  4. Test Adaper Tado v0.1.x
tadoadaptertesting team
868 Beiträge 62 Kommentatoren 316.3k Aufrufe 59 Beobachtet
  • H Offline
    Hohenbostler
    #140
    Hallo
    ich habe auch eine dauerhafte Fehlermeldung.
    tado.0	2019-10-28 21:56:42.012	error	Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 2158
    tado.0	2019-10-28 21:55:38.381	error	Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 2158
    tado.0	2019-10-28 21:54:34.731	error	Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 2158
    tado.0	2019-10-28 21:53:31.114	error	Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 2158
    tado.0	2019-10-28 21:52:27.454	error	Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 2158
    tado.0	2019-10-28 21:51:23.868	error	Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 2158
    tado.0	2019-10-28 21:50:20.048	error	Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 2158
    tado.0	2019-10-28 21:49:16.463	error	Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 2158
    tado.0	2019-10-28 21:48:12.841	error	Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 2158
    tado.0	2019-10-28 21:47:09.272	error	Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 2158
    tado.0	2019-10-28 21:46:05.656	error	Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 2158
    tado.0	2019-10-28 21:45:01.908	error	Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 2158
    tado.0	2019-10-28 21:45:01.885	error	Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 2158
    tado.0	2019-10-28 21:45:01.867	error	Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 2158
    tado.0	2019-10-28 21:45:01.795	error	Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 2158
    • CKMartensC Offline
      CKMartensC Offline
      CKMartens
      #141
      Nachdem ein Thermostat aus- und wieder eingeschaltet wurde, wird ja die vorher eingestellte Temperatur wieder übernommen. Ist dies auch mit dem Modus möglich?
      Beispiel:
      Meine Thermostate laufen im Auto-Modus um die Away-Funktion von tado zu verwenden.
      Wenn ein Fenster im Raum aufgemacht wird zum lüften, schalte ich per Skript das Thermostat aus:
      Dabei schaltet tado natürlich auf den Modus "Manual"
      Wenn das Fenster wieder zu gemacht wird, wird das Thermostat wieder eingeschaltet. Der Modus bleibt aber weiterhin auf "Manual", was auch dazu führt, das die Away-Temperatur übersteuert wird.
      Als Workaround setze ich, nachdem das Thermostat wieder eingeschaltet wurde, den State von clearZoneOverlay auf true.
      Könnte der Adapter automatisch wierder den Modus einstellen der vorher eingestellt war? Also Auto wieder auf Auto und Manual wieder aus Manual.
      Danke.
      • CKMartensC CKMartens
        Beispiel:
        Danke.
        Stormbringer
        #142
        @CKMartens Das er nach ausschalten, wieder auf die ursprünglich gesetzten Modus (und bei manuell Temperatur) stellt fände ich auch sehr praktisch.
        Angaben zur Installation: JS Controller 5.0.12, npm 9.6.7, node 18.17.1, auf einem Intel NUC mit Ubuntu 22.04
        • S Stormbringer
          @Dutchman Modus Auto und Manuell 😉 Dachte das kommt noch? Die API mûsste es eigentlich hergeben, übern HAM Adapter gehts
          DutchmanD Offline
          DutchmanD Offline
          Dutchman
          #143
          @Stormbringer sagte in Test Adaper Tado v0.1.x:
          kommt, diese Woche bissl schwer mit zeit :/
          • C Offline
            Coffeelover
            #144
            Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 4469
            @CKMartens: Cool - danke für deinen Hinweis zum Workaround.
            • DutchmanD Dutchman
              Stormbringer
              #145
              @Dutchman Danke Perfekt, kein Stress. Hauptsache es kommt irgendwann 😉 Bis dahin läuft der HAM ja 😉
              • H Offline
                Hohenbostler
                schrieb am zuletzt editiert von Hohenbostler
                #146
                Guten Morgen,
                passend zu Tado adapter habe ich mir alle für mich wichten Funktionen von der Tado V3+ nachgebaut.
                Beim Tado ditrekt stört mich das die Fenster offen erkennung nicht wirklich klappt und ich für den Away Modus zahlen muss. Ich stelle es hier gerne zur Verfügung muss aber dazu sagen das ich kein Fachmann bin aber es tut was es soll. Alles geht über einzelne selbst angelegte Datenpunkte Datenpunkte.PNG
                Heizungssteuerung.zip
                Ich hoffe damit kann evtl jemand was anfangen.[Heizungssteuerung.zip]
                Hier ein Update >>>> Heizungssteuerung.zip
                C DutchmanD 2 Antworten Letzte Antwort
                • H Hohenbostler
                  Guten Morgen,
                  Coffeelover
                  #147
                  @Hohenbostler super Sache. Wie steuert dein Adapter denn jetzt? Heizphasen und dazu aus wenn Fenster auf oder away? Woher triggerst du den away Status?
                  H 1 Antwort Letzte Antwort
                  • C Coffeelover
                    Hohenbostler
                    #148
                    @Coffeelover sagte in Test Adaper Tado v0.1.x:
                    Naja away -> Sobald meine Frau und ich aus dem Haus sind steuer ich den Datenpunkt away. Siehe script..
                    Fenster auf werden auch Datenpunkte geschrieben -> Getriggert von Xiaomi Fenster sensoren. Die reagieren ja wirklich wenn die Fenster auf sind.
                    Naja der rest ist in den scripten. ;)
                    • H Hohenbostler
                      Guten Morgen,
                      DutchmanD Offline
                      DutchmanD Offline
                      Dutchman
                      schrieb am zuletzt editiert von Dutchman
                      #149
                      @Hohenbostler sagte in Test Adaper Tado v0.1.x:
                      hmm, das ist aber ein sehr interessanter Ansatz den diese Funktionen könnte man auch über den adapter definieren.
                      Ich hab nur n bissl angst das Tado irgendwann Sachen blockieren wird da die ja jetzt Geld fragen und wir es so steuern können.... hmm
                      ich denke mal sowas sollte in der community bleiben und per additionele scripts ermöglicht werden, nicht das die wegen sowas irgendwas die API fuer den adapter komplett sperren das währe mist.
                      S H 2 Antworten Letzte Antwort
                        senger1985
                        #150
                        @Dutchman da bin ich deiner Meinung.
                          Hohenbostler
                          #151
                          @Dutchman sagte in Test Adaper Tado v0.1.x:
                          Soll ich den Post wieder löschen?
                          • H Hohenbostler
                            DutchmanD Offline
                            DutchmanD Offline
                            Dutchman
                            #152
                            noe ... sensur soweit gehts noch :P wie gesagt selber machen kan ja jeder aber ich finde es zu gefaehrlich dedicated in den adapter ein zu bauen.
                            dEn damit bauen ich ihre bezahlte version nach und ich möchten niemanden verärgern.
                            • C Offline
                              Coffeelover
                              #153
                              (2881) Send this info to developer !!! { Unhandable information found in DoHome : "boilerId" with value : 4469
                              S R 2 Antworten Letzte Antwort
                              • C Coffeelover
                                senger1985
                                #154
                                @Coffeelover wir sind dran.
                                Habe bitte noch etwas Geduld.
                                • C Offline
                                  Coffeelover
                                  #155
                                  Überhaupt keine Eile - ich dachte nur es würde euch helfen, wenn ich das hier poste...
                                  Wenn nicht, lasse ich das auch gerne bleiben.
                                  • C Coffeelover
                                    senger1985
                                    #156
                                    @Coffeelover gar kein Problem.
                                    Gut wäre es, wenn du auf der Github-Seite, zum Adapter ein Issue eröffnest.
                                    C 1 Antwort Letzte Antwort
                                    • S senger1985
                                      Coffeelover
                                      #157
                                      @senger1985 Würde ich auch - aber ich weiß nicht, was das Problem dahinter ist. Einfach: "Fehlermeldungen im Log"?
                                      • C Coffeelover
                                        senger1985
                                        #158
                                        @Coffeelover so in etwa.
                                        "Fehlermeldung, bei Installation"
                                        "Bei der Installation von Version xyz kommt folgende Fehlermeldung:
                                        (hier dann den Screenshot einfügen.)
                                        Nur so als Beispiel.
                                        • H Offline
                                          hilde0407
                                          #159
                                          Ich bin gerade dabei ein paar Skripte für die Tado Heizung mittels des Tado Adapters zu erstellen, dabei habe ich das Problem, dass ich mit Blocky nicht den clearZoneOverlay schalten kann. Wenn ich den Datenpunkt händisch auslöse (Button simulieren) klappt das. Wie muss ich das per Blocky erledigen?
                                          CKMartensC 1 Antwort Letzte Antwort
