  4. [Aufruf] ZigBee CC253x Adapter Version 0.10.x
zigbee0.10.xadapter
373 Beiträge 27 Kommentatoren 87.5k Aufrufe 23 Beobachtet
  • MyzerATM MyzerAT
    @Asgothian sagte in [Aufruf] ZigBee CC253x Adapter Version 0.10.x:
    //github.com/asgothian/ioBroker.zigbee/tarball/Admin_Changes
    ich bekomme dies wenn ich deinen link ausführe
    admin.0	2019-03-24 20:55:38.201	info	successful connection to socket.io from ::ffff:192.168.0.2
    host.RDJL_Home	2019-03-24 20:55:27.101	info	Update repository "default" under "http://download.iobroker.net/sources-dist.json"
    iobroker	2019-03-24 20:55:26.987	info	exit 0
    iobroker	2019-03-24 20:55:26.902	info	npm ERR! /root/.npm/_logs/2019-03-24T19_55_26_881Z-debug.log
    iobroker	2019-03-24 20:55:26.902	info	npm ERR! A complete log of this run can be found in:
    iobroker	2019-03-24 20:55:26.879	info	ERR! code ENOLOCALnpm ERR! Could not install from "../github.com/asgothian/ioBroker.zigbee/tarball/Admin_Changes" as it does not contain a package.json file.
    iobroker	2019-03-24 20:55:26.876	info	npm
    iobroker	2019-03-24 20:55:18.549	info	npm install //github.com/asgothian/ioBroker.zigbee/tarball/Admin_Changes --production --save --prefix "/opt/iobroker" (System call)
    iobroker	2019-03-24 20:55:17.975	info	install //github.com/asgothian/ioBroker.zigbee/tarball/Admin_Changes
    iobroker	2019-03-24 20:55:17.472	info	url "//github.com/asgothian/ioBroker.zigbee/tarball/Admin_Changes"
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    #107
    @MyzerAT
    Hmm.. gerade geschaut.. bei mir gehts.
    • MyzerATM Offline
      MyzerATM Offline
      MyzerAT
      #108
      https://github.com/asgothian/ioBroker.zigbee/tarball/Admin_Changes
      was meint er damit ?
      iobroker	2019-03-24 21:48:16.058	info	bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
      iobroker	2019-03-24 21:48:16.057	info	WARN
      iobroker	2019-03-24 21:48:16.057	info	npm
      lg Rudi
      Node 22.23.0
      Nodejs 22.23.0
      npm 10.9.8
      js-controller 7.2.2
      • MyzerATM MyzerAT
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        #109
        @MyzerAT Da wird ueber eine nicht erfüllte abhängigkeit berichtet. Ist aber kein Problem.
        A.
        • MyzerATM Offline
          MyzerATM Offline
          MyzerAT
          #110
          @Asgothian
          ist es das ?
          zigbee.0	2019-03-24 22:06:28.438	info	Attempting to configure device 0x00158d000192d13d
          zigbee.0	2019-03-24 22:06:03.797	info	Attempting to configure device 0x00158d000192d13d
          zigbee.0	2019-03-24 22:05:54.685	info	Configure on Message active for 300 sekunden
          lg Rudi
          Node 22.23.0
          Nodejs 22.23.0
          npm 10.9.8
          js-controller 7.2.2
          • MyzerATM MyzerAT
            @Asgothian
            ist es das ?
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            #111
            @MyzerAT ist was das ?
            • MyzerATM Offline
              MyzerATM Offline
              MyzerAT
              #112
              deine änderung , diese log kenne ich nicht von den Eurotronic Thermostaten
              lg Rudi
              Node 22.23.0
              Nodejs 22.23.0
              npm 10.9.8
              js-controller 7.2.2
              • MyzerATM MyzerAT
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                #113
                @MyzerAT Das ist teil der Änderung.Allerdings sollten nicht so viele Nachrichten kommen
                • MyzerATM Offline
                  MyzerATM Offline
                  MyzerAT
                  #114
                  nicht viele ist ein wenig untertrieben ^^
                  zigbee.1	2019-03-24 22:42:47.831	info	new dev 0x00158d000201a358 38941 lumi.sensor_switch
                  info.0	2019-03-24 22:42:26.308	info	Popup-News readed...
                  zigbee.1	2019-03-24 22:41:17.032	info	Zigbee: allowing new devices to join.
                  admin.0	2019-03-24 22:41:15.092	info	successful connection to socket.io from ::ffff:192.168.0.2
                  zigbee.0	2019-03-24 22:39:47.271	info	Zigbee: allowing new devices to join.
                  sonoff.0	2019-03-24 22:37:28.731	info	Client [DVES_3E4B4242] connected with secret 1553463448730_4384
                  sonoff.0	2019-03-24 22:37:28.219	info	Client [DVES_3E4B4242] connection closed: closed
                  javascript.0	2019-03-24 22:37:20.996	info	script.js.common.Heizung.Zigbee_Badezimmer_Heizung: **** Fenster Badezimmer geschlossen
                  javascript.0	2019-03-24 22:37:20.995	info	script.js.common.Klima.Aussen_5_Grad_unter_Innentemperatur: ********* stop intervall
                  sonoff.0	2019-03-24 22:35:15.514	info	Client [DVES_3E4B4242] connected with secret 1553463315514_4830
                  sonoff.0	2019-03-24 22:35:14.598	info	Client [DVES_3E4B4242] connection closed: closed
                  zigbee.0	2019-03-24 22:34:59.674	info	configure on Message closed
                  zigbee.0	2019-03-24 22:34:42.611	info	Attempting to configure device 0x00158d0001922cdf
                  zigbee.0	2019-03-24 22:34:40.392	info	Attempting to configure device 0x00158d0001922dcd
                  zigbee.0	2019-03-24 22:34:40.372	info	Attempting to configure device 0x00158d000192d1ae
                  zigbee.0	2019-03-24 22:34:28.583	info	Zigbee: allowing new devices to join.
                  zigbee.0	2019-03-24 22:34:21.836	info	Attempting to configure device 0x00158d0001922cdf
                  zigbee.0	2019-03-24 22:34:20.023	info	new dev 0x0017880104101f75 63604 LWB010
                  zigbee.0	2019-03-24 22:34:19.702	info	Attempting to configure device 0x00158d0001922dcd
                  zigbee.0	2019-03-24 22:34:19.688	info	Attempting to configure device 0x00158d000192d1ae
                  zigbee.0	2019-03-24 22:34:12.491	info	new dev 0x000d6ffffebb1e78 49023 TRADFRI signal repeater
                  zigbee.0	2019-03-24 22:33:59.449	info	Attempting to configure device 0x00158d0001922cdf
                  zigbee.0	2019-03-24 22:33:58.961	info	Attempting to configure device 0x00158d000192d1ae
                  zigbee.0	2019-03-24 22:33:58.911	info	Attempting to configure device 0x00158d0001922dcd
                  zigbee.0	2019-03-24 22:33:39.872	info	new dev 0x000d6ffffe9f8c0d 48832 TRADFRI signal repeater
                  zigbee.0	2019-03-24 22:33:38.664	info	Attempting to configure device 0x00158d0001922cdf
                  zigbee.0	2019-03-24 22:33:38.253	info	Attempting to configure device 0x00158d000192d1ae
                  zigbee.0	2019-03-24 22:33:38.159	info	Attempting to configure device 0x00158d0001922dcd
                  zigbee.0	2019-03-24 22:33:17.942	info	Attempting to configure device 0x00158d0001922cdf
                  zigbee.0	2019-03-24 22:33:17.617	info	Attempting to configure device 0x00158d000192d1ae
                  zigbee.0	2019-03-24 22:33:17.471	info	Attempting to configure device 0x00158d0001922dcd
                  zigbee.0	2019-03-24 22:33:12.878	info	Successfully configured 0x00158d000192d13d SPZB0001
                  zigbee.0	2019-03-24 22:33:10.026	error	Zigbee publish to '0x00158d000192d13d', hvacThermostat - write - [{"attrId":16387,"dataType":41,"attrData":1800}] - 1 failed with error Error: AF data request fails, status code: 205. No network rout
                  zigbee.0	2019-03-24 22:33:09.123	info	Attempting to configure device 0x00158d000192d13d
                  zigbee.0	2019-03-24 22:33:06.973	info	new dev 0x000d6ffffe9f907c 33053 TRADFRI signal repeater
                  zigbee.0	2019-03-24 22:32:57.099	info	Attempting to configure device 0x00158d0001922cdf
                  zigbee.0	2019-03-24 22:32:56.849	info	Attempting to configure device 0x00158d000192d1ae
                  zigbee.0	2019-03-24 22:32:56.703	info	Attempting to configure device 0x00158d0001922dcd
                  zigbee.0	2019-03-24 22:32:48.425	info	Attempting to configure device 0x00158d000192d13d
                  zigbee.0	2019-03-24 22:32:36.336	info	Attempting to configure device 0x00158d0001922cdf
                  zigbee.0	2019-03-24 22:32:36.158	info	Attempting to configure device 0x00158d000192d1ae
                  zigbee.0	2019-03-24 22:32:36.042	info	Attempting to configure device 0x00158d0001922dcd
                  zigbee.0	2019-03-24 22:32:35.113	info	new dev 0x000d6ffffe9cc0e8 16053 TRADFRI signal repeater
                  zigbee.0	2019-03-24 22:32:27.711	info	Attempting to configure device 0x00158d000192d13d
                  zigbee.0	2019-03-24 22:32:15.519	info	Attempting to configure device 0x00158d0001922cdf
                  zigbee.0	2019-03-24 22:32:15.425	info	Attempting to configure device 0x00158d000192d1ae
                  zigbee.0	2019-03-24 22:32:15.233	info	Attempting to configure device 0x00158d0001922dcd
                  zigbee.0	2019-03-24 22:32:07.016	info	Attempting to configure device 0x00158d000192d13d
                  zigbee.0	2019-03-24 22:32:02.751	info	new dev 0xd0cf5efffeea2f74 33127 TRADFRI signal repeater
                  zigbee.0	2019-03-24 22:31:54.771	info	Attempting to configure device 0x00158d0001922cdf
                  zigbee.0	2019-03-24 22:31:54.734	info	Attempting to configure device 0x00158d000192d1ae
                  zigbee.0	2019-03-24 22:31:54.476	info	Attempting to configure device 0x00158d0001922dcd
                  zigbee.0	2019-03-24 22:31:46.308	info	Attempting to configure device 0x00158d000192d13d
                  zigbee.0	2019-03-24 22:31:34.033	info	Attempting to configure device 0x00158d000192d1ae
                  zigbee.0	2019-03-24 22:31:33.954	info	Attempting to configure device 0x00158d0001922cdf
                  zigbee.0	2019-03-24 22:31:33.724	info	Attempting to configure device 0x00158d0001922dcd
                  zigbee.0	2019-03-24 22:31:31.271	info	new dev 0x000d6ffffe9c27d9 46341 TRADFRI signal repeater
                  zigbee.0	2019-03-24 22:31:25.626	info	Attempting to configure device 0x00158d000192d13d
                  zigbee.0	2019-03-24 22:31:13.347	info	Attempting to configure device 0x00158d000192d1ae
                  zigbee.0	2019-03-24 22:31:13.240	info	Attempting to configure device 0x00158d0001922cdf
                  zigbee.0	2019-03-24 22:31:12.976	info	Attempting to configure device 0x00158d0001922dcd
                  zigbee.0	2019-03-24 22:31:04.926	info	Attempting to configure device 0x00158d000192d13d
                  zigbee.0	2019-03-24 22:30:52.642	info	Attempting to configure device 0x00158d000192d1ae
                  zigbee.0	2019-03-24 22:30:52.377	info	Attempting to configure device 0x00158d0001922cdf
                  zigbee.0	2019-03-24 22:30:52.209	info	Attempting to configure device 0x00158d0001922dcd
                  zigbee.0	2019-03-24 22:30:44.206	info	Attempting to configure device 0x00158d000192d13d
                  zigbee.0	2019-03-24 22:30:19.556	info	Attempting to configure device 0x00158d000192d13d
                  lg Rudi
                  Node 22.23.0
                  Nodejs 22.23.0
                  npm 10.9.8
                  js-controller 7.2.2
                  • MyzerATM MyzerAT
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    #115
                    @MyzerAT
                    In der Objektansicht - hat der Thermostat nen orangen oder blauen tag ?
                    A
                    • MyzerATM Offline
                      MyzerATM Offline
                      MyzerAT
                      #116
                      gar keinen
                      lg Rudi
                      Node 22.23.0
                      Nodejs 22.23.0
                      npm 10.9.8
                      js-controller 7.2.2
                      • MyzerATM MyzerAT
                        gar keinen
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        #117
                        @MyzerAT dann hast du keinen Upload gemacht
                        A
                        • MyzerATM Offline
                          MyzerATM Offline
                          MyzerAT
                          #118
                          wusste ich nicht das ich den auch machen muss, aber jetzt
                          ist das statt der FM die früher immer kam?
                          lg Rudi
                          Node 22.23.0
                          Nodejs 22.23.0
                          npm 10.9.8
                          js-controller 7.2.2
                          • AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            #119
                            ja.. die andere Meldung kommt auch noch weg.
                            A.
                            • MyzerATM Offline
                              MyzerATM Offline
                              MyzerAT
                              #120
                              also nach ein paar mal drauf drücken auf das orange Symbol , sind nun alle Thermostate "Successfully configured " SUPER, thx @Asgothian
                              lg Rudi
                              Node 22.23.0
                              Nodejs 22.23.0
                              npm 10.9.8
                              js-controller 7.2.2
                              • MyzerATM MyzerAT
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                #121
                                @MyzerAT
                                Der Trick sollte sein:
                                1mal drücken, an jedem Thermostat z.bsp. Die solltemperatur verstellen, dann ist es sauber configured.
                                • MyzerATM Offline
                                  MyzerATM Offline
                                  MyzerAT
                                  #122
                                  ich werde es beobachten, eine Verbesserung ist es jedenfalls! thx für deine Tolle Arbeit!!!
                                  lg Rudi
                                  Node 22.23.0
                                  Nodejs 22.23.0
                                  npm 10.9.8
                                  js-controller 7.2.2
                                  • AsgothianA Asgothian
                                    Hallo Zusammen,
                                    ich habe mich mal dem Konfigurieren der Geräte nach start des Adapters gewidmet. Dabei ist die folgende Version heraus gekommen.
                                    Installation von hier:
                                    Was hat sich getan:
                                    • Die Warnungen über nicht konfigurierte Geräte sind weg. Ob ein Gerät erfolgreich konfiguriert wurde kann nun in der Devices Ansicht des Adapters gesehen werden:
                                      noch nicht konfiguriertes Gerät
                                      Konfiguriertes Gerät
                                    Wichtig ist dabei das auch nicht konfigurierte Geräte üblicherweise normal funktionieren - sofern sie bereits einmal erfolgreich konfiguriert wurden nachdem sie gepaired wurden. Auch müssen bei weitem nicht alle Geräte konfiguriert werden.
                                    Geräte verlieren ihre Konfiguration wenn sie längerfristig stromlos sind. Wie lange das dauert ist von Gerät zu Gerät unterschiedlich.
                                    • Man kann den Adapter in einen Modus schalten, bei dem bei jeder empfangenen Meldung versucht wird (falls notwendig) das dazugehörige Gerät zu konfigurieren. Das geschieht dadurch das man auf den orangenen Knopf drückt. Damit kann man z.Bsp. Fernbedienungen konfigurieren, in dem man den Modus aktiviert und dann Knöpfe auf der Fernbedienung drückt.
                                    • Der Koordinator ist wird auf der Devices Seite mit angezeigt, und zeigt die aktuelle FW Version des Stick sowie die PanID des Netzwerks an Screen Shot 2019-03-24 at 19.29.35 .png
                                    Ich wäre dankbar wenn diese Version etwas getestet wird bevor ich sie per pull-request in den Hauptzweig integrieren lasse.
                                    Wichtig - die Anpassungen für neue Geräte die seit letztem Wochenende gelaufen sind sind in dieser Version NICHT enthalten. Die werde ich erst mergen wenn die Tests durch sind.
                                    A.
                                    W Online
                                    W Online
                                    Wildbill
                                    schrieb am zuletzt editiert von Wildbill
                                    #123
                                    Hi, erstmal Danke für die neue Version. Ich habe eben die Möglichkeit gefunden, sie zu installieren. Parallel habe ich dem Stick eine neue Firmware gegönnt von hier:
                                    https://github.com/Koenkk/Z-Stack-firmware/blob/dev/coordinator/max_stability/CC2531/CC2531_MAX_STABILITY_20190315.zip
                                    Die max_stable soll dafür sorgen, dass das Netz möglichst stabil läuft und der Stick nur mit 5 Routern redet und der Rest dann mit denen.
                                    Aktuell habe ich nun 17 Lampen, 5 Bewegungsmelder (die habe ich wieder manuell eingefügt), 2 Remotes und einen Dimmer angelernt. Alles Tradfri bis auf eine Innr E14.
                                    Es scheint alles zu laufen und die Fehlermeldungen beim Start waren die Üblichen bis alles stabil ist. Im Adapter sind nun alle End devices als konfiguriert angezeigt. Nun schauen wir mal, ob, und wie lange das so läuft.
                                    BTW, ich habe heute nach einigem Lesen, auch bei Koenkk mal das Queuing ausgeschaltet, da sich hier die Geister streiten. Hat da jemand hier schon Erfahrungen im Vergleich mit/ohne gemacht?
                                    Gruss, Jürgen
                                    Kleines EDIT: Interessanterweise sehe ich nun zum ersten Mal die End devices jeweils mit der Lampe (Router) verbunden, die ihnen funktechnisch am nächsten sind. Wenn auch mit Status 255 (OFF) aber das ist ja normal. Das war bislang auch nicht immer so gegeben.
                                      Matdos
                                      #124
                                      Also habe es drauf gemacht und bei mir wurden die orangen Fenster von selber blau mit dem Haken ohne das ich was machen musste.
                                      Bin jetzt überall durch und habe alles ausprobiert, soweit geht alles was noch nicht gut geht ist der Türsensor bei Selina hier musste ich 4 mal die Türe auf und zu machen bis er mal den richtigen Zustand hatte nach Betätigen vom Anlern Knopf hat der Aqara Sensor 4 mal geblinkt (so solls sein wenn er ein Netz erkannt hat) danach habe ich mind 15 mal hintereinander auf und zu gemacht ohne Fehler mal schauen ob das so bleibt.
                                      Hier glaube ich aber langsam das die HW kacke ist da der schon irgendwie von Anfang an Probleme macht🤔
                                      Was ich noch habe das er beim setzen vom Wert 32 immer ne Fehlermeldung bringt, das hat jetzt aber nix mit dem Update zu tun das war vorher schon.
                                        Matdos
                                        schrieb am zuletzt editiert von Matdos
                                        #125
                                        Habt ihr noch mehr verändert? Soll ich die 2 Steckdosen und 2 Temp Sensoren auch wieder anlernen und schauen ob Probleme auftreten oder erst mal nen Tag so beobachten ob alles sauber läuft?
                                        • MyzerATM Offline
                                          MyzerATM Offline
                                          MyzerAT
                                          #126
                                          habt ihr auch das Problem das die Thermostate nicht immer auf 0% gehen, ich versteh nicht warum, im Wohnzimmer habe ich zur Zeit 24°C und er steht auf 2% Problem ist das mein Sonoff 5v der die Therme ein ausschaltet, dann nicht off geht, weil über 0% als Heizaufforderung zählt
                                          lg Rudi
                                          Node 22.23.0
                                          Nodejs 22.23.0
                                          npm 10.9.8
                                          js-controller 7.2.2
