  4. KNX Adapter überholt
1.0k Beiträge 123 Kommentatoren 513.1k Aufrufe 26 Beobachtet
    sound31
    #882
    Hallo Chefkoch!
    Nach dem Update des Adapters auf die Version 1.0.19 startet dieser nun alle 30 sec. neu.
    undefined2019-01-25 07:17:06.541 - error: host.Visu-Beelink instance system.adapter.knx.0 terminated with code 7 (Adapter already running)
    2019-01-25 07:17:06.541 - info: host.Visu-Beelink Restart adapter system.adapter.knx.0 because enabled
    2019-01-25 07:17:36.563 - info: host.Visu-Beelink instance system.adapter.knx.0 started with pid 22190
    2019-01-25 07:17:37.707 - error: host.Visu-Beelink instance system.adapter.knx.0 terminated with code 7 (Adapter already running)
    2019-01-25 07:17:37.707 - info: host.Visu-Beelink Restart adapter system.adapter.knx.0 because enabled
    2019-01-25 07:18:07.741 - info: host.Visu-Beelink instance system.adapter.knx.0 started with pid 22221
    2019-01-25 07:18:08.910 - error: host.Visu-Beelink instance system.adapter.knx.0 terminated with code 7 (Adapter already running)
    2019-01-25 07:18:08.910 - info: host.Visu-Beelink Restart adapter system.adapter.knx.0 because enabled
    2019-01-25 07:18:38.947 - info: host.Visu-Beelink instance system.adapter.knx.0 started with pid 22231
    2019-01-25 07:18:40.219 - error: host.Visu-Beelink instance system.adapter.knx.0 terminated with code 7 (Adapter already running)
    2019-01-25 07:18:40.220 - info: host.Visu-Beelink Restart adapter system.adapter.knx.0 because enabled
    2019-01-25 07:19:10.256 - info: host.Visu-Beelink instance system.adapter.knx.0 started with pid 22261
    2019-01-25 07:19:11.392 - error: host.Visu-Beelink instance system.adapter.knx.0 terminated with code 7 (Adapter already running)
    2019-01-25 07:19:11.393 - info: host.Visu-Beelink Restart adapter system.adapter.knx.0 because enabled
    2019-01-25 07:19:41.428 - info: host.Visu-Beelink instance system.adapter.knx.0 started with pid 22271
    2019-01-25 07:19:42.576 - error: host.Visu-Beelink instance system.adapter.knx.0 terminated with code 7 (Adapter already running)
    2019-01-25 07:19:42.576 - info: host.Visu-Beelink Restart adapter system.adapter.knx.0 because enabled
    2019-01-25 07:20:12.603 - info: host.Visu-Beelink instance system.adapter.knx.0 started with pid 22301
    2019-01-25 07:20:13.739 - error: host.Visu-Beelink instance system.adapter.knx.0 terminated with code 7 (Adapter already running)
    2019-01-25 07:20:13.740 - info: host.Visu-Beelink Restart adapter system.adapter.knx.0 because enabled
    2019-01-25 07:20:43.773 - info: host.Visu-Beelink instance system.adapter.knx.0 started with pid 22311
    2019-01-25 07:20:44.914 - error: host.Visu-Beelink instance system.adapter.knx.0 terminated with code 7 (Adapter already running)
    2019-01-25 07:20:44.914 - info: host.Visu-Beelink Restart adapter system.adapter.knx.0 because enabled
    2019-01-25 07:21:14.949 - info: host.Visu-Beelink instance system.adapter.knx.0 started with pid 22341
    2019-01-25 07:21:16.096 - error: host.Visu-Beelink instance system.adapter.knx.0 terminated with code 7 (Adapter already running)
    2019-01-25 07:21:16.096 - info: host.Visu-Beelink Restart adapter system.adapter.knx.0 because enabled
    2019-01-25 07:21:46.131 - info: host.Visu-Beelink instance system.adapter.knx.0 started with pid 22351
    2019-01-25 07:21:47.275 - error: host.Visu-Beelink instance system.adapter.knx.0 terminated with code 7 (Adapter already running)
    2019-01-25 07:21:47.275 - info: host.Visu-Beelink Restart adapter system.adapter.knx.0 because enabled
    2019-01-25 07:22:17.302 - info: host.Visu-Beelink instance system.adapter.knx.0 started with pid 22363
    2019-01-25 07:22:18.424 - error: host.Visu-Beelink instance system.adapter.knx.0 terminated with code 7 (Adapter already running)
    2019-01-25 07:22:18.425 - info: host.Visu-Beelink Restart adapter system.adapter.knx.0 because enabled
    2019-01-25 07:22:48.458 - info: host.Visu-Beelink instance system.adapter.knx.0 started with pid 22393
    2019-01-25 07:22:49.631 - error: host.Visu-Beelink instance system.adapter.knx.0 terminated with code 7 (Adapter already running)
    2019-01-25 07:22:49.631 - info: host.Visu-Beelink Restart adapter system.adapter.knx.0 because enabled
    2019-01-25 07:23:19.665 - info: host.Visu-Beelink instance system.adapter.knx.0 started with pid 22403
    2019-01-25 07:23:20.802 - error: host.Visu-Beelink instance system.adapter.knx.0 terminated with code 7 (Adapter already running)
    2019-01-25 07:23:20.802 - info: host.Visu-Beelink Restart adapter system.adapter.knx.0 because enabled
    Was kann ich dagegen tun?
    Grüße, Andy
    • GarfonsoG Offline
      GarfonsoG Offline
      Garfonso
      #883
      @sound31:
      Hallo Chefkoch!
      Grüße, Andy ` Da steht "Adapter already running". Vermutlich läuft da noch ein Zombie. Das einfachste dürfte sein den ganzen Rechner mal neuzustarten.
      Gesendet von meinem LYA-L29 mit Tapatalk
      Ultimativer Lovelace Leitfaden: https://forum.iobroker.net/topic/35937/der-ultimative-iobroker-lovelace-leitfaden-dokumentation
      Lovelace UI Beispiele: https://forum.iobroker.net/topic/35950/zeigt-her-eure-lovelace-visualisierung
        sound31
        #884
        Das habe ich versucht -> keine Wirkung.
        Nachdem ich nun den Adapter Deinstalliert habe und Neu Installiert funktioniert das richtig,
        alle Schalter und Status-Objekte werden richtig dargestellt.
        Kleines Problem am Rande - kann den Adapter nicht Einstellen.
        chefkoch009C 1 Antwort Letzte Antwort
        • C Offline
          cadmando
          #885
          ich habe gerade frisch mit IO-Broker begonnen und mir die Version 1.0.19 des KNX-Adapters installiert.
          Der Import meines Projektfiles hat soweit erst einmal gut funktioniert und ich kann alle Schaltzustände und Temperaturen der Objekte sehen und auch protokollieren. Das Funktioniert schon mal super.
          Wo ich auf ein Problem gestoßen bin, von dem ich die Ursache noch nicht gefunden habe, ist das - bisher nur bei einem von drei getesteten - Aktoren, ich den Schaltzustand nicht zuverlässig ändern kann.
          Ich habe bei mir im Keller drei Lampen, zwei kann ich ohne Probleme verändern, eine will manchmal - manchmal nicht.
          Dietmar
          PS: Gibt es eine Möglichkeit Eigenschaften der Objekte im Paket zu verändern - Beispielsweise ob schreib bar? Erscheint mir auf Dauer etwas mühselig.
          • S sound31
            chefkoch009C Offline
            chefkoch009
            #886
            @sound31 führe Mal bitte in deiner Konsole im iobroker installationsverzeichnis folgendes aus: "iobroker u knx".
            Anschließend sollte der konfigurationsdialog korrekt erscheinen Punkt
            Chefkoch009
            • T tombox
              Die GAs die ein Status anzeigen sollte wie die GAs heißen mit denen ein Zustand gesetzt nur mit „ status“ am Ende dann verknüpft der knx Adapter die beiden Adressen automatisch.
              Merlin123M Offline
              Merlin123M Offline
              Merlin123
              schrieb am zuletzt editiert von Merlin123
              #887
              @tombox sagte in KNX Adapter überholt:
              Wie kann ich die manuell sauber verknüpfen? Oder alternativ: Wenn ich die in der ETS umbenenne und das ganze neu einlese: Wird es dann sauber verknüpft?
              Beta-Tester
              • Merlin123M Merlin123
                tombox
                #888
                @Merlin123 ja müssten dann automatisch verknüpft werden
                Merlin123M 1 Antwort Letzte Antwort
                • chefkoch009C Offline
                  chefkoch009
                  #889
                  Hallo @all,
                  willkommen zurück in einem niegelnagelneuem Forum. 👍
                  Ich habe die Version 1.0.20 online gestellt. In dieser wurde ein Bug in der Process-queue beseitigt, welcher für mitunter häufige re-connects gesorgt hat. Weiterhin wurde die upload Routine für knxproj Dateien optimiert.
                  Viel Spass beim Testen.....und schon vielen Dank im Vorraus für euer Feedback.
                  chefkoch009
                  • Merlin123M Offline
                    Merlin123M Offline
                    Merlin123
                    #890
                    Werd ihn heute abend mal installieren. Danke für Deine Arbeit :)
                    Beta-Tester
                      Merlin123M Offline
                      Merlin123
                      #891
                      Installation war problemlos, läuft bisher unauffällig.
                      Beta-Tester
                      • T tombox
                        Merlin123M Offline
                        Merlin123M Offline
                        Merlin123
                        #892
                        So.. Hatte endlich mal Zeit das zu testen. Hab die Status Objekte in der ETS umbenannt, in iobroker die Status Objekte gelöscht und neu importiert.
                        Hat geklappt. Sind sauber verknüpft :)
                        Danke!
                        Beta-Tester
                        • cvidalC Online
                          cvidalC Online
                          cvidal
                          Forum Testing
                          #893
                          Auch hier keine Probleme, hatte ein paar Kleinigkeiten mit der ETS verändert,
                          Projektdatei hochgeladen, wurde auch alles sauber importiert.
                          Gruß Christian
                            axel.rathey
                            #894
                            Hallo Chefkoch,
                            auch bei der 1.0.20 habe ich leider weiterhin Probleme meine KNX-Projekt-Datei einzulesen. Habe die 1.0.20 installiert, dann die KNX-Objekte in eine json Datei gesichert. Dann habe ich mal den Zweig für meine KNX-Außenobjekte gelöscht. Beim Einlesen der knx.proj Datei (nur neuere Objekte) kommt dann kurz eine Meldung "Handling devices finished". Der rollende Wartebalken läuft aber weiter bis in alle Ewigkeit, ich muss dann wieder mit Speichern und schließen abbrechen.
                            Der erhoffte Erstellen des Zweiges mit den Außenobjekten hat nicht geklappt. Habe diese dann aus der json-Datei wiederhergestellt.
                            Alle anderen Teile von iobroker sind soweit aktuell, habe vorher alle Updates eingespielt. Kann ich eventuell dir die proj-Datei mal zukommen lassen, damit du das Einlesen testen kannst?
                            Viele Grüße
                            Axel
                            iobroker, KNX, tradfi, fritzdect, tr-064
                            • E Offline
                              excalibur270
                              #895
                              Hallo. Wie bekomme ich zb die Außentemperatur von HM auf den Bus damit mein glastaster diese anzeigen kann?
                              Adapter läuft knxproj ist eingelesen.
                              Habe es mit blockly versucht. Der datenpunkt wird auch befüllt in knx.0. Aber der taster zeigt nichts an. Gehe ich falsch ran?
                              • E excalibur270
                                tombox
                                #896
                                @excalibur270 zeig mal ein Bild von Dateninhalt und ko im ets
                                E 1 Antwort Letzte Antwort
                                • T tombox
                                  excalibur270
                                  schrieb am zuletzt editiert von excalibur270
                                  #897
                                  @tombox Danke für deine Antwort. Läuft jetzt. Hatte im blockly aktualisiere anstatt steuere angewählt. Schäm.
                                  Edit. Jetzt wieder nicht. Nur einmal die busspannung weg.
                                    adsid
                                    #898
                                    Hallo Zusammen
                                    Bin neu im IO Broker.
                                    Habe die ETS Datei importiert habe es schon hingekriegt das die Lampen ein und ausschalten und ich sie dimmen kann inkl. Rückmeldung.
                                    Soweit so gut. Leider kriege ich die Jalousien nicht hin. Welches Widget muss ich in der Viso nehmen ud welche Werte muss ich vom KNX Adapter verwenden. Jalousien Aktor ist ABB jas 4.230.
                                    Fogende Werte habe ich zur Auswahl:
                                    Habe in den Widgets auch keine Möglichkeit die Lamellenstellung anzuwählen.
                                    Bitte um Hilfe oder einen Ansatz.
                                    Gruss Adsid
                                    • E Offline
                                      excalibur270
                                      #899
                                      Hallo. Ich brauche mal Hilfe. Projekt ist angelegt und eingelesen. Die dp werden auch angelegt. Ich habe bislang nur einen glastaster 2smart von mdt im Einsatz. Damit wollte ich ganz gerne ein paar steuerfunktionen realisieren. Ich habe zb für taste 1 die grp adr angelegt und in meinem Fall mit bodenstrahler benannt. Für die Statusanzeige am Taster eine weitere die da heißt bodenstrahler Status. Ich kann mittlerweile vom Taster aus via blockly die Strahler ansteuern. Nur das mit dem Status will nicht hinhauen.
                                      Ist denn das Projekt richtig Parametriert mit den Adressen bzw namen?
                                      Wo liegt mein Denkfehler.
                                      • L Offline
                                        loverz
                                        #900
                                        Weiß nicht, ob das hier her gehört, aber mir ist aufgefallen, dass umbenannte oder alte Gruppenadressen in ioBroker weiterhin dargestellt werden.
                                        Bei mir hilft nur das Löschen des Adapters und neu einlesen der knxproj-Datei.
                                        Gibt es da vielleicht auch eine sauberere Lösung?
                                          schmid_no1
                                          #901
                                          @loverz GA s die es in deinem knx Projekt jetzt nicht mehr gibt werden nicht automatisch gelöscht entweder die raus suchen die du nicht mehr hast oder alle GA s löschen und projekt neu laden
                                          L 1 Antwort Letzte Antwort
