  4. Suche Spotify View
    6.6k
Suche Spotify View
107 Beiträge 32 Kommentatoren 30.6k Aufrufe 38 Beobachtet
    skokarl
    Danke, geht nicht.
    Hier passiert nix außer Fehlermeldungen.
    Nach wie vor, Spotify grün, Sonos grün.
    spotify-premium.0 2019-02-17 17:41:36.489 info terminating
    spotify-premium.0 2019-02-17 17:41:36.465 error at runCallback (timers.js:810:20)
    spotify-premium.0 2019-02-17 17:41:36.465 error at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3429:38)
    spotify-premium.0 2019-02-17 17:41:36.465 error at Adapter.emit (events.js:214:7)
    spotify-premium.0 2019-02-17 17:41:36.465 error at emitTwo (events.js:126:13)
    spotify-premium.0 2019-02-17 17:41:36.465 error at Adapter.setExternal (/opt/iobroker/node_modules/iobroker.spotify-premium/lib/cache.js:258:2)
    spotify-premium.0 2019-02-17 17:41:36.465 error at trigger (/opt/iobroker/node_modules/iobroker.spotify-premium/lib/cache.js:219:11)
    spotify-premium.0 2019-02-17 17:41:36.465 error at Array.forEach (<anonymous>)
    spotify-premium.0 2019-02-17 17:41:36.465 error at /opt/iobroker/node_modules/iobroker.spotify-premium/lib/cache.js:225:19
    spotify-premium.0 2019-02-17 17:41:36.465 error at Object.listenOnDeviceList [as func] (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:1668:9)
    spotify-premium.0 2019-02-17 17:41:36.465 error at listenOnUseForPlayback (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:1637:96)
    spotify-premium.0 2019-02-17 17:41:36.465 error TypeError: Cannot read property 'val' of null
    spotify-premium.0 2019-02-17 17:41:36.454 error uncaught exception: Cannot read property 'val' of null
    spotify-premium.0 2019-02-17 17:41:31.841 error erron in request: 403
      skokarl
      glaub das einzigste was mir hilft ist was ganz ganz kleines,
      nur zum verstehen wie es gehn müsste.
      sowas wie ... :nix.PNG
        skokarl
        sagt mal....muss zu den Widgets noch was mit javascript ???
        Das wäre ne Erklärung .... hab sowas aber noch nie gemacht, na, das kann ja lustig werden.😀
          Stuti
          Sonos uns Spotify läuft bei mir nicht. Auf dem Echo oder Notebook abspielen geht.
          Es fehlt einfach die Funktion den Player als "Aktiven" zu setzen. "SetForPlayback" fehlt bei dem Sonos.
          Du brauchst eigentlich nur drei einfach HTML Widgets. Darin einfach
          die drei html Tables darstellen.
          Dafür einfach z.B.
          {spotify-premium.0.html.tracks}
          eintragen dann kannst du den Track mit klick abspielen. Oder mit dem anderen HTML dein Device wählen.
          NUC i5 mit Proxmox - KVM für ioBroker
          Rest in Docker. z.B. KNXD, Pi-Hole, MySQL, Grafana, PostgreSQL, Wiki.js, Prometheus, Loki.
          KNX mit GIRA Homeserver, aber auch Shelly´s und Zigbee
          • S Stuti
            Dafür einfach z.B.
            skokarl
            @Stuti sagte in Suche Spotify View:
            das ist doch jetzt mal ne Aussage die mich weiterbringt. Danke.
            S 2 Antworten Letzte Antwort
            • S skokarl
              Stuti
              @skokarl ich weiß noch nicht, ob das an der V1.0.0 des Adapters liegt.
              Die Buttons "Shuffle" und "Repeat" haben bei mir auch keinerlei Wirkung.
              Downgrade will ich eigentlich nicht machen, da ich dann die HTML views verliere. Dazu gibt es wohl ein Script, welches diese Liste zusammenbaut, aber das muss man ja nicht machen, wenn nicht nötig.
              • S skokarl
                Stuti
                @skokarl Der Adapter 0.31 zeigt bei mir den Sonos nicht mal an.
                Repeat und Shuffle haben nur keine Funktion, wenn ich gerade auf dem Sonos etwas abspiele. Auf dem Echo läuft alles ohne Probleme.
                • wendy2702W wendy2702
                  Hier mein kompletter View. Geht nur über einen Umweg da Limitierung auf 40000 Zeichen.
                  Spotify View.docx
                  Martin1324M Offline
                  Martin1324M Offline
                  Martin1324
                  @wendy2702 Hi Wendy,
                  habe mir erlaubt deine View zu testen. Funktioniert super!! Habe nur ein kleines Problem mit den Pause/Play button. Der funktioniert bei mir nicht richtig.
                  Sehe dass da folgendes Skript dahinter ist:
                  javascript.0.spotify-premium.playpause
                  javascript.0.spotify-premium.playpausebutton
                  Was genau passiert in diesen Skripts? Könntest du sie mir evtl. zukommen lassen?
                  Vielen Dank
                  lg
                  Martin
                  • Martin1324M Martin1324
                    Vielen Dank
                    lg
                    Martin
                    wendy2702W Online
                    wendy2702W Online
                    @MartinG
                    Sorry ich nutze das nicht mehr und habe auch die Script nicht mehr.
                    Martin1324M 1 Antwort Letzte Antwort
                      @MartinG
                      Martin1324M Offline
                      Martin1324M Offline
                      Martin1324
                      @wendy2702
                      Ok. Schade
                      Danke dir trotzdem
                      • JB_SullivanJ Offline
                        JB_Sullivan
                        Falls jemand Interesse an meinem VIEW hat - habe es selber erst die Tage mit Hilfe eines anderen Users zusammen gebastelt. Es wird ausschließlich auf die Datenpunkte vom Spotify Adapter 1.1.0 zurück gegriffen. Keine javascripte o.ä.
                        Ich finde es sieht gut aus und funktioniert bei mir hervorragend. Muss mal gucken wie ich noch einen "Fortschrittsbalken" zum schnellen vorspulen von Lieder integrieren kann.
                        ...... hmmmm würde den Code für das VIEW gerne als Code /Spoiler hochladen. Leider meckert die Forensoftware das ich nur Beiträge bis 5000 Zeichen verfassen kann. Offensichtlich zählt Code/Spoiler mit dazu ..... naja mal gucken wie ich das hin bekomme.
                        sigi234S R 2 Antworten Letzte Antwort
                        • JB_SullivanJ JB_Sullivan
                          sigi234S Online
                          sigi234S Online
                          @JB_Sullivan sagte in Suche Spotify View:
                          Als Datei hochladen.........rechts neben dem Wolke Icon
                            JB_Sullivan
                            OK, hier also das komplette VIEW - KEIN Widget
                            Spotify VIEW.txt
                              JB_Sullivan
                              So ich habe das VIEW nochmal eine bisschen verändert und nun sind entsprechende Slider für Titel Fortschritt und Lautstärke eingebaut.
                              Spotify View 2.txt
                              C FeuersturmF Michael DolpM 3 Antworten Letzte Antwort
                                Spotify View 2.txt
                                Chrisx51
                                @JB_Sullivan Mann dein View ist ja der Hammer!
                                Vielen Dank dafür! 👍
                                Dann hast du aber evtl. auch eine Idee warum der View bei mir so aussieht:
                                Ich glaube da stimmt etwas mit meinen widgets nicht!
                                  JB_Sullivan
                                  Nein, das Widget ist OK - du brauchst dafür natürlich die passenden Icons aus der Icon Biliothek, die du den Datenpunkten zuordnen musst.
                                    sigi234S Online
                                    sigi234S Online
                                    @JB_Sullivan
                                      JB_Sullivan
                                      icons.zip
                                        martin
                                        Läuft der Adapter nur mit einem Premium Account? Ich habe nur den Free-Account.
                                        • M martin
                                          FredFF Online
                                          FredFF Online
                                          FredF
                                          Most Active Forum Testing
                                          @martin
                                          Ja. Er heisst auch spotify premium.
