  4. [Aufruf] Adapter: Snips - Offline Speak2Text
    1.0k
snips
635 Beiträge 43 Kommentatoren 209.0k Aufrufe 22 Beobachtet
  • WalW Wal
    Hier mal meine Config:
    Snips-Server:
    Connected to device localhost
    OS version ................... Debian GNU/Linux 9 (stretch)
    Installed assistant .......... ioBroker
    Language ..................... de
    Hotword ...................... hey_snips
    ASR engine ................... snips
    Status ....................... Live
    Service status:
    snips-analytics .............. (not running)
    snips-asr .................... 0.60.8 (running)
    snips-audio-server ........... 0.60.8 (running)
    snips-dialogue ............... 0.60.8 (running)
    snips-hotword ................ 0.60.8 (running)
    snips-nlu .................... 0.60.8 (running)
    snips-skill-server ........... 0.60.8 (not running)
    snips-tts .................... 0.60.8 (running)
    [snips-common]
     bus = "mqtt"
     mqtt = "localhost:1500"
    # audio = ["+@mqtt"]
    # assistant = "/usr/share/snips/assistant"
    # user_dir = "/var/lib/snips"
    [snips-audio-server]
    # frame = 256
    bind = "livingroom@mqtt"
    # mike = "Built-in Microphone"
    # disable_playback = false
    [snips-hotword]
    # model = "/usr/share/snips/hotword"
    # hotword_id = "default"
    # sensitivity = "0.5"
    audio = ["livingroom@mqtt", "kitchen@mqtt"]
    Satellit:
    OS version ................... Raspbian GNU/Linux 9 (stretch)
    Installed assistant .......... Not installed
    Status ....................... Live (no assistant)
    Service status:
    snips-asr .................... (not running)
    snips-audio-server ........... 0.60.12 (running)
    snips-dialogue ............... (not running)
    snips-hotword ................ (not running)
    snips-nlu .................... (not running)
    snips-skill-server ........... (not running)
    snips-tts .................... (not running)
    [snips-common]
    # bus = "mqtt"
    mqtt = "192.168.111.5:1500"
    # frame = 256
    bind = "kitchen@mqtt"
    # disable_capture = false
    Injection geht mit dieser Config bei mir.
    Edit: snips-injection ist nur auf dem Server installiert.
    unltdnetworxU Offline
    unltdnetworx
    #384
    @Wal sagte in [Aufruf] Adapter: Snips - Offline Speak2Text:
    Snips-Server:
    Service status:
    [snips-common]
     bus = "mqtt"
    # frame = 256
    [snips-hotword]
    Satellit:
    Service status:
    [snips-common]
    # bus = "mqtt"
    # frame = 256
    @Wal
    Hat es schön dargestellt. So sollte es klappen. Die Arbeit macht der Server. Du kannst je nach Laune noch den Hotword Server aktivieren, wenn du ein eigenes Hotword für den Satelliten willst.
    Gruß, Michael
    Weitere Infos im Profil.
    Wenn euch der Beitrag weitergeholfen hat, könnt ihr die Bewertung rechts unten im Beitrag nutzen.
      mmaric
      #385
      Sieht wie meine König aus. Frage ist welche text2command version
      • M mmaric
        mmaric
        #386
        @mmaric said in [Aufruf] Adapter: Snips - Offline Speak2Text:
        Meine Konfiguration
        unltdnetworxU 1 Antwort Letzte Antwort
        • M mmaric
          Meine Konfiguration
          unltdnetworx
          #387
          @mmaric
          Ich hab die neueste Version über Github aktualisiert.
          Gruß, Michael
          • M mmaric
            hallo,
            momentan habe ich einen Master (PC) und einen Satellit.
            Auf dem Satellit ist nur snips-audio-server, nach der Beschreibung von snips.ai.
            Nur zwei Werte eingetragen.
            snips-common
            mqtt = "masterip:1883"
            snips-audio-server
            bind= "satelitt:1883"
            sam habe ich nicht auf dem satelliten,
            brauche ich eventuell mehr ?
            unltdnetworx
            schrieb am zuletzt editiert von unltdnetworx
            #388
            @mmaric
            Aber was mir von unterwegs auffällt, du hast beim Audio-Server
            @1883
            Stehen statt
            @mqtt
            Gruß, Michael
            • unltdnetworxU unltdnetworx
              @mmaric
              @1883
              Stehen statt
              @mqtt
              mmaric
              #389
              @unltdnetworx said in [Aufruf] Adapter: Snips - Offline Speak2Text:
              @mmaric
              @1883
              Stehen statt
              @mqtt
              hallo,
              das war ein Schreibfehler.
                mmaric
                #390
                Anbei noch einmal alle Informationen. Viele Augen sehen besser.
                1. Zentrale ( PC)
                [snips-common]
                bus = "mqtt"
                mqtt = "localhost:1883"
                bind = "zentrale@mqtt"
                [snips-hotword]
                audio = ["zentrale@mqtt", "wohnzimmer@mqtt"]
                1. Satellit
                [snips-common]
                mqtt = "192.168.178.32:1883"
                bind = "wohnzimmer@mqtt"
                Zusammengefasst wie der Ablauf ist:
                Wenn ich das hotword am Satelliten nenne, dann wird im Adapter snips die Session ID eingetragen.
                Jedoch wird der Wert text (text to send) unter devices.all.send.text nicht aktualisiert mit der Antwort.
                Wenn ich über den Adapter text2send das Wort wetter morgen eintrage, dann wird das richtige Feld ausgeführt und als Antwort in das devices.all.send.text gefüllt.
                Unten noch einmal die Log Ausgabe von sam watch.
                Vielen Dank für die Unterstützung.
                [Dialogue] session with id '51e90396-a62f-4dee-82ba-587f73da0c62' was ended on site wohnzimmer. The session was ended because one of the component didn't respond in a timely manner
                [10:18:51] [Asr] was asked to stop listening on site wohnzimmer
                [10:18:51] [Hotword] was asked to toggle itself 'on' on site wohnzimmer
                [10:18:51] [Dialogue] session with id 'cc9060db-49d1-4d8b-ad69-f1ba8e8bfd42' was ended on site zentrale. The session was ended because one of the component didn't respond in a timely manner
                [10:18:51] [Asr] was asked to stop listening on site zentrale
                [10:18:51] [Hotword] was asked to toggle itself 'on' on site zentrale
                [10:19:17] [Hotword] detected on site wohnzimmer, for model hey_snips
                [10:19:17] [Asr] was asked to stop listening on site wohnzimmer
                [10:19:17] [Hotword] was asked to toggle itself 'off' on site wohnzimmer
                [10:19:17] [Dialogue] session with id 'ffce8e3f-3cdc-47c8-a479-e453d2cf51cb' was started on site wohnzimmer
                [10:19:17] [AudioServer] was asked to play a wav of 41.1 kB with id '165026fc-7784-4d32-96d4-ff2372c54346' on site wohnzimmer
                [10:19:17] [Hotword] detected on site zentrale, for model hey_snips
                [10:19:17] [Asr] was asked to stop listening on site zentrale
                [10:19:17] [Hotword] was asked to toggle itself 'off' on site zentrale
                [10:19:17] [Dialogue] session with id '187b9df9-b5e9-4707-af19-bedc7e5f9e86' was started on site zentrale
                [10:19:17] [AudioServer] was asked to play a wav of 41.1 kB with id '750082ad-a37d-4db1-add1-6353e5927a1f' on site zentrale
                [10:19:18] [AudioServer] finished playing wav with id '750082ad-a37d-4db1-add1-6353e5927a1f'
                [10:19:18] [Asr] was asked to listen on site zentrale
                [10:19:18] [AudioServer] finished playing wav with id '165026fc-7784-4d32-96d4-ff2372c54346'
                [10:19:18] [Asr] was asked to listen on site wohnzimmer
                [10:19:20] [Asr] captured text "wetter morgen" in 2.0s
                [10:19:20] [Asr] was asked to stop listening on site zentrale
                [10:19:20] [AudioServer] was asked to play a wav of 93.1 kB with id '42e5d28c-eb0a-45c2-9d84-ea079e28e521' on site zentrale
                [10:19:20] [Asr] captured text "becker morgen" in 2.0s
                [10:19:20] [Asr] was asked to stop listening on site wohnzimmer
                [10:19:20] [AudioServer] was asked to play a wav of 93.1 kB with id 'd228188f-0b4b-4ccb-b5e6-e25d3a19ed0f' on site wohnzimmer
                [10:19:22] [AudioServer] finished playing wav with id '42e5d28c-eb0a-45c2-9d84-ea079e28e521'
                [10:19:22] [Nlu] was asked to parse input "wetter morgen"
                [10:19:22] [Nlu] detected intent m-maric:Default with confidence score 1.000 for input "wetter morgen"
                [10:19:22] [Dialogue] New intent detected m-maric:Default with confidence 1.000
                [10:19:22] [AudioServer] finished playing wav with id 'd228188f-0b4b-4ccb-b5e6-e25d3a19ed0f'
                [10:19:22] [Nlu] was asked to parse input "becker morgen"
                [10:19:22] [Nlu] detected intent m-maric:Default with confidence score 1.000 for input "becker morgen"
                [10:19:28] [Dialogue] session with id 'ffce8e3f-3cdc-47c8-a479-e453d2cf51cb' was ended on site wohnzimmer. The session was ended because one of the component didn't respond in a timely manner
                [10:19:28] [Asr] was asked to stop listening on site wohnzimmer
                [10:19:28] [Hotword] was asked to toggle itself 'on' on site wohnzimmer
                [10:19:28] [Dialogue] session with id '187b9df9-b5e9-4707-af19-bedc7e5f9e86' was ended on site zentrale. The session was ended because one of the component didn't respond in a timely manner
                [10:19:28] [Asr] was asked to stop listening on site zentrale
                [10:19:28] [Hotword] was asked to toggle itself 'on' on site zentrale
                • unltdnetworxU Offline
                  unltdnetworx
                  #391
                  Also momentan scheint dein Adapter nichts an text2command weiterzugeben. Hast du die richtige Instanz in den Einstellungen eingetragen? Im Normalfall sollte es die erste sein, also mit .0.
                  Ich hab leider noch keinen Satelliten, daher kann ich das Protokoll nicht vergleichen, aber mir erscheint etwas komisch, dass sowohl die Zentrale als auch "Wohnzimmer" auf deine Eingabe reagieren. Das kann vllt. jemand beantworten, der ebenfalls mehrere Satelliten hat.
                  Evtl. musst du dazu deine Client ID erhöhen. Da du ja schon einen Satelliten hast, wird der vermutlich die 0 haben. Versuch mal 1 oder sogar 2. Vllt. ändert sich was an der Doppelerkennung. Oder stehen die beiden Geräte nebeneinander?
                  Im Endeffekt ist die Kommunikation zwischen Adapter und Snips aber am Laufen, da auch eine SessionID eingetragen wird.
                  Gruß, Michael
                    mmaric
                    #392
                    @unltdnetworx
                    anbei die Einstellung des Adapters.
                    Die reagieren bei, weil sowohl Laptop und Satellit im gleichen Raum momentan stehen.
                      unltdnetworx
                      #393
                      @mmaric sagte in [Aufruf] Adapter: Snips - Offline Speak2Text:
                      m-maric:Default
                      Aaaaah, jetzt hab ich den Fehler gefunden.
                      Du hast nicht meine Snips-App genommen sondern eine eigene geforked: m-maric:Default
                      Das klappt leider nicht. Der Adapter reagiert nur auf Intents von unltdnetworx:
                      Wenn du eigene Wünsche hast, kannst du sie gerne hier mitteilen, etwa Wörter die nicht enthalten sind oder Sätze die nicht verstanden werden. Gerne her damit und ich pflege sie ein. 😊
                      Und den Filter solltest du auf verstehe setzen, weil sonst immer eine Ausgabe von text2command ausgegeben wird, wenn einzelne Worte/Aufgaben nicht erkannt werden. "Ich verstehe 'nicht erkannten Befehl' nicht."
                      Gruß, Michael
                        m-maric:Default
                        mmaric
                        #394
                        @unltdnetworx
                        Ich habe mal die den Default Intent umbenannt und bei eingespielt.
                        Klappt aber nicht.
                          unltdnetworx
                          #395
                          Das muss ja auch unltdnetworx:getStatus oder :setDevice,etc. heißen. Es geht definitiv nicht einfach umzubenennen.
                          Gruß, Michael
                          M ___manalishi_ 2 Antworten Letzte Antwort
                            mmaric
                            #396
                            @unltdnetworx
                            ok, verstanden.
                            Wie komme ich da dran ?
                            Danke für die Geduld.
                              ___manalishi_ Offline
                              ___manalishi
                              schrieb am zuletzt editiert von ___manalishi
                              #397
                              Hallo, war die letzten Tage beruflich eingespannt und daher hier wenig aktiv.
                              Ich habe meinen ersten Prototyp des Gehäuses montiert. Bei der Montage des Pi's mit den 2 Karten hat sich etwas Optimierungspotential in der Konstruktion gezeigt.
                              Das Gehäuse wurde mit einem Prusa 3D Printer hergestellt. Ich hatte mir die Ansicht von oben bei der Grösse der Löcher und der grünen Farbe der Platine schlimmer vorgestellt. Lediglich die Oberflächenqualität mag Designeransprüchen nicht genügen.
                              Der Pi wird mit den 4 Schrauben inkl. den 2 Platinen zwischen Bodenplatte und Gehäusedeckel fixiert. Hier erscheint es mir sinnvoller den Pi mit 4 Schrauben nur auf die Bodenplatte zu schrauben und den Deckel separat zu befestigen.
                              Die Aussparung ermöglicht Zugang zur SD Karte,sollte aber auch noch grösser werden.
                              Ich bin noch auf der Suche nach geeigneten, selbtsklebenden Gummifüssen. Das scheint mir sinnvoller als etwas zu drucken.
                              /ioBoker auf PVE LXC
                                unltdnetworx
                                #398
                                Sieht schon mal super aus. :)
                                Gruß, Michael
                                ___manalishi_ 1 Antwort Letzte Antwort
                                  ___manalishi
                                  #399
                                  Nach ca.10 Tagen Dauerbetrieb habe ich folgendes beobachtet:
                                  1. Mit den Neustarts (2x täglich die Snips-Services und 1x den Pi) habe ich ein zuverlässiges Verhalten der Satelliten, sowohl vom Hotword wie auch vom RESpeaker Skill für die LEDs
                                  2. Der Snips Server läuft zuverlässig mit 2x Neustart der Services ohne rebooten des OS.
                                  3. Da ich mit Telegram meinen ioBroker monitore fällt mir auf, dass in unregelmässigen Abständen das Hotword erkannt wird, ohne dass es wirklich ausgesprochen wurde. Das deckt sich auch in den Fällen, in denen ich es "live" beobachtet habe, durch Leuchten der LEDs am Satelliten.
                                  Ich bin bisher davon ausgegangen, dass "Hey Snips" im Alltagsbetrieb ein zuverlässiges Hotword ist, da es (zumindest in unserem Sprachgebrauch zu Hause) nicht vorkommt.
                                  Kann jemand dieses Verhalten bestätigen?
                                  • R Offline
                                    rascal
                                    #400
                                    Hey,
                                    ich verfolge den "neuen" Adapter mit Spannung, bin aber noch nicht dazugekommen, dass ich ihn installiere und ausprobiere.
                                    Was mir nicht ganz klar ist im Moment:
                                    • gibt der Adapter nur auf jenem Snips eine Antwort, wo er auch aktiviert worden ist? (mit dem Text2Command Adapter)
                                    • Ist das Problem mit dem verschwindenden Antwort-Datenpunkt im T2C-Adapter behoben?
                                    LG
                                    Martin
                                    • R rascal
                                      Hey,
                                      LG
                                      Martin
                                      unltdnetworx
                                      #401
                                      @rascal
                                      Hi Martin,
                                      der Adapter gibt in der neuen Version (testing) immer auf dem Gerät aus, auf dem auch der Dialog gestartet wurde. In text2command muss aber auf alle gestellt werden. Der Adapter regelt die Ausgabe selbstständig.
                                      Wenn der Datenpunkt für alle Geräte direkt angesprochen wird, also nicht über Snips, sondern etwa über ein Skript, z.B. wenn die Waschmaschine fertig ist, werden alle Geräte gleichzeitig angesprochen, vllt. mit wenigen Millisekunden Unterschied.
                                      Wenn die einzelnen say-Datenpunkte direkt angesprochen werden, gibt auch nur das jeweilige Gerät aus.
                                      Gruß, Michael
                                      • ___manalishi_ ___manalishi
                                        unltdnetworx
                                        #402
                                        @frank70
                                        Hi Frank,
                                        das kann ich so nicht bestätigen. Bei mir läuft es seit langem 24/7 ohne jegliche Neustarts problemlos.
                                        Mit der neuesten Version der Snips-Plattform muss ich sagen habe ich kaum bis gar keine Falscherkennungen mehr. Bin damit äußerst zufrieden. Die Erkennung bei lauter Umgebung oder großer Entfernung hat sich hingegen kaum/nicht verbessert.
                                        Aktuell ist die neueste Version der Plattform und testing-Version des Adapters bei mir im Einsatz.
                                        Gruß, Michael
                                          @frank70
                                          Hi Frank,
                                          ___manalishi
                                          #403
                                          @unltdnetworx Ok, dann werde ich die Snips Umgebung mal auf neuesten Stand bringen. Ich bin mit der jetzigen Qualität auch zufrieden. Neustarts stören nicht den Betrieb. Die falsch erkannten Hotwords richteten bisher keinen Schaden an, soll heissen, die danach erkannten Worte haben keines meiner Skripte Verwendung gefunden.
                                          Edit:
                                          Bei mir siehts nach dem Update jetzt so aus:
                                          Update mit sam update durchgeführt. Sind die unterschiedlichen Versionen so ok?
                                          Server:
                                          Service status:
                                          snips-analytics .............. 0.61.1 (not running)
                                          snips-asr .................... 0.61.1 (running)
                                          snips-audio-server ........... 0.61.1 (not running)
                                          snips-dialogue ............... 0.61.1 (running)
                                          snips-hotword ................ 0.61.1 (running)
                                          snips-nlu .................... 0.61.1 (not running)
                                          snips-skill-server ........... 0.61.1 (not running)
                                          snips-tts .................... 0.61.1 (running)
                                          Clients
                                          Service status:
                                          snips-analytics .............. 0.60.10 (not running)
                                          snips-asr .................... 0.60.10 (not running)
                                          snips-audio-server ........... 0.60.10 (running)
                                          snips-dialogue ............... 0.60.10 (not running)
                                          snips-hotword ................ 0.60.10 (running)
                                          snips-nlu .................... 0.60.10 (not running)
                                          snips-skill-server ........... 0.60.10 (running)
                                          snips-tts .................... 0.60.10 (running)
