  4. PI4 Lässt JS Kontrolle nicht updaten
js-controller 2.0.25
106 Beiträge 8 Kommentatoren 13.9k Aufrufe 9 Beobachtet
  • F freaktech
    @AlCalzone
    hab ich grad gemacht und nun?
    pi@iobrocker:/opt/iobroker $
    pi@iobrocker:/opt/iobroker $ npm i production --ignore-scripts
    npm WARN deprecated CSSselect@0.7.0: the module is now available as 'css-select'
    npm WARN deprecated CSSwhat@0.4.7: the module is now available as 'css-what'
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    • production@0.0.2
      added 29 packages from 55 contributors and audited 1563 packages in 15.581s
      found 42 vulnerabilities (28 low, 3 moderate, 11 high)
      run npm audit fix to fix them, or npm audit for details
      pi@iobrocker:/opt/iobroker $ npm uninstall production --ignore-scripts
    removed 29 packages and audited 1529 packages in 12.734s
    found 39 vulnerabilities (28 low, 11 high)
    pi@iobrocker:/opt/iobroker $ npm i --production --ignore-scripts
    up to date in 20.908s
    AlCalzoneA Offline
    AlCalzoneA Offline
    AlCalzone
    @freaktech Das sieht doch gut aus... Probier jetzt nochmal das iobroker upgrade self
    • F Offline
      freaktech
      @AlCalzone said in PI4 Lässt JS Kontrolle nicht updaten:
      zuerst machte er was dann Seitenweise
      Chmod finished. Restart controller
      -bash: rlaubt: Kommando nicht gefunden.
      pi@iobrocker:/opt/iobroker $ chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.discovery/lib/adapters/nuki 2.js': Die Operation ist nicherlaubt
      -bash: chmod:: Kommando nicht gefunden.
      pi@iobrocker:/opt/iobroker $ chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.discovery/lib/adapters/sql. js': Die Operation ist nicht laubt
      pi@iobrocker:/opt/iobroker $ chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.discovery/lib/adapters/vis. js': Die Operation ist nicht laubt
      pi@iobrocker:/opt/iobroker $ chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.discovery/lib/adapters/knx. js': Die Operation ist nicht laubt
      pi@iobrocker:/opt/iobroker $ chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.discovery/lib/adapters/enet .js': Die Operation ist nichtrlaubt
      pi@iobrocker:/opt/iobroker $ chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.discovery/lib/adapters/flot .js': Die Operation ist nichtrlaubt
      pi@iobrocker:/opt/iobroker $ chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.discovery/lib/adapters/sonn en.js': Die Operation ist nic erlaubt
      pi@iobrocker:/opt/iobroker $ chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.discovery/lib/adapters/clou d.js': Die Operation ist nicherlaubt
      pi@iobrocker:/opt/iobroker $ chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.discovery/lib/adapters/web. js': Die Operation ist nicht laubt
      pi@iobrocker:/opt/iobroker $ chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.discovery/lib/adapters/zwav e.js': Die Operation ist nicherlaubt
      pi@iobrocker:/opt/iobroker $ chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.discovery/lib/adapters/nut. js': Die Operation ist nicht laubt
      pi@iobrocker:/opt/iobroker $ chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.discovery/lib/adapters/emby .js': Die Operation ist nichtrlaubt
      pi@iobrocker:/opt/iobroker $ chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.discovery/lib/adapters/upnp .js': Die Operation ist nichtrlaubt
      pi@iobrocker:/opt/iobroker $ chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.discovery/lib/adapters/fhem .js': Die Operation ist nichtrlaubt
      pi@iobrocker:/opt/iobroker $ chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.discovery/lib/adapters/hass .js': Die Operation ist nichtrlaubt
      pi@iobrocker:/opt/iobroker $ Chmod finished. Restart controller
      -bash: Chmod: Kommando nicht gefunden.
      • F Offline
        freaktech
        schrieb am zuletzt editiert von freaktech
        irgendwie kommt nur der blaue Balken des webinterface sowohl im chrome als auch im IE
        ?!?! glaub nicht dass das richtig läuft so ein Mist
        wenn ich stoppe kommt
        wenn ich starte kurz oben blau und der Kreis dreht in allen Farben noch bevor links ein Menü kommt
        • F freaktech
          AlCalzoneA Offline
          AlCalzoneA Offline
          AlCalzone
          @freaktech Das chmod-Zeug kannst du glaube ich ignorieren. Die Adapter scheinen installiert. Eventuell fehlt einfach ein iobroker start?
          Falls es dann noch nicht geht, bitte einmal die Ausgabe der folgenden Kommandos posten (einzeln bitte):
          iobroker list instances
          ls -la /opt/iobroker
          tail -f /opt/iobroker/log/iobroker.2019-10-14.log
          (Beim letzten bin ich mir nicht ganz sicher, ob die Datei so richtig heißt, bitte mal in dem Ordner nachsehen).
          • F Offline
            freaktech
            @freaktech
            pi@iobrocker:/opt/iobroker $ iobroker list instances
            + system.adapter.admin.0                 : admin       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              system.adapter.alexa2.1                : alexa2      -  enabled
              system.adapter.backitup.0              : backitup    -  enabled
              system.adapter.cloud.0                 : cloud       -  enabled
              system.adapter.daswetter.0             : daswetter   -  enabled
              system.adapter.discovery.0             : discovery   -  enabled
              system.adapter.hue.0                   : hue         -  enabled, port: 80
              system.adapter.ical.0                  : ical        -  enabled
              system.adapter.ical.1                  : ical        -  enabled
              system.adapter.info.0                  : info        -  enabled
              system.adapter.javascript.0            : javascript  -  enabled
              system.adapter.js2fs.0                 : js2fs       -  enabled
              system.adapter.maxcube.0               : maxcube     -  enabled, port: 62910, bind: 0.0.0.0
              system.adapter.mqtt.0                  : mqtt        -  enabled, port: 1883
              system.adapter.opi.0                   : opi         -  enabled
              system.adapter.pushover.0              : pushover    -  enabled
              system.adapter.pushover.1              : pushover    -  enabled
              system.adapter.ring.0                  : ring        -  enabled
              system.adapter.shelly.0                : shelly      -  enabled, port: 1882, bind: 0.0.0.0
              system.adapter.simple-api.0            : simple-api  -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
              system.adapter.telegram.0              : telegram    - disabled, port: 8443, bind: 0.0.0.0
              system.adapter.terminal.0              : terminal    -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
              system.adapter.vis-colorpicker.0       : vis-colorpicker -  enabled
              system.adapter.vis-fancyswitch.0       : vis-fancyswitch -  enabled
              system.adapter.vis-hqwidgets.0         : vis-hqwidgets -  enabled
              system.adapter.vis-jqui-mfd.0          : vis-jqui-mfd -  enabled
              system.adapter.vis-timeandweather.0    : vis-timeandweather -  enabled
              system.adapter.vis.0                   : vis         -  enabled
              system.adapter.web.0                   : web         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + instance is alive
            pi@iobrocker:/opt/iobroker $ ls -la /opt/iobroker
            insgesamt 112
            drwxrwxrwx+   9 iobroker iobroker  4096 Okt 14 10:08 .
            drwxr-xr-x    4 root     root      4096 Jul 23 20:25 ..
            drwxrwxrwx+   2 iobroker iobroker  4096 Okt 13 14:31 backups
            -rwxrwxrwx+   1 iobroker iobroker  1049 Okt 13 14:00 CHANGELOG_FIXER_LINUX.md
            -rwxrwxrwx+   1 iobroker iobroker  3556 Okt 13 14:00 CHANGELOG_INSTALLER_LINUX.md
            drwxrwxrwx+   2 iobroker iobroker  4096 Aug 18 12:20 etc
            -rwxrwxrwx+   1 iobroker iobroker 23988 Okt 13 14:00 fix_installation.sh
            drwxrwxrwx+   3 iobroker iobroker  4096 Jul 23 20:25 install
            -rwxrwxrwx+   1 iobroker iobroker   789 Okt 13 14:50 INSTALLER_INFO.txt
            lrwxrwxrwx    1 iobroker iobroker    22 Okt 13 14:50 iob -> /opt/iobroker/iobroker
            -rwxrwxrwx+   1 iobroker iobroker   303 Okt 13 14:50 iobroker
            drwxrwxrwx+   5 iobroker iobroker  4096 Sep  4 23:21 iobroker-data
            drwxrwxrwx+   2 iobroker iobroker  4096 Okt 13 14:00 lib
            -rwxrwxrwx+   1 iobroker iobroker  1137 Okt 13 14:00 LICENSE
            drwxrwxrwx+   2 iobroker iobroker  4096 Okt 14 10:39 log
            drwxr-xr-x+ 367 pi       pi       12288 Okt 14 10:09 node_modules
            -rwxrwxrwx+   1 iobroker iobroker    19 Okt 13 14:01 .npmrc
            -rwxrwxrwx+   1 pi       pi         569 Okt 14 10:08 package.json
            -rwxrwxrwx+   1 iobroker iobroker  6101 Okt 13 14:00 README.md
            -rwxrwxrwx+   1 iobroker iobroker  5868 Okt 13 14:01 reinstall.js
            das dritte kann ich nicht posten das läuft ewig
            2019-10-14 10:41:55.762  - info: admin.0 starting. Version 3.6.9 in /opt/iobroker/node_modules/iobroker.admin, node: v10.15.2
            2019-10-14 10:41:55.870  - info: admin.0 requesting all states
            2019-10-14 10:41:55.872  - info: admin.0 requesting all objects
            0-14 10:41:28.919  - info: admin.0 terminating http server on port 8081
            2019-10-14 10:41:30.423  - info: admin.0 terminating http server on port 8081
            2019-10-14 10:41:32.846  - info: host.iobrocker iobroker.js-controller version 1.5.14 js-controller starting
            2019-10-14 10:41:32.852  - info: host.iobrocker Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
            2019-10-14 10:41:32.852  - info: host.iobrocker hostname: iobrocker, node: v10.15.2
            2019-10-14 10:41:32.855  - info: host.iobrocker ip addresses: 10.0.0.144 fe80::dea6:32ff:fe28:5861 fe80::fc28:a4ff:fe7a:c5d8
            2019-10-14 10:41:33.107  - info: host.iobrocker  inMem-states listening on port 9000
            2019-10-14 10:41:34.267  - info: host.iobrocker  inMem-objects listening on port 9001
            2019-10-14 10:41:34.289  - info: host.iobrocker InMemoryDB connected
            2019-10-14 10:41:34.336  - info: host.iobrocker 29 instances found
            2019-10-14 10:41:34.368  - info: host.iobrocker starting 28 instances
            2019-10-14 10:41:34.374  - warn: host.iobrocker startInstance cannot find adapter "telegram@1.4.3". Try to install it... 1 attempt
            2019-10-14 10:41:34.374  - info: iobroker install telegram@1.4.3
            2019-10-14 10:41:34.483  - info: host.iobrocker instance system.adapter.admin.0 started with pid 6516
            2019-10-14 10:41:35.489  - error: uncaught exception: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/pids.txt'
            2019-10-14 10:41:35.491  - error: Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/pids.txt'
                at Object.openSync (fs.js:439:3)
                at Object.writeFileSync (fs.js:1190:35)
                at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:2024:16)
                at ontimeout (timers.js:436:11)
                at tryOnTimeout (timers.js:300:5)
                at listOnTimeout (timers.js:263:5)
                at Timer.processTimers (timers.js:223:10)
            2019-10-14 10:41:35.497  - info: iobroker _restart
            2019-10-14 10:41:37.827  - info: iobroker Starting node restart.js
            2019-10-14 10:41:37.849  - info: iobroker exit 0
            2019-10-14 10:41:37.999  - info: admin.0 starting. Version 3.6.9 in /opt/iobroker/node_modules/iobroker.admin, node: v10.15.2
            2019-10-14 10:41:38.131  - info: admin.0 requesting all states
            2019-10-14 10:41:38.132  - info: admin.0 requesting all objects
            2019-10-14 10:41:41.714  - info: iobroker NPM version: 6.12.0
            2019-10-14 10:41:42.799  - info: admin.0 received all objects
            2019-10-14 10:41:42.879  - info: admin.0 http server listening on port 8081
            2019-10-14 10:41:42.880  - info: admin.0 Use link "http://localhost:8081" to configure.
            2019-10-14 10:41:44.068  - info: iobroker npm install iobroker.telegram@1.4.3 --production --save --prefix "/opt/iobroker" (System call)
            2019-10-14 10:41:45.503  - info: host.iobrocker force terminating
            2019-10-14 10:41:45.504  - info: Adapter admin still running
            2019-10-14 10:41:46.632  - info: admin.0 terminating http server on port 8081
            2019-10-14 10:41:48.136  - info: admin.0 terminating http server on port 8081
            2019-10-14 10:41:59.427  - info: iobroker NPM version: 6.12.0
            • F freaktech
              @freaktech
              + instance is alive
              insgesamt 112
              AlCalzoneA Offline
              AlCalzoneA Offline
              AlCalzone
              @freaktech Ahh dann haben wir es fast!
              iobroker stop
              sudo rm -f /opt/iobroker/node_modules/iobroker.js-controller/pids.txt
              iobroker start
              • F Offline
                freaktech
                pi@iobrocker:/opt/iobroker $ sudo iobroker stop
                pi@iobrocker:/opt/iobroker $ sudo rm -f /opt/iobroker/node_modules/iobroker.js-controller/pids.txt
                pi@iobrocker:/opt/iobroker $ sudo iobroker start
                läuft wieder nur halb weg
                • F freaktech
                  AlCalzoneA Offline
                  AlCalzoneA Offline
                  AlCalzone
                  @freaktech sagte in PI4 Lässt JS Kontrolle nicht updaten:
                  Hä, was?
                  F 1 Antwort Letzte Antwort
                  • AlCalzoneA AlCalzone
                    Hä, was?
                    freaktech
                    @AlCalzone
                    es kommt im WEBINTERFACE nur oben der blaue Balken und
                    • F freaktech
                      @AlCalzone
                      AlCalzoneA Offline
                      AlCalzoneA Offline
                      AlCalzone
                      @freaktech Dann bitte nochmal den Log posten
                      (kannst du nach ein paar Sekunden abbrechen und posten, das Kommando läuft sonst ewig weiter).
                      • F Offline
                        freaktech
                        permitted by applicable law.
                        Last login: Mon Oct 14 10:24:34 2019 from 10.0.0.202
                        pi@iobrocker:~ $ tail -f /opt/iobroker/log/iobroker.2019-10-14.log
                        2019-10-14 10:54:25.005  - info: admin.0 requesting all objects
                        2019-10-14 10:54:28.592  - info: iobroker NPM version: 6.12.0
                        2019-10-14 10:54:29.691  - info: admin.0 received all objects
                        2019-10-14 10:54:29.770  - info: admin.0 http server listening on port 8081
                        2019-10-14 10:54:29.771  - info: admin.0 Use link "http://localhost:8081" to configure.
                        2019-10-14 10:54:30.953  - info: iobroker npm install iobroker.telegram@1.4.3 --production --save --prefix "/opt/iobroker" (System ca        ll)
                        2019-10-14 10:54:32.464  - info: host.iobrocker force terminating
                        2019-10-14 10:54:32.465  - info: Adapter admin still running
                        2019-10-14 10:54:33.598  - info: admin.0 terminating http server on port 8081
                        2019-10-14 10:54:35.101  - info: admin.0 terminating http server on port 8081
                        2019-10-14 10:54:37.483  - info: host.iobrocker iobroker.js-controller version 1.5.14 js-controller starting
                        2019-10-14 10:54:37.489  - info: host.iobrocker Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
                        2019-10-14 10:54:37.489  - info: host.iobrocker hostname: iobrocker, node: v10.15.2
                        2019-10-14 10:54:37.491  - info: host.iobrocker ip addresses: 10.0.0.144 fe80::dea6:32ff:fe28:5861 fe80::fc74:2dff:fefc:7a31
                        2019-10-14 10:54:37.743  - info: host.iobrocker  inMem-states listening on port 9000
                        2019-10-14 10:54:38.845  - info: host.iobrocker  inMem-objects listening on port 9001
                        2019-10-14 10:54:38.866  - info: host.iobrocker InMemoryDB connected
                        2019-10-14 10:54:38.913  - info: host.iobrocker 29 instances found
                        2019-10-14 10:54:38.946  - info: host.iobrocker starting 28 instances
                        2019-10-14 10:54:38.951  - warn: host.iobrocker startInstance cannot find adapter "telegram@1.4.3". Try to install it... 1 attempt
                        2019-10-14 10:54:38.951  - info: iobroker install telegram@1.4.3
                        2019-10-14 10:54:39.060  - info: host.iobrocker instance system.adapter.admin.0 started with pid 1620
                        2019-10-14 10:54:40.065  - error: uncaught exception: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-control        ler/pids.txt'
                        2019-10-14 10:54:40.068  - error: Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/pids.txt'
                        2019-10-14 10:54:40.075  - info: iobroker _restart
                        2019-10-14 10:54:42.397  - info: iobroker Starting node restart.js
                        2019-10-14 10:54:42.420  - info: iobroker exit 0
                        2019-10-14 10:54:42.490  - info: admin.0 starting. Version 3.6.9 in /opt/iobroker/node_modules/iobroker.admin, node: v10.15.2
                        2019-10-14 10:54:42.602  - info: admin.0 requesting all states
                        2019-10-14 10:54:42.603  - info: admin.0 requesting all objects
                        2019-10-14 10:54:46.230  - info: iobroker NPM version: 6.12.0
                        ^C
                        pi@iobrocker:~ $
                        code_text
                        • F freaktech
                          ^C
                          pi@iobrocker:~ $
                          code_text
                          AlCalzoneA Offline
                          AlCalzoneA Offline
                          AlCalzone
                          @freaktech Schon wieder das permission-Ding. Lass mal den Fixer laufen:
                          curl -sL https://iobroker.net/fix.sh | bash -
                          • F Offline
                            freaktech
                            ah jetzt ist er wieder da
                            soll ich jetzt das upgrade shelf wieder probieren?
                            • F freaktech
                              AlCalzoneA Offline
                              AlCalzoneA Offline
                              AlCalzone
                              @freaktech Das Upgrade müsste schon passiert sein oder? Schau mal im Hosts-Reiter nach der Version.
                              • F Offline
                                freaktech
                                nein
                                iobrocker
                                Typ: js-controller
                                Titel: JS controller
                                OS: linux
                                Verfügbar: 2.0.25
                                Eingerichtet: 1.5.14
                                • F Offline
                                  freaktech
                                  bis auf den hue haben sich die meisten wieder gefangt
                                  update geht weiterhin nicht
                                  wie kann ich den hue auf grün bekommen
                                  pi@iobrocker:/opt/iobroker $ sudo iobroker upgrade self
                                  Update js-controller from @1.5.14 to @2.0.29
                                  NPM version: 6.12.0
                                  npm install iobroker.js-controller@2.0.29 --unsafe-perm --production --save --pr        efix "/opt/iobroker" (System call)
                                  npm WARN registry Unexpected warning for https://registry.npmjs.org/: Miscellane        ous Warning ENODATA: Cache input stream was empty
                                  npm WARN registry Using stale data from https://registry.npmjs.org/ due to a req        uest error during revalidation.
                                  npm ERR! code EINTEGRITY
                                  npm ERR! errno EINTEGRITY
                                  npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/        require-main-filename: Integrity verification failed for sha512-mt/8/lQDEN6TRunL        156JlOqfF1v32IYOe2Ey6+rn43FdBDLSNSblDErg9i/vfuLWA0PWo/NS6vOwM8iCP+SaSg== (/home/        iobroker/.npm/_cacache/content-v2/sha512/9a/df/fcfe540310de9346e9cbd79e8994ea9f1        75bf7d8860e7b6132ebeae7e3715d0432d23526e50c4ae0f62fef7ee2d60343d6a3f352eaf3b033c        8823fe49a4a)
                                  npm ERR!     /home/iobroker/.npm/_logs/2019-10-14T09_52_21_098Z-debug.log
                                  Host "iobrocker" (linux) updated
                                  Execute: chmod -R 777 /opt/iobroker
                                  • F freaktech
                                    NPM version: 6.12.0
                                    AlCalzoneA Offline
                                    AlCalzoneA Offline
                                    AlCalzone
                                    Da ist der Fehler wieder... Irgendwas ist bei dir da faul. Alles was ich zu dem Fehler finde sagt entweder Proxy falsch konfiguriert oder npm-Cache kaputt. Das hatten wir aber beides ausgeschlossen.
                                    Hast du noch einen Pi, auf dem du testen kannst? D.h. ioBroker installieren und dein Backup vom aktuellen Pi einspielen?
                                    EDIT:
                                    Probiere nochmal ein
                                    npm cache verify
                                    und/oder
                                    npm cache clean --force
                                    vor dem upgrade.
                                    • F Offline
                                      freaktech
                                      probier ich nachher
                                      und dass der HUE nicht grün wird?
                                      • apollon77A Online
                                        apollon77A Online
                                        Ok, mach mal:
                                        curl -v https://registry.npmjs.org/
                                        Falls Curl nicht installiert ist
                                        wget -qO- https://registry.npmjs.org/
                                        • F Offline
                                          freaktech
                                          @apollon77 said in PI4 Lässt JS Kontrolle nicht updaten:
                                          bringt auch nix
                                          NPM version: 6.12.0
                                          npm install iobroker.js-controller@2.0.29 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
                                          npm WARN registry Unexpected warning for https://registry.npmjs.org/: Miscellaneous Warning ENODATA: Cache input stream was empty
                                          npm WARN registry Using stale data from https://registry.npmjs.org/ due to a request error during revalidation.
                                          npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/y18n: Integrity verification failed for sha512-nT7014PDaWpa3jrXmq1tS07aiudLEjWmD1iEbLzOxO/4+6DMqVptZ1Scz5PnnN/haHCZTAmWOMNvHKfY32wv9A== (/home/iobroker/.npm/_cacache/content-v2/sha512/9d/3e/f4d783c3696a5ade3ad79aad6d4b4eda8ae74b1235a60f58846cbccec4eff8fba0cca95a6d67549ccf93e79cdfe16870994c099638c36f1ca7d8df6c2ff4)
                                          npm ERR!     /home/iobroker/.npm/_logs/2019-10-14T10_22_22_506Z-debug.log
                                          soll ich mir ein neues PI4 Image runterladen und dann mit backitup restoren ?!?
                                          ist zwar mords aufwändig wieder aber aktuell geht der HUE scheinbar nicht mehr
