  3. Entwicklung
  4. [Neuer Adapter] hue-extended
adapter
441 Beiträge 32 Kommentatoren 144.1k Aufrufe 31 Beobachtet
  • ZefauZ Zefau
    @sigi234 sagte in [Neuer Adapter] hue-lights:
    Ja, ich habe beobachtet dass wenn ich Alle angehakt habe das im 0-3 Sekunden Takt diese abgerufen werden........
    Bitte den Punkt in der neuen Version nochmal validieren. Danke dir.
    BBTownB Offline
    BBTownB Offline
    BBTown
    @Zefau
    ich habe auch einige Fehlermeldungen
    hue-lights.0	2019-08-07 22:40:31.439	error	at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
    hue-lights.0	2019-08-07 22:40:31.439	error	at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
    hue-lights.0	2019-08-07 22:40:31.439	error	at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
    hue-lights.0	2019-08-07 22:40:31.439	error	at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
    hue-lights.0	2019-08-07 22:40:31.439	error	at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
    hue-lights.0	2019-08-07 22:40:31.439	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
    hue-lights.0	2019-08-07 22:40:31.439	error	at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    hue-lights.0	2019-08-07 22:40:31.439	error	at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
    hue-lights.0	2019-08-07 22:40:31.439	error	at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
    hue-lights.0	2019-08-07 22:40:31.439	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
    hue-lights.0	2019-08-07 22:40:31.439	error	at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    hue-lights.0	2019-08-07 22:40:31.439	error	at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
    hue-lights.0	2019-08-07 22:40:31.439	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    hue-lights.0	2019-08-07 22:40:31.439	error	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    hue-lights.0	2019-08-07 22:40:31.439	error	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
    hue-lights.0	2019-08-07 22:40:31.439	error	at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
    hue-lights.0	2019-08-07 22:40:31.439	error	at Socket.that.getForeignObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:870:25)
    hue-lights.0	2019-08-07 22:40:31.439	error	at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:831:13)
    hue-lights.0	2019-08-07 22:40:31.439	error	at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:870:54)
    hue-lights.0	2019-08-07 22:40:31.439	error	at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5290:18)
    hue-lights.0	2019-08-07 22:40:31.439	error	at Adapter.emit (events.js:198:13)
    hue-lights.0	2019-08-07 22:40:31.439	error	at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.hue-lights/hue-lights.js:79:19)
    hue-lights.0	2019-08-07 22:40:31.439	error	TypeError: library.terminate is not a function
    hue-lights.0	2019-08-07 22:40:31.439	error	uncaught exception: library.terminate is not a function
    • ZefauZ Offline
      ZefauZ Offline
      Zefau
      Merkwürdig, bei mir läuft es sauber. Dann geht erstmal auf die Vorversion. Ich schaue heute Abend nochmal.
      • HiltexH Offline
        HiltexH Offline
        Hiltex
        Hi.
        Ich habe heute meine ersten HUE-Lampen in Betrieb genommen und direkt mal diesen Adapter ausprobiert. Auf der Suche nach einer Möglichkeit, eine Lampe mit einem einzelnen Befehl zu steuern ist mir aufgefallen, dass der Datenpunkt xy einer Lampe vom Typ value ist, jedoch einen Wert wie 0.2503,0.5168 trägt. Dieses Format passt jedoch nicht zum Typ value, weshalb man da nichts verwertbares eingeben kann.
        Gestattet mir jedoch bitte folgende allgemeine Frage:
        Wie kann man die Lichtfarbe, Helligkeit und Temperatur einer Lampe einstellen? Welche Datenpunkte müssen dazu verwendet werden?
        Blog: indibit.de
        ZefauZ 2 Antworten Letzte Antwort
        • ZefauZ Offline
          ZefauZ Offline
          Zefau
          @BBTown @sigi234 Hab nochmal ein Update auf Github geschoben (Versionsnummer bleibt gleich). Bitte nochmal probieren, ob es nun stabiler läuft.
          BBTownB sigi234S 2 Antworten Letzte Antwort
          • HiltexH Hiltex
            Hi.
            ZefauZ Offline
            ZefauZ Offline
            Zefau
            @Hiltex sagte in [Neuer Adapter] hue-lights:
            Habe ich in der aktuellen Version auf Github angepasst. Bitte die Version von Github drüber installieren. Danach bitte den Datenpunkt xy löschen und Adapter neustarten. Der (angepasste) Datenpunkt sollte dann richtig angelegt werden.
            • HiltexH Hiltex
              Hi.
              ZefauZ Offline
              ZefauZ Offline
              Zefau
              hue ist das Farbspektrum (Lichtfarbe?). Helligkeit ist bri.
              HiltexH 1 Antwort Letzte Antwort
              • ZefauZ Zefau
                BBTownB Offline
                BBTownB Offline
                BBTown
                @Zefau
                Mein erster Eindruck ist, dass alles sehr viel ruhiger läuft 👍
                • ZefauZ Zefau
                  HiltexH Offline
                  HiltexH Offline
                  Hiltex
                  @Zefau Danke. Aber hast du das auch mal ausprobiert? Normalerweise müsste die Lampe ja rot leuchten, wenn ich da eine 0 reinschreibe, gelb bei 90, usw. das funktioniert jedoch leider nicht.
                  Auch die Kombination mit HomeKit und Yahka funktioniert nicht, wobei ich behaupten würde, das HomeKit und Yahka korrekt arbeiten. Ich hab die Werte mal in ein paar Testdatenpunkte schreiben lassen und da kommen die Werte wie erwartet an.
                  Der andere Hue-Adapter arbeitet da meiner Ansicht nach auch nicht korrekt. Dort konnte ich mir aber mit XY behelfen.
                  Ich würde mich freuen, wenn du dir das nochmal anschauen könntest.
                  Blog: indibit.de
                  ZefauZ 3 Antworten Letzte Antwort
                  • HiltexH Hiltex
                    ZefauZ Offline
                    ZefauZ Offline
                    Zefau
                    schrieb am zuletzt editiert von Zefau
                    Laut hue API Dokumentation:
                    Hue of the light. This is a wrapping value between 0 and 65535.
                    Note, that hue/sat values are hardware dependent which means that programming two devices with the same value does not garantuee that they will be the same color. Programming 0 and 65535 would mean that the light will resemble the color red, 21845 for green and 43690 for blue.
                    • HiltexH Hiltex
                      ZefauZ Offline
                      ZefauZ Offline
                      Zefau
                      Welche Kombination? Mit dem Datenpunkt für den hue Wert?
                      • HiltexH Hiltex
                        ZefauZ Offline
                        ZefauZ Offline
                        Zefau
                        Sollte nun auch bei diesem Adapter funktionieren. Ggf. die alten States löschen und neu anlegen.
                        BBTownB 2 Antworten Letzte Antwort
                        • ZefauZ Zefau
                          sigi234S Online
                          sigi234S Online
                          @Zefau sagte in [Neuer Adapter] hue-lights:
                          Nein nicht so Richtig, ich glaube es hat was damit zu tun, weil ich auch den Hue Adapter laufen habe und die App all4hue.
                          Wenn ich alles anhake habe ich ca. 3000 Datenpunkte..........
                          Edit2
                          Es wird besser, braucht anscheinend zum Anfang einige Zeit..........derzeit 1400 DP. Einige Haken habe ich aber mal rausgenommen.
                          • ZefauZ Zefau
                            BBTownB Offline
                            BBTownB Offline
                            BBTown
                            xy ist nun aber erneut als "text" angelegt?!
                            • ZefauZ Zefau
                              BBTownB Offline
                              BBTownB Offline
                              BBTown
                              schrieb am zuletzt editiert von BBTown
                              @Zefau
                              müßten "bri" und "level" nicht beide vom Typ "level.dimmer" sein?
                              EDIT
                              https://www.iobroker.net/#en/documentation/dev/stateroles.md
                              • BBTownB BBTown
                                ZefauZ Offline
                                ZefauZ Offline
                                Zefau
                                @BBTown sagte in [Neuer Adapter] hue-lights:
                                Als was ist es denn im hue Adapter angelegt? Funktioniert es denn auch nicht als Text?
                                BBTownB 1 Antwort Letzte Antwort
                                • ZefauZ Zefau
                                  HiltexH Offline
                                  HiltexH Offline
                                  Hiltex
                                  Soweit richtig, 0...360° waren die alten Werte. Entsprechend der Beschreibung müsste bei voller Sättigung (255) und Farbwert 21845 die Lampe grün leuchten. Das tut sie aber nicht, die Farbe bleibt einfach unverändert und der Wert, der zuvor in hue geschrieben wurde, wird bei der nächsten Aktualisierung einfach auf 0 gesetzt.
                                  Ja genau, die Farbe über HomeKit -> Yahka -> hue-lights zu setzen. Das ist das eigentlich erklärte ziel. Dass das jedoch nicht funktioniert, wenn das manuelle setzen des hue-Wertes nicht klappt, scheint mir logisch ;)
                                  Blog: indibit.de
                                  • HiltexH Hiltex
                                    ZefauZ Offline
                                    ZefauZ Offline
                                    Zefau
                                    @Hiltex Jo, ich versuche es komplett zu verstehen. Was sagt das Log?
                                    • ZefauZ Zefau
                                      HiltexH Offline
                                      HiltexH Offline
                                      Hiltex
                                      schrieb am zuletzt editiert von Hiltex
                                      #66
                                      @Zefau das Log:
                                      hue-lights.0	2019-08-09 07:59:18.602	debug	system.adapter.admin.0: logging true
                                      hue-lights.0	2019-08-09 07:59:13.941	debug	Refreshing scenes ({"scenes":{"HCms0PK98-UyxCI":{"name":"Entspannen","type":"GroupScene","group":"8","lights":["1","2"],"owner":"ebd73c0e-eba4-41b3-8c88-9a29acc06964","recycle":false,"locked":false,"
                                      hue-lights.0	2019-08-09 07:59:13.924	debug	Retrieving scenes from Hue Bridge...
                                      hue-lights.0	2019-08-09 07:59:13.915	debug	Refreshing lights ({"lights":{"1":{"state":{"on":false,"bri":254,"hue":0,"sat":189,"effect":"none","xy":[0.4426,0.4058],"ct":345,"alert":"select","colormode":"xy","mode":"homeautomation","reachable":
                                      hue-lights.0	2019-08-09 07:59:13.904	debug	Received updated value for config.whitelist.xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx-node.js_api.last use date: "2019-08-09T05:59:14"
                                      hue-lights.0	2019-08-09 07:59:13.902	debug	Received updated value for config.localtime: "2019-08-09T07:59:14"
                                      hue-lights.0	2019-08-09 07:59:13.901	debug	Received updated value for config.UTC: "2019-08-09T05:59:14"
                                      hue-lights.0	2019-08-09 07:59:13.900	debug	Refreshing config ({"config":{"name":"Philips hue","zigbeechannel":20,"bridgeid":"ECB5FAFFFE054110","mac":"ec:b5:fa:05:41:10","dhcp":true,"ipaddress":"192.168.243.61","netmask":"255.255.255.0","gatew
                                      hue-lights.0	2019-08-09 07:59:13.898	debug	Retrieving lights from Hue Bridge...
                                      hue-lights.0	2019-08-09 07:59:13.885	debug	Retrieving config from Hue Bridge...
                                      hue-lights.0	2019-08-09 07:59:13.065	debug	system.adapter.admin.0: logging false
                                      hue-lights.0	2019-08-09 07:59:07.813	info	Successfully set /lights/2/state/hue on device Nachttischlampe rechts (to 21000).
                                      hue-lights.0	2019-08-09 07:59:07.799	debug	Send command to Nachttischlampe rechts (lights/2/state): {"hue":21000}.
                                      Blog: indibit.de
                                      • HiltexH Hiltex
                                        @Zefau das Log:
                                        ZefauZ Offline
                                        ZefauZ Offline
                                        Zefau
                                        #67
                                        @Hiltex ok danke. Prüfe ich heute Abend. Lösch bitte die Zeile mit whitelist, da steht dein User.
                                        • ZefauZ Zefau
                                          BBTownB Offline
                                          BBTownB Offline
                                          BBTown
                                          #68
                                          es geht ja nicht nur darum ob es grundsätzlich funktioniert, sondern um Einheitlichkeit.
                                          Wenn ich zum Beispiel Abfrage welche Lampen und Dimmer noch eingeschaltet sind, dann suche ich nach "switch.light" und "level.dimmer"
                                          Anbei die Aufstellung eines Color-Bulb aus dem ursprünglichen HUE-Adpter
