  4. Test Adapter ioBroker.backitup v3.1.x
    1.6k
    1.5k
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 2.8m Aufrufe 113 Beobachtet
  • JB_SullivanJ
    JB_SullivanJ
    JB_Sullivan
    schrieb am zuletzt editiert von JB_Sullivan
    Habe auch gerade versucht auf 1.3.1 upzudaten, mit dem Ergennis dieser Fehler hier.
    $ ./iobroker upgrade backitup
    Update backitup from @1.3.0 to @1.3.1
    host.iobroker(ioBroker) Adapter "system.adapter.backitup.0" is stopped.
    NPM version: 6.9.0
    npm install iobroker.backitup@1.3.1 --loglevel error --prefix "C:/IoB Testsysteme/ioBroker" (System call)
    npm
     ERR! path C:\IoB Testsysteme\ioBroker\node_modules\iobroker.backitupnpm ERR! code EPERMnpm
    ERR!
    errno
     -4048
    npm
    ERR!
    syscall
     rename
    npm
     ERR!
     Error: EPERM: operation not permitted, rename 'C:\IoB Testsysteme\ioBroker\node_modules\iobroker.backitup' -> 'C:\IoB Testsysteme\ioBroker\node_modules\.iobroker.backitup.DELETE'
    npm
    ERR!
      { [Error: EPERM: operation not permitted, rename 'C:\IoB Testsysteme\ioBroker\node_modules\iobroker.backitup' -> 'C:\IoB Testsysteme\ioBroker\node_modules\.iobroker.backitup.DELETE']npm
    ERR!
       cause:
    npm
     ERR!
        { Error: EPERM: operation not permitted, rename 'C:\IoB Testsysteme\ioBroker\node_modules\iobroker.backitup' -> 'C:\IoB Testsysteme\ioBroker\node_modules\.iobroker.backitup.DELETE'
    npm
    ERR!
          errno: -4048,
    npm
    ERR!      code: 'EPERM',
    npm
    ERR!
          syscall: 'rename',
    npm
    ERR!
          path:npm
     ERR!
           'C:\\IoB Testsysteme\\ioBroker\\node_modules\\iobroker.backitup',
    npm
    ERR!
          dest:npm
    ERR!
           'C:\\IoB Testsysteme\\ioBroker\\node_modules\\.iobroker.backitup.DELETE' },
    npm
    ERR!   stack:
    npm
     ERR!
        'Error: EPERM: operation not permitted, rename \'C:\\IoB Testsysteme\\ioBroker\\node_modules\\iobroker.backitup\' -> \'C:\\IoB Testsysteme\\ioBroker\\node_modules\\.iobroker.backitup.DELETE\'',
    npm
    ERR!
       errno: -4048,npm
    ERR!
       code: 'EPERM',
    npm
    ERR!
       syscall: 'rename',npm
    ERR!   path:
    npm
     ERR!
    npm
    ERR!
       dest:
    npm
    ERR!
        'C:\\IoB Testsysteme\\ioBroker\\node_modules\\.iobroker.backitup.DELETE',npm
    ERR!
       parent: 'ioBroker' }
    npm
     ERR!
    npm
     ERR!
     The operation was rejected by your operating system.
    npm
    ERR!
     It's possible that the file was already in use (by a text editor or antivirus),npm
    ERR!
     or that you lack permissions to access it.
    npm
    ERR!
    npm
    ERR!
     If you believe this might be a permissions issue, please double-check the
    npm
    ERR!
     permissions of the file and its containing directories, or try running
    npm
    ERR!
     the command again as root/Administrator (though this is not recommended).
    npm ERR! A complete log of this run can be found in:npm ERR!     C:\IoB Testsysteme\ioBroker\env\npm-cache\_logs\2019-12-02T18_13_24_958Z-debug.log
    ERROR: host.iobroker(ioBroker) Cannot install iobroker.backitup@1.3.1: 4294963248
    HomoranH simatecS 2 Antworten Letzte Antwort
    • JB_SullivanJ JB_Sullivan
      NPM version: 6.9.0
      npm
      ERR!
      errno
       -4048
      npm
      ERR!
      syscall
       rename
      npm
       ERR!
      npm
      ERR!
      ERR!
         cause:
      npm
       ERR!
      npm
      ERR!
            errno: -4048,
      npm
      ERR!      code: 'EPERM',
      npm
      ERR!
            syscall: 'rename',
      npm
      ERR!
            path:npm
       ERR!
      npm
      ERR!
            dest:npm
      ERR!
      npm
      ERR!   stack:
      npm
       ERR!
      npm
      ERR!
         errno: -4048,npm
      ERR!
         code: 'EPERM',
      npm
      ERR!
      ERR!   path:
      npm
       ERR!
      npm
      ERR!
         dest:
      npm
      ERR!
      ERR!
      npm
       ERR!
      npm
       ERR!
      npm
      ERR!
      ERR!
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
      npm
      ERR!
      @JB_Sullivan sagte in Test Adapter Backitup v1.3.x:
      Error: EPERM:
      wie alt ist deine Installation?
      als root?
      als User xy?
      als user ioBroker?
      • JB_SullivanJ
        JB_SullivanJ
        JB_Sullivan
        Es ist eine Windows Installation aus 2018 mit einem Datenbestand den ich seit 2018 immer via "Komplettes Backup" mit herum geschleppt habe. Vor ca. 2 Wochen wurde mit dem alten Installer 1.5.4 eine neun Sitzung mit der Option "Migration" auf Basis dieser 2018er Dateien angelegt.
        Anschließend wurde per manuellem Update der js-controller 2.1.1 auf den letzten Stand gebracht.
        Ich wollte eigentlich alles mit dem neuen Windows Installer 2.1.0 neu aufsetzen - keine Chance - siehe hier -> https://forum.iobroker.net/topic/25692/js-controller-2-0-ab-sofort-im-latest-repo/992
        Ich bekomme diese Woche mein NUC und da werde ich ioBroker mal komplett neu Installieren und dann ein minimal Backup einspielen. Allerdings werde ich Windows10 treu bleiben. Für die ganzen anderen Betriebssysteme und VM Lösungen bin ich zu Blöd.
          @JB_Sullivan
          Dann kann ich dir nicht helfen. Der Fixer ist mMn nur für Linux
            NPM version: 6.9.0
            npm
            ERR!
            errno
             -4048
            npm
            ERR!
            syscall
             rename
            npm
             ERR!
            npm
            ERR!
            ERR!
               cause:
            npm
             ERR!
            npm
            ERR!
                  errno: -4048,
            npm
            ERR!      code: 'EPERM',
            npm
            ERR!
                  syscall: 'rename',
            npm
            ERR!
                  path:npm
             ERR!
            npm
            ERR!
                  dest:npm
            ERR!
            npm
            ERR!   stack:
            npm
             ERR!
            npm
            ERR!
               errno: -4048,npm
            ERR!
               code: 'EPERM',
            npm
            ERR!
            ERR!   path:
            npm
             ERR!
            npm
            ERR!
               dest:
            npm
            ERR!
            ERR!
            npm
             ERR!
            npm
             ERR!
            npm
            ERR!
            ERR!
            npm
            ERR!
            npm
            ERR!
            npm
            ERR!
            npm
            ERR!
            simatecS
            simatecS
            simatec
            @JB_Sullivan
            Dir fehlen Schreibrechte oder irgendwas ist da noch aktiv.
            Starte mal dein komplettes Windows neu und probiere es noch einmal
            • Besuche meine Github Seite
            • HowTo Restore ioBroker
            • simatecS simatec
              @Einstein67
              Die Redis Meldungen sind ab js-Controller 2.0.x normal.
              Die Warnungen sind aufgrund von Löschungen alter nicht mehr benötigter Objekte in backitup für das total backup.
              Beim nächsten Neustart sollten die Objekte für total und auch die Warnmeldungen verschwunden sein
              E
              E
              Einstein67
              @simatec said in Test Adapter Backitup v1.3.x:
              Hab jetzt ioBroker, danach den Container und zum Schluss auch noch Proxmox "neu gestartet"! Die Warnungen sind nicht loszuwerden! Backups werden aber erstellt wie gewünscht ..
              Also alles OK ;)
              • E Einstein67
                Also alles OK ;)
                simatecS
                simatecS
                simatec
                @Einstein67
                Sind die Objekte für minimal und total weg oder sind die auch noch da?
                E 1 Antwort Letzte Antwort
                • simatecS simatec
                  @JB_Sullivan
                  JB_SullivanJ
                  JB_SullivanJ
                  JB_Sullivan
                  @simatec sagte in Test Adapter Backitup v1.3.x:
                  @JB_Sullivan
                  Eben gerade gemacht - nun ist es ganz sauber durchgelaufen 👍 👍 👍 👍
                  • simatecS simatec
                    @Einstein67
                    E
                    E
                    Einstein67
                    Ja, die alten Objekte scheinen weg zu sein.
                    • E Einstein67
                      simatecS
                      simatecS
                      simatec
                      @Einstein67 perfekt ... so sollte es sein.
                      Habe die Meldungen bereits gefixt.
                      • JB_SullivanJ
                        JB_SullivanJ
                        JB_Sullivan
                        Habt ihr das Komplett Backup jetzt doch wieder aufleben lassen?
                        Ich wundere mich gerade - habe 1.3.1 drauf und bekomme im Instanz Menü wieder mit Komplett Backup Option angezeigt.
                        ..... oder liegt es evtl. daran das ich Remote via iobroker.pro auf meine Installation zugreife?
                        2019-12-03 10_57_24-instances - ioBroker.png 2019-12-03 10_58_03-adapters - ioBroker.png
                          simatecS
                          simatecS
                          simatec
                          @JB_Sullivan
                          Das muss etwas mit deinem Cache oder remote zu tun haben.
                          Das Menü sieht definitiv nicht mehr so aus ...
                          Und nein, das total wird es nicht mehr geben.
                          • D
                            D
                            deifel
                            leider bekomme ich mit der neuen Version folgende Fehler:
                            backitup.0	2019-12-03 15:37:01.846	error	at Timer.listOnTimeout (timers.js:290:5)
                            backitup.0	2019-12-03 15:37:01.846	error	at tryOnTimeout (timers.js:323:5)
                            backitup.0	2019-12-03 15:37:01.846	error	at ontimeout (timers.js:498:11)
                            backitup.0	2019-12-03 15:37:01.846	error	at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/iobroker.backitup/lib/list.js:86:55)
                            backitup.0	2019-12-03 15:37:01.846	error	at result (/opt/iobroker/node_modules/iobroker.backitup/main.js:723:35)
                            backitup.0	2019-12-03 15:37:01.846	error	at Array.forEach (<anonymous>)
                            backitup.0	2019-12-03 15:37:01.846	error	at Object.keys.forEach.type (/opt/iobroker/node_modules/iobroker.backitup/main.js:726:26)
                            backitup.0	2019-12-03 15:37:01.846	error	at data.(anonymous function).iobroker.data.(anonymous function).iobroker.filter.forEach.f (/opt/iobroker/node_modules/iobroker.backitup/main.js:727:42)
                            backitup.0	2019-12-03 15:37:01.846	error	at getName (/opt/iobroker/node_modules/iobroker.backitup/main.js:702:27)
                            backitup.0	2019-12-03 15:37:01.846	error	(29799) TypeError: Cannot read property 'split' of undefined
                            backitup.0	2019-12-03 15:37:01.846	error	(29799) uncaught exception: Cannot read property 'split' of undefined
                            Sobald ich zurück auf die 1.3.0 gehe, läuft alles wieder einwandfrei.
                            Habe bereits mehrfach versucht, upzudaten. Kann mir jemand sagen, was ich falsch mache oder woran der Fehler liegt?
                            Anderenfalls bleibe ich erstmal bei der für mich stabilen Version.
                            Viele Grüße
                            Frank
                            • simatecS simatec
                              Aktuelle Test Version 3.1.0
                              Veröffentlichungsdatum 02.03.2025
                              Github Link https://github.com/simatec/ioBroker.backitup
                              Wiki Link https://github.com/simatec/ioBroker.backitup/wiki
                              Hier geht es um die aktuelle Version von ioBroker.backitup, nachdem der alte Thread langsam zu unübersichtlich wurde.
                              Bitte gebt euer Feedback und eure Anregungen hier ab.
                              3.1.0 (2025-03-02)
                              • (Bluefox) Dependencies updated
                              • (Bluefox) Vite added
                              • (simatec) jsonConfig updated
                              • (simatec) Fix month for history
                              3.0.37 (2025-02-28)
                              • (simatec) Fix CronJob
                              3.0.36 (2025-02-26)
                              • (simatec) Fix src-admin
                              3.0.35 (2025-02-26)
                              3.0.34 (2025-02-26)
                              3.0.33 (2025-02-25)
                              • (simatec) Fix cronjob
                              • (simatec) Fix Backup Console
                              3.0.32 (2025-02-24)
                              • (simatec) Error handling for GoogleDrive fix
                              • (simatec) globalDependencies updated
                              • (simatec) Dependencies updated
                              • (simatec) Design Fix
                              3.0.31 (2024-11-30)
                              • (simatec) Fix Tab Menu
                              3.0.30 (2024-11-29)
                              3.0.29 (2024-11-29)
                              3.0.28 (2024-11-27)
                              • (simatec) eslint-config added
                              • (bluefox) Allow to store files for up to ca 3 years
                              • (Marc-Berg) Grafana Docu updated
                              3.0.27 (2024-11-12)
                              • (simatec) dependencies updated
                              3.0.26 (2024-10-16)
                              • (simatec) Fix FTP Connections
                              • (simatec) Issue Workflow added
                              3.0.25 (2024-09-26)
                              • (bluefox) Improvement of Google Drive authentication workflow
                              • (bluefox) Removed gulp from a build process
                              • (simatec) small Design Fix
                              • (simatec) Fix for Admin 7.1.5
                              • (simatec) Fix Test & Release
                              • (simatec) Fix ESlint errors
                              3.0.22 (2024-09-03)
                              • (simatec) Fix Notification Instance
                              • (simatec) Fix Notification Design
                              • (simatec) Fix Default Settings
                              3.0.21 (2024-09-01)
                              • (simatec) Fix Onedrive Notification
                              • (simatec) Fix Zigbee2MQTT Backup
                              3.0.20 (2024-08-22)
                              • (simatec) Responsive Design for Tab added
                              • (simatec) Responsive Design for jsonConfig added
                              3.0.19 (2024-08-15)
                              • (simatec) Fix CCU Backup
                              • (simatec) Fix InfluxDB Backup Config
                              • (simatec) Fix Backup-Log for Slave Instanz
                              3.0.18 (2024-08-14)
                              • (simatec) Package optimisation
                              • (simatec) Fix the warning when opening the configuration
                              3.0.17 (2024-08-12)
                              • (simatec) Fix io-package for Release
                              • (simatec) manual-review added
                              • (simatec) Fix Slave Backup
                              3.0.16 (2024-08-05)
                              • (bluefox) dependencies updated
                              • (simatec) Rename json5 Files
                              3.0.15 (2024-08-03)
                              • (simatec) fix dependencies
                              3.0.14 (2024-08-02)
                              • (simatec) Improved log outputs
                              3.0.12 (2024-08-01)
                              • (simatec) Backup Log for History added
                              • (simatec) Added separate selection for deleting FTP backups
                              • (simatec) Added separate selection for deleting Onedrive backups
                              • (simatec) Added separate selection for deleting Webdav backups
                              • (simatec) Added separate selection for deleting Dropbox backups
                              • (simatec) Added separate selection for deleting Googledrive backups
                              • (simatec) Source code cleaned up
                              3.0.11 (2024-07-28)
                              3.0.10 (2024-07-22)
                              • (simatec) Design Fix for Dark Mode
                              3.0.9 (2024-07-11)
                              • (simatec) Tab Icons added
                              • (simatec) small fix
                              • (simatec) Docu updated
                              3.0.8 (2024-07-01)
                              • (Grothesk242/simatec) forceuid and forcegid added
                              3.0.7 (2024-06-26)
                              • (simatec) Restore Information added
                              • (simatec) Fix Formaterrors
                              • (bluefox) Fixing the problems with styles
                              • (simatec) Fix iobroker Backup Error
                              3.0.6 (2024-06-26)
                              3.0.5 (2024-06-18)
                              • (simatec) Fix Build
                              3.0.4 (2024-06-18)
                              • (simatec) History Gui Fix
                              • (simatec) Tab GUI modified
                              • (bluefox) Added support for Admin 7
                              • (simatec) Onedrive ready for School/Business Accounts
                              3.0.3 (2024-06-10)
                              • (simatec) Fixed WebDav
                              • (simatec) Admin Notification for Backup errors added
                              • (simatec) Remove Sentry Config
                              • (simatec) Translations updated
                              • (simatec) Error handling optimized
                              3.0.2 (2024-06-06)
                              • (simatec) Fixed Google Drive
                              • (simatec) Fixed Translations
                              • (simatec) Fixed Onedrive
                              • (simatec) Fixed MySql Backup
                              • (simatec) Fixed Translation added
                              • (simatec) new notifications content added
                              3.0.1 (2024-05-29)
                              • (simatec) Fixed umount callback
                              • (simatec) Fixed Backup Message
                              • (simatec) Fixed InfluxDB Multi Backup
                              • (simatec) Fixed Restore Console
                              • (simatec) Fixed Backup Console
                              3.0.0 (2024-05-28)
                              • (simatec) jsonConfig added
                              • (bluefox) Conversion to React
                              • (bluefox) Added react components
                              • (bluefox/simatec) Working on React GUI
                              • (simatec) Fix Yahka Backup
                              • (simatec) Fix Nodered Backup
                              • (simatec) some bugs fixed
                              • (bluefox/simatec) New Restore-Interface
                              • (simatec) Translation updated
                              DiginixD
                              DiginixD
                              Diginix
                              @simatec
                              Kann es sein dass die Bereinigung alter Backups auf dem System und im Cloudspeicher nicht mehr funktioniert seit der Umbenennung der Backups? Mein Limit steht auf 30, ich habe aber 32 in der Dropbox und lokal. 30 alte heißen noch minimal... und 2 neue iobroker...
                              Könnte man das History Backup seltener als das tägliche Minimal einplanen?
                              Mein minimal ist nur 4 MB groß, der gepackte history Ordner hat 80 MB. Das würde ich aber ungern täglich in die Dropbox schaufeln wollen.
                              ..:: So long! Tom ::..
                              • DiginixD Diginix
                                @simatec
                                simatecS
                                simatecS
                                simatec
                                @Diginix sagte in Test Adapter Backitup v1.3.x:
                                @simatec
                                Richtig ... minimal sind die alten und müssen nun händisch gelöscht werden oder einfach umbenannt werden.
                                Schaue ich mir mal an ...
                                • D deifel
                                  Viele Grüße
                                  Frank
                                  simatecS
                                  simatecS
                                  simatec
                                  @deifel sagte in Test Adapter Backitup v1.3.x:
                                  Viele Grüße
                                  Frank
                                  Schaue mal bitte in den Tab "Wiederherstellen" ...
                                  Was ist da bei dir als "Backup Quelle" ausgewählt?
                                  Denke da liegt das Problem, da ein kleiner Schreibfehler in dieser Version vorlag.
                                  • simatecS
                                    simatecS
                                    simatec
                                    Ab sofort steht die Version 1.3.2 auf Github und spätestens ab heute Nacht auch in der latest Repo zur Verfügung.
                                    Wichtigste Neuerung neben einigen kleinen Bugfix ist das kleine Webinterface für den Restore.
                                    Hier öffnet sich nun bei Start des Restore's ein neuer Tab, in dem ihr den log bzw. Wiederherstellungsprozess genau verfolgen könnt.
                                    Aufgrund des Stopps von ioBroker war dies bisher nicht möglich und man sah nur über einige Umwege, was gerade passiert.
                                    Ab sofort sieht man genau, was gerade für Prozesse der Wiederherstellung laufen.
                                    Hier ein paar Screenshots, wie das Ganze dann ausschaut ...
                                    DiginixD sigi234S 2 Antworten Letzte Antwort
                                    • simatecS simatec
                                      DiginixD
                                      DiginixD
                                      Diginix
                                      @simatec Wow, das nenne ich Komfort und Transparenz!
                                      • simatecS simatec
                                        sigi234S
                                        sigi234S
                                        @simatec
                                        Hallo, seit dem update schaut die Formatierung von backitup.0.history.html anders aus, hast du was umgestellt?
                                        Muss ich was umstellen?
                                        Kannst du auch eine Html machen für Latest backup found by start?
                                        JB_SullivanJ simatecS 2 Antworten Letzte Antwort
                                        • sigi234S sigi234
                                          @simatec
                                          JB_SullivanJ
                                          JB_SullivanJ
                                          JB_Sullivan
                                          @sigi234 sagte in Test Adapter Backitup v1.3.x:
                                          @simatec
                                          Die gleiche Frage wollte ich auch eben stellen ;)
