  4. Adapter: ioBroker.unifi
unifi
1.0k Beiträge 172 Kommentatoren 730.1k Aufrufe 93 Beobachtet
  • dslraserD dslraser
    @liv-in-sky
    @thewhobox
    das aus aus dem Log unterm Script
    26.8.2019, 18:16:40.833	[info ]: javascript.0 Start javascript script.js.Heiko.Unifi.unifi_wifi
    26.8.2019, 18:16:40.833	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: registered 0 subscriptions and 0 schedules
    26.8.2019, 18:16:41.126	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: Login war erfolgreich!
    26.8.2019, 18:16:41.149	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: Status erfolgreich geholt!
    26.8.2019, 18:16:41.149	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: {'statusCode':401,'body':'{\'meta\':{\'rc\':\'error\',\'msg\':\'api.err.LoginRequired\'},\'data\':[]}','headers':{'cache-control':'private','expires':'Thu, 01 Jan 1970 00:00:00 GMT','vary':'Origin','access-control-allow-credentials':'true','access-control-expose-headers':'Access-Control-Allow-Origin,Access-Control-Allow-Credentials','x-frame-options':'DENY','content-type':'application/json;charset=UTF-8','content-length':'63','date':'Mon, 26 Aug 2019 16:16:41 GMT','connection':'close'},'request':{'uri':{'protocol':'https:','slashes':true,'auth':null,'host':'192.168.180.110:8443','port':'8443','hostname':'192.168.180.110','hash':null,'search':null,'query':null,'pathname':'/api/s/default/rest/wlanconf/5d3c5be0bc96040011365fe5','path':'/api/s/default/rest/wlanconf/5d3c5be0bc96040011365fe5','href':'https://192.168.180.110:8443/api/s/default/rest/wlanconf/5d3c5be0bc96040011365fe5'},'method':'GET','headers':{}}}
    26.8.2019, 18:16:41.149	[error]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: SyntaxError: Unexpected token o in JSON at position 1
    26.8.2019, 18:16:41.149	[error]: javascript.0     at Request.request.get [as _callback] (script.js.Heiko.Unifi.unifi_wifi:29:31)
    thewhoboxT
    thewhoboxT
    thewhobox
    #325
    @dslraser @liv-in-sky Könnte einer von euch mal nach "Login erfolgreich" folgende Zeilen einfügen?
    console.log('HEADERS: ' + JSON.stringify(resp.headers));
    onsole.log('Cookies: ' + resp.getHeader("Set-Cookie"));
    Meine Adapter: emby | discovery
    • thewhoboxT thewhobox
      liv-in-skyL
      liv-in-skyL
      #326
      moin @thewhobox
      thewhoboxT 1 Antwort Letzte Antwort
      • liv-in-skyL liv-in-sky
        moin @thewhobox
        thewhoboxT
        thewhoboxT
        thewhobox
        schrieb am zuletzt editiert von thewhobox
        #327
        @liv-in-sky Moin. Danke fürs ausprobieren. Hier nochmal das angepasste Script für die cookies.
        Edit: Siehe unten
        liv-in-skyL dslraserD 2 Antworten Letzte Antwort
          Edit: Siehe unten
          liv-in-skyL
          liv-in-skyL
          #328
          @thewhobox - danke fürs programmieren
          jetzt kommt der erste fehler wieder :-(
          bei "const request = require('request');"
          10:08:00.824	info	javascript.2 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN1
          10:08:01.924	info	javascript.2 Start javascript script.js.Armin_Schalter.ALLERLEI.UnifiWLAN1
          10:08:01.924	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN1: registered 0 subscriptions and 0 schedules
          10:08:01.941	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN1: Login Fehler! Error: self signed certificate
          10:08:03.833	info	javascript.2 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN1
          bei "const request = require('request').defaults({ rejectUnauthorized: false });"
            Edit: Siehe unten
            dslraserD
            dslraserD
            dslraser
            #329
            @thewhobox sagte in Adapter: ioBroker.unifi:
            let cookies = [];
            bei mir auch
            10:15:42.843	info	javascript.0 script.js.Heiko.Unifi.unifi_wifi: Login war erfolgreich!
            10:15:42.843	info	javascript.0 script.js.Heiko.Unifi.unifi_wifi: Cookies: ["unifises=GyZZk8h1ERsg5Kn9AeYyD2sL5Lcduutx","csrf_token=dKB4b1jFoeScvPlh97hKMywEdt1oUdBI"]
            10:15:42.893	info	javascript.0 script.js.Heiko.Unifi.unifi_wifi: Status erfolgreich geholt!
            10:15:42.893	info	javascript.0 script.js.Heiko.Unifi.unifi_wifi: {'statusCode':200,'body':'{\'meta\':{\'rc\':\'ok\'},\'data\':[{\'_id\':\'5d3c5be0bc96040011365fe5\',\'enabled\':true,\'security\':\'open\',\'wep_idx\':1,\'wpa_mode\':\'wpa2\',\'wpa_enc\':\'ccmp\',\'usergroup_id\':\'5d3b2323bc9604001132d2c5\',\'dtim_mode\':\'default\',\'dtim_ng\':1,\'dtim_na\':1,\'minrate_ng_enabled\':false,\'minrate_ng_advertising_rates\':false,\'minrate_ng_data_rate_kbps\':1000,\'minrate_ng_cck_rates_enabled\':true,\'minrate_na_enabled\':false,\'minrate_na_advertising_rates\':false,\'minrate_na_data_rate_kbps\':6000,\'mac_filter_enabled\':false,\'mac_filter_policy\':\'allow\',\'mac_filter_list\':[],\'bc_filter_enabled\':false,\'bc_filter_list\':[],\'group_rekey\':3600,\'name\':\'Hübis Gäste\',\'is_guest\':true,\'x_passphrase\':\'dashieristprivat\',\'wlangroup_id\':\'5d3b2323bc9604001132d2c6\',\'schedule\':[],\'minrate_ng_mgmt_rate_kbps\':1000,\'minrate_na_mgmt_rate_kbps\':6000,\'minrate_ng_beacon_rate_kbps\':1000,\'minrate_na_beacon_rate_kbps\':6000,\'site_id\':\'5d3b231abc9604001132d2b8\',\'x_iapp_key\':\'0613db2263d118bc9e21936a202a964e\',\'fast_roaming_enabled\':false,\'no2ghz_oui\':true}]}','headers':{'cache-control':'private','expires':'Thu, 01 Jan 1970 00:00:00 GMT','vary':'Origin,Accept-Encoding','access-control-allow-credentials':'true','access-control-expose-headers':'Access-Control-Allow-Origin,Access-Control-Allow-Credentials','x-frame-options':'DENY','content-type':'application/json;charset=UTF-8','content-length':'1000','date':'Tue, 27 Aug 2019 08:15:42 GMT','connection':'close'},'request':{'uri':{'protocol':'https:','slashes':true,'auth':null,'host':'192.168.180.110:8443','port':'8443','hostname':'192.168.180.110','hash':null,'search':null,'query':null,'pathname':'/api/s/default/rest/wlanconf/5d3c5be0bc96040011365fe5','path':'/api/s/default/rest/wlanconf/5d3c5be0bc96040011365fe5','href':'https://192.168.180.110:8443/api/s/default/rest/wlanconf/5d3c5be0bc96040011365fe5'},'method':'GET','headers':{'Cookie':'unifises=GyZZk8h1ERsg5Kn9AeYyD2sL5Lcduutx; csrf_token=dKB4b1jFoeScvPlh97hKMywEdt1oUdBI'}}}
            10:15:42.893	error	javascript.0 script.js.Heiko.Unifi.unifi_wifi: SyntaxError: Unexpected token o in JSON at position 1
            10:15:42.893	error	javascript.0 at Request.request.get [as _callback] (script.js.Heiko.Unifi.unifi_wifi:39:31)
              thewhoboxT
              thewhoboxT
              thewhobox
              #330
              @liv-in-sky Ja hast recht. Hab den teil vergessen zu ändern.
              Hab das Skript oben angepasst. einfach mal das JSON.parse weg lassen.
              • dslraserD
                dslraserD
                dslraser
                #331
                @thewhobox
                @liv-in-sky
                Ich habe keine Ahnung davon, aber wenn ich google dazu befrage, dann kommt Sinngemäß oft die Antwort, das es schon ein Objekt ist und man es direkt verwenden kann und nicht parsen braucht ?
                Danke für die Mühe.
                  @thewhobox
                  @liv-in-sky
                  Danke für die Mühe.
                  thewhoboxT
                  thewhoboxT
                  thewhobox
                  #332
                  @dslraser Ja das stimmt. Hab das Skript oben angepasst.
                    liv-in-skyL
                    liv-in-skyL
                    #333
                    @thewhobox cool - läuft
                    könntest du das ein und ausschalten auch noch für uns machen :-) :-)
                    	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN1: WLAN ist: an
                    thewhoboxT 2 Antworten Letzte Antwort
                      thewhoboxT
                      thewhoboxT
                      thewhobox
                      #334
                      @liv-in-sky okay super :) Kann ich später machen.
                      dslraserD liv-in-skyL 2 Antworten Letzte Antwort
                        dslraserD
                        dslraserD
                        dslraser
                        #335
                        @thewhobox
                        klappt 👍 👍 👍
                        10:33:43.645	info	javascript.0 script.js.Heiko.Unifi.unifi_wifi: Login war erfolgreich!
                        10:33:43.645	info	javascript.0 script.js.Heiko.Unifi.unifi_wifi: Cookies: ["unifises=JA7z7GVM4cnOB6sZnqkcjBFBFpFzJw5S","csrf_token=GcAjwdvcY6hc58t6E4gLi4X3X7g490mn"]
                        10:33:43.689	info	javascript.0 script.js.Heiko.Unifi.unifi_wifi: Status erfolgreich geholt!
                        10:33:43.690	info	javascript.0 script.js.Heiko.Unifi.unifi_wifi: {'statusCode':200,'body':'{\'meta\':{\'rc\':\'ok\'},\'data\':[{\'_id\':\'5d3c5be0bc96040011365fe5\',\'enabled\':true,\'security\':\'open\',\'wep_idx\':1,\'wpa_mode\':\'wpa2\',\'wpa_enc\':\'ccmp\',\'usergroup_id\':\'5d3b2323bc9604001132d2c5\',\'dtim_mode\':\'default\',\'dtim_ng\':1,\'dtim_na\':1,\'minrate_ng_enabled\':false,\'minrate_ng_advertising_rates\':false,\'minrate_ng_data_rate_kbps\':1000,\'minrate_ng_cck_rates_enabled\':true,\'minrate_na_enabled\':false,\'minrate_na_advertising_rates\':false,\'minrate_na_data_rate_kbps\':6000,\'mac_filter_enabled\':false,\'mac_filter_policy\':\'allow\',\'mac_filter_list\':[],\'bc_filter_enabled\':false,\'bc_filter_list\':[],\'group_rekey\':3600,\'name\':\'Hübis Gäste\',\'is_guest\':true,\'x_passphrase\':\'dashieristprivat\',\'wlangroup_id\':\'5d3b2323bc9604001132d2c6\',\'schedule\':[],\'minrate_ng_mgmt_rate_kbps\':1000,\'minrate_na_mgmt_rate_kbps\':6000,\'minrate_ng_beacon_rate_kbps\':1000,\'minrate_na_beacon_rate_kbps\':6000,\'site_id\':\'5d3b231abc9604001132d2b8\',\'x_iapp_key\':\'0613db2263d118bc9e21936a202a964e\',\'fast_roaming_enabled\':false,\'no2ghz_oui\':true}]}','headers':{'cache-control':'private','expires':'Thu, 01 Jan 1970 00:00:00 GMT','vary':'Origin,Accept-Encoding','access-control-allow-credentials':'true','access-control-expose-headers':'Access-Control-Allow-Origin,Access-Control-Allow-Credentials','x-frame-options':'DENY','content-type':'application/json;charset=UTF-8','content-length':'1000','date':'Tue, 27 Aug 2019 08:33:43 GMT','connection':'close'},'request':{'uri':{'protocol':'https:','slashes':true,'auth':null,'host':'192.168.180.110:8443','port':'8443','hostname':'192.168.180.110','hash':null,'search':null,'query':null,'pathname':'/api/s/default/rest/wlanconf/5d3c5be0bc96040011365fe5','path':'/api/s/default/rest/wlanconf/5d3c5be0bc96040011365fe5','href':'https://192.168.180.110:8443/api/s/default/rest/wlanconf/5d3c5be0bc96040011365fe5'},'method':'GET','headers':{'Cookie':'unifises=JA7z7GVM4cnOB6sZnqkcjBFBFpFzJw5S; csrf_token=GcAjwdvcY6hc58t6E4gLi4X3X7g490mn'}}}
                        10:33:43.690	info	javascript.0 script.js.Heiko.Unifi.unifi_wifi: WLAN ist: an
                          liv-in-skyL
                          liv-in-skyL
                          #336
                          @thewhobox noch ne frage:
                          kann ich die function getStatus auch dafür benutzen (ohne header) , um mit dem simpleapi adapter eines anderen iobroker zu kommunizieren ?
                            thewhoboxT
                            thewhoboxT
                            thewhobox
                            #337
                            @liv-in-sky Jain, da die Funktion nur auf die spezielle zurückgabe vom Unifi Controller angepasst ist.
                            Du musst das im Callback anpassen und die Header weglassen.
                            Vereinfacht geht:
                            request.get("http://192.168.0.xxx/get/system.adapter.admin.0.alive", (err, resp) => {
                                if(!err) {
                                    let state = JSON.parse(resp);
                                    console.log("State hat den Wert: " + state.val);
                                } else {
                                    console.log("Es trat ein Fehler auf: " + err);
                              Vereinfacht geht:
                                  if(!err) {
                                  } else {
                              liv-in-skyL
                              liv-in-skyL
                              #338
                              @thewhobox danke dir - werd das mal testen
                                thewhoboxT
                                thewhoboxT
                                thewhobox
                                #339
                                @liv-in-sky So, hier auch noch mit ein und ausschalten. Änderungen sind:
                                • Bei Aufruf von getStatus oder setWifi wird automatisch vorher eingeloggt.
                                • Es gibt nun auch ein logout
                                • Über setWifi(true/false) kann das WLAN ein/aus geschaltet werden.
                                const request = require('request-promise-native').defaults({ rejectUnauthorized: false });
                                const unifi_username = "user";
                                const unifi_password = "pass";
                                const unifi_controller = "https://192.168.x.xx:xxxx";
                                const wifi_id = "dsa4fsda6g46fdsg984";
                                let cookies = [];
                                let loggedIn = false;
                                async function login() {
                                    return new Promise(async (resolve, reject) => {
                                        let resp = await request.post({
                                            url: unifi_controller + "/api/login",
                                            body: JSON.stringify({ username: unifi_username, password: unifi_password }),
                                            headers: { 'Content-Type': 'application/json' }
                                        }).catch((e) => reject(e));
                                        if(resp != null) {
                                            console.log("Login war erfolgreich!");
                                            let set_cookies = resp.headers["set-cookie"];
                                            for(i = 0; i < set_cookies.length; i++) {
                                                let cookie = set_cookies[i];
                                                cookie = cookie.split(";")[0];
                                                cookies.push(cookie);
                                            console.log("Cookies: " + JSON.stringify(cookies));
                                            loggedIn = true;
                                            resolve();
                                        } else {
                                            reject("resp = null");
                                async function getStatus() {
                                        if(!loggedIn) await login().catch((e) => reject(e));
                                        let resp = await request.get({
                                            url: unifi_controller + "/api/s/default/rest/wlanconf/" + wifi_id,
                                            headers: { Cookie: cookies.join("; ") }
                                        if(resp != null && resp.statusCode == 200) {
                                            console.log("Status erfolgreich geholt!");
                                            console.log(resp);
                                            let status = JSON.parse(resp);
                                            let wlanOn = status.data[0].enabled;
                                            console.log("WLAN ist: " + (wlanOn ? "an" : "aus"));
                                            resolve(wlanOn);
                                        } else {
                                            reject(JSON.parse(resp.body).meta.msg);
                                async function logout() {
                                            url: unifi_controller + "/logout",
                                        if(resp != null) {
                                            console.log("Du bist nun ausgeloggt.");
                                            console.log(resp);
                                            resolve();
                                        } else {
                                async function setWifi(enabled) {
                                        let resp = request.post({
                                            body: JSON.stringify({ _id: "", enabled }),
                                            headers: { 'Content-Type': 'application/json', Cookie: cookies.join("; ") }
                                            console.log("Wifi wurde erfolgreich " + (enabled ? "eingeschaltet" : "ausgeschaltet"));
                                            console.log(resp);
                                            resolve();
                                        } else {
                                Aufruf über:
                                async function test() {
                                    await setWifi(true).catch((e) => console.log("Es trat ein Fehler auf: " + e));
                                    let isWlanOn = await getStatus();
                                test();
                                  let cookies = [];
                                          if(resp != null) {
                                              loggedIn = true;
                                              resolve();
                                          } else {
                                              console.log(resp);
                                              resolve(wlanOn);
                                          } else {
                                          if(resp != null) {
                                              console.log(resp);
                                              resolve();
                                          } else {
                                              console.log(resp);
                                              resolve();
                                          } else {
                                  Aufruf über:
                                  test();
                                  liv-in-skyL
                                  liv-in-skyL
                                  #340
                                  @thewhobox also wenn ich dich richtig verstehe
                                  kann ich mit setWifi(true) einschalten bzw setWifi(false) ausschalten - dass funktioniert aber nicht
                                  es wird nicht geschalten obwohl die meldung es sagt
                                  oder mach ich was falsch ?
                                    thewhoboxT
                                    thewhoboxT
                                    thewhobox
                                    #341
                                    @liv-in-sky Ah okay. Nein liegt nicht an dir. ich hab vergessen, dass das alles ja gar nicht synchron abläuft.
                                    Ich hab den Code oben angepasst.
                                    Achtung! Jetzt wird das Modul request-promise-native benötigt.
                                    Beachte! Die Funktionen sind nun asynchron! Heißt um danach den Status abfragen zu können musst du es in eine ebenfalls asynchrone Funktion machen und mit await auf die beendigung warten.
                                    asynch function test() {
                                        await setWifi(true);
                                      liv-in-skyL
                                      liv-in-skyL
                                      #342
                                      @thewhobox da stimmt was nicht mit dem upgedaten file
                                        thewhoboxT
                                        thewhoboxT
                                        thewhobox
                                        #343
                                        @liv-in-sky Habs korrigiert.
                                          liv-in-skyL
                                          liv-in-skyL
                                          #344
                                          @thewhobox compiler fehler bei der
                                          sollte woh async heißen
                                          33.2k
                                          84.4k
