  4. PI4 Lässt JS Kontrolle nicht updaten
js-controller 2.0.25
106 Beiträge 8 Kommentatoren 13.9k Aufrufe 9 Beobachtet
  • F Offline
    freaktech
    Hi!
    Ich hab nen PI 4 und er schlägt mir vor den JS upzudaten
    Image:
    ioBroker Image für Raspberry Pi2/3/4 Buster mit piVCCU 20190723
    es kommt dann immer dieser Fehler:
    lg
    tom
    pi@iobrocker:/opt/iobroker $ sudo iobroker upgrade self
    Update js-controller from @1.5.14 to @2.0.25
    NPM version: 6.12.0
    npm install iobroker.js-controller@2.0.25 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
    npm WARN registry Unexpected warning for https://registry.npmjs.org/: Miscellaneous Warning ENODATA: Cache input stream was empty
    npm WARN registry Using stale data from https://registry.npmjs.org/ due to a request error during revalidation.
    npm ERR! code EINTEGRITY
    npm ERR! errno EINTEGRITY
    npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/get-caller-file: Integrity verification failed for sha512-IfwTILdYjp+Ukq2yLXk0yAqHSiUGHzUpHmnejtSMhGVNEMp+9NYf8fvPGycAdHHx+r64IPSjnRM4gc/DFuCbNw== (/home/iobroker/.npm/_cacache/content-v2/sha512/21/fc/1320b7588e9f9492adb22d7934c80a874a25061f35291e69de8ed48c84654d10ca7ef4d61ff1fbcf1b27007471f1fabeb820f4a39d133881cfc316e09b37)
    npm ERR! /home/iobroker/.npm/_logs/2019-10-13T12_27_20_625Z-debug.log
    Host "iobrocker" (linux) updated
    Execute: chmod -R 777 /opt/iobroker
    Chmod finished. Restart controller
    Starting node restart.js
    • F Offline
      freaktech
      das klappt auch nicht
      sudo -H -u iobroker npm install iobroker.js-controller
      npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/yargs-parser: Integrity verification failed for sha512-SeQhve+jcDUw0frQ8bbOinZUc8cXcMxs1waTgkCXH9D5W4Fua3Ns8bwPhGe0GX+Jky2cwYGm/pZAnNsMq8O0UQ== (/home/iobroker/.npm/_cacache/content-v2/sha512/49/e4/21bdefa3703530d1fad0f1b6ce8a765473c71770cc6cd706938240971fd0f95b816e6b736cf1bc0f8467b4197f89932d9cc181a6fe96409cdb0cabc3b451)
      npm ERR! /home/iobroker/.npm/_logs/2019-10-13T13_01_36_269Z-debug.log
      GlasfaserG AlCalzoneA 2 Antworten Letzte Antwort
      • F freaktech
        GlasfaserG Offline
        GlasfaserG Offline
        @freaktech
        Link Text
        F 1 Antwort Letzte Antwort
        • GlasfaserG Glasfaser
          @freaktech
          Link Text
          freaktech
          @Glasfaseja gelesen, zumindest was mir nicht ganz fremd ist
          Finde die Lösung trotzdem nicht
          • F freaktech
            AlCalzoneA Offline
            AlCalzoneA Offline
            AlCalzone
            @freaktech sagte in PI4 Lässt JS Kontrolle nicht updaten:
            npm stellt fest, dass der Hash des heruntergeladenen Pakets nicht mit dem übereinstimmt, was er sein sollte. Sitzt du ggf. hinter einem Proxy, der an den Antworten was ändert?
            • AlCalzoneA AlCalzone
              freaktech
              @AlCalzone
              Nein ganz normales Standard Internet privat
              • F freaktech
                @AlCalzone
                AlCalzoneA Offline
                AlCalzoneA Offline
                AlCalzone
                @freaktech Hast du eine package-lock.json in /opt/iobroker? Wenn ja, dann mal löschen und Installation nochmal probieren.
                • F Offline
                  freaktech
                  Wie prüf ich das ? Bin ja erst ) Wochen hier
                  • F freaktech
                    Jan1
                    @freaktech
                    na in dem Du in das Verzeichnis gehst und schaust ob die Datei dort vorhanden ist
                    • F Offline
                      freaktech
                      grad gemacht wieder
                      ^[[Api@iobrocker:/opt/iobroker $ sudo iobroker upgrade self
                      NPM version: 6.12.0
                      npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/require-main-filename: Integrity verification failed for sha512-mt/8/lQDEN6TRunL156JlOqfF1v32IYOe2Ey6+rn43FdBDLSNSblDErg9i/vfuLWA0PWo/NS6vOwM8iCP+SaSg== (/home/iobroker/.npm/_cacache/content-v2/sha512/9a/df/fcfe540310de9346e9cbd79e8994ea9f175bf7d8860e7b6132ebeae7e3715d0432d23526e50c4ae0f62fef7ee2d60343d6a3f352eaf3b033c8823fe49a4a)
                      npm ERR! /home/iobroker/.npm/_logs/2019-10-13T15_18_13_497Z-debug.log
                      pi@iobrocker:/opt/iobroker $ ^C
                      pi@iobrocker:/opt/iobroker $ dir
                      backups install lib README.md
                      CHANGELOG_FIXER_LINUX.md INSTALLER_INFO.txt LICENSE reinstall.js
                      CHANGELOG_INSTALLER_LINUX.md iob log
                      etc iobroker node_modules
                      fix_installation.sh iobroker-data package.json
                      • F freaktech
                        grad gemacht wieder
                        NPM version: 6.12.0
                        AlCalzoneA Offline
                        AlCalzoneA Offline
                        AlCalzone
                        @freaktech Nach diesem Post sollte es helfen, den NPM-Cache zu reparieren:
                        npm cache verify
                        dann erneut probieren.
                        • F Offline
                          freaktech
                          @AlCalzone said in PI4 Lässt JS Kontrollupdaten:
                          npm cache verify
                          leider bringt res auch keinen Erfolg
                          pi@iobrocker:/opt/iobroker $ npm cache verify
                          Cache verified and compressed (~/.npm/_cacache):
                          Content verified: 1488 (56506421 bytes)
                          Content garbage-collected: 65 (2812582 bytes)
                          Index entries: 2519
                          Finished in 12.571s
                          NPM version: 6.12.0
                          npm ERR! /home/iobroker/.npm/_logs/2019-10-13T16_40_06_853Z-debug.log
                          • F Offline
                            freaktech
                            hat noch wer eine Idee?
                            lg
                            tom
                            sigi234S AlCalzoneA 2 Antworten Letzte Antwort
                            • F freaktech
                              lg
                              tom
                              sigi234S Online
                              sigi234S Online
                              lg
                              tom
                              Schon 2.0.29 latest installiert?
                              • sigi234S sigi234
                                lg
                                tom
                                AlCalzoneA Offline
                                AlCalzoneA Offline
                                AlCalzone
                                @sigi234 Das versucht er doch
                                • F freaktech
                                  lg
                                  tom
                                  AlCalzoneA Offline
                                  AlCalzoneA Offline
                                  AlCalzone
                                  Die Holzhammer-Methode (bitte vorher Backup machen, falls die Installation dann immer noch nicht klappt):
                                  cd /opt/iobroker
                                  rm package-lock.json
                                  rm -rf node_modules
                                  npm cache clear --force
                                  npm i --production --ignore-scripts
                                  AphofisA 1 Antwort Letzte Antwort
                                    sigi234S Online
                                    sigi234S Online
                                    @AlCalzone sagte in PI4 Lässt JS Kontrolle nicht updaten:
                                    Ja, aber nochmal
                                    • sigi234S sigi234
                                      Ja, aber nochmal
                                      AlCalzoneA Offline
                                      AlCalzoneA Offline
                                      AlCalzone
                                      @sigi234 Bitte lesen... Er versucht es - npm lässt ihn nicht...
                                        sigi234S Online
                                        sigi234S Online
                                        Ja dachte weil Warning ENODATA: Cache input stream was empty
                                        • F Offline
                                          freaktech
                                          genau, geht heute genausowenig wie gestern
                                          NPM version: 6.12.0
                                          npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/y18n: Integrity verification failed for sha512-nT7014PDaWpa3jrXmq1tS07aiudLEjWmD1iEbLzOxO/4+6DMqVptZ1Scz5PnnN/haHCZTAmWOMNvHKfY32wv9A== (/home/iobroker/.npm/_cacache/content-v2/sha512/9d/3e/f4d783c3696a5ade3ad79aad6d4b4eda8ae74b1235a60f58846cbccec4eff8fba0cca95a6d67549ccf93e79cdfe16870994c099638c36f1ca7d8df6c2ff4)
                                          npm ERR! /home/iobroker/.npm/_logs/2019-10-14T07_22_48_474Z-debug.log
