  4. Test js-controller v2.0.x (GitHub)
js-controller
1.0k Beiträge 48 Kommentatoren 628.1k Aufrufe 35 Beobachtet
  • opossumO
    opossumO
    opossum
    schrieb am zuletzt editiert von opossum
    Habe mein Testsystem gerade angehoben, alle Adapter sind gestartet. Im Log habe ich nach dem Neustart folgenden Fehler:
    2019-09-19 06:25:00.141 - info: host.buster instance system.adapter.weatherunderground.0 started with pid 8917
    2019-09-19 06:25:00.192 - info: javascript.0 script.js.common.UWZ: []
    2019-09-19 06:25:01.059 - error: host.buster could not store process id list in /opt/iobroker/node_modules/iobroker.js-controller/pids.txt . Please check permissions and check left over processes when stopping ioBroker!
    Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/pids.txt'
    2019-09-19 06:25:02.455 - info: daswetter.0 starting. Version 2.8.0 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.16.3
    2019-09-19 06:25:02.813 - info: weatherunderground.0 starting. Version 3.1.1 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v10.16.3
    2019-09-19 06:25:03.518 - info: dwd.0 starting. Version 2.4.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v10.16.3
    2019-09-19 06:25:05.002 - info: dwd.0 Terminated (NO_ERROR): Without reason
    2019-09-19 06:25:05.017 - info: host.buster instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
    2019-09-19 06:25:06.018 - error: host.buster could not store process id list in /opt/iobroker/node_modules/iobroker.js-controller/pids.txt . Please check permissions and check left over processes when stopping ioBroker!
    2019-09-19 06:25:06.473 - info: weatherunderground.0 Terminated (NO_ERROR): Without reason
    2019-09-19 06:25:06.497 - info: host.buster instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
    2019-09-19 06:25:07.498 - error: host.buster could not store process id list in /opt/iobroker/node_modules/iobroker.js-controller/pids.txt . Please check permissions and check left over processes when stopping ioBroker!
    Nachdem ich die Rechte des Ordners iobroker.js-Controller auf 777 gesetzt hatte, war der Fehler nach einem Neustart nicht mehr vorhanden, jetzt ist auch die Datei pid.txt vorhanden. Könnte aber auch an Debian Buster liegen.
    Egbert
    https://www.schlepper-petersdorf.de
    arteckA apollon77A 2 Antworten Letzte Antwort
    • opossumO opossum
      Egbert
      arteckA
      arteckA
      arteck
      @opossum
      curl -sL https://iobroker.net/fix.sh | bash -
      hast du gemach t??
      opossumO 1 Antwort Letzte Antwort
      • apollon77A
        apollon77A
        Bei dem Fehler ist es denke ich mal interesssant wem die pids.txt gehört. Falls „root“ ist die Frage wie es dazu gekommen sein könnte. Weil damit das ist muss iobroker mal als root gestartet worden sein.
        • opossumO opossum
          Egbert
          apollon77A
          apollon77A
          @opossum sagte in [Aufruf] js-controller 2.0 Beta Test:
          Bitte nicht mehr mit chmod 777 arbeiten :-) Der Installation Fixer ist das Mittel der Wahl!
          • sigi234S
            sigi234S
            Fehlermeldung 1
            Adapter: iqcontrol:
            Die UI wird geöffnet, aber es kommen keine Daten mehr und man kann auch keine Geräte mit den Icon Bleistift bearbeiten.
            https://github.com/sbormann/ioBroker.iqontrol/issues/81
            • sigi234S
              sigi234S
              Fehlermeldung 2
              Adapter: Alle
              Fehler: code 7
              iqontrol.0	2019-09-19 10:27:23.113	debug	system.adapter.admin.0: logging true
              host.Medion	2019-09-19 10:27:22.904	info	Restart adapter system.adapter.snmp.0 because enabled
              host.Medion	2019-09-19 10:27:22.904	error	instance system.adapter.snmp.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
              snmp.0	2019-09-19 10:27:22.890	error	snmp.0 already running
              host.Medion	2019-09-19 10:27:22.699	info	instance system.adapter.firetv.1 started with pid 7004
              host.Medion	2019-09-19 10:27:22.497	info	instance system.adapter.ping.0 started with pid 13792
              host.Medion	2019-09-19 10:27:22.249	info	instance system.adapter.snmp.0 started with pid 8660
              host.Medion	2019-09-19 10:27:21.847	info	Restart adapter system.adapter.statistics.0 because enabled
              host.Medion	2019-09-19 10:27:21.847	error	instance system.adapter.statistics.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
              statistics.0	2019-09-19 10:27:21.826	error	statistics.0 already running
              host.Medion	2019-09-19 10:27:21.311	info	instance system.adapter.statistics.0 started with pid 12120
              host.Medion	2019-09-19 10:27:21.203	info	Restart adapter system.adapter.snmp.0 because enabled
              host.Medion	2019-09-19 10:27:21.203	error	instance system.adapter.snmp.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
              snmp.0	2019-09-19 10:27:21.182	error	snmp.0 already running
              host.Medion	2019-09-19 10:27:21.066	info	Restart adapter system.adapter.wifilight.0 because enabled
              host.Medion	2019-09-19 10:27:21.066	error	instance system.adapter.wifilight.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
              wifilight.0	2019-09-19 10:27:21.033	error	wifilight.0 already running
              host.Medion	2019-09-19 10:27:20.840	info	Restart adapter system.adapter.cloud.0 because enabled
              host.Medion	2019-09-19 10:27:20.840	error	instance system.adapter.cloud.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
              host.Medion	2019-09-19 10:27:20.830	info	Restart adapter system.adapter.hue.0 because enabled
              host.Medion	2019-09-19 10:27:20.830	error	instance system.adapter.hue.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
              cloud.0	2019-09-19 10:27:20.794	error	cloud.0 already running
              hue.0	2019-09-19 10:27:20.779	error	hue.0 already running
              • sigi234S sigi234
                Fehlermeldung 2
                Adapter: Alle
                Fehler: code 7
                apollon77A
                apollon77A
                @sigi234 Und was ist DAVOR passiert? Das "error 7" sagt nur "uups der läuft schon aber ich will ihn nochmal starten" ... das heisst die Frage ist was davor war
                • apollon77A
                  apollon77A
                  Und PS: Hat sich das mit Error 7 danach gefangen pder hast Du manuell etwas tun müssen? AN sich sollten solche Fehler einmalig kommen und der Adapter danach es alleine fixen
                  • apollon77A apollon77
                    sigi234S
                    sigi234S
                    @apollon77 sagte in [Aufruf] js-controller 2.0 Beta Test:
                    Nein, Fehler kommen ständig.
                    • apollon77A
                      apollon77A
                      Ok, dann kille mal die prozesse die laufen. Ist im Log davor irgendwas? Es muss nen grund geben warum er die neu starten wollte
                        sigi234S
                        sigi234S
                        Dann müsste ich alle killen.....ich starte mal neu.
                        Keine Änderung,...
                        LOG:
                        iobroker.2019-09-19 - Kopie (3).zip
                        • SBorgS
                          SBorgS
                          SBorg
                          Läuft seit gestern Abend, allerdings hatte ich auch den PID-Fehler. Die TXT existierte bei mir einfach nicht, also auch nix mit Rechte setzen. Leider habe ich dann zu schnell den Fixer drüber laufen lassen (danach funktionierte es) und mir nicht die Rechte vom Verzeichnis angeschaut. Die müssten aber gestimmt haben, da ich schon ein paar mal vorher den Fixer drüber laufen hatte.
                          Ein paar Schwierigkeiten hatte ich noch mit node-RED:
                          node-red.0	2019-09-19 10:57:31.326	error	node-red.0 invalid instance object: {"_id":"","type":"channel","common":{"name":"States created by node-red.%INSTANCE%","role":"info"},"native":{}}
                          und dann (stimmt jetzt zeitlich nicht so ganz, da falsch aus dem Log kopiert) bis zum abwinken:
                          2019-09-19 09:24:57.808 - error: node-red.0 19 Sep 09:24:57 - [error] [ioBroker get:c7dd8250.fd991] TypeError: Cannot read property 'getObject' of undefined
                          at Adapter.getObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1917:26)
                          at checkState (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:85:17)
                          at new IOBrokerGetNode (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:330:17)
                          at Object.createNode (/opt/iobroker/node_modules/iobroker.node-red/node_modules/@node-red/runtime/lib/nodes/flows/util.js:483:31)
                          at Flow.start (/opt/iobroker/node_modules/iobroker.node-red/node_modules/@node-red/runtime/lib/nodes/flows/Flow.js:176:44)
                          at start (/opt/iobroker/node_modules/iobroker.node-red/node_modules/@node-red/runtime/lib/nodes/flows/index.js:329:33)
                          at tryCatchReject (/opt/iobroker/node_modules/iobroker.node-red/node_modules/when/lib/makePromise.js:845:30)
                          at runContinuation1 (/opt/iobroker/node_modules/iobroker.node-red/node_modules/when/lib/makePromise.js:804:4)
                          at Fulfilled.when (/opt/iobroker/node_modules/iobroker.node-red/node_modules/when/lib/makePromise.js:592:4)
                          at Pending.run (/opt/iobroker/node_modules/iobroker.node-red/node_modules/when/lib/makePromise.js:483:13)
                          Neustart nur von node-RED löste das Problem und derzeit läuft soweit erst mal alles.
                          LG SBorg ( SBorg auf GitHub)
                          • SBorgS SBorg
                            apollon77A
                            apollon77A
                            @SBorg Den erste Fehler fixe ich das das nicht angezeigt wird. Der zweite passiert wenn der Adapter die Objects-DB Verbindung verliert. Was ewar denn so im Log als das begonnen hat (also kurz davor)?
                            • SBorgS
                              SBorgS
                              SBorg
                              Nichts schlimmes, nur der 1. node-RED Fehler, dann paar normale Infos und der "übliche"
                              2019-09-19 09:24:55.189 - warn: node-red.0 19 Sep 09:24:55 - [warn] Projekte inaktiviert: setze editorTheme.projects.enabled=true zum Aktivieren
                              danach kommt dann der 2. Fehler.
                              • apollon77A
                                apollon77A
                                Hey All,
                                Auf GitHub gibt es die 2.0.3 mit ein paar Optimierungen für Fälle wie Verbindungsverluste von Adaptern zur Objects/Sate DB und "Error 7" Fälle. Der Fehler sollte jetzt maximal einmal kommen und dann weg bleiben ... bitte schaut mal ob das alles so passt.
                                Nach dem Stoppen bitte nochmal schauen das wirklich alle Prozesse auch weg sind (io.*), dann update und neu starten ...
                                • SBorgS
                                  SBorgS
                                  SBorg
                                  Node-RED lüppt nu auch 👍
                                  • E
                                    E
                                    e-s
                                    schrieb am zuletzt editiert von e-s
                                    @apollon77
                                    Habe 2.0 installiert, bei mir ohne Fehlermeldung. Scheint alles gut zu sein.
                                    • apollon77A
                                      apollon77A
                                      Auf GitHub gibt es seid eben die 2.0.4. Ein fehlerhaftes "iobroker host" Kommando wurde gefixt und eine weitere Abfrage bei der Objekt-Migration hinzugefügt.
                                      • arteckA arteck
                                        @opossum
                                        hast du gemach t??
                                        opossumO
                                        opossumO
                                        opossum
                                        @arteck sagte in [Aufruf] js-controller 2.0 Beta Test:
                                        @opossum
                                        hast du gemach t??
                                        ups, auf das Naheliegende kommt man nicht. Danke für den Tip, Fehler ist nun weg.
                                        • opossumO opossum
                                          @opossum
                                          hast du gemach t??
                                          apollon77A
                                          apollon77A
                                          @opossum naheliegend? .... naja lies mal den ersten Beitrag bei Installation durch :-(
                                          33.2k
                                          84.4k
