  4. Kein autostart debian stretch
83 Beiträge 19 Kommentatoren 28.5k Aufrufe
  • VumerV
    VumerV
    Vumer
    @paul53:
    Bitte damit neu installieren (und berichten).
    cd /opt/iobroker
    sudo npm install iobroker --unsafe-perm
    sudo reboot
    hat wahrscheinlich nichts mit dem eigentlichen Fehler zu tun, aber bekkome beim Update einen Fehler
    ! root@sekret:~# cd /opt/iobroker
    ! root@sekret:/opt/iobroker# sudo npm install iobroker –unsafe-perm
    ! npm ERR! not a package /opt/iobroker/iobroker
    ! npm ERR! addLocal Could not install /opt/iobroker/iobroker
    ! npm ERR! Linux 4.9.68-v7+
    ! npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker" "--unsafe-perm"
    ! npm ERR! node v6.12.2
    ! npm ERR! npm v3.10.10
    ! npm ERR! path /tmp/npm-905-252b49b2/unpack-4f9a642e/package.json
    ! npm ERR! code ENOENT
    ! npm ERR! errno -2
    ! npm ERR! syscall open
    ! npm ERR! enoent ENOENT: no such file or directory, open '/tmp/npm-905-252b49b2/unpack-4f9a642e/package.json'
    ! npm ERR! enoent This is most likely not a problem with npm itself
    ! npm ERR! enoent and is related to npm not being able to find a file.
    ! npm ERR! enoent
    ! npm ERR! Please include the following file with any support request:
    ! npm ERR! /opt/iobroker/npm-debug.log
    npm-debug.log
    ! 0 info it worked if it ends with ok
    ! 1 verbose cli [ '/usr/bin/node',
    ! 1 verbose cli '/usr/bin/npm',
    ! 1 verbose cli 'install',
    ! 1 verbose cli 'iobroker',
    ! 1 verbose cli '–unsafe-perm' ]
    ! 2 info using npm@3.10.10
    ! 3 info using node@v6.12.2
    ! 4 silly loadCurrentTree Starting
    ! 5 silly install loadCurrentTree
    ! 6 silly install readLocalPackageData
    ! 7 silly fetchPackageMetaData iobroker
    ! 8 silly fetchOtherPackageData iobroker
    ! 9 silly cache add args [ 'iobroker', null ]
    ! 10 verbose cache add spec iobroker
    ! 11 silly cache add parsed spec Result {
    ! 11 silly cache add raw: 'iobroker',
    ! 11 silly cache add scope: null,
    ! 11 silly cache add escapedName: 'iobroker',
    ! 11 silly cache add name: null,
    ! 11 silly cache add rawSpec: 'iobroker',
    ! 11 silly cache add spec: '/opt/iobroker/iobroker',
    ! 11 silly cache add type: 'local' }
    ! 12 silly addLocalTarball shasum (computed) 172d89ea6df6ab508c7b69dc0540b583db07e40c
    ! 13 verbose addTmpTarball /opt/iobroker/iobroker not in flight; adding
    ! 14 verbose correctMkdir /root/.npm correctMkdir not in flight; initializing
    ! 15 verbose addTmpTarball validating metadata from /opt/iobroker/iobroker
    ! 16 verbose tar unpack /opt/iobroker/iobroker
    ! 17 verbose tar unpacking to /tmp/npm-905-252b49b2/unpack-4f9a642e
    ! 18 silly gentlyRm /tmp/npm-905-252b49b2/unpack-4f9a642e is being purged
    ! 19 verbose gentlyRm don't care about contents; nuking /tmp/npm-905-252b49b2/unpack-4f9a642e
    ! 20 silly gunzTarPerm modes [ '755', '644' ]
    ! 21 error not a package /opt/iobroker/iobroker
    ! 22 error addLocal Could not install /opt/iobroker/iobroker
    ! 23 silly fetchPackageMetaData Error: ENOENT: no such file or directory, open '/tmp/npm-905-252b49b2/unpack-4f9a642e/package.json'
    ! 23 silly fetchPackageMetaData at Error (native)
    ! 23 silly fetchPackageMetaData error for iobroker { Error: ENOENT: no such file or directory, open '/tmp/npm-905-252b49b2/unpack-4f9a642e/package.json'
    ! 23 silly fetchPackageMetaData errno: -2,
    ! 23 silly fetchPackageMetaData code: 'ENOENT',
    ! 23 silly fetchPackageMetaData syscall: 'open',
    ! 23 silly fetchPackageMetaData path: '/tmp/npm-905-252b49b2/unpack-4f9a642e/package.json' }
    ! 24 silly rollbackFailedOptional Starting
    ! 25 silly rollbackFailedOptional Finishing
    ! 26 silly runTopLevelLifecycles Finishing
    ! 27 silly install printInstalled
    ! 28 verbose stack Error: ENOENT: no such file or directory, open '/tmp/npm-905-252b49b2/unpack-4f9a642e/package.json'
    ! 28 verbose stack at Error (native)
    ! 29 verbose cwd /opt/iobroker
    ! 30 error Linux 4.9.68-v7+
    ! 31 error argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker" "–unsafe-perm"
    ! 32 error node v6.12.2
    ! 33 error npm v3.10.10
    ! 34 error path /tmp/npm-905-252b49b2/unpack-4f9a642e/package.json
    ! 35 error code ENOENT
    ! 36 error errno -2
    ! 37 error syscall open
    ! 38 error enoent ENOENT: no such file or directory, open '/tmp/npm-905-252b49b2/unpack-4f9a642e/package.json'
    ! 39 error enoent ENOENT: no such file or directory, open '/tmp/npm-905-252b49b2/unpack-4f9a642e/package.json'
    ! 39 error enoent This is most likely not a problem with npm itself
    ! 39 error enoent and is related to npm not being able to find a file.
    ! 40 verbose exit [ -2, true ]
    Schöne Grüße
    • CampinoC
      CampinoC
      Campino
      hab es jetzt noch mal mit der Version 1.0.4 installiert unter ubuntu 17.10
      mit der ganz normalen Anleitung von
      http://www.iobroker.net/docu/?page_id=5106&lang=de
      diesmal ist es nach dem reboot automatisch gestartet … sieht soweit gut aus alle Adapter sind da
      das war der Code beim installieren falls es wen interessiert
      ! sudo npm install iobroker@1.0.4 --unsafe-perm ! > iobroker@1.0.4 install /opt/iobroker/node_modules/iobroker node lib/setup.js ! npm install iobroker.discovery --production --save --prefix /opt/iobroker npm install iobroker.admin --production --save --prefix /opt/iobroker npm install iobroker.js-controller --production --save --prefix /opt/iobroker npm WARN deprecated localhost.daplie.me-certificates@1.3.5: this package has been deprecated npm WARN prefer global npm@2.15.12 should be installed with -g Write "./iobroker start" to start the ioBroker Auto-start was enabled. Write "update-rc.d -f iobroker.sh remove" to disable auto-start iobroker is started. Go to "http://ip-addr:8081" to open the admin UI. /opt/iobroker └─┬ iobroker@1.0.4 └─┬ yargs@7.1.0 ├── camelcase@3.0.0 ├─┬ cliui@3.2.0 │ ├─┬ strip-ansi@3.0.1 │ │ └── ansi-regex@2.1.1 │ └── wrap-ansi@2.1.0 ├── decamelize@1.2.0 ├── get-caller-file@1.0.2 ├─┬ os-locale@1.4.0 │ └─┬ lcid@1.0.0 │ └── invert-kv@1.0.0 ├─┬ read-pkg-up@1.0.1 │ ├─┬ find-up@1.1.2 │ │ ├── path-exists@2.1.0 │ │ └─┬ pinkie-promise@2.0.1 │ │ └── pinkie@2.0.4 │ └─┬ read-pkg@1.1.0 │ ├─┬ load-json-file@1.1.0 │ │ ├── graceful-fs@4.1.11 │ │ ├─┬ parse-json@2.2.0 │ │ │ └─┬ error-ex@1.3.1 │ │ │ └── is-arrayish@0.2.1 │ │ ├── pify@2.3.0 │ │ └─┬ strip-bom@2.0.0 │ │ └── is-utf8@0.2.1 │ ├─┬ normalize-package-data@2.4.0 │ │ ├── hosted-git-info@2.5.0 │ │ ├─┬ is-builtin-module@1.0.0 │ │ │ └── builtin-modules@1.1.1 │ │ ├── semver@5.4.1 │ │ └─┬ validate-npm-package-license@3.0.1 │ │ ├─┬ spdx-correct@1.0.2 │ │ │ └── spdx-license-ids@1.2.2 │ │ └── spdx-expression-parse@1.0.4 │ └── path-type@1.1.0 ├── require-directory@2.1.1 ├── require-main-filename@1.0.1 ├── set-blocking@2.0.0 ├─┬ string-width@1.0.2 │ ├── code-point-at@1.1.0 │ └─┬ is-fullwidth-code-point@1.0.0 │ └── number-is-nan@1.0.1 ├── which-module@1.0.0 ├── y18n@3.2.1 └── yargs-parser@5.0.0 ! npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json' npm WARN iobroker No description npm WARN iobroker No repository field. npm WARN iobroker No README data npm WARN iobroker No license field. !
      danke noch mal an alle die es gerichtet haben
      mfg Campino
      • S
        S
        sammartin8935
        @chrram:
        hallo habe iobroker auf debien Stretch x64 installiert wenn ich es manuel starte funktioniert es ,
        aber bei einen neu start muss ich es auch wieder per Hand starten. habe sogar iobroker per root instaliert .woran könnte es liegen?
        wenn ich eingebe kommt
        sudo systemctl status iobroker.service
        ● iobroker.service - LSB: starts ioBroker
        Loaded: loaded (/etc/init.d/iobroker.sh; generated; vendor preset: enabled)
        Active: inactive (dead)
        Docs: man:systemd-sysv-generator(8)
        Danach habe starte iobroker immer noch nicht erst mit einen iobroker start
        node -v
        v4.8.7
        npm -v
        2.15.11
        #!/bin/bash
        ### BEGIN INIT INFO
        # Provides:          iobroker.sh
        # Required-Start:    $network $local_fs $remote_fs
        # Required-Stop::    $network $local_fs $remote_fs
        # Default-Start:     2 3 4 5
        # Default-Stop:      0 1 6
        # Short-Description: starts ioBroker
        # Description:       starts ioBroker
        ### END INIT INFO
        (( EUID )) && echo .You need to have root privileges.. && exit 1
        PIDF=/opt/iobroker/node_modules/iobroker.js-controller/lib/iobroker.pid
        NODECMD=@@node
        IOBROKERCMD=/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
        RETVAL=0
        IOBROKERUSER=@@user
        start() {
                    export IOBROKER_HOME=/opt/iobroker
                    echo -n "Starting ioBroker"
                    sudo -u ${IOBROKERUSER} $NODECMD $IOBROKERCMD start
                    RETVAL=$?
        stop() {
                    echo -n "Stopping ioBroker"
                    sudo -u ${IOBROKERUSER} $NODECMD $IOBROKERCMD stop
                    RETVAL=$?
        case "$1" in
            start)
              start
            stop)
              stop
            restart)
              stop
              start
              echo "Usage: iobroker {start|stop|restart}"
              exit 1
        esac
        exit $RETVAL
        Dies könnte helfen:
        https://support.ivacy.com/kb/setup-vpn-on-debian-linux/
        • M
          M
          mguenther
          sorry, dass ich hier den alten Thread hochhole…
          Ich hatte ne alte node und npm Version auf meinem PI und mir wurde geraten, diese zu aktualisieren. Ich muss dazu sagen, dass ich mich mit Linux so gut wie nicht auskenne...
          Anleitung war gemäß:
          http://www.iobroker.net/docu/?page_id=8 ... ion_Nodejs
          habe jetzt node und nodejs 8.15 und npm 6.4.1
          seit dem startet bei mir iobroker aber nicht mehr automatisch. Über Konsoleneingabe "iobroker start" startet bei mir iobroker über die Weboberfläche.
          Ich habe daraufhin gesucht und u.a. diesen Thread gefunden. Ich habe alles gelesen, einiges ausprobiert, von Homoran die https://forum.iobroker.net/viewtopic.php?p=108996#p108996 hochgeladen, aber es startet nicht automatisch. Ich fürchte beim Wandeln von Windows zu Linux hat etwas nicht geklappt.
          ich bekomme die folgenden Infos:
          pi@raspberrypi:/etc/init.d $ ls -l iobroker.sh
          -rwxrwxrwx 1 root root 1014 Jan 2 04:41 iobroker.sh
          pi@raspberrypi:/etc/init.d $ sudo ./iobroker.sh start
          Starting ioBrokersudo: /usr/bin/node: Befehl nicht gefunden
          was kann das sein? Was kann ich machen?
          EDIT:
          habe gerade festgestellt, dass ich den Ordner "/usr/bin/node" gar nicht habe. Die anderen Pfadangaben aus der Datei stimmen.
          NODECMD=/usr/bin/node
          • paul53P
            paul53P
            #66
            @mguenther:
            habe gerade festgestellt, dass ich den Ordner "/usr/bin/node" gar nicht habe `
            Das muss eine ausführbare Datei oder ein Symlink sein. Was ergibt ?
            which node
            Produktiv: Asus PN42: N100 / 8 GB / 500 GB; Proxmox mit 2 VM (ioBroker / openCCU)
            • AlCalzoneA
              AlCalzoneA
              AlCalzone
              #67
              @mguenther:
              habe jetzt node und nodejs 8.15 und npm 6.4.1 `
              Wenn du tatsächlich nach dieser Anleitung installierst hast, sollte es auch keinen Eintrag in /etc/init.d geben - Die Installation nutzt jetzt systemd, daher sollte in /etc/systemd/system/ eine Datei iobroker.service existieren.
              Was sagt
              • M
                M
                mguenther
                #68
                hallo ihr 2,
                was habe ich eben gemacht? "sudo reboot" und dann den folgenden Screenshot:
                • M
                  M
                  mguenther
                  #69
                  @AlCalzone:
                  da liegt aber keine Datei iobroker.service…
                  ich habe das update gemäß dieser Anleitung von der Homepage gemacht:
                  ! Installation Node.js
                  ! System-Update: sudo apt-get update && sudo apt-get upgrade
                  ! Je nach verwendetem OS kann das Update auch mittels: sudo apt update && sudo apt upgrade ausgeführt werden
                  ! Auf bereits vorhandene Versionen von nodejs und npm testen.
                  ! node -v
                  ! nodejs -v
                  ! npm -v
                  ! nur wenn ALLE diese Befehle kein Ergebnis bringen (also keine Versionsnummer mehr anzeigen) mit Schritt 4. dieses Abschnittes weitermachen, sonst
                  ! Die alten node & node.js Versionen deinstallieren
                  ! sudo apt-get –purge remove node
                  ! sudo apt-get --purge remove nodejs
                  ! sudo apt-get autoremove
                  ! sudo reboot
                  ! Node.js neu installieren nur für Raspberry Pi1 (sollte es beim download zu einer Fehlermeldung kommen, bitte unter http://nodejs.org/dist/latest-v8.x/ die aktuelle Versionsnummer heraussuchen und in den Befehlen 1-3 ersetzen)
                  ! wget http://nodejs.org/dist/latest-v8.x/node ... v6l.tar.gz
                  ! tar -xvf node-v8.11.3-linux-armv6l.tar.gz
                  ! cd node-v8.11.3-linux-armv6l
                  ! sudo cp -R * /usr/local/
                  ! sudo ln -s /usr/local/bin/node /usr/bin/nodejs
                  ! Nach der Installation müssen das Kommandos “node -v” und “nodejs -v” die gleiche Versionsnummer zurückgeben.
                  ! Falls “node -v” eine Fehlermeldung wie “nicht gefunden” erzeugt, dann bitte ein sudo ln -s /usr/local/bin/nodejs /usr/bin/node an der Konsole ausführen.
                  ! Sind die Versionen unterschiedlich, bitte nochmals den Abschnitt “Installation Node.js” abarbeiten
                  ! Als letzte Überprüfung bitte noch die Version von npm mittels npm -v überprüfen.
                  ! Ergibt dies eine Version < 6, bitte noch mit sudo npm install -g npm@6 ein npm-Update durchführen
                  • M
                    M
                    mguenther
                    #70
                    Also, nachdem ich nun in die Datei von Homoran bei nodecmd den Pfad in "/etc/local/bin/node" geändert habe, startet iobroker auch nach reboot automatisch auf der weboberfläche. Das geht zumindest.
                    Hier der neue Screenshot für das 2. Problem:
                    danke
                    • paul53P
                      paul53P
                      #71
                      which node
                      zeigt, dass node in das Verzeichnis /usr/local/bin installiert wurde. Die Fehlermeldungen zeigen, dass /usr/bin/node nicht existiert. Deshalb erzeuge einen Symlink in /usr/bin:
                      Evtl. mit sudo davor.
                      • AlCalzoneA
                        AlCalzoneA
                        AlCalzone
                        #72
                        @mguenther:
                        ich habe das update gemäß dieser Anleitung von der Homepage gemacht: `
                        Du meinst diesen Abschnitt, oder?
                        ` > Installation ioBroker
                        ioBroker installieren. Die Installation kann mit dem User pi aber auch mit dem User root erfolgen
                        An der Konsole dann
                        curl -sL https://raw.githubusercontent.com/ioBro … staller.sh | bash -
                        ausführen
                        Die Installation erfolgt in 4 Schritten:
                        Creating ioBroker directory (1/4)
                        Downloading installation files (2/4)
                        Installing ioBroker (3/4)
                        Finalizing installation (4/4)
                        Zum Abschluss kommt dann noch die Meldung
                        ioBroker was installed successfully
                        Open http://localhost:8081 in a browser and start configuring!
                        ioBroker nun über IP im Webbrowser aufrufen: http://IP-Adresse:8081 `
                        • M
                          M
                          mguenther
                          #73
                          @AlCalzone:
                          @mguenther:
                          An der Konsole dann
                          ausführen
                          äh.. ne, ich habe "nur" node und npm aktualisiert mit dem Abschnitt zuvor. Muss ich dann noch einmal iobroker "neu" installieren, wenn ich etwas aktualisiere? War mir so nicht bewusst..
                          Ich gehe davon aus, dass die Einstellungen dann auch weg sind?
                          • M
                            M
                            mguenther
                            #74
                            @paul53:
                            which node
                            Evtl. mit sudo davor. `
                            danke Paul - wie sooft. Hab den Pfad in der Datei wieder auf den ursprünglichen Pfad geändert und es geht
                            • AlCalzoneA
                              AlCalzoneA
                              AlCalzone
                              #75
                              @mguenther:
                              äh.. ne, ich habe "nur" node und npm aktualisiert mit dem Abschnitt zuvor. `
                              Ok sorry, ich habe nur überflogen. Ich bin davon ausgegangen, dass du nach der Anleitung installiert hast. In dem Fall kann es durchaus auch sein, dass du noch Dateien in /etc/init.d/ hast.
                              Ich dachte schon das ist ein Problem mit der neuen Routine - ignorier einfach alles was ich hier geschrieben habe.
                              • paul53P
                                paul53P
                                #76
                                @mguenther:
                                @mguenther:
                                Muss ich dann noch einmal iobroker "neu" installieren, wenn ich etwas aktualisiere? `
                                Welche Node-Version lief vor dem Update ? Falls kleiner 8.x (4.x, 6.x) <u>und</u> der ein oder andere Adapter Probleme macht, sollte
                                cd /opt/iobroker
                                sudo ./reinstall.sh
                                ausgeführt werden (ackert eine Weile).
                                • M
                                  M
                                  mguenther
                                  #77
                                  @AlCalzone:
                                  @mguenther:
                                  Ich dachte schon das ist ein Problem mit der neuen Routine - ignorier einfach alles was ich hier geschrieben habe. `
                                  ok, auch dir vielen Dank
                                  macht es denn aber Sinn, iobroker jetzt noch einmal drüber zu installieren und nen großes backup mit dem backitup Adapter wieder einzuspielen?
                                  • M
                                    M
                                    mguenther
                                    #78
                                    @paul53:
                                    @mguenther:
                                    @mguenther:
                                    Welche Node-Version lief vor dem Update ? Falls kleiner 8.x <u>und</u> der ein oder andere Adapter Probleme macht, sollte
                                    cd /opt/iobroker
                                    sudo ./reinstall.sh
                                    ausgeführt werden (ackert eine Weile). `
                                    hatte ich gemacht - bei mir macht momentan nur Cloud Adapter momentan komische Dinge, die ich noch nicht verstanden habe, Rest funktioniert wie vorher
                                    • paul53P
                                      paul53P
                                      #79
                                      @mguenther:
                                      macht es denn aber Sinn, iobroker jetzt noch einmal drüber zu installieren `
                                      Nein. Reinstall hat das erledigt.
                                      • M
                                        M
                                        mguenther
                                        #80
                                        @paul53:
                                        @mguenther:
                                        macht es denn aber Sinn, iobroker jetzt noch einmal drüber zu installieren Nein. Reinstall hat das erledigt.
                                        hat dann aber zur Konsequenz, dass ich in irgendwelchen Ordnern noch Dateien haben, die da nicht mehr hingehören… aber es gibt ja das Forum :)
                                        danke euch
                                        • AlCalzoneA
                                          AlCalzoneA
                                          AlCalzone
                                          #81
                                          @mguenther:
                                          macht es denn aber Sinn, iobroker jetzt noch einmal drüber zu installieren und nen großes backup mit dem backitup Adapter wieder einzuspielen? `
                                          Wie sagt man so schön… never change a running system.
                                          84.2k
