  4. Test Adapter enigma2 v1.2.x
adapterenigma2
640 Beiträge 71 Kommentatoren 272.5k Aufrufe 60 Beobachtet
  • GlasfaserG Glasfaser
    @XBiT
    Widget
    [{"tpl":"tplMfdSocketCtrl","data":{"oid":"javascript.0.Datenpunkt.Dreambox","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"asButton":true,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"iconColor_on":"#13fe0b","icon_on":"/vis.0/picon/{enigma2.0.enigma2.CHANNEL_SERVICEREFERENCE_NAME}.png","icon_off":"/vis.0/Wohnen/-Samsung-UE49MU9009-aus.jpg","invert_icon":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","min":"false","max":"true","name":"Fernseher"},"style":{"left":"59px","top":"559px","width":"147px","height":"89px","z-index":"10","border-width":"4px","border-style":"inset","border-color":"blue","border-radius":"5px","font-family":"Jura-DemiBold","font-size":"14px"},"widgetSet":"jqui-mfd"}]
    XBiTX
    XBiTX
    XBiT
    #125
    @Glasfaser 👍
    Danke, du kopierst also die Picons nochmal in den ioBroker und nimmst sie nicht direkt von der e2Box
    Aber das geht ja auch so oft ändern die sich ja nicht habe ich noch gar nicht dran gedacht.
    Matten MattenM 2 Antworten Letzte Antwort
    • XBiTX XBiT
      @Glasfaser 👍
      Matten MattenM
      Matten MattenM
      Matten Matten
      #126
      @XBiT
      Doch von der Box geht das auch wenn du das openwebif nutzt. Ich muss Mal schauen wie der Pfad war....😑
      ioBroker auf Beelink mit WIN10 home|CCU3 (Raspberrymatic)|Neato BotVac D3|HYPERION Ambilight auf RPI3 und RPI ZeroW|HA-Bridge|Milight LED|Nodered&Redmatic|VU Duo2 & Solo se V2
      • XBiTX XBiT
        @Glasfaser 👍
        Matten MattenM
        Matten MattenM
        Matten Matten
        #127
        @XBiT
        http://192.168.0.1:80/picon/1_0_19_2B5C_41B_1_FFFF014A_0_0_0.png
        XBiTX L 2 Antworten Letzte Antwort
        • Matten MattenM Matten Matten
          @XBiT
          XBiTX
          XBiTX
          XBiT
          #128
          @Matten-Matten said in Test Adapter enigma2 v1.2.x:
          Danke so hatte ich mir das Vorgestellt über PiconManager neue Picons drauf machen und gleich synchron mit der Vis
          Matten MattenM 1 Antwort Letzte Antwort
          • XBiTX XBiT
            Matten MattenM
            Matten MattenM
            Matten Matten
            #129
            @XBiT
            Ich hätte es ja gerne in den Adapter integriert, jedoch nutzt nicht jeder das openwebif. Was ja auch völlig okay ist, nur beim dreamwebif funktioniert der Aufruf nicht. Dort kann man das so leider nicht machen.
            Matten Matten
            • L
              L
              LJSven
              #130
              Hast du eine Idee für mein Problem?
              • L LJSven
                Matten MattenM
                Matten MattenM
                Matten Matten
                #131
                @LJSven sagte in Test Adapter enigma2 v1.2.x:
                Da musst du dich gedulden, zurzeit bin ich im Urlaub.
                • Matten MattenM
                  Matten MattenM
                  Matten Matten
                  #132
                  Neue Version
                  Bild Text
                  Bild Texthttps://github.com/Matten-Matten/ioBroker.enigma2.git
                  Changelog
                  1.2.5 (2019-11-17)
                  • (Scrounger) add: .enigma2.Timer_list #25 (Merge pull request #28)
                  Großen Dank an Scrounger!
                  Matten Matten
                  NegaleinN ScroungerS 2 Antworten Letzte Antwort
                    Neue Version
                    Bild Text
                    Changelog
                    1.2.5 (2019-11-17)
                    Matten Matten
                    NegaleinN
                    NegaleinN
                    Negalein
                    #133
                    @Matten-Matten sagte in Test Adapter enigma2 v1.2.x:
                    Neue Version
                    läuft 😊
                    ° Fixer ---> iob fix
                      Neue Version
                      Bild Text
                      Changelog
                      1.2.5 (2019-11-17)
                      Matten Matten
                      ScroungerS
                      ScroungerS
                      Scrounger
                      schrieb am zuletzt editiert von Scrounger
                      #134
                      1.2.5 (2019-11-17)
                      Damit kann man mit meiner Table des Material Design Wigdets Adapter ein ganz schickes Widget realisieren:
                      Skript um Daten aufzubereiten:
                      // import
                      const moment = require("moment");
                      const momentDurationFormatSetup = require("moment-duration-format");
                      moment.locale("de");
                      let enigma2AdapterTimerListId = 'enigma2.0.enigma2.Timer_list';
                      on({ id: enigma2AdapterTimerListId }, formatList);
                      function formatList() {
                          try {
                              let list = JSON.parse(getState(enigma2AdapterTimerListId).val);
                              let myList = [];
                              if (list && list !== null && list !== undefined && list !== '') {
                                  for (var i = 0; i <= list.length - 1; i++) {
                                      let listItem = list[i]
                                      let startTime = moment(listItem.starTime * 1000);
                                      let endTime = moment(listItem.endTime * 1000);
                                      let recordDateFormatted = `${startTime.format('ddd')} ${startTime.format('DD.MM')}`
                                      let starTimeFormatted = `${startTime.format('LT')}`
                                      let endTimeFormatted = `${endTime.format('LT')}`
                                      if (moment().isSame(startTime, 'day')) {
                                          recordDateFormatted = `Heute ${startTime.format('DD.MM')}`;
                                      } else if (moment().add(1, 'day').isSame(startTime, 'day')) {
                                          recordDateFormatted = `Morgen ${startTime.format('DD.MM')}`;
                                      let rawtitle = listItem.title;
                                      let title = rawtitle;
                                      let subtitle = listItem.subtitle;
                                      if (title.includes(' - ')) {
                                          title = rawtitle.substring(0, rawtitle.indexOf(' - ')).trim();
                                          if (subtitle === '') {
                                              subtitle = rawtitle.substring(rawtitle.indexOf(' - ') + 2, rawtitle.length).trim();
                                      myList.push(
                                              channelImage: `/vis.0/myImages/picons/${listItem.serviceRefName}.png`,
                                              title: title,
                                              recordDateFormatted: recordDateFormatted,
                                              subtitle: subtitle,
                                              starTimeFormatted: starTimeFormatted,
                                              startTime: listItem.starTime,
                                              endTimeFormatted: endTimeFormatted,
                                              channel: listItem.channel,
                                  myList.sort(function (a, b) {
                                      // Liste sortieren nach Startzeit
                                      return a.starTime == b.starTime ? 0 : +(a.starTime > b.starTime) || -1;
                              myDevices.Netzwerk.Devices.VuPlus.TimerList.setState(JSON.stringify(myList), true);
                          } catch (err) {
                              console.error(`[createList] error: ${err.message}`);
                              console.error(`[createList] stack: ${err.stack}`);
                      formatList();
                      Widget:
                      [{"tpl":"tplVis-materialdesign-Table","data":{"oid":"linkeddevices.0.Netzwerk.Devices.VuPlus.TimerList","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","countCols":"2","tableLayout":"standard","showHeader":"true","headerTextSize":"11","showColumn0":"true","colType0":"image","textAlign0":"center","showColumn1":"true","colType1":"text","textAlign1":"left","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"showColumn2":"true","colType2":"text","textAlign2":"right","showColumn3":"true","colType3":"text","textAlign3":"center","imageSize0":"50","sortKey1":"channel","showColumn4":"true","colType4":"text","textAlign4":"center","showColumn5":"true","colType5":"text","textAlign5":"center","showColumn6":"true","colType6":"text","textAlign6":"center","showColumn7":"true","colType7":"text","textAlign7":"center","showColumn8":"true","colType8":"text","textAlign8":"center","label0":"Kanal","label1":"Aufnahme","label2":"Zeit","padding_left0":"6","colorHeaderRowText":"#ffffff","colorRowBackground":"","colorHeaderRowBackground":"#44739e","headerFontFamily":"RobotoCondensed-Regular","rowHeight":"","suffix1":"<br>\n<span style=\"display: inline-block; white-space: nowrap; overflow: hidden !important; text-overflow: ellipsis; max-width: 170px; font-size: 12px; font-family: RobotoCondensed-LightItalic; color: #8a8a8a\">#[obj.subtitle]</span>\n","textSize1":"14","fontFamily1":"RobotoCondensed-Regular","textColor1":"#44739e","padding_right0":"6","padding_left1":"0","sortKey0":"channel","sortKey2":"startTime","fontFamily2":"RobotoCondensed-LightItalic","textSize2":"11px","suffix2":"<br>\n<span style=\"display: inline-block; white-space: nowrap; overflow: hidden !important; max-width: 150px; font-size: 12px; font-family: RobotoCondensed-LightItalic; color: #8a8a8a\">#[obj.starTimeFormatted] - #[obj.endTimeFormatted]</span>\n","padding_left2":"0","padding_right1":"0","textColor2":"#44739e"},"style":{"left":"667px","top":"16px","width":"340px","height":"372px","overflow-y":"auto"},"widgetSet":"materialdesign"}]
                      Zur Info ich hab die Channel picons lokal abgelegt, da meine Box nicht immer läuft.
                      Ihr könnt aber im Skript natürlich auch das verwenden:
                      GlasfaserG K 2 Antworten Letzte Antwort
                      • ScroungerS Scrounger
                        1.2.5 (2019-11-17)
                        // import
                            try {
                                let myList = [];
                                        myList.push(
                                                title: title,
                                                subtitle: subtitle,
                            } catch (err) {
                        formatList();
                        Widget:
                        GlasfaserG
                        GlasfaserG
                        #135
                        @Scrounger sagte in Test Adapter enigma2 v1.2.x:
                        } catch (err) {
                        Hast du da ein Fehler drin !?
                        ist das nicht so :
                        setState("myDevices.Netzwerk.Devices.VuPlus.TimerList",JSON.stringify(myList), true);
                        ScroungerS 1 Antwort Letzte Antwort
                          } catch (err) {
                          ist das nicht so :
                          ScroungerS
                          ScroungerS
                          Scrounger
                          #136
                          @Glasfaser
                          Ne alles richtig. Sowas geht mit dem meinem linkedDevices Adapter. Damit kann man sich automatisch Variablen erzeugen lassen.
                          Wenn du z.B. mit ner IDE deine Skripte schreibst, dann werden diese erzeugten Variablen entsprechend vorgeschlagen. Vorteil man muss nicht immer die Id's sich einzeln raus suchen.
                          • E
                            E
                            eve11
                            #137
                            Hallo zusammen, ich habe schon seit über einen Jahr den Enigma Adapter nicht mit einem Update versehen. (Never change a running system :-) ) Jetzt habe ich von der alten version 1.1.0 auf die aktuellste Version upgedatet. Nun habe ich natürlich ein Problem.
                            Log:
                            enigma2.0	2019-11-24 14:02:44.335	info	(594) enigma2: 192.168.178.33:80 ist nicht erreichbar
                            enigma2.0	2019-11-24 14:02:47.098	info	(594) enigma2 Verbunden
                            Wie ihr sehen könnt, verliert der Adapter kurz die Verbindung zur VU Box.
                            Da ich an das Ein-und Ausschalten gewisse Aktionen gebunden habe, werden diese natürlich jetzt ausgelöst.
                            Wie kann ich dieses Problem angehen ? Kann ich irgendwo die alten Versionen downloaden ?
                            Die Node.js und der js-controller sind jeweils auf dem aktuellen Stand.
                            Vielen Dank für eure Hilfe.
                            eve11
                            • C
                              C
                              ChrisXY
                              schrieb am zuletzt editiert von ChrisXY
                              #138
                              Selbst schon verstanden ;)
                              • C ChrisXY
                                J
                                J
                                Jan1
                                #139
                                @ChrisXY
                                Da hast recht, ist ne dumme Frage.
                                Erstens weil der Adapter Enigma2 heißt und das nicht die Version des Adapter ist sondern das OS des Sat Receiver und zweitens steht gleich im ersten Post das Changelog des Adapter 😊
                                • J Jan1
                                  @ChrisXY
                                  NegaleinN
                                  NegaleinN
                                  Negalein
                                  #140
                                  @Jan1 sagte in Test Adapter enigma2 v1.2.x:
                                  Ähhhh sorry, aber es gibt KEINE dummen Fragen !!
                                  • NegaleinN Negalein
                                    J
                                    J
                                    Jan1
                                    #141
                                    @Negalein
                                    Doch, hatte er ja schon selber bemerkt und wo er recht hat, hat er recht 😉
                                    • B
                                      B
                                      BlueEssi
                                      #142
                                      Ich habe in einem anderen Thread gelesen, dass es parallel zum Enigma2-Adapter noch einen VU+-Adapter gibt. Dieser scheint nicht mehr weiter entwickelt zu werden, hat aber eine Erweiterung zur Steuerung von Enigmalight integriert. Wäre es möglich, diese Erweiterung für den Enigma2-Adapter zu übernehmen?
                                      E Matten MattenM 2 Antworten Letzte Antwort
                                      • B BlueEssi
                                        E
                                        E
                                        el_malto
                                        #143
                                        @BlueEssi
                                        Ich denke das wird schwierig. Der Adapter hier soll ja "universal" sein, also für jedes Image. Soweit ich weiß, läuft Enigmalight nur mit dem VTi Image.
                                        • E el_malto
                                          @BlueEssi
                                          J
                                          J
                                          Jan1
                                          #144
                                          Enigma Light läuft auf der Box als Plugin, warum sollte man das im Adapter noch steuern können? Da erschließt sich mir der Sinn nicht, da das an oder aus ist.
                                          Das läuft übrigens bei mir auf der DM900 mit der original FW OS2.5, ist halt ne Dream und keine VU😎
                                          84.2k
