  4. JavaScript
  5. Hilfe bei Javaskript Device Counter
javascript
24 Beiträge 4 Kommentatoren 4.8k Aufrufe 1 Beobachtet
  • A
    A
    Adnim
    schrieb am zuletzt editiert von Adnim
    Hi!
    der Cache Selektor zeile 11 "Error" funktioniert nicht mehr mit folgender Fehlermeldung. Das klappte aber immer so, jemand ne Idee was ich tun kann ?
    //Add device rules
    addDeviceCounter("lowbat",         $('channel[state.id=*LOWBAT]'),                     true);
    addDeviceCounter("lowbat",         $('channel[state.id=*lowbat]'),                      true);
    addDeviceCounter("sticky_unreach", $('channel[state.id=*.STICKY_UNREACH]'),              true);
    addDeviceCounter("unreach",        $('channel[state.id=*.UNREACH]'),                     true);
    addDeviceCounter("config_pending", $('channel[state.id=*.CONFIG_PENDING]'),              true);
    addDeviceCounter("Motion",  $('channel[state.id=*.MOTION]'),               true);
    addDeviceCounter("DutyCycle",  $('channel[state.id=*.DUTYCYCLE]'),               true);
    addDeviceCounter("Spannungsüberwachung",  $('channel[state.id=*.VOLTAGE]'),           function(state){return state<200;});
    addDeviceCounter("Auskühlschutz",  $('channel[state.id=*.ACTUAL_TEMPERATURE]'),           function(state){return state<14;});
    addDeviceCounter("ERROR",  $('channel[state.id=*.ERROR*]'),               function(state){return state>0;});
    addDeviceCounter("Heizbedarf",  $('channel[state.id=*.VALVE_STATE]'),           function(state){return state>15;});
    addDeviceCounter("Alive",         $('channel[state.id=*alive]'),                     false);
    addDeviceCounter("CONNECTED",         $('channel[state.id=*.connected]'),                     false);
    addDeviceCounter("open_shutters",  $('channel{TYPE=BLIND}[state.id=*.LEVEL]'),           function(state){return state>0;});
    addDeviceCounter("open_windows",   $('channel{TYPE=SHUTTER_CONTACT}[state.id=*.STATE]'), true);
     * Code - do not change anything bellow this line *
    function addDeviceCounter(name, selector, val_to_count) {
        //Total amount of devices found by selector
        var state_total = 'deviceCounter.' + name + '.total';
        createState(state_total, 0);
        //List of devices that match condition
        var state_list = 'deviceCounter.' + name + '.list';
        createState(state_list, "");
        //Number of devices that match condition
        var state_counter = 'deviceCounter.' + name + '.counter';
        createState(state_counter, 0);
        function countDevs(obj) {
            var d_count = 0;
            var d_list  = [];
            selector.each(function (id, i) {
                var status = getState(id).val;
                var obj    = getObject(id);
                if ((typeof val_to_count === 'function' && val_to_count(status)) ||
                    (typeof val_to_count === 'boolean'  && val_to_count == status)) {
                    //Get parent object
                    var parentChannelId = id.slice(id.lastIndexOf("."));
                    var parentDevicelId = id.split(".").slice(0,-2).join(".");
                    var deviceObject = getObject(parentDevicelId);
                    //remember device name
                    d_list.push(deviceObject.common.name);
                ++d_count;                                                 // Zählt die Anzahl der vorhandenen Geräte unabhängig vom Status
    //if ("state_counter" > 0) {event(name + "(" + d_count + "): " + d_list);
            setState(state_list,     d_list.join('<br>'));
            setState(state_counter,  d_list.length);
            setState(state_total,    d_count);
        //Re-evaluate when a device status changes
        selector.on(function(obj) {    // bei Zustandänderung *. LOWBAT in allen Gewerken
            countDevs(obj);
        //Re-evaluate each hour
        schedule("*/60 * * * *", countDevs);
        //Evaluate for the first time
        countDevs();
    javascript.0	2019-10-12 16:02:30.844	info	(13143) Stop script script.js.common.DeviceCounter
    javascript.0	2019-10-12 16:02:19.889	error	(13143) at Script.runInContext (vm.js:133:20)
    javascript.0	2019-10-12 16:02:19.889	error	(13143) at script.js.common.DeviceCounter:11:1
    javascript.0	2019-10-12 16:02:19.889	error	(13143) at addDeviceCounter (script.js.common.DeviceCounter:72:5)
    javascript.0	2019-10-12 16:02:19.889	error	(13143) at countDevs (script.js.common.DeviceCounter:40:18)
    javascript.0	2019-10-12 16:02:19.889	error	(13143) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:808:29)
    javascript.0	2019-10-12 16:02:19.889	error	(13143) at script.js.common.DeviceCounter:50:42
    javascript.0	2019-10-12 16:02:19.889	error	(13143) TypeError: Cannot read property 'common' of null
    javascript.0	2019-10-12 16:02:19.889	error	(13143) ^
    javascript.0	2019-10-12 16:02:19.889	error	(13143) d_list.push(deviceObject.common.name);
    javascript.0	2019-10-12 16:02:19.889	error	(13143) script.js.common.DeviceCounter: script.js.common.DeviceCounter:50
    javascript.0	2019-10-12 16:02:19.888	warn	(13143) Object "javascript.0.deviceCounter" does not exist
    GlasfaserG paul53P 2 Antworten Letzte Antwort
    • A Adnim
      Hi!
      //Add device rules
              var d_count = 0;
              var d_list  = [];
                      //Get parent object
              countDevs(obj);
          countDevs();
      GlasfaserG
      GlasfaserG
      @Adnim
      Datenpunkt nicht vorhanden !
      • GlasfaserG Glasfaser
        @Adnim
        A
        A
        Adnim
        @Glasfaser sagte in Hilfe bei Javaskript Device Counter:
        @Adnim
        den legt das skript aber doch eigentlich an!?
        • A Adnim
          @Adnim
          GlasfaserG
          GlasfaserG
          @Adnim
          und … ist er vorhanden !?
            @Adnim
            A
            A
            Adnim
            @Adnim
            sind alle da, der errors teil wird aber seit ein paar tagen nicht aktualisiert und wirft halt die Fehlermeldung
            • A Adnim
              @Adnim
              GlasfaserG
              GlasfaserG
              @Adnim
              Dein Bild ist zu klein , kann nichts erkennen .
              So sieht es bei mir aus
              • A
                A
                Adnim
                japp exakt so sieht es bei mir aus, nimm mal die // vor der Zeile 11 weg und starte das skript neu, das geht nicht mehr und habe ich auskommentiert das ich die andren funktionen erstmal nutzen kann
                • A Adnim
                  GlasfaserG
                  GlasfaserG
                  @Adnim
                  Alles in Ordnung ,keine ERROR Meldung ,
                  • A
                    A
                    Adnim
                    hmm ich starte mal neu
                    • A Adnim
                      A
                      A
                      Adnim
                      @Adnim sagte in Hilfe bei Javaskript Device Counter:
                      hilft nicht kommt immer die obige fehlermeldung
                      • A Adnim
                        GlasfaserG
                        GlasfaserG
                        @Adnim
                        Verstehe ich nicht !?
                        Hast du mal alle Datenpunkte gelöscht und das Skript dann mal neugestartet , damit die Datenpunkte " neu "erzeugt werden !!
                        Zeig mal einen aktuellen Log vom Fehler !
                        und einen Screenshot von den Datenpunkten , der besser zu erkennen ist.
                        • A Adnim
                          Hi!
                          //Add device rules
                                  var d_count = 0;
                                  var d_list  = [];
                                          //Get parent object
                                  countDevs(obj);
                              countDevs();
                          paul53P
                          paul53P
                          @Adnim sagte:
                          $('channel[state.id=.ERROR]')
                          Was liefert ?
                          $('channel[state.id=*.ERROR*]').each(function(id, i) {
                             log(id);
                          Produktiv: Asus PN42: N100 / 8 GB / 500 GB; Proxmox mit 2 VM (ioBroker / openCCU)
                          • A
                            A
                            Adnim
                            @paul53 sagte in Hilfe bei Javaskript Device Counter:
                            @Adnim sagte:
                            Was liefert ?
                            Da bekomm ich nen error, irgendwo fehlt eine klammer?
                            @Glasfaser
                            habe die objekte gelöscht sie werden angelegt ,dann stürzt das skript aber mit der Fehlermeldung ab, neustart hilft dann auch nicht
                            Danke euch!
                            • A Adnim
                              @Adnim sagte:
                              Was liefert ?
                              @Glasfaser
                              Danke euch!
                              GlasfaserG
                              GlasfaserG
                              @Adnim
                              … das Skript von paul53 in ein neues Skript starten !!!
                                @Adnim
                                A
                                A
                                Adnim
                                @Glasfaser
                                oh ok, habe ich versucht. Da kommt nix nur Start Skript im Log
                                • A Adnim
                                  @Glasfaser
                                  GlasfaserG
                                  GlasfaserG
                                  @Adnim
                                  so muss es aussehen :
                                  • A
                                    A
                                    Adnim
                                    sieht bei mir aber so aus
                                    • A Adnim
                                      GlasfaserG
                                      GlasfaserG
                                      @Adnim
                                      Datenpunkte mit ERROR ,die bei mir z.B aufgelistet werden :
                                      • A
                                        A
                                        Adnim
                                        ja habe ich auch ne ganze menge von den Errors States ,148 laut dem Skript er zählt sie ja beim ersten start
                                        aber irgendwie findet er sie nicht mit Pauls Skript, habe Neustart und den Fixer aber gleiches Ergebnis
                                        • A Adnim
                                          GlasfaserG
                                          GlasfaserG
                                          @Adnim
                                          Gib mal anstatt " ERROR" im Skript von paul53 ,"UNREACH" ein
                                          Zeig mal bitte die ausgabe von
                                          iobroker list adapters
                                          84.1k
