    6.7k
7.5k Beiträge 335 Kommentatoren 11.6m Aufrufe 254 Beobachtet
  • simatecS simatec
    @SWeimar
    Starte nach der kompletten Deinstallation mal dein iobroker neu.
    Der Log in Version 0.2.10 müsste wie folgt aussehen
    shuttercontrol.0	2019-06-19 18:10:00.016	debug	redis pmessage io.shuttercontrol.0.info.Elevation io.shuttercontrol.0.info.Elevation {"val":28.3,"ack":true,"ts":1560960600013,"q":0,"from":"system.adapter.shuttercontrol.0","user":"system.user.admin
    shuttercontrol.0	2019-06-19 18:10:00.016	debug	redis pmessage io.shuttercontrol.0.info.Azimut io.shuttercontrol.0.info.Azimut {"val":272.4,"ack":true,"ts":1560960600013,"q":0,"from":"system.adapter.shuttercontrol.0","user":"system.user.admin","lc
    shuttercontrol.0	2019-06-19 18:10:00.014	debug	Sun Elevation: 28.3°
    shuttercontrol.0	2019-06-19 18:10:00.014	debug	Sun Azimut: 272.4°
    host.iobroker-dev	2019-06-19 18:00:08.660	info	instance system.adapter.weatherunderground.0 terminated with code 0 (OK)
    shuttercontrol.0	2019-06-19 18:00:07.024	debug	Set ID: javascript.0.Rolladen.Kind_1.LEVEL value: 50%
    shuttercontrol.0	2019-06-19 18:00:06.148	debug	TriggerID Change: weatherunderground.0.forecast.current.temp
    shuttercontrol.0	2019-06-19 18:00:06.148	debug	redis pmessage io.weatherunderground.0.forecast.current.temp io.weatherunderground.0.forecast.current.temp {"val":31.1,"ack":true,"ts":1560960006140,"q":0,"from":"system.adapter.weatherunderground.0"
    weatherunderground.0	2019-06-19 18:00:02.117	info	starting. Version 3.0.11 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v8.15.0
    host.iobroker-dev	2019-06-19 18:00:00.034	info	instance system.adapter.weatherunderground.0 started with pid 16723
    shuttercontrol.0	2019-06-19 18:00:00.017	debug	redis pmessage io.shuttercontrol.0.info.Elevation io.shuttercontrol.0.info.Elevation {"val":29.8,"ack":true,"ts":1560960000014,"q":0,"from":"system.adapter.shuttercontrol.0","user":"system.user.admin
    shuttercontrol.0	2019-06-19 18:00:00.017	debug	redis pmessage io.shuttercontrol.0.info.Azimut io.shuttercontrol.0.info.Azimut {"val":270.5,"ack":true,"ts":1560960000014,"q":0,"from":"system.adapter.shuttercontrol.0","user":"system.user.admin","lc
    shuttercontrol.0	2019-06-19 18:00:00.015	debug	Sun Elevation: 29.8°
    shuttercontrol.0	2019-06-19 18:00:00.015	debug	Sun Azimut: 270.5°
    shuttercontrol.0	2019-06-19 17:50:00.017	debug	redis pmessage io.shuttercontrol.0.info.Elevation io.shuttercontrol.0.info.Elevation {"val":31.4,"ack":true,"ts":1560959400014,"q":0,"from":"system.adapter.shuttercontrol.0","user":"system.user.admin
    shuttercontrol.0	2019-06-19 17:50:00.017	debug	redis pmessage io.shuttercontrol.0.info.Azimut io.shuttercontrol.0.info.Azimut {"val":268.5,"ack":true,"ts":1560959400014,"q":0,"from":"system.adapter.shuttercontrol.0","user":"system.user.admin","lc
    shuttercontrol.0	2019-06-19 17:50:00.015	debug	Sun Elevation: 31.4°
    shuttercontrol.0	2019-06-19 17:50:00.014	debug	Sun Azimut: 268.5°
    SWE1008S Offline
    SWE1008S Offline
    SWE1008
    #467
    @simatec
    Nochmal deinstalliert, iobroker neu gestartet, neu installiert und konfiguriert. Nachdem alle Einstellungen gemacht wurden wird das Log im Debug Modus wieder voll gespamt.
    • SWE1008S SWE1008
      @simatec
      simatecS Offline
      simatecS Offline
      simatec
      #468
      @SWeimar sagte in [Aufruf] Neuer Adapter ioBroker.shuttercontrol:
      @simatec
      Hast auch mal dein System neu gestartet nach der Deinstallation? Die Meldungen scheinen ja von Redis zukommen.
      Shuttercontrol gibt diese Meldungen nicht raus
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      SWE1008S 1 Antwort Letzte Antwort
      • simatecS simatec
        @simatec
        SWE1008S Offline
        SWE1008S Offline
        SWE1008
        #469
        @simatec
        Ja, nach deinstallation Rechner komplett neu gestartet.
        • SWE1008S SWE1008
          @simatec
          simatecS Offline
          simatecS Offline
          simatec
          #470
          @SWeimar
          Und sind die Meldungen weg?
          • simatecS simatec
            @SWeimar
            SWE1008S Offline
            SWE1008S Offline
            SWE1008
            #471
            @simatec
            @SWeimar said in [Aufruf] Neuer Adapter ioBroker.shuttercontrol:
            @simatec
            Mit "iobroker neu gestartet" meinte ich den kompletten Rechner neu gestartet.
            Aber als Quelle der Meldungen steht doch shuttercontrol drin. Dann kommen die Meldungen doch auch da her, oder täusche ich mich?
            • SWE1008S SWE1008
              @simatec
              @simatec
              simatecS Offline
              simatecS Offline
              simatec
              #472
              @SWeimar
              Mache mal bitte folgendes ... lösche mal alles komplett und starte den Adapter nach neuer Installation nur mit dem example shutter in der Tabelle drin.
              Ohne irgendwelche Änderungen an der Config.
              Dann schalt ihn im Anschluss mal auf debug und schaue was an Meldungen kommt.
              Die Meldungen kommen nicht aus dem Code von Shuttercontrol, sondern über redis.
              • simatecS simatec
                @SWeimar
                SWE1008S Offline
                SWE1008S Offline
                SWE1008
                #473
                @simatec
                Kann ich auch aus dem latest repo installieren? Da taucht er schon auf.
                • SWE1008S SWE1008
                  @simatec
                  simatecS Offline
                  simatecS Offline
                  simatec
                  #474
                  @SWeimar ja das geht ... aber vorher alles entfernen
                  Instanz stoppen, deinstallieren und dann in den Adaptern löschen
                  • simatecS simatec
                    SWE1008S Offline
                    SWE1008S Offline
                    SWE1008
                    #475
                    @simatec
                    Ich denke ich habe den Fehler gefunden. Liegt wohl am Javascript Adapter. Über 800 Ereignisse ist nicht normal, oder?
                    • SWE1008S SWE1008
                      @simatec
                      Habe Instanz und Adapter deinstalliert und neu installiert. Wenn nichts konfiguriert ist wird auch das Log im Debug Modus nicht voll gespamt. Sobald ich die Konfiguration abgeschlossen habe und wieder auf Debug stelle wird das Log wieder voll gespammt.
                      #476
                      @SWeimar welcher js-Controller ist im Einsatz?
                      • apollon77A apollon77
                        SWE1008S Offline
                        SWE1008S Offline
                        SWE1008
                        #477
                        @apollon77
                        • flugwelleF Offline
                          flugwelleF Offline
                          flugwelle
                          #478
                          Eine Sache ist mir heute noch aufgefallen:
                          • Jalousie war unten wegen Beschattungsautomatik
                          • meine Frau war der Meinung, dass die Jalousie nicht mehr nötig wäre und hat sie von Hand hochgefahren
                          • einen kurzen Moment später hat die Automatik sie wieder runtergefahren ...
                          Man müsste also den manuellen Eingriff erkennen und die Automatik entsprechend aussetzen. Vielleicht so:
                          • man kann eine Epsilon für den Level angeben (z.B. 10%) in deren Bereich der aktuelle Zustand mit dem durch die Automatik errechneten als gleich angesehen wird (also z.B. wenn die Automatik 1% sagt, dann ist alles von 0 -10% ok)
                          • verlässt der aktuelle Zustand diesen Bereich, geht man von einem manuellen Eingriff aus
                          • dann setzt die Automatik aus - solange bis man wieder in diesem Bereich ist (z.B. weil die Frau die Jalousie doch wieder runtergefahren hat) oder durch die Automatik ein komplett anderer Zustand eingestellt werden soll (z.B. Soll ist 1%, manuell wurde auf 30% gestellt und nun ändern sich die Bedingungen so, dass die Automatik das Rollo ganz hochfahren will - also 100%)
                          simatecS 2 Antworten Letzte Antwort
                          • flugwelleF flugwelle
                            simatecS Offline
                            simatecS Offline
                            simatec
                            #479
                            @flugwelle
                            Da überlege ich mir mal was ... stimmt aber, die Automatik wird spätestens bei Änderung eines Triggers wie Innentemp oder Außentemp oder halt auch die Himmelsrichtung wieder aktiv.
                            Guter Hinweis 👍🏻
                            • SWE1008S SWE1008
                              @simatec
                              simatecS Offline
                              simatecS Offline
                              simatec
                              #480
                              @SWeimar
                              Das scheint mit auch sehr viel zu sein
                              Hat die Installation über die latest Repro etwas geändert?
                              SWE1008S 2 Antworten Letzte Antwort
                              • simatecS simatec
                                @SWeimar
                                SWE1008S Offline
                                SWE1008S Offline
                                SWE1008
                                #481
                                @simatec
                                Nein leider nicht. Ich denke auch das es nichts mit dem shuttercontrol Adapter zu tun hat. Da hab ich irgendwo ein anderen Fehler.
                                  dos1973
                                  #482
                                  hallo zusammen,
                                  Sorry Simatec, ich muss leider nochmals fragen, die Zeiten verwirren mich.
                                  Ich habe in dem Dropdown 3 Möglichkeiten
                                  1. "Nur die Zeit Wohnbereich"
                                  es werden nur die Zeiten gefahren, welche im nächsten Screenshot gezeigt werden, es wird keine Rücksicht auf Astro genommen, richtig?
                                  2. "Zeit Wohnbereich mit Sonnenaufgang und Untergang"
                                  Ich verstehe die Verbindung nicht Zeit mit Sonnenaufgang und Untergang und die daraus resultierenden Uhrzeiten
                                  warum ist Downtime/ Uptime Living jetzt nicht = Sunset / Sunrise?
                                  Warum nimmt er hier 22:00 Uhr und nicht 21:33 Uhr ? beim morgendliche Lauf das gleiche: Sunrise 4:44, es wird aber erst um 6 Uhr hochgefahren.
                                  MIN./ MAX Zeit für das hochfahren in der Woche
                                  die MIN Zeit ist für unter der Woche ist 5:30, der Sonnenaufgang ist 4:44 Uhr, warum also 6:00 Uhr und nicht 5:30 Uhr
                                  die Min/ max Zeiten verstehe ich auch nicht, oder interpretiere diese falsch.
                                  ich nehme an, wenn ich option 1 &2 verstanden habe, kapiere ich auch 3 :-)
                                  • simatecS simatec
                                    @flugwelle
                                    Guter Hinweis 👍🏻
                                    adlerauge1980
                                    #483
                                    @simatec sagte in [Aufruf] Neuer Adapter ioBroker.shuttercontrol:
                                    @flugwelle
                                    Guter Hinweis 👍🏻
                                    @simatec Ich habe heute die 480 Kommentare durchgelesen da ich den Adapter auch installieren möchte. Danke für deine Arbeit! so macht ioBroker richtig Spass!!
                                    Wie wäre es mit einer Funktion "Bei manuellem Eingreifen nichts unternehmen bis: xx"
                                    Bei xx sollte man dann verschiedene Inputs auswählen können wie z.Beispiel:
                                    Sonnenstand, Helligkeit, Temperatur (also Änderung eines Objekt ID Werte die bei xx stehen), aber auch die Option nach Ablauf von manuelle Ereigniszeit plus x Stunden (Sprich die Automatik stopt ab dem Zeitpunkt des manuellen Eingreifens und startet nach Ablauf des Zeit-Triggers wieder.
                                    Ich persönlich würde dort die Option "Runter fahren (Sonnenschutz) am nächsten Tag" eintragen. Also das die Automatik am nächsten Tag wieder normal läuft. Genial wäre natürlich wenn noch bestimmt werden kann, an welchen Rolläden die Automatik aussetzt. Nur an dem bei dem manuell eingegriffen wurde oder bei allen (ggf. bei einer Gruppe von Rolläden)
                                    In meinem Fall werde ich mit dem Adapter ein Sonnenschutz bei Aussentemp. von mehr als 25° einrichten. Welcher die Rolläden nach Ereignis x (habe ich für mich noch nicht definiert, vermutlich Sonnenuntergang -x Stunden) wieder hochfährt.
                                    Dies mal so als Idee.
                                    • simatecS simatec
                                      @SWeimar
                                      SWE1008S Offline
                                      SWE1008S Offline
                                      SWE1008
                                      #484
                                      @simatec
                                      Nachdem ich nun Redis deaktiviert habe ist auch das Log im Debug Modus normal.
                                      • D dos1973
                                        hallo zusammen,
                                        simatecS Offline
                                        simatecS Offline
                                        simatec
                                        #485
                                        @dos1973
                                        Die Zeitberechnung in Verbindung mit Astrozeiten ist wie folgt aufgebaut.
                                        Hochfahren: Es gibt eine Min und eine Max Zeit. Das ist im Prinzip als Range zu sehen.
                                        Liegt der Sonnenaufgang oder GoldenHour Ende in dieser Zeitspanne, wird die Astrozeit verwendet.
                                        Ist diese früher oder später, wird die maximale Zeit der Range verwendet.
                                        Beim Runtenfahren ist es so, dass du mit der zeit die späteste Zeit festlegst.
                                        Ist der Sonnenuntergang oder Goldenhour später als deine eingestellte Zeit, werden die Rollläden zu der eingegebenen Zeit runtergefahren.
                                        Ist der Sonnenuntergang oder Goldenhour eher, wird diese Zeit zum runterfahren verwendet.
                                        • SWE1008S SWE1008
                                          @simatec
                                          simatecS Offline
                                          simatecS Offline
                                          simatec
                                          #486
                                          @SWeimar
                                          Hmm eventuell auch ein Problem mit dem js-controller??
                                          Ich gebe das Thema mal an die Dev's weiter ...
