  4. Test js-controller v2.0.x (GitHub)
    1.9k
    1.6k
js-controller
1.0k Beiträge 48 Kommentatoren 440.5k Aufrufe 35 Beobachtet
  • apollon77A apollon77
    @sven12 tut er noch oder nur "rot?
    S
    S
    sven12
    #497
    @apollon77 sagte in [Aufruf] js-controller 2.0 Beta Test:
    Ob er noch tut kann ich jetzt gerade nicht testen. Reiche ich aber morgen nach....
    Sven
    Hier das Logfile
    2019-10-03 22:19:06.731  - debug: shelly.0 (20158) objectDB connected
    2019-10-03 22:19:06.735  - debug: shelly.0 (20158) Redis States: Use Redis connection: 0.0.0.0:9000
    2019-10-03 22:19:06.738  - debug: shelly.0 (20158) Objects connected to redis: 0.0.0.0:9001
    2019-10-03 22:19:06.742  - debug: shelly.0 (20158) statesDB connected
    2019-10-03 22:19:06.757  - debug: shelly.0 (20158) States connected to redis: 0.0.0.0:9000
    2019-10-03 22:19:07.699  - info: shelly.0 (20158) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.16.1
    2019-10-03 22:19:07.755  - info: shelly.0 (20158) Stating Shelly adapter in CoAP modus.
    2019-10-03 22:19:07.824  - info: host.iobroker-host instance system.adapter.shelly.0 terminated with code 0 (NO_ERROR)
    2019-10-03 22:19:07.825  - info: host.iobroker-host Restart adapter system.adapter.shelly.0 because enabled
    2019-10-03 22:19:08.676  - info: host.iobroker-host instance system.adapter.shelly.0 started with pid 20387
    2019-10-03 22:19:09.600  - debug: shelly.0 (20387) Redis Objects: Use Redis connection: 0.0.0.0:9001
    2019-10-03 22:19:09.642  - debug: shelly.0 (20387) objectDB connected
    2019-10-03 22:19:09.644  - debug: shelly.0 (20387) Redis States: Use Redis connection: 0.0.0.0:9000
    2019-10-03 22:19:09.645  - debug: shelly.0 (20387) Objects connected to redis: 0.0.0.0:9001
    2019-10-03 22:19:09.649  - debug: shelly.0 (20387) statesDB connected
    2019-10-03 22:19:09.659  - debug: shelly.0 (20387) States connected to redis: 0.0.0.0:9000
    2019-10-03 22:19:10.512  - info: shelly.0 (20387) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.16.1
    2019-10-03 22:19:10.558  - info: shelly.0 (20387) Stating Shelly adapter in CoAP modus.
    2019-10-03 22:19:10.645  - info: host.iobroker-host instance system.adapter.shelly.0 terminated with code 0 (NO_ERROR)
    2019-10-03 22:19:10.646  - info: host.iobroker-host Restart adapter system.adapter.shelly.0 because enabled
    2019-10-03 22:19:22.846  - info: host.iobroker-host instance system.adapter.poolcontroller.0 terminated with code 0 (NO_ERROR)
    2019-10-03 22:19:40.682  - info: host.iobroker-host instance system.adapter.shelly.0 started with pid 21308
    2019-10-03 22:19:41.789  - debug: shelly.0 (21308) Redis Objects: Use Redis connection: 0.0.0.0:9001
    2019-10-03 22:19:41.834  - debug: shelly.0 (21308) objectDB connected
    2019-10-03 22:19:41.835  - debug: shelly.0 (21308) Redis States: Use Redis connection: 0.0.0.0:9000
    2019-10-03 22:19:41.837  - debug: shelly.0 (21308) Objects connected to redis: 0.0.0.0:9001
    2019-10-03 22:19:41.841  - debug: shelly.0 (21308) statesDB connected
    2019-10-03 22:19:41.853  - debug: shelly.0 (21308) States connected to redis: 0.0.0.0:9000
    2019-10-03 22:19:43.147  - info: shelly.0 (21308) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.16.1
    2019-10-03 22:19:43.884  - info: shelly.0 (21308) Stating Shelly adapter in CoAP modus.
    2019-10-03 22:19:44.298  - info: host.iobroker-host instance system.adapter.shelly.0 terminated with code 0 (NO_ERROR)
    2019-10-03 22:19:44.298  - info: host.iobroker-host Restart adapter system.adapter.shelly.0 because enabled
    2019-10-03 22:20:00.050  - info: host.iobroker-host instance system.adapter.poolcontroller.0 started with pid 21795
    • S sven12
      gerade von 2.0.17 auf 2.0.21 gewechselt.
      Seitdem ist der Shelly Adapter rot.
      2019-10-03 19:45:38.196 - debug: shelly.0 (7340) Redis Objects: Use Redis connection: 0.0.0.0:9001
      2019-10-03 19:45:38.258 - debug: shelly.0 (7340) Objects connected to redis: 0.0.0.0:9001
      2019-10-03 19:45:38.267 - debug: shelly.0 (7340) objectDB connected
      2019-10-03 19:45:38.267 - debug: shelly.0 (7340) Redis States: Use Redis connection: 0.0.0.0:9000
      2019-10-03 19:45:38.271 - debug: shelly.0 (7340) statesDB connected
      2019-10-03 19:45:38.280 - debug: shelly.0 (7340) States connected to redis: 0.0.0.0:9000
      2019-10-03 19:45:39.156 - info: shelly.0 (7340) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.16.1
      2019-10-03 19:45:39.287 - info: shelly.0 (7340) Stating Shelly adapter in CoAP modus.
      Mit der 2.0.17 wars noch ok
      Sven
      StuebiS
      StuebiS
      Stuebi
      #498
      @sven12 , ich habe gerade den Fall nachgestellt. D.h. Shelly Adapter 3.1.0 und js-controller in Version 2.0.21 im CoAP Modus installiert. Funktioniert bei mir wunderbar. Der Adapter wird nicht neu gestartet. Siehst Du irgendwelche Fehlermeldungen im Logfile (rote Error Meldungen)?
      Hast Du Redis installiert? Das habe ich mir auf der Maschine nicht.
      Stübi
      ioBroker auf Synology DS216+II im Docker Container
      • apollon77A
        apollon77A
        #499
        Hi All,
        auf GitHub wartet die 2.0.22 auf Euch. Das JavaScript ZIP Download sollte damit gefixt sein und ich habe auch etwas an der Performance gearbeitet.
        @SBorg Wie lange braucht daswetter jetzt? (Aber nicht zuviel erwarten ...)
        • SBorgS
          SBorgS
          SBorg
          #500
          Juckt zwar in den Fingern, aber jetzt laufen bei mir gleich sämtliche Tagesskripte, muss bis morgen früh warten :(
          LG SBorg ( SBorg auf GitHub)
          apollon77A 2 Antworten Letzte Antwort
          • SBorgS SBorg
            apollon77A
            apollon77A
            #501
            @SBorg Also auf meinem redis/redis system braucht daswetter mit 2700 Werten 10s :-) Ich stelle das dann mal auf file/file um ...
            • SBorgS SBorg
              apollon77A
              apollon77A
              #502
              @SBorg Brauchst nicht traurig sein ... meine Optimierungen haben weniger gebracht als ich dachte :-(
              • redis/redis laufen 2700 Werte in 10s durch
              • file/file sinds 130s
              Bin dran
              E SBorgS 2 Antworten Letzte Antwort
              • MathiasJM
                MathiasJM
                MathiasJ
                #503
                ..ich warte mal, bis der neue JS-Controller läuft.
                OT:
                Weiß jemand, ob man nodejs 12 schon gefahrlos installieren kann?
                Bei meiner Testinstallation wollte ja Radar2 und BLE nicht.
                IObroker auf dem NUC als VM.
                • MathiasJM MathiasJ
                  OT:
                  apollon77A
                  apollon77A
                  #504
                  @MathiasJ
                  Generell läuft alles. Es gibt nur bei Adaptern wie daswetter die in einem Schlag mehrere tausend Objekte anlegen und solche Dinge tun noch Performance-Themen.
                  nodejs12 - der controller kanns ... ich bin leider zeitlich komplett damit gebunden sodass ich gerade keinen Überblick habe welche Adapter aufgrund Ihrer Dependencies mit nodejs 12 laufen und welche nicht. Ich würde weiterhin auf 10 setzen
                    Bin dran
                    E
                    E
                    e-s
                    #505
                    Bin dran
                    Kann das auch zu generellen Performanceproblemen führen? Gefühlt ist das ganze System recht träge, nutze derzeit nur File.
                    Besonders stark ist mir das aufgefallen, als ich unter Adapter die Suche nutzen wollte. Kann dies damit zusammenhängen?
                    • E e-s
                      Bin dran
                      apollon77A
                      apollon77A
                      #506
                      @e-s Im Admin wird an sich alles initial geladen und alles andere (Filtern der Adapter und so) findet dann nur im Browser statt ... also in dem Fall eher nicht.
                      Ob man die aktuellen Performancethemen wirklich merkt weiss ich gerade nicht. Es kommt gerade vor allem bei Adaptern mit sehr vielen Object/State anlagen in einzelnen Aufrufen dazu das man es merkt weil sich da Dinge summieren ...
                        Bin dran
                        SBorgS
                        SBorgS
                        SBorg
                        #507
                        Bin dran
                        Och, traurig bin ich nicht ;)
                        ...aber wie du schon befürchtet hattest:
                        2.0.22
                        host.Ubuntu	2019-10-04 09:28:58.714	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                        daswetter.0	2019-10-04 09:26:07.998	info	(15967) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v8.16.1
                        host.Ubuntu	2019-10-04 09:26:00.090	info	instance system.adapter.daswetter.0 started with pid 15967
                        2.0.19
                        2019-10-03 23:28:55.784 - info: host.Ubuntu instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                        2019-10-03 23:28:55.484 - info: daswetter.0 (1180) Terminated (NO_ERROR): Without reason
                        2019-10-03 23:26:06.438 - info: daswetter.0 (1180) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v8.16.1
                        Also round about ~180 Sekunden und immer noch etwas mehr als 5x langsamer wie der 1.5.14. Aktuell würde bei mir nur noch ein Raspberry 4 mit 4GB RAM funktionieren.
                          Hi All,
                          sigi234S
                          sigi234S
                          #508
                          Hi All,
                          Aktualisiert, war extrem langsam danach. Nach einem Neustart ging es aber wieder.
                          Ja
                          Ja, kommt mir schneller vor. Die Ram-Auslastung wurde deutlich weniger. Kann das sein?
                          • sigi234S sigi234
                            Hi All,
                            Ja
                            apollon77A
                            apollon77A
                            #509
                            @sigi234 sagte in [Aufruf] js-controller 2.0 Beta Test:
                            RAM an sich eher nicht :-) Auch nach aktuellen tests sollten die Geschwindigkeitsgewinne eher klein ausgefallen sein :-(
                            • S sven12
                              Sven
                              Hier das Logfile
                              S
                              S
                              sven12
                              schrieb am zuletzt editiert von sven12
                              #510
                              @apollon77
                              bin jetzt auf 2.0.22. Shelly am Host immer noch rot und ohne Funktion.
                              Bei mir läuft ioBroker Host auf Debian 9 in einer VM unter Proxmox.
                              Ein Multihostclient auf Raspi.
                              Der Shelly Adapter auf dem Host läuft nicht und ist rot, wenn ich den auf den PI verschiebe funktioniert er dort aber.
                              Edit: Wobei ich erwähnen sollte, das die ip 192.168.10.57 der debian host ist, der client auf dem es läuft hat 192.168.10.25
                              Hier das Log vom pi
                              2019-10-04 14:24:08.435  - info: host.ccu2rfdpieasy instance system.adapter.shelly.0 started with pid 30156
                              2019-10-04 14:24:13.261  - debug: shelly.0 (30156) Redis Objects: Use Redis connection: 192.168.10.57:9001
                              2019-10-04 14:24:13.691  - debug: shelly.0 (30156) objectDB connected
                              2019-10-04 14:24:13.701  - debug: shelly.0 (30156) Redis States: Use Redis connection: 192.168.10.57:9000
                              2019-10-04 14:24:13.711  - debug: shelly.0 (30156) Objects connected to redis: 192.168.10.57:9001
                              2019-10-04 14:24:13.731  - debug: shelly.0 (30156) statesDB connected
                              2019-10-04 14:24:13.811  - debug: shelly.0 (30156) States connected to redis: 192.168.10.57:9000
                              2019-10-04 14:24:14.538  - info: shelly.0 (30156) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.16.1
                              2019-10-04 14:24:14.768  - info: shelly.0 (30156) Stating Shelly adapter in CoAP modus.
                              2019-10-04 14:24:15.312  - info: shelly.0 (30156) Listening for Shelly packets in the network
                              2019-10-04 14:24:19.295  - debug: shelly.0 (30156) CoAP status package received: {"3332":"SHSW-1#5BAC87#1","3412":38400,"3420":1024,"Uri-Path":"cit/s"} / {"G":[[0,112,1],[0,118,0]]}
                              2019-10-04 14:24:19.298  - debug: shelly.0 (30156) Status update received for SHSW-1#5BAC87#1: {"G":[[0,112,1],[0,118,0]]}
                              2019-10-04 14:24:19.303  - debug: shelly.0 (30156) CoAP device description request for SHSW-1#5BAC87#1 to 192.168.10.79(0)
                              2019-10-04 14:24:19.341  - debug: shelly.0 (30156) CoAP response: {"3332":"SHSW-1#5BAC87#1"}
                              2019-10-04 14:24:19.343  - debug: shelly.0 (30156) Device description received: {"3332":"SHSW-1#5BAC87#1"} / {"blk":[{"I":0,"D":"Relay0"},{"I":118,"T":"S","D":"Input","R":"0/1/2","L":1}],"sen":[{"I":112,"T":"Switch","R":"0/1","L":0}],"act":[{"I":211,"D":"Switch","L":0,"P":[{"I":2011,"D":"ToState","R":"0/1"}]}]}
                              2019-10-04 14:24:19.352  - info: shelly.0 (30156) Shelly device 192.168.10.79 (shelly1 / shelly1-5BAC87 / SHSW-1#5BAC87#1) with CoAP connected!
                              2019-10-04 14:24:19.430  - debug: shelly.0 (30156) CoAP Message for SHSW-1#5BAC87#1 : {"G":[[0,112,1],[0,118,0]]}
                              2019-10-04 14:24:19.432  - debug: shelly.0 (30156) Create State : SHSW-1#5BAC87#1.Relay0.Switch, Payload: {"G":[[0,112,1],[0,118,0]]}for SHSW-1#5BAC87#1
                              2019-10-04 14:24:19.435  - debug: shelly.0 (30156) State change : SHSW-1#5BAC87#1.Relay0.Switch, Value: true for 192.168.10.79 (shelly1 / shelly1-5BAC87 / SHSW-1#5BAC87#1)
                              2019-10-04 14:24:19.649  - debug: shelly.0 (30156) Set state SHSW-1#5BAC87#1.Relay0.AutoTimerOff, Value: 0 for 192.168.10.79 (shelly1 / shelly1-5BAC87 / SHSW-1#5BAC87#1)
                              2019-10-04 14:24:19.654  - debug: shelly.0 (30156) Set state SHSW-1#5BAC87#1.Relay0.AutoTimerOn, Value: 0 for 192.168.10.79 (shelly1 / shelly1-5BAC87 / SHSW-1#5BAC87#1)
                              2019-10-04 14:24:19.658  - debug: shelly.0 (30156) Set state SHSW-1#5BAC87#1.version, Value: "20190821-094851/v1.5.2@4148d2b7" for 192.168.10.79 (shelly1 / shelly1-5BAC87 / SHSW-1#5BAC87#1)
                              2019-10-04 14:24:19.749  - debug: shelly.0 (30156) Set state SHSW-1#5BAC87#1.firmware, Value: false for 192.168.10.79 (shelly1 / shelly1-5BAC87 / SHSW-1#5BAC87#1)
                              2019-10-04 14:24:19.755  - debug: shelly.0 (30156) Set state SHSW-1#5BAC87#1.uptime, Value: "01:31:39" for 192.168.10.79 (shelly1 / shelly1-5BAC87 / SHSW-1#5BAC87#1)
                              2019-10-04 14:24:19.757  - debug: shelly.0 (30156) Set state SHSW-1#5BAC87#1.hostname, Value: "192.168.10.79" for 192.168.10.79 (shelly1 / shelly1-5BAC87 / SHSW-1#5BAC87#1)
                              2019-10-04 14:24:19.760  - debug: shelly.0 (30156) Set state SHSW-1#5BAC87#1.rssi, Value: -56 for 192.168.10.79 (shelly1 / shelly1-5BAC87 / SHSW-1#5BAC87#1)
                              2019-10-04 14:24:24.939  - debug: shelly.0 (30156) Set state SHSW-1#5BAC87#1.uptime, Value: "01:31:44" for 192.168.10.79 (shelly1 / shelly1-5BAC87 / SHSW-1#5BAC87#1)
                              2019-10-04 14:24:24.942  - debug: shelly.0 (30156) Set state SHSW-1#5BAC87#1.rssi, Value: -57 for 192.168.10.79 (shelly1 / shelly1-5BAC87 / SHSW-1#5BAC87#1)
                              2019-10-04 14:24:30.121  - debug: shelly.0 (30156) Set state SHSW-1#5BAC87#1.uptime, Value: "01:31:50" for 192.168.10.79 (shelly1 / shelly1-5BAC87 / SHSW-1#5BAC87#1)
                              2019-10-04 14:24:30.126  - debug: shelly.0 (30156) Set state SHSW-1#5BAC87#1.rssi, Value: -56 for 192.168.10.79 (shelly1 / shelly1-5BAC87 / SHSW-1#5BAC87#1)
                              2019-10-04 14:24:34.249  - debug: shelly.0 (30156) CoAP data ignored: {"3332":"SHSW-1#5BAC87#1","3412":38400,"3420":1024,"Uri-Path":"cit/s"} / {"G":[[0,112,1],[0,118,0]]}
                              2019-10-04 14:24:35.308  - debug: shelly.0 (30156) Set state SHSW-1#5BAC87#1.uptime, Value: "01:31:55" for 192.168.10.79 (shelly1 / shelly1-5BAC87 / SHSW-1#5BAC87#1)
                              2019-10-04 14:24:35.313  - debug: shelly.0 (30156) Set state SHSW-1#5BAC87#1.rssi, Value: -54 for 192.168.10.79 (shelly1 / shelly1-5BAC87 / SHSW-1#5BAC87#1)
                              2019-10-04 14:24:40.493  - debug: shelly.0 (30156) Set state SHSW-1#5BAC87#1.uptime, Value: "01:32:00" for 192.168.10.79 (shelly1 / shelly1-5BAC87 / SHSW-1#5BAC87#1)
                              2019-10-04 14:24:40.496  - debug: shelly.0 (30156) Set state SHSW-1#5BAC87#1.rssi, Value: -55 for 192.168.10.79 (shelly1 / shelly1-5BAC87 / SHSW-1#5BAC87#1)
                              @Stuebi könnte also mit Redis zusammen hängen, möglicherweise ist es auf dem Pi drauf und auf dem Debian 9 x64 Host nicht.... Weiß nur nicht wie ich das rausfinden kann
                              • coyoteC
                                coyoteC
                                coyote
                                #511
                                @apollon77 update auf 2.0.22 mit Umstellung auf redis/redis sieht jetzt gut aus. Alles ohne Fehler in der Konsole durchgelaufen. web Adapter musste ich einmal neu durchstarten, der blieb rot.
                                Jetzt sind alle Adapter grün.
                                Aber es kamen öfter warn Meldungen im Log:
                                hm-rega.0	2019-10-04 16:47:32.742	warn	(1855) get state ReplyError: BUSY Redis is busy running a script. You can only call SCRIPT KILL or SHUTDOWN NOSAVE.
                                hm-rega.0	2019-10-04 16:47:32.741	warn	(1855) get state ReplyError: BUSY Redis is busy running a script. You can only call SCRIPT KILL or SHUTDOWN NOSAVE.
                                hm-rega.0	2019-10-04 16:47:32.740	warn	(1855) get state ReplyError: BUSY Redis is busy running a script. You can only call SCRIPT KILL or SHUTDOWN NOSAVE.
                                hm-rega.0	2019-10-04 16:47:32.725	warn	(1855) get state ReplyError: BUSY Redis is busy running a script. You can only call SCRIPT KILL or SHUTDOWN NOSAVE.
                                Was sagt mir das?
                                • S sven12
                                  @apollon77
                                  Hier das Log vom pi
                                  apollon77A
                                  apollon77A
                                  #512
                                  @sven12 Werden denn die Werte die da im log stehen so aktualisert? Auf was stehen die werte im Admin? Kannst Du schalten? bzw jetzt sag mal bitte ganz genau was "ist rot" bedeutet ... oder kannst Du nichts mehr schalten udn es kommen keine Werte an? Wo geprüft? Admin?
                                  • coyoteC coyote
                                    Was sagt mir das?
                                    apollon77A
                                    apollon77A
                                    #513
                                    @coyote Wann genau kam das? Beim Start von hm-rega? oder zwischendurch oder wann genau?
                                    coyoteC 1 Antwort Letzte Antwort
                                    • S sven12
                                      @apollon77
                                      Hier das Log vom pi
                                      apollon77A
                                      apollon77A
                                      #514
                                      @sven12 PS: Mit Redis hat das nichts zu tun.Nutzt Du doch gar nicht.
                                        coyoteC
                                        coyoteC
                                        coyote
                                        #515
                                        @apollon77 das kam bei mehreren Adapter beim starten, müsste nochmal nachschauen welche Adapter dabei waren.
                                        Aber momentan alles grün und noch nichts auffälliges
                                          S
                                          S
                                          sven12
                                          #516
                                          OK ich versuche es nochmal Verständlicher zu erklären.
                                          Normalerweise läuft der Shelly Adapter auf dem Host System. Der grüne Punkt im Admin ist normal ja grün (Punkt vor dem Adapter) wenn der Adapter läuft. Aktuell das nicht der Fall. Dort wird ein roter Punkt angezeigt. Ein schalten über die Objekte (switch true/flase) wird beim shelly nicht ausgeführt. Auch die Zustände unter Objekte ändern sich nicht wenn ich den Shelly über seine Weboberfläche schalte. Fazit Shelly Adapter roter Punkt davor und keine Funktion.
                                          Verschiebe ich die Shelly Instanz auf den client (ccu2rfdpieasy) bei mir ein pi3. Wird der Punkt vor dem Adapter grün. Der Shelly lässt sich über Objekte schalten. Änderungen der Schaltzustände am Shelly über die Shelly Weboberfläche werden dann auch unter ioBroker Objekte angezeigt.
                                          Ich hoffe es ist jetzt verständlich.
                                          Sven
                                          Hier noch die Logs als Ergänzung
                                          Hier keine Funktion beim Start der Instanz auf dem Host
                                          2019-10-04 18:36:23.356  - info: host.iobroker-host instance system.adapter.shelly.0 started with pid 30257
                                          2019-10-04 18:36:24.789  - debug: shelly.0 (30257) Redis Objects: Use Redis connection: 0.0.0.0:9001
                                          2019-10-04 18:36:25.439  - debug: shelly.0 (30257) Objects connected to redis: 0.0.0.0:9001
                                          2019-10-04 18:36:25.444  - debug: shelly.0 (30257) objectDB connected
                                          2019-10-04 18:36:25.446  - debug: shelly.0 (30257) Redis States: Use Redis connection: 0.0.0.0:9000
                                          2019-10-04 18:36:25.450  - debug: shelly.0 (30257) statesDB connected
                                          2019-10-04 18:36:25.461  - debug: shelly.0 (30257) States connected to redis: 0.0.0.0:9000
                                          2019-10-04 18:36:26.416  - info: shelly.0 (30257) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.16.1
                                          2019-10-04 18:36:26.487  - info: shelly.0 (30257) Stating Shelly adapter in CoAP modus.
                                          2019-10-04 18:36:26.561  - info: host.iobroker-host instance system.adapter.shelly.0 terminated with code 0 (NO_ERROR)
                                          2019-10-04 18:36:26.562  - info: host.iobroker-host Restart adapter system.adapter.shelly.0 because enabled
                                          Hier ein Startvorgang auf dem Client (Pi)
                                          2019-10-04 16:36:36.813  - info: host.ccu2rfdpieasy instance system.adapter.shelly.0 started with pid 1482
                                          2019-10-04 16:36:41.669  - debug: shelly.0 (1482) Redis Objects: Use Redis connection: 192.168.10.57:9001
                                          2019-10-04 16:36:42.083  - debug: shelly.0 (1482) objectDB connected
                                          2019-10-04 16:36:42.096  - debug: shelly.0 (1482) Redis States: Use Redis connection: 192.168.10.57:9000
                                          2019-10-04 16:36:42.109  - debug: shelly.0 (1482) Objects connected to redis: 192.168.10.57:9001
                                          2019-10-04 16:36:42.133  - debug: shelly.0 (1482) statesDB connected
                                          2019-10-04 16:36:42.246  - debug: shelly.0 (1482) States connected to redis: 192.168.10.57:9000
                                          2019-10-04 16:36:43.103  - info: shelly.0 (1482) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.16.1
                                          2019-10-04 16:36:43.280  - info: shelly.0 (1482) Stating Shelly adapter in CoAP modus.
                                          2019-10-04 16:36:43.783  - info: shelly.0 (1482) Listening for Shelly packets in the network
                                          2019-10-04 16:36:50.340  - debug: shelly.0 (1482) CoAP status package received: {"3332":"SHSW-1#5BAC87#1","3412":38400,"3420":1792,"Uri-Path":"cit/s"} / {"G":[[0,112,0],[0,118,0]]}
                                          2019-10-04 16:36:50.343  - debug: shelly.0 (1482) Status update received for SHSW-1#5BAC87#1: {"G":[[0,112,0],[0,118,0]]}
                                          2019-10-04 16:36:50.346  - debug: shelly.0 (1482) CoAP device description request for SHSW-1#5BAC87#1 to 192.168.10.79(0)
                                          2019-10-04 16:36:50.384  - debug: shelly.0 (1482) CoAP response: {"3332":"SHSW-1#5BAC87#1"}
                                          2019-10-04 16:36:50.386  - debug: shelly.0 (1482) Device description received: {"3332":"SHSW-1#5BAC87#1"} / {"blk":[{"I":0,"D":"Relay0"},{"I":118,"T":"S","D":"Input","R":"0/1/2","L":1}],"sen":[{"I":112,"T":"Switch","R":"0/1","L":0}],"act":[{"I":211,"D":"Switch","L":0,"P":[{"I":2011,"D":"ToState","R":"0/1"}]}]}
                                          2019-10-04 16:36:50.394  - info: shelly.0 (1482) Shelly device 192.168.10.79 (shelly1 / shelly1-5BAC87 / SHSW-1#5BAC87#1) with CoAP connected!
                                          2019-10-04 16:36:50.463  - debug: shelly.0 (1482) CoAP Message for SHSW-1#5BAC87#1 : {"G":[[0,112,0],[0,118,0]]}
                                          2019-10-04 16:36:50.466  - debug: shelly.0 (1482) Create State : SHSW-1#5BAC87#1.Relay0.Switch, Payload: {"G":[[0,112,0],[0,118,0]]}for SHSW-1#5BAC87#1
                                          2019-10-04 16:36:50.468  - debug: shelly.0 (1482) State change : SHSW-1#5BAC87#1.Relay0.Switch, Value: false for 192.168.10.79 (shelly1 / shelly1-5BAC87 / SHSW-1#5BAC87#1)
                                          83.8k
