  4. [Fehler] io.controller wird ständig neu gestartet
21 Beiträge 3 Kommentatoren 6.0k Aufrufe
  • BluefoxB Offline
    BluefoxB Offline
    Couch und Redis sind schon längst raus und werden nicht benötigt.
    Firewall?
    • derAugeD Offline
      derAugeD Offline
      derAuge
      @Bluefox:
      Firewall? `
      Das System ist IP-technisch nicht verändert worden
      • derAugeD Offline
        derAugeD Offline
        derAuge
        Guten Morgen
        habe noch mal versucht der Ursache auf den Grund zu gehen. Leider ohne Erfolg.
        :( Das System ist nicht mehr nutzbar :(
        history-0	2015-03-20 05:55:35	warn	Reconnection to DB.
        admin-0	2015-03-20 05:55:35	warn	Reconnection to DB.
        sonos-0	2015-03-20 05:55:35	warn	Reconnection to DB.
        ping-0	2015-03-20 05:55:35	warn	Reconnection to DB.
        web-0	2015-03-20 05:55:35	warn	Reconnection to DB.
        javascript-0	2015-03-20 05:55:35	warn	Reconnection to DB.
        sayit-0	2015-03-20 05:55:34	warn	Reconnection to DB.
        ping-0	2015-03-20 05:55:34	warn	Reconnection to DB.
        sonos-0	2015-03-20 05:55:34	warn	Reconnection to DB.
        history-0	2015-03-20 05:55:34	warn	Reconnection to DB.
        admin-0	2015-03-20 05:55:34	warn	Reconnection to DB.
        web-0	2015-03-20 05:55:34	warn	Reconnection to DB.
        javascript-0	2015-03-20 05:55:34	warn	Reconnection to DB.
        host-pi2	2015-03-20 05:55:32	info	starting 14 instances
        host-pi2	2015-03-20 05:55:32	info	17 instances found
        host-pi2	2015-03-20 05:55:32	info	InMemoryDB connected
        inMem-objects	2015-03-20 05:55:32	info	listening on port 9001
        inMem-states	2015-03-20 05:55:32	info	listening on port 9000
        host-pi2	2015-03-20 05:55:31	info	ip addresses: 192.168.28.77
        host-pi2	2015-03-20 05:55:31	info	hostname: pi2
        host-pi2	2015-03-20 05:55:31	info	Copyright (c) 2014 bluefox, hobbyquaker
        host-pi2	2015-03-20 05:55:31	info	ioBroker.js-controller version 0.5.15 js-controller starting
        	2015-03-20 05:55:31	info	info
        host-pi2	2015-03-20 05:55:27	info	force terminating
        host-pi2	2015-03-20 05:55:27	info	received SIGTERM
        host-pi2	2015-03-20 05:55:26	info	force terminated after 10s
        host-pi2	2015-03-20 05:55:25	info	received SIGTERM
        host-pi2	2015-03-20 05:55:24	info	received SIGTERM
        host-pi2	2015-03-20 05:55:23	info	received SIGTERM
        host-pi2	2015-03-20 05:55:22	info	received SIGTERM
        host-pi2	2015-03-20 05:55:21	info	received SIGTERM
        host-pi2	2015-03-20 05:55:21	info	instance system.adapter.yr.0 terminated with code 0 (OK)
        host-pi2	2015-03-20 05:55:21	info	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
        admin-0	2015-03-20 05:55:21	error	already running
        	2015-03-20 05:55:19	info	info
        host-pi2	2015-03-20 05:55:19	info	received SIGTERM
        host-pi2	2015-03-20 05:55:18	info	received SIGTERM
        host-pi2	2015-03-20 05:55:17	info	received SIGTERM
        iobroker	2015-03-20 05:55:17	info	exit 0
        iobroker	2015-03-20 05:55:17	info	Starting node restart.js
        yr-0	2015-03-20 05:55:16	info	got weather data from yr.no
        iobroker	2015-03-20 05:55:16	info	_restart
        TypeError:	2015-03-20 05:55:16	error	at Timer.listOnTimeout [as ontimeout] (timers.js:112:15)
        TypeError:	2015-03-20 05:55:16	error	at timer._onTimeout (timers.js:219:16)
        TypeError:	2015-03-20 05:55:16	error	at null. (/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/controller.js:831:17)
        TypeError:	2015-03-20 05:55:16	error	at startInstance (/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/controller.js:913:88)
        TypeError:	2015-03-20 05:55:16	error	Cannot read property '0' of undefined
        uncaught	2015-03-20 05:55:16	error	exception: Cannot read property '0' of undefined
        yr-0	2015-03-20 05:55:15	info	starting. Version 0.1.2 in /mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.yr
        	2015-03-20 05:55:14	info	info
        host-pi2	2015-03-20 05:55:13	info	instance system.adapter.admin.0 started with pid 23540
        host-pi2	2015-03-20 05:55:13	info	Restart adapter system.adapter.javascript.0 because enabled
        host-pi2	2015-03-20 05:55:13	error	instance system.adapter.javascript.0 terminated with code 7 (Adapter already running)
        javascript-0	2015-03-20 05:55:13	error	already running
        	2015-03-20 05:55:11	info	info
        host-pi2	2015-03-20 05:55:12	info	instance system.adapter.yr.0 started with pid 23538
        host-pi2	2015-03-20 05:55:12	info	instance scheduled system.adapter.yr.0 1 * * * *
        host-pi2	2015-03-20 05:55:08	info	instance system.adapter.javascript.0 started with pid 23523
        host-pi2	2015-03-20 05:55:07	info	Restart adapter system.adapter.sayit.0 because enabled
        host-pi2	2015-03-20 05:55:07	error	instance system.adapter.sayit.0 terminated with code 7 (Adapter already running)
        sayit-0	2015-03-20 05:55:06	error	already running
        	2015-03-20 05:55:05	info	info
        host-pi2	2015-03-20 05:55:04	info	Restart adapter system.adapter.sonos.0 because enabled
        host-pi2	2015-03-20 05:55:04	error	instance system.adapter.sonos.0 terminated with code 7 (Adapter already running)
        sonos-0	2015-03-20 05:55:04	error	already running
        	2015-03-20 05:55:01	info	info
        [sonos]	2015-03-20 05:55:01	info	info
        host-pi2	2015-03-20 05:55:04	info	instance system.adapter.sayit.0 started with pid 23517
        host-pi2	2015-03-20 05:55:03	info	instance system.adapter.dwd.0 terminated with code 0 (OK)
        host-pi2	2015-03-20 05:55:00	info	instance system.adapter.sonos.0 started with pid 23511
        host-pi2	2015-03-20 05:54:59	info	Restart adapter system.adapter.ping.0 because enabled
        host-pi2	2015-03-20 05:54:59	error	instance system.adapter.ping.0 terminated with code 7 (Adapter already running)
        ping-0	2015-03-20 05:54:58	error	already running
        dwd-0	2015-03-20 05:54:58	info	setting states
        	2015-03-20 05:54:57	info	info
        dwd-0	2015-03-20 05:54:57	info	getFile Z_CAP_C_EDZW_20150319212320_OMEDES_WWEM59_BORX.xml
        dwd-0	2015-03-20 05:54:56	info	getFile Z_CAP_C_EDZW_20150318233833_OMEDES_WWEM59_BORX.xml
        host-pi2	2015-03-20 05:54:56	info	instance system.adapter.ping.0 started with pid 23496
        dwd-0	2015-03-20 05:54:55	info	starting. Version 0.1.7 in /mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.dwd
        	2015-03-20 05:54:54	info	info
        host-pi2	2015-03-20 05:54:52	info	instance system.adapter.dwd.0 started with pid 23490
        host-pi2	2015-03-20 05:54:52	info	instance scheduled system.adapter.dwd.0 0,30 * * * *
        host-pi2	2015-03-20 05:54:50	info	Restart adapter system.adapter.history.0 because enabled
        host-pi2	2015-03-20 05:54:50	error	instance system.adapter.history.0 terminated with code 7 (Adapter already running)
        history-0	2015-03-20 05:54:50	error	already running
        	2015-03-20 05:54:49	info	info
        host-pi2	2015-03-20 05:54:48	info	instance system.adapter.history.0 started with pid 23484
        host-pi2	2015-03-20 05:54:46	info	Restart adapter system.adapter.web.0 because enabled
        host-pi2	2015-03-20 05:54:46	error	instance system.adapter.web.0 terminated with code 1 ()
        web-0	2015-03-20 05:54:46	error	port 8082 already in use
        web-0	2015-03-20 05:54:46	info	socket.io server listening on port 8082
        web-0	2015-03-20 05:54:44	info	starting. Version 0.2.6 in /mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.web
        host-pi2	2015-03-20 05:54:43	info	Restart adapter system.adapter.admin.0 because enabled
        	2015-03-20 05:54:42	info	info
        host-pi2	2015-03-20 05:54:43	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
        admin-0	2015-03-20 05:54:43	error	already running
        host-pi2	2015-03-20 05:54:40	info	instance system.adapter.web.0 started with pid 23460
        admin-0	2015-03-20 05:54:38	warn	Reconnection to DB.
        history-0	2015-03-20 05:54:38	warn	Reconnection to DB.
        javascript-0	2015-03-20 05:54:37	warn	Reconnection to DB.
        web-0	2015-03-20 05:54:37	warn	Reconnection to DB.
        sayit-0	2015-03-20 05:54:37	warn	Reconnection to DB.
        sonos-0	2015-03-20 05:54:37	warn	Reconnection to DB.
        ping-0	2015-03-20 05:54:37	warn	Reconnection to DB.
        history-0	2015-03-20 05:54:37	warn	Reconnection to DB.
        admin-0	2015-03-20 05:54:37	warn	Reconnection to DB.
        ping-0	2015-03-20 05:54:36	warn	Reconnection to DB.
        sonos-0	2015-03-20 05:54:36	warn	Reconnection to DB.
        sayit-0	2015-03-20 05:54:36	warn	Reconnection to DB.
        history-0	2015-03-20 05:54:36	warn	Reconnection to DB.
        host-pi2	2015-03-20 05:54:36	info	starting 14 instances
        host-pi2	2015-03-20 05:54:36	info	17 instances found
        host-pi2	2015-03-20 05:54:36	info	InMemoryDB connected
        inMem-objects	2015-03-20 05:54:36	info	listening on port 9001
        inMem-states	2015-03-20 05:54:35	info	listening on port 9000
        host-pi2	2015-03-20 05:54:34	info	ip addresses: 192.168.28.77
        host-pi2	2015-03-20 05:54:34	info	hostname: pi2
        host-pi2	2015-03-20 05:54:34	info	Copyright (c) 2014 bluefox, hobbyquaker
        host-pi2	2015-03-20 05:54:34	info	ioBroker.js-controller version 0.5.15 js-controller starting
        	2015-03-20 05:54:34	info	info
        Wenn es keinen Lösungsweg gibt, muss ich die geasmte Installation erneuern und alle Daten und Einstellungen von vorne beginnen.
        Wo kann ich noch unterstützen die Fehlerursache zu finden?
        • BluefoxB Offline
          BluefoxB Offline
          Läuft überhaupt js-contorller?
          ps -A
          Gibt es 9000 und 9001 Ports dabei?
          netstat -n -a
          • derAugeD Offline
            derAugeD Offline
            derAuge
            @Bluefox:
            ps -A
            netstat -n -a
            root@pi2:/mnt/ioBroker/iobroker.Pi2# ps -A |grep io
               10 ?        00:00:00 migration/0
               11 ?        00:00:00 migration/1
               15 ?        00:00:00 migration/2
               19 ?        00:00:00 migration/3
               30 ?        00:00:00 bioset
               33 ?        00:00:00 rpciod
               36 ?        00:00:00 nfsiod
               49 ?        00:00:00 DWC Notificatio
             2551 ?        00:04:27 io.js-controlle
             2573 ?        00:03:05 io.sayit.0
             2588 ?        00:03:04 io.ping.0
             2626 ?        00:07:56 io.admin.0
             2628 ?        00:07:51 io.web.0
             2647 ?        00:06:05 io.history.0
             2672 ?        00:05:42 io.ping.0
             2689 ?        00:03:34 io.sonos.0
             2705 ?        00:03:14 io.sayit.0
             2711 ?        00:07:41 io.javascript.0
             2741 ?        00:00:21 io.hm-rpc.0
             2762 ?        00:00:25 io.hm-rega.0
            23057 ?        00:02:39 io.history.0
            23060 ?        00:00:49 io.ping.0
            23063 ?        00:00:36 io.sonos.0
            23117 ?        00:00:30 io.sayit.0
            root@pi2:/mnt/ioBroker/iobroker.Pi2# netstat -n -a
            Aktive Internetverbindungen (Server und stehende Verbindungen)
            Proto Recv-Q Send-Q Local Address           Foreign Address         State
            tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN
            tcp        0      0 0.0.0.0:57983           0.0.0.0:*               LISTEN
            tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN
            tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN
            tcp        0      0 0.0.0.0:3500            0.0.0.0:*               LISTEN
            tcp        0      0 0.0.0.0:3501            0.0.0.0:*               LISTEN
            tcp        0      0 0.0.0.0:44686           0.0.0.0:*               LISTEN
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN
            tcp        0      0 192.168.28.77:2001      0.0.0.0:*               LISTEN
            tcp        0      0 0.0.0.0:8081            0.0.0.0:*               LISTEN
            tcp        0      0 0.0.0.0:8082            0.0.0.0:*               LISTEN
            tcp        0      0 0.0.0.0:8083            0.0.0.0:*               LISTEN
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN
            tcp        0      0 127.0.0.1:9000          127.0.0.1:37340         TIME_WAIT
            tcp        0      0 127.0.0.1:9001          127.0.0.1:45565         TIME_WAIT
            tcp        0      0 127.0.0.1:9001          127.0.0.1:42253         VERBUNDEN
            tcp        0      0 127.0.0.1:42207         127.0.0.1:9001          VERBUNDEN
            tcp        0      0 127.0.0.1:45601         127.0.0.1:9001          TIME_WAIT
            tcp        0      0 127.0.0.1:45615         127.0.0.1:9001          TIME_WAIT
            tcp        0      0 127.0.0.1:9001          127.0.0.1:45600         TIME_WAIT
            tcp        0      0 127.0.0.1:37288         127.0.0.1:9000          TIME_WAIT
            tcp        0      0 127.0.0.1:9001          127.0.0.1:42257         VERBUNDEN
            tcp        0      0 127.0.0.1:9000          127.0.0.1:37275         TIME_WAIT
            tcp        0      0 127.0.0.1:37323         127.0.0.1:9000          TIME_WAIT
            tcp        0      0 127.0.0.1:9000          127.0.0.1:37289         TIME_WAIT
            tcp        0      0 127.0.0.1:42251         127.0.0.1:9001          VERBUNDEN
            tcp        0      0 127.0.0.1:9001          127.0.0.1:45608         TIME_WAIT
            tcp        0      0 127.0.0.1:9000          127.0.0.1:37281         TIME_WAIT
            tcp        0      0 127.0.0.1:9000          127.0.0.1:37302         TIME_WAIT
            tcp        0      0 127.0.0.1:9000          127.0.0.1:37331         TIME_WAIT
            tcp        0      0 127.0.0.1:9000          127.0.0.1:37283         TIME_WAIT
            tcp        0      0 127.0.0.1:9000          127.0.0.1:37336         TIME_WAIT
            tcp        0      0 127.0.0.1:45566         127.0.0.1:9001          TIME_WAIT
            tcp        0      0 127.0.0.1:9000          127.0.0.1:37322         TIME_WAIT
            tcp        0      0 127.0.0.1:9001          127.0.0.1:45592         TIME_WAIT
            tcp        0      0 192.168.28.77:714       192.168.28.24:2049      VERBUNDEN
            tcp        0      0 127.0.0.1:42213         127.0.0.1:9001          VERBUNDEN
            tcp        0      0 127.0.0.1:9000          127.0.0.1:33936         VERBUNDEN
            tcp        0      0 127.0.0.1:34144         127.0.0.1:9000          VERBUNDEN
            tcp        0      0 127.0.0.1:9000          127.0.0.1:33954         VERBUNDEN
            tcp        0      0 127.0.0.1:9000          127.0.0.1:33946         VERBUNDEN
            tcp        0      0 127.0.0.1:45607         127.0.0.1:9001          TIME_WAIT
            tcp        0      0 127.0.0.1:42255         127.0.0.1:9001          VERBUNDEN
            tcp        0      0 127.0.0.1:45579         127.0.0.1:9001          TIME_WAIT
            tcp        0      0 127.0.0.1:9001          127.0.0.1:45584         TIME_WAIT
            tcp        0      0 127.0.0.1:42253         127.0.0.1:9001          VERBUNDEN
            tcp        0      0 127.0.0.1:9001          127.0.0.1:42209         VERBUNDEN
            tcp        0      0 127.0.0.1:9000          127.0.0.1:33950         VERBUNDEN
            tcp        0      0 127.0.0.1:9001          127.0.0.1:45553         TIME_WAIT
            tcp        0      0 127.0.0.1:9000          127.0.0.1:37293         TIME_WAIT
            tcp        0      0 127.0.0.1:42405         127.0.0.1:9001          VERBUNDEN
            tcp        0      0 127.0.0.1:45591         127.0.0.1:9001          TIME_WAIT
            tcp        0      0 127.0.0.1:9000          127.0.0.1:37344         TIME_WAIT
            tcp        0      0 127.0.0.1:37276         127.0.0.1:9000          TIME_WAIT
            tcp        0      0 127.0.0.1:33956         127.0.0.1:9000          VERBUNDEN
            tcp        0      0 127.0.0.1:9000          127.0.0.1:37330         TIME_WAIT
            tcp        0      0 127.0.0.1:9001          127.0.0.1:42422         VERBUNDEN
            tcp        0      0 127.0.0.1:9001          127.0.0.1:45622         TIME_WAIT
            tcp        0      0 127.0.0.1:9001          127.0.0.1:45606         TIME_WAIT
            tcp        0      0 127.0.0.1:9000          127.0.0.1:37287         TIME_WAIT
            tcp        0      0 127.0.0.1:37337         127.0.0.1:9000          TIME_WAIT
            tcp        0      0 127.0.0.1:33938         127.0.0.1:9000          VERBUNDEN
            tcp        0      0 127.0.0.1:9001          127.0.0.1:45580         TIME_WAIT
            tcp        0      0 127.0.0.1:42215         127.0.0.1:9001          VERBUNDEN
            tcp        0      0 127.0.0.1:9001          127.0.0.1:42213         VERBUNDEN
            tcp        0      0 127.0.0.1:33940         127.0.0.1:9000          VERBUNDEN
            tcp        0      0 127.0.0.1:45623         127.0.0.1:9001          TIME_WAIT
            tcp        0      0 127.0.0.1:33958         127.0.0.1:9000          VERBUNDEN
            tcp        0      0 192.168.28.77:8081      192.168.28.88:49704     VERBUNDEN
            tcp        0      0 127.0.0.1:9001          127.0.0.1:45575         TIME_WAIT
            tcp        0      0 127.0.0.1:9001          127.0.0.1:42405         VERBUNDEN
            tcp        0      0 127.0.0.1:37345         127.0.0.1:9000          TIME_WAIT
            tcp        0      0 127.0.0.1:42422         127.0.0.1:9001          VERBUNDEN
            tcp        0      0 127.0.0.1:37307         127.0.0.1:9000          TIME_WAIT
            tcp        0      0 127.0.0.1:9000          127.0.0.1:34144         VERBUNDEN
            tcp        0      0 127.0.0.1:42245         127.0.0.1:9001          VERBUNDEN
            tcp        0      0 127.0.0.1:9001          127.0.0.1:45561         TIME_WAIT
            tcp        0      0 127.0.0.1:9000          127.0.0.1:33960         VERBUNDEN
            tcp        0      0 127.0.0.1:9001          127.0.0.1:42245         VERBUNDEN
            tcp        0      0 127.0.0.1:45585         127.0.0.1:9001          TIME_WAIT
            tcp        0      0 127.0.0.1:9001          127.0.0.1:45616         TIME_WAIT
            tcp        0      0 127.0.0.1:9001          127.0.0.1:45567         TIME_WAIT
            tcp        0      0 127.0.0.1:42257         127.0.0.1:9001          VERBUNDEN
            tcp        0      0 127.0.0.1:9000          127.0.0.1:37324         TIME_WAIT
            tcp        0      0 127.0.0.1:9000          127.0.0.1:37339         TIME_WAIT
            tcp        0      0 127.0.0.1:33936         127.0.0.1:9000          VERBUNDEN
            tcp        0      0 127.0.0.1:45560         127.0.0.1:9001          TIME_WAIT
            tcp        0      0 127.0.0.1:9000          127.0.0.1:37316         TIME_WAIT
            tcp        0      0 127.0.0.1:33946         127.0.0.1:9000          VERBUNDEN
            tcp        0      0 127.0.0.1:9001          127.0.0.1:45559         TIME_WAIT
            tcp        0      0 127.0.0.1:9000          127.0.0.1:33952         VERBUNDEN
            tcp        0      0 127.0.0.1:33954         127.0.0.1:9000          VERBUNDEN
            tcp        0      0 127.0.0.1:9001          127.0.0.1:45571         TIME_WAIT
            tcp        0      0 127.0.0.1:9001          127.0.0.1:42207         VERBUNDEN
            tcp        0      0 127.0.0.1:45554         127.0.0.1:9001          TIME_WAIT
            tcp        0      0 127.0.0.1:9000          127.0.0.1:37315         TIME_WAIT
            tcp        0      0 127.0.0.1:33944         127.0.0.1:9000          VERBUNDEN
            tcp        0      0 127.0.0.1:9001          127.0.0.1:45624         TIME_WAIT
            tcp        0      0 192.168.28.77:8082      192.168.28.88:49924     VERBUNDEN
            tcp        0      0 127.0.0.1:9001          127.0.0.1:42247         VERBUNDEN
            tcp        0      0 127.0.0.1:9000          127.0.0.1:33948         VERBUNDEN
            tcp        0      0 127.0.0.1:37301         127.0.0.1:9000          TIME_WAIT
            tcp        0      0 127.0.0.1:37295         127.0.0.1:9000          TIME_WAIT
            tcp        0      0 127.0.0.1:9000          127.0.0.1:37332         TIME_WAIT
            tcp        0      0 127.0.0.1:9001          127.0.0.1:45586         TIME_WAIT
            tcp        0      0 127.0.0.1:33960         127.0.0.1:9000          VERBUNDEN
            tcp        0      0 127.0.0.1:9000          127.0.0.1:34130         VERBUNDEN
            tcp        0      0 127.0.0.1:9001          127.0.0.1:42249         VERBUNDEN
            tcp        0      0 127.0.0.1:9000          127.0.0.1:37300         TIME_WAIT
            tcp        0      0 127.0.0.1:9001          127.0.0.1:42215         VERBUNDEN
            tcp        0      0 127.0.0.1:33948         127.0.0.1:9000          VERBUNDEN
            tcp        0      0 127.0.0.1:9001          127.0.0.1:45602         TIME_WAIT
            tcp        0      0 127.0.0.1:9000          127.0.0.1:37338         TIME_WAIT
            tcp        0      0 127.0.0.1:34130         127.0.0.1:9000          VERBUNDEN
            tcp        0      0 127.0.0.1:45572         127.0.0.1:9001          TIME_WAIT
            tcp        0      0 127.0.0.1:42249         127.0.0.1:9001          VERBUNDEN
            tcp        0   4368 192.168.28.77:22        192.168.28.88:49693     VERBUNDEN
            tcp        0      0 127.0.0.1:33942         127.0.0.1:9000          VERBUNDEN
            tcp        0      0 127.0.0.1:9000          127.0.0.1:37277         TIME_WAIT
            tcp        0      0 127.0.0.1:9000          127.0.0.1:37346         TIME_WAIT
            tcp        0      0 127.0.0.1:9001          127.0.0.1:45578         TIME_WAIT
            tcp        0      0 127.0.0.1:9001          127.0.0.1:45614         TIME_WAIT
            tcp        0      0 127.0.0.1:9000          127.0.0.1:37328         TIME_WAIT
            tcp        0      0 127.0.0.1:42209         127.0.0.1:9001          VERBUNDEN
            tcp        0      0 127.0.0.1:37282         127.0.0.1:9000          TIME_WAIT
            tcp        0      0 127.0.0.1:9000          127.0.0.1:33958         VERBUNDEN
            tcp        0      0 127.0.0.1:42243         127.0.0.1:9001          VERBUNDEN
            tcp        0      0 127.0.0.1:42247         127.0.0.1:9001          VERBUNDEN
            tcp        0      0 192.168.28.77:2001      192.168.28.25:47449     VERBUNDEN
            tcp        0      0 127.0.0.1:9000          127.0.0.1:33944         VERBUNDEN
            tcp        0      0 127.0.0.1:9001          127.0.0.1:42243         VERBUNDEN
            tcp        0      0 127.0.0.1:33952         127.0.0.1:9000          VERBUNDEN
            tcp        0      0 127.0.0.1:37329         127.0.0.1:9000          TIME_WAIT
            tcp        0      0 127.0.0.1:9001          127.0.0.1:45628         VERBUNDEN
            tcp        0      0 127.0.0.1:9000          127.0.0.1:37314         TIME_WAIT
            tcp        0      0 127.0.0.1:9001          127.0.0.1:42211         VERBUNDEN
            tcp        0      0 127.0.0.1:9000          127.0.0.1:33938         VERBUNDEN
            tcp        0      0 127.0.0.1:9000          127.0.0.1:37306         TIME_WAIT
            tcp        0      0 127.0.0.1:9000          127.0.0.1:37312         TIME_WAIT
            tcp        0      0 127.0.0.1:9001          127.0.0.1:45590         TIME_WAIT
            tcp        0      0 127.0.0.1:9000          127.0.0.1:33956         VERBUNDEN
            tcp        0      0 127.0.0.1:9001          127.0.0.1:45573         TIME_WAIT
            tcp        0      0 127.0.0.1:9000          127.0.0.1:37308         TIME_WAIT
            tcp        0      0 127.0.0.1:9001          127.0.0.1:42251         VERBUNDEN
            tcp        0      0 127.0.0.1:9000          127.0.0.1:33942         VERBUNDEN
            tcp        0      0 127.0.0.1:9001          127.0.0.1:42255         VERBUNDEN
            tcp        0      0 127.0.0.1:9001          127.0.0.1:45555         TIME_WAIT
            tcp        0      0 192.168.28.77:8081      192.168.28.184:49599    VERBUNDEN
            tcp        0      0 127.0.0.1:33950         127.0.0.1:9000          VERBUNDEN
            tcp        0      0 127.0.0.1:37313         127.0.0.1:9000          TIME_WAIT
            tcp        0      0 127.0.0.1:9000          127.0.0.1:33940         VERBUNDEN
            tcp      307      0 127.0.0.1:45628         127.0.0.1:9001          CLOSE_WAIT
            tcp        0      0 127.0.0.1:42211         127.0.0.1:9001          VERBUNDEN
            tcp        0      0 127.0.0.1:9000          127.0.0.1:37296         TIME_WAIT
            udp        0      0 0.0.0.0:68              0.0.0.0:*
            udp        0      0 0.0.0.0:111             0.0.0.0:*
            udp        0      0 192.168.28.77:123       0.0.0.0:*
            udp        0      0 127.0.0.1:123           0.0.0.0:*
            udp        0      0 0.0.0.0:123             0.0.0.0:*
            udp        0      0 0.0.0.0:700             0.0.0.0:*
            udp        0      0 127.0.0.1:742           0.0.0.0:*
            udp        0      0 0.0.0.0:46353           0.0.0.0:*
            udp        0      0 0.0.0.0:60330           0.0.0.0:*
            udp        0      0 0.0.0.0:44459           0.0.0.0:*
            Aktive Sockets in der UNIX-Domäne (Server und stehende Verbindungen)
            Proto RefCnt Flags       Type       State         I-Node   Pfad
            unix  3      [ ]         DGRAM                    9256     /var/run/wpa_supplicant/wlan0
            unix  2      [ ]         DGRAM                    8533     /var/run/thd.socket
            unix  2      [ ]         DGRAM                    7525     /tmp/wpa_ctrl_1898-1
            unix  2      [ ACC ]     STREAM     HÖRT         6011     /var/run/rpcbind.sock
            unix  2      [ ACC ]     STREAM     HÖRT         8572     /var/run/dbus/system_bus_socket
            unix  7      [ ]         DGRAM                    9393     /dev/log
            unix  2      [ ACC ]     SEQPAKET   HÖRT         4556     /run/udev/control
            unix  2      [ ]         DGRAM                    9412
            unix  3      [ ]         STREAM     VERBUNDEN     9280
            unix  3      [ ]         DGRAM                    5140
            unix  3      [ ]         STREAM     VERBUNDEN     423225
            unix  2      [ ]         STREAM     VERBUNDEN     7630
            unix  2      [ ]         DGRAM                    303550
            unix  3      [ ]         STREAM     VERBUNDEN     424591
            unix  2      [ ]         DGRAM                    303908
            unix  3      [ ]         STREAM     VERBUNDEN     8579
            unix  2      [ ]         DGRAM                    9448
            unix  3      [ ]         STREAM     VERBUNDEN     462460
            unix  3      [ ]         STREAM     VERBUNDEN     9279
            unix  3      [ ]         DGRAM                    5141
            unix  2      [ ]         DGRAM                    245555
            unix  3      [ ]         STREAM     VERBUNDEN     462459
            unix  3      [ ]         STREAM     VERBUNDEN     424590
            unix  3      [ ]         STREAM     VERBUNDEN     8578
            unix  3      [ ]         STREAM     VERBUNDEN     423224
            870_generategas.js
            • BluefoxB Offline
              BluefoxB Offline
              Was sagt "top"? Ich kann nur jetzt RAM vermuten.
              • derAugeD Offline
                derAugeD Offline
                derAuge
                da wir hier nicht wirklich weiter kommen, habe ich mich entschieden das iobroker-System neu aufzusetzen. (Schade)
                habe das "alte" Verzeichniss gesichert.
                Anschließend mit
                root@pi2:/mnt/ioBroker/iobroker.Pi2# npm install iobroker
                neu installiert.
                Den Gedanke die einzelen Adapter nach und nach zurück zu sichern / kopieren habe ich wieder verworfen, da die Konfiguration aller Adapter in einer Datei gespeichert sind. [objects.json] (Oder sehe ich das falsch?) Daher habe ich keine Changse einzelne Adapter mit ihrer Konfiguration zurück zu spielen. (Da sind wir wieder bei dem Thema BACKUP: http://forum.iobroker.org/viewtopic.php … =445#p3164 )
                Frage: Habe ich die Möglichkeit einzelne Adapter mit ihrer Konfiguration zurück zu sichern ?
                Wenn es nicht Möglich ist muss ich wieder von vorne Anfangen und die Adapter installieren und konfigurieren
                EDIT:
                Im Bereich von VIS gibt es die Möglichkeit die Konfiguration zurück zu spielen.
                Nach installation des Adaptern habe ich folgendes zurück kopiert:
                root@pi2:/mnt/ioBroker/iobroker.Pi2# mkdir iobroker-data/files/vis.0
                root@pi2:/mnt/ioBroker/iobroker.Pi2# mkdir iobroker-data/files/vis.0/main
                root@pi2:/mnt/ioBroker/iobroker.Pi2# cp ../iobroker.Pi2.defekt/iobroker-data/files/vis.0/main/* iobroker-data/files/vis.0/main/
                root@pi2:/mnt/ioBroker/iobroker.Pi2# ls -l iobroker-data/files/vis.0/main
                insgesamt 28
                ---------- 1 root root     0 Mär 21 10:17 vis-user.css
                ---------- 1 root root 25244 Mär 21 10:17 vis-views.json
                Somit habe ich eine Menge Arbeit gespart
                • BluefoxB Offline
                  BluefoxB Offline
                  Man kann alles (jeden einzelnen Adapter) importieren. Nun ist es nicht so bequem.
                  Alle Daten liegen in objects.json. Wenn du denn aufmachst und formatierst (z.b. mit notepad++) dann kannst du für jeden Adapter system.adapter.XXX.0 finden. Das ist Konfiguration vom Adapter XXX.
                  Man kann diese information einfach nehmen (common und native getrennt und in admin reinkopieren)
                  • ruhr70R Offline
                    ruhr70R Offline
                    ruhr70
                    @derAuge:
                    seit gestern Abend habe ich eine erhöte CPU-Last
                    filename="ioBrokerCPU-Last.PNG" index="0">~~
                    derAuge `
                    Hi derAuge,
                    womit hast Du denn die Grafik erzeugt?
                    Sieht sehr brauchbar aus.
                    Viele Grüße,
                    Michael
                    • derAugeD Offline
                      derAugeD Offline
                      derAuge
                      @ruhr70:
                      @derAuge:
                      derAuge `
                      Hi derAuge,
                      Viele Grüße,
                      Michael `
                      Schau mal unter : http://rpi-experiences.blogspot.fr/p/rpi-monitor.html
                      derAuge
                      • ruhr70R Offline
                        ruhr70R Offline
                        ruhr70
                        @derAuge:
                        derAuge `
                        Super, ich danke Dir!
                        Das werde ich auf den Raspberrys ausprobieren.
                        In meiner ioBroker installation hilft es mir leider nicht, da diese auf Debian läuft.
                        Aber da wird es mit Sicherheit auch was geben ;-)
                        • BluefoxB Offline
                          BluefoxB Offline
                          @ruhr70:
                          @derAuge:
                          derAuge `
                          Danke :) `
                          Kann jemand das beschreiben, wir nehmen das in Wiki rein. Grafik kann man in vis anbinden.
                          • derAugeD Offline
                            derAugeD Offline
                            derAuge
                            @Bluefox:
                            @ruhr70:
                            @derAuge:
                            derAuge `
                            Danke :) Kann jemand das beschreiben, wir nehmen das in Wiki rein. Grafik kann man in vis anbinden.
                            Ich hatte es nach folgender Anleitung installiert: http://jankarres.de/2013/11/raspberry-p … tallieren/
                            ! Voraussetzung: Raspbian oder vergleichbare Distribution installiert
                            ! Step 1
                            ! Zunächst aktualisieren wir das System, sodass wir sichergehen können, dass alle installierten Pakete aktuell sind.
                            sudo apt-get update && sudo apt-get upgrade
                            Step 2
                            >! Nun installieren wir folgende Pakete, welche von RPI-Monitor benötigt werden.
                            sudo apt-get install dpkg-dev librrds-perl libhttp-daemon-perl libjson-perl libipc-sharelite-perl libfile-which-perl
                            Step 3
                            ! Jetzt ist es an der Zeit, RPI-Monitor herunterzuladen. Im Git Repository des Projekts findet man die aktuellen Debian Packages. Zum Zeitpunkt als dieses Tutorial geschrieben wurde, war Version 2.6-1 aktuell.
                            wget --no-check-certificate https://github.com/XavierBerger/RPi-Monitor-deb/raw/master/packages/rpimonitor_2.6-1_all.deb
                            Step 4
                            >! Wir installieren RPI-Monitor und löschen anschließend die nicht mehr benötigte deb-Datei.
                            sudo dpkg -i rpimonitor_2.6-1_all.deb
                            rm rpimonitor_2.6-1_all.deb
                            Step 5
                            ! RPI-Monitor ist nun im Browser unter http://IP:8888/ (IP ersetzt durch IP-Adresse des Raspberry Pis) aufrufbar. Der Service wurde bereits automatisch im Autostart eingetragen, sodass das Webinterface auch nach einem Neustart des Raspberry Pis wieder verfügbar ist.
                            ! Und das wars schon. Nun hat man übersichtlich den Status des Raspberry Pis im Blick und es werden automatisch Langzeitstatistiken erzeugt.
                            • BluefoxB Offline
                              BluefoxB Offline
                              Super.
                              • BluefoxB Offline
                                BluefoxB Offline
                                @derAuge:
                                ! Step 1
                                Step 2
                                Step 3
                                Step 4
                                Step 5
                                ! Und das wars schon. Nun hat man übersichtlich den Status des Raspberry Pis im Blick und es werden automatisch Langzeitstatistiken erzeugt. `
                                Habe es übernommen. Ist das OK, dass ich dein Bild nutze?
                                https://github.com/ioBroker/ioBroker/wi … stallieren
                                • derAugeD Offline
                                  derAugeD Offline
                                  derAuge
                                  @Bluefox:
                                  @derAuge:
                                  ! Step 1
                                  Step 2
                                  Step 3
                                  Step 4
                                  Step 5
                                  https://github.com/ioBroker/ioBroker/wi … stallieren `
                                  passt
