  4. INFO / ACHTUNG : Zwave-Adapter
info
64 Beiträge 20 Kommentatoren 14.7k Aufrufe 15 Beobachtet
  • F Offline
    fisch
    habe heute den 1.5.0 insatlliert...jetzt geht wieder nichts :-(
    $ ./iobroker add zwave  --host ioBroker-Pi
    host.ioBroker-Pi install adapter zwave
    npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.zwave"
    find: ‘/tmp/systemd-private-e840114d2b404515948665fe563358d5-redis-server.service-S60QFf’: Keine Berechtigungfind: ‘/tmp/systemd-private-e840114d2b404515948665fe563358d5-colord.service-o5xroB’: Keine Berechtigung
      % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current                                 Dload  Upload   Total   Spent    Left  Speed
      0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
    100   125    0   125    0     0    362      0 --:--:-- --:--:-- --:--:--   363
      0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0Warning: Failed to create the file master.zip: Keine Berechtigung
      0 12.5M    0  1370    0     0   1615      0  2:16:13 --:--:--  2:16:13 12685
    curl: (23) Failed writing body (0 != 1370)
    /opt/iobroker/node_modules/iobroker.zwave/lib/preinstall.js:16    if (!suppressException) throw e;
    Error: Command failed: curl -L -O https://github.com/OpenZWave/open-zwave/archive/master.zip
        at checkExecSyncError (child_process.js:629:11)
        at Object.execSync (child_process.js:666:13)
        at doScript (/opt/iobroker/node_modules/iobroker.zwave/lib/preinstall.js:13:15)
        at installOpenZwaveFromSource (/opt/iobroker/node_modules/iobroker.zwave/lib/preinstall.js:147:3)
        at installOpenZwave (/opt/iobroker/node_modules/iobroker.zwave/lib/preinstall.js:139:3)
        at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zwave/lib/preinstall.js:27:7)
        at Module._compile (internal/modules/cjs/loader.js:776:30)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:787:10)
        at Module.load (internal/modules/cjs/loader.js:653:32)
        at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    npm
    ERR! code ELIFECYCLEnpm ERR! errno 1
    npm ERR! iobroker.zwave@1.5.0 preinstall: `node lib/preinstall.js`npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the iobroker.zwave@1.5.0 preinstall script.
    npm WARN Local package.json exists, but node_modules missing, did you mean to install?
    npm ERR!     /home/iobroker/.npm/_logs/2019-07-12T13_49_56_096Z-debug.log
    ERROR: fs.js:114    throw err;
    Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.zwave/iob_npm.done'
        at Object.openSync (fs.js:443:3)
        at Object.writeFileSync (fs.js:1194:35)
        at ChildProcess.child.on (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2946:20)
        at ChildProcess.emit (events.js:198:13)
        at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
    ERROR: process exited with code 1
    Kann mir jemand weiterhelfen?
    habe schon iobroker del zwave gemacht und neuinstalliert... und dann über Admin eine neue Instanz installieren wollen
    • F Offline
      fisch
      schrieb am zuletzt editiert von fisch
      ok installiert habe ich ihn nun bekommen....
      host.ioBroker-Pi	2019-07-12 16:51:28.841	error	instance system.adapter.zwave.0 terminated with code 0 (OK)
      Caught	2019-07-12 16:51:28.841	error	by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
      Caught	2019-07-12 16:51:28.841	error	by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:787:10)
      Caught	2019-07-12 16:51:28.841	error	by controller[0]: at Module._compile (internal/modules/cjs/loader.js:776:30)
      Caught	2019-07-12 16:51:28.841	error	by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/lib/openzwave-shared.js:27:19)
      Caught	2019-07-12 16:51:28.841	error	by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
      Caught	2019-07-12 16:51:28.841	error	by controller[0]: at Module.require (internal/modules/cjs/loader.js:690:17)
      Caught	2019-07-12 16:51:28.840	error	by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
      Caught	2019-07-12 16:51:28.840	error	by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
      Caught	2019-07-12 16:51:28.840	error	by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
      Caught	2019-07-12 16:51:28.840	error	by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:805:18)
      Caught	2019-07-12 16:51:28.839	error	by controller[0]: Error: libopenzwave.so.1.6: cannot open shared object file: No such file or directory
      EDIT: OK, ich habe wieder die 1.4.2 installiert...geht wieder?!
      Mit der 1.5.0 gehts leider nicht!
      F 1 Antwort Letzte Antwort
      • F fisch
        fisch
        Erledigt:
        mit
        sudo ldconfig
        läuft es nun !°
        • G Offline
          gery80
          Hallo versuche gerade zwave adapter zu installieren leider funktioniert es nicht image ist das neue ioBroker Image für Raspberry Pi2/3/4 Buster mit piVCCU 20190723 bitte um hilfe
          $ ./iobroker add zwave  --host IOBroker
          NPM version: 6.9.0
          npm install iobroker.zwave@1.4.2 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
          find: ‘/tmp/systemd-private-7f33173bc5a64f34b66e60d9b4e94fb9-systemd-timesyncd.service-fwIlBw’: Keine Berechtigungfind: ‘/tmp/pivccu-var/empty’: Keine Berechtigung
          find: ‘/tmp/systemd-private-7f33173bc5a64f34b66e60d9b4e94fb9-redis-server.service-prEu7C’: Keine Berechtigung
          100   122    0   122    0     0    231      0 --:--:-- --:--:-- --:--:--   231
            0 1917k    0   733    0     0    698      0  0:46:53  0:00:01  0:46:52   698
           49 1917k   49  942k    0     0   426k      0  0:00:04  0:00:02  0:00:02  811k
          100 1917k  100 1917k    0     0   830k      0  0:00:02  0:00:02 --:--:-- 1521k
          100   147    0   147    0     0    281      0 --:--:-- --:--:-- --:--:--   281
          100 16081    0 16081    0     0  12958      0 --:--:--  0:00:01 --:--:-- 40506
          /opt/iobroker/node_modules/iobroker.zwave/open-zwave-1.4/cpp/src/command_classes/DoorLockLogging.cpp: In member function ‘virtual bool OpenZWave::DoorLockLogging::HandleMsg(const uint8*, uint32, uint32)’:/opt/iobroker/node_modules/iobroker.zwave/open-zwave-1.4/cpp/src/command_classes/DoorLockLogging.cpp:313:48: error: ‘char* strncat(char*, const char*, size_t)’ output may be truncated copying between 0 and 253 bytes from a string of length 253 [-Werror=stringop-truncation]
                                                   strncat(usercode, tmpusercode, sizeof(usercode) - strlen(usercode) - 1 );
          cc1plus: all warnings being treated as errors
          make[1]: *** [/opt/iobroker/node_modules/iobroker.zwave/open-zwave-1.4/cpp/build/support.mk:151: /opt/iobroker/node_modules/iobroker.zwave/open-zwave-1.4/.lib/DoorLockLogging.o] Fehler 1
          make: *** [Makefile:20: all] Fehler 2
          Error: Command failed: cd open-zwave-1.4 && make && sudo make install
              at installOpenZwaveFromSource (/opt/iobroker/node_modules/iobroker.zwave/lib/preinstall.js:154:3)
              at Module._compile (internal/modules/cjs/loader.js:778:30)
              at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
          npm
           WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
          npm
          npm ERR! iobroker.zwave@1.4.2 preinstall: `node lib/preinstall.js`npm
          ERR! Exit status 1npm ERR!
          npm ERR! Failed at the iobroker.zwave@1.4.2 preinstall script.
          npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-08-14T19_44_00_445Z-debug.log
          host.IOBroker install adapter zwave
          NPM version: 6.9.0
          100   122    0   122    0     0    243      0 --:--:-- --:--:-- --:--:--   242
            1 1917k    1 39004    0     0  34486      0  0:00:56  0:00:01  0:00:55 34486
          100 1917k  100 1917k    0     0   952k      0  0:00:02  0:00:02 --:--:-- 2131k
          100   147    0   147    0     0    280      0 --:--:-- --:--:-- --:--:--   280
          100 16026    0 16026    0     0  13501      0 --:--:--  0:00:01 --:--:-- 13501
          100 16081    0 16081    0     0  13536      0 --:--:--  0:00:01 --:--:-- 55000
          npm
          npm
          npm ERR! iobroker.zwave@1.4.2 preinstall: `node lib/preinstall.js`npm ERR! Exit status 1
          npm
          ERR! npm ERR! Failed at the iobroker.zwave@1.4.2 preinstall script.
          npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-08-14T19_47_05_108Z-debug.log
          NPM version: 6.9.0
          100   122    0   122    0     0    223      0 --:--:-- --:--:-- --:--:--   223
            4 1917k    4 95062    0     0  64274      0  0:00:30  0:00:01  0:00:29 64274
           55 1917k   55 1065k    0     0   435k      0  0:00:04  0:00:02  0:00:02 1004k
          100 1917k  100 1917k    0     0   626k      0  0:00:03  0:00:03 --:--:-- 1153k
          100   147    0   147    0     0    231      0 --:--:-- --:--:-- --:--:--   231
          100 16081    0 16081    0     0  11502      0 --:--:--  0:00:01 --:--:-- 11502
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
          npm ERR! code ELIFECYCLE
          npm ERR! errno 1
          npm ERR!
          npm ERR!     /home/iobroker/.npm/_logs/2019-08-14T19_50_10_182Z-debug.log
          ERROR: host.IOBroker Cannot install zwave
          ERROR: process exited with code 13
          • G gery80
            NPM version: 6.9.0
            npm
            npm
            NPM version: 6.9.0
            npm
            npm
            npm
            NPM version: 6.9.0
            npm ERR! errno 1
            npm ERR!
            arteckA Offline
            arteckA Offline
            arteck
            @gery80
            welche version versuchst du zu installieren ???
            • arteckA arteck
              @gery80
              AlCalzoneA Offline
              AlCalzoneA Offline
              AlCalzone
              @arteck Laut Log 1.4.2, welche OZW 1.4 mitbringt.
              @gery80 kannst du mal probieren, die Version 1.5.1 zu installieren?
              cd /opt/iobroker
              npm i iobroker.zwave
              iobroker upload zwave
              G 1 Antwort Letzte Antwort
              • AlCalzoneA AlCalzone
                cd /opt/iobroker
                gery80
                @AlCalzone Hallo zwave wurde installiert jedoch bei iobroker upload zwave sagt er mir es wurde nicht gefunden
                + iobroker.zwave@1.5.1
                added 2 packages from 29 contributors and audited 1926 packages in 1571.599s
                found 39 vulnerabilities (28 low, 11 high)
                  run `npm audit fix` to fix them, or `npm audit` for details
                pi@IOBroker:/opt/iobroker $ iobroker upload zwave
                got /opt/iobroker/node_modules/iobroker.zwave/admin
                upload [15] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/zwave.png zwave.png image/png
                upload [14] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/words.js words.js application/javascript
                upload [13] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/js/comClasses.js js/comClasses.js application/javascript
                upload [12] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/index.html index.html text/html
                upload [11] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/soft-reset.png img/soft-reset.png image/png
                upload [10] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/sleepOn.png img/sleepOn.png image/png
                upload [9] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/sleep.png img/sleep.png image/png
                upload [8] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/readyOn.png img/readyOn.png image/png
                upload [7] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/ready.png img/ready.png image/png
                upload [6] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/neighbors.png img/neighbors.png image/png
                upload [5] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/heal.png img/heal.png image/png
                upload [4] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/hard-reset.png img/hard-reset.png image/png
                upload [3] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/delete.png img/delete.png image/png
                upload [2] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/aliveOn.png img/aliveOn.png image/png
                upload [1] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/alive.png img/alive.png image/png
                upload [0] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/add.png img/add.png image/png
                system.adapter.zwave does not exist
                • G gery80
                  AlCalzoneA Offline
                  AlCalzoneA Offline
                  AlCalzone
                  @gery80 Alles gut, dann musst du im Admin noch eine Instanz hinzufügen.
                    gery80
                    schrieb am zuletzt editiert von gery80
                    @AlCalzone kannst du mir das bitte erklären wie ich die Instanz hinzufüge ich bring es einfach nicht zusammen danke
                    • G gery80
                      AlCalzoneA Offline
                      AlCalzoneA Offline
                      AlCalzone
                      @gery80 Dann empfehle ich die Doku zu lesen:
                      https://www.iobroker.net/#de/documentation/tutorial/adapter.md
                      • G Offline
                        gery80
                        danke hat funktioniert
                        • F Offline
                          fisch
                          hi @all
                          kann mir jemand sagen was das genau beduetet?
                          Inkludieren klappt ohne Probleme aber, sobald ich schalten will kommt das:
                          zwave.0	2019-08-15 21:01:41.841	debug	node3: timeout
                          zwave.0	2019-08-15 21:01:31.841	debug	node3: timeout
                          zwave.0	2019-08-15 21:01:21.840	debug	node3: timeout
                          zwave.0	2019-08-15 21:01:18.294	debug	system.adapter.admin.0: logging true
                          zwave.0	2019-08-15 21:01:13.925	debug	setState for: nodeID=3: comClass=98: index=0: instance=1: value=true
                          zwave.0	2019-08-15 21:01:13.925	debug	stateChange zwave.0.NODE3.DOOR_LOCK.Locked_1 set {"val":true,"ack":false,"ts":1565895673921,"q":0,"from":"system.adapter.node-red.0","user":"system.user.admin","lc":1565895673700}
                          zwave.0	2019-08-15 21:01:13.782	debug	setState for: nodeID=3: comClass=98: index=0: instance=1: value=true
                          zwave.0	2019-08-15 21:01:13.782	debug	stateChange zwave.0.NODE3.DOOR_LOCK.Locked_1 set {"val":true,"ack":false,"ts":1565895673779,"q":0,"from":"system.adapter.node-red.0","user":"system.user.admin","lc":1565895673700}
                          zwave.0	2019-08-15 21:01:13.705	debug	setState for: nodeID=3: comClass=98: index=0: instance=1: value=true
                          zwave.0	2019-08-15 21:01:13.704	debug	stateChange zwave.0.NODE3.DOOR_LOCK.Locked_1 set {"val":true,"ack":false,"ts":1565895673700,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1565895673700}
                          zwave.0	2019-08-15 21:01:11.839	debug	setState for: nodeID=3: comClass=98: index=0: instance=1: value=false
                          zwave.0	2019-08-15 21:01:11.838	debug	stateChange zwave.0.NODE3.DOOR_LOCK.Locked_1 set {"val":false,"ack":false,"ts":1565895671836,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1565891882149}
                          zwave.0	2019-08-15 21:01:09.012	debug	system.adapter.admin.0: logging false
                          zwave.0	2019-08-15 21:00:44.352	debug	system.adapter.admin.0: logging true
                          zwave.0	2019-08-15 20:59:55.980	debug	fixing zwave buttons to use common.role "switch" instead of "button"
                          zwave.0	2019-08-15 20:59:55.976	info	Scan completed
                          zwave.0	2019-08-15 20:59:55.970	info	Update zwave.0.NODE3
                          zwave.0	2019-08-15 20:59:55.970	info	node ready nodeID: 3, nodeInfo: {"manufacturer":"Poly-control","manufacturerid":"0x010e","product":"Danalock V3 BTZE","producttype":"0x0009","productid":"0x0001","type":"Door Lock Keypad","name":"","
                          zwave.0	2019-08-15 20:59:55.969	debug
                          • F fisch
                            hi @all
                            arteckA Offline
                            arteckA Offline
                            arteck
                            @fisch sagte in INFO / ACHTUNG : Zwave-Adapter:
                            NODE3
                            scheint nicht erreichbar zu sein
                            • snadorS Offline
                              snadorS Offline
                              snador
                              Wie ist denn so der allgemeine Stand des Adapters. Ich frage weil mich das Thema Central Scene interessiert und mein NodOn Octane noch nicht funktioniert... Kommt da was oder sollte schon gehen?
                              Danke für die Info!
                              C 1 Antwort Letzte Antwort
                              • MichaM Offline
                                MichaM Offline
                                Micha
                                schrieb am zuletzt editiert von Micha
                                Schließe mich dem Vorredner mal an.
                                Die zwave Installation schlägt fehl auf einen Raspberry 4 mit dem iobroker Image pi_vccu 20190723_buster.
                                Gibt es dafür schon eine Lösung?
                                @AlCalzone
                                Edit
                                Fehlermeldung beim hinzufügen der Instanz
                                $ ./iobroker add zwave --host raspberrypi
                                host.raspberrypi install adapter zwave
                                npm
                                WARN
                                checkPermissions
                                Missing write access to /opt/iobroker/node_modules/iobroker.zwave
                                npm
                                ERR! path
                                /opt/iobroker/node_modules/iobroker.zwavenpm ERR! code
                                EACCESnpm ERR!
                                errno -13npm ERR!
                                syscall access
                                npm
                                ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.zwave'npm ERR! { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.zwave']
                                npm ERR! stack:
                                npm ERR!
                                'Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.zwave'',npm ERR! errno: -13,
                                npm ERR! code: 'EACCES',
                                npm ERR! syscall: 'access',
                                npm ERR! path: '/opt/iobroker/node_modules/iobroker.zwave' }
                                npm ERR!
                                npm ERR! The operation was rejected by your operating system.
                                npm ERR! It is likely you do not have the permissions to access this file as the current user
                                npm ERR!
                                npm ERR! If you believe this might be a permissions issue, please double-check the
                                npm ERR! permissions of the file and its containing directories, or try running
                                npm
                                ERR! the command again as root/Administrator (though this is not recommended).
                                npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2019-09-16T19_50_09_155Z-debug.log
                                Cannot install iobroker.zwave: 243
                                VG Micha
                                • eumatsE Offline
                                  eumatsE Offline
                                  eumats
                                  schrieb am zuletzt editiert von eumats
                                  Mit „permission denied“ steht doch um Log schon ziemlich genau was nicht stimmt...
                                  Mein Vorschlag: Den Fixer laufen lassen (wenn unbekannt, dann Forumsuche) und noch mal versuchen...
                                  MichaM 1 Antwort Letzte Antwort
                                  • snadorS snador
                                    Danke für die Info!
                                    cburghardt
                                    @snador Central Scene wird mittlerweile von openzwave vernünftig unterstützt. Ob es auch mit dem Adapter funktioniert, werde ich demnächst mal testen.
                                    • eumatsE eumats
                                      MichaM Offline
                                      MichaM Offline
                                      Micha
                                      @eumats said in INFO / ACHTUNG : Zwave-Adapter:
                                      Vielen Dank für den Suchvorschlag.
                                      Ich habe sowohl den fix durchgeführt als auch das Forum durchsucht. Das es hier was mit den Rechten zu tun hat sehe ich auch.
                                      Selbst wenn ich den Befehl in der Konsole als Admin eingebe kommt der gleiche Fehler.
                                      Grundsätzlich geht es hier um ein Installationsproblem unter Buster.
                                      Wie oben empfohlen habe ich den zwave per
                                      npm i iobroker.zwave installiert und dann mit
                                      Iobroker upload zwave eingespielt.
                                      Dann auch den npm audit fix ausgeführt und über das UI dann die Instanz installieren wollen.
                                      Laut Anzeige ist zwave auch installiert aber keine Instanz.
                                      Iobroker add zwave bringt auch nichts außer den Fehler.
                                      VG Micha
                                      • MichaM Micha
                                        VG Micha
                                        AlCalzoneA Offline
                                        AlCalzoneA Offline
                                        AlCalzone
                                        @Micha npm audit fix != fixer
                                        Führe den fixer nochmal aus und probiere dann eine Instanz hinzuzufügen.
                                        • MichaM Offline
                                          MichaM Offline
                                          Micha
                                          Hallo @AlCalzone ,
                                          leider führt auch dieser Weg nicht zu dem gewünschten Erfolg.
                                          Habe nochmals ein frisches Image genommen und wollte den Zwave Adapter installieren.
                                          Die Installation auf der UI von Iobroker endet mit folgenden Fehler.
                                          Fertig mit Fehler: fs.js:114 throw err; ^ Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.zwave/iob_npm.done' at Object.openSync (fs.js:443:3) at Object.writeFileSync (fs.js:1194:35) at ChildProcess.child.on (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2938:20) at ChildProcess.emit (events.js:198:13) at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                                          der Fixer endet mit folgenden Fehler.
                                          pi@raspberrypi:/opt/iobroker $ sudo npm audit fix != fixer
                                          npm ERR! code ELOCKVERIFY
                                          npm ERR! Errors were found in your package-lock.json, run npm install to fix them.
                                          npm ERR! Missing: iobroker.b-control-em@^0.2.1
                                          npm ERR! Missing: iobroker.node-red@^1.9.0
                                          npm ERR! /root/.npm/_logs/2019-09-29T11_47_52_769Z-debug.log
                                          Komme da irgendwie nicht weiter.
                                          auf dem Raspi 3B läuft der Adapter.
                                          Hast du noch ne Idee für mich ?
                                          VG Micha
                                          arteckA AlCalzoneA 2 Antworten Letzte Antwort
