  4. [gelöst] ioBroker Wiederherstellung mit Backitup
backitupdockerdiskstationbackupwiederherstellungdropbox
48 Beiträge 8 Kommentatoren 8.6k Aufrufe 7 Beobachtet
  • StM47S StM47
    @Jan1
    ja, wenn er läuft.
    Habe die Wiederherstellung mal über Nacht laufen lassen.
    Bekomme folgende Fehlermeldung:
    Gestartet...
    [DEBUG] [mount] start with {"mountType":"NFS","type":"storage","source":"local","mount":"192.168.178.50","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","dirTotal":"sharename/backupDir","user":"","pass":"****"}
    [ERROR] [mount] - [undefined sudo: Hostname iobroker kann nicht aufgelöst werden
    sudo: Die Audit-Nachricht kann nicht gesendet werden: Unbekannter Fehler -1
    sudo: pam_open_session: Systemfehler
    sudo: Regelwerks-Plugin konnte Sitzung nicht initialisieren
    [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount 192.168.178.50:/sharename/backupDir /opt/iobroker/backups
    [DEBUG] [minimal] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","nameSuffix":"Standartbackup","deleteBackupAfter":"5","mysqlEnabled":false,"redisEnabled":false,"zigbeeEnabled":false,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"local","mount":"192.168.178.50","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/sharename/backupDir","dirMinimal":"sharename/backupDir","dirTotal":"sharename/backupDir","user":"","pass":"","context":{"fileNames":[],"errors":{"mount":{"killed":false,"code":1,"signal":null,"cmd":"sudo mount 192.168.178.50:/sharename/backupDir /opt/iobroker/backups"}},"done":[],"types":[]},"adapter":null},"dropbox":{"enabled":true,"type":"storage","source":"local","deleteOldBackup":false,"accessToken":"","ownDir":true,"bkpType":"Minimal","dir":"backup/iobroker/minimal","dirMinimal":"backup/iobroker/minimal","dirTotal":"backup/iobroker/total"},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"local","mount":"192.168.178.50","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","dirTotal":"sharename/backupDir","user":"","pass":""},"dropbox":{"enabled":true,"type":"storage","source":"local","deleteOldBackup":false,"accessToken":"9LHciNbWSksAAAAAAAAyTh9pfSb6ILAf7P4NMM0_MFavZz3_w3U_nD2QCyacnPUt","ownDir":true,"bkpType":"Minimal","dir":"backup/iobroker/minimal","dirMinimal":"backup/iobroker/minimal","dirTotal":"backup/iobroker/total"},"googledrive":{"enabled":false,"type":"storage","source":"local","deleteOldBackup":false,"accessJson":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"local","mount":"192.168.178.50","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","dirTotal":"sharename/backupDir","user":"","pass":""},"dropbox":{"enabled":true,"type":"storage","source":"local","deleteOldBackup":false,"accessToken":"9LHciNbWSksAAAAAAAAyTh9pfSb6ILAf7P4NMM0_MFavZz3_w3U_nD2QCyacnPUt","ownDir":true,"bkpType":"Minimal","dir":"backup/iobroker/minimal","dirMinimal":"backup/iobroker/minimal","dirTotal":"backup/iobroker/total"},"googledrive":{"enabled":false,"type":"storage","source":"local","deleteOldBackup":false,"accessJson":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/opt/iobroker/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":null,"onlyError":false,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"stopIoB":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
    [DEBUG] [minimal] - Backup created: /opt/iobroker/backups/minimal_2019_10_28-02_00_20_Standartbackup_backupiobroker.tar.gz
    [DEBUG] [minimal] - done
    [DEBUG] [cifs] start with {"mountType":"NFS","type":"storage","source":"local","mount":"192.168.178.50","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/sharename/backupDir","dirMinimal":"sharename/backupDir","dirTotal":"sharename/backupDir","user":"","pass":"","backupDir":"/opt/iobroker/backups","deleteBackupAfter":"5"}
    [DEBUG] [cifs] - done
    [DEBUG] [dropbox] start with {"type":"storage","source":"local","deleteOldBackup":false,"accessToken":"
    ","ownDir":true,"bkpType":"Minimal","dir":"backup/iobroker/minimal","dirMinimal":"backup/iobroker/minimal","dirTotal":"backup/iobroker/total","deleteBackupAfter":"5"}
    [DEBUG] [dropbox] - Copy minimal_2019_10_28-02_00_20_Standartbackup_backupiobroker.tar.gz...
    [DEBUG] [dropbox] - done
    [DEBUG] [clean] start with {"deleteBackupAfter":"5"}
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    [DEBUG] [clean] - done
    [DEBUG] [telegram] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","nameSuffix":"Standartbackup","deleteBackupAfter":"5","mysqlEnabled":false,"redisEnabled":false,"zigbeeEnabled":false,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"local","mount":"192.168.178.50","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/sharename/backupDir","dirMinimal":"sharename/backupDir","dirTotal":"sharename/backupDir","user":"","pass":"","context":{"fileNames":["/opt/iobroker/backups/minimal_2019_10_28-02_00_20_Standartbackup_backupiobroker.tar.gz"],"errors":{"mount":{"killed":false,"code":1,"signal":null,"cmd":"sudo mount 192.168.178.50:/sharename/backupDir /opt/iobroker/backups"}},"done":["minimal","dropbox"],"types":["minimal"]},"adapter":null},"dropbox":{"enabled":true,"type":"storage","source":"local","deleteOldBackup":false,"accessToken":"","ownDir":true,"bkpType":"Minimal","dir":"backup/iobroker/minimal","dirMinimal":"backup/iobroker/minimal","dirTotal":"backup/iobroker/total"},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"local","mount":"192.168.178.50","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","dirTotal":"sharename/backupDir","user":"","pass":""},"dropbox":{"enabled":true,"type":"storage","source":"local","deleteOldBackup":false,"accessToken":"9LHciNbWSksAAAAAAAAyTh9pfSb6ILAf7P4NMM0_MFavZz3_w3U_nD2QCyacnPUt","ownDir":true,"bkpType":"Minimal","dir":"backup/iobroker/minimal","dirMinimal":"backup/iobroker/minimal","dirTotal":"backup/iobroker/total"},"googledrive":{"enabled":false,"type":"storage","source":"local","deleteOldBackup":false,"accessJson":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"local","mount":"192.168.178.50","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","dirTotal":"sharename/backupDir","user":"","pass":""},"dropbox":{"enabled":true,"type":"storage","source":"local","deleteOldBackup":false,"accessToken":"9LHciNbWSksAAAAAAAAyTh9pfSb6ILAf7P4NMM0_MFavZz3_w3U_nD2QCyacnPUt","ownDir":true,"bkpType":"Minimal","dir":"backup/iobroker/minimal","dirMinimal":"backup/iobroker/minimal","dirTotal":"backup/iobroker/total"},"googledrive":{"enabled":false,"type":"storage","source":"local","deleteOldBackup":false,"accessJson":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/opt/iobroker/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":null,"onlyError":false,"telegramWaiting":0,"systemLang":"de","time":"28. Oktober 2019 um 02:00 Uhr"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"stopIoB":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
    [DEBUG] [telegram] - done
    [DEBUG] [history] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","nameSuffix":"Standartbackup","deleteBackupAfter":"5","mysqlEnabled":false,"redisEnabled":false,"zigbeeEnabled":false,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"local","mount":"192.168.178.50","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/sharename/backupDir","dirMinimal":"sharename/backupDir","dirTotal":"sharename/backupDir","user":"","pass":"","context":{"fileNames":["/opt/iobroker/backups/minimal_2019_10_28-02_00_20_Standartbackup_backupiobroker.tar.gz"],"errors":{"mount":{"killed":false,"code":1,"signal":null,"cmd":"sudo mount 192.168.178.50:/sharename/backupDir /opt/iobroker/backups"}},"done":["minimal","dropbox"],"types":["minimal"]},"adapter":null},"dropbox":{"enabled":true,"type":"storage","source":"local","deleteOldBackup":false,"accessToken":"","ownDir":true,"bkpType":"Minimal","dir":"backup/iobroker/minimal","dirMinimal":"backup/iobroker/minimal","dirTotal":"backup/iobroker/total"},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"local","mount":"192.168.178.50","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","dirTotal":"sharename/backupDir","user":"","pass":""},"dropbox":{"enabled":true,"type":"storage","source":"local","deleteOldBackup":false,"accessToken":"9LHciNbWSksAAAAAAAAyTh9pfSb6ILAf7P4NMM0_MFavZz3_w3U_nD2QCyacnPUt","ownDir":true,"bkpType":"Minimal","dir":"backup/iobroker/minimal","dirMinimal":"backup/iobroker/minimal","dirTotal":"backup/iobroker/total"},"googledrive":{"enabled":false,"type":"storage","source":"local","deleteOldBackup":false,"accessJson":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"local","mount":"192.168.178.50","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","dirTotal":"sharename/backupDir","user":"","pass":""},"dropbox":{"enabled":true,"type":"storage","source":"local","deleteOldBackup":false,"accessToken":"9LHciNbWSksAAAAAAAAyTh9pfSb6ILAf7P4NMM0_MFavZz3_w3U_nD2QCyacnPUt","ownDir":true,"bkpType":"Minimal","dir":"backup/iobroker/minimal","dirMinimal":"backup/iobroker/minimal","dirTotal":"backup/iobroker/total"},"googledrive":{"enabled":false,"type":"storage","source":"local","deleteOldBackup":false,"accessJson":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/opt/iobroker/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"28. Oktober 2019 um 02:00 Uhr"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":null,"onlyError":false,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"stopIoB":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
    [DEBUG] [history] - backitup.0.history.html
    [DEBUG] [umount] start with {"mountType":"NFS","type":"storage","source":"local","mount":"192.168.178.50","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/sharename/backupDir","dirMinimal":"sharename/backupDir","dirTotal":"sharename/backupDir","user":"","pass":"****","backupDir":"/opt/iobroker/backups"}
    Und im LOG steht die selbe Fehlermeldung, wie im ersten Post.
    simatecS Offline
    simatecS Offline
    simatec
    @StM47
    Der Log ist nicht vom restore sondern von einem backup und sagt aus, dass dein mount nicht korrekt konfiguriert ist.
    Ich glaube du bringst hier ein wenig was durcheinander ...
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    • StM47S StM47
      @Jan1
      ja, wenn er läuft.
      Gestartet...
      Jan1
      @StM47
      Du versuchst auf ein Mount zu zugreifen was nicht geht, deshalb war der Rat das Backup in den Ordner /opt/iobroker/backups zu legen und mit dem Backitup Adapter dann lokal zu wählen und eben das Backup aus besagtem Ordner wieder herzustellen.
      Wenn das nicht geht, dann hast Dein System versaut.
      StM47S 1 Antwort Letzte Antwort
      • J Jan1
        @StM47
        StM47S Offline
        StM47S Offline
        StM47
        schrieb am zuletzt editiert von StM47
        @Jan1
        genau das ist mein Plan.
        ich möchte ein gesichertes backup in /opt/iobroker/backups legen und von dort aus wieder herstellen.
        Das geht aber nur über das Terminal per SSH mit root.
        Mir fehlen aber eine genaue Anleitung dazu.
        Ich komme soweit, mich mit root auf der DiskStation mit Putty anzumelden.
        Dann weiß ich nicht weiter.
        ioBroker im Docker auf Synology DiskStation DS 716+II mit DSM 6.2.1
        • Lightmanager Air / Lupusec XT2 Plus mit div. Fenster- u. Türkontakten, Rauch- u. Bewegungsmelder / Harmony Hub / Fritzbox 7590 OS7
        • schaltbare Steckdosen / Alexa Echo Dot 3 / Zigbee USB Stick / diverse Xiaomi Produkte / Xiaomi Yeelight Birnen
        • StM47S StM47
          @Jan1
          Jan1
          @StM47
          Warum willst was anderes machen, als man Dir rät?
          • J Jan1
            @StM47
            StM47S Offline
            StM47S Offline
            StM47
            @Jan1
            jetzt vertehe ich gar nichts mehr.
            Du schreibst:
            "deshalb war der Rat das Backup in den Ordner /opt/iobroker/backups zu legen und mit dem Backitup Adapter dann lokal zu wählen und eben das Backup aus besagtem Ordner wieder herzustellen"
            Genau das habe ich vor.
            Geht das auch anderst als mit dem Terminal?
            J simatecS 2 Antworten Letzte Antwort
            • StM47S StM47
              @Jan1
              Du schreibst:
              Jan1
              @StM47
              Steht da Backitup Adapter oder Terminal???
              Der einzige der hier immer Terminal schreibt, bist Du.
              StM47S 2 Antworten Letzte Antwort
              • StM47S StM47
                @Jan1
                Du schreibst:
                simatecS Offline
                simatecS Offline
                simatec
                @StM47
                Warum willst du ein frisch erstelltes Backup direkt wieder herstellen?
                Ich denke du verwechselst hier was grundlegendes ...
                • J Jan1
                  @StM47
                  StM47S Offline
                  StM47S Offline
                  StM47
                  @Jan1
                  ich muss doch aber erst ein gesichertes Backup in den Ordner /opt/iobroker/backups
                  legen.
                  Wie soll ich das ohne Terminal machen?
                  • simatecS simatec
                    @StM47
                    StM47S Offline
                    StM47S Offline
                    StM47
                    @simatec
                    ich habe mich sicher falsch ausgedrückt.
                    Ich möchte ein altes Backup, welches ich in der Dropbox liegen habe, wiederherstellen.
                    • StM47S StM47
                      @Jan1
                      legen.
                      Jan1
                      @StM47
                      Mit Filezilla z.B. oder einem FTP Programm Deiner Wahl.
                      Wobei ich jetzt auch nicht verstehe, was DU überhaupt machen willst.
                      • StM47S StM47
                        @Jan1
                        legen.
                        simatecS Offline
                        simatecS Offline
                        simatec
                        @StM47
                        Du nimmst ein Standard Backup von deiner alten Installation und legst es per SFTP auf dein neues System.
                        Danach stellst du mit backitup lokal das Backup wieder her ...
                        • J Jan1
                          @StM47
                          StM47S Offline
                          StM47S Offline
                          StM47
                          @Jan1
                          auf ein FTP Programm bin ich noch gar nicht gekommen.
                          Teste ich gleich mal an..
                          • StM47S Offline
                            StM47S Offline
                            StM47
                            Ich gebe bald auf,
                            Es ist ohnen größeren Aufwand nicht möglich, per SFTP (SSH) mit eienm FTP Programm auf das root Verzeichnis einer Synology DiskStation zu kommen.
                            Es ist wohl einfacher, die Backup-Datei mit 2 bis 3 Shell-Befehlen in das Verzeichnis /opt/iobroker/backups zu bekommen, wie mit SFTP.
                            Es müsste mir nur jemand zeigen, wie das geht.
                            • StM47S StM47
                              Ich gebe bald auf,
                              simatecS Offline
                              simatecS Offline
                              simatec
                              @StM47
                              Kommst du per ssh in das Verzeichnis /opt/iobroker/backups?
                              • StM47S Offline
                                StM47S Offline
                                StM47
                                ja, komme ich.
                                • StM47S StM47
                                  ja, komme ich.
                                  simatecS Offline
                                  simatecS Offline
                                  simatec
                                  @StM47
                                  Dann sollte es auch per sftp gehen
                                  • StM47S Offline
                                    StM47S Offline
                                    StM47
                                    es geht auch mit SFTP. Muss aber vorher per Shell den Key aus der DiskStation extrahieren und damit für SFTP eine Schlüsseldatei basteln.
                                    Also ist das wieder eine ganz andere, für mich größere Baustelle.
                                    Synology hat da echt fliese Sicherheitsmaßnahmen getroffen.
                                    • StM47S Offline
                                      StM47S Offline
                                      StM47
                                      Ist hier kein Linux Spezialist, der mir kurz die 3 Befehle zum kopieren meines alten Backups in das Verzeichnis /opt/iobroker/backups aufschreiben kan?
                                      • StM47S StM47
                                        simatecS Offline
                                        simatecS Offline
                                        simatec
                                        @StM47
                                        Hast du es mal mit Filezilla getestet?
                                        • simatecS simatec
                                          @StM47
                                          StM47S Offline
                                          StM47S Offline
                                          StM47
                                          @simatec
                                          ja, habe ich. Man kommt nur in das Home- Verzeichnis. Für Root- Zugriff wird die Schlüsseldatei benötigt.
