  4. [Fehler] io.controller wird ständig neu gestartet
21 Beiträge 3 Kommentatoren 6.0k Aufrufe
  • derAugeD Offline
    derAugeD Offline
    derAuge
    @Bluefox:
    Couch und Redis sind schon längst raus und werden nicht benötigt.
    Firewall? `
    Das System ist IP-technisch nicht verändert worden
    • derAugeD Offline
      derAugeD Offline
      derAuge
      Guten Morgen
      habe noch mal versucht der Ursache auf den Grund zu gehen. Leider ohne Erfolg.
      :( Das System ist nicht mehr nutzbar :(
      history-0	2015-03-20 05:55:35	warn	Reconnection to DB.
      admin-0	2015-03-20 05:55:35	warn	Reconnection to DB.
      sonos-0	2015-03-20 05:55:35	warn	Reconnection to DB.
      ping-0	2015-03-20 05:55:35	warn	Reconnection to DB.
      web-0	2015-03-20 05:55:35	warn	Reconnection to DB.
      javascript-0	2015-03-20 05:55:35	warn	Reconnection to DB.
      sayit-0	2015-03-20 05:55:34	warn	Reconnection to DB.
      ping-0	2015-03-20 05:55:34	warn	Reconnection to DB.
      sonos-0	2015-03-20 05:55:34	warn	Reconnection to DB.
      history-0	2015-03-20 05:55:34	warn	Reconnection to DB.
      admin-0	2015-03-20 05:55:34	warn	Reconnection to DB.
      web-0	2015-03-20 05:55:34	warn	Reconnection to DB.
      javascript-0	2015-03-20 05:55:34	warn	Reconnection to DB.
      host-pi2	2015-03-20 05:55:32	info	starting 14 instances
      host-pi2	2015-03-20 05:55:32	info	17 instances found
      host-pi2	2015-03-20 05:55:32	info	InMemoryDB connected
      inMem-objects	2015-03-20 05:55:32	info	listening on port 9001
      inMem-states	2015-03-20 05:55:32	info	listening on port 9000
      host-pi2	2015-03-20 05:55:31	info	ip addresses: 192.168.28.77
      host-pi2	2015-03-20 05:55:31	info	hostname: pi2
      host-pi2	2015-03-20 05:55:31	info	Copyright (c) 2014 bluefox, hobbyquaker
      host-pi2	2015-03-20 05:55:31	info	ioBroker.js-controller version 0.5.15 js-controller starting
      	2015-03-20 05:55:31	info	info
      host-pi2	2015-03-20 05:55:27	info	force terminating
      host-pi2	2015-03-20 05:55:27	info	received SIGTERM
      host-pi2	2015-03-20 05:55:26	info	force terminated after 10s
      host-pi2	2015-03-20 05:55:25	info	received SIGTERM
      host-pi2	2015-03-20 05:55:24	info	received SIGTERM
      host-pi2	2015-03-20 05:55:23	info	received SIGTERM
      host-pi2	2015-03-20 05:55:22	info	received SIGTERM
      host-pi2	2015-03-20 05:55:21	info	received SIGTERM
      host-pi2	2015-03-20 05:55:21	info	instance system.adapter.yr.0 terminated with code 0 (OK)
      host-pi2	2015-03-20 05:55:21	info	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
      admin-0	2015-03-20 05:55:21	error	already running
      	2015-03-20 05:55:19	info	info
      host-pi2	2015-03-20 05:55:19	info	received SIGTERM
      host-pi2	2015-03-20 05:55:18	info	received SIGTERM
      host-pi2	2015-03-20 05:55:17	info	received SIGTERM
      iobroker	2015-03-20 05:55:17	info	exit 0
      iobroker	2015-03-20 05:55:17	info	Starting node restart.js
      yr-0	2015-03-20 05:55:16	info	got weather data from yr.no
      iobroker	2015-03-20 05:55:16	info	_restart
      TypeError:	2015-03-20 05:55:16	error	at Timer.listOnTimeout [as ontimeout] (timers.js:112:15)
      TypeError:	2015-03-20 05:55:16	error	at timer._onTimeout (timers.js:219:16)
      TypeError:	2015-03-20 05:55:16	error	at null. (/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/controller.js:831:17)
      TypeError:	2015-03-20 05:55:16	error	at startInstance (/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/controller.js:913:88)
      TypeError:	2015-03-20 05:55:16	error	Cannot read property '0' of undefined
      uncaught	2015-03-20 05:55:16	error	exception: Cannot read property '0' of undefined
      yr-0	2015-03-20 05:55:15	info	starting. Version 0.1.2 in /mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.yr
      	2015-03-20 05:55:14	info	info
      host-pi2	2015-03-20 05:55:13	info	instance system.adapter.admin.0 started with pid 23540
      host-pi2	2015-03-20 05:55:13	info	Restart adapter system.adapter.javascript.0 because enabled
      host-pi2	2015-03-20 05:55:13	error	instance system.adapter.javascript.0 terminated with code 7 (Adapter already running)
      javascript-0	2015-03-20 05:55:13	error	already running
      	2015-03-20 05:55:11	info	info
      host-pi2	2015-03-20 05:55:12	info	instance system.adapter.yr.0 started with pid 23538
      host-pi2	2015-03-20 05:55:12	info	instance scheduled system.adapter.yr.0 1 * * * *
      host-pi2	2015-03-20 05:55:08	info	instance system.adapter.javascript.0 started with pid 23523
      host-pi2	2015-03-20 05:55:07	info	Restart adapter system.adapter.sayit.0 because enabled
      host-pi2	2015-03-20 05:55:07	error	instance system.adapter.sayit.0 terminated with code 7 (Adapter already running)
      sayit-0	2015-03-20 05:55:06	error	already running
      	2015-03-20 05:55:05	info	info
      host-pi2	2015-03-20 05:55:04	info	Restart adapter system.adapter.sonos.0 because enabled
      host-pi2	2015-03-20 05:55:04	error	instance system.adapter.sonos.0 terminated with code 7 (Adapter already running)
      sonos-0	2015-03-20 05:55:04	error	already running
      	2015-03-20 05:55:01	info	info
      [sonos]	2015-03-20 05:55:01	info	info
      host-pi2	2015-03-20 05:55:04	info	instance system.adapter.sayit.0 started with pid 23517
      host-pi2	2015-03-20 05:55:03	info	instance system.adapter.dwd.0 terminated with code 0 (OK)
      host-pi2	2015-03-20 05:55:00	info	instance system.adapter.sonos.0 started with pid 23511
      host-pi2	2015-03-20 05:54:59	info	Restart adapter system.adapter.ping.0 because enabled
      host-pi2	2015-03-20 05:54:59	error	instance system.adapter.ping.0 terminated with code 7 (Adapter already running)
      ping-0	2015-03-20 05:54:58	error	already running
      dwd-0	2015-03-20 05:54:58	info	setting states
      	2015-03-20 05:54:57	info	info
      dwd-0	2015-03-20 05:54:57	info	getFile Z_CAP_C_EDZW_20150319212320_OMEDES_WWEM59_BORX.xml
      dwd-0	2015-03-20 05:54:56	info	getFile Z_CAP_C_EDZW_20150318233833_OMEDES_WWEM59_BORX.xml
      host-pi2	2015-03-20 05:54:56	info	instance system.adapter.ping.0 started with pid 23496
      dwd-0	2015-03-20 05:54:55	info	starting. Version 0.1.7 in /mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.dwd
      	2015-03-20 05:54:54	info	info
      host-pi2	2015-03-20 05:54:52	info	instance system.adapter.dwd.0 started with pid 23490
      host-pi2	2015-03-20 05:54:52	info	instance scheduled system.adapter.dwd.0 0,30 * * * *
      host-pi2	2015-03-20 05:54:50	info	Restart adapter system.adapter.history.0 because enabled
      host-pi2	2015-03-20 05:54:50	error	instance system.adapter.history.0 terminated with code 7 (Adapter already running)
      history-0	2015-03-20 05:54:50	error	already running
      	2015-03-20 05:54:49	info	info
      host-pi2	2015-03-20 05:54:48	info	instance system.adapter.history.0 started with pid 23484
      host-pi2	2015-03-20 05:54:46	info	Restart adapter system.adapter.web.0 because enabled
      host-pi2	2015-03-20 05:54:46	error	instance system.adapter.web.0 terminated with code 1 ()
      web-0	2015-03-20 05:54:46	error	port 8082 already in use
      web-0	2015-03-20 05:54:46	info	socket.io server listening on port 8082
      web-0	2015-03-20 05:54:44	info	starting. Version 0.2.6 in /mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.web
      host-pi2	2015-03-20 05:54:43	info	Restart adapter system.adapter.admin.0 because enabled
      	2015-03-20 05:54:42	info	info
      host-pi2	2015-03-20 05:54:43	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
      admin-0	2015-03-20 05:54:43	error	already running
      host-pi2	2015-03-20 05:54:40	info	instance system.adapter.web.0 started with pid 23460
      admin-0	2015-03-20 05:54:38	warn	Reconnection to DB.
      history-0	2015-03-20 05:54:38	warn	Reconnection to DB.
      javascript-0	2015-03-20 05:54:37	warn	Reconnection to DB.
      web-0	2015-03-20 05:54:37	warn	Reconnection to DB.
      sayit-0	2015-03-20 05:54:37	warn	Reconnection to DB.
      sonos-0	2015-03-20 05:54:37	warn	Reconnection to DB.
      ping-0	2015-03-20 05:54:37	warn	Reconnection to DB.
      history-0	2015-03-20 05:54:37	warn	Reconnection to DB.
      admin-0	2015-03-20 05:54:37	warn	Reconnection to DB.
      ping-0	2015-03-20 05:54:36	warn	Reconnection to DB.
      sonos-0	2015-03-20 05:54:36	warn	Reconnection to DB.
      sayit-0	2015-03-20 05:54:36	warn	Reconnection to DB.
      history-0	2015-03-20 05:54:36	warn	Reconnection to DB.
      host-pi2	2015-03-20 05:54:36	info	starting 14 instances
      host-pi2	2015-03-20 05:54:36	info	17 instances found
      host-pi2	2015-03-20 05:54:36	info	InMemoryDB connected
      inMem-objects	2015-03-20 05:54:36	info	listening on port 9001
      inMem-states	2015-03-20 05:54:35	info	listening on port 9000
      host-pi2	2015-03-20 05:54:34	info	ip addresses: 192.168.28.77
      host-pi2	2015-03-20 05:54:34	info	hostname: pi2
      host-pi2	2015-03-20 05:54:34	info	Copyright (c) 2014 bluefox, hobbyquaker
      host-pi2	2015-03-20 05:54:34	info	ioBroker.js-controller version 0.5.15 js-controller starting
      	2015-03-20 05:54:34	info	info
      Wenn es keinen Lösungsweg gibt, muss ich die geasmte Installation erneuern und alle Daten und Einstellungen von vorne beginnen.
      Wo kann ich noch unterstützen die Fehlerursache zu finden?
      • BluefoxB Offline
        BluefoxB Offline
        Läuft überhaupt js-contorller?
        ps -A
        Gibt es 9000 und 9001 Ports dabei?
        netstat -n -a
        • derAugeD Offline
          derAugeD Offline
          derAuge
          @Bluefox:
          ps -A
          netstat -n -a
          root@pi2:/mnt/ioBroker/iobroker.Pi2# ps -A |grep io
             10 ?        00:00:00 migration/0
             11 ?        00:00:00 migration/1
             15 ?        00:00:00 migration/2
             19 ?        00:00:00 migration/3
             30 ?        00:00:00 bioset
             33 ?        00:00:00 rpciod
             36 ?        00:00:00 nfsiod
             49 ?        00:00:00 DWC Notificatio
           2551 ?        00:04:27 io.js-controlle
           2573 ?        00:03:05 io.sayit.0
           2588 ?        00:03:04 io.ping.0
           2626 ?        00:07:56 io.admin.0
           2628 ?        00:07:51 io.web.0
           2647 ?        00:06:05 io.history.0
           2672 ?        00:05:42 io.ping.0
           2689 ?        00:03:34 io.sonos.0
           2705 ?        00:03:14 io.sayit.0
           2711 ?        00:07:41 io.javascript.0
           2741 ?        00:00:21 io.hm-rpc.0
           2762 ?        00:00:25 io.hm-rega.0
          23057 ?        00:02:39 io.history.0
          23060 ?        00:00:49 io.ping.0
          23063 ?        00:00:36 io.sonos.0
          23117 ?        00:00:30 io.sayit.0
          root@pi2:/mnt/ioBroker/iobroker.Pi2# netstat -n -a
          Aktive Internetverbindungen (Server und stehende Verbindungen)
          Proto Recv-Q Send-Q Local Address           Foreign Address         State
          tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN
          tcp        0      0 0.0.0.0:57983           0.0.0.0:*               LISTEN
          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN
          tcp        0      0 0.0.0.0:3500            0.0.0.0:*               LISTEN
          tcp        0      0 0.0.0.0:3501            0.0.0.0:*               LISTEN
          tcp        0      0 0.0.0.0:44686           0.0.0.0:*               LISTEN
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN
          tcp        0      0 192.168.28.77:2001      0.0.0.0:*               LISTEN
          tcp        0      0 0.0.0.0:8081            0.0.0.0:*               LISTEN
          tcp        0      0 0.0.0.0:8082            0.0.0.0:*               LISTEN
          tcp        0      0 0.0.0.0:8083            0.0.0.0:*               LISTEN
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN
          tcp        0      0 127.0.0.1:9000          127.0.0.1:37340         TIME_WAIT
          tcp        0      0 127.0.0.1:9001          127.0.0.1:45565         TIME_WAIT
          tcp        0      0 127.0.0.1:9001          127.0.0.1:42253         VERBUNDEN
          tcp        0      0 127.0.0.1:42207         127.0.0.1:9001          VERBUNDEN
          tcp        0      0 127.0.0.1:45601         127.0.0.1:9001          TIME_WAIT
          tcp        0      0 127.0.0.1:45615         127.0.0.1:9001          TIME_WAIT
          tcp        0      0 127.0.0.1:9001          127.0.0.1:45600         TIME_WAIT
          tcp        0      0 127.0.0.1:37288         127.0.0.1:9000          TIME_WAIT
          tcp        0      0 127.0.0.1:9001          127.0.0.1:42257         VERBUNDEN
          tcp        0      0 127.0.0.1:9000          127.0.0.1:37275         TIME_WAIT
          tcp        0      0 127.0.0.1:37323         127.0.0.1:9000          TIME_WAIT
          tcp        0      0 127.0.0.1:9000          127.0.0.1:37289         TIME_WAIT
          tcp        0      0 127.0.0.1:42251         127.0.0.1:9001          VERBUNDEN
          tcp        0      0 127.0.0.1:9001          127.0.0.1:45608         TIME_WAIT
          tcp        0      0 127.0.0.1:9000          127.0.0.1:37281         TIME_WAIT
          tcp        0      0 127.0.0.1:9000          127.0.0.1:37302         TIME_WAIT
          tcp        0      0 127.0.0.1:9000          127.0.0.1:37331         TIME_WAIT
          tcp        0      0 127.0.0.1:9000          127.0.0.1:37283         TIME_WAIT
          tcp        0      0 127.0.0.1:9000          127.0.0.1:37336         TIME_WAIT
          tcp        0      0 127.0.0.1:45566         127.0.0.1:9001          TIME_WAIT
          tcp        0      0 127.0.0.1:9000          127.0.0.1:37322         TIME_WAIT
          tcp        0      0 127.0.0.1:9001          127.0.0.1:45592         TIME_WAIT
          tcp        0      0 192.168.28.77:714       192.168.28.24:2049      VERBUNDEN
          tcp        0      0 127.0.0.1:42213         127.0.0.1:9001          VERBUNDEN
          tcp        0      0 127.0.0.1:9000          127.0.0.1:33936         VERBUNDEN
          tcp        0      0 127.0.0.1:34144         127.0.0.1:9000          VERBUNDEN
          tcp        0      0 127.0.0.1:9000          127.0.0.1:33954         VERBUNDEN
          tcp        0      0 127.0.0.1:9000          127.0.0.1:33946         VERBUNDEN
          tcp        0      0 127.0.0.1:45607         127.0.0.1:9001          TIME_WAIT
          tcp        0      0 127.0.0.1:42255         127.0.0.1:9001          VERBUNDEN
          tcp        0      0 127.0.0.1:45579         127.0.0.1:9001          TIME_WAIT
          tcp        0      0 127.0.0.1:9001          127.0.0.1:45584         TIME_WAIT
          tcp        0      0 127.0.0.1:42253         127.0.0.1:9001          VERBUNDEN
          tcp        0      0 127.0.0.1:9001          127.0.0.1:42209         VERBUNDEN
          tcp        0      0 127.0.0.1:9000          127.0.0.1:33950         VERBUNDEN
          tcp        0      0 127.0.0.1:9001          127.0.0.1:45553         TIME_WAIT
          tcp        0      0 127.0.0.1:9000          127.0.0.1:37293         TIME_WAIT
          tcp        0      0 127.0.0.1:42405         127.0.0.1:9001          VERBUNDEN
          tcp        0      0 127.0.0.1:45591         127.0.0.1:9001          TIME_WAIT
          tcp        0      0 127.0.0.1:9000          127.0.0.1:37344         TIME_WAIT
          tcp        0      0 127.0.0.1:37276         127.0.0.1:9000          TIME_WAIT
          tcp        0      0 127.0.0.1:33956         127.0.0.1:9000          VERBUNDEN
          tcp        0      0 127.0.0.1:9000          127.0.0.1:37330         TIME_WAIT
          tcp        0      0 127.0.0.1:9001          127.0.0.1:42422         VERBUNDEN
          tcp        0      0 127.0.0.1:9001          127.0.0.1:45622         TIME_WAIT
          tcp        0      0 127.0.0.1:9001          127.0.0.1:45606         TIME_WAIT
          tcp        0      0 127.0.0.1:9000          127.0.0.1:37287         TIME_WAIT
          tcp        0      0 127.0.0.1:37337         127.0.0.1:9000          TIME_WAIT
          tcp        0      0 127.0.0.1:33938         127.0.0.1:9000          VERBUNDEN
          tcp        0      0 127.0.0.1:9001          127.0.0.1:45580         TIME_WAIT
          tcp        0      0 127.0.0.1:42215         127.0.0.1:9001          VERBUNDEN
          tcp        0      0 127.0.0.1:9001          127.0.0.1:42213         VERBUNDEN
          tcp        0      0 127.0.0.1:33940         127.0.0.1:9000          VERBUNDEN
          tcp        0      0 127.0.0.1:45623         127.0.0.1:9001          TIME_WAIT
          tcp        0      0 127.0.0.1:33958         127.0.0.1:9000          VERBUNDEN
          tcp        0      0 192.168.28.77:8081      192.168.28.88:49704     VERBUNDEN
          tcp        0      0 127.0.0.1:9001          127.0.0.1:45575         TIME_WAIT
          tcp        0      0 127.0.0.1:9001          127.0.0.1:42405         VERBUNDEN
          tcp        0      0 127.0.0.1:37345         127.0.0.1:9000          TIME_WAIT
          tcp        0      0 127.0.0.1:42422         127.0.0.1:9001          VERBUNDEN
          tcp        0      0 127.0.0.1:37307         127.0.0.1:9000          TIME_WAIT
          tcp        0      0 127.0.0.1:9000          127.0.0.1:34144         VERBUNDEN
          tcp        0      0 127.0.0.1:42245         127.0.0.1:9001          VERBUNDEN
          tcp        0      0 127.0.0.1:9001          127.0.0.1:45561         TIME_WAIT
          tcp        0      0 127.0.0.1:9000          127.0.0.1:33960         VERBUNDEN
          tcp        0      0 127.0.0.1:9001          127.0.0.1:42245         VERBUNDEN
          tcp        0      0 127.0.0.1:45585         127.0.0.1:9001          TIME_WAIT
          tcp        0      0 127.0.0.1:9001          127.0.0.1:45616         TIME_WAIT
          tcp        0      0 127.0.0.1:9001          127.0.0.1:45567         TIME_WAIT
          tcp        0      0 127.0.0.1:42257         127.0.0.1:9001          VERBUNDEN
          tcp        0      0 127.0.0.1:9000          127.0.0.1:37324         TIME_WAIT
          tcp        0      0 127.0.0.1:9000          127.0.0.1:37339         TIME_WAIT
          tcp        0      0 127.0.0.1:33936         127.0.0.1:9000          VERBUNDEN
          tcp        0      0 127.0.0.1:45560         127.0.0.1:9001          TIME_WAIT
          tcp        0      0 127.0.0.1:9000          127.0.0.1:37316         TIME_WAIT
          tcp        0      0 127.0.0.1:33946         127.0.0.1:9000          VERBUNDEN
          tcp        0      0 127.0.0.1:9001          127.0.0.1:45559         TIME_WAIT
          tcp        0      0 127.0.0.1:9000          127.0.0.1:33952         VERBUNDEN
          tcp        0      0 127.0.0.1:33954         127.0.0.1:9000          VERBUNDEN
          tcp        0      0 127.0.0.1:9001          127.0.0.1:45571         TIME_WAIT
          tcp        0      0 127.0.0.1:9001          127.0.0.1:42207         VERBUNDEN
          tcp        0      0 127.0.0.1:45554         127.0.0.1:9001          TIME_WAIT
          tcp        0      0 127.0.0.1:9000          127.0.0.1:37315         TIME_WAIT
          tcp        0      0 127.0.0.1:33944         127.0.0.1:9000          VERBUNDEN
          tcp        0      0 127.0.0.1:9001          127.0.0.1:45624         TIME_WAIT
          tcp        0      0 192.168.28.77:8082      192.168.28.88:49924     VERBUNDEN
          tcp        0      0 127.0.0.1:9001          127.0.0.1:42247         VERBUNDEN
          tcp        0      0 127.0.0.1:9000          127.0.0.1:33948         VERBUNDEN
          tcp        0      0 127.0.0.1:37301         127.0.0.1:9000          TIME_WAIT
          tcp        0      0 127.0.0.1:37295         127.0.0.1:9000          TIME_WAIT
          tcp        0      0 127.0.0.1:9000          127.0.0.1:37332         TIME_WAIT
          tcp        0      0 127.0.0.1:9001          127.0.0.1:45586         TIME_WAIT
          tcp        0      0 127.0.0.1:33960         127.0.0.1:9000          VERBUNDEN
          tcp        0      0 127.0.0.1:9000          127.0.0.1:34130         VERBUNDEN
          tcp        0      0 127.0.0.1:9001          127.0.0.1:42249         VERBUNDEN
          tcp        0      0 127.0.0.1:9000          127.0.0.1:37300         TIME_WAIT
          tcp        0      0 127.0.0.1:9001          127.0.0.1:42215         VERBUNDEN
          tcp        0      0 127.0.0.1:33948         127.0.0.1:9000          VERBUNDEN
          tcp        0      0 127.0.0.1:9001          127.0.0.1:45602         TIME_WAIT
          tcp        0      0 127.0.0.1:9000          127.0.0.1:37338         TIME_WAIT
          tcp        0      0 127.0.0.1:34130         127.0.0.1:9000          VERBUNDEN
          tcp        0      0 127.0.0.1:45572         127.0.0.1:9001          TIME_WAIT
          tcp        0      0 127.0.0.1:42249         127.0.0.1:9001          VERBUNDEN
          tcp        0   4368 192.168.28.77:22        192.168.28.88:49693     VERBUNDEN
          tcp        0      0 127.0.0.1:33942         127.0.0.1:9000          VERBUNDEN
          tcp        0      0 127.0.0.1:9000          127.0.0.1:37277         TIME_WAIT
          tcp        0      0 127.0.0.1:9000          127.0.0.1:37346         TIME_WAIT
          tcp        0      0 127.0.0.1:9001          127.0.0.1:45578         TIME_WAIT
          tcp        0      0 127.0.0.1:9001          127.0.0.1:45614         TIME_WAIT
          tcp        0      0 127.0.0.1:9000          127.0.0.1:37328         TIME_WAIT
          tcp        0      0 127.0.0.1:42209         127.0.0.1:9001          VERBUNDEN
          tcp        0      0 127.0.0.1:37282         127.0.0.1:9000          TIME_WAIT
          tcp        0      0 127.0.0.1:9000          127.0.0.1:33958         VERBUNDEN
          tcp        0      0 127.0.0.1:42243         127.0.0.1:9001          VERBUNDEN
          tcp        0      0 127.0.0.1:42247         127.0.0.1:9001          VERBUNDEN
          tcp        0      0 192.168.28.77:2001      192.168.28.25:47449     VERBUNDEN
          tcp        0      0 127.0.0.1:9000          127.0.0.1:33944         VERBUNDEN
          tcp        0      0 127.0.0.1:9001          127.0.0.1:42243         VERBUNDEN
          tcp        0      0 127.0.0.1:33952         127.0.0.1:9000          VERBUNDEN
          tcp        0      0 127.0.0.1:37329         127.0.0.1:9000          TIME_WAIT
          tcp        0      0 127.0.0.1:9001          127.0.0.1:45628         VERBUNDEN
          tcp        0      0 127.0.0.1:9000          127.0.0.1:37314         TIME_WAIT
          tcp        0      0 127.0.0.1:9001          127.0.0.1:42211         VERBUNDEN
          tcp        0      0 127.0.0.1:9000          127.0.0.1:33938         VERBUNDEN
          tcp        0      0 127.0.0.1:9000          127.0.0.1:37306         TIME_WAIT
          tcp        0      0 127.0.0.1:9000          127.0.0.1:37312         TIME_WAIT
          tcp        0      0 127.0.0.1:9001          127.0.0.1:45590         TIME_WAIT
          tcp        0      0 127.0.0.1:9000          127.0.0.1:33956         VERBUNDEN
          tcp        0      0 127.0.0.1:9001          127.0.0.1:45573         TIME_WAIT
          tcp        0      0 127.0.0.1:9000          127.0.0.1:37308         TIME_WAIT
          tcp        0      0 127.0.0.1:9001          127.0.0.1:42251         VERBUNDEN
          tcp        0      0 127.0.0.1:9000          127.0.0.1:33942         VERBUNDEN
          tcp        0      0 127.0.0.1:9001          127.0.0.1:42255         VERBUNDEN
          tcp        0      0 127.0.0.1:9001          127.0.0.1:45555         TIME_WAIT
          tcp        0      0 192.168.28.77:8081      192.168.28.184:49599    VERBUNDEN
          tcp        0      0 127.0.0.1:33950         127.0.0.1:9000          VERBUNDEN
          tcp        0      0 127.0.0.1:37313         127.0.0.1:9000          TIME_WAIT
          tcp        0      0 127.0.0.1:9000          127.0.0.1:33940         VERBUNDEN
          tcp      307      0 127.0.0.1:45628         127.0.0.1:9001          CLOSE_WAIT
          tcp        0      0 127.0.0.1:42211         127.0.0.1:9001          VERBUNDEN
          tcp        0      0 127.0.0.1:9000          127.0.0.1:37296         TIME_WAIT
          udp        0      0 0.0.0.0:68              0.0.0.0:*
          udp        0      0 0.0.0.0:111             0.0.0.0:*
          udp        0      0 192.168.28.77:123       0.0.0.0:*
          udp        0      0 127.0.0.1:123           0.0.0.0:*
          udp        0      0 0.0.0.0:123             0.0.0.0:*
          udp        0      0 0.0.0.0:700             0.0.0.0:*
          udp        0      0 127.0.0.1:742           0.0.0.0:*
          udp        0      0 0.0.0.0:46353           0.0.0.0:*
          udp        0      0 0.0.0.0:60330           0.0.0.0:*
          udp        0      0 0.0.0.0:44459           0.0.0.0:*
          Aktive Sockets in der UNIX-Domäne (Server und stehende Verbindungen)
          Proto RefCnt Flags       Type       State         I-Node   Pfad
          unix  3      [ ]         DGRAM                    9256     /var/run/wpa_supplicant/wlan0
          unix  2      [ ]         DGRAM                    8533     /var/run/thd.socket
          unix  2      [ ]         DGRAM                    7525     /tmp/wpa_ctrl_1898-1
          unix  2      [ ACC ]     STREAM     HÖRT         6011     /var/run/rpcbind.sock
          unix  2      [ ACC ]     STREAM     HÖRT         8572     /var/run/dbus/system_bus_socket
          unix  7      [ ]         DGRAM                    9393     /dev/log
          unix  2      [ ACC ]     SEQPAKET   HÖRT         4556     /run/udev/control
          unix  2      [ ]         DGRAM                    9412
          unix  3      [ ]         STREAM     VERBUNDEN     9280
          unix  3      [ ]         DGRAM                    5140
          unix  3      [ ]         STREAM     VERBUNDEN     423225
          unix  2      [ ]         STREAM     VERBUNDEN     7630
          unix  2      [ ]         DGRAM                    303550
          unix  3      [ ]         STREAM     VERBUNDEN     424591
          unix  2      [ ]         DGRAM                    303908
          unix  3      [ ]         STREAM     VERBUNDEN     8579
          unix  2      [ ]         DGRAM                    9448
          unix  3      [ ]         STREAM     VERBUNDEN     462460
          unix  3      [ ]         STREAM     VERBUNDEN     9279
          unix  3      [ ]         DGRAM                    5141
          unix  2      [ ]         DGRAM                    245555
          unix  3      [ ]         STREAM     VERBUNDEN     462459
          unix  3      [ ]         STREAM     VERBUNDEN     424590
          unix  3      [ ]         STREAM     VERBUNDEN     8578
          unix  3      [ ]         STREAM     VERBUNDEN     423224
          870_generategas.js
          • BluefoxB Offline
            BluefoxB Offline
            Was sagt "top"? Ich kann nur jetzt RAM vermuten.
            • derAugeD Offline
              derAugeD Offline
              derAuge
              da wir hier nicht wirklich weiter kommen, habe ich mich entschieden das iobroker-System neu aufzusetzen. (Schade)
              habe das "alte" Verzeichniss gesichert.
              Anschließend mit
              root@pi2:/mnt/ioBroker/iobroker.Pi2# npm install iobroker
              neu installiert.
              Den Gedanke die einzelen Adapter nach und nach zurück zu sichern / kopieren habe ich wieder verworfen, da die Konfiguration aller Adapter in einer Datei gespeichert sind. [objects.json] (Oder sehe ich das falsch?) Daher habe ich keine Changse einzelne Adapter mit ihrer Konfiguration zurück zu spielen. (Da sind wir wieder bei dem Thema BACKUP: http://forum.iobroker.org/viewtopic.php … =445#p3164 )
              Frage: Habe ich die Möglichkeit einzelne Adapter mit ihrer Konfiguration zurück zu sichern ?
              Wenn es nicht Möglich ist muss ich wieder von vorne Anfangen und die Adapter installieren und konfigurieren
              EDIT:
              Im Bereich von VIS gibt es die Möglichkeit die Konfiguration zurück zu spielen.
              Nach installation des Adaptern habe ich folgendes zurück kopiert:
              root@pi2:/mnt/ioBroker/iobroker.Pi2# mkdir iobroker-data/files/vis.0
              root@pi2:/mnt/ioBroker/iobroker.Pi2# mkdir iobroker-data/files/vis.0/main
              root@pi2:/mnt/ioBroker/iobroker.Pi2# cp ../iobroker.Pi2.defekt/iobroker-data/files/vis.0/main/* iobroker-data/files/vis.0/main/
              root@pi2:/mnt/ioBroker/iobroker.Pi2# ls -l iobroker-data/files/vis.0/main
              insgesamt 28
              ---------- 1 root root     0 Mär 21 10:17 vis-user.css
              ---------- 1 root root 25244 Mär 21 10:17 vis-views.json
              Somit habe ich eine Menge Arbeit gespart
              • BluefoxB Offline
                BluefoxB Offline
                Man kann alles (jeden einzelnen Adapter) importieren. Nun ist es nicht so bequem.
                Alle Daten liegen in objects.json. Wenn du denn aufmachst und formatierst (z.b. mit notepad++) dann kannst du für jeden Adapter system.adapter.XXX.0 finden. Das ist Konfiguration vom Adapter XXX.
                Man kann diese information einfach nehmen (common und native getrennt und in admin reinkopieren)
                • ruhr70R Offline
                  ruhr70R Offline
                  ruhr70
                  @derAuge:
                  seit gestern Abend habe ich eine erhöte CPU-Last
                  filename="ioBrokerCPU-Last.PNG" index="0">~~
                  derAuge `
                  Hi derAuge,
                  womit hast Du denn die Grafik erzeugt?
                  Sieht sehr brauchbar aus.
                  Viele Grüße,
                  Michael
                  • derAugeD Offline
                    derAugeD Offline
                    derAuge
                    @ruhr70:
                    @derAuge:
                    derAuge `
                    Hi derAuge,
                    Viele Grüße,
                    Michael `
                    Schau mal unter : http://rpi-experiences.blogspot.fr/p/rpi-monitor.html
                    derAuge
                    • ruhr70R Offline
                      ruhr70R Offline
                      ruhr70
                      @derAuge:
                      derAuge `
                      Super, ich danke Dir!
                      Das werde ich auf den Raspberrys ausprobieren.
                      In meiner ioBroker installation hilft es mir leider nicht, da diese auf Debian läuft.
                      Aber da wird es mit Sicherheit auch was geben ;-)
                      • BluefoxB Offline
                        BluefoxB Offline
                        @ruhr70:
                        @derAuge:
                        derAuge `
                        Danke :) `
                        Kann jemand das beschreiben, wir nehmen das in Wiki rein. Grafik kann man in vis anbinden.
                        • derAugeD Offline
                          derAugeD Offline
                          derAuge
                          @Bluefox:
                          @ruhr70:
                          @derAuge:
                          derAuge `
                          Danke :) Kann jemand das beschreiben, wir nehmen das in Wiki rein. Grafik kann man in vis anbinden.
                          Ich hatte es nach folgender Anleitung installiert: http://jankarres.de/2013/11/raspberry-p … tallieren/
                          ! Voraussetzung: Raspbian oder vergleichbare Distribution installiert
                          ! Step 1
                          ! Zunächst aktualisieren wir das System, sodass wir sichergehen können, dass alle installierten Pakete aktuell sind.
                          sudo apt-get update && sudo apt-get upgrade
                          Step 2
                          >! Nun installieren wir folgende Pakete, welche von RPI-Monitor benötigt werden.
                          sudo apt-get install dpkg-dev librrds-perl libhttp-daemon-perl libjson-perl libipc-sharelite-perl libfile-which-perl
                          Step 3
                          ! Jetzt ist es an der Zeit, RPI-Monitor herunterzuladen. Im Git Repository des Projekts findet man die aktuellen Debian Packages. Zum Zeitpunkt als dieses Tutorial geschrieben wurde, war Version 2.6-1 aktuell.
                          wget --no-check-certificate https://github.com/XavierBerger/RPi-Monitor-deb/raw/master/packages/rpimonitor_2.6-1_all.deb
                          Step 4
                          >! Wir installieren RPI-Monitor und löschen anschließend die nicht mehr benötigte deb-Datei.
                          sudo dpkg -i rpimonitor_2.6-1_all.deb
                          rm rpimonitor_2.6-1_all.deb
                          Step 5
                          ! RPI-Monitor ist nun im Browser unter http://IP:8888/ (IP ersetzt durch IP-Adresse des Raspberry Pis) aufrufbar. Der Service wurde bereits automatisch im Autostart eingetragen, sodass das Webinterface auch nach einem Neustart des Raspberry Pis wieder verfügbar ist.
                          ! Und das wars schon. Nun hat man übersichtlich den Status des Raspberry Pis im Blick und es werden automatisch Langzeitstatistiken erzeugt.
                          • BluefoxB Offline
                            BluefoxB Offline
                            Super.
                            • BluefoxB Offline
                              BluefoxB Offline
                              @derAuge:
                              ! Step 1
                              Step 2
                              Step 3
                              Step 4
                              Step 5
                              ! Und das wars schon. Nun hat man übersichtlich den Status des Raspberry Pis im Blick und es werden automatisch Langzeitstatistiken erzeugt. `
                              Habe es übernommen. Ist das OK, dass ich dein Bild nutze?
                              https://github.com/ioBroker/ioBroker/wi … stallieren
                              • derAugeD Offline
                                derAugeD Offline
                                derAuge
                                @Bluefox:
                                @derAuge:
                                ! Step 1
                                Step 2
                                Step 3
                                Step 4
                                Step 5
                                https://github.com/ioBroker/ioBroker/wi … stallieren `
                                passt
