  4. ioBroker.js-controller 1.5.6
testcall for action
150 Beiträge 31 Kommentatoren 32.6k Aufrufe 26 Beobachtet
  • BluefoxB Bluefox
    @lobomau da kann ich leider jetzt nicht helfen. Man muss sauber alles trennen. Da ist was mit der Installation kaputt
    lobomauL Offline
    lobomauL Offline
    lobomau
    @Bluefox sagte in ioBroker.js-controller 1.5.6:
    Ja, alles klar. Danke. Eben snapshot zurück und gut. Neu mache ich irgendwann in Ruhe.
    Host: NUC8i3 mit Proxmox:
    • Slave: Pi4
    • BluefoxB Bluefox
      @sigi234 Welche DasWetter Version hast du?
      kannst du so was probieren ?:
      node C:\ioBroker\node_modules\iobroker.daswetter\main.js --logs
      sigi234S Online
      sigi234S Online
      starting. Version 2.6.1 in C:/ioBroker/node_modules/iobroker.daswetter, node: v8.15.0
      set timeout to 300 sec
      checking data structures
      deleting unused dataset, reset to true
      using new datastructure
      calling forecast 5 days: http://api.daswetter.com/index.php?api_lang=de&localidad=xxxxx&affiliate_id=xxxxxxx=2.05 days forecast done, objects in list 947
      objects in list: 947
      calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=xxxx&affiliate_id=xxxxxx&v=2.0&h=1
      got 148 channels
      RangeError: Maximum call stack size exceeded
          at tryParse (C:\ioBroker\node_modules\socket.io-parser\index.js:336:12)
          at decodeString (C:\ioBroker\node_modules\socket.io-parser\index.js:325:9)
          at Decoder.add (C:\ioBroker\node_modules\socket.io-parser\index.js:237:14)
          at Manager.ondata (C:\ioBroker\node_modules\socket.io-client\lib\manager.js:322:16)
          at Socket.<anonymous> (C:\ioBroker\node_modules\component-bind\index.js:21:15)
          at Socket.Emitter.emit (C:\ioBroker\node_modules\engine.io-client\node_modules\component-emitter\index.js:133:20)
          at Socket.onPacket (C:\ioBroker\node_modules\engine.io-client\lib\socket.js:451:14)
          at WS.<anonymous> (C:\ioBroker\node_modules\engine.io-client\lib\socket.js:268:10)
          at WS.Emitter.emit (C:\ioBroker\node_modules\engine.io-client\node_modules\component-emitter\index.js:133:20)
          at WS.Transport.onPacket (C:\ioBroker\node_modules\engine.io-client\lib\transport.js:145:8)
      hourly forecast done, objects in list 2581
      update already running
      terminating
      • P Offline
        PrinzEisenherz1
        Hi Bluefox, also bei mir kommt folgendes
        oot@ioBroker-VM:~# node /opt/iobroker/node_modules/iobroker.daswetter/main.js --logs
        starting. Version 2.6.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v8.15.0
        set timeout to 80 sec
        calling forecast 7 days: http://api.daswetter.com/index.php?api_lang=de&localidad=100557&affiliate_id=1h42khm1qqjz
        7 days forecast done, objects in list 107
        objects in list: 107
        calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=100557&affiliate_id=1h42khm1qqjz&v=2.0&h=1
        got 150 channels
        got 2875 states
        hourly forecast done, objects in list 1699
        nothing to do
        exit, all done
        root@ioBroker-VM:~#
        Ich hab die Version 2.6.1
        Intel-NUC mit ProxMox: ioBroker,SQL, logging Strom- Gas- u. Wasserzähler;10Zoll Tab im Flur für VIS; weiteres: Homematic CCU2, Homeduino, Kameras, selbstgebaute Wetterstation;
        BluefoxB 1 Antwort Letzte Antwort
        • coyoteC coyote
          Nach neustart alles gut.
          repetier.0	2019-02-13 21:05:24.548	info	starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.repetier, node: v8.12.0
          host.debian	2019-02-13 21:05:24.013	info	instance system.adapter.repetier.0 started with pid 31337
          host.debian	2019-02-13 21:05:21.150	info	instance system.adapter.repetier.0 terminated with code 0 (OK)
          host.debian	2019-02-13 21:05:18.227	info	instance scheduled system.adapter.daswetter.0 */15 * * * *
          repetier.0	2019-02-13 21:05:16.608	info	starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.repetier, node: v8.12.0
          host.debian	2019-02-13 21:05:16.013	info	instance system.adapter.repetier.0 started with pid 31323
          host.debian	2019-02-13 21:05:15.722	warn	stopInstance system.adapter.daswetter.0 not scheduled
          host.debian	2019-02-13 21:05:15.722	info	stopInstance system.adapter.daswetter.0
          host.debian	2019-02-13 21:05:15.721	info	object change system.adapter.daswetter.0
          Schätze, dass der Fehler erst nach dem ersten Schedule kommt
          sigi234S Online
          sigi234S Online
          @coyote sagte in ioBroker.js-controller 1.5.6:
          Kann ich bestätigen.
          coyoteC 1 Antwort Letzte Antwort
          • P PrinzEisenherz1
            got 150 channels
            got 2875 states
            nothing to do
            exit, all done
            root@ioBroker-VM:~#
            BluefoxB Offline
            BluefoxB Offline
            @PrinzEisenherz1 Hier ist alles OK.
            • simatecS simatec
              Bei einer Iobroker Installation mit neuen Installer ist auf die korrekte Rechtevergabe zu achten.
              Der Befehl
              npm i iobroker.js-controller@1.5.6
              kann nicht einfach als anderer User ausgeführt werden, da sonst der User iobroker nicht alle Recht hat.
              #66
              @simatec Nach Rücksprache mit @AlCalzone ist das nicht ganz korrek t- zumindestens nicht mit den Installern seit 20.1. glaube ich.
              Dafpr ind die Default ACLs da die vom Instller gesetzt werden
              Dann gehören die Dateien zwar dem aktuellen user, iobroker behält trotzdem die Berechtigungen
              simatecS 2 Antworten Letzte Antwort
              • apollon77A apollon77
                simatecS Offline
                simatecS Offline
                simatec
                #67
                @apollon77
                OK dann teste ich das noch einmal mit einer neu aufgesetzten Installation.
                Meine aktuelle mit den manuellen Patch, den ich dann als PR für den Installer gepusht hatte, ging es nicht.
                Aber ich werde das nochmal reproduzieren und berichten 😉
                • Besuche meine Github Seite
                • HowTo Restore ioBroker
                • sigi234S sigi234
                  coyoteC Offline
                  coyoteC Offline
                  coyote
                  #68
                  @sigi234 sagte in ioBroker.js-controller 1.5.6:
                  Also bei mir alles ok, kein Fehler im Log von DasWetter. Sind ja jetzt schon mehrere Zyklen durchgelaufen ohne Probleme....
                  • coyoteC coyote
                    sigi234S Online
                    sigi234S Online
                    #69
                    Hm........... da wären deine Einstellungen vom Adapter interessant.
                    • sigi234S Online
                      sigi234S Online
                      #70
                      Ich habe folgendes Verhalten beobachtet:
                      Beim laden wird immer auf 127.0.0.1 gefiltert, wenn ich das Rote X Drücke geht es.
                      • coyoteC Offline
                        coyoteC Offline
                        coyote
                        #71
                        Ist nur "neue Datenstruktur" angewählt, Pfad 1-4 ausgefüllt, 60Sek Zeitlimit und Iconset 6
                        Das war's auch schon
                        • coyoteC coyote
                          sigi234S Online
                          sigi234S Online
                          #72
                          Aha, ich habe nur Pfad 2+3 drinnen.
                          • coyoteC Offline
                            coyoteC Offline
                            coyote
                            schrieb am zuletzt editiert von coyote
                            #73
                            Hm ok, hab 1 und 4 mal raus genommen und schedule auf 2 min, mal sehen ob ein Fehler kommt.
                            Edit: Alles gut, kein Fehler 🤷
                            • coyoteC coyote
                              sigi234S Online
                              sigi234S Online
                              #74
                              @coyote
                              daswetter.0	2019-02-14 00:02:01.516	error	RangeError: Maximum call stack size exceeded at tryParse (C:\ioBroker\node_modules\socket.io-parser\index.js:336:12) at decodeString (C:\ioBroker\node_modules\socket.io-parser\index.js:325:9)
                              daswetter.0	2019-02-14 00:02:01.516	error	uncaught exception: Maximum call stack size exceeded
                              • coyoteC Offline
                                coyoteC Offline
                                coyote
                                #75
                                Zur Info:
                                Socket.io 2.1.1
                                npm 6.4.1
                                nodejs 8.12.0
                                Also hab ich nur eine andere nodejs Version
                                • cvidalC Online
                                  cvidalC Online
                                  cvidal
                                  Forum Testing
                                  #76
                                  Seit 1.5.6 wird bei mir auch gefiltert, entweder steht da mal meine Email Adresse oder ne 2323...
                                  Kann mir das überhaupt nicht erklären...
                                  Holger76H sigi234S 2 Antworten Letzte Antwort
                                  • Homer.J.H Offline
                                    Homer.J.H Offline
                                    Homer.J.
                                    #77
                                    Morgen,
                                    2019-02-14 05:15:03.312 - error: daswetter.0 uncaught exception: Maximum call stack size exceeded
                                    2019-02-14 05:15:03.313 - error: daswetter.0 RangeError: Maximum call stack size exceeded
                                    • sigi234S sigi234
                                      BluefoxB Offline
                                      BluefoxB Offline
                                      #78
                                      @sigi234 hat nichts mit js-controller zu tun.
                                      • Homer.J.H Homer.J.
                                        Morgen,
                                        BluefoxB Offline
                                        BluefoxB Offline
                                        #79
                                        @Homer1976 hat jemand meine git Version ausprobiert?
                                        Homer.J.H 1 Antwort Letzte Antwort
                                        • MatzebhvM Offline
                                          MatzebhvM Offline
                                          Matzebhv
                                          #80
                                          Moin,
                                          nachdem die 1.5.6 bei mir ja nicht lief und ich wieder zurück auf die 1.4.2 bin habe ich mir ( scheinbar ) wieder ein altes Problem mit Cron eingefangen. Mein Weckerscript wirft bei Cron und Astro einen Fehler:
                                          javascript.0	2019-02-14 08:24:57.808	error	at ContextifyScript.Script.runInContext (vm.js:59:29)
                                          javascript.0	2019-02-14 08:24:57.808	error	at script.js.Funktionen.Wecker:10:1
                                          javascript.0	2019-02-14 08:24:57.808	error	TypeError: schedule is not a function
                                          javascript.0	2019-02-14 08:24:57.808	error	^
                                          javascript.0	2019-02-14 08:24:57.808	error	schedule("30 30 6 * * 1-5", function () {
                                          javascript.0	2019-02-14 08:24:57.808	error	script.js.Funktionen.Wecker: script.js.Funktionen.Wecker:10
                                          javascript.0	2019-02-14 08:27:24.979	error	at ContextifyScript.Script.runInContext (vm.js:59:29)
                                          javascript.0	2019-02-14 08:27:24.979	error	at script.js.Funktionen.Wecker:22:1
                                          javascript.0	2019-02-14 08:27:24.979	error	TypeError: schedule is not a function
                                          javascript.0	2019-02-14 08:27:24.979	error	^
                                          javascript.0	2019-02-14 08:27:24.979	error	schedule({astro: "sunriseEnd", shift: 0}, function () {
                                          javascript.0	2019-02-14 08:27:24.979	error	script.js.Funktionen.Wecker: script.js.Funktionen.Wecker:22
                                          Konnte das noch jemand beobachten?
                                          Matze
                                          BluefoxB BBTownB 2 Antworten Letzte Antwort
