  4. [gelöst] Fehler - HM-RPC läuft plötzlich nicht mehr
40 Beiträge 3 Kommentatoren 2.3k Aufrufe
    skorpil
    Hier die Versionen….
      skorpil
      Node -v
      8.15.0
      • foxriver76F Offline
        foxriver76F Offline
        foxriver76
        Node passt. Ist das Logfile oben mit Rega 2.1.6 entstanden?
        Videotutorials & mehr
          skorpil
          Ja
            foxriver76F Offline
            foxriver76
            Hm okay, damit lässt sich leider nix anfangen, in der Zeile steht ne normal Zuweisung. :|
              skorpil
               host.raspberrypi	2019-01-21 14:33:05.669	info	Restart adapter system.adapter.hm-rega.0 because enabled
              host.raspberrypi	2019-01-21 14:33:05.669	error	instance system.adapter.hm-rega.0 terminated with code 1 ()
              host.raspberrypi	2019-01-21 14:33:05.669	error	Caught by controller[0]: at bootstrap_node.js:625:3
              host.raspberrypi	2019-01-21 14:33:05.669	error	Caught by controller[0]: at startup (bootstrap_node.js:204:16)
              host.raspberrypi	2019-01-21 14:33:05.669	error	Caught by controller[0]: at Function.Module.runMain (module.js:694:10)
              host.raspberrypi	2019-01-21 14:33:05.668	error	Caught by controller[0]: at Function.Module._load (module.js:498:3)
              host.raspberrypi	2019-01-21 14:33:05.668	error	Caught by controller[0]: at tryModuleLoad (module.js:506:12)
              host.raspberrypi	2019-01-21 14:33:05.668	error	Caught by controller[0]: at Module.load (module.js:566:32)
              host.raspberrypi	2019-01-21 14:33:05.668	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
              host.raspberrypi	2019-01-21 14:33:05.668	error	Caught by controller[0]: at Module._compile (module.js:617:28)
              host.raspberrypi	2019-01-21 14:33:05.668	error	Caught by controller[0]: at Object.runInThisContext (vm.js:139:10)
              host.raspberrypi	2019-01-21 14:33:05.668	error	Caught by controller[0]: at createScript (vm.js:80:10)
              host.raspberrypi	2019-01-21 14:33:05.668	error	Caught by controller[0]: SyntaxError: Invalid or unexpected token
              host.raspberrypi	2019-01-21 14:33:05.667	error	Caught by controller[0]:
              host.raspberrypi	2019-01-21 14:33:05.667	error	Caught by controller[0]: ����{`��k�LU�����C�a)���t2���d�ݕ�C�H�=J�l��F�s��E�`<��W��7^�A,sNp:0ˬ�B�>����\�S��m&�6�,�;�O�K���y7����˚��_{�S#���!�ل���l�@@�Dz�|�~��RQ�y�P�'�㜜.V�����
              host.raspberrypi	2019-01-21 14:33:05.667	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.hm-rega/hm-rega.js:258
              host.raspberrypi	2019-01-21 14:33:05.334	info	instance system.adapter.hm-rega.0 started with pid 1932
              host.raspberrypi	2019-01-21 14:32:35.331	info	Restart adapter system.adapter.hm-rega.0 because enabled
              host.raspberrypi	2019-01-21 14:32:35.331	error	instance system.adapter.hm-rega.0 terminated with code 1 ()
              host.raspberrypi	2019-01-21 14:32:35.330	error	Caught by controller[0]: at bootstrap_node.js:625:3
              host.raspberrypi	2019-01-21 14:32:35.330	error	Caught by controller[0]: at startup (bootstrap_node.js:204:16)
              host.raspberrypi	2019-01-21 14:32:35.330	error	Caught by controller[0]: at Function.Module.runMain (module.js:694:10)
              host.raspberrypi	2019-01-21 14:32:35.330	error	Caught by controller[0]: at Function.Module._load (module.js:498:3)
              host.raspberrypi	2019-01-21 14:32:35.330	error	Caught by controller[0]: at tryModuleLoad (module.js:506:12)
              host.raspberrypi	2019-01-21 14:32:35.330	error	Caught by controller[0]: at Module.load (module.js:566:32)
              host.raspberrypi	2019-01-21 14:32:35.330	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
              host.raspberrypi	2019-01-21 14:32:35.329	error	Caught by controller[0]: at Module._compile (module.js:617:28)
              host.raspberrypi	2019-01-21 14:32:35.329	error	Caught by controller[0]: at Object.runInThisContext (vm.js:139:10)
              host.raspberrypi	2019-01-21 14:32:35.329	error	Caught by controller[0]: at createScript (vm.js:80:10)
              host.raspberrypi	2019-01-21 14:32:35.329	error	Caught by controller[0]: SyntaxError: Invalid or unexpected token
              host.raspberrypi	2019-01-21 14:32:35.328	error	Caught by controller[0]: ����{`��k�LU�����C�a)���t2���d�ݕ�C�H�=J�l��F�s��E�`<��W��7^�A,sNp:0ˬ�B�>����\�S��m&�6�,�;�O�K���y7����˚��_{�S#���!�ل���l�@@�Dz�|�~��RQ�y�P�'�㜜.V�����
              host.raspberrypi	2019-01-21 14:32:35.322	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.hm-rega/hm-rega.js:258
              host.raspberrypi	2019-01-21 14:32:34.991	info	instance system.adapter.hm-rega.0 started with pid 1926
              Hier noch einmal ganz aktuell
                skorpil
                Normale Zuweisung? Verstehe ich nicht.
                Was musst Du wissen, um helfen zu können? Ich liefere…
                • paul53P Offline
                  Ich tippe auf eine sich verabschiedende SD Card.
                    skorpil
                    Daran hatte ich auch schon gedacht. Kann ich das unter Linux irgendwie testen? Unter Win gibt es ja chkdsk…
                      foxriver76F Offline
                      foxriver76
                      @paul53:
                      Ich tippe auf eine sich verabschiedende SD Card. `
                      An ein korruptes File System habe ich auch schon gedacht. Allerdings kenne ich mich da leider nicht aus.
                      @skorpil:
                      Was musst Du wissen, um helfen zu können? Ich liefere… `
                      Hier scheint der Fehler seinen Urpsrung zu haben: https://github.com/ioBroker/ioBroker.hm … ga.js#L258 und das macht für mich keinen Sinn
                      • paul53P Offline
                        @skorpil:
                        Kann ich das unter Linux irgendwie testen? `
                        Da kenne ich mich leider auch nicht aus.
                        Ich würde die Datei /opt/iobroker/node_modules/iobroker.hm-rega/hm-rega.js mit WinSCP auf den PC kopieren, mit Notepad++ öffnen und das Umfeld von Zeile 258 ansehen.
                          skorpil
                          So, jetzt der Hammer: auch das Backup macht den gleichen Fehler.
                          ! host.raspberrypi 2019-01-21 15:04:11.670 info Restart adapter system.adapter.hm-rpc.0 because enabled
                          ! host.raspberrypi 2019-01-21 15:04:11.669 error instance system.adapter.hm-rpc.0 terminated with code 1 ()
                          ! host.raspberrypi 2019-01-21 15:04:11.669 error Caught by controller[0]: at bootstrap_node.js:625:3
                          ! host.raspberrypi 2019-01-21 15:04:11.669 error Caught by controller[0]: at startup (bootstrap_node.js:204:16)
                          ! host.raspberrypi 2019-01-21 15:04:11.669 error Caught by controller[0]: at Function.Module.runMain (module.js:694:10)
                          ! host.raspberrypi 2019-01-21 15:04:11.669 error Caught by controller[0]: at Function.Module._load (module.js:498:3)
                          ! host.raspberrypi 2019-01-21 15:04:11.669 error Caught by controller[0]: at tryModuleLoad (module.js:506:12)
                          ! host.raspberrypi 2019-01-21 15:04:11.669 error Caught by controller[0]: at Module.load (module.js:566:32)
                          ! host.raspberrypi 2019-01-21 15:04:11.668 error Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
                          ! host.raspberrypi 2019-01-21 15:04:11.668 error Caught by controller[0]: at Module._compile (module.js:653:30)
                          ! host.raspberrypi 2019-01-21 15:04:11.668 error Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.hm-rpc/hm-rpc.js:1634:5)
                          ! host.raspberrypi 2019-01-21 15:04:11.668 error Caught by controller[0]: at startAdapter (/opt/iobroker/node_modules/iobroker.hm-rpc/hm-rpc.js:606:15)
                          ! host.raspberrypi 2019-01-21 15:04:11.668 error Caught by controller[0]: TypeError: utils.Adapter is not a constructor
                          ! host.raspberrypi 2019-01-21 15:04:11.667 error Caught by controller[0]: ^
                          ! host.raspberrypi 2019-01-21 15:04:11.667 error Caught by controller[0]: adapter = new utils.Adapter(options);
                          ! host.raspberrypi 2019-01-21 15:04:11.664 error Caught by controller[0]: /opt/iobroker/node_modules/iobroker.hm-rpc/hm-rpc.js:606
                          ! host.raspberrypi 2019-01-21 15:04:11.305 info instance system.adapter.hm-rpc.0 started with pid 1408</anonymous>
                          Ich verstehe gerade die Welt nicht mehr…
                          • paul53P Offline
                            @skorpil:
                            auch das Backup macht den gleichen Fehler. `
                            hm-rpc ist nicht hm-rega.
                              skorpil
                              Das stimmt.
                              Also, zur Klarheit: RPC läuft nicht. Warum ich eben und auch im Titel über rega gesprochen habe… ich bin verwirrt. Sorry
                                skorpil
                                ich habe unter windows und virtual dub noch eine iobroker Installation, die ich gelegentlich zum Testen nutze. Die habe ich gerade gestartet. Und, hier läuft die rpc Instanz. Damit kann ich nun mindestens ausschließen, dass das Problem nicht in der CCU liegt
                                • paul53P Offline
                                  @skorpil:
                                  Warum ich eben und auch im Titel über rega gesprochen habe… ich bin verwirrt. `
                                  Weil die Fehlermeldung sich auf die Datei /opt/iobroker/node_modules/iobroker.hm-rega/hm-rega.js bezog.@skorpil:
                                    foxriver76F Offline
                                    foxriver76
                                    Jetzt ist es ja hm-rpc. Installier den mal neu.
                                      skorpil
                                      so, jetzt kann ich mindestens das Missverständnis aufklären (ich dachte schon, ich spinne):
                                      • in der aktuellen Version funktioniert REGA nicht
                                      • im backup läuft RPC nicht
                                      Ich verzweifele
                                        skorpil
                                        @foxriver
                                        den mal neu heißt löschen und neu installieren???????
                                          foxriver76F Offline
                                          foxriver76
                                          Sorry Post gerade war auf Rega bezogen deshalb gelöscht.
                                          Mach mal````
                                          npm i iobroker.rpc --production --prefix /opt/iobroker/
