  4. Nach Umzug auf Pi4, Probleme mit Zigbee und ble
zigbee adapter cc2531ble adapter
39 Beiträge 6 Kommentatoren 3.9k Aufrufe 3 Beobachtet
  • H Offline
    Henrik
    bin mit Backitup vom Pi3 zum Pi4 gewechselt. Soweit läuft auch alles. Hab nur Probleme mit
    Zigbee Adaper siehe Log:
    host.ioBroker-RasPi4
    2019-11-09 12:28:28.264
    error
    instance system.adapter.zigbee.0 terminated with code 1 ()
    error
    Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    error
    Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
    error
    Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/serialport/lib/bindings/linux.js:2:36)
    error
    Caught by controller[0]: at bindings (/opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:81:44)
    error
    Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
    error
    Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
    error
    Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    error
    Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    error
    Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
    2019-11-09 12:28:28.263
    error
    Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)
    error
    Caught by controller[0]: the module (for instance, using npm rebuild or npm install).
    error
    Caught by controller[0]: NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
    error
    Caught by controller[0]: NODE_MODULE_VERSION 57. This version of Node.js requires
    error
    Caught by controller[0]: was compiled against a different Node.js version using
    error
    Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/serialport/build/Release/serialport.node'
    error
    Caught by controller[0]: ^
    error
    Caught by controller[0]: throw e
    error
    Caught by controller[0]: /opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:88
    2019-11-09 12:28:27.678
    info
    instance system.adapter.zigbee.0 started with pid 28740
    2019-11-09 12:27:57.664
    info
    Restart adapter system.adapter.zigbee.0 because enabled
    Scheint irgendwie ein Versionskonflikt??
    Auch der ble Adapter bleibt rot.
    Log:
    Kann jemand helfen?
    J BBTownB 2 Antworten Letzte Antwort
    • H Henrik
      error
      error
      error
      error
      error
      error
      error
      error
      error
      error
      error
      error
      error
      error
      error
      error
      error
      error
      error
      info
      info
      Log:
      Kann jemand helfen?
      Jan1
      @Henrik-Regen
      welches Backup wurde verwendet?
      H 1 Antwort Letzte Antwort
      • H Henrik
        error
        error
        error
        error
        error
        error
        error
        error
        error
        error
        error
        error
        error
        error
        error
        error
        error
        error
        error
        info
        info
        Log:
        Kann jemand helfen?
        BBTownB Offline
        BBTownB Offline
        BBTown
        @Henrik-Regen dein Beitrag ist nicht vernünftig lesbar, bitte packe die Logs in "code-Tags"
        • J Jan1
          @Henrik-Regen
          Henrik
          @BBTown
          Vollständiges Backup
          • H Henrik
            @BBTown
            Jan1
            @Henrik-Regen
            Wie gut das es das in der nächsten Version von Backitup nicht mehr gibt.
            Das ist Dein Fehler.
            • BBTownB BBTown
              Henrik
              @BBTown
              Stell mich irgendwie zu doof an das Log vernünftig zu kopieren. :-(
              • J Jan1
                @Henrik-Regen
                Henrik
                @Jan1
                Soll heißen: alles noch mal mit dem Minimal Backup, Richtig?
                • H Henrik
                  @Jan1
                  Jan1
                  @Henrik-Regen
                  genau, wobei alles eigentlich nur aus löschen vom Ordner IObroker ist und ab da neu
                  Wird aber gefühlt mindesten ein mal am Tag gefragt und der Entwickler des Backitup Adapter hat darauf reagiert und entfernt das Komplettbackup aus dem Adapter.
                  • J Jan1
                    @Henrik-Regen
                    Henrik
                    @Jan1
                    Kann ich das Minimal Backup einfach draufbügeln?
                    • H Henrik
                      @Jan1
                      Jan1
                      @Henrik-Regen
                      ja, für das ist es ja da 😊
                      • J Jan1
                        @Henrik-Regen
                        Henrik
                        @Jan1
                        Okay, wird gleich probiert.
                        • H Henrik
                          @Jan1
                          Jan1
                          @Henrik
                          dauert aber recht lange, weil alle Adapter neu installiert werden
                          • J Jan1
                            @Henrik
                            Henrik
                            @Jan1
                            Was ist jetzt?
                            permission denied
                            Hab jetzt keine Rechte um auf das Verzechnis mit Filezilla zu schreiben.
                            • H Henrik
                              @Jan1
                              Was ist jetzt?
                              permission denied
                              Jan1
                              @Henrik
                              Fixer mal laufen lassen und wo willst DU mit Filzilla was machen?
                              Vorgehensweise ist ohne Filzilla beim Rückspielen.
                              • J Jan1
                                @Henrik
                                Henrik
                                @Jan1
                                Hab mein Pi3 Backup auf dem Windows PC gesichert. Wollte ich auf den Pi4 draufspielen.
                                Was ist Fixer?
                                • H Henrik
                                  @Jan1
                                  Was ist Fixer?
                                  Jan1
                                  @Henrik
                                  Such mal hier im Board danach.
                                  OK, wenn Du von Windows auf Linux kommst, dann kennst den Fixer nicht, wobei dann eigentlich klar gewesen sein sollte, dass das komplett Backup nie funktionieren kann.
                                  Die Frage was Du mit Filezilla machen willst, ist aber immer noch nicht beantwortet.
                                  • J Jan1
                                    @Henrik
                                    Henrik
                                    @Jan1
                                    Mit Filezilla wollte ich einfach nur die Backup Datei auf den Pi kopieren.
                                    • H Henrik
                                      @Jan1
                                      Jan1
                                      @Henrik
                                      Das kann man machen, aber genau um das zu vereinfachen gibts ja den Backitup Adapter. Den installierst und stellst die Einstellungen wieder, dann geht alles über den Adapter.
                                      paul53P H 2 Antworten Letzte Antwort
                                      • J Jan1
                                        @Henrik
                                        @Jan1 sagte:
                                        Auch der benötigt zum Restore eine Datei mit dem Backup.
                                          @Jan1 sagte:
                                          Jan1
                                          OK, ich gehe mal davon aus, dass das aufm NAS liegt und das kann der Adapter, wenn nicht eben was ich oben schon geschrieben habe.
