  4. ioBroker.zigbee Neue Geräte
zigbee cc2531
93 Beiträge 20 Kommentatoren 20.0k Aufrufe 18 Beobachtet
  • P plbartek89
    @Asgothian Z-Stack_Home_1.2 CC2531_DEFAULT_20190608
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    @plbartek89 OK.. damit müsste es eigentlich gehen. Kannst du bitte schauen ob es von dem Knopf Meldungen im Log gibt wenn
    • du den Log-Level auf info legst
    • du den Knopf betätigst.
    Danke.
    A.
    • P Offline
      plbartek89
      host.iobroker	2019-10-06 20:05:48.389	info	Restart adapter system.adapter.zigbee.0 because enabled
      host.iobroker	2019-10-06 20:05:48.389	error	instance system.adapter.zigbee.0 terminated with code 0 (OK)
      host.iobroker	2019-10-06 20:05:48.389	error	Caught by controller[0]: at ZigbeeController.emit (events.js:224:7)
      host.iobroker	2019-10-06 20:05:48.389	error	Caught by controller[0]: at emitMany (events.js:147:13)
      host.iobroker	2019-10-06 20:05:48.389	error	Caught by controller[0]: at ZigbeeController.onDevEvent (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1532:24)
      host.iobroker	2019-10-06 20:05:48.389	error	Caught by controller[0]: at Array.forEach (<anonymous>)
      host.iobroker	2019-10-06 20:05:48.389	error	Caught by controller[0]: at converters.forEach (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1542:17)
      host.iobroker	2019-10-06 20:05:48.388	error	Caught by controller[0]: at collectOptions (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1404:15)
      host.iobroker	2019-10-06 20:05:48.388	error	Caught by controller[0]: at collectOptions (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1549:29)
      host.iobroker	2019-10-06 20:05:48.388	error	Caught by controller[0]: at publish (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1538:23)
      host.iobroker	2019-10-06 20:05:48.388	error	Caught by controller[0]: at publishToState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1292:31)
      host.iobroker	2019-10-06 20:05:48.388	error	Caught by controller[0]: at Object.getter (/opt/iobroker/node_modules/iobroker.zigbee/lib/devstates.js:1439:90)
      host.iobroker	2019-10-06 20:05:48.384	error	Caught by controller[0]: TypeError: Cannot read property 'startsWith' of undefined
      • P plbartek89
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @plbartek89
        Installier bitte mit dem Link oben noch einmal neu, dann sollte der Fehler weg sein.
        A
        • P Offline
          plbartek89
          @Asgothian said in ioBroker.zigbee Neue Geräte:
          https://github.com/asgothian/ioBroker.zigbee/tarball/11.4-Devices
          host.iobroker	2019-10-06 20:44:18.982	info	instance system.adapter.zigbee.0 started with pid 1728
          host.iobroker	2019-10-06 20:43:48.951	info	Restart adapter system.adapter.zigbee.0 because enabled
          host.iobroker	2019-10-06 20:43:48.950	error	instance system.adapter.zigbee.0 terminated with code 0 (OK)
          Caught	2019-10-06 20:43:48.950	error	by controller[0]: at ZigbeeController.emit (events.js:224:7)
          Caught	2019-10-06 20:43:48.950	error	by controller[0]: at emitMany (events.js:147:13)
          Caught	2019-10-06 20:43:48.950	error	by controller[0]: at ZigbeeController.onDevEvent (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1532:24)
          Caught	2019-10-06 20:43:48.949	error	by controller[0]: at Array.forEach (<anonymous>)
          Caught	2019-10-06 20:43:48.949	error	by controller[0]: at converters.forEach (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1542:17)
          Caught	2019-10-06 20:43:48.946	error	by controller[0]: at collectOptions (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1404:15)
          Caught	2019-10-06 20:43:48.946	error	by controller[0]: at collectOptions (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1549:29)
          Caught	2019-10-06 20:43:48.946	error	by controller[0]: at publish (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1538:23)
          Caught	2019-10-06 20:43:48.946	error	by controller[0]: at publishToState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1292:31)
          Caught	2019-10-06 20:43:48.945	error	by controller[0]: at Object.getter (/opt/iobroker/node_modules/iobroker.zigbee/lib/devstates.js:1439:90)
          Caught	2019-10-06 20:43:48.944	error	by controller[0]: TypeError: Cannot read property 'startsWith' of undefined
          zigbee.0	2019-10-06 20:43:48.881	error	at ZigbeeController.emit (events.js:224:7)
          zigbee.0	2019-10-06 20:43:48.881	error	at emitMany (events.js:147:13)
          zigbee.0	2019-10-06 20:43:48.881	error	at ZigbeeController.onDevEvent (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1532:24)
          zigbee.0	2019-10-06 20:43:48.881	error	at Array.forEach (<anonymous>)
          zigbee.0	2019-10-06 20:43:48.881	error	at converters.forEach (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1542:17)
          zigbee.0	2019-10-06 20:43:48.881	error	at collectOptions (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1404:15)
          zigbee.0	2019-10-06 20:43:48.881	error	at collectOptions (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1549:29)
          zigbee.0	2019-10-06 20:43:48.881	error	at publish (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1538:23)
          zigbee.0	2019-10-06 20:43:48.881	error	at publishToState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1292:31)
          zigbee.0	2019-10-06 20:43:48.881	error	at Object.getter (/opt/iobroker/node_modules/iobroker.zigbee/lib/devstates.js:1439:90)
          zigbee.0	2019-10-06 20:43:48.881	error	TypeError: Cannot read property 'startsWith' of undefined
          danach startet der adapter nicht mehr
          host.iobroker	2019-10-06 20:44:21.539	error	instance system.adapter.zigbee.0 terminated with code 1 ()
          Caught	2019-10-06 20:44:21.539	error	by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/main.js:20:23)
          Caught	2019-10-06 20:44:21.539	error	by controller[0]: at require (internal/module.js:11:18)
          Caught	2019-10-06 20:44:21.539	error	by controller[0]: at Module.require (module.js:597:17)
          Caught	2019-10-06 20:44:21.538	error	by controller[0]: at Function.Module._load (module.js:498:3)
          Caught	2019-10-06 20:44:21.538	error	by controller[0]: at tryModuleLoad (module.js:506:12)
          Caught	2019-10-06 20:44:21.538	error	by controller[0]: at Module.load (module.js:566:32)
          Caught	2019-10-06 20:44:21.538	error	by controller[0]: at Object.Module._extensions..js (module.js:664:10)
          Caught	2019-10-06 20:44:21.538	error	by controller[0]: at Module._compile (module.js:617:28)
          Caught	2019-10-06 20:44:21.537	error	by controller[0]: at Object.runInThisContext (vm.js:139:10)
          Caught	2019-10-06 20:44:21.537	error	by controller[0]: at createScript (vm.js:80:10)
          Caught	2019-10-06 20:44:21.537	error	by controller[0]: SyntaxError: Unexpected identifier
          Caught	2019-10-06 20:44:21.537	error	by controller[0]: ^^^^^^^
          Caught	2019-10-06 20:44:21.537	error	by controller[0]: getter: payload => (typeof(payload.action) === "string") ? (payload.action === 'brightness_up' ? 'up' : (payload.action payload.action.startsWith('brightness') ? payload.act
          Caught	2019-10-06 20:44:21.536	error	by controller[0]: /opt/iobroker/node_modules/iobroker.zigbee/lib/devstates.js:1439
          AsgothianA 2 Antworten Letzte Antwort
          • P plbartek89
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            @plbartek89 moment.. bei mir hat er gestartet... ich prüf das.
            • P plbartek89
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              @plbartek89
              So, jetzt bitte nochmal, jetzt muss es gehen.
              A.
              P 1 Antwort Letzte Antwort
              • AsgothianA Asgothian
                @plbartek89
                A.
                plbartek89
                @Asgothian
                jetzt
                zigbee.0	2019-10-07 12:45:15.812	info	new dev 0x14b457fffecbaf5d 13770 TRADFRI on/off switch
                zigbee.0	2019-10-07 12:44:46.857	error	Device 14b457fffecbaf5d "TRADFRI on/off switch" not described in statesMapping.
                zigbee.0	2019-10-07 12:44:13.633	info
                ```	Zigbee: allowing new devices to join.
                vielleicht mache ich was falsch. Glaube aber nicht.
                • P plbartek89
                  @Asgothian
                  jetzt
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  @plbartek89 sagte in ioBroker.zigbee Neue Geräte:
                  Taucht er denn mit Bild in der Device Ansicht im Adapter auf ?
                  A.
                  • P Offline
                    plbartek89
                    Nachdem ich die letzte ver. aufgespielt habe ,nicht mehr. Das ist aber nicht der switch was auf dem Bild zu sehen ist , falls das wichtig ist.👍
                    • P plbartek89
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      @plbartek89 Poste bitte mal ein Bild, und jetzt bin ich irritiert. An meiner Version hat sich (im Bezug auf den Switch) nur etwas in den states getan - wenn er mit dem Bug erkannt wurde sollte er auch jetzt erkannt werden.
                      A.
                      • P Offline
                        plbartek89
                        E1743 sowas habe ich.
                        Die bilder wie das ganze im IOB aussieht :
                        IOB
                        alt text
                        Das ist glaube ich der kabellose dimmer
                        Dimmer
                        • P plbartek89
                          IOB
                          alt text
                          Dimmer
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          @plbartek89
                          Ok.. das Bild kann ich tauschen. Die Datenpunkte sehen auch so aus wie ich sie erwarte.
                          Wenn du den Adapter auf "info" logging stellst kommen aber immer noch keine Log-Meldungen mit den Nachrichten des Knopfes an den adapter ?
                          A.
                          Nachtrag: was passiert wenn du in der Kachel auf das "i" drückst, nachdem du einen Knopf auf der FB gedrückt hast ?
                          • P Offline
                            plbartek89
                            schrieb am zuletzt editiert von plbartek89
                            @Asgothian Nachtrag: was passiert wenn du in der Kachel auf das "i" drückst, nachdem du einen Knopf auf der FB gedrückt hast ?
                            Firmware Version: 2.2.008
                                Hardware Version: 1
                            hat aber nur einmal funktioniert :
                            im log
                            zigbee.0	2019-10-09 11:38:58.513	error	Zigbee publish to '0x14b457fffecbaf5d', genBasic - 0 - [{"attrId":16384},{"attrId":3}] - 1 failed with error Error: AF data request fails, status code: 240. MAC transaction expired.
                            zigbee.0	2019-10-09 11:38:43.516	error	Zigbee publish to '0x14b457fffecbaf5d', genBasic - 0 - [{"attrId":16384},{"attrId":3}] - 1 failed with error Error: AF data request fails, status code: 240. MAC transaction expired.
                            zigbee.0	2019-10-09 11:37:42.296	info	Successfully configured 0x14b457fffecbaf5d TRADFRI on/off switch
                            zigbee.0	2019-10-09 11:37:34.127	error	Zigbee publish to '0x14b457fffecbaf5d', genBasic - 0 - [{"attrId":16384},{"attrId":3}] - 1 failed with error Error: AF data request fails, status code: 240. MAC transaction expired.
                            zigbee.0	2019-10-09 11:36:19.521	error	Zigbee publish to '0x14b457fffecbaf5d', genBasic - 0 - [{"attrId":16384},{"attrId":3}] - 1 failed with error Error: AF data request fails, status code: 240. MAC transaction expired.
                            zigbee.0	2019-10-09 11:35:39.534	info	new dev 0x14b457fffecbaf5d 13770 TRADFRI on/off switch
                            zigbee.0	2019-10-09 11:35:12.162	info	Dev 0x14b457fffecbaf5d TRADFRI on/off switch not configured yet (2), will retry on next incoming message.
                            zigbee.0	2019-10-09 11:34:16.533	error	Zigbee publish to '0x14b457fffecbaf5d', genBasic - 0 - [{"attrId":16384},{"attrId":3}] - 1 failed with error Error: AF data request fails, status code: 240. MAC transaction expired.
                            U 1 Antwort Letzte Antwort
                              @plbartek89
                              So, nachdem es jetzt ein paar tage gedauert hab hab ich eine Version des Adapters der den Zigbee on.off switch unterstützen müsste. Testen kannte ich das nicht, ich hab keinen.
                              Auch der FNB56-SKT1JXN1.0 von @klausiob kann gehen.
                              A.
                              klausiob
                              @Asgothian So nachdem ich aus dem Urlaub zurück bin könnte ich das ja mal testen. Es scheint aber noch nicht fehlerfrei zu sein? Wie muß ich den Tarball installieren?
                              Pi4B, Pi3B+, Master-Slave, EchoPlus, 3xEchoDot, FireTVstick, Xiaomi Sensoren, Fritzbox, DECT200, HS100, ZBT-ExtendedColor (ALDI), Shelly 2.5, 2xZigBee-Router-Plugs, Sileno 500 smart, Somfy switch, IONIQ5, tibber
                              node.js: 22.21.0 - npm: 10.9.4 - linux: raspbian-trixie - admin 7.7.19 - vis 1.5.6 - js-controller: 7.0.7
                              • K klausiob
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                @klausiob in der Adapter Ansicht, Experten Modus, Katzen Icon nehmen und den weiter oben im thread angegebenen link nutzen.
                                A.
                                  A.
                                  klausiob
                                  schrieb am zuletzt editiert von klausiob
                                  @Asgothian Danke, ist ja einfach 😊
                                  Hat aber leider keine Verbesserung gebracht. Habe das Gefühl, dass es ab Version 0.11.3 schlechter lief. Habe mal 0.10.2 installiert. Da zeigt er alles in der Netzwerkkarte gut an, ab 0.11.3 nicht mehr, auch die Router-Steckdose nur ohne Bild. Das hatte ich aber schon hingekriegt (s.o.).20191014 Zigbee Mesh.JPG Können sich die Router nur mit dem Koordinator verbinden? Insgesamt ist das Zigbee aber eine wackeliche Sache und für Sicherheit im Haus für mich fraglich. Welche Erfahrungen hast Du da? Hatte gehofft so eine Routerkette im Haus aufzubauen.
                                  • K klausiob
                                    klausiob
                                    @Asgothian Also mit der Version 0.10.2 funktioniert das Netzwerk und vorallem die Netzwerkkarte gut. Mit meinen Anpassungen in /opt/iobroker/node_modules/iobroker.zigbee/lib/devstates.js und devices.js arbeitet FNB56-SKT1JXN1.0 als Router. (keine log-Fehler) Dabei verbindet er sich mit allen Routern und dem Coordinator, arbeitet aber nur mit einem zusammen (blaue Zahlen). Zu den inaktiven Verbindungen sieht man rote Zahlen.
                                    Ich werde nun mal wieder auf 0.11.3 und dann 0.11.4 upgraden, denn schalten läßt sich die Steckdose noch nicht.
                                    • K klausiob
                                      AsgothianA Offline
                                      AsgothianA Offline
                                      Asgothian
                                      @klausiob
                                      Die Netzwerkkarte solltest du nicht überbewerten. Sie ist nur eine Momentaufnahme eines dynamischen Netzes.
                                      Vor der0.11..4 wird deine Steckdose nicht schalten.
                                      A.
                                        @klausiob
                                        A.
                                        klausiob
                                        @Asgothian OK. Habe seit gestern nach 0.11.3 wieder 0.11.4 installiert. Hier zeigt er in der Netzwerkkarte öfters den Coordinator rot an, was sonst nie war. Da zeigt er im Netzwerk nur Verbindungen mit dem Coordinator. Man muß ziemlich lange warten bis der mal grün wird. Dann zeigt er was hinter den Routern ist. Meine Steckdose ist zwar da und arbeitet als Router, aber läßt sich nicht schalten.
                                        Wenn ich den Datenpunkt schalte, kommt 2x diese Meldung. (Wo ist bei Dir der Modelname überall eingetragen?)
                                        error	Unknown device model FNB56-SKT1JXN1.0
                                        • K klausiob
                                          arteckA Offline
                                          arteckA Offline
                                          arteck
                                          @klausiob dann ist der nicht im converter
