  4. Test js-controller v2.0.x (GitHub)
js-controller
1.0k Beiträge 48 Kommentatoren 429.8k Aufrufe 35 Beobachtet
    msauer
    schrieb am zuletzt editiert von msauer
    #977
    wenn ich Files mit "iobroker file write file.png 0_userdata.0/files/icons/" (Schreibweise richtig?) schreibe, wo finde ich die denn im VIS Explorer?
    Proxmox 3 Node HA-Cluster Mini-PC N150 mit 32 GB RAM und 3x1TB shared SSDs via Linstor. VM- iobroker ,OpenCCU / LXC - Adguard, Traccar, iSpy, Fileserver (emby, MiniDLNA)...etc.
    • M msauer
      #978
      @msauer sagte in Test js-controller v2.0.x (GitHub):
      Unter /0_userdata.0/files/icons/
      • apollon77A apollon77
        Hallo an die Beta-Tester-Runde ... wir sind noch nicht ganz fertig ;-)
        Ich habe heute (vorab, bevor es später ins Latest kommt) für Euch auf GitHub die 2.0.40 (Aka Stable-RC1). Es sind noch viele Kleinigkeiten eingeflossen:
        2.0.40 (2019-11-08) Release Bella RC1
        • (Apollon77) make sure multiple instances of same adapter do not disturb each other in compact mode, finalize compact mode
        • (AlCalzone) correctly handle git commits and branches as custom install sources
        • (Apollon77) make sure callbacks with setImmediate return the rela values from code execution and not pot. changed values from other actions (fixing file content being undefined when write/read happen in parallel)
        • (Apollon77) handle more cases for aliases automatically (On/Ein is converted to true case insensitive now)
        • (bluefox) getForeignStates() return correct ids when used with aliases
        • (Apollon77) optimize controller group stopping
        • (Apollon77) when target state is deleted also emit "null" onChange events to adapters for alias states
        • (Apollon77) optimize controller stop behaviour with compact groups
        • (Apollon77) make sure that schedules instances can start even after a "once" run that set a sigKill value
        • (Apollon77) add method to synchronize file directories with file DB storage
          • add new CLI command "iobroker file sync <id>" to do the sync
          • integrate the sync with "iobroker setup first"
        Vor allem der letzte Punkt könnte interessant sein für die die immer noch eigene Files in offizielle Verzeichnisse reinkopiert haben. Beim Install dieser Version daher bitte mal auf die Ausgaben von nom (nach dem "node iobroker.js setup first") achten, was da so kommt.
        Bin gespannt ob es tut habe es natürlich nur bei mir testen können bisher.
        Files in offiziellen Verzeichnissen werden gesynct, Eigene Verzeichnisse werden "angemeckert", aber nicht gesynct (gibt ja nichts definiertes wohin).
        Ingo
        darkiop
        #979
        @apollon77 sagte in Test js-controller v2.0.x (GitHub):
        Läuft hier, werde beobachten übers WE :)
        Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
        • D darkiop
          sigi234S Online
          sigi234S Online
          #980
          @darkiop sagte in Test js-controller v2.0.x (GitHub):
          Welche Version hast du?
          • sigi234S sigi234
            darkiop
            #981
            @sigi234 sagte in Test js-controller v2.0.x (GitHub):
            Die 2.0.40 - aufm master + slave
            • apollon77A Offline
              #982
              Die 2.0.40 sollte inzwischen auch im latest kommen.
              E 1 Antwort Letzte Antwort
                msauer
                #983
                @apollon77 hii...1...das Icon von gestern ist jetzt im Dateimanager zu sehen, komisch...nun habe ich versucht mehrere Dateien zu kopieren. Das scheint nicht zu gehen..ok, dachte ich, dann einzeln...also Befehl "iobroker file write /tmp/thermo/control_minus.png 0_userdata.0/files/icons/thermo/" abgesetzt...Also Antwort kam dann "File "/tmp/thermo/control_minus.png" stored as "files/icons/thermo/"..Im Dateimanager ist aber nichts zu sehen... auch refresh hilft nicht...
                Wie kann ich den eine ganze Gruppe von Dateien, wenn es denn geht, kopieren?
                Mark
                • coyoteC Offline
                  coyoteC Offline
                  coyote
                  #984
                  Update auf 2.0.40 gemacht, keine Fehler im Log, alle Adapter grün. Sieht soweit gut aus👍
                    Einstein67
                    #985
                    @apollon77 said in Test js-controller v2.0.x (GitHub):
                    Jaaa da hab ich sie gefunden ;) Installation hat funktioniert, IoBroker läuft perfekt wie immer! ABER das stoppen vom IoBroker dauert bei mir nun so um die 90 Sekunden!
                    2019-11-09 13:40:00.972  - info: host.iob12b instance system.adapter.admin.0 terminated with code 156 (156)
                    2019-11-09 13:40:00.974  - info: host.iob12b instance system.adapter.pi-hole.0 terminated with code 156 (156)
                    2019-11-09 13:40:00.977  - info: host.iob12b instance system.adapter.netatmo.0 terminated with code 156 (156)
                    2019-11-09 13:40:00.980  - info: host.iob12b instance system.adapter.yeelight-2.0 terminated with code 156 (156)
                    2019-11-09 13:40:00.987  - info: host.iob12b instance system.adapter.javascript.0 terminated with code 156 (156)
                    2019-11-09 13:40:00.989  - info: host.iob12b instance system.adapter.web.0 terminated with code 156 (156)
                    2019-11-09 13:40:01.001  - info: host.iob12b instance system.adapter.history.0 terminated with code 156 (156)
                    2019-11-09 13:40:01.458  - info: host.iob12b stopInstance system.adapter.sonoff.0 killing pid 2064
                    2019-11-09 13:40:01.459  - info: host.iob12b stopInstance system.adapter.backitup.0 killing pid 2087
                    2019-11-09 13:40:01.463  - warn: host.iob12b instance system.adapter.sonoff.0 terminated due to SIGTERM
                    2019-11-09 13:40:01.464  - info: host.iob12b instance system.adapter.sonoff.0 terminated with code null ()
                    2019-11-09 13:40:01.464  - warn: host.iob12b instance system.adapter.backitup.0 terminated due to SIGTERM
                    2019-11-09 13:40:01.464  - info: host.iob12b instance system.adapter.backitup.0 terminated with code null ()
                    2019-11-09 13:40:01.464  - info: host.iob12b All instances are stopped.
                    Also nach "All Instances are stopped" dauert es 90s bis man auf der Konsole wieder was eingeben kann. Was könnte denn das für ein Problem sein?
                    • E Einstein67
                      Jan1
                      #986
                      @Einstein67
                      Kann ich bestätigen, hatte mal den Beelink durch booten wollen und der zeigt mit an was beim Restart passiert. Da hat er ewig beim Stoppen vom IOBroke rum gerödelt, was vorher deutlich schneller lief.
                      apollon77A 2 Antworten Letzte Antwort
                      • M msauer
                        Mark
                        #987
                        @msauer gib mal bei dem Kommando beim ziel auch den Dateinamen am Ende an. Nicht nur den Pfad. Ich schau beim Kommando nochmal.
                        • J Jan1
                          @Einstein67
                          #988
                          @Jan1 Interessant, nutzt Ihr Compact Mode?
                          J E 2 Antworten Letzte Antwort
                            Jan1
                            #989
                            @apollon77
                            Ja und da auch endlich für Telegramm ohne Probleme
                              Einstein67
                              #990
                              Ich hab den Compact Mode mal getestet (hat auch problemlos funktioniert), aber mittlerweile ist der Modus "disabled".
                                Marty56
                                #991
                                @apollon77
                                Wäre es eigentlich möglich, dass in dem iobroker list instances Befehl auch gelistet wird, ob der Adapter überhaupt den Compact Modus grundsätzlich unterstützt?
                                Sonst ist das immer ein Try und Error.
                                HW:NUC (16 GB Ram)
                                OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
                                • J Jan1
                                  @Einstein67
                                  #992
                                  @Jan1 gefunden. die 2.0.41 kommt heute bend
                                    Jan1
                                    #993
                                    @apollon77
                                    Wo ist Deine Kaffeekasse?
                                    • J Jan1
                                      @apollon77
                                      #994
                                      @Jan1 in meiner Signatur stehen beide ;-)
                                      J 2 Antworten Letzte Antwort
                                      • M Marty56
                                        @apollon77
                                        #995
                                        @Marty56 steht es doch. Tut es doch. Sobald compact an ist für den Host stet die Gruppe und aktiv dabei wenn der Adapter es kann.
                                          #996
                                          2.0.41 auf GitHub und npm (latest dannn auch abhängig von Cache-Zeiten bald).
                                          Das Stop-Handling ist wieder gefixt und Zertifikate wurden verbessert:
                                          2.0.41 (2019-11-08) Release Bella Stable-RC2
                                          • (Stabilostick) enhance certificate methods and add certificate checks in setup first
                                          • (Stabilostick) add iobroker cert view <name> CLI command
                                          • (Apollon77) fix problems in stop controller handling
