  4. [Diskussion] js-controller 1.5.8 im Latest Repository
js-controller
76 Beiträge 20 Kommentatoren 13.7k Aufrufe 15 Beobachtet
  • kmxakK Offline
    kmxakK Offline
    kmxak
    ich habe probleme mit meinem slave:
    root@raspberrypi:/opt/iobroker# npm install iobroker.js-controller
    > iobroker.js-controller@1.5.9 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.4.1
    npm version >= 5: disabling package-lock
    > iobroker.js-controller@1.5.9 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.bat'
    Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat'
    fs.js:885
      return binding.mkdir(pathModule._makeLong(path),
    Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../tmp'
        at Object.fs.mkdirSync (fs.js:885:18)
        at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:157:58)
        at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:634:27
        at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:664:15)
        at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3160:5)
        at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:100)
        at Module._compile (module.js:653:30)
        at Object.Module._extensions..js (module.js:664:10)
        at Module.load (module.js:566:32)
        at tryModuleLoad (module.js:506:12)
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! iobroker.js-controller@1.5.9 install: `node iobroker.js setup first`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@1.5.9 install script.
    da ich erst dachte rechte problem habe ich iobroker einfach mal mit 777 überschrieben. selber fehler!
    danach wollte ich den fixer ausprobieren. dieser erkannte die iobroker installation nicht mehr.
    danach habe ich iobroker neu aufgesetzt und direkt danach das js.controller update probiert aber es kommt der selbe fehler.
    Gruß Alex
    • NashraN Offline
      NashraN Offline
      Nashra
      Most Active Forum Testing
      Moin, selbiges Problem hatte ich gestern auch.
      Wollte auf dem Slave den Fix drauf machen und den js-controller updaten.
      Nur Fehlermeldungen, nichts funktionierte. Der Gedanke den Slave neu aufzusetzen
      bringt wohl auch nichts wie ich oben gelesen habe. Problem an der Sache ist auch das
      z.B. der Tankerkönig nicht mehr läuft, der meldete ich soll den js-controller 1.2.0 updaten.
      Also diesen erstmal wieder auf den Master, Problem behoben.
      Aber was kann man jetzt machen?
      Gruß Ralf
      • E e-i-k-e
        @apollon77 said in [Diskussion] js-controller 1.5.8 im Latest Repository:
        @e-i-k-e Also 1.5.7 und 1.5.8 sind da kompatibel. auch in deinem Fall hast DU ja quasi die Slaves vorher aktuell gehabt als den Master. Also auch das ist ok.
        Die Frage ist warum bei Dir Port 9000 belegt war. Das musst Du rausfinden. ggf lief da noch ein prozess oder ein anderes Programm hat den Port blockiert.
        Ich habe das Problem nicht lösen können.
        Zwei mal versucht (mit neuem ioBroker) und zwei mal den selben Fehler.
        Darf ich dich über PN kontaktieren?
        StabilostickS Offline
        Stabilostick
        schrieb am zuletzt editiert von Stabilostick
        @e-i-k-e sagte in [Diskussion] js-controller 1.5.8 im Latest Repository:
        Die Probleme sind behobenen und der Master auf dem Rock64 und die sechs? Slaves auf den Raspberries laufen jetzt mit 1.5.9.
        Ursache waren Rechteprobleme, die auftraten, weil der Installationsuser der Root-User war. ioBroker läuft mit einem eigenen Benutzer, der aus Sicherheitsgründen deutlich weniger Systemrechte hat. Wenn jetzt ein Root-User die Installation anstößt, kann es sein, dass Ordner oder Dateien Besitz/Zugriffsrecht des Root-Useres erhalten bzw. aufgrund früher Installationsversuche bereits erhalten haben. Dann kann der ioBroker mit seinem ioBroker-User nicht mehr auf diese Daten zugreifen und es kommt zu unvorhergesehenen Problemen.
        Nachdem der Anwender seinen Root-Zugang weiter als Standardanmeldung verwenden wollte, konnte das Upgrade (z.b. von 1.4.2 auf 1.5.9) wie folgt beschrieben auf verschiedenen Rechnern wiederholt erfolgreich durchgeführt werden:
        cd /opt/iobroker
        iobroker stop
        curl -sL https://iobroker.net/fix.sh | bash -
        iobroker upgrade self
        iobroker start
        npm war jeweils 6.8 oder 6.9. Node.js kein Ahnung. 😇
        Viel Spaß noch!
        PS: Vielleicht hilft das @Nashra und @kmxak et al auch?
        • apollon77A Offline
          Hi All,
          ab sofort gibt es last but not least noch die 1.5.11, die das Problem mit dem "null/io-package.json nicht gefunden" fixt, was in manchen Fällen aufgetreten ist. Wenn es keine Probleme gibt planen wir die 1.5.11 am Mittwoch ins Stable zu schieben ...
          Ingo
            Und hat schon jemand die 1.5.11 im Einsatz? :-)
            sigi234S K 2 Antworten Letzte Antwort
            • apollon77A apollon77
              sigi234S Online
              sigi234S Online
              @apollon77 sagte in [Diskussion] js-controller 1.5.8 im Latest Repository:
              Ja, keine Probleme bis jetzt..........
              • G Offline
                gfrene
                Auch bei mir er läuft und läuft und läuft.....
                  Kueppert
                  #66
                  @apollon77 Hi, hast nochmal kurz die Info für Multihost? Erst der Master dann der Slave, oder? Hab das im Forum (hier oder im alten?) schon mal gelesen, aber nicht ganz verinnerlicht anscheinent ^^
                  Danke und Grüße, Thorsten
                  • K Kueppert
                    arteckA Offline
                    arteckA Offline
                    arteck
                    #67
                    @Kueppert du stoppst den iobroker ehh.. also ist es egal.. hauptsache beide fahren dann wieder mit der neuen Version hoch
                    K apollon77A 2 Antworten Letzte Antwort
                    • arteckA arteck
                      Kueppert
                      #68
                      @arteck danke dir. Habs gerade mal gemacht. Das einzige, was beim iobroker stop aufgetaucht ist, war
                      root@iobrokerNUC:/opt/iobroker# sudo iobroker stop
                      Stopping iobroker controller daemon...
                      iobroker controller daemon stopped.
                      No "killall.sh" script found. Just stop.
                      Denke aber, das hat nix ausgemacht. Ich teste jetzt mal, ob mir was auffällt ;)
                      Viele Grüße, Thorsten
                      • arteckA arteck
                        #69
                        @arteck Naja, wenn Du slaves updaten willst muss der Master laufen! Also alles runterfahren geht nicht :-)
                        Ja, im Changelog steht das man zuerst den Master und dann die Slaves updaten soll. Das ist primär aus kompatibilitätsgründen weil es Fälle gab wo "neue" Slaves nicht mehr zum Master kamen bevor der auch aktualisiert war.
                        • ? Offline
                          #70
                          hier auf 7 ( 2 in anderen VM's) unterschiedlichen Systemen, Windows, Debian, Mint, Raspian ohne Probleme
                            arteckA Offline
                            arteckA Offline
                            arteck
                            #71
                            @apollon77 doch das geht
                            du kannst alles runnterfahern ..also master und slave und dann die updates durchführen..
                            npm install js-controller@versionsnummer
                            dann alles wieder hoch
                            • arteckA arteck
                              #72
                              @arteck Hihi ... Na klar geht es mit dem Holzhammer immer ... ;-)
                              Der saubere und empfohlene Weg ist aber "iobroker upgrade self" und der tut nur wenn der Master da ist
                                Kueppert
                                #73
                                @apollon77 nungut, dann hab ich mal wieder den Hammer ausgepackt :D ist auch nix kaputt gegangen ^^
                                • eumatsE Offline
                                  eumatsE Offline
                                  eumats
                                  #74
                                  V1.5.11 läuft bei mir auch ohne Probleme...
                                  • IssiI Offline
                                    IssiI Offline
                                    Issi
                                    #75
                                    bei mir läuft die V1.5.11 auch ohne Probleme
                                      #76
                                      Vielen Dank für Eure Unterstützung. die 1.5.11 ist ab sofort "Stable" :-)
                                      Weiter gehts damit ... hier --> https://forum.iobroker.net/topic/22804/diskussion-js-controller-1-5-11-ab-sofort-im-stable-repository
