  4. Test Adapter Material Design Widgets v0.2.x
visadapatervisualizationmaterialwidget
902 Beiträge 77 Kommentatoren 343.4k Aufrufe 79 Beobachtet
  • ScroungerS Scrounger
    @Zipkart
    Hast du einen Toggle Button oder einen State Button verwendet?
    Von welchem Typ ist der Datenpunkt?
    Edit:
    Mach mal nen Export von dem Widget und poste die raw daten des zugewiesenen datenpunktes.
    Z Offline
    Z Offline
    Zipkart
    @Scrounger sagte in Test Adapter Material Design Widgets v0.2.x:
    @Zipkart
    Edit:
    Sorry dass ich mich jetzt erst melde, aber ich musst mal wieder ein Backup einspielen im Livesystem.
    Hier ist schon mal das Widget
    [{"tpl":"tplVis-materialdesign-Button-Toggle-vertical","data":{"oid":"hue.0.Philips_hue.Kugel_SZ.on","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","buttonStyle":"unelevated","toggleType":"boolean","stateIfNotTrueValue":"on","vibrateOnMobilDevices":"50","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"colorBgFalse":"rgb(70, 70, 70)","colorBgTrue":"#CDDC39","imageTrue":"/icons-ultimate-png/983.png","image":"/icons-ultimate-png/981.png","valueOff":"","valueOn":"","labelFalse":"","labelTrue":"","colorPress":"green"},"style":{"left":"5px","top":"410px","width":"275px","height":"130px","text-align":"center"},"widgetSet":"materialdesign"}]
    und hier der Raw des Datenpunktes
    "from": "system.adapter.hue.0",
    "user": "system.user.admin",
    "ts": 1562209210940,
    "common": {
    "name": "Philips_hue.Kugel_SZ.on",
    "type": "boolean",
    "role": "switch",
    "read": true,
    "write": true
    "native": {
    "id": "26"
    "acl": {
    "object": 1636,
    "owner": "system.user.admin",
    "state": 1636
    "_id": "hue.0.Philips_hue.Kugel_SZ.on",
    "type": "state"
    Vielleicht kannst du ja helfen
    Produktiv Proxmox / NUC / IOBroker / RFLInk / Mysensor / Raspimatic / Keymatic / HUE / MiHome / Tradfri / Shelly / SOnOff / Alexa / Sonos / Wandtablet / iPad
    Testsystem…
    immer mal wieder unterschiedlich
    • O Online
      O Online
      Oli
      ich habe ein paar Fragen zum Line History Chart.
      1. ist es Möglich nur das Diagrammfeld einzufärben wie beim angefügten Diagramm?
      2. Wie kann ich mir zu der Uhrzeit noch das Datum in der X-Achse anzeigen lassen?
      3. Wie kann ich die Messeinheit in der Y-Achse anzeigen lassen?
      Oliver
      ScroungerS 1 Antwort Letzte Antwort
      • O Oli
        ScroungerS Offline
        ScroungerS Offline
        Scrounger
        @Oli sagte in Test Adapter Material Design Widgets v0.2.x:
        Nee das geht nicht, kann man aber sicher leicht einbauen - ich schau mal. Am besten wäre wenn du dazu ein Issue auf git anlegest, damit wir es nicht vergessen.
        1. Wie kann ich mir zu der Uhrzeit noch das Datum in der X-Achse anzeigen lassen?
        Du kannst über die Option 'time formats of x-axis' im Editor ganz individuell dein format einstellen. Ist in der Doku entsprechend beschrieben:
        https://github.com/Scrounger/ioBroker.vis-materialdesign#line-history-chart
        1. Wie kann ich die Messeinheit in der Y-Achse anzeigen lassen?
        Ist noch nicht implementiert. Hier das gleiche wie oben, bitte ein issue auf github erstellen.
        O 2 Antworten Letzte Antwort
          O Online
          O Online
          Oli
          @Scrounger
          alles klar, mache ich
          Oliver
            O Online
            O Online
            Oli
            @Scrounger
            sorry, aber ich habe mir deinen Link zig mal durchgelesen, aber anscheinend reicht mein Horizont dafür nicht aus. Wäre nett wenn du mir da etwas unter die Arme greifen könntest.
            Was müsste ich in der Option 'time formats of x-axis' eingeben, damit ich zur Uhrzeit zusätzlich noch das Datum angezeigt bekomme?
            Beim testen deines 'List Value' Wigets ist mir aufgefallen, dass man die Höhe nicht ändern kann, ist das nur bei mir so?
            Ich habe leider auch keine Einstellung gefunden, wo ich die Schriftfarbe ändern kann.
            Und noch eine letzte Frage hätte och, gibt es bei deinem Table Wigets ein Möglichkeit des Zeilenumbruchs, wenn der Text zu lang ist?
            Oliver
            sigi234S ScroungerS 2 Antworten Letzte Antwort
            • O Oli
              @Scrounger
              sigi234S Online
              sigi234S Online
              Layout des Listenelements
              O 1 Antwort Letzte Antwort
              • sigi234S sigi234
                O Online
                O Online
                Oli
                @sigi234
                und wo finde ich das?
                Oliver
                • O Oli
                  @sigi234
                  sigi234S Online
                  sigi234S Online
                  @sigi234
                  Warte, das ist das Widget List
                  Du meinst ja Value Select
                  • sigi234S sigi234
                    @sigi234
                    O Online
                    O Online
                    Oli
                    @sigi234
                    ich glaube wir sprechen von unterschiedlichen Widgets, ich meine das hier:
                    Oliver
                    • O Oli
                      @sigi234
                      sigi234S Online
                      sigi234S Online
                      @sigi234
                      Siehe Beitrag unten, 2.Screenshot
                      • sigi234S sigi234
                        @sigi234
                        D Online
                        D Online
                        darkiop
                        schrieb am zuletzt editiert von darkiop
                        @Scrounger Kurze Frage, planst du aktuell auch ein 'input' für die Texteingabe?
                        Weiterhin alle Daumen hoch für die Arbeit hier!
                        Und noch eine Frage:
                        Könntest du die Schriftfarbe / Schriftart bei den Selects noch über VIS Edit Konfigurierbar machen? Aktuell bin ich da immer den Umweg über CSS gegangen.
                        Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
                        • O Oli
                          @Scrounger
                          ScroungerS Offline
                          ScroungerS Offline
                          Scrounger
                          @Scrounger
                          folgendes ist ja standardmäßig eingestellt:
                                          "millisecond":    "H:mm:ss.SSS",
                                          "second":         "H:mm:ss",
                                          "minute":         "H:mm",
                                          "hour":           "H",
                                          "day":            "MMM D",
                                          "week":           "ll",
                                          "month":          "MMM YYYY",
                                          "quarter":        "[Q]Q - YYYY",
                                          "year":           "YYYY"
                          Wnn du jetzt z.B. als Timeinterval 1 Stunde festgelegt hast, dann zieht er die Fomatierung von 'minute' an. Du musst dann z.B. um folgendes erweitern H:mm DD.MM.YYYY. Mögliche Formatierungen sind hier beschrieben: https://momentjs.com/docs/#/displaying/format/
                          Einfach mal bissle rum spielen und ausprobieren, dann findet man meistens raus wie es funktioniert.
                          auf die schnelle, bei 'vorangesteller Text' folgendes eintragen <span style="display: inline-block; word-wrap:break-word;"> und bei 'nachgestellter Text' folgendes eintragen </span> oder so ähnlich.
                          @darkiop sagte in Test Adapter Material Design Widgets v0.2.x:
                          Ja, da es bestandteil der mdc lib ist. Allerdings ganz niedrige prio, da ich in meiner VIS keine input felder benötige. Am besten erstelltst dafür ein issue bei github, damit wir es nicht vergessen.
                          Ja kann ich einbauen. Hierfür bitte auch ein issue auf github erstellen, danke!
                          O D 2 Antworten Letzte Antwort
                            @Scrounger
                                            "minute":         "H:mm",
                                            "hour":           "H",
                                            "day":            "MMM D",
                                            "week":           "ll",
                                            "year":           "YYYY"
                            O Online
                            O Online
                            Oli
                            @Scrounger said in Test Adapter Material Design Widgets v0.2.x:
                            danke, dass mit dem Datumsformat hab ich jetzt begriffen, aber das mit dem Zeilenumbruch klappt leider noch nicht.
                            Oliver
                              @Scrounger
                                              "minute":         "H:mm",
                                              "hour":           "H",
                                              "day":            "MMM D",
                                              "week":           "ll",
                                              "year":           "YYYY"
                              D Online
                              D Online
                              darkiop
                              Guten Abend, sind beide erstellt.
                              Rein aus Interesse, würdest du als Entwickler der Widgets mal einen Screen deiner VIS posten?
                              • O Oli
                                ScroungerS Offline
                                ScroungerS Offline
                                Scrounger
                                Ok da ist noch ein bug drin, weshalb das nicht so einfach geht.
                                😁 Da wärt ihr alle sehr entäuscht. Hab grad mal 3 halbfertige Views bis jetzt, weil ich nebenbei immer Fehler oder Sachen entdecke, die ich zur Umsetzung meiner Ideen noch programmieren muss. Und sobald das implementiert ist hab ich mein Idee bereits vergessen 🤦
                                Sobald ich mal einen representativen Stand habe werde ich hier, wie bereits erwähnt, einen extra Thread eröffnen wo wir dann unsere zusammengestellten Widgets zur Bedienung von Lampen, Media, Heizung, etc. teilen können.
                                  O Online
                                  O Online
                                  Oli
                                  @Scrounger
                                  im Basic Wiget kann man die breite der einzelnen Spalten angeben, vielleicht liegt es daran.
                                  Kann ich irgendwo die Farbe des ausgewählten Wertes ändern, habe irgendwie nichts gefunden?
                                  Oliver
                                  • O Oli
                                    @Scrounger
                                    sigi234S Online
                                    sigi234S Online
                                    @Scrounger
                                    Die 2 Minuten? Also bei mir 10
                                    Hab ich auch noch nicht raus gefunden.
                                    • sigi234S sigi234
                                      @Scrounger
                                      O Online
                                      O Online
                                      Oli
                                      @sigi234
                                      ja die 2 Minuten
                                      Oliver
                                      • O Oli
                                        @sigi234
                                        ja die 2 Minuten
                                        ScroungerS Offline
                                        ScroungerS Offline
                                        Scrounger
                                        @Oli, @sigi234
                                          @Oli, @sigi234
                                          O Online
                                          O Online
                                          Oli
                                          @Scrounger
                                          das habe ich gefunden, ich meinte, sobald eine Auswahl getroffen wurde, wie in meinen Bild, die 2 Minuten.
                                          Oliver
