberrypi instance system.adapter.tr-064-community.0 started with pid 18626
      2019-12-12 21:24:17.602  - debug: tr-064-community.0 (18626) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2019-12-12 21:24:17.671  - debug: tr-064-community.0 (18626) Objects client ready ... initialize now
      2019-12-12 21:24:17.680  - debug: tr-064-community.0 (18626) Objects create PubSub Client
      2019-12-12 21:24:17.683  - debug: tr-064-community.0 (18626) Objects client initialize lua scripts
      2019-12-12 21:24:17.712  - debug: tr-064-community.0 (18626) objectDB connected
      2019-12-12 21:24:17.718  - debug: tr-064-community.0 (18626) Redis States: Use Redis connection: 127.0.0.1:9000
      2019-12-12 21:24:17.725  - debug: tr-064-community.0 (18626) Objects connected to redis: 127.0.0.1:9001
      2019-12-12 21:24:17.735  - debug: tr-064-community.0 (18626) States create PubSub Client
      2019-12-12 21:24:17.738  - debug: tr-064-community.0 (18626) statesDB connected
      2019-12-12 21:24:17.805  - debug: tr-064-community.0 (18626) States connected to redis: 127.0.0.1:9000
      2019-12-12 21:24:18.366  - info: tr-064-community.0 (18626) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.17.0
      2019-12-12 21:24:21.236  - error: tr-064-community.0 (18626) uncaught exception: st is not defined
      2019-12-12 21:24:21.241  - error: tr-064-community.0 (18626) ReferenceError: st is not defined
          at createObjects (/opt/iobroker/node_modules/iobroker.tr-064-community/main.js:102:59)
          at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:940:9
          at /opt/iobroker/node_modules/iobroker.tr-064-community/lib/soef.js:1610:28
          at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
          at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:306:18)
          at Parser.emit (events.js:198:13)
          at SAXParser.onclosetag (/opt/iobroker/node_modules/xml2js/lib/parser.js:264:26)
          at emit (/opt/iobroker/node_modules/sax/lib/sax.js:624:35)
          at emitNode (/opt/iobroker/node_modules/sax/lib/sax.js:629:5)
          at closeTag (/opt/iobroker/node_modules/sax/lib/sax.js:889:7)
      2019-12-12 21:24:21.300  - info: tr-064-community.0 (18626) terminating
      2019-12-12 21:24:21.303  - info: tr-064-community.0 (18626) Terminated (NO_ERROR): Without reason
      2019-12-12 21:24:21.861  - error: host.raspberrypi Caught by controller[0]: ReferenceError: st is not defined
      2019-12-12 21:24:21.864  - error: host.raspberrypi Caught by controller[0]:     at createObjects (/opt/iobroker/node_modules/iobroker.tr-064-community/main.js:102:59)
      2019-12-12 21:24:21.865  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:940:9
      2019-12-12 21:24:21.866  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.tr-064-community/lib/soef.js:1610:28
      2019-12-12 21:24:21.866  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
      2019-12-12 21:24:21.867  - error: host.raspberrypi Caught by controller[0]:     at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:306:18)
      2019-12-12 21:24:21.867  - error: host.raspberrypi Caught by controller[0]:     at Parser.emit (events.js:198:13)
      2019-12-12 21:24:21.868  - error: host.raspberrypi Caught by controller[0]:     at SAXParser.onclosetag (/opt/iobroker/node_modules/xml2js/lib/parser.js:264:26)
      2019-12-12 21:24:21.868  - error: host.raspberrypi Caught by controller[0]:     at emit (/opt/iobroker/node_modules/sax/lib/sax.js:624:35)
      2019-12-12 21:24:21.869  - error: host.raspberrypi Caught by controller[0]:     at emitNode (/opt/iobroker/node_modules/sax/lib/sax.js:629:5)
      2019-12-12 21:24:21.869  - error: host.raspberrypi Caught by controller[0]:     at closeTag (/opt/iobroker/node_modules/sax/lib/sax.js:889:7)
      2019-12-12 21:24:21.870  - info: host.raspberrypi instance system.adapter.tr-064-community.0 terminated with code 0 (NO_ERROR)
      2019-12-12 21:24:21.870  - info: host.raspberrypi Restart adapter system.adapter.tr-064-community.0 because enabled
        #482
        gggrrrr ... fixed on GitHub. Sorry
          conectasC Offline
          conectasC Offline
          conectas
          #483
          @apollon77
          außer toPauseState werden im callmonitor nix angelegt.. 2x getestet
          • conectasC conectas
            @apollon77
            #484
            @conectas Hast Du wieder ein Log?
              conectasC Offline
              conectasC Offline
              conectas
              #485
              @apollon77
              vom Start .. da steht dann man ganzes Telefonbuch drin ;-)
              (habe auch Telefon .. falls de nicht tippen magst)
                @apollon77
                #486
                @conectas In dem Fall interessiert mich ja eher der "call" teil ... Ansonsten per email an iobroker@fischer-ka.de schicken
                  conectasC Offline
                  conectasC Offline
                  conectas
                  #487
                  @apollon77
                  2019-12-12 21:46:45.420  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:46:45;CALL;1;4;254xy;628xy7;SIP3;\r\n"
                  2019-12-12 21:46:45.422  - debug: tr-064-community.0 (23433) callmonitor handle outbound message: {"caller":"254xy","callee":"628xy7","extension":"4"}
                  2019-12-12 21:46:45.428  - debug: tr-064-community.0 (23433) Search number 004930254xy in phonebook: {"name":"NNAme Stefan","normalizedName":"NNAmestefan","number":"004930254xy","id":"634","phonebookId":"0"}
                  2019-12-12 21:46:45.430  - debug: tr-064-community.0 (23433) Search number 004930628xy7 in phonebook: {"name":"NNAme Stefan","normalizedName":"NNAmestefan","number":"004930628xy7","id":"634","phonebookId":"0"}
                  2019-12-12 21:46:45.431  - debug: tr-064-community.0 (23433) callMonitor.set: type=outbound caller=254xy callee=628xy7 callerName=NNAme Stefan calleeName=NNAme Stefan
                  2019-12-12 21:46:45.790  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:46:45;RING;2;030254xy;628xy7;SIP1;\r\n"
                  2019-12-12 21:46:45.792  - debug: tr-064-community.0 (23433) callmonitor handle inbound message: {"caller":"030254xy","callee":"628xy7"}
                  2019-12-12 21:46:45.794  - debug: tr-064-community.0 (23433) Search number 004930254xy in phonebook: {"name":"NNAme Stefan","normalizedName":"NNAmestefan","number":"004930254xy","id":"634","phonebookId":"0"}
                  2019-12-12 21:46:45.796  - debug: tr-064-community.0 (23433) Search number 004930628xy7 in phonebook: {"name":"NNAme Stefan","normalizedName":"NNAmestefan","number":"004930628xy7","id":"634","phonebookId":"0"}
                  2019-12-12 21:46:45.799  - debug: tr-064-community.0 (23433) callMonitor.set: type=inbound caller=030254xy callee=628xy7 callerName=NNAme Stefan calleeName=NNAme Stefan
                  2019-12-12 21:46:47.697  - debug: tr-064-community.0 (23433) in updateAll
                  2019-12-12 21:46:47.699  - debug: tr-064-community.0 (23433) updateDevices
                  2019-12-12 21:46:47.701  - debug: tr-064-community.0 (23433) forEachConfiguredDevice
                  2019-12-12 21:46:47.779  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:46:47;CONNECT;2;11;030254xy;\r\n"
                  2019-12-12 21:46:47.781  - debug: tr-064-community.0 (23433) callmonitor handle connect message: {"caller":"030254xy","callee":"628xy7","_type":"inbound","callerName":"NNAme Stefan","calleeName":"NNAme Stefan","extension":"11"}
                  2019-12-12 21:46:47.790  - debug: tr-064-community.0 (23433) callMonitor.set: type=connect caller=030254xy callee=628xy7 callerName=NNAme Stefan calleeName=NNAme Stefan
                  2019-12-12 21:46:47.906  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:46:47;CONNECT;1;4;628xy7;\r\n"
                  2019-12-12 21:46:47.907  - debug: tr-064-community.0 (23433) callmonitor handle connect message: {"caller":"254xy","callee":"628xy7","extension":"4","_type":"outbound","callerName":"NNAme Stefan","calleeName":"NNAme Stefan"}
                  2019-12-12 21:46:47.911  - debug: tr-064-community.0 (23433) callMonitor.set: type=connect caller=254xy callee=628xy7 callerName=NNAme Stefan calleeName=NNAme Stefan
                  2019-12-12 21:46:50.443  - debug: tr-064-community.0 (23433) setting 0 enable=false
                  2019-12-12 21:46:50.444  - debug: tr-064-community.0 (23433) setting 1 enable=false
                  2019-12-12 21:46:50.444  - debug: tr-064-community.0 (23433) setting 2 enable=false
                  2019-12-12 21:46:50.445  - debug: tr-064-community.0 (23433) setting 3 enable=false
                  2019-12-12 21:46:50.445  - debug: tr-064-community.0 (23433) setting 4 enable=false
                  2019-12-12 21:46:50.446  - debug: tr-064-community.0 (23433) setting 5 enable=true
                  2019-12-12 21:46:50.446  - debug: tr-064-community.0 (23433) setting 6 enable=true
                  2019-12-12 21:46:50.446  - debug: tr-064-community.0 (23433) setting 7 enable=true
                  2019-12-12 21:46:50.447  - debug: tr-064-community.0 (23433) setting 8 enable=true
                  2019-12-12 21:46:50.448  - debug: tr-064-community.0 (23433) setting 9 enable=true
                  2019-12-12 21:46:52.331  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:46:52;DISCONNECT;1;5;\r\n"
                  2019-12-12 21:46:52.341  - debug: tr-064-community.0 (23433) callmonitor handle lastCall message: {"caller":"254xy","callee":"628xy7","extension":"4","_type":"connect","callerName":"NNAme Stefan","calleeName":"NNAme Stefan","type":"disconnect","duration":5}
                  2019-12-12 21:46:52.347  - debug: tr-064-community.0 (23433) callMonitor.set: type=lastCall caller=254xy callee=628xy7 callerName=NNAme Stefan calleeName=NNAme Stefan
                  2019-12-12 21:46:52.374  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:46:52;DISCONNECT;2;5;\r\n"
                  2019-12-12 21:46:52.375  - debug: tr-064-community.0 (23433) callmonitor handle lastCall message: {"caller":"030254xy","callee":"628xy7","_type":"connect","callerName":"NNAme Stefan","calleeName":"NNAme Stefan","extension":"11","type":"disconnect","duration":5}
                  2019-12-12 21:46:52.380  - debug: tr-064-community.0 (23433) callMonitor.set: type=lastCall caller=030254xy callee=628xy7 callerName=NNAme Stefan calleeName=NNAme Stefan
                    @apollon77
                    conectasC Offline
                    conectasC Offline
                    conectas
                    #488
                    @conectas
                    glaube das ist besser.. wegen den Namen? Ansonsten gleich
                    2019-12-12 21:49:26.143  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:49:26;CALL;1;4;254xy;628xy6;SIP3;\r\n"
                    2019-12-12 21:49:26.144  - debug: tr-064-community.0 (23433) callmonitor handle outbound message: {"caller":"254xy","callee":"628xy6","extension":"4"}
                    2019-12-12 21:49:26.145  - debug: tr-064-community.0 (23433) Search number 004930254xy in phonebook: {"name":"NName Stefan","normalizedName":"NNamestefan","number":"004930254xy","id":"634","phonebookId":"0"}
                    2019-12-12 21:49:26.150  - debug: tr-064-community.0 (23433) Search number 004930628xy6 in phonebook: {"name":"NName Kerstin","normalizedName":"NNamekerstin","number":"004930628xy6","id":"631","phonebookId":"0"}
                    2019-12-12 21:49:26.151  - debug: tr-064-community.0 (23433) callMonitor.set: type=outbound caller=254xy callee=628xy6 callerName=NName Stefan calleeName=NName Kerstin
                    2019-12-12 21:49:26.526  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:49:26;RING;2;030254xy;628xy6;SIP0;\r\n"
                    2019-12-12 21:49:26.527  - debug: tr-064-community.0 (23433) callmonitor handle inbound message: {"caller":"030254xy","callee":"628xy6"}
                    2019-12-12 21:49:26.529  - debug: tr-064-community.0 (23433) Search number 004930254xy in phonebook: {"name":"NName Stefan","normalizedName":"NNamestefan","number":"004930254xy","id":"634","phonebookId":"0"}
                    2019-12-12 21:49:26.531  - debug: tr-064-community.0 (23433) Search number 004930628xy6 in phonebook: {"name":"NName Kerstin","normalizedName":"NNamekerstin","number":"004930628xy6","id":"631","phonebookId":"0"}
                    2019-12-12 21:49:26.532  - debug: tr-064-community.0 (23433) callMonitor.set: type=inbound caller=030254xy callee=628xy6 callerName=NName Stefan calleeName=NName Kerstin
                    2019-12-12 21:49:30.495  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:49:30;CONNECT;2;11;030254xy;\r\n"
                    2019-12-12 21:49:30.497  - debug: tr-064-community.0 (23433) callmonitor handle connect message: {"caller":"030254xy","callee":"628xy6","_type":"inbound","callerName":"NName Stefan","calleeName":"NName Kerstin","extension":"11"}
                    2019-12-12 21:49:30.517  - debug: tr-064-community.0 (23433) callMonitor.set: type=connect caller=030254xy callee=628xy6 callerName=NName Stefan calleeName=NName Kerstin
                    2019-12-12 21:49:30.537  - debug: tr-064-community.0 (23433) in updateAll
                    2019-12-12 21:49:30.542  - debug: tr-064-community.0 (23433) updateDevices
                    2019-12-12 21:49:30.543  - debug: tr-064-community.0 (23433) forEachConfiguredDevice
                    2019-12-12 21:49:30.633  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:49:30;CONNECT;1;4;628xy6;\r\n"
                    2019-12-12 21:49:30.635  - debug: tr-064-community.0 (23433) callmonitor handle connect message: {"caller":"254xy","callee":"628xy6","extension":"4","_type":"outbound","callerName":"NName Stefan","calleeName":"NName Kerstin"}
                    2019-12-12 21:49:30.640  - debug: tr-064-community.0 (23433) callMonitor.set: type=connect caller=254xy callee=628xy6 callerName=NName Stefan calleeName=NName Kerstin
                    2019-12-12 21:49:33.283  - debug: tr-064-community.0 (23433) setting 0 enable=false
                    2019-12-12 21:49:33.284  - debug: tr-064-community.0 (23433) setting 1 enable=false
                    2019-12-12 21:49:33.285  - debug: tr-064-community.0 (23433) setting 2 enable=false
                    2019-12-12 21:49:33.290  - debug: tr-064-community.0 (23433) setting 3 enable=false
                    2019-12-12 21:49:33.291  - debug: tr-064-community.0 (23433) setting 4 enable=false
                    2019-12-12 21:49:33.291  - debug: tr-064-community.0 (23433) setting 5 enable=true
                    2019-12-12 21:49:33.292  - debug: tr-064-community.0 (23433) setting 6 enable=true
                    2019-12-12 21:49:33.293  - debug: tr-064-community.0 (23433) setting 7 enable=true
                    2019-12-12 21:49:33.293  - debug: tr-064-community.0 (23433) setting 8 enable=true
                    2019-12-12 21:49:33.294  - debug: tr-064-community.0 (23433) setting 9 enable=true
                    2019-12-12 21:49:33.520  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:49:33;DISCONNECT;1;3;\r\n"
                    2019-12-12 21:49:33.522  - debug: tr-064-community.0 (23433) callmonitor handle lastCall message: {"caller":"254xy","callee":"628xy6","extension":"4","_type":"connect","callerName":"NName Stefan","calleeName":"NName Kerstin","type":"disconnect","duration":3}
                    2019-12-12 21:49:33.528  - debug: tr-064-community.0 (23433) callMonitor.set: type=lastCall caller=254xy callee=628xy6 callerName=NName Stefan calleeName=NName Kerstin
                    2019-12-12 21:49:33.564  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:49:33;DISCONNECT;2;4;\r\n"
                    2019-12-12 21:49:33.573  - debug: tr-064-community.0 (23433) callmonitor handle lastCall message: {"caller":"030254xy","callee":"628xy6","_type":"connect","callerName":"NName Stefan","calleeName":"NName Kerstin","extension":"11","type":"disconnect","duration":4}
                    2019-12-12 21:49:33.580  - debug: tr-064-community.0 (23433) callMonitor.set: type=lastCall caller=030254xy callee=628xy6 callerName=NName Stefan calleeName=NName Kerstin
                    2019-12-12 21:49:43.296  - debug: tr-064-community.0 (23433) in updateAll
                    2019-12-12 21:49:43.299  - debug: tr-064-community.0 (23433) updateDevices
                    2019-12-12 21:49:43.300  - debug: tr-064-community.0 (23433) forEachConfiguredDevice
                    2019-12-12 21:49:45.844  - debug: tr-064-community.0 (23433) setting 0 enable=false
                    2019-12-12 21:49:45.845  - debug: tr-064-community.0 (23433) setting 1 enable=false
                    2019-12-12 21:49:45.846  - debug: tr-064-community.0 (23433) setting 2 enable=false
                    2019-12-12 21:49:45.847  - debug: tr-064-community.0 (23433) setting 3 enable=false
                    2019-12-12 21:49:45.847  - debug: tr-064-community.0 (23433) setting 4 enable=false
                    2019-12-12 21:49:45.847  - debug: tr-064-community.0 (23433) setting 5 enable=true
                    2019-12-12 21:49:45.848  - debug: tr-064-community.0 (23433) setting 6 enable=true
                    2019-12-12 21:49:45.848  - debug: tr-064-community.0 (23433) setting 7 enable=true
                    2019-12-12 21:49:45.854  - debug: tr-064-community.0 (23433) setting 8 enable=true
                    2019-12-12 21:49:45.854  - debug: tr-064-community.0 (23433) setting 9 enable=true
                      #489
                      Und dann nochmal bitte von GitHub. Logging nochmal erweitert und so
                        conectasC Offline
                        conectasC Offline
                        conectas
                        #490
                        @apollon77
                        Bitte am Ende des Tages bitte nicht vergessen eine func Version rein zu legen (habe gerade festgestellt das im iobroker backup .. nix von tr-064 drin ist)
                        1. Ich muss wahrscheinlich gleich Mittag essen... sonst wird die besagte Kerstin .. na ja ;-)
                        2019-12-12 22:08:04.642  - debug: tr-064-community.0 (31690) callmonitor raw data: "12.12.19 22:08:04;CALL;1;4;254xy;628xy6;SIP3;\r\n"
                        2019-12-12 22:08:04.643  - debug: tr-064-community.0 (31690) callmonitor handle outbound message: {"caller":"254xy","callee":"628xy6","extension":"4"}
                        2019-12-12 22:08:04.647  - debug: tr-064-community.0 (31690) Search number 004930254xy in phonebook: {"name":"NNAme Stefan","normalizedName":"NNAmestefan","number":"004930254xy","id":"634","phonebookId":"0"}
                        2019-12-12 22:08:04.652  - debug: tr-064-community.0 (31690) Search number 004930628xy6 in phonebook: {"name":"NNAme Kerstin","normalizedName":"NNAmekerstin","number":"004930628xy6","id":"631","phonebookId":"0"}
                        2019-12-12 22:08:04.656  - debug: tr-064-community.0 (31690) callMonitor.set: type=outbound caller=254xy callee=628xy6 callerName=NNAme Stefan calleeName=NNAme Kerstin
                        2019-12-12 22:08:04.686  - debug: tr-064-community.0 (31690) State-Change {"val":false,"ack":true,"ts":1576184884671,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184855434}
                        2019-12-12 22:08:04.693  - debug: tr-064-community.0 (31690) State-Change {"val":"254xy","ack":true,"ts":1576184884672,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182914392}
                        2019-12-12 22:08:04.699  - debug: tr-064-community.0 (31690) State-Change {"val":"628xy6","ack":true,"ts":1576184884676,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184851355}
                        2019-12-12 22:08:04.704  - debug: tr-064-community.0 (31690) State-Change {"val":"4","ack":true,"ts":1576184884677,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182914401}
                        2019-12-12 22:08:04.708  - debug: tr-064-community.0 (31690) State-Change {"val":"12.12.19 22:08:04","ack":true,"ts":1576184884678,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184884678}
                        2019-12-12 22:08:04.711  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184884680,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182914403}
                        2019-12-12 22:08:04.717  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184884681,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184851367}
                        2019-12-12 22:08:04.721  - debug: tr-064-community.0 (31690) State-Change {"val":"{\"caller\":\"254xy\",\"callee\":\"628xy6\",\"extension\":\"4\",\"_type\":\"outbound\",\"callerName\":\"NNAme Stefan\",\"calleeName\":\"NNAme Kerstin\"}","ack":true,"ts":1576184884682,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184851368}
                        2019-12-12 22:08:04.999  - debug: tr-064-community.0 (31690) callmonitor raw data: "12.12.19 22:08:04;RING;2;030254xy;628xy6;SIP0;\r\n"
                        2019-12-12 22:08:05.000  - debug: tr-064-community.0 (31690) callmonitor handle inbound message: {"caller":"030254xy","callee":"628xy6"}
                        2019-12-12 22:08:05.003  - debug: tr-064-community.0 (31690) Search number 004930254xy in phonebook: {"name":"NNAme Stefan","normalizedName":"NNAmestefan","number":"004930254xy","id":"634","phonebookId":"0"}
                        2019-12-12 22:08:05.004  - debug: tr-064-community.0 (31690) Search number 004930628xy6 in phonebook: {"name":"NNAme Kerstin","normalizedName":"NNAmekerstin","number":"004930628xy6","id":"631","phonebookId":"0"}
                        2019-12-12 22:08:05.006  - debug: tr-064-community.0 (31690) callMonitor.set: type=inbound caller=030254xy callee=628xy6 callerName=NNAme Stefan calleeName=NNAme Kerstin
                        2019-12-12 22:08:05.022  - debug: tr-064-community.0 (31690) State-Change {"val":true,"ack":true,"ts":1576184885010,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184885010}
                        2019-12-12 22:08:05.026  - debug: tr-064-community.0 (31690) State-Change {"val":"030254xy","ack":true,"ts":1576184885011,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576183605807}
                        2019-12-12 22:08:05.031  - debug: tr-064-community.0 (31690) State-Change {"val":"628xy6","ack":true,"ts":1576184885011,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184851814}
                        2019-12-12 22:08:05.034  - debug: tr-064-community.0 (31690) State-Change {"val":"12.12.19 22:08:04","ack":true,"ts":1576184885011,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184885011}
                        2019-12-12 22:08:05.039  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184885012,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182914757}
                        2019-12-12 22:08:05.044  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184885013,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184851817}
                        2019-12-12 22:08:05.048  - debug: tr-064-community.0 (31690) State-Change {"val":"{\"caller\":\"030254xy\",\"callee\":\"628xy6\",\"_type\":\"inbound\",\"callerName\":\"NNAme Stefan\",\"calleeName\":\"NNAme Kerstin\"}","ack":true,"ts":1576184885014,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184851819}
                        2019-12-12 22:08:05.053  - debug: tr-064-community.0 (31690) State-Change {"val":"ring","ack":true,"ts":1576184885014,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184885014}
                        2019-12-12 22:08:08.937  - debug: tr-064-community.0 (31690) in updateAll
                        2019-12-12 22:08:08.939  - debug: tr-064-community.0 (31690) updateDevices
                        2019-12-12 22:08:08.940  - debug: tr-064-community.0 (31690) forEachConfiguredDevice
                        2019-12-12 22:08:09.991  - debug: tr-064-community.0 (31690) callmonitor raw data: "12.12.19 22:08:09;CONNECT;2;11;030254xy;\r\n"
                        2019-12-12 22:08:09.993  - debug: tr-064-community.0 (31690) callmonitor handle connect message: {"caller":"030254xy","callee":"628xy6","_type":"inbound","callerName":"NNAme Stefan","calleeName":"NNAme Kerstin","extension":"11"}
                        2019-12-12 22:08:09.997  - debug: tr-064-community.0 (31690) callMonitor.set: type=connect caller=030254xy callee=628xy6 callerName=NNAme Stefan calleeName=NNAme Kerstin
                        2019-12-12 22:08:10.022  - debug: tr-064-community.0 (31690) State-Change {"val":false,"ack":true,"ts":1576184890002,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890002}
                        2019-12-12 22:08:10.027  - debug: tr-064-community.0 (31690) State-Change {"val":"030254xy","ack":true,"ts":1576184890003,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890003}
                        2019-12-12 22:08:10.032  - debug: tr-064-community.0 (31690) State-Change {"val":"628xy6","ack":true,"ts":1576184890003,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576183770528}
                        2019-12-12 22:08:10.037  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184890004,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182926674}
                        2019-12-12 22:08:10.042  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184890005,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576183770530}
                        2019-12-12 22:08:10.047  - debug: tr-064-community.0 (31690) State-Change {"val":"11","ack":true,"ts":1576184890006,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890006}
                        2019-12-12 22:08:10.055  - debug: tr-064-community.0 (31690) State-Change {"val":"12.12.19 22:08:09","ack":true,"ts":1576184890006,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890006}
                        2019-12-12 22:08:10.060  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184890007,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182926676}
                        2019-12-12 22:08:10.063  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184890016,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576183770535}
                        2019-12-12 22:08:10.083  - debug: tr-064-community.0 (31690) State-Change {"val":"{\"caller\":\"030254xy\",\"callee\":\"628xy6\",\"_type\":\"connect\",\"callerName\":\"NNAme Stefan\",\"calleeName\":\"NNAme Kerstin\",\"extension\":\"11\"}","ack":true,"ts":1576184890017,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890017}
                        2019-12-12 22:08:10.087  - debug: tr-064-community.0 (31690) State-Change {"val":"connect","ack":true,"ts":1576184890019,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890019}
                        2019-12-12 22:08:10.089  - debug: tr-064-community.0 (31690) State-Change {"val":"connect","ack":true,"ts":1576184890019,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890019}
                        2019-12-12 22:08:10.105  - debug: tr-064-community.0 (31690) callmonitor raw data: "12.12.19 22:08:10;CONNECT;1;4;628xy6;\r\n"
                        2019-12-12 22:08:10.106  - debug: tr-064-community.0 (31690) callmonitor handle connect message: {"caller":"254xy","callee":"628xy6","extension":"4","_type":"outbound","callerName":"NNAme Stefan","calleeName":"NNAme Kerstin"}
                        2019-12-12 22:08:10.113  - debug: tr-064-community.0 (31690) callMonitor.set: type=connect caller=254xy callee=628xy6 callerName=NNAme Stefan calleeName=NNAme Kerstin
                        2019-12-12 22:08:10.126  - debug: tr-064-community.0 (31690) State-Change {"val":false,"ack":true,"ts":1576184890118,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890002}
                        2019-12-12 22:08:10.130  - debug: tr-064-community.0 (31690) State-Change {"val":"254xy","ack":true,"ts":1576184890119,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890119}
                        2019-12-12 22:08:10.135  - debug: tr-064-community.0 (31690) State-Change {"val":"628xy6","ack":true,"ts":1576184890120,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576183770528}
                        2019-12-12 22:08:10.138  - debug: tr-064-community.0 (31690) State-Change {"val":"4","ack":true,"ts":1576184890120,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890120}
                        2019-12-12 22:08:10.141  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184890121,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182926674}
                        2019-12-12 22:08:10.145  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184890121,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576183770530}
                        2019-12-12 22:08:10.150  - debug: tr-064-community.0 (31690) State-Change {"val":"12.12.19 22:08:10","ack":true,"ts":1576184890121,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890121}
                        2019-12-12 22:08:10.154  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184890122,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182926676}
                        2019-12-12 22:08:10.158  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184890122,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576183770535}
                        2019-12-12 22:08:10.162  - debug: tr-064-community.0 (31690) State-Change {"val":"{\"caller\":\"254xy\",\"callee\":\"628xy6\",\"extension\":\"4\",\"_type\":\"connect\",\"callerName\":\"NNAme Stefan\",\"calleeName\":\"NNAme Kerstin\"}","ack":true,"ts":1576184890123,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890123}
                        2019-12-12 22:08:10.166  - debug: tr-064-community.0 (31690) State-Change {"val":"connect","ack":true,"ts":1576184890123,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890019}
                        2019-12-12 22:08:10.169  - debug: tr-064-community.0 (31690) State-Change {"val":"connect","ack":true,"ts":1576184890124,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890124}
                        2019-12-12 22:08:12.263  - debug: tr-064-community.0 (31690) callmonitor raw data: "12.12.19 22:08:12;DISCONNECT;1;3;\r\n"
                        2019-12-12 22:08:12.264  - debug: tr-064-community.0 (31690) callmonitor handle lastCall message: {"caller":"254xy","callee":"628xy6","extension":"4","_type":"connect","callerName":"NNAme Stefan","calleeName":"NNAme Kerstin","type":"disconnect","duration":3}
                        2019-12-12 22:08:12.270  - debug: tr-064-community.0 (31690) callMonitor.set: type=lastCall caller=254xy callee=628xy6 callerName=NNAme Stefan calleeName=NNAme Kerstin
                        2019-12-12 22:08:12.286  - debug: tr-064-community.0 (31690) State-Change {"val":false,"ack":true,"ts":1576184892275,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890002}
                        2019-12-12 22:08:12.291  - debug: tr-064-community.0 (31690) State-Change {"val":"254xy","ack":true,"ts":1576184892275,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892275}
                        2019-12-12 22:08:12.296  - debug: tr-064-community.0 (31690) State-Change {"val":"628xy6","ack":true,"ts":1576184892276,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184859270}
                        2019-12-12 22:08:12.301  - debug: tr-064-community.0 (31690) State-Change {"val":"4","ack":true,"ts":1576184892277,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892277}
                        2019-12-12 22:08:12.306  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184892277,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182933087}
                        2019-12-12 22:08:12.310  - debug: tr-064-community.0 (31690) callmonitor raw data: "12.12.19 22:08:12;DISCONNECT;2;3;\r\n"
                        2019-12-12 22:08:12.311  - debug: tr-064-community.0 (31690) callmonitor handle lastCall message: {"caller":"030254xy","callee":"628xy6","_type":"connect","callerName":"NNAme Stefan","calleeName":"NNAme Kerstin","extension":"11","type":"disconnect","duration":3}
                        2019-12-12 22:08:12.325  - debug: tr-064-community.0 (31690) callMonitor.set: type=lastCall caller=030254xy callee=628xy6 callerName=NNAme Stefan calleeName=NNAme Kerstin
                        2019-12-12 22:08:12.338  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184892278,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184859272}
                        2019-12-12 22:08:12.340  - debug: tr-064-community.0 (31690) State-Change {"val":"disconnect","ack":true,"ts":1576184892279,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184859273}
                        2019-12-12 22:08:12.343  - debug: tr-064-community.0 (31690) State-Change {"val":3,"ack":true,"ts":1576184892279,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892279}
                        2019-12-12 22:08:12.345  - debug: tr-064-community.0 (31690) State-Change {"val":"12.12.19 22:08:12","ack":true,"ts":1576184892280,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892280}
                        2019-12-12 22:08:12.348  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184892281,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182933103}
                        2019-12-12 22:08:12.350  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184892281,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184859275}
                        2019-12-12 22:08:12.359  - debug: tr-064-community.0 (31690) State-Change {"val":"{\"caller\":\"254xy\",\"callee\":\"628xy6\",\"extension\":\"4\",\"_type\":\"lastCall\",\"callerName\":\"NNAme Stefan\",\"calleeName\":\"NNAme Kerstin\",\"type\":\"disconnect\",\"duration\":3}","ack":true,"ts":1576184892282,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892282}
                        2019-12-12 22:08:12.362  - debug: tr-064-community.0 (31690) State-Change {"val":"end","ack":true,"ts":1576184892282,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892282}
                        2019-12-12 22:08:12.364  - debug: tr-064-community.0 (31690) State-Change {"val":"end","ack":true,"ts":1576184892283,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892283}
                        2019-12-12 22:08:12.384  - debug: tr-064-community.0 (31690) State-Change {"val":false,"ack":true,"ts":1576184892370,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890002}
                        2019-12-12 22:08:12.386  - debug: tr-064-community.0 (31690) State-Change {"val":"030254xy","ack":true,"ts":1576184892375,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892375}
                        2019-12-12 22:08:12.389  - debug: tr-064-community.0 (31690) State-Change {"val":"628xy6","ack":true,"ts":1576184892376,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184859270}
                        2019-12-12 22:08:12.393  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184892376,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182933087}
                        2019-12-12 22:08:12.396  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184892377,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184859272}
                        2019-12-12 22:08:12.398  - debug: tr-064-community.0 (31690) State-Change {"val":"11","ack":true,"ts":1576184892377,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892377}
                        2019-12-12 22:08:12.404  - debug: tr-064-community.0 (31690) State-Change {"val":"disconnect","ack":true,"ts":1576184892378,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184859273}
                        2019-12-12 22:08:12.409  - debug: tr-064-community.0 (31690) State-Change {"val":3,"ack":true,"ts":1576184892378,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892279}
                        2019-12-12 22:08:12.411  - debug: tr-064-community.0 (31690) State-Change {"val":"12.12.19 22:08:12","ack":true,"ts":1576184892378,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892280}
                        2019-12-12 22:08:12.416  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184892379,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182933103}
                        2019-12-12 22:08:12.422  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184892379,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184859275}
                        2019-12-12 22:08:12.425  - debug: tr-064-community.0 (31690) State-Change {"val":"{\"caller\":\"030254xy\",\"callee\":\"628xy6\",\"_type\":\"lastCall\",\"callerName\":\"NNAme Stefan\",\"calleeName\":\"NNAme Kerstin\",\"extension\":\"11\",\"type\":\"disconnect\",\"duration\":3}","ack":true,"ts":1576184892380,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892380}
                        2019-12-12 22:08:12.430  - debug: tr-064-community.0 (31690) State-Change {"val":"end","ack":true,"ts":1576184892380,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892282}
                        2019-12-12 22:08:12.432  - debug: tr-064-community.0 (31690) State-Change {"val":"end","ack":true,"ts":1576184892381,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892381}
                        2019-12-12 22:08:20.527  - debug: tr-064-community.0 (31690) in updateAll
                        2019-12-12 22:08:20.530  - debug: tr-064-community.0 (31690) updateDevices
                        2019-12-12 22:08:20.530  - debug: tr-064-community.0 (31690) forEachConfiguredDevice
                        apollon77A 2 Antworten Letzte Antwort
                        • marcusklM Offline
                          marcusklM Offline
                          marcuskl
                          #491
                          Findet man diesen Adaper schon in IoBroker/Adapter ?
                          Host: Intel Nuc6cayh (16GB Ram, 240GB SSD) mit Proxmox.
                          Iobroker VM, InfluxDB LXC, Pihole LXC, Tasmoadmin LXC, Easy2connect VM
                            @apollon77
                            #492
                            @conectas jetzt sollte aber alles geschrieben werden oder ?! Zumindestens sagt das log das
                              @apollon77
                              #493
                              @conectas sagte in Test Adapter tr-064-community v1.0.x:
                              Das wird so eine Sache ... Den Stand von früher heute wiederherzustellen wir nahezu unmöglich ... und wir müssen jetzt mal endlich vorankommen
                                conectasC Offline
                                conectasC Offline
                                conectas
                                #494
                                @apollon77
                                tr-064-community.0.callmonitor // Hat sich nicht geändert.
                                tr-064-community.0.callForwarding sieht okay aus..
                                tr-064-community.0.states ist bis auf den Eintrag: tr-064-community.0.states.calllists auch leer
                                • marcusklM marcuskl
                                  conectasC Offline
                                  conectasC Offline
                                  conectas
                                  #495
                                  @marcuskl sagte in Test Adapter tr-064-community v1.0.x:
                                  Nein.
                                  marcusklM 1 Antwort Letzte Antwort
                                    der tr-064 Adapter von soef ist mit fast 10.000 Installationen ein sehr oft genutzter Adapter. Leider ist der Entwickler nicht mehr aktiv und so wird auch der Adapter nicht mehr weiterentwickelt. Um dies ggf zu ändern hat sich die Entwicklergruppe der ioBroker-Community-Adapter entschieden die soef Adapter zu übernehmen und versuchen weiterzuentwickeln.
                                    Der erste so etwas aufgefrischte Adapter ist genau der tr-064 Adapter. Am Funktionsumfang hat sich hier noch nichts geändert, aber der Adapter wurde intern aktualisiert.
                                    Jetzt würden wir diese neue Version gern veröffentlichen um Sie als neue Basis zu nutzen.
                                    Die neue Version steht zur manuellen Installation unter GitHub-Link https://github.com/iobroker-community-adapters/ioBroker.tr-064-community zur Verfügung. Installiert einfach per GitHub-Icon.
                                    Die Einstellungen einer bestehenden tr-06 Instanz sollten sich durch Übername des "native"-Teils der Instanzeinstellungen unter system.adapter.tr-064.X (X=Instanznummer) in das neue Instanzobjekt übernehmen lassen.
                                    Hier brauchen wir von Euch Testunterstützung und freuen uns auf Euer Feedback!
                                    Danke für Eure Unterstützung.
                                    Ingo und die anderen Community-Entwickler
                                    sigi234S Online
                                    sigi234S Online
                                    #496
                                    @apollon77
                                    Für Apollon77
                                    • sigi234S sigi234
                                      @apollon77
                                      Für Apollon77
                                      conectasC Offline
                                      conectasC Offline
                                      conectas
                                      #497
                                      @sigi234 sagte in Test Adapter tr-064-community v1.0.x:
                                      oder so.. mit Bild ist ja feige ;-)
                                      bin für 15min weg. Mittagessen...
                                        sigi234S Online
                                        sigi234S Online
                                        #498
                                        Ein Bild sagt mehr als 1000 Worte. 😀
                                          #499
                                          Ok, ich lege jetzt mit dem Stand einen Branch an und rolle alles zurück ... Das Ding braucht nen kompletten rewrite des Object und State handlings.
                                          Also bitte nochmal versuchen, es ist alles soweit reverted und habe an einer Stelle ewas anderes geändert
