  4. Reload Button auf der VIS
20 Beiträge 12 Kommentatoren 6.8k Aufrufe 8 Beobachtet
  • C Offline
    csamaggi
    @peoples Das funktioniert doch ich hätte das halt gerne als Button und nicht als frei Text.
    MFG Maggi
    • smartboartS Offline
      smartboartS Offline
      smartboart
      kannst dir doch nen button machen... im prinzip brauchst nur ein kleines Script mit state.. und dann beschreibst du die States...Leider ist men Kioskmode ( auf multihost slave ) in den entsprechenden States undefined... Ist das bei dir auch so...
      • C csamaggi
        MFG Maggi
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        @csamaggi sagte in Reload Button auf der VIS:
        Hier mein Widget für den Refresh
        [{"tpl":"tplJquiButtonLink","data":{"g_fixed":true,"g_visibility":true,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","buttontext":"Refresh","padding":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"href":"javascript:window.location.reload(true);","no_style":false,"name":"Refresh Button"},"style":{"left":"1193px","top":"6px","width":"95px","height":"35px","z-index":"1","transform":""},"widgetSet":"jqui"}]
        ° Fixer ---> iob fix
          smartboartS Offline
          smartboart
          schrieb am zuletzt editiert von smartboart
          hier das Skript für dein Button...
          createState('javascript.0.Tabled.Vis.reload', {def: 'false', type: 'boolean', name: 'Projekt reload'});
          var logging = true;
          const id1 = 'javascript.0.Tabled.Vis.reload';//state zum aktivieren des reload
          const id2 = 'vis.0.control.instance/*Control vis*/';
          const id3 =  'vis.0.control.command'/*Command for vis*/;
          function reload() {
          if (logging) log ('reload durch vis aktiviert');
          setStateDelayed(id1,false,2*1000);
          setState(id2,'instanzname');
          setStateDelayed(id3,'reload',1*1000);
          on({id:'id1', change:'ne',val:true}, function(dp) {
             reload();
          • NegaleinN Negalein
            smartboartS Offline
            smartboartS Offline
            smartboart
            @Negalein oh, da warst schneller als ich....hab das eben kurz zusammengeschustert
            Damit ist das natürlich super umgesetzt...damit ist mein Skript hinfällig....
            • crunchipC Abwesend
              crunchipC Abwesend
              Is schon ne klasse Sache, wenn der Fragesteller nach Einem Jahr die Antwort bekommt 😂😂😂
              Oder Stimmt hier etwas im Forum nicht?
              • smartboartS smartboart
                crunchipC Abwesend
                crunchipC Abwesend
                @smartboart sagte in Reload Button auf der VIS:
                Schneller
                😂😂😂😂 2018/2019
                  NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  @crunchip sagte in Reload Button auf der VIS:
                  Nö du, im Forum passt alles.
                  Ich gebs zu, dass ich nicht aus Datum geschaut habe.
                  Aber ist auch nicht schlimm.
                  1. stand noch keine Lösung da
                  2. kann es auch nach 1 Jahr noch wer gebrauchen
                  Also, was ist besser?
                  Nach einem Jahr helfen, oder nach einem Jahr sich über die Helfenden lustig zu machen?
                  L crunchipC W 3 Antworten Letzte Antwort
                    lindi200000
                    @Negalein Danke :) Ich hab gerade dafür nach einer Lösung gesucht :)
                      crunchipC Abwesend
                      crunchipC Abwesend
                      @Negalein war nicht böse gemeint, eher witzig, da es so schön passend war....mit "schneller"
                      sorry, falls es falsch rüber kam.
                      lustig machen, sieht für mich anders aus und käme mir auch nicht in den Sinn.
                      Bin selber froh und dankbar für jede Hilfe hier im Forum, sei es gleich oder auch erst nach einem längerem Zeitraum.
                      Ausserdem, hatte ich dazu gefügt, ob was im Forum nicht stimmt...da ich dachte, wegen dem Datum, das da vllt. was falsch angezeigt wird.
                        NegaleinN Offline
                        NegaleinN Offline
                        Negalein
                        Dann hab ich es falsch verstanden! ;)
                        sissiwupS 1 Antwort Letzte Antwort
                          sissiwupS Offline
                          sissiwupS Offline
                          sissiwup
                          @Negalein
                          Danke, genau das hat mir grade gefehlt. VIS spinnt aktuell ab und an und zeigt alte Werte.
                          MfG
                          Sissi
                          1 CCU3 1 CCU2-Gateway 1 LanGateway 1 Pi-Gateway 1 I7 für ioBroker/MySQL
                            W Offline
                            W Offline
                            Werner53844
                            @Negalein Auch wenn das Thema nun schin 2 1/2 Jahre hier steht: Mir hat die Antwort heute weiter geholfen
                            jmeister79J 1 Antwort Letzte Antwort
                            • W Werner53844
                              jmeister79J Offline
                              jmeister79J Offline
                              jmeister79
                              @werner53844 und mir jetzt gerade ;-)
                                MacQuire
                                Und mir hat der Thread 5 Jahre nach Erstellung heute ebenfalls geholfen ;-)
                                  Muhagl
                                  @Negalein Mir auch! 😊
