  4. INFO / ACHTUNG : Zwave-Adapter
info
64 Beiträge 20 Kommentatoren 14.7k Aufrufe 15 Beobachtet
  • eumatsE eumats
    @Matten
    Wenn ich das richtig verstanden habe bringt der Adapter 1.5.0 OZW 1.6 gleich mit.
    Matten
    @eumats : Danke, leider habe ich das zu spät gemerkt und musste jetzt nochmal aufsetzen.
    Leider habe ich jetzt einen ständigen Neustart:
    host.debian 2019-07-11 13:37:51.689 error instance system.adapter.zwave.0 terminated with code null ()
    host.debian 2019-07-11 13:37:51.688 warn instance system.adapter.zwave.0 terminated due to SIGSEGV
    zwave.0 2019-07-11 13:37:43.111 info State updated: zwave.0.NODE18.SENSOR_MULTILEVEL.Power_1 = 0, index = 4, comClass = 49, instance = 1
    history.0 2019-07-11 13:37:06.988 info enabled logging of zwave.0.NODE5.SENSOR_MULTILEVEL.Power_1, Alias=false
    zwave.0 2019-07-11 13:37:06.989 info State updated: zwave.0.NODE5.SENSOR_MULTILEVEL.Power_1 = 158.6, index = 4, comClass = 49, instance = 1
    history.0 2019-07-11 13:37:05.259 info enabled logging of zwave.0.NODE5.SENSOR_MULTILEVEL.Power_1, Alias=false
    zwave.0 2019-07-11 13:37:05.335 info Update zwave.0.NODE47
    zwave.0 2019-07-11 13:37:05.335 info State updated: zwave.0.NODE45.CONFIGURATION.Load_control_mode = 0, index = 31, comClass = 112, instance = 1
    zwave.0 2019-07-11 13:37:05.335 info State updated: zwave.0.NODE45.CONFIGURATION.Load_control_mode = control mode selected automatically (based on auto-calibration), index = 30, comClass = 112, instance = 1
    zwave.0 2019-07-11 13:37:05.335 info State updated: zwave.0.NODE45.METER.Reset = false, index = 33, comClass = 50, instance = 2
    zwave.0 2019-07-11 13:37:05.335 info State updated: zwave.0.NODE45.METER.Reset = false, index = 33, comClass = 50, instance = 1
    zwave.0 2019-07-11 13:37:05.334 info Update zwave.0.NODE45
    zwave.0 2019-07-11 13:37:05.334 info State updated: zwave.0.NODE29.CONFIGURATION.Load_control_mode = 0, index = 31, comClass = 112, instance = 1
    zwave.0 2019-07-11 13:37:05.334 info State updated: zwave.0.NODE29.CONFIGURATION.Load_control_mode = 5, index = 30, comClass = 112, instance = 1
    zwave.0 2019-07-11 13:37:05.334 info Update zwave.0.NODE29
    Das ist ein Auszug. Zwave startet und updatet alle nodes, dann bricht er ab und startet neu. Das seltsame ist, ich kann
    die Geräte steuern, also bis dahin funktioniert alles. Das ist natürlich kein Zustand. Hat jemand eine Idee?
    Hardware: NUC 386i, Proxmox: als VM ioBroker, HomeMatic, Hue(Zigbee), UnifiAC, Visualisierung: 24 Zoll Touchscreen Portrait Modus
    • M Matten
      AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      @Matten sagte in INFO / ACHTUNG : Zwave-Adapter:
      SIGSEGV
      Klingt für mich als wäre beim Update was nicht sauber gelaufen. Am besten mal den Z-Wave-Adapter komplett löschen (nicht nur Instanzen) und neu installieren.
      • AlCalzoneA AlCalzone
        SIGSEGV
        Matten
        @AlCalzone Danke, das war es. 👍
        • F Offline
          fisch
          habe heute den 1.5.0 insatlliert...jetzt geht wieder nichts :-(
          $ ./iobroker add zwave  --host ioBroker-Pi
          host.ioBroker-Pi install adapter zwave
          npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.zwave"
          find: ‘/tmp/systemd-private-e840114d2b404515948665fe563358d5-redis-server.service-S60QFf’: Keine Berechtigungfind: ‘/tmp/systemd-private-e840114d2b404515948665fe563358d5-colord.service-o5xroB’: Keine Berechtigung
            % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current                                 Dload  Upload   Total   Spent    Left  Speed
            0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
          100   125    0   125    0     0    362      0 --:--:-- --:--:-- --:--:--   363
            0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0Warning: Failed to create the file master.zip: Keine Berechtigung
            0 12.5M    0  1370    0     0   1615      0  2:16:13 --:--:--  2:16:13 12685
          curl: (23) Failed writing body (0 != 1370)
          /opt/iobroker/node_modules/iobroker.zwave/lib/preinstall.js:16    if (!suppressException) throw e;
          Error: Command failed: curl -L -O https://github.com/OpenZWave/open-zwave/archive/master.zip
              at checkExecSyncError (child_process.js:629:11)
              at Object.execSync (child_process.js:666:13)
              at doScript (/opt/iobroker/node_modules/iobroker.zwave/lib/preinstall.js:13:15)
              at installOpenZwaveFromSource (/opt/iobroker/node_modules/iobroker.zwave/lib/preinstall.js:147:3)
              at installOpenZwave (/opt/iobroker/node_modules/iobroker.zwave/lib/preinstall.js:139:3)
              at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zwave/lib/preinstall.js:27:7)
              at Module._compile (internal/modules/cjs/loader.js:776:30)
              at Object.Module._extensions..js (internal/modules/cjs/loader.js:787:10)
              at Module.load (internal/modules/cjs/loader.js:653:32)
              at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
          npm
          ERR! code ELIFECYCLEnpm ERR! errno 1
          npm ERR! iobroker.zwave@1.5.0 preinstall: `node lib/preinstall.js`npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the iobroker.zwave@1.5.0 preinstall script.
          npm WARN Local package.json exists, but node_modules missing, did you mean to install?
          npm ERR!     /home/iobroker/.npm/_logs/2019-07-12T13_49_56_096Z-debug.log
          ERROR: fs.js:114    throw err;
          Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.zwave/iob_npm.done'
              at Object.openSync (fs.js:443:3)
              at Object.writeFileSync (fs.js:1194:35)
              at ChildProcess.child.on (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2946:20)
              at ChildProcess.emit (events.js:198:13)
              at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
          ERROR: process exited with code 1
          Kann mir jemand weiterhelfen?
          habe schon iobroker del zwave gemacht und neuinstalliert... und dann über Admin eine neue Instanz installieren wollen
          • F Offline
            fisch
            schrieb am zuletzt editiert von fisch
            ok installiert habe ich ihn nun bekommen....
            host.ioBroker-Pi	2019-07-12 16:51:28.841	error	instance system.adapter.zwave.0 terminated with code 0 (OK)
            Caught	2019-07-12 16:51:28.841	error	by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
            Caught	2019-07-12 16:51:28.841	error	by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:787:10)
            Caught	2019-07-12 16:51:28.841	error	by controller[0]: at Module._compile (internal/modules/cjs/loader.js:776:30)
            Caught	2019-07-12 16:51:28.841	error	by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/lib/openzwave-shared.js:27:19)
            Caught	2019-07-12 16:51:28.841	error	by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
            Caught	2019-07-12 16:51:28.841	error	by controller[0]: at Module.require (internal/modules/cjs/loader.js:690:17)
            Caught	2019-07-12 16:51:28.840	error	by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
            Caught	2019-07-12 16:51:28.840	error	by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
            Caught	2019-07-12 16:51:28.840	error	by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
            Caught	2019-07-12 16:51:28.840	error	by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:805:18)
            Caught	2019-07-12 16:51:28.839	error	by controller[0]: Error: libopenzwave.so.1.6: cannot open shared object file: No such file or directory
            EDIT: OK, ich habe wieder die 1.4.2 installiert...geht wieder?!
            Mit der 1.5.0 gehts leider nicht!
            F 1 Antwort Letzte Antwort
            • F fisch
              fisch
              Erledigt:
              mit
              sudo ldconfig
              läuft es nun !°
              • G Offline
                gery80
                Hallo versuche gerade zwave adapter zu installieren leider funktioniert es nicht image ist das neue ioBroker Image für Raspberry Pi2/3/4 Buster mit piVCCU 20190723 bitte um hilfe
                $ ./iobroker add zwave  --host IOBroker
                NPM version: 6.9.0
                npm install iobroker.zwave@1.4.2 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
                find: ‘/tmp/systemd-private-7f33173bc5a64f34b66e60d9b4e94fb9-systemd-timesyncd.service-fwIlBw’: Keine Berechtigungfind: ‘/tmp/pivccu-var/empty’: Keine Berechtigung
                find: ‘/tmp/systemd-private-7f33173bc5a64f34b66e60d9b4e94fb9-redis-server.service-prEu7C’: Keine Berechtigung
                100   122    0   122    0     0    231      0 --:--:-- --:--:-- --:--:--   231
                  0 1917k    0   733    0     0    698      0  0:46:53  0:00:01  0:46:52   698
                 49 1917k   49  942k    0     0   426k      0  0:00:04  0:00:02  0:00:02  811k
                100 1917k  100 1917k    0     0   830k      0  0:00:02  0:00:02 --:--:-- 1521k
                100   147    0   147    0     0    281      0 --:--:-- --:--:-- --:--:--   281
                100 16081    0 16081    0     0  12958      0 --:--:--  0:00:01 --:--:-- 40506
                /opt/iobroker/node_modules/iobroker.zwave/open-zwave-1.4/cpp/src/command_classes/DoorLockLogging.cpp: In member function ‘virtual bool OpenZWave::DoorLockLogging::HandleMsg(const uint8*, uint32, uint32)’:/opt/iobroker/node_modules/iobroker.zwave/open-zwave-1.4/cpp/src/command_classes/DoorLockLogging.cpp:313:48: error: ‘char* strncat(char*, const char*, size_t)’ output may be truncated copying between 0 and 253 bytes from a string of length 253 [-Werror=stringop-truncation]
                                                         strncat(usercode, tmpusercode, sizeof(usercode) - strlen(usercode) - 1 );
                cc1plus: all warnings being treated as errors
                make[1]: *** [/opt/iobroker/node_modules/iobroker.zwave/open-zwave-1.4/cpp/build/support.mk:151: /opt/iobroker/node_modules/iobroker.zwave/open-zwave-1.4/.lib/DoorLockLogging.o] Fehler 1
                make: *** [Makefile:20: all] Fehler 2
                Error: Command failed: cd open-zwave-1.4 && make && sudo make install
                    at installOpenZwaveFromSource (/opt/iobroker/node_modules/iobroker.zwave/lib/preinstall.js:154:3)
                    at Module._compile (internal/modules/cjs/loader.js:778:30)
                    at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                npm
                 WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                npm
                npm ERR! iobroker.zwave@1.4.2 preinstall: `node lib/preinstall.js`npm
                ERR! Exit status 1npm ERR!
                npm ERR! Failed at the iobroker.zwave@1.4.2 preinstall script.
                npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-08-14T19_44_00_445Z-debug.log
                host.IOBroker install adapter zwave
                NPM version: 6.9.0
                100   122    0   122    0     0    243      0 --:--:-- --:--:-- --:--:--   242
                  1 1917k    1 39004    0     0  34486      0  0:00:56  0:00:01  0:00:55 34486
                100 1917k  100 1917k    0     0   952k      0  0:00:02  0:00:02 --:--:-- 2131k
                100   147    0   147    0     0    280      0 --:--:-- --:--:-- --:--:--   280
                100 16026    0 16026    0     0  13501      0 --:--:--  0:00:01 --:--:-- 13501
                100 16081    0 16081    0     0  13536      0 --:--:--  0:00:01 --:--:-- 55000
                npm
                npm
                npm ERR! iobroker.zwave@1.4.2 preinstall: `node lib/preinstall.js`npm ERR! Exit status 1
                npm
                ERR! npm ERR! Failed at the iobroker.zwave@1.4.2 preinstall script.
                npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-08-14T19_47_05_108Z-debug.log
                NPM version: 6.9.0
                100   122    0   122    0     0    223      0 --:--:-- --:--:-- --:--:--   223
                  4 1917k    4 95062    0     0  64274      0  0:00:30  0:00:01  0:00:29 64274
                 55 1917k   55 1065k    0     0   435k      0  0:00:04  0:00:02  0:00:02 1004k
                100 1917k  100 1917k    0     0   626k      0  0:00:03  0:00:03 --:--:-- 1153k
                100   147    0   147    0     0    231      0 --:--:-- --:--:-- --:--:--   231
                100 16081    0 16081    0     0  11502      0 --:--:--  0:00:01 --:--:-- 11502
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                npm ERR! code ELIFECYCLE
                npm ERR! errno 1
                npm ERR!
                npm ERR!     /home/iobroker/.npm/_logs/2019-08-14T19_50_10_182Z-debug.log
                ERROR: host.IOBroker Cannot install zwave
                ERROR: process exited with code 13
                • G gery80
                  NPM version: 6.9.0
                  npm
                  npm
                  NPM version: 6.9.0
                  npm
                  npm
                  npm
                  NPM version: 6.9.0
                  npm ERR! errno 1
                  npm ERR!
                  arteckA Offline
                  arteckA Offline
                  arteck
                  @gery80
                  welche version versuchst du zu installieren ???
                  • arteckA arteck
                    @gery80
                    AlCalzoneA Offline
                    AlCalzoneA Offline
                    AlCalzone
                    @arteck Laut Log 1.4.2, welche OZW 1.4 mitbringt.
                    @gery80 kannst du mal probieren, die Version 1.5.1 zu installieren?
                    cd /opt/iobroker
                    npm i iobroker.zwave
                    iobroker upload zwave
                    G 1 Antwort Letzte Antwort
                      cd /opt/iobroker
                      gery80
                      @AlCalzone Hallo zwave wurde installiert jedoch bei iobroker upload zwave sagt er mir es wurde nicht gefunden
                      + iobroker.zwave@1.5.1
                      added 2 packages from 29 contributors and audited 1926 packages in 1571.599s
                      found 39 vulnerabilities (28 low, 11 high)
                        run `npm audit fix` to fix them, or `npm audit` for details
                      pi@IOBroker:/opt/iobroker $ iobroker upload zwave
                      got /opt/iobroker/node_modules/iobroker.zwave/admin
                      upload [15] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/zwave.png zwave.png image/png
                      upload [14] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/words.js words.js application/javascript
                      upload [13] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/js/comClasses.js js/comClasses.js application/javascript
                      upload [12] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/index.html index.html text/html
                      upload [11] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/soft-reset.png img/soft-reset.png image/png
                      upload [10] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/sleepOn.png img/sleepOn.png image/png
                      upload [9] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/sleep.png img/sleep.png image/png
                      upload [8] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/readyOn.png img/readyOn.png image/png
                      upload [7] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/ready.png img/ready.png image/png
                      upload [6] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/neighbors.png img/neighbors.png image/png
                      upload [5] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/heal.png img/heal.png image/png
                      upload [4] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/hard-reset.png img/hard-reset.png image/png
                      upload [3] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/delete.png img/delete.png image/png
                      upload [2] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/aliveOn.png img/aliveOn.png image/png
                      upload [1] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/alive.png img/alive.png image/png
                      upload [0] zwave.admin /opt/iobroker/node_modules/iobroker.zwave/admin/img/add.png img/add.png image/png
                      system.adapter.zwave does not exist
                      • G gery80
                        AlCalzoneA Offline
                        AlCalzoneA Offline
                        AlCalzone
                        @gery80 Alles gut, dann musst du im Admin noch eine Instanz hinzufügen.
                          gery80
                          schrieb am zuletzt editiert von gery80
                          @AlCalzone kannst du mir das bitte erklären wie ich die Instanz hinzufüge ich bring es einfach nicht zusammen danke
                          • G gery80
                            AlCalzoneA Offline
                            AlCalzoneA Offline
                            AlCalzone
                            @gery80 Dann empfehle ich die Doku zu lesen:
                            https://www.iobroker.net/#de/documentation/tutorial/adapter.md
                            • G Offline
                              gery80
                              danke hat funktioniert
                              • F Offline
                                fisch
                                hi @all
                                kann mir jemand sagen was das genau beduetet?
                                Inkludieren klappt ohne Probleme aber, sobald ich schalten will kommt das:
                                zwave.0	2019-08-15 21:01:41.841	debug	node3: timeout
                                zwave.0	2019-08-15 21:01:31.841	debug	node3: timeout
                                zwave.0	2019-08-15 21:01:21.840	debug	node3: timeout
                                zwave.0	2019-08-15 21:01:18.294	debug	system.adapter.admin.0: logging true
                                zwave.0	2019-08-15 21:01:13.925	debug	setState for: nodeID=3: comClass=98: index=0: instance=1: value=true
                                zwave.0	2019-08-15 21:01:13.925	debug	stateChange zwave.0.NODE3.DOOR_LOCK.Locked_1 set {"val":true,"ack":false,"ts":1565895673921,"q":0,"from":"system.adapter.node-red.0","user":"system.user.admin","lc":1565895673700}
                                zwave.0	2019-08-15 21:01:13.782	debug	setState for: nodeID=3: comClass=98: index=0: instance=1: value=true
                                zwave.0	2019-08-15 21:01:13.782	debug	stateChange zwave.0.NODE3.DOOR_LOCK.Locked_1 set {"val":true,"ack":false,"ts":1565895673779,"q":0,"from":"system.adapter.node-red.0","user":"system.user.admin","lc":1565895673700}
                                zwave.0	2019-08-15 21:01:13.705	debug	setState for: nodeID=3: comClass=98: index=0: instance=1: value=true
                                zwave.0	2019-08-15 21:01:13.704	debug	stateChange zwave.0.NODE3.DOOR_LOCK.Locked_1 set {"val":true,"ack":false,"ts":1565895673700,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1565895673700}
                                zwave.0	2019-08-15 21:01:11.839	debug	setState for: nodeID=3: comClass=98: index=0: instance=1: value=false
                                zwave.0	2019-08-15 21:01:11.838	debug	stateChange zwave.0.NODE3.DOOR_LOCK.Locked_1 set {"val":false,"ack":false,"ts":1565895671836,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1565891882149}
                                zwave.0	2019-08-15 21:01:09.012	debug	system.adapter.admin.0: logging false
                                zwave.0	2019-08-15 21:00:44.352	debug	system.adapter.admin.0: logging true
                                zwave.0	2019-08-15 20:59:55.980	debug	fixing zwave buttons to use common.role "switch" instead of "button"
                                zwave.0	2019-08-15 20:59:55.976	info	Scan completed
                                zwave.0	2019-08-15 20:59:55.970	info	Update zwave.0.NODE3
                                zwave.0	2019-08-15 20:59:55.970	info	node ready nodeID: 3, nodeInfo: {"manufacturer":"Poly-control","manufacturerid":"0x010e","product":"Danalock V3 BTZE","producttype":"0x0009","productid":"0x0001","type":"Door Lock Keypad","name":"","
                                zwave.0	2019-08-15 20:59:55.969	debug
                                • F fisch
                                  hi @all
                                  arteckA Offline
                                  arteckA Offline
                                  arteck
                                  @fisch sagte in INFO / ACHTUNG : Zwave-Adapter:
                                  NODE3
                                  scheint nicht erreichbar zu sein
                                  • snadorS Offline
                                    snadorS Offline
                                    snador
                                    Wie ist denn so der allgemeine Stand des Adapters. Ich frage weil mich das Thema Central Scene interessiert und mein NodOn Octane noch nicht funktioniert... Kommt da was oder sollte schon gehen?
                                    Danke für die Info!
                                    C 1 Antwort Letzte Antwort
                                    • MichaM Offline
                                      MichaM Offline
                                      Micha
                                      schrieb am zuletzt editiert von Micha
                                      Schließe mich dem Vorredner mal an.
                                      Die zwave Installation schlägt fehl auf einen Raspberry 4 mit dem iobroker Image pi_vccu 20190723_buster.
                                      Gibt es dafür schon eine Lösung?
                                      @AlCalzone
                                      Edit
                                      Fehlermeldung beim hinzufügen der Instanz
                                      $ ./iobroker add zwave --host raspberrypi
                                      host.raspberrypi install adapter zwave
                                      npm
                                      WARN
                                      checkPermissions
                                      Missing write access to /opt/iobroker/node_modules/iobroker.zwave
                                      npm
                                      ERR! path
                                      /opt/iobroker/node_modules/iobroker.zwavenpm ERR! code
                                      EACCESnpm ERR!
                                      errno -13npm ERR!
                                      syscall access
                                      npm
                                      ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.zwave'npm ERR! { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.zwave']
                                      npm ERR! stack:
                                      npm ERR!
                                      'Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.zwave'',npm ERR! errno: -13,
                                      npm ERR! code: 'EACCES',
                                      npm ERR! syscall: 'access',
                                      npm ERR! path: '/opt/iobroker/node_modules/iobroker.zwave' }
                                      npm ERR!
                                      npm ERR! The operation was rejected by your operating system.
                                      npm ERR! It is likely you do not have the permissions to access this file as the current user
                                      npm ERR!
                                      npm ERR! If you believe this might be a permissions issue, please double-check the
                                      npm ERR! permissions of the file and its containing directories, or try running
                                      npm
                                      ERR! the command again as root/Administrator (though this is not recommended).
                                      npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2019-09-16T19_50_09_155Z-debug.log
                                      Cannot install iobroker.zwave: 243
                                      VG Micha
                                      • eumatsE Offline
                                        eumatsE Offline
                                        eumats
                                        schrieb am zuletzt editiert von eumats
                                        Mit „permission denied“ steht doch um Log schon ziemlich genau was nicht stimmt...
                                        Mein Vorschlag: Den Fixer laufen lassen (wenn unbekannt, dann Forumsuche) und noch mal versuchen...
                                        MichaM 1 Antwort Letzte Antwort
                                        • snadorS snador
                                          Danke für die Info!
                                          cburghardt
                                          @snador Central Scene wird mittlerweile von openzwave vernünftig unterstützt. Ob es auch mit dem Adapter funktioniert, werde ich demnächst mal testen.
