  4. Reload Button auf der VIS
20 Beiträge 12 Kommentatoren 6.8k Aufrufe 8 Beobachtet
  • smartboartS Offline
    smartboartS Offline
    smartboart
    kannst dir doch nen button machen... im prinzip brauchst nur ein kleines Script mit state.. und dann beschreibst du die States...Leider ist men Kioskmode ( auf multihost slave ) in den entsprechenden States undefined... Ist das bei dir auch so...
    • C csamaggi
      @peoples Das funktioniert doch ich hätte das halt gerne als Button und nicht als frei Text.
      MFG Maggi
      NegaleinN Offline
      NegaleinN Offline
      Negalein
      @csamaggi sagte in Reload Button auf der VIS:
      Hier mein Widget für den Refresh
      [{"tpl":"tplJquiButtonLink","data":{"g_fixed":true,"g_visibility":true,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","buttontext":"Refresh","padding":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"href":"javascript:window.location.reload(true);","no_style":false,"name":"Refresh Button"},"style":{"left":"1193px","top":"6px","width":"95px","height":"35px","z-index":"1","transform":""},"widgetSet":"jqui"}]
      ° Fixer ---> iob fix
        smartboartS Offline
        smartboart
        schrieb am zuletzt editiert von smartboart
        hier das Skript für dein Button...
        createState('javascript.0.Tabled.Vis.reload', {def: 'false', type: 'boolean', name: 'Projekt reload'});
        var logging = true;
        const id1 = 'javascript.0.Tabled.Vis.reload';//state zum aktivieren des reload
        const id2 = 'vis.0.control.instance/*Control vis*/';
        const id3 =  'vis.0.control.command'/*Command for vis*/;
        function reload() {
        if (logging) log ('reload durch vis aktiviert');
        setStateDelayed(id1,false,2*1000);
        setState(id2,'instanzname');
        setStateDelayed(id3,'reload',1*1000);
        on({id:'id1', change:'ne',val:true}, function(dp) {
           reload();
        • NegaleinN Negalein
          smartboartS Offline
          smartboartS Offline
          smartboart
          @Negalein oh, da warst schneller als ich....hab das eben kurz zusammengeschustert
          Damit ist das natürlich super umgesetzt...damit ist mein Skript hinfällig....
          • crunchipC Abwesend
            crunchipC Abwesend
            Is schon ne klasse Sache, wenn der Fragesteller nach Einem Jahr die Antwort bekommt 😂😂😂
            Oder Stimmt hier etwas im Forum nicht?
            • smartboartS smartboart
              crunchipC Abwesend
              crunchipC Abwesend
              @smartboart sagte in Reload Button auf der VIS:
              Schneller
              😂😂😂😂 2018/2019
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                @crunchip sagte in Reload Button auf der VIS:
                Nö du, im Forum passt alles.
                Ich gebs zu, dass ich nicht aus Datum geschaut habe.
                Aber ist auch nicht schlimm.
                1. stand noch keine Lösung da
                2. kann es auch nach 1 Jahr noch wer gebrauchen
                Also, was ist besser?
                Nach einem Jahr helfen, oder nach einem Jahr sich über die Helfenden lustig zu machen?
                L crunchipC W 3 Antworten Letzte Antwort
                  lindi200000
                  @Negalein Danke :) Ich hab gerade dafür nach einer Lösung gesucht :)
                    crunchipC Abwesend
                    crunchipC Abwesend
                    @Negalein war nicht böse gemeint, eher witzig, da es so schön passend war....mit "schneller"
                    sorry, falls es falsch rüber kam.
                    lustig machen, sieht für mich anders aus und käme mir auch nicht in den Sinn.
                    Bin selber froh und dankbar für jede Hilfe hier im Forum, sei es gleich oder auch erst nach einem längerem Zeitraum.
                    Ausserdem, hatte ich dazu gefügt, ob was im Forum nicht stimmt...da ich dachte, wegen dem Datum, das da vllt. was falsch angezeigt wird.
                      NegaleinN Offline
                      NegaleinN Offline
                      Negalein
                      Dann hab ich es falsch verstanden! ;)
                      sissiwupS 1 Antwort Letzte Antwort
                        sissiwupS Offline
                        sissiwupS Offline
                        sissiwup
                        @Negalein
                        Danke, genau das hat mir grade gefehlt. VIS spinnt aktuell ab und an und zeigt alte Werte.
                        MfG
                        Sissi
                        1 CCU3 1 CCU2-Gateway 1 LanGateway 1 Pi-Gateway 1 I7 für ioBroker/MySQL
                          W Offline
                          W Offline
                          Werner53844
                          @Negalein Auch wenn das Thema nun schin 2 1/2 Jahre hier steht: Mir hat die Antwort heute weiter geholfen
                          jmeister79J 1 Antwort Letzte Antwort
                          • W Werner53844
                            jmeister79J Offline
                            jmeister79J Offline
                            jmeister79
                            @werner53844 und mir jetzt gerade ;-)
                              MacQuire
                              Und mir hat der Thread 5 Jahre nach Erstellung heute ebenfalls geholfen ;-)
                                Muhagl
                                @Negalein Mir auch! 😊
