  4. [gelöst] Fehler - HM-RPC läuft plötzlich nicht mehr
    6.0k
    1.5k
40 Beiträge 3 Kommentatoren 1.6k Aufrufe
    skorpil
    wie im Betreff beschrieben: plötzlich läuft die rega nicht mehr und ich habe keine Idee, warum! Fehlermeldung aus dem log hier:
    ! host.raspberrypi 2019-01-21 13:08:28.462 info Restart adapter system.adapter.hm-rega.0 because enabled
    ! host.raspberrypi 2019-01-21 13:08:28.462 error instance system.adapter.hm-rega.0 terminated with code 1 ()
    ! host.raspberrypi 2019-01-21 13:08:28.462 error Caught by controller[0]: at bootstrap_node.js:625:3
    ! host.raspberrypi 2019-01-21 13:08:28.461 error Caught by controller[0]: at startup (bootstrap_node.js:204:16)
    ! host.raspberrypi 2019-01-21 13:08:28.461 error Caught by controller[0]: at Function.Module.runMain (module.js:694:10)
    ! host.raspberrypi 2019-01-21 13:08:28.461 error Caught by controller[0]: at Function.Module._load (module.js:498:3)
    ! host.raspberrypi 2019-01-21 13:08:28.461 error Caught by controller[0]: at tryModuleLoad (module.js:506:12)
    ! host.raspberrypi 2019-01-21 13:08:28.461 error Caught by controller[0]: at Module.load (module.js:566:32)
    ! host.raspberrypi 2019-01-21 13:08:28.461 error Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
    ! host.raspberrypi 2019-01-21 13:08:28.460 error Caught by controller[0]: at Module.compile (module.js:617:28)
    ! host.raspberrypi 2019-01-21 13:08:28.460 error Caught by controller[0]: at Object.runInThisContext (vm.js:139:10)
    ! host.raspberrypi 2019-01-21 13:08:28.460 error Caught by controller[0]: at createScript (vm.js:80:10)
    ! host.raspberrypi 2019-01-21 13:08:28.460 error Caught by controller[0]: SyntaxError: Invalid or unexpected token
    ! host.raspberrypi 2019-01-21 13:08:28.459 error Caught by controller[0]: ����{��k�LU�����C�a)���t2���d�ݕ�C�H�=J�l��F�s��E�<��W��7^�A,sNp:0ˬ�B�>����\�S��m&�6�,�;�O�K���y7����˚��
    {�S#���!�ل���l�@@�Dz�|�~��RQ�y�P�'�㜜.V�����
    ! host.raspberrypi 2019-01-21 13:08:28.456 error Caught by controller[0]: /opt/iobroker/node_modules/iobroker.hm-rega/hm-rega.js:258
    ! host.raspberrypi 2019-01-21 13:08:28.109 info instance system.adapter.hm-rega.0 started with pid 4044
    Kann das jemand interpretieren und mir sagen, was da los ist?
    • foxriver76F Offline
      foxriver76F Offline
      foxriver76
      Hat du kürzlich geupdated? Bzw korreliert das Auftreten des Fehlers mit dem Zeitpunkt eines Updates?
      Videotutorials & mehr
        skorpil
        Nein, keine Updates
          foxriver76F Offline
          foxriver76
          Und welche Version von hm-Rega ist installiert?
            skorpil
            Installiert ist die 2.1.6
            Inzwischen habe ich schon einiges probiert: auf die o.g. Version geupdated. Vorher war eine etwas ältere Version. Auch Rpc habe ich aktualisiert. Alles ohne Erfolg. Dann habe ich Node,js aktualisiert, die CCU neu gestartet. Dem Raspi ein Update und Upgrade verpasst. Den Raspi neu gestartet. Alles erfolglos.
            Ich habe noch ein Backup. Das werde ich gleich mal einspielen und schauen, was passiert. Das ist sehr merkwürdig…
              skorpil
              Was mich irritiert, sinddie Fehlermeldungen, mit denen ich nichts anfangen kann…
                foxriver76F Offline
                foxriver76
                Bei deinem log oben sagt er auf jeden Fall es kommt von Rega Zeile 258, jedoch bringt mir das nix ohne Versionsnummer.
                  foxriver76F Offline
                  foxriver76
                  Und welche Version von Node hast du drauf?
                    skorpil
                    Hier die Versionen….
                      skorpil
                      Node -v
                      8.15.0
                        foxriver76F Offline
                        foxriver76
                        Node passt. Ist das Logfile oben mit Rega 2.1.6 entstanden?
                          skorpil
                          Ja
                            foxriver76F Offline
                            foxriver76
                            Hm okay, damit lässt sich leider nix anfangen, in der Zeile steht ne normal Zuweisung. :|
                              skorpil
                               host.raspberrypi	2019-01-21 14:33:05.669	info	Restart adapter system.adapter.hm-rega.0 because enabled
                              host.raspberrypi	2019-01-21 14:33:05.669	error	instance system.adapter.hm-rega.0 terminated with code 1 ()
                              host.raspberrypi	2019-01-21 14:33:05.669	error	Caught by controller[0]: at bootstrap_node.js:625:3
                              host.raspberrypi	2019-01-21 14:33:05.669	error	Caught by controller[0]: at startup (bootstrap_node.js:204:16)
                              host.raspberrypi	2019-01-21 14:33:05.669	error	Caught by controller[0]: at Function.Module.runMain (module.js:694:10)
                              host.raspberrypi	2019-01-21 14:33:05.668	error	Caught by controller[0]: at Function.Module._load (module.js:498:3)
                              host.raspberrypi	2019-01-21 14:33:05.668	error	Caught by controller[0]: at tryModuleLoad (module.js:506:12)
                              host.raspberrypi	2019-01-21 14:33:05.668	error	Caught by controller[0]: at Module.load (module.js:566:32)
                              host.raspberrypi	2019-01-21 14:33:05.668	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
                              host.raspberrypi	2019-01-21 14:33:05.668	error	Caught by controller[0]: at Module._compile (module.js:617:28)
                              host.raspberrypi	2019-01-21 14:33:05.668	error	Caught by controller[0]: at Object.runInThisContext (vm.js:139:10)
                              host.raspberrypi	2019-01-21 14:33:05.668	error	Caught by controller[0]: at createScript (vm.js:80:10)
                              host.raspberrypi	2019-01-21 14:33:05.668	error	Caught by controller[0]: SyntaxError: Invalid or unexpected token
                              host.raspberrypi	2019-01-21 14:33:05.667	error	Caught by controller[0]:
                              host.raspberrypi	2019-01-21 14:33:05.667	error	Caught by controller[0]: ����{`��k�LU�����C�a)���t2���d�ݕ�C�H�=J�l��F�s��E�`<��W��7^�A,sNp:0ˬ�B�>����\�S��m&�6�,�;�O�K���y7����˚��_{�S#���!�ل���l�@@�Dz�|�~��RQ�y�P�'�㜜.V�����
                              host.raspberrypi	2019-01-21 14:33:05.667	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.hm-rega/hm-rega.js:258
                              host.raspberrypi	2019-01-21 14:33:05.334	info	instance system.adapter.hm-rega.0 started with pid 1932
                              host.raspberrypi	2019-01-21 14:32:35.331	info	Restart adapter system.adapter.hm-rega.0 because enabled
                              host.raspberrypi	2019-01-21 14:32:35.331	error	instance system.adapter.hm-rega.0 terminated with code 1 ()
                              host.raspberrypi	2019-01-21 14:32:35.330	error	Caught by controller[0]: at bootstrap_node.js:625:3
                              host.raspberrypi	2019-01-21 14:32:35.330	error	Caught by controller[0]: at startup (bootstrap_node.js:204:16)
                              host.raspberrypi	2019-01-21 14:32:35.330	error	Caught by controller[0]: at Function.Module.runMain (module.js:694:10)
                              host.raspberrypi	2019-01-21 14:32:35.330	error	Caught by controller[0]: at Function.Module._load (module.js:498:3)
                              host.raspberrypi	2019-01-21 14:32:35.330	error	Caught by controller[0]: at tryModuleLoad (module.js:506:12)
                              host.raspberrypi	2019-01-21 14:32:35.330	error	Caught by controller[0]: at Module.load (module.js:566:32)
                              host.raspberrypi	2019-01-21 14:32:35.330	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
                              host.raspberrypi	2019-01-21 14:32:35.329	error	Caught by controller[0]: at Module._compile (module.js:617:28)
                              host.raspberrypi	2019-01-21 14:32:35.329	error	Caught by controller[0]: at Object.runInThisContext (vm.js:139:10)
                              host.raspberrypi	2019-01-21 14:32:35.329	error	Caught by controller[0]: at createScript (vm.js:80:10)
                              host.raspberrypi	2019-01-21 14:32:35.329	error	Caught by controller[0]: SyntaxError: Invalid or unexpected token
                              host.raspberrypi	2019-01-21 14:32:35.328	error	Caught by controller[0]: ����{`��k�LU�����C�a)���t2���d�ݕ�C�H�=J�l��F�s��E�`<��W��7^�A,sNp:0ˬ�B�>����\�S��m&�6�,�;�O�K���y7����˚��_{�S#���!�ل���l�@@�Dz�|�~��RQ�y�P�'�㜜.V�����
                              host.raspberrypi	2019-01-21 14:32:35.322	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.hm-rega/hm-rega.js:258
                              host.raspberrypi	2019-01-21 14:32:34.991	info	instance system.adapter.hm-rega.0 started with pid 1926
                              Hier noch einmal ganz aktuell
                                skorpil
                                Normale Zuweisung? Verstehe ich nicht.
                                Was musst Du wissen, um helfen zu können? Ich liefere…
                                • paul53P Offline
                                  Ich tippe auf eine sich verabschiedende SD Card.
                                    skorpil
                                    Daran hatte ich auch schon gedacht. Kann ich das unter Linux irgendwie testen? Unter Win gibt es ja chkdsk…
                                      foxriver76F Offline
                                      foxriver76
                                      @paul53:
                                      Ich tippe auf eine sich verabschiedende SD Card. `
                                      An ein korruptes File System habe ich auch schon gedacht. Allerdings kenne ich mich da leider nicht aus.
                                      @skorpil:
                                      Was musst Du wissen, um helfen zu können? Ich liefere… `
                                      Hier scheint der Fehler seinen Urpsrung zu haben: https://github.com/ioBroker/ioBroker.hm … ga.js#L258 und das macht für mich keinen Sinn
                                      • paul53P Offline
                                        @skorpil:
                                        Kann ich das unter Linux irgendwie testen? `
                                        Da kenne ich mich leider auch nicht aus.
                                        Ich würde die Datei /opt/iobroker/node_modules/iobroker.hm-rega/hm-rega.js mit WinSCP auf den PC kopieren, mit Notepad++ öffnen und das Umfeld von Zeile 258 ansehen.
                                          skorpil
                                          So, jetzt der Hammer: auch das Backup macht den gleichen Fehler.
                                          ! host.raspberrypi 2019-01-21 15:04:11.670 info Restart adapter system.adapter.hm-rpc.0 because enabled
                                          ! host.raspberrypi 2019-01-21 15:04:11.669 error instance system.adapter.hm-rpc.0 terminated with code 1 ()
                                          ! host.raspberrypi 2019-01-21 15:04:11.669 error Caught by controller[0]: at bootstrap_node.js:625:3
                                          ! host.raspberrypi 2019-01-21 15:04:11.669 error Caught by controller[0]: at startup (bootstrap_node.js:204:16)
                                          ! host.raspberrypi 2019-01-21 15:04:11.669 error Caught by controller[0]: at Function.Module.runMain (module.js:694:10)
                                          ! host.raspberrypi 2019-01-21 15:04:11.669 error Caught by controller[0]: at Function.Module._load (module.js:498:3)
                                          ! host.raspberrypi 2019-01-21 15:04:11.669 error Caught by controller[0]: at tryModuleLoad (module.js:506:12)
                                          ! host.raspberrypi 2019-01-21 15:04:11.669 error Caught by controller[0]: at Module.load (module.js:566:32)
                                          ! host.raspberrypi 2019-01-21 15:04:11.668 error Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
                                          ! host.raspberrypi 2019-01-21 15:04:11.668 error Caught by controller[0]: at Module._compile (module.js:653:30)
                                          ! host.raspberrypi 2019-01-21 15:04:11.668 error Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.hm-rpc/hm-rpc.js:1634:5)
                                          ! host.raspberrypi 2019-01-21 15:04:11.668 error Caught by controller[0]: at startAdapter (/opt/iobroker/node_modules/iobroker.hm-rpc/hm-rpc.js:606:15)
                                          ! host.raspberrypi 2019-01-21 15:04:11.668 error Caught by controller[0]: TypeError: utils.Adapter is not a constructor
                                          ! host.raspberrypi 2019-01-21 15:04:11.667 error Caught by controller[0]: ^
                                          ! host.raspberrypi 2019-01-21 15:04:11.667 error Caught by controller[0]: adapter = new utils.Adapter(options);
                                          ! host.raspberrypi 2019-01-21 15:04:11.664 error Caught by controller[0]: /opt/iobroker/node_modules/iobroker.hm-rpc/hm-rpc.js:606
                                          ! host.raspberrypi 2019-01-21 15:04:11.305 info instance system.adapter.hm-rpc.0 started with pid 1408</anonymous>
                                          Ich verstehe gerade die Welt nicht mehr…
                                          82.7k
