  4. Kleines Problem große Auswirkung
    6.5k
31 Beiträge 6 Kommentatoren 2.4k Aufrufe
    Austriacus
    In dieser Reihenfolge wurden einige Dateien downgeloaded und installiert.
    Lieder funktioniert die Adapter-Installation noch immer nicht
    Hier das Protokoll von
    apt-get update
    apt-get upgrade
    vielleicht kann jemand etwas rauslesen?
    root@tinkerboard:/# apt-get update
    Hit:1 http://security.debian.org stretch/updates InRelease
    Hit:4 https://deb.nodesource.com/node_10.x stretch InRelease
    Ign:3 http://cdn-fastly.deb.debian.org/debian stretch InRelease
    Hit:5 http://cdn-fastly.deb.debian.org/debian stretch-updates InRelease
    Hit:6 https://www.pivccu.de/piVCCU stable InRelease
    Hit:7 http://cdn-fastly.deb.debian.org/debian stretch-backports InRelease
    Hit:8 http://cdn-fastly.deb.debian.org/debian stretch Release
    Hit:2 https://apt.armbian.com stretch InRelease
    Reading package lists… Done
    root@tinkerboard:/# apt-get upgrade
    Building dependency tree
    Calculating upgrade... Done
    The following package was automatically installed and is no longer required:
    libuv1
    Use 'apt autoremove' to remove it.
    The following packages will be upgraded:
    libssl1.0.2 nodejs pivccu-modules-dkms pivccu3
    4 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    Need to get 117 MB of archives.
    After this operation, 25.6 kB of additional disk space will be used.
    Do you want to continue? [Y/n] Y
    Get:1 http://security.debian.org stretch/updates/main armhf libssl1.0.2 armhf 1.0.2q-1~deb9u1 [922 kB]
    Get:2 https://deb.nodesource.com/node_10.x stretch/main armhf nodejs armhf 10.15.0-1nodesource1 [13.5 MB]
    Get:3 https://www.pivccu.de/piVCCU stable/main armhf pivccu-modules-dkms all 1.0.20 [24.1 kB]
    Get:4 https://www.pivccu.de/piVCCU stable/main armhf pivccu3 armhf 3.41.11-14 [103 MB]
    Fetched 117 MB in 18s (6,185 kB/s)
    Preconfiguring packages …
    (Reading database ... 76533 files and directories currently installed.)
    Preparing to unpack .../pivccu-modules-dkms_1.0.20_all.deb ...
    Removed /etc/systemd/system/multi-user.target.wants/pivccu-dkms.service.
    -------- Uninstall Beginning --------
    Module: pivccu
    Version: 1.0.18
    Kernel: 4.14.81-rockchip (armv7l)
    Status: Before uninstall, this module version was ACTIVE on this kernel.
    dummy_rx8130.ko:
    • Uninstallation
    • Deleting from: /lib/modules/4.14.81-rockchip/updates/dkms/
    • Original module
    • No original module was found for this module on this kernel.
    • Use the dkms install command to reinstall any previous module version.
    dw_apb_raw_uart.ko:
    • Uninstallation
    • Original module
    eq3_char_loop.ko:
    • Uninstallation
    • Original module
    fake_hmrf.ko:
    • Uninstallation
    • Original module
    generic_raw_uart.ko:
    • Uninstallation
    • Original module
    led_trigger_timer.ko:
    • Uninstallation
    • Original module
    meson_raw_uart.ko:
    • Uninstallation
    • Original module
    pl011_raw_uart.ko:
    • Uninstallation
    • Original module
    plat_eq3ccu2.ko:
    • Uninstallation
    • Original module
    rpi_rf_mod_led.ko:
    • Uninstallation
    • Original module
    depmod...
    DKMS: uninstall completed.
    Deleting module version: 1.0.18
    completely from the DKMS tree.
    Done.
    Unpacking pivccu-modules-dkms (1.0.20) over (1.0.18) ...
    Preparing to unpack .../pivccu3_3.41.11-14_armhf.deb ...
    Removed /etc/systemd/system/multi-user.target.wants/pivccu.service.
    Unpacking pivccu3 (3.41.11-14) over (3.41.11-12) ...
    Preparing to unpack .../libssl1.0.2_1.0.2q-1~deb9u1_armhf.deb ...
    Unpacking libssl1.0.2:armhf (1.0.2q-1~deb9u1) over (1.0.2l-2+deb9u3) ...
    Preparing to unpack .../nodejs_10.15.0-1nodesource1_armhf.deb ...
    Detected old npm client, removing...
    Unpacking nodejs (10.15.0-1nodesource1) over (10.14.2-1nodesource1) ...
    Setting up nodejs (10.15.0-1nodesource1) ...
    Setting up libssl1.0.2:armhf (1.0.2q-1~deb9u1) ...
    Processing triggers for libc-bin (2.24-11+deb9u3) ...
    Setting up pivccu-modules-dkms (1.0.20) ...
    Loading new pivccu-1.0.20 DKMS files...
    Building for 4.14.81-rockchip
    Building initial module for 4.14.81-rockchip
    Done.
    dummy_rx8130:
    Running module version sanity check.
    • Original module
    • No original module exists within this kernel
    • Installation
    • Installing to /lib/modules/4.14.81-rockchip/updates/dkms/
    dw_apb_raw_uart.ko:
    • Original module
    • Installation
    eq3_char_loop.ko:
    • Original module
    • Installation
    fake_hmrf.ko:
    • Original module
    • Installation
    • Original module
    • Installation
    hb_rf_usb.ko:
    • Original module
    • Installation
    • Original module
    • Installation
    meson_raw_uart.ko:
    • Original module
    • Installation
    pl011_raw_uart.ko:
    • Original module
    • Installation
    plat_eq3ccu2.ko:
    • Original module
    • Installation
    rpi_rf_mod_led.ko:
    • Original module
    • Installation
    depmod...
    DKMS: install completed.
    Created symlink /etc/systemd/system/multi-user.target.wants/pivccu-dkms.service → /lib/systemd/system/pivccu-dkms.service.
    Processing triggers for man-db (2.7.6.1-2) ...
    Setting up pivccu3 (3.41.11-14) ...
    Installing new version of config file /etc/piVCCU3/lxc.config ...
    Created symlink /etc/systemd/system/multi-user.target.wants/pivccu.service → /lib/systemd/system/pivccu.service.
    piVCCU: DTB rk3288-tinker.dtb was already patched
      Austriacus
      Hier ist auch noch eine Fehlermeldung die nach dem Stop von ioBroker ausgegeben wurde
      root@tinkerboard:/# sudo iobroker stop
      Stopping iobroker controller daemon…
      iobroker controller daemon stopped.
      fs.js:115
      throw err;
      Error: ENOENT: no such file or directory, chmod '/opt/iobroker/node_modules/iobroker.js-controller/lib/../killall.sh'
      at Object.chmodSync (fs.js:1023:3)
      at Daemon.daemon.on (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:286:32)
      at Daemon.emit (events.js:187:15)
      at Daemon. <anonymous>(/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:267:14)
      at Daemon._tryKill (/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:277:23)
      at ontimeout (timers.js:436:11)
      at tryOnTimeout (timers.js:300:5)
      at listOnTimeout (timers.js:263:5)
      at Timer.processTimers (timers.js:223:10)</anonymous>
      • R Offline
        Rogni
        Sieht für mich aus als wäre da ein node.js fehler.
        Abrr da sollte noch mal jemand anderes drüberkucken. Bin noch nicht richtig fit was linux betrifft.
        Erik :mrgreen: :mrgreen:
        • MatzebhvM Offline
          MatzebhvM Offline
          Matzebhv
          Von wem hast du das Board denn bekommen? Und viel wichtiger: hast du da Geld für abgelatzt?
          Matze
            Austriacus
            Wär ja mein Geld!
            Das ist aber nicht das Problem. Das Ding hat ja anstandslos funktioniert, bis ich es mit dem Abbruch einer Adapterinstallation und möglicherweise Änderung der IP Adresse "zerschossen" habe.
            Ich kann und will niemanden einen Vorwurf machen. War mein Fehler.
            Wenn Du davon etwas verstehst wäre mir mit einem Lösungsansatz mehr geholfen, als solche Fragen zu stellen.
              Austriacus
              Hier ist übrigens noch eine Fehlermeldung die beim ioBroker Update ausgegeben wird.
              Ähnelt sehr der Fehlermeldung bei der Adapterinstallation.
              root@tinkerboard:/opt/iobroker# sudo iobroker update
              Used repository: default
              update done
              Cannot read or parse /opt/iobroker/node_modules/iobroker.js-controller/lib/../node_modules/iobro ker.hm-rpc/io-package.json: SyntaxError: Unexpected end of JSON input
              Danach folgt noch eine unauffällige Liste von Adaptern
              • MatzebhvM Offline
                MatzebhvM Offline
                Matzebhv
                Hey,
                war mir schon fast klar, das war natürlich dein Geld.
                Hier wäre aber eigentlich die erste Anlaufstelle derjenige, der dir das Ding verkauft hat.
                Da dein System eh noch nicht wirklich konfiguriert war, ich würde es platt machen und neu installieren.
                Matze
                  Ich hab leider noch keine Antwort wie der Installationsversuch abgebrochen wurde.
                  Einfach mit strom raus?
                  Dann besteht hoffnung im Unglück.
                  Dann hat es die Installation zerschossen und mit eu em drüberinstallieren des gesamten ioBroker könnte es gerettet werden können.
                    Austriacus
                    Der ist leider heute nicht erreichbar, und es wird nicht das letzte Mal sein, dass ich hier im Forum etwas frage; also hab ich es mal probiert.
                    Ich habe da allerdings etwas gefunden was vielleicht hilft:
                    Inhalt des Ordners /opt/iobroker löschen und dann darin wieder npm install iobroker ausführen
                    Wenn ich das richtig verstehe wird dabei nur der ioBroker neu installiert.
                    Bevor ich das starte, stelle ich die Frage ob man dabei irgendwelche Konfigurationsdaten eingeben muss; wenn ja welche?
                      Austriacus
                      @Homoran
                      Ich habe die Adapterinstallation gestartet und die ist mit Erfolg durchgelaufen.
                      Danach kommt das Fenster für die Konfiguration wo man u.a. die IP Adresse der CCU eingeben muss.
                      Hier habe ich abgebrochen und die Server mit fixen IP Adressen versorgt. Danach das Tinkerborad neu gestartet und ioBroker mit der neuen IP wieder aufgerufen. Da keine Instanz von HM RPC angelegt wurde habe ich die Adapterinstallation neu gestartet mit dem Resultat der eingangs erwähnten Fehlermeldung.
                        Also nix abgebrochen!
                        Nur nicht konfiguriert.
                        Das kann so etwas nicht verursachen.
                        Dann besteht die Gefahr, dass die sd karte einen schuss hat.
                        Leg die zur srite, nimm eine neue und mach alkes neu.
                          Austriacus
                          Ja, das wird das Beste sein
                          • MatzebhvM Offline
                            MatzebhvM Offline
                            Matzebhv
                            @Austriacus:
                            Bevor ich das starte, stelle ich die Frage ob man dabei irgendwelche Konfigurationsdaten eingeben muss; wenn ja welche? `
                            Danach ist das Ding "nakisch". Derzeit ist doch aber anscheinend eh nix konfiguriert, oder?
                            Natürlich kannst du jederzeit hier fragen, ich finde aber immer schräg: es verkaufen anscheinend Leute iOBroker-Geräte und verdienen Geld mit fremden Federn. Gibt es dann Probleme wird auf kostenlose Hilfe im Forum gehofft.
                            Wenn du neu installieren willst: http://www.iobroker.net/docu/?page_id=8323&lang=de
                            Matze
                              Meine allererste Frage was der TE genau hat ist auch nicht beantwortet worden.
                              @TE:
                              Ich habe heute mein Tinkerboard mit ioBroker und CCU3 bekommen und wollte nach Anleitung den Homematic Adapter verbinden. `
                              Es handelt sich ja nicht nur um ein ioBroker Tinker, da soll auch noch eine CCU3 (in welcher Form auch immer) drauf sein.
                              Da muss natürlich noch mehr installiert werden.
