  4. js-controller 2.0 ab sofort im Latest Repo
js-controller
1.1k Beiträge 89 Kommentatoren 539.8k Aufrufe 64 Beobachtet
    @apollon77 sagte in js-controller 2.0 ab sofort im Latest Repo:
    @ilovegym PS: Danach aber im normalen Log gab es keine solchen Meldungen?
    nee, ab und zu kommt mal : some Hosts are offline ( sind sie aber nicht).. und der Sonoff Adapter zickt seitdem rum..
    host.iobroker	2019-11-22 17:30:09.407	error	Caught by controller[0]: at DestroyableTransform.onreadable (/opt/iobroker/node_modules/duplexify/index.js:134:10)
    host.iobroker	2019-11-22 17:30:09.406	error	Caught by controller[0]: at Connection.Duplexify._forward (/opt/iobroker/node_modules/duplexify/index.js:170:26)
    host.iobroker	2019-11-22 17:30:09.406	error	Caught by controller[0]: at Connection.Readable.push (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:245:10)
    host.iobroker	2019-11-22 17:30:09.406	error	Caught by controller[0]: at readableAddChunk (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:278:11)
    host.iobroker	2019-11-22 17:30:09.406	error	Caught by controller[0]: at addChunk (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:291:12)
    host.iobroker	2019-11-22 17:30:09.406	error	Caught by controller[0]: at Connection.emit (events.js:198:13)
    host.iobroker	2019-11-22 17:30:09.405	error	Caught by controller[0]: at Connection.emitPacket (/opt/iobroker/node_modules/mqtt-connection/connection.js:10:8)
    host.iobroker	2019-11-22 17:30:09.405	error	Caught by controller[0]: at Connection.emit (events.js:198:13)
    host.iobroker	2019-11-22 17:30:09.405	error	Caught by controller[0]: at Connection.client.on.packet (/opt/iobroker/node_modules/iobroker.sonoff/lib/server.js:1558:21)
    host.iobroker	2019-11-22 17:30:09.405	error	Caught by controller[0]: at receivedTopic (/opt/iobroker/node_modules/iobroker.sonoff/lib/server.js:1067:30)
    host.iobroker	2019-11-22 17:30:09.405	error	Caught by controller[0]: TypeError: Cannot read property 'topic' of undefined
    host.iobroker	2019-11-22 17:30:08.181	info	instance system.adapter.meteoalarm.0 started with pid 15225
    host.iobroker	2019-11-22 17:30:04.158	info	instance system.adapter.ical.0 started with pid 15210
    host.iobroker	2019-11-22 17:30:01.603	info	instance system.adapter.wifilight.0 started with pid 15191
    host.iobroker	2019-11-22 17:30:00.582	info	Restart adapter system.adapter.wifilight.0 because enabled
    host.iobroker	2019-11-22 17:30:00.582	error	instance system.adapter.wifilight.0 terminated with code 156 (156)
    host.iobroker	2019-11-22 17:30:00.023	info	instance system.adapter.openweathermap.0 started with pid 15179
    host.iobroker	2019-11-22 17:29:31.207	warn	some hosts are offline
    apollon77A
    apollon77A
    #979
    @ilovegym "some hosts are offline" ist nur die Meldung das es da Hosts im System gibt die offline sind ... mehr heisst das nicht. Irgendein Host ist da aber dann offline noch (also irgend ein Slave)
    • E Einstein67
      Hab die RESTORE Funktion mit aktivierten Compact-Mode getestet.
      Funktioniert mit 2.1.1 nun problemlos bei allen Gruppen!!
      Vielen Dank!
      apollon77A
      apollon77A
      #980
      @Einstein67 Danke, extrem cool
      • apollon77A apollon77
        #981
        ähm, nö.. :-) da ist nix offline.. vielleicht dem Herrn iobroker nicht schnell genug? Timeout?
        hier alles grün:
        hier die Pings:
        ilovegym@iobroker ~ $ cd /opt/iobroker
        ilovegym@iobroker /opt/iobroker $ ping zeroberry
        PING zeroberry.fritz.box (192.168.178.31) 56(84) bytes of data.
        64 bytes from zeroberry.fritz.box (192.168.178.31): icmp_seq=1 ttl=64 time=26.0 ms
        64 bytes from zeroberry.fritz.box (192.168.178.31): icmp_seq=2 ttl=64 time=39.3 ms
        64 bytes from zeroberry.fritz.box (192.168.178.31): icmp_seq=3 ttl=64 time=79.6 ms
        ^C
        --- zeroberry.fritz.box ping statistics ---
        3 packets transmitted, 3 received, 0% packet loss, time 2002ms
        rtt min/avg/max/mdev = 26.016/48.327/79.664/22.812 ms
        ilovegym@iobroker /opt/iobroker $ ping meterberry
        PING meterberry.fritz.box (192.168.0.57) 56(84) bytes of data.
        64 bytes from meterberry.fritz.box (192.168.0.57): icmp_seq=1 ttl=64 time=0.563 ms
        64 bytes from meterberry.fritz.box (192.168.0.57): icmp_seq=2 ttl=64 time=9.68 ms
        ^C
        --- meterberry.fritz.box ping statistics ---
        2 packets transmitted, 2 received, 0% packet loss, time 1010ms
        rtt min/avg/max/mdev = 0.563/5.123/9.683/4.560 ms
        ilovegym@iobroker /opt/iobroker $ ping zweiberry
        PING zweiberry.fritz.box (192.168.0.67) 56(84) bytes of data.
        64 bytes from zweiberry.fritz.box (192.168.0.67): icmp_seq=1 ttl=64 time=0.668 ms
        64 bytes from zweiberry.fritz.box (192.168.0.67): icmp_seq=2 ttl=64 time=0.813 ms
        ^C
        --- zweiberry.fritz.box ping statistics ---
        2 packets transmitted, 2 received, 0% packet loss, time 1001ms
        rtt min/avg/max/mdev = 0.668/0.740/0.813/0.077 ms
        ilovegym@iobroker /opt/iobroker $ ping berrymotion
        PING berrymotion.fritz.box (192.168.178.32) 56(84) bytes of data.
        64 bytes from berrymotion.fritz.box (192.168.178.32): icmp_seq=1 ttl=64 time=6.37 ms
        64 bytes from berrymotion.fritz.box (192.168.178.32): icmp_seq=2 ttl=64 time=4.14 ms
        ^C
        --- berrymotion.fritz.box ping statistics ---
        rtt min/avg/max/mdev = 4.142/5.259/6.376/1.117 ms
        ilovegym@iobroker /opt/iobroker $ ping gymberry
        PING gymberry.fritz.box (192.168.0.84) 56(84) bytes of data.
        64 bytes from gymberry.fritz.box (192.168.0.84): icmp_seq=1 ttl=64 time=0.814 ms
        64 bytes from gymberry.fritz.box (192.168.0.84): icmp_seq=2 ttl=64 time=0.752 ms
        ^C
        --- gymberry.fritz.box ping statistics ---
        rtt min/avg/max/mdev = 0.752/0.783/0.814/0.031 ms
          hier alles grün:
          hier die Pings:
          ^C
          ^C
          ^C
          ^C
          ^C
          apollon77A
          apollon77A
          #982
          @ilovegym Also ich habe nochmal geschaut. Der Admin fragt bei den controllern Infos ab und eine dieser Infos ist welche Version auf welchem Host installiert ist :-) Also genau das was in der Hosts Ansicht im Admin so angezeigt wird. Diese ABfrage über alle Hosts hat aktuell 5s zum Fertig werden ... wenn nicht alle Hosts so schnell geantwortet haben kommt die Meldung.
          Beobachte es mal
            Beobachte es mal
            #983
            Beobachte es mal
            Moin, hmm wenn ich wüsste, welcher Host das wäre.. ich hab n Raspi Zero, der ist per Wlan und n bisschen lahm..
            hier der Auszug von heute, kommt immer noch..
            Seit 10 sitz ich am Rechner.. das mag er wohl nicht :-)
            ilovegym@iobroker /opt/iobroker/log $ cat iobroker.2019-11-23.log | grep some
            2019-11-23 02:11:09.312  - warn: host.iobroker some hosts are offline
            2019-11-23 02:11:19.166  - warn: host.iobroker some hosts are offline
            2019-11-23 02:13:24.964  - warn: host.iobroker some hosts are offline
            2019-11-23 03:45:03.836  - warn: host.iobroker some hosts are offline
            2019-11-23 04:42:12.865  - warn: host.iobroker some hosts are offline
            2019-11-23 10:05:57.985  - warn: host.iobroker some hosts are offline
            2019-11-23 10:06:33.360  - warn: host.iobroker some hosts are offline
            2019-11-23 10:06:56.107  - warn: host.iobroker some hosts are offline
            2019-11-23 10:20:42.512  - warn: host.iobroker some hosts are offline
            2019-11-23 10:20:52.313  - warn: host.iobroker some hosts are offline
            2019-11-23 10:29:49.736  - warn: host.iobroker some hosts are offline
            2019-11-23 10:30:15.023  - warn: host.iobroker some hosts are offline
            2019-11-23 10:31:01.581  - warn: host.iobroker some hosts are offline
            2019-11-23 10:38:29.141  - warn: host.iobroker some hosts are offline
            2019-11-23 10:45:17.477  - warn: host.iobroker some hosts are offline
              Beobachte es mal
              apollon77A
              apollon77A
              #984
              @ilovegym hast du im Admin den „hosts Tab“ vllt da offen? Das würde die verstärkte Anzahl erklären.
              Bzw schau mal ob die system.hosts.* zu deinen hosts passen und das bei den Objekten nicht irgend ein Alter drin ist.
              Also effektiv ist’s erstmal nur ne Meldung.
                #985
                @apollon77 ah, wenn sich die Zeiten für alle Hosts summieren, dann sind 5sek recht wenig.. ich glaub ich meinen Kanditaten, die Einträge sind zwar alle ok aber wenn ich auf den Zeroberry per console gehe, habe ich ein delay von ca. 1-2 sek... wenn der so auch an den iobroker antwortet, dann sind das mit den anderen 4 Hosts dann schnell mal mehr als 5sek..
                Also da es nur ein Warn ist und keinen Einfluss auf das System und die Funktion hat, beobachte ich mal weiter, aber unternehm tun wir deshalb nix.
                Vielen Dank
                • JB_SullivanJ
                  JB_SullivanJ
                  JB_Sullivan
                  schrieb am zuletzt editiert von JB_Sullivan
                  #986
                  So dann wollen wir mal - ich habe die ganze letzte Woche immer und immer wieder versucht mit dem Windows Installer die neu Version 2.1 auf den Rechner zu bekommen.
                  Ich bin jedes mal gescheitert. Die Migration von meiner bestehenden und Lauffähigen Version funktioniert nie. Selbst der Versuch diese lauffähige Version per manuellem Update auf 2.1 hoch zu ziehen scheitert.
                  Jetzt möchte ich das ganze heute nochmal strukturiert und sofern möglich mit allen LOG Einträgen angehen.
                  Dazu folgende Fragen:
                  Wenn ich den WinInstaller benutze und in der Vergangenheit diesen ebefalls benutzt habe (V1.5.14), wird mir die Neuinstallation immer wieder in den "damals" eingegebenen Pfad rein geschrieben. Ich kann keinen anderen Pfad auswählen - ist das immer so?
                  Beispiel - 1. Installation von 1.5.14 unter - C:/ioBroker_test/ioB_Test/ Jetzt möchte ich aber die Version 2.1 in C:/iobroker installieren unter Zuhilfenahme der Daten aus C:/ioBroker_test/ioB_Test/iobroker-data.
                  Die Migrationsüberprüfung sagt OK, Es besteht aber keine Möglichkeit das Zielverzeichnis anzupassen und so wird diese neue 2.1er Kopie als C:/ioBroker_test/iobroker/ angelegt - was ich aber so nicht haben möchte.
                  Das nächste Problem, scheint die Migration zu sein. Ich gehe mal davon aus, das hier "einfach" der Ordner iobroker-data aus dem Quellverzeichnis in das neue Zielverzeichnis kopiert wird - ist das so?
                  Wenn ja, findet das bei mir, aus welchen Gründen auch immer nichts statt - auch nach 3 Stunden warten nicht. Vielmehr hagelt es im LOG File jede Menge Fehlermeldungen. Ich kenne jetzt den genauen Prozess nicht, aber meine Vermutung ist, die das es eine Datei gibt, in der alle installierten Adapter aufgelistet sind.
                  Die installierten Adapter kommen per copy aus dem Quellzeichnis. Da das bei mir aber nicht passiert, hagelt es die Fehlermeldungen im Rahmen der Adapter Überprüfungen / Aktualisierungen, weil die entsprechenden Ordner gar nicht in iobroker-data vorhanden sind. Sind meine Beobachtungen soweit korrekt?
                  Soweit die Probleme wenn ich mit dem Installler arbeite.
                  Nun zum Versuch die laufende Version manuell zu aktualisieren.
                  Ich stoppe ioB, kontrolliere ob alle Node.js Instanzen beendet sind und gebe folgendes im DOS Fenster ein.
                  C:\IoB _test\ioBroker>ioB_Test iobroker status
                  *** Node.js not found. Please start the ioBroker commandline environment using the corresponding startmenu shortcut. Aborting...
                  Ich kann mit diesem Hinweis nichts anfangen - was genau soll ich machen. Was ist die Komandozeilen Umgebung und welche Start Menü Verknüpfung soll ich eingeben?
                  Warum wird Node.js nicht gefunden? Diese Instanz von ioBroker ist lauffähig und funktioniert einwandfrei, sobald man den Windows Dienst von ioB startet.
                  Wie gesagt im Moment bekomme ich es nicht gebacken - weder mit Aktualisierung noch mit einer Migrierten Neuinstallation.
                  Vielleicht kann mir ja jemand den einen oder anderen Hilfreichen Hinweis geben.
                  StabilostickS 1 Antwort Letzte Antwort
                  • JB_SullivanJ JB_Sullivan
                    StabilostickS
                    StabilostickS
                    Stabilostick
                    schrieb am zuletzt editiert von Stabilostick
                    #987
                    @JB_Sullivan sagte in js-controller 2.0 ab sofort im Latest Repo:
                    Bei der ersten Installation von ioBroker wird beim ersten Mal nach einem Stamm-Installationspfad für alle Instanzen gefagt. Dieser wird dann für alle Instanzen verwendet. Eine Änderung ist nicht möglich. Das steht auch im beschreibenden Text im Installer.
                    Tipp: Ein neuer Stammpfad kann dann gewählt werden, nachdem alle ioBroker-Instanzen mit dem ioBroker Installer gelöscht wurden.
                    Das ist ein wichtiger Bestandteil. Zusätzlich werden noch einige kleine Änderungen durchgeführt. Wichtig ist, dass der Quell-ioBroker nicht auf die Dateien zugreift. Wenn die Quelle eine mit dem neuen Installer erstellte ioBroker-Instanz ist, bietet der Installer sogar die Möglichkeit, den entsprechenden Dienst automatisch zu beenden und zu deaktivieren. Bei alten Installationen muss das der Anwender selbst tun.
                    Bitte hier bereitstellen.
                    Nein. In den Datenbanken von ioBroker stehen Informationen zur Adapterkonfiguration. ioBroker selbst stellt beim ersten Start fest, dass eine Adapterinstanz-Konfiguration da ist und will den Adapter starten, merkt dann aber, dass die Programmdateien fehlen und installiert deshalb die gleiche Version per npm im Hintergrund nach. Dieser Prozess kann einige Zeit dauern. Deswegen sind alle Adapter bis auf admin, discovery und info erst einmal nach der Migration im Admin rot. Im Log kann man den Installationsvorgang beobachten. Vor allem VIS-Bibliotheken benötigen Zeit. Adapter, die z.B. manuell von GitHub mit js-controller <2.0 installiert wurden, bleiben nachdem das System mit der Nachinstallation fertig ist rot, weil sie per Hand manuell wieder (z.B. von Github oder normal) nachinstalliert werden müssen.
                    1. Öffne das Startmenü von Windows. Das mit dem Windows-Symbol.
                    2. Dort siehst Du eine Liste von Ordnern und Programmen.
                    3. Scrolle bis zum Ordner „ioBroker“
                    4. Lies die einzelnen Einträge im Ordner.
                    5. Da steht für jede Instanz was von Kommandozeile und Admin.
                    6. Klicke bei der gewünschten Instanz auf den Link zur Kommandozeile.
                    7. Bestätige Sicherheitsdialog.
                    8. Kommandozeile da. Oben steht was von ioBroker und Hilfe.
                    9. Jetzt Befehle eintippen.
                    Gerne.
                    • StabilostickS
                      StabilostickS
                      Stabilostick
                      #988
                      Ich habe gerade eine neue Version (2.1.0.b) des Installers auf der Downloadseite veröffentlicht. Die Version steht im Begrüßungsbild zu Beginn der Installation.
                      Es wird 2.1.0 stable statt 2.1.0 latest installiert. ;-)
                      • JB_SullivanJ
                        JB_SullivanJ
                        JB_Sullivan
                        #989
                        Hallo Stabilostick - vielen Dank das du dir die Zeit genommen hast alles so detailliert aufzuschreiben.
                        Das Ergebniss ist ja mal interessant....... weil ich bislang immer als Admin via cmd.exe die Eingabeaufforderung aufgerufen in dem sich öffnenden DOS Fenster die Befehle eingegeben habe.
                        Das es unter dem WIN Start Menü ein iobroker Ordner mit entsprechenden Sitzungsspezifischen Eingabe Aufforderungen gibt, habe ich nicht gewusst - und natürlich bin ich auch nicht auf die Idee gekommen, dort nachzusehen.
                        Also habe ich jetzt erstmal die bestehende iobroker Instanz händisch aktualisiert - und BINGO, keine Fehlermeldung mehr wie oben beschrieben. Die Aktualisierung ist offensichtlich einwandfrei durchgelaufen, denn es funktioniert wieder alles. Siehe LOG
                        *** Welcome to ioBroker. ***
                        *** Type 'iobroker help' for list of instructions. ***
                        *** For more help see ***
                        *** https://github.com/ioBroker/ioBroker.docs ***
                        Your environment has been set up for using Node.js 10.16.3 (ia32) and npm.
                        C:\IoB Testsysteme\ioBroker>iobroker status
                        iobroker is not running
                        Objects type: file
                        States type: file
                        C:\IoB Testsysteme\ioBroker>iobroker update
                        Used repository: latest
                        hash changed => force download of new sources
                        update done
                        Adapter "admin" : 3.7.1 , installed 3.7.1
                        Adapter "alexa2" : 2.6.4 , installed 2.6.4
                        Adapter "alpha2" : 1.0.0
                        Adapter "amazon-dash" : 0.3.1
                        Adapter "artnet" : 1.0.0
                        Adapter "asterisk" : 1.0.6
                        Adapter "asuswrt" : 1.0.1
                        Adapter "b-control-em" : 0.2.1
                        Adapter "backitup" : 1.3.0 , installed 1.2.2 [Updateable]
                        Adapter "beckhoff" : 1.1.0
                        Adapter "benq" : 0.2.0
                        Adapter "ble" : 0.10.1
                        Adapter "bmw" : 1.4.0
                        Adapter "boblight" : 0.0.1
                        Adapter "bosesoundtouch": 0.2.4
                        Adapter "botvac" : 1.0.0
                        Adapter "bring" : 1.6.6 , installed 1.6.6
                        Adapter "broadlink2" : 2.0.2
                        Adapter "bsblan" : 0.0.6
                        Adapter "bshb" : 0.0.14
                        Adapter "chromecast" : 2.3.1
                        Adapter "cloud" : 2.8.0 , installed 2.8.0
                        Adapter "comfoair" : 0.3.2
                        Adapter "contactid" : 1.0.0
                        Adapter "corrently" : 0.0.2
                        Adapter "countdown" : 1.0.4
                        Adapter "cul" : 1.0.0
                        Adapter "daikin" : 1.0.5
                        Adapter "daswetter" : 2.8.1 , installed 2.8.1
                        Adapter "deconz" : 1.1.2 , installed 1.1.2
                        Adapter "denon" : 1.7.1
                        Adapter "devices" : 0.1.8
                        Adapter "discovergy" : 0.4.9 , installed 0.4.9
                        Adapter "discovery" : 2.0.0 , installed 2.0.0
                        Adapter "doorbird" : 0.1.5
                        Adapter "ds18b20" : 1.1.0
                        Adapter "dwd" : 2.4.3 , installed 2.4.3
                        Adapter "ebus" : 0.8.2
                        Adapter "egigeozone" : 0.1.2
                        Adapter "ekey" : 1.1.0
                        Adapter "email" : 1.0.5 , installed 1.0.5
                        Adapter "emby" : 1.0.0
                        Adapter "energymanager" : 1.2.2
                        Adapter "enet" : 1.0.1
                        Adapter "epson_stylus_px830": 0.2.1
                        Adapter "fakeroku" : 0.2.1
                        Adapter "feiertage" : 1.0.11
                        Adapter "fhem" : 1.3.0
                        Adapter "find-my-iphone": 0.2.17
                        Adapter "firetv" : 0.0.33
                        Adapter "fitbit-api" : 0.1.1
                        Adapter "flot" : 1.9.2 , installed 1.9.2
                        Adapter "foobar2000" : 1.0.0
                        Adapter "fritzbox" : 0.2.1 , installed 0.2.1
                        Adapter "fritzdect" : 0.2.4 , installed 0.2.4
                        Adapter "fronius" : 1.0.5
                        Adapter "fullcalendar" : 0.2.4
                        Adapter "fullybrowser" : 1.0.1 , installed 1.0.1
                        Adapter "g-homa" : 0.5.1
                        Adapter "geofency" : 0.3.2
                        Adapter "gruenbeck" : 0.0.15
                        Adapter "habpanel" : 0.3.4
                        Adapter "haier" : 1.0.2
                        Adapter "ham" : 1.1.2
                        Adapter "ham-wemo" : 1.0.1
                        Adapter "harmony" : 1.2.2
                        Adapter "hass-mqtt" : 0.0.7
                        Adapter "heatingcontrol": 0.3.4
                        Adapter "heytech" : 0.1.9
                        Adapter "hid" : 0.1.17
                        Adapter "hilink" : 0.2.7
                        Adapter "history" : 1.8.7 , installed 1.8.7
                        Adapter "hm-rega" : 2.4.12
                        Adapter "hm-rpc" : 1.11.1
                        Adapter "hmip" : 0.0.11
                        Adapter "hombot" : 0.1.3
                        Adapter "homeconnect" : 0.0.26
                        Adapter "homee" : 0.3.1
                        Adapter "homepilot" : 1.0.3
                        Adapter "hp-ilo" : 1.0.5
                        Adapter "hs100" : 1.0.10
                        Adapter "hue" : 2.4.3
                        Adapter "hue-extended" : 1.1.6
                        Adapter "hyperion" : 0.0.9
                        Adapter "i2c" : 0.0.6
                        Adapter "ical" : 1.7.0 , installed 1.7.0
                        Adapter "icons-addictive-flavour-png": 0.1.0
                        Adapter "icons-fatcow-hosting": 0.1.0
                        Adapter "icons-icons8" : 0.0.1
                        Adapter "icons-material-png": 0.1.0 , installed 0.1.0
                        Adapter "icons-material-svg": 0.1.0 , installed 0.1.0
                        Adapter "icons-mfd-png" : 1.0.2
                        Adapter "icons-mfd-svg" : 1.0.2
                        Adapter "icons-open-icon-library-png": 0.1.3
                        Adapter "icons-ultimate-png": 1.0.1
                        Adapter "influxdb" : 1.6.3
                        Adapter "info" : 1.5.7 , installed 1.5.7
                        Adapter "innogy-smarthome": 0.3.3 , installed 0.3.3
                        Adapter "intesishome" : 0.1.2
                        Adapter "iogo" : 0.4.17
                        Adapter "iot" : 1.1.8 , installed 1.1.8
                        Adapter "iqontrol" : 0.2.14
                        Adapter "javascript" : 4.3.4 , installed 4.3.4
                        Adapter "jeelink" : 0.1.3
                        Controller "js-controller" : 2.1.1 , installed 1.5.14 [Updateable]
                        Adapter "js2fs" : 0.1.5
                        Adapter "kecontact" : 0.1.0
                        Adapter "klf200" : 0.9.5
                        Adapter "km200" : 2.0.3
                        Adapter "knmi-weather" : 0.1.1
                        Adapter "knx" : 1.0.36
                        Adapter "kodi" : 1.0.0
                        Adapter "kress" : 2.5.5
                        Adapter "lametric" : 0.0.6
                        Adapter "landroid" : 1.0.3
                        Adapter "lcn" : 0.4.2
                        Adapter "letrika_comgw" : 0.0.4
                        Adapter "lgtv" : 1.1.0
                        Adapter "lgtv-rs" : 0.0.4
                        Adapter "lgtv11" : 1.0.5
                        Adapter "lifx" : 0.1.0
                        Adapter "lightify" : 0.2.16
                        Adapter "link" : 0.4.9
                        Adapter "linkeddevices" : 1.0.1
                        Adapter "lovelace" : 0.2.3
                        Adapter "loxone" : 1.0.0
                        Adapter "luftdaten" : 0.0.9
                        Adapter "lupusec" : 1.2.0
                        Adapter "luxtronik1" : 0.1.0
                        Adapter "material" : 0.12.1
                        Adapter "maxcube" : 0.1.2
                        Adapter "maxcul" : 1.1.2
                        Adapter "mbus" : 2.0.0
                        Adapter "mclighting" : 0.0.12
                        Adapter "megad" : 1.2.1
                        Adapter "megadd" : 0.2.0
                        Adapter "megaesp" : 0.1.0
                        Adapter "mercedesme" : 0.0.16
                        Adapter "meross" : 1.0.0
                        Adapter "meteoalarm" : 1.0.8
                        Adapter "miele" : 0.1.5
                        Adapter "mihome" : 1.2.8
                        Adapter "mihome-airpurifier": 0.0.6
                        Adapter "mihome-lamp" : 1.1.0
                        Adapter "mihome-plug" : 0.2.0
                        Adapter "mihome-vacuum" : 1.1.5 , installed 1.1.5
                        Adapter "miio" : 0.0.13
                        Adapter "mikrotik" : 1.0.4
                        Adapter "milight" : 0.3.6
                        Adapter "milight-smart-light": 0.2.7
                        Adapter "mobile" : 0.5.0
                        Adapter "modbus" : 3.0.0
                        Adapter "moma" : 1.2.3
                        Adapter "mpd" : 1.0.2
                        Adapter "mqtt" : 2.1.1
                        Adapter "mqtt-client" : 1.2.1
                        Adapter "multicast" : 0.1.1
                        Adapter "musiccast" : 0.1.2
                        Adapter "mysensors" : 2.0.0
                        Adapter "nanoleaf-lightpanels": 0.8.2
                        Adapter "nello" : 2.0.8
                        Adapter "netatmo" : 1.3.1
                        Adapter "nibeuplink" : 0.3.0
                        Adapter "nina" : 0.0.13
                        Adapter "node-red" : 1.13.0
                        Adapter "nuki" : 1.1.2
                        Adapter "nuki-extended" : 2.0.3
                        Adapter "nut" : 1.1.3
                        Adapter "odl" : 1.0.1
                        Adapter "oilfox" : 1.0.1
                        Adapter "onkyo" : 2.0.3
                        Adapter "onvif" : 0.0.2
                        Adapter "openhab" : 1.1.0
                        Adapter "opentherm" : 0.1.9
                        Adapter "openweathermap": 0.1.0
                        Adapter "opi" : 0.1.1
                        Adapter "oppoplayer" : 0.2.1
                        Adapter "owfs" : 0.6.1
                        Adapter "owntracks" : 0.6.2
                        Adapter "panasonic-viera": 1.0.2
                        Adapter "parser" : 1.0.7
                        Adapter "paw" : 0.3.2
                        Adapter "phantomjs" : 1.0.1
                        Adapter "pi-hole" : 1.2.2
                        Adapter "piface" : 1.0.0
                        Adapter "pimatic" : 0.1.5
                        Adapter "ping" : 1.3.2 , installed 1.3.2
                        Adapter "places" : 0.7.0
                        Adapter "plex" : 0.8.4
                        Adapter "plexconnect" : 0.0.7
                        Adapter "pollenflug" : 1.0.4
                        Adapter "primelab" : 1.0.2
                        Adapter "proxmox" : 0.5.1
                        Adapter "proxy" : 1.1.1 , installed 1.1.1
                        Adapter "pushbullet" : 0.0.11
                        Adapter "pushover" : 1.1.1
                        Adapter "pushsafer" : 0.1.8
                        Adapter "radar2" : 1.0.9
                        Adapter "radiohead" : 1.0.2
                        Adapter "rflink" : 2.0.0 , installed 2.0.0
                        Adapter "rickshaw" : 1.0.0
                        Adapter "ring" : 1.0.5
                        Adapter "roadtraffic" : 0.0.2
                        Adapter "roomba" : 1.0.7 , installed 1.0.7
                        Adapter "rpi2" : 1.1.1
                        Adapter "s7" : 1.1.4
                        Adapter "samsung" : 0.2.9
                        Adapter "sayit" : 1.8.2
                        Adapter "sbfspot" : 2.3.4
                        Adapter "scenes" : 1.1.0
                        Adapter "schoolfree" : 0.3.1
                        Adapter "shelly" : 3.1.1
                        Adapter "shuttercontrol": 0.4.1
                        Adapter "sia" : 1.0.3
                        Adapter "siegenia" : 1.0.0
                        Adapter "simple-api" : 2.3.2
                        Adapter "sma-em" : 0.5.6
                        Adapter "smappee" : 0.2.2
                        Adapter "smartmeter" : 1.2.2
                        Adapter "snips" : 1.5.0
                        Adapter "snmp" : 0.5.0
                        Adapter "socketio" : 2.1.2 , installed 2.1.2
                        Adapter "solarlog" : 1.0.0
                        Adapter "solarwetter" : 1.0.0
                        Adapter "sonnen" : 1.3.0
                        Adapter "sonoff" : 2.3.2 , installed 2.3.2
                        Adapter "sonos" : 2.0.1
                        Adapter "sonus" : 0.1.1
                        Adapter "sony-bravia" : 1.0.1
                        Adapter "sourceanalytix": 0.2.5 , installed 0.2.281
                        Adapter "spotify-premium": 1.0.0 , installed 1.0.0
                        Adapter "sql" : 1.9.5
                        Adapter "squeezebox" : 1.0.0
                        Adapter "squeezeboxrpc" : 0.8.18
                        Adapter "starline" : 1.0.0
                        Adapter "statistics" : 0.2.2
                        Adapter "stiebel-isg" : 1.4.10
                        Adapter "stockmarket" : 0.0.2
                        Adapter "synology" : 0.0.4
                        Adapter "systeminfo" : 0.3.1
                        Adapter "tado" : 0.1.3
                        Adapter "tankerkoenig" : 2.0.6 , installed 2.0.6
                        Adapter "telegram" : 1.4.3 , installed 1.4.3
                        Adapter "terminal" : 0.1.2
                        Adapter "text2command" : 1.3.0
                        Adapter "tileboard" : 0.1.1
                        Adapter "tinker" : 0.1.4
                        Adapter "tino" : 0.1.1
                        Adapter "tinyrx4" : 0.1.4
                        Adapter "tr-064" : 0.4.18 , installed 0.4.18
                        Adapter "tradfri" : 2.4.7
                        Adapter "tunnelbroker-endpoint-updater": 0.0.1
                        Adapter "tuya" : 3.0.0
                        Adapter "tvspielfilm" : 1.0.4
                        Adapter "unifi" : 0.3.1
                        Adapter "upnp" : 1.0.14
                        Adapter "valloxmv" : 1.0.0
                        Adapter "vcard" : 0.0.9
                        Adapter "vedirect" : 0.1.0
                        Adapter "viessmann" : 1.2.3
                        Adapter "viessmannapi" : 1.3.2
                        Adapter "virtualpowermeter": 1.0.1
                        Adapter "vis" : 1.2.2 , installed 1.2.2
                        Adapter "vis-bars" : 0.1.4
                        Adapter "vis-canvas-gauges": 0.1.5 , installed 0.1.5
                        Adapter "vis-colorpicker": 1.1.1
                        Adapter "vis-fancyswitch": 1.1.0
                        Adapter "vis-google-fonts": 0.1.0
                        Adapter "vis-history" : 1.0.0 , installed 1.0.0
                        Adapter "vis-hqwidgets" : 1.1.3 , installed 1.1.3
                        Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12
                        Adapter "vis-justgage" : 1.0.2 , installed 1.0.2
                        Adapter "vis-keyboard" : 0.0.2
                        Adapter "vis-lcars" : 1.0.4
                        Adapter "vis-map" : 1.0.2
                        Adapter "vis-material" : 0.1.3
                        Adapter "vis-materialdesign": 0.2.4
                        Adapter "vis-metro" : 1.1.2
                        Adapter "vis-players" : 0.1.5
                        Adapter "vis-plumb" : 1.0.2 , installed 1.0.2
                        Adapter "vis-rgraph" : 0.0.2
                        Adapter "vis-timeandweather": 1.1.7 , installed 1.1.7
                        Adapter "vis-weather" : 2.4.0 , installed 2.4.0
                        Adapter "vr200" : 1.0.0
                        Adapter "weatherunderground": 3.1.6
                        Adapter "web" : 2.4.10 , installed 2.4.10
                        Adapter "weishaupt-wem" : 0.0.6
                        Adapter "wetty" : 0.1.1
                        Adapter "wiffi-wz" : 2.1.4
                        Adapter "wifilight" : 0.2.0
                        Adapter "wlanthermo-nano": 0.1.1
                        Adapter "wm-bus" : 0.3.1
                        Adapter "wolf" : 0.9.2
                        Adapter "worx" : 0.4.0
                        Adapter "xbox" : 0.5.10
                        Adapter "xs1" : 1.0.2
                        Adapter "yahka" : 0.9.2
                        Adapter "yamaha" : 0.3.19
                        Adapter "yeelight-2" : 1.0.1
                        Adapter "youtube" : 0.0.2
                        Adapter "yr" : 2.0.3
                        Adapter "zigbee" : 0.11.5
                        Adapter "zoneminder" : 0.3.3
                        Adapter "zont" : 0.5.3
                        Adapter "zwave" : 1.7.0
                        Adapter "zwave2" : 0.2.1
                        C:\IoB Testsysteme\ioBroker>iobroker upgrade self
                        Update js-controller from @1.5.14 to @2.1.1
                        NPM version: 6.9.0
                        npm install iobroker.js-controller@2.1.1 --unsafe-perm --production --save --prefix "C:/IoB Testsysteme/ioBroker" (System call)
                        gyp ERR! build error
                        gyp ERR! stack Error: C:\Program Files\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe failed with exit code: 1
                        gyp ERR! stack at ChildProcess.onExit (C:\IoB Testsysteme\ioBroker\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:262:23)
                        gyp ERR! stack at ChildProcess.emit (events.js:198:13)
                        gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                        gyp ERR! System Windows_NT 10.0.17763
                        gyp ERR! command "C:\IoB Testsysteme\ioBroker\nodejs\node.exe" "C:\IoB Testsysteme\ioBroker\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "rebuild"
                        gyp ERR! cwd C:\IoB Testsysteme\ioBroker\node_modules\iobroker.js-controller\node_modules\unix-dgram
                        gyp ERR! node -v v10.16.3
                        gyp ERR! node-gyp -v v3.8.0
                        gyp ERR! not ok
                        (node:4652) UnhandledPromiseRejectionWarning: ParserError: Protocol error, got "H" as reply type byte. Please report this.
                        at handleError (C:\IoB Testsysteme\ioBroker\node_modules\iobroker.js-controller\node_modules\redis-parser\lib\parser.js:190:15)
                        at parseType (C:\IoB Testsysteme\ioBroker\node_modules\iobroker.js-controller\node_modules\redis-parser\lib\parser.js:304:14)
                        (node:4652) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
                        (node:4652) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                        (node:4652) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules\iobroker.js-controller\node_modules\fsevents):
                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"ia32"})
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.2 (node_modules\iobroker.js-controller\node_modules\unix-dgram):
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.2 install: node-gyp rebuild
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                        Host "iobroker(ioBroker)" (win32) updated
                        Starting node restart.js
                        C:\IoB Testsysteme\ioBroker>iobroker start
                        2019-11-23 14:29:17,410 INFO - Starting the service with id 'iobroker(ioBroker)'
                        Allerdings gibt es auch einige Warn und Error Meldungen die ich nicht recht verstehe. Da es dabei aber um gyp geht, vermute ich mal das dass auch die Ursache dafür ist, das ich CANVAS für den iRobot Adapter nicht installiert bekomme. Wie ich das heilen kann, weiß ich aber nicht.
                        Ich werde jetzt nochmal einen Versuch unternehmen und den automatischen Install Prozess via WindowsInstaller durchführen - ich melde mich dann nochmal.
                        • StabilostickS Stabilostick
                          JB_SullivanJ
                          JB_SullivanJ
                          JB_Sullivan
                          #990
                          @Stabilostick sagte in js-controller 2.0 ab sofort im Latest Repo:
                          Wie lange dauert das üblicher Weise bis das zur Verfügung steht? Habe es eben versucht, aber da wir noch latest (im Dateinamen) herunter geladen .
                          • JB_SullivanJ
                            JB_SullivanJ
                            JB_Sullivan
                            #991
                            So, jetzt war es die passende Version. Aktuell läuft der Adapter Vergleich / Installationsprozess. Hier das LOG File von der ioB Installation - für den Fall das dass für dich von Interesse ist. Auch hier wird ein Fehler von MS Visual Studio angezeigt - das hängt glaube ich auch mit gyp bzw. CANVAS zusammen.
                            Log started 11/23/2019 at 15:21:46
                            Preferred installation mode : win32
                            Trying to init installer in mode win32
                            Mode win32 successfully initialized
                            [15:21:47] Instance list: 'ioBroker Prod'
                            [15:21:47] msiexec.exe version found: 5.0
                            [15:21:47] Microsft .NET release: 528049
                            [15:21:47] Git version found: 2.24.0.2
                            [15:21:47] Bonjour version found: 3.0.0.10
                            [15:21:47] OpenSSL version found: 1.0.2.17
                            [15:21:47] VS_BuildTools_2017: vswhere.exe not found
                            Executing certutil.exe -decode "C:\Users\SmartHome\AppData\Local\Temp\jq.txt" "C:\Users\SmartHome\AppData\Local\Temp\jq.exe"
                            Script exit code: 0
                            Script output:
                            Eingabelänge = 3728172
                            Ausgabelänge = 2711358
                            CertUtil: -decode-Befehl wurde erfolgreich ausgeführt.
                            Script stderr:
                            iobroker.json
                            Executing jq.exe type "C:\IoB Testsysteme\ioBroker\iobroker-data\iobroker.json" | find /v /c ""
                            Script exit code: 0
                            Script output:
                            Script stderr:
                            Setting variable multihostService from jq.exe -r .multihostService.enabled "C:\IoB Testsysteme\ioBroker\iobroker-data\iobroker.json"
                            Script exit code: 0
                            Script output:
                            false
                            Script stderr:
                            Setting variable objectstype from jq.exe -r .objects.type "C:\IoB Testsysteme\ioBroker\iobroker-data\iobroker.json"
                            Script exit code: 0
                            Script output:
                            file
                            Script stderr:
                            Setting variable statestype from jq.exe -r .states.type "C:\IoB Testsysteme\ioBroker\iobroker-data\iobroker.json"
                            Script exit code: 0
                            Script output:
                            file
                            Script stderr:
                            objects.json
                            Executing jq.exe type "C:\IoB Testsysteme\ioBroker\iobroker-data\objects.json" | find /v /c ""
                            Script exit code: 0
                            Script output:
                            Script stderr:
                            states.json
                            Executing jq.exe type "C:\IoB Testsysteme\ioBroker\iobroker-data\states.json" | find /v /c ""
                            Script exit code: 0
                            Script output:
                            Script stderr:
                            Config
                            Setting variable mighostname from jq.exe -r ".|with_entries(select(.key|contains("system.host.")))|.[].common.hostname | select(.==null|not)" "C:\IoB Testsysteme\ioBroker\iobroker-data\objects.json"
                            Script exit code: 0
                            Script output:
                            iobroker(ioBroker)
                            Script stderr:
                            Setting variable port_admin from jq.exe -r ."system.adapter.admin.0".native.port "C:\IoB Testsysteme\ioBroker\iobroker-data\objects.json"
                            Script exit code: 0
                            Script output:
                            8081
                            Script stderr:
                            Setting variable oldnode_version from jq.exe -r ".|with_entries(select(.key|contains("system.host.")))|.[].native.process.versions.node | select(.==null|not)" "C:\IoB Testsysteme\ioBroker\iobroker-data\objects.json"
                            Script exit code: 0
                            Script output:
                            10.16.3
                            Script stderr:
                            Setting variable winsw_id from jq.exe -r ".|with_entries(select(.key|contains("system.host.")))|.[].native.process.env.WINSW_SERVICE_ID | select(.==null|not)" "C:\IoB Testsysteme\ioBroker\iobroker-data\objects.json"
                            Script exit code: 0
                            Script output:
                            iobroker(ioBroker)
                            Script stderr:
                            Setting variable port_objects from jq.exe -r .objects.port "C:\IoB Testsysteme\ioBroker\iobroker-data\iobroker.json"
                            Script exit code: 0
                            Script output:
                            9001
                            Script stderr:
                            Setting variable port_states from jq.exe -r .states.port "C:\IoB Testsysteme\ioBroker\iobroker-data\iobroker.json"
                            Script exit code: 0
                            Script output:
                            9000
                            Script stderr:
                            Bereite die Installation vor
                            Executing powershell.exe -inputformat none -outputformat none -NonInteractive -Command "Add-MpPreference -ExclusionPath 'C:\IoB Testsysteme\SmartHome'"
                            Script exit code: 0
                            Script output:
                            Script stderr:
                            Erstelle Verzeichnis C:\IoB Testsysteme\SmartHome\setup
                            Entpacke Dateien
                            Verbinden mit Remoteserver
                            Connecting to remote server
                            250 KB heruntergeladen. Geschwindigkeit: 0 KB/s. Verbleibende Zeit: (warten)
                            500 KB heruntergeladen. Geschwindigkeit: 0 KB/s. Verbleibende Zeit: (warten)
                            750 KB heruntergeladen. Geschwindigkeit: 0 KB/s. Verbleibende Zeit: (warten)
                            1000 KB heruntergeladen. Geschwindigkeit: 0 KB/s. Verbleibende Zeit: (warten)
                            1250 KB heruntergeladen. Geschwindigkeit: 0 KB/s. Verbleibende Zeit: (warten)
                            1251 KB heruntergeladen. Geschwindigkeit: 0 KB/s. Verbleibende Zeit: (warten)
                            Das Verzeichnis existiert bereits: C:\IoB Testsysteme\SmartHome\setup
                            Entpacke Dateien
                            Entpacke C:\IoB Testsysteme\SmartHome\setup\python27.exe
                            Entpacke Dateien
                            Entpacke C:\IoB Testsysteme\SmartHome\setup\nodepack.exe
                            Erstelle Verzeichnis C:\IoB Testsysteme\SmartHome\nodejs
                            Entpacke Dateien
                            Entpacke C:\IoB Testsysteme\SmartHome\nodejs\node.exe
                            Entpacke Dateien
                            Entpacke C:\IoB Testsysteme\SmartHome\setup\iob.exe
                            Erstelle Verzeichnis C:\IoB Testsysteme\SmartHome\setup\patch
                            Erstelle Verzeichnis C:\IoB Testsysteme\SmartHome\setup\patch\daemon
                            Erstelle Verzeichnis C:\IoB Testsysteme\SmartHome\setup\patch\nodejs
                            Erstelle Verzeichnis C:\IoB Testsysteme\SmartHome\setup\patch\node_modules
                            Erstelle Verzeichnis C:\IoB Testsysteme\SmartHome\setup\patch\node_modules\iobroker.js-controller
                            Erstelle Verzeichnis C:\IoB Testsysteme\SmartHome\setup\patch\node_modules\iobroker.js-controller\conf
                            Erstelle Verzeichnis C:\IoB Testsysteme\SmartHome\setup\patch\setup
                            Entpacke Dateien
                            Entpacke C:\IoB Testsysteme\SmartHome\setup\patch\setup\subinacl.exe
                            Entpacke C:\IoB Testsysteme\SmartHome\setup\patch\iob.bat
                            Entpacke C:\IoB Testsysteme\SmartHome\setup\patch\iobroker.bat
                            Entpacke C:\IoB Testsysteme\SmartHome\setup\patch\serviceIoBroker.bat
                            Entpacke C:\IoB Testsysteme\SmartHome\setup\patch\daemon\iobroker.xml
                            Entpacke C:\IoB Testsysteme\SmartHome\setup\patch\nodejs\nodevars.bat
                            Entpacke C:\IoB Testsysteme\SmartHome\setup\patch\node_modules\iobroker.js-controller_service_iobroker.bat
                            Entpacke C:\IoB Testsysteme\SmartHome\setup\patch\node_modules\iobroker.js-controller\conf\iobroker-dist.json
                            Entpacke C:\IoB Testsysteme\SmartHome\setup\patch\setup\servicesec.cmd
                            Entpacke C:\IoB Testsysteme\SmartHome\setup\patch\setup\setupfirst.cmd
                            Microsoft VisualStudio BuildTools 2017 - Download und Installation von bis zu 1.4GB Daten
                            Executing cmd.exe /C vs_buildtools.exe --wait --norestart --quiet --cache --includeRecommended --add Microsoft.VisualStudio.Workload.VCTools --add Microsoft.VisualStudio.Workload.NodeBuildTools
                            Script exit code: 1
                            Script output:
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\HelpFile\1028\help.html...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\HelpFile\2052\help.html...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\HelpFile\1055\help.html...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\HelpFile\1046\help.html...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\HelpFile\1042\help.html...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\HelpFile\1029\help.html...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\HelpFile\1036\help.html...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\HelpFile\3082\help.html...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\HelpFile\1040\help.html...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\HelpFile\1031\help.html...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\HelpFile\1045\help.html...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\HelpFile\1033\help.html...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\HelpFile\1041\help.html...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\HelpFile\1049\help.html...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\vs_setup_bootstrapper.exe...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\Microsoft.Diagnostics.Tracing.EventSource.dll...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\Microsoft.VisualStudio.RemoteControl.dll...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\Microsoft.VisualStudio.Setup.Common.dll...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\Microsoft.VisualStudio.Setup.Configuration.Interop.dll...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\Microsoft.VisualStudio.Setup.dll...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\Microsoft.VisualStudio.Setup.Download.dll...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\Microsoft.VisualStudio.Setup.Engine.dll...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\Microsoft.VisualStudio.Telemetry.dll...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\Microsoft.VisualStudio.Utilities.Internal.dll...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\Newtonsoft.Json.dll...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\zh-Hans\vs_setup_bootstrapper.resources.dll...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\zh-Hant\vs_setup_bootstrapper.resources.dll...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\es\vs_setup_bootstrapper.resources.dll...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\pt-BR\vs_setup_bootstrapper.resources.dll...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\cs\vs_setup_bootstrapper.resources.dll...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\tr\vs_setup_bootstrapper.resources.dll...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\de\vs_setup_bootstrapper.resources.dll...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\fr\vs_setup_bootstrapper.resources.dll...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\it\vs_setup_bootstrapper.resources.dll...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\pl\vs_setup_bootstrapper.resources.dll...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\ko\vs_setup_bootstrapper.resources.dll...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\ja\vs_setup_bootstrapper.resources.dll...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\ru\vs_setup_bootstrapper.resources.dll...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\vs_setup_bootstrapper.config...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\vs_setup_bootstrapper.exe.config...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\detection.json...
                            Preparing: C:\Users\SMARTH~1\AppData\Local\Temp\f479c7d96fa5d24917cb34f5c9\vs_bootstrapper_d15\vs_setup_bootstrapper.json...
                            Script stderr:
                            Program ended with an error exit code
                            Fehler beim Ausführen cmd.exe /C vs_buildtools.exe --wait --norestart --quiet --cache --includeRecommended --add Microsoft.VisualStudio.Workload.VCTools --add Microsoft.VisualStudio.Workload.NodeBuildTools: Program ended with an error exit code
                            [15:23:02] VS BuildTools 2017 already installed but wrong version? Doing nothing.
                            Python 2.7.17
                            Python 2.7.17
                            Executing python27.exe -o... -y
                            Script exit code: 0
                            Script output:
                            7-Zip SFX 19.00 (x86) : Copyright (c) 1999-2018 Igor Pavlov : 2019-02-21
                            Extracting archive: C:\IoB Testsysteme\SmartHome\setup\python27.exe
                            Path = C:\IoB Testsysteme\SmartHome\setup\python27.exe
                            Type = 7z
                            0%
                            20% 131
                            65% 131
                            69% 298 - python27\Lib\Cookie.py
                            69% 473 - python27\Lib\dummy_thread.py
                            69% 664 - python27\Lib\encodings\utf_32_le.py
                            69% 833 - python27\Lib\json\tests\test_recursion.py
                            69% 1014 - python27\Lib\nntplib.py
                            69% 1207 - python27\Lib\test\decimaltestdata\ddCopy.decTest
                            69% 1402 - python27\Lib\test\string_tests.py
                            69% 1603 - python27\Lib\test\test_iterlen.py
                            69% 1802 - python27\Lib\test\test_wave.py
                            69% 2002 - python27\tcl\tcl8.5\encoding\iso2022-jp.enc
                            69% 2165 - python27\tcl\tcl8.5\msgs\vi.msg
                            69% 2371 - python27\tcl\tcl8.5\tzdata\America\Santa_Isabel
                            69% 2582 - python27\tcl\tcl8.5\tzdata\Etc\GMT-2
                            69% 2794 - python27\tcl\tix8.4.3\bitmaps\drop.xbm
                            69% 3002 - python27\tcl\tix8.4.3\Select.tcl
                            69% 3163 - python27\tcl\tk8.5\text.tcl
                            69% 3299 - python27\DLLs\bz2.pyd
                            Everything is Ok
                            Script stderr:
                            Installiere Microsoft Visual C++ 2008 Redistributable
                            Executing vcredist_x86.exe /q
                            Script exit code: 0
                            Script output:
                            Script stderr:
                            Node.js 10.17.0
                            Node.js 10.17.0
                            Executing nodepack.exe -o... -y
                            Script exit code: 0
                            Script output:
                            Extracting archive: C:\IoB Testsysteme\SmartHome\setup\nodepack.exe
                            Path = C:\IoB Testsysteme\SmartHome\setup\nodepack.exe
                            Type = 7z
                            0%
                            0% 468 - nodejs\node_modules\npm\node_modules\mute-stream
                            0% 727 - nodejs\node_modules\npm\node_modules\socks-proxy-agent\node_modules
                            64% 910
                            99% 1024 - nodejs\node_modules\npm\html\doc\cli\npm-dedupe.html
                            99% 1225 - nodejs\node_modules\npm\lib\stars.js
                            99% 1423 - nodejs\node_modules\npm\node_modules\ajv\lib\dot\definitions.def
                            99% 1616 - nodejs\node_modules\npm\node_modules\bcrypt-pbkdf\CONTRIBUTING.md
                            99% 1812 - nodejs\node_modules\npm\node_modules\co\History.md
                            99% 2007 - nodejs\node_modules\npm\node_modules\decamelize\license
                            99% 2188 - nodejs\node_modules\npm\node_modules\es-abstract\package.json
                            99% 2375 - nodejs\node_modules\npm\node_mo . lib\internal\streams\destroy.js
                            99% 2573 - nodejs\node_modules\npm\node_m . odules\get-stream\package.json
                            99% 2774 - nodejs\node_modules\npm\node_mo . -ci\node_modules\ci-info\LICENSE
                            99% 2963 - nodejs\node_modules\npm\node_mo . ONStream\test\destroy_missing.js
                            99% 3164 - nodejs\node_modules\npm\node_modules\libnpx\locales\ko.json
                            99% 3365 - nodejs\node_modules\npm\node_modules\move-concurrently\move.js
                            99% 3557 - nodejs\node_modules\npm\node_mo . node_modules\resolve.travis.yml
                            99% 3735 - nodejs\node_modules\npm\node_mo . npropertydescriptors.npmignore
                            99% 3936 - nodejs\node_modules\npm\node . _modules\retry\test\common.js
                            99% 4137 - nodejs\node_modules\npm\node_modules\read-package-tree\package.json
                            99% 4338 - nodejs\node_modules\npm\node_modules\socks-proxy-agent\yarn.lock
                            99% 4535 - nodejs\node_modules\npm\node_ . odules\ansi-regex\package.json
                            99% 4734 - nodejs\node_modules\npm\node_mo . que-filename\coverage\index.html
                            99% 4913 - nodejs\node_modules\npm\node_modules\y18n\package.json
                            99% 5110 - nodejs\node_modules\npm\test\tap\debug-logs.js
                            99% 5313 - nodejs\node_modules\npm\test\tap\uninstall-link-clean.js
                            Everything is Ok
                            Script stderr:
                            Konfiguriere Node.js 10.17.0
                            ioBroker Core Server
                            Executing iob.exe -o... -y
                            Script exit code: 0
                            Script output:
                            Extracting archive: C:\IoB Testsysteme\SmartHome\setup\iob.exe
                            Path = C:\IoB Testsysteme\SmartHome\setup\iob.exe
                            Type = 7z
                            0%
                            0% 406 - env\npm-cache_cacache\content-v2\sha1\df\60
                            0% 848 - env\npm-cache_cacache\content-v2\sha512\5f
                            0% 1301 - env\npm-cache_cacache\content-v2\sha512\ca
                            0% 1737 - env\npm-cache_cacache\index-v5\1b\ed
                            0% 2145 - env\npm-cache_cacache\index-v5\51\57
                            0% 2449 - env\npm-cache_cacache\index-v5\7b\25
                            0% 2870 - env\npm-cache_cacache\index-v5\af\35
                            0% 3342 - env\npm-cache_cacache\index-v5\ee\47
                            0% 3771
                            0% 4299 - node_modules\is-binary-path
                            0% 4715
                            0% 5106
                            20% 5106
                            28% 5106
                            48% 5106
                            64% 5106
                            68% 5106
                            75% 5106
                            99% 5151 - env\npm-cache_cacache\content- . 7ffe05c77e64e7c86e4cd94bf0e1228a
                            99% 5334 - env\npm-cache_cacache\content- . 168aadc40e57d97e81191ac8f4398b3e
                            99% 5485 - env\npm-cache_cacache\content- . 547ee26a3d748e9bbb43c9ab3439221
                            99% 5646 - env\npm-cache_cacache\content- . d4d1fed418ca01e804e3b0d5d8bfd5c
                            99% 5788 - env\npm-cache_cacache\content- . 837537201445ceb5d8fa4aee0d490f6
                            99% 5811 - env\npm-cache_cacache\content- . fca689d86be201b858cb770b2d7345d
                            99% 5969 - env\npm-cache_cacache\content- . e1e93042149152264891e26ce76f8b2
                            99% 6127 - env\npm-cache_cacache\content- . 1268816e92c18fe0668e38f97729032
                            99% 6276 - env\npm-cache_cacache\index- . 328f8a971b3e1f2ffb06a00853fa19
                            99% 6468 - env\npm-cache_cacache\index- . bb550d2ad726b8e9822f1ca03d43ca
                            99% 6663 - env\npm-cache_cacache\index- . c2ede80d4c125b53e47d094e28ab0a
                            99% 6853 - env\npm-cache_cacache\index- . ee4937216e574d0c9be964ae91d319
                            99% 7041 - env\npm-cache_cacache\index- . 1c619f209ce9c788f08b63e968a880
                            99% 7213 - env\npm-cache_cacache\index- . 7cb564b9f7bd0268d2bbebe3dc8bef
                            99% 7373 - env\npm-cache_cacache\index- . 6230edf9bb8d009afcd390842d613a
                            99% 7556 - env\npm-cache_cacache\index- . 83dada091a3da9c1ec1f5d49a51c9c
                            99% 7728 - env\npm-cache_cacache\index- . 7b8afcd3d470b78c309e98003147f5
                            99% 7924 - env\npm-cache_cacache\index- . 5fd61e208da290ea03b345e98054fa
                            99% 8117 - env\npm\node_modules\node-gyp\node_modules\ajv\lib\dotjs\anyOf.js
                            99% 8315 - env\npm\node_modules\node-gyp\n . les\extsprintf\lib\extsprintf.js
                            99% 8486 - env\npm\node_modules\node-gyp\node_modules\isstream\package.json
                            99% 8684 - env\npm\node_modules\node-gyp\node_modules\psl\index.js
                            99% 8879 - env\npm\node_modules\node-gyp\node_modules\tweetnacl\CHANGELOG.md
                            99% 9083 - node_modules.bin\sshpk-conv.ps1
                            99% 9293 - node_modules\ajv\package.json
                            99% 9513 - node_modules\async\during.js
                            99% 9728 - node_modules\binary-extensions\index.d.ts
                            99% 9911 - node_modules\cluster-key-slot\lib\index.js
                            99% 10126 - node_modules\decache\decache.d.ts
                            99% 10326 - node_modules\eckles\fixtures\pub-ec-p256.spki.pem
                            99% 10537 - node_modules\expand-template\test.js
                            99% 10745 - node_modules\form-data\README.md
                            99% 10960 - node_modules\has-binary\README.md
                            99% 11320 - node_modules\iobroker.discovery\lib\adapters\rflink.js
                            99% 11777 - node_modules\iobroker.info\widgets\info.html
                            99% 11972 - node_modules\iobroker.js-con . .io\lib\transports\polling.js
                            99% 12162 - node_modules\iobroker.js-contro . _modules\yargs\lib\validation.js
                            99% 12350 - node_modules\is-nan\README.md
                            99% 12527 - node_modules\jszip\lib\signature.js
                            99% 12717 - node_modules\le-store-certbot\LICENSE
                            99% 12933 - node_modules\lodash\fp\curryRightN.js
                            99% 13148 - node_modules\lodash\fp\propOr.js
                            99% 13346 - node_modules\lodash\isRegExp.js
                            99% 13520 - node_modules\lodash\valueOf.js
                            99% 13739 - node_modules\lodash_Hash.js
                            99% 13959 - node_modules\mime-db\HISTORY.md
                            99% 14168 - node_modules\moment\locale\nl.js
                            99% 14370 - node_modules\moment\src\locale\gd.js
                            99% 14580 - node_modules\node-forge\lib\form.js
                            99% 14787 - node_modules\object-hash\test\writeToStream.js
                            99% 14926 - node_modules\passport-local\lib\strategy.js
                            99% 15123 - node_modules\prompt-checkbox\LICENSE
                            99% 15326 - node_modules\qs\lib\index.js
                            99% 15536 - node_modules\require-directory.travis.yml
                            99% 15744 - node_modules\serialport\node_modules\debug\node.js
                            99% 15949 - node_modules\source-map\dist\source-map.min.js
                            99% 16157 - node_modules\tar-fs\test\fixtures\a\hello.txt
                            99% 16325 - node_modules\unpipe\README.md
                            99% 16536 - node_modules\window-size\utils.js
                            99% 16728 - node_modules\yargs-parser\index.js
                            Everything is Ok
                            Script stderr:
                            Setting ioBroker language
                            Language de
                            [15:23:33] Installer Sprachcode: de
                            ioBroker Sprache gesetzt auf: de
                            ioBroker Währung gesetzt auf: €
                            Datenbankinstallation und Erstkonfiguration
                            Executing cmd.exe /C setup\setupfirst.cmd
                            Script exit code: 0
                            Script output:
                            *** ioBroker bootstrap setup ***
                            *** Version: 2.1.0.b
                            *** Installdate: 23.11.2019 15:23:33.98
                            ** Firewall rules
                            ** There is no problem if the following commands generate errors.
                            ** Now errors are relevant
                            OK.
                            OK.
                            OK.
                            OK.
                            ** iobroker first init
                            ** set admin port
                            New port for "admin.0" is: 8081
                            Instance settings for "admin.0" are changed.
                            ** install service
                            2019-11-23 15:24:30,353 INFO - Installing the service with id 'iobroker(SmartHome)'
                            Errorlevel: 0
                            Script stderr:
                            Service Sicherheit
                            Executing sc.exe config iobroker(SmartHome) obj= "NT SERVICE\iobroker(SmartHome)"
                            Script exit code: 0
                            Script output:
                            [SC] ChangeServiceConfig ERFOLG
                            Script stderr:
                            Registrierung ioBroker Service
                            Executing iobroker.exe test
                            Script exit code: 0
                            Script output:
                            2019-11-23 15:24:31,529 INFO - Starting "C:\IoB Testsysteme\SmartHome\nodejs\node.exe" "C:\IoB Testsysteme\SmartHome\node_modules\iobroker.js-controller\controller.js"
                            2019-11-23 15:24:31,546 INFO - Started process 6012
                            2019-11-23 15:24:32,577 INFO - Stopping iobroker(SmartHome)
                            2019-11-23 15:24:32,577 INFO - Stopping process 6012
                            2019-11-23 15:24:32,577 INFO - Send SIGINT 6012
                            2019-11-23 15:24:34,838 INFO - SIGINT to 6012 successful
                            2019-11-23 15:24:34,870 INFO - Finished iobroker(SmartHome)
                            Script stderr:
                            Dateisystem Sicherheit
                            Executing cmd.exe /C servicesec.cmd
                            Script exit code: 0
                            Script output:
                            i o b r o k e r ( S m a r t H o m e ) : n e w a c e f o r n t s e r v i c e \ i o b r o k e r ( s m a r t h o m e )
                            i o b r o k e r ( S m a r t H o m e ) : 1 c h a n g e ( s )
                            Script stderr:
                            Starten des Dienstes
                            Executing iobroker.exe start
                            Script exit code: 0
                            Script output:
                            2019-11-23 15:24:41,466 INFO - Starting the service with id 'iobroker(SmartHome)'
                            Script stderr:
                            Warte auf Webadmin
                            Löschen temporärer Dateien
                            Stopping ioBroker service
                            Executing iobroker.exe stop
                            Script exit code: 0
                            Script output:
                            2019-11-23 15:24:43,854 INFO - Stopping the service with id 'iobroker(SmartHome)'
                            Script stderr:
                            Waiting for service to exit
                            Deleting iobroker-data
                            Copying new iobroker-data
                            Setting variable iobrokerjson_new from jq.exe .states.port=9000 "C:\IoB Testsysteme\ioBroker\iobroker-data\iobroker.json"
                            Script exit code: 0
                            Script output:
                            "system": {
                            "memoryLimitMB": 0,
                            "hostname": "iobroker(ioBroker)",
                            "statisticsInterval": 15000,
                            "statisticsIntervalComment": "Interval how often the counters for input/output in adapters and controller will be updated"
                            "multihostService": {
                            "enabled": false,
                            "secure": true
                            "network": {
                            "IPv4": true,
                            "IPv6": true,
                            "bindAddress": null
                            "objects": {
                            "type": "file",
                            "typeComment": "Possible values: 'file' - [port 9001], redis - [port 6379], couch - [port 5984].",
                            "host": "127.0.0.1",
                            "port": 9001,
                            "user": "",
                            "pass": "",
                            "noFileCache": false,
                            "connectTimeout": 2000,
                            "backup": {
                            "disabled": false,
                            "files": 24,
                            "filesComment": "Minimal number of backup files, after the deletion will be executed according to backupTime settings",
                            "hours": 48,
                            "hoursComment": "All backups older than 48 hours will be deleted. But only if the number of files is greater than of backupNumber",
                            "period": 120,
                            "periodComment": "by default backup every 2 hours. Time is in minutes. To disable backup set the value to 0",
                            "path": "",
                            "pathComment": "Absolute path to backup directory or empty to backup in data directory"
                            "options": {
                            "auth_pass": null,
                            "retry_max_delay": 5000
                            "states": {
                            "type": "file",
                            "typeComment": "Possible values: 'file' - [port 9000], 'redis' - [port 6379].",
                            "port": 9000,
                            "maxQueue": 1000,
                            "options": {
                            "auth_pass": null,
                            "backup": {
                            "disabled": false,
                            "files": 24,
                            "hours": 48,
                            "period": 120,
                            "path": "",
                            "log": {
                            "level": "info",
                            "maxDays": 7,
                            "noStdout": true,
                            "transport": {
                            "file1": {
                            "type": "file",
                            "enabled": true,
                            "filename": "log/iobroker",
                            "fileext": ".log",
                            "maxsize": null,
                            "maxFiles": null
                            "syslog1": {
                            "type": "syslog",
                            "enabled": false,
                            "host": "localhost",
                            "host_comment": "The host running syslogd, defaults to localhost.",
                            "port_comment": "The port on the host that syslog is running on, defaults to syslogd's default port(514/UDP).",
                            "protocol": "udp4",
                            "protocol_comment": "The network protocol to log over (e.g. tcp4, udp4, unix, unix-connect, etc).",
                            "path_comment": "The path to the syslog dgram socket (i.e. /dev/log or /var/run/syslog for OS X).",
                            "facility_comment": "Syslog facility to use (Default: local0).",
                            "localhost": "iobroker",
                            "localhost_comment": "Host to indicate that log messages are coming from (Default: localhost).",
                            "sysLogType_comment": "The type of the syslog protocol to use (Default: BSD).",
                            "app_name_comment": "The name of the application (Default: process.title).",
                            "eol_comment": "The end of line character to be added to the end of the message (Default: Message without modifications)."
                            "dataDirComment": "Always relative to iobroker.js-controller/",
                            "dataDir": "../../iobroker-data/"
                            Script stderr:
                            Setting variable iobrokerjson_new from jq.exe .objects.port=9001 "C:\IoB Testsysteme\ioBroker\iobroker-data\iobroker.json"
                            Script exit code: 0
                            Script output:
                            "system": {
                            "memoryLimitMB": 0,
                            "enabled": false,
                            "secure": true
                            "network": {
                            "IPv4": true,
                            "IPv6": true,
                            "bindAddress": null
                            "objects": {
                            "type": "file",
                            "port": 9001,
                            "user": "",
                            "pass": "",
                            "backup": {
                            "disabled": false,
                            "files": 24,
                            "hours": 48,
                            "period": 120,
                            "path": "",
                            "options": {
                            "auth_pass": null,
                            "states": {
                            "type": "file",
                            "port": 9000,
                            "maxQueue": 1000,
                            "options": {
                            "auth_pass": null,
                            "backup": {
                            "disabled": false,
                            "files": 24,
                            "hours": 48,
                            "period": 120,
                            "path": "",
                            "log": {
                            "level": "info",
                            "maxDays": 7,
                            "noStdout": true,
                            "transport": {
                            "file1": {
                            "type": "file",
                            "enabled": true,
                            "fileext": ".log",
                            "maxsize": null,
                            "maxFiles": null
                            "syslog1": {
                            "type": "syslog",
                            "enabled": false,
                            "protocol": "udp4",
                            Script stderr:
                            Change settings
                            Executing cmd.exe /c migrate.cmd
                            Script exit code: 0
                            Script output:
                            Script stderr:
                            Script exit code: 0
                            Script output:
                            2019-11-23 15:26:49,596 INFO - Starting the service with id 'iobroker(SmartHome)'
                            Script stderr:
                            Warte auf Webadmin
                            Installation beendet
                            Log finished 11/23/2019 at 15:26:54
                            Launching http://localhost:8081
                            • JB_SullivanJ
                              JB_SullivanJ
                              JB_Sullivan
                              #992
                              Jetzt sind wir bei dem Abgleich der Adapter genau da, wo wir die ganzen Tage auch waren.
                              Es wird ein js-controller stopped gemeldet und es wird nicht mehr weiter überprüft, bzw. aktualisiert. Das führt scheinbar auch dazu, das der web Adapter von seiner ursprünglichen Version 4.7.10 auf 4.7.8 zurückgesetzt wurde. Daraufhin erscheint eine Fehlermeldung bzgl. der Kompatibilität der aktuellen Version.
                              Genau das war auch das Problem bei meinen ganzen Versuchen in Lauf der letzten Woche.
                              LogFile.txt <- Achtung ist grooooooß
                              Versucht man dann den Web Adapter auf 4.7.10 upzudaten kommt es zu folgender Meldung
                              $ ./iobroker upgrade web
                              ERROR: No objects found!
                              ERROR: process exited with code 101
                              Da es ja eh nicht mehr weiter geht, habe ich diese Installationsinstanz gestoppt und wollte sie nochmal manuell updaten, da ja auch angezeigt wurde das js-controller mit der Version 2.1.1 zu Verfügung steht.
                              Alles brav gestoppt wie immer und versucht upzudaten. Leider dieses mal mit dem Ergebniss, das nix mehr geht.
                              Your environment has been set up for using Node.js 10.17.0 (ia32) and npm.
                              C:\IoB Testsysteme\SmartHome>iobroker stop
                              2019-11-23 16:00:16,620 INFO  - Stopping the service with id 'iobroker(SmartHome)'
                              2019-11-23 16:00:16,635 FATAL - WMI Operation failure: ServiceCannotAcceptControl
                              WMI.WmiException: ServiceCannotAcceptControl
                                 bei WMI.WmiRoot.BaseHandler.CheckError(ManagementBaseObject result)
                                 bei WMI.WmiRoot.InstanceHandler.Invoke(Object proxy, MethodInfo method, Object[] args)
                                 bei WMI.Win32ServiceProxy.StopService()
                                 bei winsw.WrapperService.Run(String[] _args, ServiceDescriptor descriptor)
                                 bei winsw.WrapperService.Main(String[] args)
                              C:\IoB Testsysteme\SmartHome>iobroker status
                              No objects found!
                              C:\IoB Testsysteme\SmartHome>iobroker update
                              No objects found!
                              C:\IoB Testsysteme\SmartHome>iobroker upgrade self
                              No objects found!
                              Ein erneuter Versuch den Dienst wieder zu starten wurde mit der folgenden Fehlermeldung quittiert. Also bin ich heute genauso weit gekommen wie die ganzen Tage.
                              • MathiasJM
                                MathiasJM
                                MathiasJ
                                schrieb am zuletzt editiert von MathiasJ
                                #993
                                Das nächste Problem hat sich erledigt.
                                PAW Instanz und App auf dem Raspberry PI4 und dem Tablet deinstalliert,
                                IP des Tablets neu vergeben und beides neu installiert.
                                Im Moment läuft es
                                PAW läuft, es werden bim JS-Controller 2.1.1 keine Objekte angelegt.
                                IObroker auf dem NUC als VM.
                                • MathiasJM MathiasJ
                                  Im Moment läuft es
                                  apollon77A
                                  apollon77A
                                  #994
                                  @MathiasJ bitte issue beim Adapter anlegen bzw falls es eins gibt da Infos rein.
                                  MathiasJM 1 Antwort Letzte Antwort
                                    MathiasJM
                                    MathiasJM
                                    MathiasJ
                                    #995
                                    @apollon77
                                    gerade passiert......
                                    Anscheinend sind die bei paw in Verbindung mit dem JS-Controller noch in der Testphase.
                                      A
                                      A
                                      aleks-83
                                      #996
                                      Das würde mich auch interessieren.
                                      Aber auch:
                                      Wie kann man eine ioBroker Installation unter Windows updaten?
                                      Einfach den neuen Installer starten?
                                      = Dell Optiplex Micro - 10GB RAM - 200GB SSD - Debian VM =
                                      = Node.js v22.22.2 = NPM 10.9.7 = JS Controller 7.2.5 =
                                      Ubiquiti UAP-AC-LR - UAP-AC-Lite - Synology DS716+II - Fritz!Box 7490
                                      Glasfaser 400
                                      • A aleks-83
                                        Aber auch:
                                        sigi234S
                                        sigi234S
                                        #997
                                        @aleks-83 sagte in js-controller 2.0 ab sofort im Latest Repo:
                                        Jupp, und migrieren.
                                        JB_SullivanJ A 2 Antworten Letzte Antwort
                                        • sigi234S sigi234
                                          JB_SullivanJ
                                          JB_SullivanJ
                                          JB_Sullivan
                                          #998
                                          @sigi234 sagte in js-controller 2.0 ab sofort im Latest Repo:
                                          Wenn es denn geht ; ) Ich habe es jetzt, nach weiteren Fehlversuchen (siehe oben) aufgegeben. Da ich mir eh eine NUC holen will, werde ich dann auf einem frischen System nochmal einen neuen Anlauf unternehmen.
                                          Kann man sich für so einem Fall eigentlich die alte IoB Installation auf einen Stick ziehen und dann von da aus als Migration Ordner iobroker-data Quelle auswählen?
                                          BBTownB 1 Antwort Letzte Antwort
                                          33.2k
                                          84.3k
