  4. Adapter "smartmeter"
3.6k Beiträge 281 Kommentatoren 3.1m Aufrufe 162 Beobachtet
    backons
    #1332
    ich habe heute meinen Adapter von Weidmann Elektronik bekommen und angeschlossen.
    Als Stromzähler habe ich einen MT175 und folgendes habe ich im Smartmeter eingestellt:
    wenn ich den Adapter starte kommt folgendes im LOG:
    host.rock64	2019-02-20 20:41:12.062	info	Restart adapter system.adapter.smartmeter.0 because enabled
    host.rock64	2019-02-20 20:41:12.062	error	instance system.adapter.smartmeter.0 terminated with code 1 ()
    Caught	2019-02-20 20:41:12.061	error	by controller[0]: at Object.Module._extensions..js (module.js:664:10)
    Caught	2019-02-20 20:41:12.061	error	by controller[0]: at Module._compile (module.js:653:30)
    Caught	2019-02-20 20:41:12.061	error	by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/serialport/lib/bindings/linux.js:2:36)
    Caught	2019-02-20 20:41:12.061	error	by controller[0]: at bindings (/opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:81:44)
    Caught	2019-02-20 20:41:12.061	error	by controller[0]: at require (internal/module.js:11:18)
    Caught	2019-02-20 20:41:12.061	error	by controller[0]: at Module.require (module.js:597:17)
    Caught	2019-02-20 20:41:12.060	error	by controller[0]: at Function.Module._load (module.js:498:3)
    Caught	2019-02-20 20:41:12.060	error	by controller[0]: at tryModuleLoad (module.js:506:12)
    Caught	2019-02-20 20:41:12.060	error	by controller[0]: at Module.load (module.js:566:32)
    Caught	2019-02-20 20:41:12.060	error	by controller[0]: at Object.Module._extensions..node (module.js:682:18)
    Caught	2019-02-20 20:41:12.060	error	by controller[0]: Error: /opt/iobroker/node_modules/serialport/build/Release/serialport.node: wrong ELF class: ELFCLASS32
    Caught	2019-02-20 20:41:12.060	error	by controller[0]: ^
    Caught	2019-02-20 20:41:12.059	error	by controller[0]: throw e
    Caught	2019-02-20 20:41:12.059	error	by controller[0]: /opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:88
    host.rock64	2019-02-20 20:41:10.699	info	instance system.adapter.smartmeter.0 started with pid 9496
    Kann mir jemand sagen was den Fehler auslöst ?
    • portyP Offline
      portyP Offline
      porty
      schrieb am zuletzt editiert von porty
      #1333
      @backons
      warum hast du unter Datenprotokoll: D0 angegeben?
      Der MT175 nutzt die SML (SmartMeterLanguage)
      Dann ist schon mal die Hälfte der Settings weg.
      Dann trägst du den USb Port ein. Am besten als "/dev/serial/by-id/id_bzw_port_des_Adapters"
        digitalnaive
        #1334
        Jetzt muss ich den Thread leider doch wieder aufgreifen. Aus dem nichts bekomme ich plötzlich keine Werte mehr von meinem Smartmeter. Und die Logfile wirft alt bekannte Probleme aus. Was kann denn dafür der Grund sein, dass ein vorher funktionierendes Setting plötzlich nicht mehr die gewünschten Daten liefert?
        smartmeter.0	2019-03-13 09:22:12.929	debug	SCHEDULE NEXT RUN IN 30000s
        smartmeter.0	2019-03-13 09:22:12.929	debug	DELETE rest of data (0) because new Message start with a new Request Message
        smartmeter.0	2019-03-13 09:22:12.929	debug	CURRENT SIGNON MESSAGE COUNTER 1 OF 1
        smartmeter.0	2019-03-13 09:22:12.929	debug	SERIALPORT REMOVE LISTENERS
        smartmeter.0	2019-03-13 09:22:12.929	debug	SERIALPORT CLOSE
        smartmeter.0	2019-03-13 09:22:12.929	debug	CLEAR MESSAGE TIMEOUT TIMER
        smartmeter.0	2019-03-13 09:22:12.928	debug	STOP
        smartmeter.0	2019-03-13 09:22:12.928	debug	Transport Reset!! Restart = true
        smartmeter.0	2019-03-13 09:22:12.928	debug	Error: No or too long answer from Serial Device after last request.
        smartmeter.0	2019-03-13 09:22:12.928	warn	No or too long answer from Serial Device after last request.
        smartmeter.0	2019-03-13 09:22:12.927	debug	MESSAGE TIMEOUT TRIGGERED
        smartmeter.0	2019-03-13 09:21:42.916	debug	SET MESSAGE TIMEOUT TIMER2: 30000
        smartmeter.0	2019-03-13 09:21:42.915	debug	DONE SEND 0
        smartmeter.0	2019-03-13 09:21:42.664	debug	DONE SEND 1
        smartmeter.0	2019-03-13 09:21:42.658	debug	TO SEND 1: /?!
        smartmeter.0	2019-03-13 09:21:42.657	debug	CURRENT PROCESS STEP 1 IN GETNEXTMESSAGE
        smartmeter.0	2019-03-13 09:21:42.657	debug	TO SEND 2:
        smartmeter.0	2019-03-13 09:21:42.656	debug	CURRENT PROCESS STEP 0 IN GETNEXTMESSAGE
        smartmeter.0	2019-03-13 09:21:42.655	debug	INITIAL MESSAGES TO SEND: 2
        smartmeter.0	2019-03-13 09:21:42.652	debug	SERIALPORT RESET BAUDRATE TO 300
        smartmeter.0	2019-03-13 09:21:42.644	debug	SERIALPORT OPEN
        smartmeter.0	2019-03-13 09:21:42.624	debug	CREATE SERIALPORT: 300 7 1 even
        smartmeter.0	2019-03-13 09:21:42.619	debug	SmartmeterObis options: {"debug":2,"protocol":"D0Protocol","transport":"SerialRequestResponseTransport","requestInterval":"30","transportSerialPort":"/dev/ttyUSB0","transportSerialB
        • wendy2702W Online
          wendy2702W Online
          #1335
          Pauschal würde ich sagen du hast das wieder geändert....
          @digitalnaive sagte in Adapter "smartmeter":
          @Röstkartoffel said in Adapter "smartmeter":
          Kannst du bitte mal in der SignOnMessage anstelle von /?! nur das ? eintragen?
          Und kannst du uns mal deine Adapter Versionsnummer nennen?
          Es geht!!! Sorry für die Ausrufezeichen aber das war der entscheidende Tipp!!!!
          zumindest laut deinem Logfile:
          • wendy2702W wendy2702
            digitalnaive
            #1336
            @wendy2702 said in Adapter "smartmeter":
            Siehe meinen Screenshot. Das ist der Screenshot von heute. Ich habe diese Config nicht eine Sekunde angefasst. Mir ist diese Zeile auch schon aufgefallen. Aber ich habe hier immernoch nur ein Fragezeichen drinnen stehen.
            • wendy2702W Online
              wendy2702W Online
              #1337
              Wurden sonst irgendwelche Upgrades am PI gemacht?
              Den PI mal neu gestartet?
              • RöstkartoffelR Offline
                Röstkartoffel
                #1338
                Das / und das ! trägt der Adapter selbstständig ein, so dass im Log das dann so steht: /?!
                NUC7i3BNH mit Proxmox und ioBroker (VM Debian Buster), Raspi3 (Slave Smartmeter für eHZ easymeter), Hardware CCU2, SMA SB5000TL-21
                  digitalnaive
                  schrieb am zuletzt editiert von digitalnaive
                  #1339
                  Es gab ein Upgrade von JavaScript, Vis und Mobile. Beeinflusst JavaScript die Veränderung evtl?
                  Update javascript from @3.6.5 to @4.1.12
                  NPM version: 6.4.1
                  • D digitalnaive
                    NPM version: 6.4.1
                    #1340
                    @digitalnaive
                    @wendy2702 sagte in Adapter "smartmeter":
                    Wendy meint den pi selber (denke ich), nicht iobroker
                    nein!
                    Das hast du aber inzwischen gemacht?
                      @digitalnaive
                      nein!
                      digitalnaive
                      #1341
                      @Homoran Ja, hab ihn sicherheitshalber jetzt ein zweites mal restartet.
                      Folgende Meldung:
                      smartmeter.0	2019-03-13 09:54:07.177	debug	SCHEDULE NEXT RUN IN 30000s
                      smartmeter.0	2019-03-13 09:54:07.177	debug	DELETE rest of data (0) because new Message start with a new Request Message
                      smartmeter.0	2019-03-13 09:54:07.176	debug	CURRENT SIGNON MESSAGE COUNTER 1 OF 1
                      smartmeter.0	2019-03-13 09:54:07.176	debug	ERROR CLOSING SERIALPORT: Error: Port is not open
                      smartmeter.0	2019-03-13 09:54:07.176	debug	TO SEND 1: /?!
                      smartmeter.0	2019-03-13 09:54:07.176	debug	CURRENT PROCESS STEP 1 IN GETNEXTMESSAGE
                      smartmeter.0	2019-03-13 09:54:07.176	debug	TO SEND 2:
                      smartmeter.0	2019-03-13 09:54:07.176	debug	CURRENT PROCESS STEP 0 IN GETNEXTMESSAGE
                      smartmeter.0	2019-03-13 09:54:07.176	debug	INITIAL MESSAGES TO SEND: 2
                      smartmeter.0	2019-03-13 09:54:07.176	debug	CLEAR MESSAGE TIMEOUT TIMER
                      smartmeter.0	2019-03-13 09:54:07.176	debug	STOP
                      smartmeter.0	2019-03-13 09:54:07.176	debug	Transport Reset!! Restart = true
                      smartmeter.0	2019-03-13 09:54:07.176	debug	Error: Error on Baudrate changeover: Error: Port is not open
                      smartmeter.0	2019-03-13 09:54:07.176	warn	Error on Baudrate changeover: Error: Port is not open
                      Ergänzung. Mir wirft ls l /dev/ttyUSB* folgendes aus?! Auch daran habe ich nichts verändert. Heißt das auf gut deutsch, dass mein USB Gerät nicht mehr "eingehängt" ist?
                      digitalnaive@asrock:~$ ls -l /dev/ttyUSB*
                      ls: cannot access '/dev/ttyUSB*': No such file or directory
                      • wendy2702W Online
                        wendy2702W Online
                        #1342
                        Was kommt denn hier:
                        sudo dmesg | grep tty
                        Um festzustellen ob es etwas mit den Updates zu tun hat, könntest du mal downgrades machen... einem nach dem anderen und dazwischen immer schauen ob sich etwas geändert hat.
                        Node/NPM hast du nicht zufällig auch upgedated?
                          digitalnaive
                          #1343
                          @wendy2702
                          digitalnaive@asrock:/dev$ sudo dmesg | grep tty
                          [    0.000000] console [tty0] enabled
                          Nein da hab ich keine Updates gemacht. Ich hatte lediglich eine zusätzliche USB Festplatte angeschlossen. Das dürfte doch aber die bestehende Konfiguration nicht beeinträchtigen. Oder denke ich da zu naiv?
                          • wendy2702W Online
                            wendy2702W Online
                            #1344
                            Pauschal würde ich sagen das deine USB Device nicht erkannt werden.
                            Mal alle USB Device abstecken.
                            Dann
                            dmesg
                            Lesekopf anstecken und erneut dmesg, ist der jetzt sichtbar in der Ausgabe?
                              Dann
                              dmesg
                              digitalnaive
                              #1345
                              Kann ich leider erst heute Abend machen.
                              Aktuelles DMESG liefert keinerlei Werte zu FTDI. Das ist schon mal kein gutes Zeichen.
                              • jedoJ jedo
                                @PavelCoast:
                                sorry muss jetzt doch mal nachfragen, da ich irgendwie nicht weiter komme.
                                Habe einen AS1440 Zähler von elster und einen USB Schreib lesekopf von Weidmann.
                                Leider bekomme ich in iobroker keine Werte angezeigt, es wird nur "No or too long answer from Serial Device after last request." angezeigt.
                                Wo könnte das Problem liegen?
                                Es werden scheinbar auch Werte vom Zähler gelesen.
                                Ich hoffe jemand kann mir weiterhelfen. `
                                Hast du schon mal bei Volkszähler die https://wiki.volkszaehler.org/hardware/channels/meters/power/edl-ehz/elster_as1440 studiert?
                                Eventuell trifft das mit dem Passwort bei dir zu!?
                                U Offline
                                U Offline
                                uschi08
                                schrieb am zuletzt editiert von uschi08
                                #1346
                                @jedo said in Adapter "smartmeter":
                                ich habe auch die Kombi aus Weidmann IR Leser und AS1440, komme nicht weiter.
                                • Lesekopf wird erkannt mit grep ....und als ich es schrieb sehe ich, dass es nicht mehr /dev/ttyUSB1 sondern wieder 0 ist..4 Stunden später...
                                  läuft danke für die Einstellungen - die funktionieren !
                                • StabilostickS Stabilostick
                                  @steini87
                                  Deine Zählerbezeichnung lautet also eBZ DD3 2R06 DTA - SMZ1
                                  Das bedeutet:
                                  1. Der Zählergrundtyp den Du hast ist DD3.
                                  2. Du hast einen Zweirichtungszähler mit einem Maximalstrom von 60A.
                                  3. Der Zähler ist ein Doppeltarifzähler der Genauigkeitsklasse A.
                                  Zusammengefasst: Die Anleitung des eBZ DD3-Zählers passt auch für Deinen Zähler.
                                  Telegramm Mode D: nach DIN EN 625056-21
                                  Baudrate: 9600 Baud (Z=5)
                                  Byte-Format: (7,even,1)
                                  Wenn das gar nicht geht, versuche auch 2400Baud.
                                  steini87
                                  #1347
                                  @Stabilostick Hallo zusammen und danke für eure Hilfe. Ich kann nun endlich Erfolg vermelden und der Adapter liest nach Aktivierung des langen Datentelegramms sauber Daten aus.
                                  Ich bin durch einen anderen Nutzer noch einmal an eine aktuellere Bedienanleitung vom Zähler gekommen. Darin kam dann zum Vorschein, dass für Zähler vom Typ OD: 7, even, 1 gilt und für Zähler vom Typ SM (meiner): 8, none, 1 gilt. Das Ganze mit einer Baudrate von 9600 Baud. Damit lief es bei mir auf Anhieb.
                                  @Appollon: Kannst du eBZ mit in die Liste der unterstützten Zähler aufnehmen?
                                  • Elektroniker86E Offline
                                    Elektroniker86
                                    #1348
                                    ich will hier nur meine Erfahrung mit Smartmeter und meinem Stromzähler teilen. Vielleicht hilft es ja dem einen oder anderen weiter.
                                    Und zwar geht es um den ISKRA MT 681 -D4A51-K0p dieser sendet jede Sekunde ein Datenpaket mit dem aktuellen Zählerstand ohne Nachkommastellen. Und das wars dann auch schon.
                                    Um weitere Datenpunkte zu erhalten kommt man um den PIN Code leider nicht drumrum. Aber wenn dieser beim EVU angefordert dann spuckt der Zähler mehr aus.
                                    Nach dem "einleuchten" der Pin mit der Taschenlampe kommen automatisch folgende Datenpunkte im Smartmeter / ioBroker an:
                                    • Aktueller Zählerstand bis auf die 4. Nachkommastelle in kWh
                                    • Momentanverbrauch je einzelner Phase (L1, L2, und L3) in Watt
                                    • Momentanverbrauch gesamt (L1+L2+L3) ebenfalls in Watt
                                    Der Zähler bleibt freigeschaltet, außer bei einem Stromausfall, dann muss der Pin erneut eingeleuchtet werden.
                                    Ich habe euch noch ein Screenshot von den Einstellungen und den Objekten gemacht.
                                    • M Matthias I
                                      Hallo zusammen!
                                      Ich möchte - nachdem ich in den letzten Tagen die 54 Seiten dieses Threats gelesen habe - nun gerne auch meine Zähler auslesen.
                                      Bevor ich anfange möchte ich mich schonmal bei allen für den tollen Adapter und die Hilfe bedanken!!
                                      Könntet ihr mir bitte sagen, ob ich auf dem richtigen Weg mit meiner Planung bin?
                                      Meine Situation:
                                      • Stromzähler: 2 Zweirichtungszähler (EMH eHZ-IW8E2A5L0EQ2P) und einen Einrichtungszähler (EMH eHZ-IW8E2A5L0EL2P)
                                      Ich habe eine PV-Anlage, der dort produzierte Strom wird zunächst im Haushalt und dann in der Wärmepumpe selbst verbraucht, der Rest eingespeist
                                      Der Einrichtungszähler (EMH eHZ-IW8E2A5L0EL2P) zählt die Gesamtproduktion des PV-Stroms. Diese Werte kann ich aber über einen Fronius
                                      Smartmeter bereits erfolgreich abrufen.
                                      Um die Verbräuche für Haushalt und Wärmepumpe berechnen zu können benötige ich aber noch jeweils die 4 Werte (1.8.1, 1.8.2, 2.8.1, 2.8.2) der
                                      beiden Zweirichtungszähler (EMH eHZ-IW8E2A5L0EQ2P)
                                      • iobroker auf Synology Diskstation (Docker Container)
                                      Meine Zielsetzungen:
                                      1. Die 4 Zählerstände und Momentanverbräuche der beiden Zweirichtungszähler als Objekte in ioBroker einlesen
                                      2. Tages- / Monats- / Jahresverbräuche für Wärmepumpe und Haushaltsstrom in einem Script berechnen
                                      3. Die o.g. Verbräuche grafisch darstellen und in VIS einbinden
                                      Meine Planung:
                                      1. IR-USB-Leseköpfe besorgen
                                      Frage: Wer kennt eine gangbare Alternative zu "Volkszähler"? (Ist ja leider schwierig rankommen)
                                      2. Entweder Synology neben Zählern positionieren
                                      Frage: Funktioniert das Einbinden der USB-Leseköpfe wie beim Raspi?
                                      ODER
                                      Vorhandenen RasPi2 mit einem Image der ioBroker-Internetseite bespielen und als Slave in ioBroker einbinden und 2 Instanzen des Smartmeter-
                                      Adapters von der Adminoberfläche des ioBroker auf der DS auf dem Slave (RasPi2) installieren (für jeden Zähler eine Instanz)
                                      Frage: Was haltet ihr für sinnvoller?
                                      3. Die bereits hier veröffentlichten Skripte für meine 3-Zähler-Variante so anpassen, dass ich die Tages- / Monats- / Jahresverbräuche für
                                      Wärmepumpe und Haushaltsstrom berechnet bekomme
                                      Bitte: Mich hier zu unterstützen, da ich nur begrenzte Scripterfahrung besitze
                                      4. Datenpunkte (Berechnungen) mit MySQL oder History speichern (Hier habe ich noch keine Erfahrung)
                                      5. Datenpunkte grafisch darstellen und in VIS einbinden
                                      Vielen Dank für Eure Meinung / Hilfe!!!!
                                      Matthias
                                      martinschm
                                      #1349
                                      @Matthias-I said in Adapter "smartmeter":
                                      Meine Situation:
                                      Matthias
                                      Hi Matthias, hab auch den ehz-iw8e2a5l0eq2p, hast du ihn alsn Laufen bekommen ? Welche Parameter hast du im Smartmeter Adapter eingetragen ?
                                        martinschm
                                        schrieb am zuletzt editiert von martinschm
                                        #1350
                                        hab wie @Matthias-I einen ehz-iw8e2a5l0eq2p Zähler. Als Lesekopf habe ich einen Volkszähler mit RS232 Schnittstelle. Ich hab mir einen USB Konverter (Datasheet) geholt und damit an einen Raspberry angeschlossen.
                                        Stehe jetzt vor zwei Fragen, a) wie muß ich den Smartmeter Adapter konfigurieren bzw wo kann ich die Infos finden und b) wie kann ich testen ob die Hardware richtig funktioniert?
                                        Achso, bisher kommt nur das im Log
                                        smartmeter.0	2019-07-27 23:45:35.013	debug	SCHEDULE NEXT RUN IN 300s
                                        smartmeter.0	2019-07-27 23:45:35.011	debug	SERIALPORT CLOSE
                                        smartmeter.0	2019-07-27 23:45:34.955	debug	Transport Reset!! Restart = true
                                        smartmeter.0	2019-07-27 23:45:34.954	debug	Error: No or too long answer from Serial Device after last request.
                                        smartmeter.0	2019-07-27 23:45:34.954	warn	No or too long answer from Serial Device after last request.
                                        smartmeter.0	2019-07-27 23:45:34.953	debug	Error: No or too long answer from Serial Device after last request.
                                        smartmeter.0	2019-07-27 23:45:34.951	debug	MESSAGE TIMEOUT TRIGGERED
                                        smartmeter.0	2019-07-27 23:45:32.943	debug	SET MESSAGE TIMEOUT TIMER: 2000
                                        smartmeter.0	2019-07-27 23:45:32.934	debug	SERIALPORT OPEN
                                        smartmeter.0	2019-07-27 23:45:32.928	debug	CREATE SERIALPORT: 9600 8 1 none
                                        smartmeter.0	2019-07-27 23:45:32.928	debug	SmartmeterObis options: {"debug":2,"protocol":"D0Protocol","transport":"SerialResponseTransport","requestInterval":"300","anotherQueryDelay":"1000","transportSerialPort":"/dev/ttyUSB0","transportSeria
                                        smartmeter.0	2019-07-27 23:45:32.928	info	starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v8.16.0
                                        Wenn ich SML wähle kommt das gleiche. Hatte damals von Netzbetreiber noch ein Pin bekommen, wo/wie gebe ich den eigentlich ein ?
                                        Ciao
                                        Martin
                                        • M martinschm
                                          Ciao
                                          Martin
                                          toki1973
                                          #1351
                                          @martinschm said in Adapter "smartmeter":
                                          hab wie @Matthias-I einen ehz-iw8e2a5l0eq2p Zähler. Als Lesekopf habe ich einen Volkszähler mit RS232 Schnittstelle. Ich hab mir einen [USB Konverter](https://www.ebay.de/itm/3-3V-5V-Typ-A-USB-to-TTL-
                                          Ciao
                                          Martin
                                          Das schreibt doch elektroniker86 in seinem post:
                                          "Nach dem "einleuchten" der Pin mit der Taschenlampe kommen automatisch folgende Datenpunkte im Smartmeter / ioBroker an:"
                                          NUC, PROXMOX, Grafana, Influx, Unify
