  3. Entwicklung
  4. Adapter: broadlink2
Adapter: broadlink2
broad2broadlinkrm prorm3 minirm4
1.4k Beiträge 169 Kommentatoren 790.3k Aufrufe 93 Beobachtet
  • sissiwupS Offline
    sissiwupS Offline
    sissiwup
    #464
    Hab uf 2.0.0 upgedatet:
    host.zotac	2019-04-14 22:32:55.479	error	instance system.adapter.broadlink2.0 terminated with code 0 (OK)
    host.zotac	2019-04-14 22:32:55.479	error	Caught by controller[2]: at processImmediate (timers.js:658:5)
    host.zotac	2019-04-14 22:32:55.479	error	Caught by controller[2]: at tryOnImmediate (timers.js:676:5)
    host.zotac	2019-04-14 22:32:55.479	error	Caught by controller[2]: at runCallback (timers.js:706:11)
    host.zotac	2019-04-14 22:32:55.479	error	Caught by controller[2]: at Immediate.N (/opt/iobroker/node_modules/iobroker.broadlink2/node_modules/@frankjoke/myadapter/myAdapter.js:364:102)
    host.zotac	2019-04-14 22:32:55.479	error	Caught by controller[2]: at main (/opt/iobroker/node_modules/iobroker.broadlink2/broadlink2.js:794:18)
    host.zotac	2019-04-14 22:32:55.479	error	Caught by controller[2]: at Array.map (<anonymous>)
    host.zotac	2019-04-14 22:32:55.478	error	Caught by controller[2]: at rename.map.x (/opt/iobroker/node_modules/iobroker.broadlink2/broadlink2.js:794:50)
    host.zotac	2019-04-14 22:32:55.478	error	Caught by controller[2]: 2019-04-14 22:32:55.457 - broadlink2.0 TypeError: Cannot read property 'FORBIDDEN_CHARS' of undefined
    host.zotac	2019-04-14 22:32:55.478	error	Caught by controller[1]: 2019-04-14 22:32:55.457 - broadlink2.0 uncaught exception: Cannot read property 'FORBIDDEN_CHARS' of undefined
    host.zotac	2019-04-14 22:32:55.478	error	Caught by controller[0]: at processImmediate (timers.js:658:5)
    host.zotac	2019-04-14 22:32:55.478	error	Caught by controller[0]: at tryOnImmediate (timers.js:676:5)
    host.zotac	2019-04-14 22:32:55.478	error	Caught by controller[0]: at runCallback (timers.js:706:11)
    host.zotac	2019-04-14 22:32:55.478	error	Caught by controller[0]: at Immediate.N (/opt/iobroker/node_modules/iobroker.broadlink2/node_modules/@frankjoke/myadapter/myAdapter.js:364:102)
    host.zotac	2019-04-14 22:32:55.478	error	Caught by controller[0]: at main (/opt/iobroker/node_modules/iobroker.broadlink2/broadlink2.js:794:18)
    host.zotac	2019-04-14 22:32:55.478	error	Caught by controller[0]: at Array.map (<anonymous>)
    host.zotac	2019-04-14 22:32:55.478	error	Caught by controller[0]: at rename.map.x (/opt/iobroker/node_modules/iobroker.broadlink2/broadlink2.js:794:50)
    host.zotac	2019-04-14 22:32:55.478	error	Caught by controller[0]: TypeError: Cannot read property 'FORBIDDEN_CHARS' of undefined
    broadlink2.0	2019-04-14 22:32:55.459	info	broadlink2 initialization started...
    MfG
    Sissi
    1 CCU3 1 CCU2-Gateway 1 LanGateway 1 Pi-Gateway 1 I7 für ioBroker/MySQL
    sissiwupS 1 Antwort Letzte Antwort
    • sissiwupS sissiwup
      sissiwupS Offline
      sissiwupS Offline
      sissiwup
      #465
      @sissiwup sagte in Adapter: broadlink2:
      In der Datei /opt/iobroker/node_modules/iobroker.broadlink2/broadlink2.js
      habe ich AA.FORBIDDEN_CHARS in A.FORBIDDEN_CHARS geändert.
      Dann startet er zumindest ...
      MfG
      Sissi
      • frankjokeF frankjoke
        @sissiwup
        die identifizierung erfolgt jetzt nur durch mac, diese sollte sich nicht ändern soplange der router und der netzwerkname und passwort gleich bleiben.
        Der name ändert sich meistens nur bei denen die vorher nicht die netzwerkendung eingetragen hatten (also das .local oder .fritz.box herausgelöscht haben) da dies jetzt automatisch erfolgt.
        Der Adapter versucht mit dem Hostnamen zu arbeite der vom Gerät als default generiert wird und hängt nur das RM: oder SP: vorne an.
        Der jetzige Adapter bräuchte das RM: ... nicht mehr deshalb kann man auch auf komplett andere Namen umbenennen (sie dürfen halt nur einmal vorkommen).
        sissiwupS Offline
        sissiwupS Offline
        sissiwup
        #466
        @frankjoke sagte in Adapter: broadlink2:
        @sissiwup
        Hm, bei mir ist der Name komplett anders:
        Neu:
        RM:0x2797_34:ea:34:89:1b:e8
        Alt:
        RM:192-168-1-163
        Habe in der Fritzbox nur eingestellt, das er die IP behalten soll.
        MfG
        Sissi
        frankjokeF 1 Antwort Letzte Antwort
          @sissiwup
          Neu:
          Alt:
          RM:192-168-1-163
          frankjokeF Offline
          frankjokeF Offline
          frankjoke
          #467
          @sissiwup
          ja genau, alte war ip adresse und neue ist id+mac (was das gerät liefert).
          übrigens , auf git (nicht mit beliebig) sollte schon 2.0.1 sein...sollte das Problem beheben das du vorher hattest.
          Frank,
          NUC's, VM's und Raspi's unter Raspian, Ubuntu und Debian zum Testen.
          Adapter die ich selbst beigesteuert habe: BMW, broadlink2, radar2, systeminfo, km200, xs1 und einige im Anmarsch!
          • padrinoP Offline
            padrinoP Offline
            padrino
            #468
            mal eine Frage, muss der RM pro im selben WLAN sein, wie iobroker?
            Eine externe Anbindung ist nicht möglich? =)
            CU,
            padrino
            • padrinoP padrino
              CU,
              padrino
              frankjokeF Offline
              frankjokeF Offline
              frankjoke
              #469
              @padrino
              Ja, das Gerät muss auf dem gleichen Netzwerk sein wie die ioBroker/Adapterinstanz,
              Nein, das können auch verschiedene Netzwerke sein, aber dann muss der Adapter auf beide Zugriff haben!
              Ich habe z.B. bei meinem ioBroker eine Lan-Schnittstelle die im normalen Netz hängt wo auch die anderen Rechner hängen und getrennt eine W-Lan-Schnittstelle welche im selben W-Lan wie meine broadlink-Geräte hängen (diese sind auf einem W-Lan das nicht ins Internet zugreifen kann damit die China-Server meine Geräte in Ruhe lassen und umgekehrt).
              Damit kann der Adapter jedoch auf beide zugreifen und funktioniert.
              p.s. Die Geräte funktionieren auch über das Internet und die China-Server, aber dann muss man die Befehle so wie bei der Handyapp und die cloud absetzten was ich nicht will (und nicht kann da ich kein OEM bin der einen Zugriff bekommt)..
              Frank,
              • padrinoP Offline
                padrinoP Offline
                padrino
                #470
                Hmm, ok schade, dann wird das mit meinem Plan eines BL (unter Alexa) im Auto doch wohl leider nix. =)
                • padrinoP padrino
                  frankjokeF Offline
                  frankjokeF Offline
                  frankjoke
                  #471
                  @padrino
                  Auf so eine Idee wäre ich noch nicht gekommen, weiß zwar nicht was du mit einem BL im Auto willst aber mit einem Raspi auf dem iobroker und ein Router rennt kannst es hinkriegen :)
                  Frank,
                  • padrinoP Offline
                    padrinoP Offline
                    padrino
                    #472
                    Hmm, ok, das ist wohl etwas overkill. 🤣
                    Hab noch ein altes Autoradio mit IR FB, da hätte ich es witzig gefunden, wenn ich das über Alexa hätte steuern können. 😳
                    Aber, wenn das so kompliziert ist... 😇
                    Mal noch eine Frage,
                    Würde gerne ein Gerät
                    • einschalten mit Befehl1, Pause, Befehl2
                      und
                    • ausschalten mit Befehl3
                    Das bekommt man mit States nicht hin, aber wohl auch nicht mit Scenes, oder?
                    Müsste ich mir das per JS stricken, oder? 🤔
                    • padrinoP padrino
                        und
                      frankjokeF Offline
                      frankjokeF Offline
                      frankjoke
                      #473
                      @padrino
                      Es sollte schon gehen (hab's aber nicht getestet), ein State kann ja auch eine Scene enthalten, also eine Szene für's einschalten und einen State zum Umschalten.
                      Frank,
                      • padrinoP Offline
                        padrinoP Offline
                        padrino
                        #474
                        Ah, ok.
                        Scheint bei mir aber leider nicht zu klappen, im log steht
                        sendState could not find command or scene named 'TestSzene'
                        aber die Szene gibt es eigentlich
                        • padrinoP padrino
                          Ah, ok.
                          frankjokeF Offline
                          frankjokeF Offline
                          frankjoke
                          #475
                          @padrino
                          hmm, muss mir das später in der Woche mal ansehen, befürchte einen bug nachdem ich bei einem kurzen Test die selbe Meldung bekam..
                          Frank,
                            MyMeyer
                            #476
                            seit dem Update meiner Fritzboxen auf 7.11 wird der Broadlink2.0 Adapter Version 2.01 mit einem Zusatz am Namen (Mac-Adresse) erkannt und somit gehen meine Logiken nicht mehr.
                            Hat einer dafür eine Lösung da ich nicht alle Gerät neu anlernen möchte.
                            Der BroadLink ist in meiner FritzBox mit einer festen IP und einen festen Namen eingetragen.
                            Hier der Auszug aus dem Log:
                            broadlink2.0 2019-06-02 11:50:27.162 info 1 were not found: RM:Broadlink-RMPROPLUS
                            broadlink2.0 2019-06-02 11:50:27.162 info broadlink2.0 started and found 1 devices named 'RM:Broadlink-RMPROPLUS-c5-16-2a'.
                            broadlink2.0 2019-06-02 11:50:21.541 warn device RM:Broadlink-RMPROPLUS not found, please rescan later again or delete it! It was: 192.168.1.40,IPv4,80,128,10026,rm,RM:Broadlink-RMPROPLUS,RM2 Pro Plus,2a:27:28:1:a8:c0
                            broadlink2.0 2019-06-02 11:50:13.932 info Device RM:Broadlink-RMPROPLUS-c5-16-2a dedected: address=192.168.1.40, mac=xx:xx:xx:c5:16:2a, typ=rmp, id=0x272a devtype=RM2 Pro Plus
                            broadlink2.0 2019-06-02 11:50:13.823 info Discover Broadlink devices for 10sec on broadlink2.0
                            broadlink2.0 2019-06-02 11:50:13.823 info UDP socket listening on 0.0.0.0:15001
                            broadlink2.0 2019-06-02 11:50:13.807 info Devices to rename:
                            broadlink2.0 2019-06-02 11:50:13.807 info Devices to add:
                            broadlink2.0 2019-06-02 11:50:13.807 info broadlink2 starting main...
                            broadlink2.0 2019-06-02 11:50:13.807 info broadlink2 initialization started...
                            broadlink2.0 2019-06-02 11:50:13.511 info starting. Version 2.0.1 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v8.16.0
                            MyMeyer
                            Hardware: Intel I5 mit ****Debian ProxMox OS: Debian **** <<< >>> Network with UniFi <<<
                            HomeMatic CCU-2 (Wired und Funk) / Philips HUE / Echo.DOT / Echo.SHOW / Xiaomi Smart-Home / Xiaomi Robot Vacuum Cleaner / Synology DS 918+ / Shelly 1&2 <<<
                            crunchipC frankjokeF 2 Antworten Letzte Antwort
                            • M MyMeyer
                              crunchipC Abwesend
                              crunchipC Abwesend
                              #477
                              @MyMeyer ist weiter oben beschrieben, export als json, mit z.b. Notepad editieren, json wieder hochladen und in den Adaptereinstellungen eingeben...neues broadlink= alter broadlink
                              so habe ich es auch erst die Tage gemacht, habe ebenfalls Fritzbox mit aktueller Firmware
                                MyMeyer
                                #478
                                @crunchip sagte in Adapter: broadlink2:
                                Nach dem Unbenennen bekomme ich jetzt diese Meldung im Log:
                                broadlink2.0 2019-06-03 19:48:52.224 warn Error in StateChange for broadlink2.0.RM:Broadlink-RMPROPLUS-c5-16-2a.LearnRF = 'cannot get code to send for: RM:Broadlink-RMPROPLUS-c5-16-2a.LearnRF=RM:Broadlink-RMPROPLUS-c5-16-2a { val: true,ack: f
                                broadlink2.0 2019-06-03 19:48:52.223 warn cannot get code to send for: RM:Broadlink-RMPROPLUS-c5-16-2a.LearnRF=RM:Broadlink-RMPROPLUS-c5-16-2a { val: true,ack: false,ts: 1559584132219,q: 0,from: 'system.adapter.admin.0',user: 'system.user.adm
                                broa
                                MyMeyer
                                • M MyMeyer
                                  broa
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  #479
                                  @MyMeyer hast du alles aus deinem skript von RM:Broadlink-RMPROPLUS in RM:Broadlink-RMPROPLUS-c5-16-2a geändert?
                                  und in Einstellungen
                                  RM:Broadlink-RMPROPLUS-c5-16-2a=RM:Broadlink-RMPROPLUS
                                  und wieder richtig hochgeladen?
                                    MyMeyer
                                    schrieb am zuletzt editiert von MyMeyer
                                    #480
                                    @crunchip Ja alles ab den zweiten Verzeichnis Baum . (export->unbenannt->import)
                                    Moment , aber unter Einstellungen nicht. Also direkt unter Instanzen ?
                                    MyMeyer
                                    • M MyMeyer
                                      crunchipC Abwesend
                                      crunchipC Abwesend
                                      #481
                                      @MyMeyer so wie auf meinem Bild und dein Broadlink müsste ja seinen alten Namen behalten
                                        MyMeyer
                                        #482
                                        @crunchip Hi habe ich jetzt so gemacht und die Signale werden wieder versendet.
                                        Die Meldung aus LOG kommt nur wenn ich den "Learn" oder "LearnRF" Button drücke.
                                        MyMeyer
                                        • M MyMeyer
                                          frankjokeF Offline
                                          frankjokeF Offline
                                          frankjoke
                                          schrieb am zuletzt editiert von frankjoke
                                          #483
                                          @MyMeyer
                                          Du kannst die Geräte im neuen Adapter mittels konfig umbenennen!
                                          neuername1=altername1,neuername2=altername2,...
                                          Hast das schon probiert?
                                          Genau für diese Fälle hab ich die Funktion eingebaut!
                                          Frank,
