  4. Test Adapter tr-064-community v1.0.x
    6.0k
tr-064community
727 Beiträge 88 Kommentatoren 243.7k Aufrufe 66 Beobachtet
  • apollon77A apollon77
    Also dann neue logs bitte und Fälle neu checken.
    conectasC Offline
    conectasC Offline
    conectas
    schrieb am zuletzt editiert von conectas
    #477
    Fall 01: 2mal hintereinander gleicher OUT (0171) auf IN (628yxz6)
    jetzt wird nix (selbst) tr-064-community.0.callmonitor.inbound.json nicht neu geschrieben
    2019-12-12 19:58:38.454  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 19:58:38;RING;2;0171xyz;628xyz6;SIP0;\r\n"
    2019-12-12 19:58:38.456  - debug: tr-064-community.0 (15488) callmonitor handle inbound message: {"caller":"0171xyz","callee":"628xyz6"}
    2019-12-12 19:58:38.457  - debug: tr-064-community.0 (15488) Set State callmonitor.inbound.timestamp: "12.12.19 19:58:38" / ack=true
    2019-12-12 19:58:38.460  - debug: tr-064-community.0 (15488) Search number 0049171xyz in phonebook: {"name":"NNAme Stefan","normalizedName":"NNAmestefan","number":"0049171yxz","id":"634","phonebookId":"0"}
    2019-12-12 19:58:38.463  - debug: tr-064-community.0 (15488) Search number 004930628xyz6 in phonebook: {"name":"NNAme Kerstin","normalizedName":"NNAmekerstin","number":"004930628xyz6","id":"631","phonebookId":"0"}
    2019-12-12 19:58:38.465  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "ring" / ack=true
    2019-12-12 19:58:38.467  - debug: tr-064-community.0 (15488) callMonitor.set: type=inbound caller=0171xyz callee=628xyz6 callerName=NNAme Stefan calleeName=NNAme Kerstin
    2019-12-12 19:58:38.671  - debug: tr-064-community.0 (15488) Set State callmonitor.ringing: true / ack=true
    2019-12-12 19:58:38.841  - debug: tr-064-community.0 (15488) setting 0 enable=false
    2019-12-12 19:58:38.843  - debug: tr-064-community.0 (15488) setting 1 enable=false
    2019-12-12 19:58:38.843  - debug: tr-064-community.0 (15488) setting 2 enable=false
    2019-12-12 19:58:38.844  - debug: tr-064-community.0 (15488) setting 3 enable=false
    2019-12-12 19:58:38.844  - debug: tr-064-community.0 (15488) setting 4 enable=false
    2019-12-12 19:58:38.845  - debug: tr-064-community.0 (15488) setting 5 enable=true
    2019-12-12 19:58:38.845  - debug: tr-064-community.0 (15488) setting 6 enable=true
    2019-12-12 19:58:38.846  - debug: tr-064-community.0 (15488) setting 7 enable=true
    2019-12-12 19:58:38.846  - debug: tr-064-community.0 (15488) setting 8 enable=true
    2019-12-12 19:58:38.847  - debug: tr-064-community.0 (15488) setting 9 enable=true
    2019-12-12 19:58:45.625  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 19:58:45;CONNECT;2;4;0171xyz;\r\n"
    2019-12-12 19:58:45.627  - debug: tr-064-community.0 (15488) callmonitor handle connect message: {"caller":"0171xyz","callee":"628xyz6","_type":"inbound","callerName":"NNAme Stefan","calleeName":"NNAme Kerstin","extension":"4"}
    2019-12-12 19:58:45.628  - debug: tr-064-community.0 (15488) Set State callmonitor.connect.timestamp: "12.12.19 19:58:45" / ack=true
    2019-12-12 19:58:45.629  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "connect" / ack=true
    2019-12-12 19:58:45.630  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState-4: "connect" / ack=true
    2019-12-12 19:58:45.631  - debug: tr-064-community.0 (15488) callMonitor.set: type=connect caller=0171xyz callee=628xyz6 callerName=NNAme Stefan calleeName=NNAme Kerstin
    2019-12-12 19:58:45.833  - debug: tr-064-community.0 (15488) Set State callmonitor.ringing: false / ack=true
    2019-12-12 19:58:48.464  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 19:58:48;DISCONNECT;2;3;\r\n"
    2019-12-12 19:58:48.466  - debug: tr-064-community.0 (15488) callmonitor handle lastCall message: {"caller":"0171xyz","callee":"628xyz6","_type":"connect","callerName":"NNAme Stefan","calleeName":"NNAme Kerstin","extension":"4","type":"disconnect","duration":3}
    2019-12-12 19:58:48.468  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.type: "disconnect" / ack=true
    2019-12-12 19:58:48.470  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.duration: 3 / ack=true
    2019-12-12 19:58:48.472  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.timestamp: "12.12.19 19:58:48" / ack=true
    2019-12-12 19:58:48.474  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.json: "{\"caller\":\"0171xyz\",\"callee\":\"628xyz6\",\"_type\":\"lastCall\",\"callerName\":\"NNAme Stefan\",\"calleeName\":\"NNAme Kerstin\",\"extension\":\"4\",\"type\":\"disconnect\",\"duration\":3}" / ack=true
    2019-12-12 19:58:48.476  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "end" / ack=true
    2019-12-12 19:58:48.478  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState-4: "end" / ack=true
    2019-12-12 19:58:48.479  - debug: tr-064-community.0 (15488) callMonitor.set: type=lastCall caller=0171xyz callee=628xyz6 callerName=NNAme Stefan calleeName=NNAme Kerstin
    2019-12-12 19:58:48.851  - debug: tr-064-community.0 (15488) in updateAll
    2019-12-12 19:58:48.853  - debug: tr-064-community.0 (15488) updateDevices
    2019-12-12 19:58:48.854  - debug: tr-064-community.0 (15488) forEachConfiguredDevice
    2019-12-12 19:58:51.289  - debug: tr-064-community.0 (15488) setting 0 enable=false
    2019-12-12 19:58:51.290  - debug: tr-064-community.0 (15488) setting 1 enable=false
    2019-12-12 19:58:51.291  - debug: tr-064-community.0 (15488) setting 2 enable=false
    2019-12-12 19:58:51.291  - debug: tr-064-community.0 (15488) setting 3 enable=false
    2019-12-12 19:58:51.292  - debug: tr-064-community.0 (15488) setting 4 enable=false
    2019-12-12 19:58:51.292  - debug: tr-064-community.0 (15488) setting 5 enable=true
    2019-12-12 19:58:51.292  - debug: tr-064-community.0 (15488) setting 6 enable=true
    2019-12-12 19:58:51.293  - debug: tr-064-community.0 (15488) setting 7 enable=true
    2019-12-12 19:58:51.293  - debug: tr-064-community.0 (15488) setting 8 enable=true
    2019-12-12 19:58:51.295  - debug: tr-064-community.0 (15488) setting 9 enable=true
      conectasC Offline
      conectasC Offline
      conectas
      #478
      Fall2:
      abwechselt:
      OUT 0171 zu 628xy6
      danach
      OUT 0171 zu 628xy7
      tr-064-community.0.callmonitor.inbound.caller
      tr-064-community.0.callmonitor.inbound.callerName
      werden nicht aktualisiert...
      2019-12-12 20:07:10.493  - debug: tr-064-community.0 (15488) in updateAll
      2019-12-12 20:07:10.495  - debug: tr-064-community.0 (15488) updateDevices
      2019-12-12 20:07:10.496  - debug: tr-064-community.0 (15488) forEachConfiguredDevice
      2019-12-12 20:07:12.959  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 20:07:12;RING;2;0171xyz;628yxz6;SIP0;\r\n"
      2019-12-12 20:07:12.960  - debug: tr-064-community.0 (15488) callmonitor handle inbound message: {"caller":"0171xyz","callee":"628yxz6"}
      2019-12-12 20:07:12.961  - debug: tr-064-community.0 (15488) Set State callmonitor.inbound.callee: "628yxz6" / ack=true
      2019-12-12 20:07:12.962  - debug: tr-064-community.0 (15488) Set State callmonitor.inbound.timestamp: "12.12.19 20:07:12" / ack=true
      2019-12-12 20:07:12.963  - debug: tr-064-community.0 (15488) Search number 0049171xyz in phonebook: {"name":"NName Stefan","normalizedName":"NNamestefan","number":"0049171xyz","id":"634","phonebookId":"0"}
      2019-12-12 20:07:12.964  - debug: tr-064-community.0 (15488) Search number 004930628yxz6 in phonebook: {"name":"NName Kerstin","normalizedName":"NNamekerstin","number":"004930628yxz6","id":"631","phonebookId":"0"}
      2019-12-12 20:07:12.964  - debug: tr-064-community.0 (15488) Set State callmonitor.inbound.calleeName: "NName Kerstin" / ack=true
      2019-12-12 20:07:12.965  - debug: tr-064-community.0 (15488) Set State callmonitor.inbound.json: "{\"caller\":\"0171xyz\",\"callee\":\"628yxz6\",\"_type\":\"inbound\",\"callerName\":\"NName Stefan\",\"calleeName\":\"NName Kerstin\"}" / ack=true
      2019-12-12 20:07:12.966  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "ring" / ack=true
      2019-12-12 20:07:12.967  - debug: tr-064-community.0 (15488) callMonitor.set: type=inbound caller=0171xyz callee=628yxz6 callerName=NName Stefan calleeName=NName Kerstin
      2019-12-12 20:07:13.168  - debug: tr-064-community.0 (15488) Set State callmonitor.ringing: true / ack=true
      2019-12-12 20:07:13.225  - debug: tr-064-community.0 (15488) setting 0 enable=false
      2019-12-12 20:07:13.226  - debug: tr-064-community.0 (15488) setting 1 enable=false
      2019-12-12 20:07:13.227  - debug: tr-064-community.0 (15488) setting 2 enable=false
      2019-12-12 20:07:13.228  - debug: tr-064-community.0 (15488) setting 3 enable=false
      2019-12-12 20:07:13.229  - debug: tr-064-community.0 (15488) setting 4 enable=false
      2019-12-12 20:07:13.229  - debug: tr-064-community.0 (15488) setting 5 enable=true
      2019-12-12 20:07:13.230  - debug: tr-064-community.0 (15488) setting 6 enable=true
      2019-12-12 20:07:13.230  - debug: tr-064-community.0 (15488) setting 7 enable=true
      2019-12-12 20:07:13.231  - debug: tr-064-community.0 (15488) setting 8 enable=true
      2019-12-12 20:07:13.231  - debug: tr-064-community.0 (15488) setting 9 enable=true
      2019-12-12 20:07:19.126  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 20:07:19;CONNECT;2;4;0171xyz;\r\n"
      2019-12-12 20:07:19.127  - debug: tr-064-community.0 (15488) callmonitor handle connect message: {"caller":"0171xyz","callee":"628yxz6","_type":"inbound","callerName":"NName Stefan","calleeName":"NName Kerstin","extension":"4"}
      2019-12-12 20:07:19.128  - debug: tr-064-community.0 (15488) Set State callmonitor.connect.callee: "628yxz6" / ack=true
      2019-12-12 20:07:19.129  - debug: tr-064-community.0 (15488) Set State callmonitor.connect.calleeName: "NName Kerstin" / ack=true
      2019-12-12 20:07:19.130  - debug: tr-064-community.0 (15488) Set State callmonitor.connect.timestamp: "12.12.19 20:07:19" / ack=true
      2019-12-12 20:07:19.131  - debug: tr-064-community.0 (15488) Set State callmonitor.connect.json: "{\"caller\":\"0171xyz\",\"callee\":\"628yxz6\",\"_type\":\"connect\",\"callerName\":\"NName Stefan\",\"calleeName\":\"NName Kerstin\",\"extension\":\"4\"}" / ack=true
      2019-12-12 20:07:19.135  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "connect" / ack=true
      2019-12-12 20:07:19.136  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState-4: "connect" / ack=true
      2019-12-12 20:07:19.137  - debug: tr-064-community.0 (15488) callMonitor.set: type=connect caller=0171xyz callee=628yxz6 callerName=NName Stefan calleeName=NName Kerstin
      2019-12-12 20:07:19.339  - debug: tr-064-community.0 (15488) Set State callmonitor.ringing: false / ack=true
      2019-12-12 20:07:20.343  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 20:07:20;DISCONNECT;2;2;\r\n"
      2019-12-12 20:07:20.344  - debug: tr-064-community.0 (15488) callmonitor handle lastCall message: {"caller":"0171xyz","callee":"628yxz6","_type":"connect","callerName":"NName Stefan","calleeName":"NName Kerstin","extension":"4","type":"disconnect","duration":2}
      2019-12-12 20:07:20.345  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.callee: "628yxz6" / ack=true
      2019-12-12 20:07:20.346  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.calleeName: "NName Kerstin" / ack=true
      2019-12-12 20:07:20.347  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.duration: 2 / ack=true
      2019-12-12 20:07:20.348  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.timestamp: "12.12.19 20:07:20" / ack=true
      2019-12-12 20:07:20.350  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.json: "{\"caller\":\"0171xyz\",\"callee\":\"628yxz6\",\"_type\":\"lastCall\",\"callerName\":\"NName Stefan\",\"calleeName\":\"NName Kerstin\",\"extension\":\"4\",\"type\":\"disconnect\",\"duration\":2}" / ack=true
      2019-12-12 20:07:20.351  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "end" / ack=true
      2019-12-12 20:07:20.352  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState-4: "end" / ack=true
      2019-12-12 20:07:20.353  - debug: tr-064-community.0 (15488) callMonitor.set: type=lastCall caller=0171xyz callee=628yxz6 callerName=NName Stefan calleeName=NName Kerstin
      2019-12-12 20:07:23.232  - debug: tr-064-community.0 (15488) in updateAll
      2019-12-12 20:07:23.234  - debug: tr-064-community.0 (15488) updateDevices
      2019-12-12 20:07:23.235  - debug: tr-064-community.0 (15488) forEachConfiguredDevice
        conectasC Offline
        conectasC Offline
        conectas
        #479
        @apollon77 sagte in Test Adapter tr-064-community v1.0.x:
        Ich würde bei Tests dieses Script mitlaufen lassen.. oder bringt das in deinen Logs dann zu viel durcheinander?
        let tr064 = "tr-064-community.0.callmonitor.";
        var callerNumber    // Anrufernummer
        var callerName      // Name des Anrufers
        var calleeNumber    // angerufene Nummer
        var calleeName      // angerufener Name
        var callAllDataJson = { "caller": "caller Nr", "callee": "callee Nr", "_type": "_type inbound", "callerName": "Caller Name", "calleeName": "Callee Name" };
        on({ id: "tr-064-community.0.callmonitor.toPauseState", change: "any" }, function (obj) {
            console.log('---> Ringing?: ');
            let sToPauseState = getState(tr064 + "toPauseState").val;
            if ("ring" == sToPauseState) {
                callerNumber = getState(tr064 + "inbound.caller").val;          // Anrufernummer
                callerName = getState(tr064 + "inbound.callerName").val;        // Name des Anrufers
                calleeNumber = getState(tr064 + "inbound.callee").val;          // angerufene Nummer
                calleeName = getState(tr064 + "inbound.calleeName").val;        // angerufener Name
                callAllDataJson = getState(tr064 + "inbound.json").val;          // json
                console.log('---> Ringing? - callerNumber: ' + callerNumber);
                console.log('---> Ringing? - callerName: ' + callerName);
                console.log('---> Ringing? - calleeNumber: ' + calleeNumber);
                console.log('---> Ringing? - calleeName: ' + calleeName);
                console.log('---> Ringing? - callAllDataJson: ' + String(callAllDataJson));
            } else if ("end" == sToPauseState) {
                setState(tr064 + "inbound.caller", '');
                setState(tr064 + "inbound.callerName", '');
                setState(tr064 + "inbound.callee", '');
                setState(tr064 + "inbound.calleeName", '');
                setState(tr064 + "inbound.json", '');
        • apollon77A Offline
          #480
          Oooook ... ich hab mal erste DInge verändert. Bitte nochmal neu versuchen vom GitHub, bitte checkt aber auch ob der ganze Rest (also auch IP.Devices und so) noch so tut wie es soll.
          Und bitte extra Skripte weglassen. Danke
          conectasC 1 Antwort Letzte Antwort
            conectasC Offline
            conectasC Offline
            conectas
            #481
            Knallt...
            2019-12-12 21:24:14.636  - info: host.raspberrypi "system.adapter.tr-064-community.0" enabled
            2019-12-12 21:24:14.666  - info: host.raspberrypi instance system.adapter.tr-064-community.0 started with pid 18626
            2019-12-12 21:24:17.602  - debug: tr-064-community.0 (18626) Redis Objects: Use Redis connection: 127.0.0.1:9001
            2019-12-12 21:24:17.671  - debug: tr-064-community.0 (18626) Objects client ready ... initialize now
            2019-12-12 21:24:17.680  - debug: tr-064-community.0 (18626) Objects create PubSub Client
            2019-12-12 21:24:17.683  - debug: tr-064-community.0 (18626) Objects client initialize lua scripts
            2019-12-12 21:24:17.712  - debug: tr-064-community.0 (18626) objectDB connected
            2019-12-12 21:24:17.718  - debug: tr-064-community.0 (18626) Redis States: Use Redis connection: 127.0.0.1:9000
            2019-12-12 21:24:17.725  - debug: tr-064-community.0 (18626) Objects connected to redis: 127.0.0.1:9001
            2019-12-12 21:24:17.735  - debug: tr-064-community.0 (18626) States create PubSub Client
            2019-12-12 21:24:17.738  - debug: tr-064-community.0 (18626) statesDB connected
            2019-12-12 21:24:17.805  - debug: tr-064-community.0 (18626) States connected to redis: 127.0.0.1:9000
            2019-12-12 21:24:18.366  - info: tr-064-community.0 (18626) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.17.0
            2019-12-12 21:24:21.236  - error: tr-064-community.0 (18626) uncaught exception: st is not defined
            2019-12-12 21:24:21.241  - error: tr-064-community.0 (18626) ReferenceError: st is not defined
                at createObjects (/opt/iobroker/node_modules/iobroker.tr-064-community/main.js:102:59)
                at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:940:9
                at /opt/iobroker/node_modules/iobroker.tr-064-community/lib/soef.js:1610:28
                at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
                at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:306:18)
                at Parser.emit (events.js:198:13)
                at SAXParser.onclosetag (/opt/iobroker/node_modules/xml2js/lib/parser.js:264:26)
                at emit (/opt/iobroker/node_modules/sax/lib/sax.js:624:35)
                at emitNode (/opt/iobroker/node_modules/sax/lib/sax.js:629:5)
                at closeTag (/opt/iobroker/node_modules/sax/lib/sax.js:889:7)
            2019-12-12 21:24:21.300  - info: tr-064-community.0 (18626) terminating
            2019-12-12 21:24:21.303  - info: tr-064-community.0 (18626) Terminated (NO_ERROR): Without reason
            2019-12-12 21:24:21.861  - error: host.raspberrypi Caught by controller[0]: ReferenceError: st is not defined
            2019-12-12 21:24:21.864  - error: host.raspberrypi Caught by controller[0]:     at createObjects (/opt/iobroker/node_modules/iobroker.tr-064-community/main.js:102:59)
            2019-12-12 21:24:21.865  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:940:9
            2019-12-12 21:24:21.866  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.tr-064-community/lib/soef.js:1610:28
            2019-12-12 21:24:21.866  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
            2019-12-12 21:24:21.867  - error: host.raspberrypi Caught by controller[0]:     at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:306:18)
            2019-12-12 21:24:21.867  - error: host.raspberrypi Caught by controller[0]:     at Parser.emit (events.js:198:13)
            2019-12-12 21:24:21.868  - error: host.raspberrypi Caught by controller[0]:     at SAXParser.onclosetag (/opt/iobroker/node_modules/xml2js/lib/parser.js:264:26)
            2019-12-12 21:24:21.868  - error: host.raspberrypi Caught by controller[0]:     at emit (/opt/iobroker/node_modules/sax/lib/sax.js:624:35)
            2019-12-12 21:24:21.869  - error: host.raspberrypi Caught by controller[0]:     at emitNode (/opt/iobroker/node_modules/sax/lib/sax.js:629:5)
            2019-12-12 21:24:21.869  - error: host.raspberrypi Caught by controller[0]:     at closeTag (/opt/iobroker/node_modules/sax/lib/sax.js:889:7)
            2019-12-12 21:24:21.870  - info: host.raspberrypi instance system.adapter.tr-064-community.0 terminated with code 0 (NO_ERROR)
            2019-12-12 21:24:21.870  - info: host.raspberrypi Restart adapter system.adapter.tr-064-community.0 because enabled
              #482
              gggrrrr ... fixed on GitHub. Sorry
                conectasC Offline
                conectasC Offline
                conectas
                #483
                @apollon77
                außer toPauseState werden im callmonitor nix angelegt.. 2x getestet
                • conectasC conectas
                  @apollon77
                  #484
                  @conectas Hast Du wieder ein Log?
                    conectasC Offline
                    conectasC Offline
                    conectas
                    #485
                    @apollon77
                    vom Start .. da steht dann man ganzes Telefonbuch drin ;-)
                    (habe auch Telefon .. falls de nicht tippen magst)
                      @apollon77
                      #486
                      @conectas In dem Fall interessiert mich ja eher der "call" teil ... Ansonsten per email an iobroker@fischer-ka.de schicken
                        conectasC Offline
                        conectasC Offline
                        conectas
                        #487
                        @apollon77
                        2019-12-12 21:46:45.420  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:46:45;CALL;1;4;254xy;628xy7;SIP3;\r\n"
                        2019-12-12 21:46:45.422  - debug: tr-064-community.0 (23433) callmonitor handle outbound message: {"caller":"254xy","callee":"628xy7","extension":"4"}
                        2019-12-12 21:46:45.428  - debug: tr-064-community.0 (23433) Search number 004930254xy in phonebook: {"name":"NNAme Stefan","normalizedName":"NNAmestefan","number":"004930254xy","id":"634","phonebookId":"0"}
                        2019-12-12 21:46:45.430  - debug: tr-064-community.0 (23433) Search number 004930628xy7 in phonebook: {"name":"NNAme Stefan","normalizedName":"NNAmestefan","number":"004930628xy7","id":"634","phonebookId":"0"}
                        2019-12-12 21:46:45.431  - debug: tr-064-community.0 (23433) callMonitor.set: type=outbound caller=254xy callee=628xy7 callerName=NNAme Stefan calleeName=NNAme Stefan
                        2019-12-12 21:46:45.790  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:46:45;RING;2;030254xy;628xy7;SIP1;\r\n"
                        2019-12-12 21:46:45.792  - debug: tr-064-community.0 (23433) callmonitor handle inbound message: {"caller":"030254xy","callee":"628xy7"}
                        2019-12-12 21:46:45.794  - debug: tr-064-community.0 (23433) Search number 004930254xy in phonebook: {"name":"NNAme Stefan","normalizedName":"NNAmestefan","number":"004930254xy","id":"634","phonebookId":"0"}
                        2019-12-12 21:46:45.796  - debug: tr-064-community.0 (23433) Search number 004930628xy7 in phonebook: {"name":"NNAme Stefan","normalizedName":"NNAmestefan","number":"004930628xy7","id":"634","phonebookId":"0"}
                        2019-12-12 21:46:45.799  - debug: tr-064-community.0 (23433) callMonitor.set: type=inbound caller=030254xy callee=628xy7 callerName=NNAme Stefan calleeName=NNAme Stefan
                        2019-12-12 21:46:47.697  - debug: tr-064-community.0 (23433) in updateAll
                        2019-12-12 21:46:47.699  - debug: tr-064-community.0 (23433) updateDevices
                        2019-12-12 21:46:47.701  - debug: tr-064-community.0 (23433) forEachConfiguredDevice
                        2019-12-12 21:46:47.779  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:46:47;CONNECT;2;11;030254xy;\r\n"
                        2019-12-12 21:46:47.781  - debug: tr-064-community.0 (23433) callmonitor handle connect message: {"caller":"030254xy","callee":"628xy7","_type":"inbound","callerName":"NNAme Stefan","calleeName":"NNAme Stefan","extension":"11"}
                        2019-12-12 21:46:47.790  - debug: tr-064-community.0 (23433) callMonitor.set: type=connect caller=030254xy callee=628xy7 callerName=NNAme Stefan calleeName=NNAme Stefan
                        2019-12-12 21:46:47.906  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:46:47;CONNECT;1;4;628xy7;\r\n"
                        2019-12-12 21:46:47.907  - debug: tr-064-community.0 (23433) callmonitor handle connect message: {"caller":"254xy","callee":"628xy7","extension":"4","_type":"outbound","callerName":"NNAme Stefan","calleeName":"NNAme Stefan"}
                        2019-12-12 21:46:47.911  - debug: tr-064-community.0 (23433) callMonitor.set: type=connect caller=254xy callee=628xy7 callerName=NNAme Stefan calleeName=NNAme Stefan
                        2019-12-12 21:46:50.443  - debug: tr-064-community.0 (23433) setting 0 enable=false
                        2019-12-12 21:46:50.444  - debug: tr-064-community.0 (23433) setting 1 enable=false
                        2019-12-12 21:46:50.444  - debug: tr-064-community.0 (23433) setting 2 enable=false
                        2019-12-12 21:46:50.445  - debug: tr-064-community.0 (23433) setting 3 enable=false
                        2019-12-12 21:46:50.445  - debug: tr-064-community.0 (23433) setting 4 enable=false
                        2019-12-12 21:46:50.446  - debug: tr-064-community.0 (23433) setting 5 enable=true
                        2019-12-12 21:46:50.446  - debug: tr-064-community.0 (23433) setting 6 enable=true
                        2019-12-12 21:46:50.446  - debug: tr-064-community.0 (23433) setting 7 enable=true
                        2019-12-12 21:46:50.447  - debug: tr-064-community.0 (23433) setting 8 enable=true
                        2019-12-12 21:46:50.448  - debug: tr-064-community.0 (23433) setting 9 enable=true
                        2019-12-12 21:46:52.331  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:46:52;DISCONNECT;1;5;\r\n"
                        2019-12-12 21:46:52.341  - debug: tr-064-community.0 (23433) callmonitor handle lastCall message: {"caller":"254xy","callee":"628xy7","extension":"4","_type":"connect","callerName":"NNAme Stefan","calleeName":"NNAme Stefan","type":"disconnect","duration":5}
                        2019-12-12 21:46:52.347  - debug: tr-064-community.0 (23433) callMonitor.set: type=lastCall caller=254xy callee=628xy7 callerName=NNAme Stefan calleeName=NNAme Stefan
                        2019-12-12 21:46:52.374  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:46:52;DISCONNECT;2;5;\r\n"
                        2019-12-12 21:46:52.375  - debug: tr-064-community.0 (23433) callmonitor handle lastCall message: {"caller":"030254xy","callee":"628xy7","_type":"connect","callerName":"NNAme Stefan","calleeName":"NNAme Stefan","extension":"11","type":"disconnect","duration":5}
                        2019-12-12 21:46:52.380  - debug: tr-064-community.0 (23433) callMonitor.set: type=lastCall caller=030254xy callee=628xy7 callerName=NNAme Stefan calleeName=NNAme Stefan
                          @apollon77
                          conectasC Offline
                          conectasC Offline
                          conectas
                          #488
                          @conectas
                          glaube das ist besser.. wegen den Namen? Ansonsten gleich
                          2019-12-12 21:49:26.143  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:49:26;CALL;1;4;254xy;628xy6;SIP3;\r\n"
                          2019-12-12 21:49:26.144  - debug: tr-064-community.0 (23433) callmonitor handle outbound message: {"caller":"254xy","callee":"628xy6","extension":"4"}
                          2019-12-12 21:49:26.145  - debug: tr-064-community.0 (23433) Search number 004930254xy in phonebook: {"name":"NName Stefan","normalizedName":"NNamestefan","number":"004930254xy","id":"634","phonebookId":"0"}
                          2019-12-12 21:49:26.150  - debug: tr-064-community.0 (23433) Search number 004930628xy6 in phonebook: {"name":"NName Kerstin","normalizedName":"NNamekerstin","number":"004930628xy6","id":"631","phonebookId":"0"}
                          2019-12-12 21:49:26.151  - debug: tr-064-community.0 (23433) callMonitor.set: type=outbound caller=254xy callee=628xy6 callerName=NName Stefan calleeName=NName Kerstin
                          2019-12-12 21:49:26.526  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:49:26;RING;2;030254xy;628xy6;SIP0;\r\n"
                          2019-12-12 21:49:26.527  - debug: tr-064-community.0 (23433) callmonitor handle inbound message: {"caller":"030254xy","callee":"628xy6"}
                          2019-12-12 21:49:26.529  - debug: tr-064-community.0 (23433) Search number 004930254xy in phonebook: {"name":"NName Stefan","normalizedName":"NNamestefan","number":"004930254xy","id":"634","phonebookId":"0"}
                          2019-12-12 21:49:26.531  - debug: tr-064-community.0 (23433) Search number 004930628xy6 in phonebook: {"name":"NName Kerstin","normalizedName":"NNamekerstin","number":"004930628xy6","id":"631","phonebookId":"0"}
                          2019-12-12 21:49:26.532  - debug: tr-064-community.0 (23433) callMonitor.set: type=inbound caller=030254xy callee=628xy6 callerName=NName Stefan calleeName=NName Kerstin
                          2019-12-12 21:49:30.495  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:49:30;CONNECT;2;11;030254xy;\r\n"
                          2019-12-12 21:49:30.497  - debug: tr-064-community.0 (23433) callmonitor handle connect message: {"caller":"030254xy","callee":"628xy6","_type":"inbound","callerName":"NName Stefan","calleeName":"NName Kerstin","extension":"11"}
                          2019-12-12 21:49:30.517  - debug: tr-064-community.0 (23433) callMonitor.set: type=connect caller=030254xy callee=628xy6 callerName=NName Stefan calleeName=NName Kerstin
                          2019-12-12 21:49:30.537  - debug: tr-064-community.0 (23433) in updateAll
                          2019-12-12 21:49:30.542  - debug: tr-064-community.0 (23433) updateDevices
                          2019-12-12 21:49:30.543  - debug: tr-064-community.0 (23433) forEachConfiguredDevice
                          2019-12-12 21:49:30.633  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:49:30;CONNECT;1;4;628xy6;\r\n"
                          2019-12-12 21:49:30.635  - debug: tr-064-community.0 (23433) callmonitor handle connect message: {"caller":"254xy","callee":"628xy6","extension":"4","_type":"outbound","callerName":"NName Stefan","calleeName":"NName Kerstin"}
                          2019-12-12 21:49:30.640  - debug: tr-064-community.0 (23433) callMonitor.set: type=connect caller=254xy callee=628xy6 callerName=NName Stefan calleeName=NName Kerstin
                          2019-12-12 21:49:33.283  - debug: tr-064-community.0 (23433) setting 0 enable=false
                          2019-12-12 21:49:33.284  - debug: tr-064-community.0 (23433) setting 1 enable=false
                          2019-12-12 21:49:33.285  - debug: tr-064-community.0 (23433) setting 2 enable=false
                          2019-12-12 21:49:33.290  - debug: tr-064-community.0 (23433) setting 3 enable=false
                          2019-12-12 21:49:33.291  - debug: tr-064-community.0 (23433) setting 4 enable=false
                          2019-12-12 21:49:33.291  - debug: tr-064-community.0 (23433) setting 5 enable=true
                          2019-12-12 21:49:33.292  - debug: tr-064-community.0 (23433) setting 6 enable=true
                          2019-12-12 21:49:33.293  - debug: tr-064-community.0 (23433) setting 7 enable=true
                          2019-12-12 21:49:33.293  - debug: tr-064-community.0 (23433) setting 8 enable=true
                          2019-12-12 21:49:33.294  - debug: tr-064-community.0 (23433) setting 9 enable=true
                          2019-12-12 21:49:33.520  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:49:33;DISCONNECT;1;3;\r\n"
                          2019-12-12 21:49:33.522  - debug: tr-064-community.0 (23433) callmonitor handle lastCall message: {"caller":"254xy","callee":"628xy6","extension":"4","_type":"connect","callerName":"NName Stefan","calleeName":"NName Kerstin","type":"disconnect","duration":3}
                          2019-12-12 21:49:33.528  - debug: tr-064-community.0 (23433) callMonitor.set: type=lastCall caller=254xy callee=628xy6 callerName=NName Stefan calleeName=NName Kerstin
                          2019-12-12 21:49:33.564  - debug: tr-064-community.0 (23433) callmonitor raw data: "12.12.19 21:49:33;DISCONNECT;2;4;\r\n"
                          2019-12-12 21:49:33.573  - debug: tr-064-community.0 (23433) callmonitor handle lastCall message: {"caller":"030254xy","callee":"628xy6","_type":"connect","callerName":"NName Stefan","calleeName":"NName Kerstin","extension":"11","type":"disconnect","duration":4}
                          2019-12-12 21:49:33.580  - debug: tr-064-community.0 (23433) callMonitor.set: type=lastCall caller=030254xy callee=628xy6 callerName=NName Stefan calleeName=NName Kerstin
                          2019-12-12 21:49:43.296  - debug: tr-064-community.0 (23433) in updateAll
                          2019-12-12 21:49:43.299  - debug: tr-064-community.0 (23433) updateDevices
                          2019-12-12 21:49:43.300  - debug: tr-064-community.0 (23433) forEachConfiguredDevice
                          2019-12-12 21:49:45.844  - debug: tr-064-community.0 (23433) setting 0 enable=false
                          2019-12-12 21:49:45.845  - debug: tr-064-community.0 (23433) setting 1 enable=false
                          2019-12-12 21:49:45.846  - debug: tr-064-community.0 (23433) setting 2 enable=false
                          2019-12-12 21:49:45.847  - debug: tr-064-community.0 (23433) setting 3 enable=false
                          2019-12-12 21:49:45.847  - debug: tr-064-community.0 (23433) setting 4 enable=false
                          2019-12-12 21:49:45.847  - debug: tr-064-community.0 (23433) setting 5 enable=true
                          2019-12-12 21:49:45.848  - debug: tr-064-community.0 (23433) setting 6 enable=true
                          2019-12-12 21:49:45.848  - debug: tr-064-community.0 (23433) setting 7 enable=true
                          2019-12-12 21:49:45.854  - debug: tr-064-community.0 (23433) setting 8 enable=true
                          2019-12-12 21:49:45.854  - debug: tr-064-community.0 (23433) setting 9 enable=true
                            #489
                            Und dann nochmal bitte von GitHub. Logging nochmal erweitert und so
                              conectasC Offline
                              conectasC Offline
                              conectas
                              #490
                              @apollon77
                              Bitte am Ende des Tages bitte nicht vergessen eine func Version rein zu legen (habe gerade festgestellt das im iobroker backup .. nix von tr-064 drin ist)
                              1. Ich muss wahrscheinlich gleich Mittag essen... sonst wird die besagte Kerstin .. na ja ;-)
                              2019-12-12 22:08:04.642  - debug: tr-064-community.0 (31690) callmonitor raw data: "12.12.19 22:08:04;CALL;1;4;254xy;628xy6;SIP3;\r\n"
                              2019-12-12 22:08:04.643  - debug: tr-064-community.0 (31690) callmonitor handle outbound message: {"caller":"254xy","callee":"628xy6","extension":"4"}
                              2019-12-12 22:08:04.647  - debug: tr-064-community.0 (31690) Search number 004930254xy in phonebook: {"name":"NNAme Stefan","normalizedName":"NNAmestefan","number":"004930254xy","id":"634","phonebookId":"0"}
                              2019-12-12 22:08:04.652  - debug: tr-064-community.0 (31690) Search number 004930628xy6 in phonebook: {"name":"NNAme Kerstin","normalizedName":"NNAmekerstin","number":"004930628xy6","id":"631","phonebookId":"0"}
                              2019-12-12 22:08:04.656  - debug: tr-064-community.0 (31690) callMonitor.set: type=outbound caller=254xy callee=628xy6 callerName=NNAme Stefan calleeName=NNAme Kerstin
                              2019-12-12 22:08:04.686  - debug: tr-064-community.0 (31690) State-Change {"val":false,"ack":true,"ts":1576184884671,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184855434}
                              2019-12-12 22:08:04.693  - debug: tr-064-community.0 (31690) State-Change {"val":"254xy","ack":true,"ts":1576184884672,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182914392}
                              2019-12-12 22:08:04.699  - debug: tr-064-community.0 (31690) State-Change {"val":"628xy6","ack":true,"ts":1576184884676,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184851355}
                              2019-12-12 22:08:04.704  - debug: tr-064-community.0 (31690) State-Change {"val":"4","ack":true,"ts":1576184884677,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182914401}
                              2019-12-12 22:08:04.708  - debug: tr-064-community.0 (31690) State-Change {"val":"12.12.19 22:08:04","ack":true,"ts":1576184884678,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184884678}
                              2019-12-12 22:08:04.711  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184884680,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182914403}
                              2019-12-12 22:08:04.717  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184884681,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184851367}
                              2019-12-12 22:08:04.721  - debug: tr-064-community.0 (31690) State-Change {"val":"{\"caller\":\"254xy\",\"callee\":\"628xy6\",\"extension\":\"4\",\"_type\":\"outbound\",\"callerName\":\"NNAme Stefan\",\"calleeName\":\"NNAme Kerstin\"}","ack":true,"ts":1576184884682,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184851368}
                              2019-12-12 22:08:04.999  - debug: tr-064-community.0 (31690) callmonitor raw data: "12.12.19 22:08:04;RING;2;030254xy;628xy6;SIP0;\r\n"
                              2019-12-12 22:08:05.000  - debug: tr-064-community.0 (31690) callmonitor handle inbound message: {"caller":"030254xy","callee":"628xy6"}
                              2019-12-12 22:08:05.003  - debug: tr-064-community.0 (31690) Search number 004930254xy in phonebook: {"name":"NNAme Stefan","normalizedName":"NNAmestefan","number":"004930254xy","id":"634","phonebookId":"0"}
                              2019-12-12 22:08:05.004  - debug: tr-064-community.0 (31690) Search number 004930628xy6 in phonebook: {"name":"NNAme Kerstin","normalizedName":"NNAmekerstin","number":"004930628xy6","id":"631","phonebookId":"0"}
                              2019-12-12 22:08:05.006  - debug: tr-064-community.0 (31690) callMonitor.set: type=inbound caller=030254xy callee=628xy6 callerName=NNAme Stefan calleeName=NNAme Kerstin
                              2019-12-12 22:08:05.022  - debug: tr-064-community.0 (31690) State-Change {"val":true,"ack":true,"ts":1576184885010,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184885010}
                              2019-12-12 22:08:05.026  - debug: tr-064-community.0 (31690) State-Change {"val":"030254xy","ack":true,"ts":1576184885011,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576183605807}
                              2019-12-12 22:08:05.031  - debug: tr-064-community.0 (31690) State-Change {"val":"628xy6","ack":true,"ts":1576184885011,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184851814}
                              2019-12-12 22:08:05.034  - debug: tr-064-community.0 (31690) State-Change {"val":"12.12.19 22:08:04","ack":true,"ts":1576184885011,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184885011}
                              2019-12-12 22:08:05.039  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184885012,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182914757}
                              2019-12-12 22:08:05.044  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184885013,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184851817}
                              2019-12-12 22:08:05.048  - debug: tr-064-community.0 (31690) State-Change {"val":"{\"caller\":\"030254xy\",\"callee\":\"628xy6\",\"_type\":\"inbound\",\"callerName\":\"NNAme Stefan\",\"calleeName\":\"NNAme Kerstin\"}","ack":true,"ts":1576184885014,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184851819}
                              2019-12-12 22:08:05.053  - debug: tr-064-community.0 (31690) State-Change {"val":"ring","ack":true,"ts":1576184885014,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184885014}
                              2019-12-12 22:08:08.937  - debug: tr-064-community.0 (31690) in updateAll
                              2019-12-12 22:08:08.939  - debug: tr-064-community.0 (31690) updateDevices
                              2019-12-12 22:08:08.940  - debug: tr-064-community.0 (31690) forEachConfiguredDevice
                              2019-12-12 22:08:09.991  - debug: tr-064-community.0 (31690) callmonitor raw data: "12.12.19 22:08:09;CONNECT;2;11;030254xy;\r\n"
                              2019-12-12 22:08:09.993  - debug: tr-064-community.0 (31690) callmonitor handle connect message: {"caller":"030254xy","callee":"628xy6","_type":"inbound","callerName":"NNAme Stefan","calleeName":"NNAme Kerstin","extension":"11"}
                              2019-12-12 22:08:09.997  - debug: tr-064-community.0 (31690) callMonitor.set: type=connect caller=030254xy callee=628xy6 callerName=NNAme Stefan calleeName=NNAme Kerstin
                              2019-12-12 22:08:10.022  - debug: tr-064-community.0 (31690) State-Change {"val":false,"ack":true,"ts":1576184890002,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890002}
                              2019-12-12 22:08:10.027  - debug: tr-064-community.0 (31690) State-Change {"val":"030254xy","ack":true,"ts":1576184890003,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890003}
                              2019-12-12 22:08:10.032  - debug: tr-064-community.0 (31690) State-Change {"val":"628xy6","ack":true,"ts":1576184890003,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576183770528}
                              2019-12-12 22:08:10.037  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184890004,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182926674}
                              2019-12-12 22:08:10.042  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184890005,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576183770530}
                              2019-12-12 22:08:10.047  - debug: tr-064-community.0 (31690) State-Change {"val":"11","ack":true,"ts":1576184890006,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890006}
                              2019-12-12 22:08:10.055  - debug: tr-064-community.0 (31690) State-Change {"val":"12.12.19 22:08:09","ack":true,"ts":1576184890006,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890006}
                              2019-12-12 22:08:10.060  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184890007,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182926676}
                              2019-12-12 22:08:10.063  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184890016,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576183770535}
                              2019-12-12 22:08:10.083  - debug: tr-064-community.0 (31690) State-Change {"val":"{\"caller\":\"030254xy\",\"callee\":\"628xy6\",\"_type\":\"connect\",\"callerName\":\"NNAme Stefan\",\"calleeName\":\"NNAme Kerstin\",\"extension\":\"11\"}","ack":true,"ts":1576184890017,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890017}
                              2019-12-12 22:08:10.087  - debug: tr-064-community.0 (31690) State-Change {"val":"connect","ack":true,"ts":1576184890019,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890019}
                              2019-12-12 22:08:10.089  - debug: tr-064-community.0 (31690) State-Change {"val":"connect","ack":true,"ts":1576184890019,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890019}
                              2019-12-12 22:08:10.105  - debug: tr-064-community.0 (31690) callmonitor raw data: "12.12.19 22:08:10;CONNECT;1;4;628xy6;\r\n"
                              2019-12-12 22:08:10.106  - debug: tr-064-community.0 (31690) callmonitor handle connect message: {"caller":"254xy","callee":"628xy6","extension":"4","_type":"outbound","callerName":"NNAme Stefan","calleeName":"NNAme Kerstin"}
                              2019-12-12 22:08:10.113  - debug: tr-064-community.0 (31690) callMonitor.set: type=connect caller=254xy callee=628xy6 callerName=NNAme Stefan calleeName=NNAme Kerstin
                              2019-12-12 22:08:10.126  - debug: tr-064-community.0 (31690) State-Change {"val":false,"ack":true,"ts":1576184890118,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890002}
                              2019-12-12 22:08:10.130  - debug: tr-064-community.0 (31690) State-Change {"val":"254xy","ack":true,"ts":1576184890119,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890119}
                              2019-12-12 22:08:10.135  - debug: tr-064-community.0 (31690) State-Change {"val":"628xy6","ack":true,"ts":1576184890120,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576183770528}
                              2019-12-12 22:08:10.138  - debug: tr-064-community.0 (31690) State-Change {"val":"4","ack":true,"ts":1576184890120,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890120}
                              2019-12-12 22:08:10.141  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184890121,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182926674}
                              2019-12-12 22:08:10.145  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184890121,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576183770530}
                              2019-12-12 22:08:10.150  - debug: tr-064-community.0 (31690) State-Change {"val":"12.12.19 22:08:10","ack":true,"ts":1576184890121,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890121}
                              2019-12-12 22:08:10.154  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184890122,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182926676}
                              2019-12-12 22:08:10.158  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184890122,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576183770535}
                              2019-12-12 22:08:10.162  - debug: tr-064-community.0 (31690) State-Change {"val":"{\"caller\":\"254xy\",\"callee\":\"628xy6\",\"extension\":\"4\",\"_type\":\"connect\",\"callerName\":\"NNAme Stefan\",\"calleeName\":\"NNAme Kerstin\"}","ack":true,"ts":1576184890123,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890123}
                              2019-12-12 22:08:10.166  - debug: tr-064-community.0 (31690) State-Change {"val":"connect","ack":true,"ts":1576184890123,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890019}
                              2019-12-12 22:08:10.169  - debug: tr-064-community.0 (31690) State-Change {"val":"connect","ack":true,"ts":1576184890124,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890124}
                              2019-12-12 22:08:12.263  - debug: tr-064-community.0 (31690) callmonitor raw data: "12.12.19 22:08:12;DISCONNECT;1;3;\r\n"
                              2019-12-12 22:08:12.264  - debug: tr-064-community.0 (31690) callmonitor handle lastCall message: {"caller":"254xy","callee":"628xy6","extension":"4","_type":"connect","callerName":"NNAme Stefan","calleeName":"NNAme Kerstin","type":"disconnect","duration":3}
                              2019-12-12 22:08:12.270  - debug: tr-064-community.0 (31690) callMonitor.set: type=lastCall caller=254xy callee=628xy6 callerName=NNAme Stefan calleeName=NNAme Kerstin
                              2019-12-12 22:08:12.286  - debug: tr-064-community.0 (31690) State-Change {"val":false,"ack":true,"ts":1576184892275,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890002}
                              2019-12-12 22:08:12.291  - debug: tr-064-community.0 (31690) State-Change {"val":"254xy","ack":true,"ts":1576184892275,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892275}
                              2019-12-12 22:08:12.296  - debug: tr-064-community.0 (31690) State-Change {"val":"628xy6","ack":true,"ts":1576184892276,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184859270}
                              2019-12-12 22:08:12.301  - debug: tr-064-community.0 (31690) State-Change {"val":"4","ack":true,"ts":1576184892277,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892277}
                              2019-12-12 22:08:12.306  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184892277,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182933087}
                              2019-12-12 22:08:12.310  - debug: tr-064-community.0 (31690) callmonitor raw data: "12.12.19 22:08:12;DISCONNECT;2;3;\r\n"
                              2019-12-12 22:08:12.311  - debug: tr-064-community.0 (31690) callmonitor handle lastCall message: {"caller":"030254xy","callee":"628xy6","_type":"connect","callerName":"NNAme Stefan","calleeName":"NNAme Kerstin","extension":"11","type":"disconnect","duration":3}
                              2019-12-12 22:08:12.325  - debug: tr-064-community.0 (31690) callMonitor.set: type=lastCall caller=030254xy callee=628xy6 callerName=NNAme Stefan calleeName=NNAme Kerstin
                              2019-12-12 22:08:12.338  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184892278,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184859272}
                              2019-12-12 22:08:12.340  - debug: tr-064-community.0 (31690) State-Change {"val":"disconnect","ack":true,"ts":1576184892279,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184859273}
                              2019-12-12 22:08:12.343  - debug: tr-064-community.0 (31690) State-Change {"val":3,"ack":true,"ts":1576184892279,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892279}
                              2019-12-12 22:08:12.345  - debug: tr-064-community.0 (31690) State-Change {"val":"12.12.19 22:08:12","ack":true,"ts":1576184892280,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892280}
                              2019-12-12 22:08:12.348  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184892281,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182933103}
                              2019-12-12 22:08:12.350  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184892281,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184859275}
                              2019-12-12 22:08:12.359  - debug: tr-064-community.0 (31690) State-Change {"val":"{\"caller\":\"254xy\",\"callee\":\"628xy6\",\"extension\":\"4\",\"_type\":\"lastCall\",\"callerName\":\"NNAme Stefan\",\"calleeName\":\"NNAme Kerstin\",\"type\":\"disconnect\",\"duration\":3}","ack":true,"ts":1576184892282,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892282}
                              2019-12-12 22:08:12.362  - debug: tr-064-community.0 (31690) State-Change {"val":"end","ack":true,"ts":1576184892282,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892282}
                              2019-12-12 22:08:12.364  - debug: tr-064-community.0 (31690) State-Change {"val":"end","ack":true,"ts":1576184892283,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892283}
                              2019-12-12 22:08:12.384  - debug: tr-064-community.0 (31690) State-Change {"val":false,"ack":true,"ts":1576184892370,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184890002}
                              2019-12-12 22:08:12.386  - debug: tr-064-community.0 (31690) State-Change {"val":"030254xy","ack":true,"ts":1576184892375,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892375}
                              2019-12-12 22:08:12.389  - debug: tr-064-community.0 (31690) State-Change {"val":"628xy6","ack":true,"ts":1576184892376,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184859270}
                              2019-12-12 22:08:12.393  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184892376,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182933087}
                              2019-12-12 22:08:12.396  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184892377,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184859272}
                              2019-12-12 22:08:12.398  - debug: tr-064-community.0 (31690) State-Change {"val":"11","ack":true,"ts":1576184892377,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892377}
                              2019-12-12 22:08:12.404  - debug: tr-064-community.0 (31690) State-Change {"val":"disconnect","ack":true,"ts":1576184892378,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184859273}
                              2019-12-12 22:08:12.409  - debug: tr-064-community.0 (31690) State-Change {"val":3,"ack":true,"ts":1576184892378,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892279}
                              2019-12-12 22:08:12.411  - debug: tr-064-community.0 (31690) State-Change {"val":"12.12.19 22:08:12","ack":true,"ts":1576184892378,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892280}
                              2019-12-12 22:08:12.416  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Stefan","ack":true,"ts":1576184892379,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576182933103}
                              2019-12-12 22:08:12.422  - debug: tr-064-community.0 (31690) State-Change {"val":"NNAme Kerstin","ack":true,"ts":1576184892379,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184859275}
                              2019-12-12 22:08:12.425  - debug: tr-064-community.0 (31690) State-Change {"val":"{\"caller\":\"030254xy\",\"callee\":\"628xy6\",\"_type\":\"lastCall\",\"callerName\":\"NNAme Stefan\",\"calleeName\":\"NNAme Kerstin\",\"extension\":\"11\",\"type\":\"disconnect\",\"duration\":3}","ack":true,"ts":1576184892380,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892380}
                              2019-12-12 22:08:12.430  - debug: tr-064-community.0 (31690) State-Change {"val":"end","ack":true,"ts":1576184892380,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892282}
                              2019-12-12 22:08:12.432  - debug: tr-064-community.0 (31690) State-Change {"val":"end","ack":true,"ts":1576184892381,"q":0,"from":"system.adapter.tr-064-community.0","user":"system.user.admin","lc":1576184892381}
                              2019-12-12 22:08:20.527  - debug: tr-064-community.0 (31690) in updateAll
                              2019-12-12 22:08:20.530  - debug: tr-064-community.0 (31690) updateDevices
                              2019-12-12 22:08:20.530  - debug: tr-064-community.0 (31690) forEachConfiguredDevice
                              apollon77A 2 Antworten Letzte Antwort
                              • marcusklM Offline
                                marcusklM Offline
                                marcuskl
                                #491
                                Findet man diesen Adaper schon in IoBroker/Adapter ?
                                Host: Intel Nuc6cayh (16GB Ram, 240GB SSD) mit Proxmox.
                                Iobroker VM, InfluxDB LXC, Pihole LXC, Tasmoadmin LXC, Easy2connect VM
                                  @apollon77
                                  #492
                                  @conectas jetzt sollte aber alles geschrieben werden oder ?! Zumindestens sagt das log das
                                    @apollon77
                                    #493
                                    @conectas sagte in Test Adapter tr-064-community v1.0.x:
                                    Das wird so eine Sache ... Den Stand von früher heute wiederherzustellen wir nahezu unmöglich ... und wir müssen jetzt mal endlich vorankommen
                                      conectasC Offline
                                      conectasC Offline
                                      conectas
                                      #494
                                      @apollon77
                                      tr-064-community.0.callmonitor // Hat sich nicht geändert.
                                      tr-064-community.0.callForwarding sieht okay aus..
                                      tr-064-community.0.states ist bis auf den Eintrag: tr-064-community.0.states.calllists auch leer
                                      • marcusklM marcuskl
                                        conectasC Offline
                                        conectasC Offline
                                        conectas
                                        #495
                                        @marcuskl sagte in Test Adapter tr-064-community v1.0.x:
                                        Nein.
                                        marcusklM 1 Antwort Letzte Antwort
                                          der tr-064 Adapter von soef ist mit fast 10.000 Installationen ein sehr oft genutzter Adapter. Leider ist der Entwickler nicht mehr aktiv und so wird auch der Adapter nicht mehr weiterentwickelt. Um dies ggf zu ändern hat sich die Entwicklergruppe der ioBroker-Community-Adapter entschieden die soef Adapter zu übernehmen und versuchen weiterzuentwickeln.
                                          Der erste so etwas aufgefrischte Adapter ist genau der tr-064 Adapter. Am Funktionsumfang hat sich hier noch nichts geändert, aber der Adapter wurde intern aktualisiert.
                                          Jetzt würden wir diese neue Version gern veröffentlichen um Sie als neue Basis zu nutzen.
                                          Die neue Version steht zur manuellen Installation unter GitHub-Link https://github.com/iobroker-community-adapters/ioBroker.tr-064-community zur Verfügung. Installiert einfach per GitHub-Icon.
                                          Die Einstellungen einer bestehenden tr-06 Instanz sollten sich durch Übername des "native"-Teils der Instanzeinstellungen unter system.adapter.tr-064.X (X=Instanznummer) in das neue Instanzobjekt übernehmen lassen.
                                          Hier brauchen wir von Euch Testunterstützung und freuen uns auf Euer Feedback!
                                          Danke für Eure Unterstützung.
                                          Ingo und die anderen Community-Entwickler
                                          sigi234S Online
                                          sigi234S Online
                                          #496
                                          @apollon77
                                          Für Apollon77
