  4. Nach Umzug auf Pi4, Probleme mit Zigbee und ble
zigbee adapter cc2531ble adapter
39 Beiträge 6 Kommentatoren 3.9k Aufrufe 3 Beobachtet
  • H Henrik
    bin mit Backitup vom Pi3 zum Pi4 gewechselt. Soweit läuft auch alles. Hab nur Probleme mit
    Zigbee Adaper siehe Log:
    host.ioBroker-RasPi4
    2019-11-09 12:28:28.264
    error
    instance system.adapter.zigbee.0 terminated with code 1 ()
    error
    Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    error
    Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
    error
    Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/serialport/lib/bindings/linux.js:2:36)
    error
    Caught by controller[0]: at bindings (/opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:81:44)
    error
    Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
    error
    Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
    error
    Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    error
    Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    error
    Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
    2019-11-09 12:28:28.263
    error
    Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)
    error
    Caught by controller[0]: the module (for instance, using npm rebuild or npm install).
    error
    Caught by controller[0]: NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
    error
    Caught by controller[0]: NODE_MODULE_VERSION 57. This version of Node.js requires
    error
    Caught by controller[0]: was compiled against a different Node.js version using
    error
    Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/serialport/build/Release/serialport.node'
    error
    Caught by controller[0]: ^
    error
    Caught by controller[0]: throw e
    error
    Caught by controller[0]: /opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:88
    2019-11-09 12:28:27.678
    info
    instance system.adapter.zigbee.0 started with pid 28740
    2019-11-09 12:27:57.664
    info
    Restart adapter system.adapter.zigbee.0 because enabled
    Scheint irgendwie ein Versionskonflikt??
    Auch der ble Adapter bleibt rot.
    Log:
    Kann jemand helfen?
    BBTownB Offline
    BBTownB Offline
    BBTown
    @Henrik-Regen dein Beitrag ist nicht vernünftig lesbar, bitte packe die Logs in "code-Tags"
    H 1 Antwort Letzte Antwort
    • J Jan1
      @Henrik-Regen
      welches Backup wurde verwendet?
      Henrik
      @BBTown
      Vollständiges Backup
      • H Henrik
        @BBTown
        Jan1
        @Henrik-Regen
        Wie gut das es das in der nächsten Version von Backitup nicht mehr gibt.
        Das ist Dein Fehler.
        • BBTownB BBTown
          Henrik
          @BBTown
          Stell mich irgendwie zu doof an das Log vernünftig zu kopieren. :-(
          • J Jan1
            @Henrik-Regen
            Henrik
            @Jan1
            Soll heißen: alles noch mal mit dem Minimal Backup, Richtig?
            • H Henrik
              @Jan1
              Jan1
              @Henrik-Regen
              genau, wobei alles eigentlich nur aus löschen vom Ordner IObroker ist und ab da neu
              Wird aber gefühlt mindesten ein mal am Tag gefragt und der Entwickler des Backitup Adapter hat darauf reagiert und entfernt das Komplettbackup aus dem Adapter.
              • J Jan1
                @Henrik-Regen
                Henrik
                @Jan1
                Kann ich das Minimal Backup einfach draufbügeln?
                • H Henrik
                  @Jan1
                  Jan1
                  @Henrik-Regen
                  ja, für das ist es ja da 😊
                  • J Jan1
                    @Henrik-Regen
                    Henrik
                    @Jan1
                    Okay, wird gleich probiert.
                    • H Henrik
                      @Jan1
                      Jan1
                      @Henrik
                      dauert aber recht lange, weil alle Adapter neu installiert werden
                      • J Jan1
                        @Henrik
                        Henrik
                        @Jan1
                        Was ist jetzt?
                        permission denied
                        Hab jetzt keine Rechte um auf das Verzechnis mit Filezilla zu schreiben.
                        • H Henrik
                          @Jan1
                          Was ist jetzt?
                          permission denied
                          Jan1
                          @Henrik
                          Fixer mal laufen lassen und wo willst DU mit Filzilla was machen?
                          Vorgehensweise ist ohne Filzilla beim Rückspielen.
                          • J Jan1
                            @Henrik
                            Henrik
                            @Jan1
                            Hab mein Pi3 Backup auf dem Windows PC gesichert. Wollte ich auf den Pi4 draufspielen.
                            Was ist Fixer?
                            • H Henrik
                              @Jan1
                              Was ist Fixer?
                              Jan1
                              @Henrik
                              Such mal hier im Board danach.
                              OK, wenn Du von Windows auf Linux kommst, dann kennst den Fixer nicht, wobei dann eigentlich klar gewesen sein sollte, dass das komplett Backup nie funktionieren kann.
                              Die Frage was Du mit Filezilla machen willst, ist aber immer noch nicht beantwortet.
                              • J Jan1
                                @Henrik
                                Henrik
                                @Jan1
                                Mit Filezilla wollte ich einfach nur die Backup Datei auf den Pi kopieren.
                                • H Henrik
                                  @Jan1
                                  Jan1
                                  @Henrik
                                  Das kann man machen, aber genau um das zu vereinfachen gibts ja den Backitup Adapter. Den installierst und stellst die Einstellungen wieder, dann geht alles über den Adapter.
                                  paul53P H 2 Antworten Letzte Antwort
                                  • J Jan1
                                    @Henrik
                                    @Jan1 sagte:
                                    Auch der benötigt zum Restore eine Datei mit dem Backup.
                                      @Jan1 sagte:
                                      Jan1
                                      OK, ich gehe mal davon aus, dass das aufm NAS liegt und das kann der Adapter, wenn nicht eben was ich oben schon geschrieben habe.
                                      • J Jan1
                                        @Henrik
                                        Henrik
                                        @Jan1
                                        Ja, ich muß für die Erst-Wiederherstellung den Backitup irgendwie Zugang zur Backup Datei schaffen.
                                        Insofern will ich die Datei in das Backup Verzeichnis kopieren. Hat ja auch initial als iobroker
                                        noch jungfräulich war auch geklappt. Nur jetzt habe ich keine Schreibrechte mehr.
                                        H J 2 Antworten Letzte Antwort
                                        • H Henrik
                                          @Jan1
                                          Henrik
                                          @Henrik
                                          Ja, liegen auf er NAS nur da komme ich jetzt nicht drauf. Mountingproblem
