  4. Proxmox Installation und Zigbee Stick
83 Beiträge 13 Kommentatoren 23.0k Aufrufe 11 Beobachtet
  • R Offline
    Rogni
    "dsmeg" Kommando wird nicht gefunden….grrrr wohl Paket nicht installiert, nu kann ich erstmal lesen wie ich das unter Debian reinbring
    Danke erstmal
    edit
    Uha Vertipper drin ;) wird wohl Display Message sein ....DMESG
    Erik :mrgreen: :mrgreen:
    • R Offline
      Rogni
      Mag er auch nicht
      "no Such File or directory"
      muss ich auf morgen oder übermorgen vertagen, muss nu noch duschen und dann in die Spätschicht :)
      Ein Teil der Ausgabe von dmesg :
      [    3.549189] usb 3-1: New USB device found, idVendor=0451, idProduct=16a8
      [    3.549191] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
      [    3.549192] usb 3-1: Product: TI CC2531 USB CDC
      [    3.549194] usb 3-1: Manufacturer: Texas Instruments
      [    3.549195] usb 3-1: SerialNumber: __0X00124B0014D9D8FF
      [    3.631868] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
      [    3.654789] systemd-journald[441]: Received request to flush runtime journal from PID 1
      [    3.737159] cdc_acm 3-1:1.0: ttyACM0: USB ACM device
      [    3.739342] usbcore: registered new interface driver cdc_acm
      [    3.739344] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
      [    3.742528] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input5
      [    3.742532] ACPI: Power Button [PWRF]
      [    3.836599] sd 0:0:0:0: Attached scsi generic sg0 type 0
      [    3.836633] sr 2:0:0:0: Attached scsi generic sg1 type 5
      [    3.836969] input: PC Speaker as /devices/platform/pcspkr/input/input6
      [    3.890603] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
      [    3.904643] [drm] Initialized
      [    3.922662] [drm] Found bochs VGA, ID 0xb0c0.
      [    3.922663] [drm] Framebuffer size 16384 kB @ 0xfd000000, mmio @ 0xfea50000.
      [    3.922726] [TTM] Zone  kernel: Available graphics memory: 2025352 kiB
      [    3.922727] [TTM] Initializing pool allocator
      [    3.922731] [TTM] Initializing DMA pool allocator
      [    3.924303] fbcon: bochsdrmfb (fb0) is primary device
      [    3.939076] Console: switching to colour frame buffer device 128x48
      [    3.940681] bochs-drm 0000:00:02.0: fb0: bochsdrmfb frame buffer device
      [    3.958582] [drm] Initialized bochs-drm 1.0.0 20130925 for 0000:00:02.0 on minor 0
      [    4.088440] Adding 4192252k swap on /dev/sda5\.  Priority:-1 extents:1 across:4192252k FS
      [    7.504354] random: crng init done
      [    7.504356] random: 7 urandom warning(s) missed due to ratelimiting
      [ 1922.954958] usb 3-1: USB disconnect, device number 2
      [ 1927.882585] usb 3-1: new full-speed USB device number 3 using uhci_hcd
      [ 1928.328927] usb 3-1: New USB device found, idVendor=0451, idProduct=16a8
      [ 1928.328930] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
      [ 1928.328931] usb 3-1: Product: TI CC2531 USB CDC
      [ 1928.328933] usb 3-1: Manufacturer: Texas Instruments
      [ 1928.328934] usb 3-1: SerialNumber: __0X00124B0014D9D8FF
      [ 1928.331525] cdc_acm 3-1:1.0: ttyACM0: USB ACM device
      das noch schnell versucht, war leider auch nix, wieder permission denied
        mafe68
        Hast du auch deinen Stick in die VM oder LXC Container durchgereicht? Da sonst wird das nicht gehen. Ich habe hier ioBroker in einem LXC Container laufen mit dem Zigbee Stick und da musst du aber vorher in der Container config das eintragen. Bei der VM wird es nicht anderes sein.
        LG. Mario
        ioBroker LXC Container Proxmox
        ioBroker BananaPi M1
        • R Offline
          Rogni
          Habe ihn unter hardware im web frontend durchgereicht. Port 1-3
          Ausgabe lsusb
           lsusb -t
          /:  Bus 05.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M
          /:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M
          /:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M
              |__ Port 1: Dev 3, If 0, Class=Communications, Driver=cdc_acm, 12M
              |__ Port 1: Dev 3, If 1, Class=CDC Data, Driver=cdc_acm, 12M
          /:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/6p, 480M
          /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M
              |__ Port 1: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 12M
            mafe68
            Sonst schaue mal hier: https://pve.proxmox.com/wiki/USB_Device … l_Machines Da wird es erklärt was du machen musst.
            Welchen Eintrag hast du in ioBroker gemacht im ZigBee Adapter bei Einstellungen? Versuche mal den Eintrag /dev//dev/ttyACM0 und schaue ob er dann grün wird.
            Sehe gerade das die rechte nicht passen vom Stick. Mach auf der Konsole mal den Befehl
            chmod o+rw /dev/ttyACM0
            aber mit gestoppter VM und dann starte die VM verbinde dich damit und gehe in den Ordner /dev
            cd /dev
            # dann mach ein
            ls
            # und schaue ob der ttyACM0 angezeit wird
            Dann müsste es gehen.
            LG. Mario
            • R Offline
              Rogni
              Danke Dir, werde ich morgen testen, werde mich dann melden ;)
              Erik
              • Schuko80S Offline
                Schuko80S Offline
                Schuko80
                @mafe68:
                Hast du auch deinen Stick in die VM oder LXC Container durchgereicht? Da sonst wird das nicht gehen. Ich habe hier ioBroker in einem LXC Container laufen mit dem Zigbee Stick und da musst du aber vorher in der Container config das eintragen. Bei der VM wird es nicht anderes sein. `
                Bei einer Vm geht es wohl über die Webfront, bei LXC muss es über die Config gemacht werden.
                Zu empfehlen ist es, einen Alias auf das Gerät anzulegen, wenn man mehr wie einen Stick nutzt, kann es nach dem Neubooten sonst ein böses erwachen geben, dann sind die Ports nämlich evtl. vertauscht worden
                Nuc6cayh + Proxmox / Zigbee (Deconz / Conbee I ) / ZWave / Homematic (CCU2)
                • R Offline
                  Rogni
                  alles gemacht, aber immer noch permission denied.
                  Ausgabe ls auf IObroker (ttyACM0 wird angezeigt):
                  autofs           cuse     hugepages         mqueue              random  shm       tty10  tty2   tty29  tty38  tty47  tty56  tty8     vcs    vcsa3
                  block            disk     initctl           net                 rtc     snapshot  tty11  tty20  tty3   tty39  tty48  tty57  tty9     vcs1   vcsa4
                  bsg              dri      input             network_latency     rtc0    snd       tty12  tty21  tty30  tty4   tty49  tty58  ttyACM0  vcs2   vcsa5
                  btrfs-control    dvd      kmsg              network_throughput  sda     sr0       tty13  tty22  tty31  tty40  tty5   tty59  ttyS0    vcs3   vcsa6
                  bus              fb0      log               null                sda1    stderr    tty14  tty23  tty32  tty41  tty50  tty6   ttyS1    vcs4   vfio
                  cdrom            fd       loop-control      port                sda2    stdin     tty15  tty24  tty33  tty42  tty51  tty60  ttyS2    vcs5   vga_arbiter
                  char             full     mapper            ppp                 sda5    stdout    tty16  tty25  tty34  tty43  tty52  tty61  ttyS3    vcs6   vhci
                  console          fuse     mcelog            psaux               serial  tty       tty17  tty26  tty35  tty44  tty53  tty62  uhid     vcsa   vhost-net
                  core             hidraw0  mem               ptmx                sg0     tty0      tty18  tty27  tty36  tty45  tty54  tty63  uinput   vcsa1  zero
                  cpu_dma_latency  hpet     memory_bandwidth  pts                 sg1     tty1      tty19  tty28  tty37  tty46  tty55  tty7   urandom  vcsa2
                  Erik
                  • DutchmanD Offline
                    DutchmanD Offline
                    Dutchman
                    Unter welchen User hast du ioBroker installiert und nach welcher Anleitung?
                    • R Offline
                      Rogni
                      Ausgabe qm monitor 100 -> usbinfo und ls usb
                       Bus 1, Addr 2, Port 8, Speed 12 Mb/s
                          Class e0: USB device 8087:0a2b
                        Bus 1, Addr 4, Port 3, Speed 12 Mb/s
                          Class 02: USB device 0451:16a8, TI CC2531 USB CDC
                      Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                      Bus 001 Device 002: ID 8087:0a2b Intel Corp.
                      Bus 001 Device 004: ID 0451:16a8 Texas Instruments, Inc.
                      dann
                      qm set 100 -usb0 host=0451:16a8
                      ausgeführt, VM neu gestartet und wieder Permission denied
                      im Proxmox sieht das nun so aus:
                      • R Offline
                        Rogni
                        Proxmox Image heruntergeladen , installiert und auf dem Proxmox eine VM gestartet (Debian Image unter Iso abgelegtund installiert)….. keine Anleitung
                        root@iobroker:~# ls -l /home
                        insgesamt 4
                        drwxr-xr-x 5 iobroker iobroker 4096 Dez 16 15:24 iobroker
                        • DutchmanD Offline
                          DutchmanD Offline
                          Dutchman
                          Deine iobroker installation sieht nicht sauber aus ?
                          Es steht im falschen Verzeichnis, Home anstatt /opt/ioBroker eventuell sind noch mehr Sachen faul.
                          Ich würde dir empfehlen die Installation erneut laut Anleitung aus zu führen damit sollte sowohl die richtigen Ordner Strukturen als Zugriffsrechte erstellt werden.
                          • R Offline
                            Rogni
                            ?? das verstehe ich nu gar nicht?? Bin nicht der Linux Crack und noch am Anfang…..
                            Verzeichnis opt/iobroker ist doch alles drin und vorhanden??
                            iobroker@iobroker:~$ cd /opt
                            iobroker@iobroker:/opt$ cd iobroker
                            iobroker@iobroker:/opt/iobroker$ ls
                            backups  iobroker       lib      node_modules       README.md
                            install  iobroker-data  LICENSE  package.json       reinstall.sh
                            iob      killall.sh     log      package-lock.json
                            Ausgabe von groups:
                            iobroker@iobroker:/opt/iobroker$ groups
                            iobroker cdrom floppy audio dip video plugdev netdev
                            hier nochmal der ls Befehl, mit /home war nur um Rechte von User IObroker zu sehen oder liege ich da falsch??
                            iobroker@iobroker:/opt/iobroker$ ls -l /opt/iobroker
                            insgesamt 236
                            drwxr-xr-x   2 iobroker iobroker   4096 Dez 16 15:19 backups
                            drwxr-xr-x   5 iobroker root       4096 Dez 16 14:47 install
                            -rwxr-xr-x   1 iobroker root         67 Dez 16 14:48 iob
                            -rwxr-xr-x   1 iobroker root         67 Dez 16 14:48 iobroker
                            drwxr-xr-x   7 iobroker root       4096 Dez 18 16:11 iobroker-data
                            -rw-r--r--   1 iobroker root         92 Dez 16 14:47 killall.sh
                            drwxr-xr-x   2 iobroker root       4096 Dez 16 14:47 lib
                            -rw-r--r--   1 iobroker root       1137 Dez 16 14:47 LICENSE
                            drwxr-xr-x   2 iobroker root       4096 Dez 20 00:05 log
                            drwxr-xr-x 703 iobroker root      20480 Dez 20 11:18 node_modules
                            -rw-r--r--   1 iobroker iobroker   1596 Dez 20 11:18 package.json
                            -rw-r--r--   1 iobroker root     164906 Dez 16 14:48 package-lock.json
                            -rw-r--r--   1 iobroker root       6101 Dez 16 14:47 README.md
                            -rw-r--r--   1 iobroker root        709 Dez 16 14:47 reinstall.sh
                            noch schnell adduser iobroker sudo ausgeführt um iobroker in diese Gruppe zu holen, hat auch nix gebracht, muß nu mal wieder Brötchen verdienen, morgen gehts weiter…. Danke nochmal an alle.
                            • R Offline
                              Rogni
                              Also ich bekomms net hin auch bein Nano Cul permission denied, ich seh vor lauter Wald keine Bäume mehr…...............................SOS
                              • DutchmanD Offline
                                DutchmanD Offline
                                Dutchman
                                Pff Ehm könntest du Mal in TS vorbei schauen dann gucken wir zusammen
                                  mafe68
                                  Wenn du möchtest kann ich dir einen LXC Container zur Verfügung stellen mit installieren iobroker!
                                  LG. Mario
                                  • R Offline
                                    Rogni
                                    Denke erstmal für die Angebote, ich möchte ja gerne meinen Fehler verstehen ;)
                                    @Dutchman vorbeikomen wo ??
                                    Erik
                                    PeoplesP 1 Antwort Letzte Antwort
                                    • F Offline
                                      Flauschi
                                      mach mal im /opt/iobroker
                                      iobroker stop
                                      und danach nochmal
                                      sudo iobroker start
                                      das gleiche hab ich auch, weil ich auf den VMs nicht root verwende sondern einen user (der zwar volle rechte hat…dennoch gehts nur so)
                                        mafe68
                                        Ja kein Problem war nur ein Angebot
                                        TS -> Team Speaker ;)
                                        LG. Mario
                                        • R Offline
                                          Rogni
                                          ahhhh Team Speak ;)) nu hab ichs gerafft, wenn ich gar nix mehr hinbekomm würde ich mich nochmal melden, vielen Dank
                                          Erik
